Error building the (new) Serial Modem
When following through the process described on GitHub for the NCS_SERIAL_MODEM I get an error during the build. I am following the steps described in the readme exactly as indicated.
https://github.com/nrfconnect/ncs-serial-modem
Error message is...
C:/GTdev/Nordic/serial_modem/project/app/build/mcuboot/zephyr/.config.sysbuild:38: warning: attempt to assign the value 'n' to the undefined symbol BOOT_RAM_LOAD_REVERTLoaded configuration 'C:/ncs/v3.1.1/zephyr/boards/nordic/nrf9151dk/nrf9151dk_nrf9151_defconfig'
I know this is early code, but since Serial LTE Modem is slated for EOL I wanted to move forward with my testing.
Thank you,
Greg
  • PS C:\GTdev\Nordic\serial_modem\project\app> west build -p -b nrf9151dk/nrf9151/ns
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: C:/ncs/toolchains/c1a76fddb2/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v3.1.1/zephyr/.cache
    -- Found west (found suitable version "1.4.0", minimum required is "0.14.0")
    -- Board: nrf9151dk, qualifiers: nrf9151/ns
    Parsing C:/GTdev/Nordic/serial_modem/zephyr/share/sysbuild/Kconfig
    Loaded configuration 'C:/GTdev/Nordic/serial_modem/project/app/build/_sysbuild/empty.conf'
    Merged configuration 'C:/GTdev/Nordic/serial_modem/project/app/sysbuild.conf'
    Configuration saved to 'C:/GTdev/Nordic/serial_modem/project/app/build/zephyr/.config'
    Kconfig header saved to 'C:/GTdev/Nordic/serial_modem/project/app/build/_sysbuild/autoconf.h'
    * Running CMake for mcuboot *
    -- Application: C:/ncs/v3.1.1/bootloader/mcuboot/boot/zephyr
    -- CMake version: 3.21.0
    -- Zephyr version: 4.1.99 (C:/ncs/v3.1.1/zephyr)
    -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/c1a76fddb2/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/c1a76fddb2/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/c1a76fddb2/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v3.1.1/zephyr/boards/nordic/nrf9151dk/nrf9151dk_nrf9151.dts
    -- Found devicetree overlay: C:/GTdev/Nordic/serial_modem/project/app/sysbuild/mcuboot/app.overlay
    -- Generated zephyr.dts: C:/GTdev/Nordic/serial_modem/project/app/build/mcuboot/zephyr/zephyr.dts
    -- Generated pickled edt: C:/GTdev/Nordic/serial_modem/project/app/build/mcuboot/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/GTdev/Nordic/serial_modem/project/app/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    Parsing C:/ncs/v3.1.1/bootloader/mcuboot/boot/zephyr/Kconfig
    Merged configuration 'C:/GTdev/Nordic/serial_modem/project/app/sysbuild/mcuboot/prj.conf'
    Merged configuration 'C:/ncs/v3.1.1/nrf/modules/mcuboot/tfm.conf'
    Merged configuration 'C:/GTdev/Nordic/serial_modem/project/app/build/mcuboot/zephyr/.config.sysbuild'
    error: Aborting due to Kconfig warnings
    CMake Error at C:/ncs/v3.1.1/zephyr/cmake/modules/kconfig.cmake:377 (message):
    command failed with return code: 1
    C:/ncs/v3.1.1/nrf/cmake/modules/kconfig.cmake:83 (include)
    C:/ncs/v3.1.1/zephyr/cmake/modules/zephyr_default.cmake:131 (include)
    C:/ncs/v3.1.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
    C:/ncs/v3.1.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
    CMakeLists.txt:18 (find_package)
    CMake Error at cmake/modules/sysbuild_extensions.cmake:530 (message):
    CMake configure failed for Zephyr project: mcuboot
    Location: C:/ncs/v3.1.1/bootloader/mcuboot/boot/zephyr/
    cmake/modules/sysbuild_images.cmake:43 (ExternalZephyrProject_Cmake)
    cmake/modules/sysbuild_default.cmake:21 (include)
    C:/GTdev/Nordic/serial_modem/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
    C:/GTdev/Nordic/serial_modem/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
    C:/GTdev/Nordic/serial_modem/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
    template/CMakeLists.txt:10 (find_package)
    See also "C:/GTdev/Nordic/serial_modem/project/app/build/CMakeFiles/CMakeOutput.log".
    ←[91mFATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c1a76fddb2\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/c1a76fddb2/opt/bin/python.exe '-BC:\GTdev\Nordic\serial_modem\project\app\build' -GNinja -DBOARD=nrf9151dk/nrf9151/ns '-SC:\GTdev\Nordic\serial_modem\zephyr\share\sysbuild' '-DAPP_DIR:PATH=C:\GTdev\Nordic\serial_modem\project\app'
    ←[0m
  • Hi Greg,
    I have tested building serial_modem sample and build succeeded. Before running "west build" command, you can try to open the terminal in NCS v3.1.0 using nrfutil
    nrfutil sdk-manager toolchain launch --ncs-version v3.1.0 --terminal
    Dejan
  • I tried launching the external terminal as you describe without sucssess.
    Microsoft Windows [Version 10.0.26200.6899]
    (c) Microsoft Corporation. All rights reserved.
    (v3.1.0) C:\GTdev\Nordic\serial_modem\project\app> west build -p -b nrf9151dk/nrf9151/ns
    -- west build: making build dir C:\GTdev\Nordic\serial_modem\project\app\build pristine
    -- Found Python3: C:/ncs/toolchains/b8b84efebd/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v3.1.0/zephyr/.cache
    -- Application: C:/ncs/v3.1.0/bootloader/mcuboot/boot/zephyr
    -- Zephyr version: 4.1.99 (C:/ncs/v3.1.0/zephyr)
    -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/b8b84efebd/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/b8b84efebd/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/b8b84efebd/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v3.1.0/zephyr/boards/nordic/nrf9151dk/nrf9151dk_nrf9151.dts
    Parsing C:/ncs/v3.1.0/bootloader/mcuboot/boot/zephyr/Kconfig
    C:/GTdev/Nordic/serial_modem/project/app/build/mcuboot/zephyr/.config.sysbuild:38: warning: attempt to assign the value 'n' to the undefined symbol BOOT_RAM_LOAD_REVERTLoaded configuration 'C:/ncs/v3.1.0/zephyr/boards/nordic/nrf9151dk/nrf9151dk_nrf9151_defconfig'
    Merged configuration 'C:/ncs/v3.1.0/nrf/modules/mcuboot/tfm.conf'
    CMake Error at C:/ncs/v3.1.0/zephyr/cmake/modules/kconfig.cmake:377 (message):
    C:/ncs/v3.1.0/nrf/cmake/modules/kconfig.cmake:83 (include)
    C:/ncs/v3.1.0/zephyr/cmake/modules/zephyr_default.cmake:131 (include)
    C:/ncs/v3.1.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
    C:/ncs/v3.1.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
    Location: C:/ncs/v3.1.0/bootloader/mcuboot/boot/zephyr/
    ←[91mFATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\b8b84efebd\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/b8b84efebd/opt/bin/python.exe '-BC:\GTdev\Nordic\serial_modem\project\app\build' -GNinja -DBOARD=nrf9151dk/nrf9151/ns '-SC:\GTdev\Nordic\serial_modem\zephyr\share\sysbuild' '-DAPP_DIR:PATH=C:\GTdev\Nordic\serial_modem\project\app'
    ←[0m
  • The target I am attempting to build for is the nr9151DK. When drilling down in the project files I see .conf for the thingy91x and the nrf9161DK, but no .conf or .overlay files corresponding to the nrf9151DK.
  • Hi Greg,
    Which project files have you looked into? What have you observed exactly? Can you elaborate on this?
    Dejan
