Cellular: HTTP full modem update sample not working
To preface:
  • Board: nRF9151DK
  • nRF Connect SDK / Toolchain: 3.1.0
I am attempting to learn and integrate full modem FOTA functionality into my application. To begin with, I am simply trying to run the nRF Connect SDK sample on a nRF9151DK.
Sample: https://docs.nordicsemi.com/bundle/ncs-3.1.0/page/nrf/samples/cellular/http_update/modem_full_update/README.html
I have 2 unmodified nRF9151DK kits with an active SIM. Running this sample on both of them outputs the following errors:
*** Booting nRF Connect SDK v3.1.0-6c6e5b32496e ***
*** Using Zephyr OS v4.1.99-1612683d4010 ***
HTTP full modem update sample started
uart:~$ Current modem firmware version: mfw_nrf91x1_2.0.2
LTE Link Connecting ...
LTE Link Connected!
Press Button 1 or enter 'download' to download firmware update
Press Button 2 or enter 'apply' to apply modem firmware update from flash
download
uart:~$ W: Protocol not specified for nrfconnectsdk.s3.eu-central-1.amazonaws.com/fmfu_2.0.0.cbor, attempting http://
I: Failed to resolve hostname nrfconnectsdk.s3.eu-central-1.amazonaws.com on IPv6, err -2
I: Host lookup failed for hostname nrfconnectsdk.s3.eu-central-1.amazonaws.com on IPv6 (err -118), attempting IPv4
I: Connecting to 3.5.136.212
I: Downloaded 516/2114441 bytes (0%)
E: Size is incorrect
E: stream_flash_init failed (err -14)
E: dfu_target_stream_init failed -14
E: dfu_target_init error -14
Received error from fota_download
I: Connecting to 52.219.140.181
I: Downloaded 708/2114441 bytes (0%)
E: stream_flash_buffered_write error -12
E: dfu_target_write error -12
It looks like the sample reverts to IPV4, the download starts, and then fails with the above errors. Does this sample not work out of the box, or is there something I am supposed to configure for it to work?
Derek
  • After stepping through the SDK, I resolved the issue but would like Nordic to explain if this sample is expected to work out of the box (I would expect it to like every other sample).
    I had to make the following changes
    1. Add the item below in boards/nrf9151dk_nrf9151_ns.overlay to point the partition manager to the external flash.
        chosen {
    		nordic,pm-ext-flash = &gd25wb256;
    2. Add the Kconfig below to prj.conf:
    CONFIG_FLASH_MAP=y
    Pristine build the entire project and program the board. The log output will now look like the following:
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2025.11.03 17:29:38 =~=~=~=~=~=~=~=~=~=~=~=
    LTE Link Connected!
    download
    I: Connecting to 52.219.169.214
    I: Downloaded 1416/2114441 bytes (0%)
    I: Downloaded 2124/2114441 bytes (0%)
    I: Downloaded 2832/2114441 bytes (0%)
    I: Downloaded 3540/2114441 bytes (0%)
    I: Downloaded 4248/2114441 bytes (0%)
    I: Downloaded 6296/2114441 bytes (0%)
    I: Downloaded 8344/2114441 bytes (0%)
    I: Downloaded 10392/2114441 bytes (0%)
    I: Downloaded 12440/2114441 bytes (0%)
    I: Downloaded 12668/2114441 bytes (0%)
    I: Downloaded 13692/2114441 bytes (0%)
    I: Downloaded 14716/2114441 bytes (0%)
    I: Downloaded 15424/2114441 bytes (0%)
    I: Downloaded 16992/2114441 bytes (0%)
    I: Downloaded 17700/2114441 bytes (0%)
    I: Downloaded 18408/2114441 bytes (0%)
    I: Downloaded 19116/2114441 bytes (0%)
    I: Downloaded 19824/2114441 bytes (0%)
    I: Downloaded 20532/2114441 bytes (0%)
    I: Downloaded 21240/2114441 bytes (1%)
    I: Downloaded 21948/2114441 bytes (1%)
    I: Downloaded 22656/2114441 bytes (1%)
    I: Downloaded 23364/2114441 bytes (1%)
    I: Downloaded 24072/2114441 bytes (1%)
    I: Downloaded 24780/2114441 bytes (1%)
    I: Downloaded 25488/2114441 bytes (1%)
    I: Downloaded 26196/2114441 bytes (1%)
    I: Downloaded 26904/2114441 bytes (1%)
    I: Downloaded 27612/2114441 bytes (1%)
    I: Downloaded 28320/2114441 bytes (1%)
    I: Downloaded 29028/2114441 bytes (1%)
    I: Downloaded 29736/2114441 bytes (1%)
    I: Downloaded 30444/2114441 bytes (1%)
    I: Downloaded 31152/2114441 bytes (1%)
    I: Downloaded 31860/2114441 bytes (1%)
    I: Downloaded 32568/2114441 bytes (1%)
    I: Downloaded 33276/2114441 bytes (1%)
    I: Downloaded 33984/2114441 bytes (1%)
    I: Downloaded 34692/2114441 bytes (1%)
    I: Downloaded 35400/2114441 bytes (1%)
    I: Downloaded 36108/2114441 bytes (1%)
    I: Downloaded 36816/2114441 bytes (1%)
    I: Downloaded 37524/2114441 bytes (1%)
    I: Downloaded 38232/2114441 bytes (1%)
    I: Downloaded 38940/2114441 bytes (1%)
    I: Downloaded 39648/2114441 bytes (1%)
    I: Downloaded 40356/2114441 bytes (1%)
    I: Downloaded 41064/2114441 bytes (1%)
    I: Downloaded 41772/2114441 bytes (1%)
    I: Downloaded 42480/2114441 bytes (2%)
    I: Downloaded 43188/2114441 bytes (2%)
    I: Downloaded 43896/2114441 bytes (2%)
    I: Downloaded 44604/2114441 bytes (2%)
    I: Downloaded 45312/2114441 bytes (2%)
    I: Downloaded 46020/2114441 bytes (2%)
    I: Downloaded 46728/2114441 bytes (2%)
    I: Downloaded 47436/2114441 bytes (2%)
    I: Downloaded 48144/2114441 bytes (2%)
    I: Downloaded 48852/2114441 bytes (2%)
    I: Downloaded 49560/2114441 bytes (2%)
    I: Downloaded 50268/2114441 bytes (2%)
    I: Downloaded 50976/2114441 bytes (2%)
    I: Downloaded 51684/2114441 bytes (2%)
    I: Downloaded 52392/2114441 bytes (2%)
    I: Downloaded 53100/2114441 bytes (2%)
    I: Downloaded 53808/2114441 bytes (2%)
    I: Downloaded 54516/2114441 bytes (2%)
    I: Downloaded 55224/2114441 bytes (2%)
    I: Downloaded 55932/2114441 bytes (2%)
    I: Downloaded 56640/2114441 bytes (2%)
    I: Downloaded 57348/2114441 bytes (2%)
    I: Downloaded 58056/2114441 bytes (2%)
    I: Downloaded 58764/2114441 bytes (2%)
    I: Downloaded 59472/2114441 bytes (2%)
    I: Downloaded 60180/2114441 bytes (2%)
    I: Downloaded 60888/2114441 bytes (2%)
    I: Downloaded 61596/2114441 bytes (2%)
    I: Downloaded 62304/2114441 bytes (2%)
    I: Downloaded 63012/2114441 bytes (2%)
    I: Downloaded 63720/2114441 bytes (3%)
    I: Downloaded 64428/2114441 bytes (3%)
    I: Downloaded 65136/2114441 bytes (3%)
    I: Downloaded 65844/2114441 bytes (3%)
    I: Downloaded 66552/2114441 bytes (3%)
    I: Downloaded 67260/2114441 bytes (3%)
    I: Downloaded 67968/2114441 bytes (3%)
    I: Downloaded 68676/2114441 bytes (3%)
    I: Downloaded 69384/2114441 bytes (3%)
    I: Downloaded 70092/2114441 bytes (3%)
    I: Downloaded 72140/2114441 bytes (3%)
    I: Downloaded 74188/2114441 bytes (3%)
    I: Downloaded 76236/2114441 bytes (3%)
    I: Downloaded 77880/2114441 bytes (3%)
    I: Downloaded 79296/2114441 bytes (3%)
    I: Downloaded 80004/2114441 bytes (3%)
    I: Downloaded 81420/2114441 bytes (3%)
    I: Downloaded 82128/2114441 bytes (3%)
    I: Downloaded 82836/2114441 bytes (3%)
    I: Downloaded 84252/2114441 bytes (3%)
    I: Downloaded 84960/2114441 bytes (4%)
    I: Downloaded 85668/2114441 bytes (4%)
    I: Downloaded 86376/2114441 bytes (4%)
    I: Downloaded 87084/2114441 bytes (4%)
    I: Downloaded 87792/2114441 bytes (4%)
    I: Downloaded 88500/2114441 bytes (4%)
    I: Downloaded 89208/2114441 bytes (4%)
    I: Downloaded 89916/2114441 bytes (4%)
    I: Downloaded 90624/2114441 bytes (4%)
    I: Downloaded 91332/2114441 bytes (4%)
    I: Downloaded 92040/2114441 bytes (4%)
    I: Downloaded 92748/2114441 bytes (4%)
    I: Downloaded 93456/2114441 bytes (4%)
    I: Downloaded 94164/2114441 bytes (4%)
    I: Downloaded 94872/2114441 bytes (4%)
    I: Downloaded 95580/2114441 bytes (4%)
    I: Downloaded 96288/2114441 bytes (4%)
    I: Downloaded 96996/2114441 bytes (4%)
    I: Downloaded 97704/2114441 bytes (4%)
    I: Downloaded 98412/2114441 bytes (4%)
    I: Downloaded 99120/2114441 bytes (4%)
    I: Downloaded 99828/2114441 bytes (4%)
    I: Downloaded 100536/2114441 bytes (4%)
    I: Downloaded 101244/2114441 bytes (4%)
    I: Downloaded 101952/2114441 bytes (4%)
    I: Downloaded 102660/2114441 bytes (4%)
    I: Downloaded 103368/2114441 bytes (4%)
    I: Downloaded 104076/2114441 bytes (4%)
    I: Downloaded 104784/2114441 bytes (4%)
    I: Downloaded 105492/2114441 bytes (4%)
    I: Downloaded 106200/2114441 bytes (5%)
    I: Downloaded 106908/2114441 bytes (5%)
    I: Downloaded 107616/2114441 bytes (5%)
    I: Downloaded 108324/2114441 bytes (5%)
    I: Downloaded 109032/2114441 bytes (5%)
    I: Downloaded 109740/2114441 bytes (5%)
    I: Downloaded 110448/2114441 bytes (5%)
    I: Downloaded 111156/2114441 bytes (5%)
    I: Downloaded 111864/2114441 bytes (5%)
    I: Downloaded 112572/2114441 bytes (5%)
    I: Downloaded 113280/2114441 bytes (5%)
    I: Downloaded 113988/2114441 bytes (5%)
    I: Downloaded 114696/2114441 bytes (5%)
    I: Downloaded 115404/2114441 bytes (5%)
    I: Downloaded 116112/2114441 bytes (5%)
    I: Downloaded 116820/2114441 bytes (5%)
    I: Downloaded 117528/2114441 bytes (5%)
    I: Downloaded 118236/2114441 bytes (5%)
    I: Downloaded 118944/2114441 bytes (5%)
    I: Downloaded 119652/2114441 bytes (5%)
    I: Downloaded 120360/2114441 bytes (5%)
    I: Downloaded 121068/2114441 bytes (5%)
    I: Downloaded 121776/2114441 bytes (5%)
    I: Downloaded 122484/2114441 bytes (5%)
    I: Downloaded 123192/2114441 bytes (5%)
    I: Downloaded 123900/2114441 bytes (5%)
    I: Downloaded 124608/2114441 bytes (5%)
    I: Downloaded 125316/2114441 bytes (5%)
    I: Downloaded 126024/2114441 bytes (5%)
    I: Downloaded 126732/2114441 bytes (5%)
    I: Downloaded 127440/2114441 bytes (6%)
    I: Downloaded 128148/2114441 bytes (6%)
    I: Downloaded 128856/2114441 bytes (6%)
    I: Downloaded 129564/2114441 bytes (6%)
    I: Downloaded 130272/2114441 bytes (6%)
    I: Downloaded 130980/2114441 bytes (6%)
    I: Downloaded 131688/2114441 bytes (6%)
    I: Downloaded 132396/2114441 bytes (6%)
    I: Downloaded 133104/2114441 bytes (6%)
    I: Downloaded 133812/2114441 bytes (6%)
    I: Downloaded 134520/2114441 bytes (6%)
    I: Downloaded 135228/2114441 bytes (6%)
    I: Downloaded 137276/2114441 bytes (6%)
    I: Downloaded 139324/2114441 bytes (6%)
    I: Downloaded 141372/2114441 bytes (6%)
    I: Downloaded 143016/2114441 bytes (6%)
    I: Downloaded 143724/2114441 bytes (6%)
    I: Downloaded 144432/2114441 bytes (6%)
    I: Downloaded 145140/2114441 bytes (6%)
    I: Downloaded 145848/2114441 bytes (6%)
    I: Downloaded 146556/2114441 bytes (6%)
    I: Downloaded 147264/2114441 bytes (6%)
    I: Downloaded 147972/2114441 bytes (6%)
    I: Downloaded 148680/2114441 bytes (7%)
    I: Downloaded 149388/2114441 bytes (7%)
    I: Downloaded 150096/2114441 bytes (7%)
    I: Downloaded 150804/2114441 bytes (7%)
    I: Downloaded 151512/2114441 bytes (7%)
    I: Downloaded 152220/2114441 bytes (7%)
    I: Downloaded 152928/2114441 bytes (7%)
    I: Downloaded 153636/2114441 bytes (7%)
    I: Downloaded 154344/2114441 bytes (7%)
    I: Downloaded 155052/2114441 bytes (7%)
    I: Downloaded 155760/2114441 bytes (7%)
    I: Downloaded 156468/2114441 bytes (7%)
    I: Downloaded 157176/2114441 bytes (7%)
    I: Downloaded 157884/2114441 bytes (7%)
    I: Downloaded 158592/2114441 bytes (7%)
    I: Downloaded 159300/2114441 bytes (7%)
    I: Downloaded 160008/2114441 bytes (7%)
    I: Downloaded 160716/2114441 bytes (7%)
    I: Downloaded 161424/2114441 bytes (7%)
    I: Downloaded 162132/2114441 bytes (7%)
    I: Downloaded 162840/2114441 bytes (7%)
    I: Downloaded 163548/2114441 bytes (7%)
    I: Downloaded 164256/2114441 bytes (7%)
    I: Downloaded 164964/2114441 bytes (7%)
    I: Downloaded 165672/2114441 bytes (7%)
    I: Downloaded 166380/2114441 bytes (7%)
    I: Downloaded 167088/2114441 bytes (7%)
    I: Downloaded 167796/2114441 bytes (7%)
    I: Downloaded 168504/2114441 bytes (7%)
    I: Downloaded 169212/2114441 bytes (8%)
    I: Downloaded 169920/2114441 bytes (8%)
    I: Downloaded 170628/2114441 bytes (8%)
    I: Downloaded 171336/2114441 bytes (8%)
    I: Downloaded 172044/2114441 bytes (8%)
    I: Downloaded 172752/2114441 bytes (8%)
    I: Downloaded 173460/2114441 bytes (8%)
    I: Downloaded 174168/2114441 bytes (8%)
    I: Downloaded 174876/2114441 bytes (8%)
    I: Downloaded 175584/2114441 bytes (8%)
    I: Downloaded 176292/2114441 bytes (8%)
    I: Downloaded 177000/2114441 bytes (8%)
    I: Downloaded 177708/2114441 bytes (8%)
    I: Downloaded 178416/2114441 bytes (8%)
    I: Downloaded 179124/2114441 bytes (8%)
    I: Downloaded 179832/2114441 bytes (8%)
    I: Downloaded 180540/2114441 bytes (8%)
    I: Downloaded 181248/2114441 bytes (8%)
    I: Downloaded 181956/2114441 bytes (8%)
    I: Downloaded 182664/2114441 bytes (8%)
    I: Downloaded 183372/2114441 bytes (8%)
    I: Downloaded 184080/2114441 bytes (8%)
    I: Downloaded 184788/2114441 bytes (8%)
    I: Downloaded 185496/2114441 bytes (8%)
    I: Downloaded 186204/2114441 bytes (8%)
    I: Downloaded 186912/2114441 bytes (8%)
    I: Downloaded 187620/2114441 bytes (8%)
    I: Downloaded 188328/2114441 bytes (8%)
    I: Downloaded 189036/2114441 bytes (8%)
    I: Downloaded 189744/2114441 bytes (8%)
    I: Downloaded 190452/2114441 bytes (9%)
    I: Downloaded 191160/2114441 bytes (9%)
    I: Downloaded 191868/2114441 bytes (9%)
    I: Downloaded 192576/2114441 bytes (9%)
    I: Downloaded 193284/2114441 bytes (9%)
    I: Downloaded 193992/2114441 bytes (9%)
    I: Downloaded 194700/2114441 bytes (9%)
    I: Downloaded 195408/2114441 bytes (9%)
    I: Downloaded 196116/2114441 bytes (9%)
    I: Downloaded 196824/2114441 bytes (9%)
    I: Downloaded 197532/2114441 bytes (9%)
    I: Downloaded 198240/2114441 bytes (9%)
    I: Downloaded 198948/2114441 bytes (9%)
    I: Downloaded 199656/2114441 bytes (9%)
    I: Downloaded 200364/2114441 bytes (9%)
    I: Downloaded 201072/2114441 bytes (9%)
    I: Downloaded 203120/2114441 bytes (9%)
    I: Downloaded 205168/2114441 bytes (9%)
    I: Downloaded 207216/2114441 bytes (9%)
    I: Downloaded 208860/2114441 bytes (9%)
    I: Downloaded 209884/2114441 bytes (9%)
    I: Downloaded 210984/2114441 bytes (9%)
    I: Downloaded 212400/2114441 bytes (10%)
    I: Downloaded 213108/2114441 bytes (10%)
    I: Downloaded 213816/2114441 bytes (10%)
    I: Downloaded 215232/2114441 bytes (10%)
    I: Downloaded 215940/2114441 bytes (10%)
    I: Downloaded 216648/2114441 bytes (10%)
    I: Downloaded 217356/2114441 bytes (10%)
    I: Downloaded 218064/2114441 bytes (10%)
    I: Downloaded 218772/2114441 bytes (10%)
    I: Downloaded 219480/2114441 bytes (10%)
    I: Downloaded 220188/2114441 bytes (10%)
    I: Downloaded 220896/2114441 bytes (10%)
    I: Downloaded 221604/2114441 bytes (10%)
    I: Downloaded 222312/2114441 bytes (10%)
    I: Downloaded 223020/2114441 bytes (10%)
    I: Downloaded 223728/2114441 bytes (10%)
    I: Downloaded 224436/2114441 bytes (10%)
    I: Downloaded 225144/2114441 bytes (10%)
    I: Downloaded 225852/2114441 bytes (10%)
    I: Downloaded 226560/2114441 bytes (10%)
    I: Downloaded 227268/2114441 bytes (10%)
    I: Downloaded 227976/2114441 bytes (10%)
    I: Downloaded 228684/2114441 bytes (10%)
    I: Downloaded 229392/2114441 bytes (10%)
    I: Downloaded 230100/2114441 bytes (10%)
    I: Downloaded 230808/2114441 bytes (10%)
    I: Downloaded 231516/2114441 bytes (10%)
    I: Downloaded 232224/2114441 bytes (10%)
    I: Downloaded 232932/2114441 bytes (11%)
    I: Downloaded 233640/2114441 bytes (11%)
    I: Downloaded 234348/2114441 bytes (11%)
    I: Downloaded 235056/2114441 bytes (11%)
    I: Downloaded 235764/2114441 bytes (11%)
    I: Downloaded 236472/2114441 bytes (11%)
    I: Downloaded 237180/2114441 bytes (11%)
    I: Downloaded 237888/2114441 bytes (11%)
    I: Downloaded 238596/2114441 bytes (11%)
    I: Downloaded 239304/2114441 bytes (11%)
    I: Downloaded 240012/2114441 bytes (11%)
    I: Downloaded 240720/2114441 bytes (11%)
    I: Downloaded 241428/2114441 bytes (11%)
    I: Downloaded 242136/2114441 bytes (11%)
    I: Downloaded 242844/2114441 bytes (11%)
    I: Downloaded 243552/2114441 bytes (11%)
    I: Downloaded 244260/2114441 bytes (11%)
    I: Downloaded 244968/2114441 bytes (11%)
    I: Downloaded 245676/2114441 bytes (11%)
    I: Downloaded 246384/2114441 bytes (11%)
    I: Downloaded 247092/2114441 bytes (11%)
    I: Downloaded 247800/2114441 bytes (11%)
    I: Downloaded 248508/2114441 bytes (11%)
    I: Downloaded 249216/2114441 bytes (11%)
    I: Downloaded 249924/2114441 bytes (11%)
    I: Downloaded 250632/2114441 bytes (11%)
    I: Downloaded 251340/2114441 bytes (11%)
    I: Downloaded 252048/2114441 bytes (11%)
    I: Downloaded 252756/2114441 bytes (11%)
    I: Downloaded 253464/2114441 bytes (11%)
    I: Downloaded 254172/2114441 bytes (12%)
    I: Downloaded 254880/2114441 bytes (12%)
    I: Downloaded 255588/2114441 bytes (12%)
    I: Downloaded 256296/2114441 bytes (12%)
    I: Downloaded 257004/2114441 bytes (12%)
    I: Downloaded 257712/2114441 bytes (12%)
    I: Downloaded 258420/2114441 bytes (12%)
    I: Downloaded 259128/2114441 bytes (12%)
    I: Downloaded 259836/2114441 bytes (12%)
    I: Downloaded 260544/2114441 bytes (12%)
    I: Downloaded 261252/2114441 bytes (12%)
    I: Downloaded 261960/2114441 bytes (12%)
    I: Downloaded 262668/2114441 bytes (12%)
    I: Downloaded 263376/2114441 bytes (12%)
    I: Downloaded 264084/2114441 bytes (12%)
    I: Downloaded 264792/2114441 bytes (12%)
    I: Downloaded 265500/2114441 bytes (12%)
    I: Downloaded 266208/2114441 bytes (12%)
    I: Downloaded 266916/2114441 bytes (12%)
    I: Downloaded 268964/2114441 bytes (12%)
    I: Downloaded 271012/2114441 bytes (12%)
    I: Downloaded 273060/2114441 bytes (12%)
    I: Downloaded 273288/2114441 bytes (12%)
    I: Downloaded 273996/2114441 bytes (12%)
    I: Downloaded 274704/2114441 bytes (12%)
    I: Downloaded 275412/2114441 bytes (13%)
    I: Downloaded 276120/2114441 bytes (13%)
    I: Downloaded 276828/2114441 bytes (13%)
    I: Downloaded 277536/2114441 bytes (13%)
    I: Downloaded 278244/2114441 bytes (13%)
    I: Downloaded 278952/2114441 bytes (13%)
    I: Downloaded 279660/2114441 bytes (13%)
    I: Downloaded 280368/2114441 bytes (13%)
    I: Downloaded 281076/2114441 bytes (13%)
    I: Downloaded 281784/2114441 bytes (13%)
    I: Downloaded 282492/2114441 bytes (13%)
    I: Downloaded 283200/2114441 bytes (13%)
    I: Downloaded 283908/2114441 bytes (13%)
    I: Downloaded 284616/2114441 bytes (13%)
    I: Downloaded 285324/2114441 bytes (13%)
    I: Downloaded 286032/2114441 bytes (13%)
    I: Downloaded 286740/2114441 bytes (13%)
    I: Downloaded 287448/2114441 bytes (13%)
    I: Downloaded 288156/2114441 bytes (13%)
    I: Downloaded 288864/2114441 bytes (13%)
    I: Downloaded 289572/2114441 bytes (13%)
    I: Downloaded 290280/2114441 bytes (13%)
    I: Downloaded 290988/2114441 bytes (13%)
    I: Downloaded 291696/2114441 bytes (13%)
    I: Downloaded 292404/2114441 bytes (13%)
    I: Downloaded 293112/2114441 bytes (13%)
    I: Downloaded 293820/2114441 bytes (13%)
    I: Downloaded 294528/2114441 bytes (13%)
    I: Downloaded 295236/2114441 bytes (13%)
    I: Downloaded 295944/2114441 bytes (13%)
    I: Downloaded 296652/2114441 bytes (14%)
    I: Downloaded 297360/2114441 bytes (14%)
    I: Downloaded 298068/2114441 bytes (14%)
    I: Downloaded 298776/2114441 bytes (14%)
    I: Downloaded 299484/2114441 bytes (14%)
    I: Downloaded 300192/2114441 bytes (14%)
    I: Downloaded 300900/2114441 bytes (14%)
    I: Downloaded 301608/2114441 bytes (14%)
    I: Downloaded 302316/2114441 bytes (14%)
    I: Downloaded 303024/2114441 bytes (14%)
    I: Downloaded 303732/2114441 bytes (14%)
    I: Downloaded 304440/2114441 bytes (14%)
    I: Downloaded 305148/2114441 bytes (14%)
    I: Downloaded 305856/2114441 bytes (14%)
    I: Downloaded 306564/2114441 bytes (14%)
    I: Downloaded 307272/2114441 bytes (14%)
    I: Downloaded 307980/2114441 bytes (14%)
    I: Downloaded 308688/2114441 bytes (14%)
    I: Downloaded 309396/2114441 bytes (14%)
    I: Downloaded 310104/2114441 bytes (14%)
    I: Downloaded 310812/2114441 bytes (14%)
    I: Downloaded 311520/2114441 bytes (14%)
    I: Downloaded 312228/2114441 bytes (14%)
    I: Downloaded 312936/2114441 bytes (14%)
    I: Downloaded 313644/2114441 bytes (14%)
    I: Downloaded 314352/2114441 bytes (14%)
    I: Downloaded 315060/2114441 bytes (14%)
    I: Downloaded 315768/2114441 bytes (14%)
    I: Downloaded 316476/2114441 bytes (14%)
    I: Downloaded 317184/2114441 bytes (15%)
    I: Downloaded 317892/2114441 bytes (15%)
    I: Downloaded 318600/2114441 bytes (15%)
    I: Downloaded 319308/2114441 bytes (15%)
    I: Downloaded 320016/2114441 bytes (15%)
    I: Downloaded 320724/2114441 bytes (15%)
    I: Downloaded 321432/2114441 bytes (15%)
    I: Downloaded 322140/2114441 bytes (15%)
    I: Downloaded 322848/2114441 bytes (15%)
    I: Downloaded 323556/2114441 bytes (15%)
    I: Downloaded 324264/2114441 bytes (15%)
    I: Downloaded 324972/2114441 bytes (15%)
    I: Downloaded 325680/2114441 bytes (15%)
    I: Downloaded 326388/2114441 bytes (15%)
    I: Downloaded 327096/2114441 bytes (15%)
    I: Downloaded 327804/2114441 bytes (15%)
    I: Downloaded 328512/2114441 bytes (15%)
    I: Downloaded 329220/2114441 bytes (15%)
    I: Downloaded 329928/2114441 bytes (15%)
    I: Downloaded 330636/2114441 bytes (15%)
    I: Downloaded 331344/2114441 bytes (15%)
    I: Downloaded 332052/2114441 bytes (15%)
    I: Downloaded 334100/2114441 bytes (15%)
    I: Downloaded 336148/2114441 bytes (15%)
    I: Downloaded 338196/2114441 bytes (15%)
    I: Downloaded 339840/2114441 bytes (16%)
    I: Downloaded 341256/2114441 bytes (16%)
    I: Downloaded 341964/2114441 bytes (16%)
    I: Downloaded 342988/2114441 bytes (16%)
    I: Downloaded 344088/2114441 bytes (16%)
    I: Downloaded 344796/2114441 bytes (16%)
    I: Downloaded 345504/2114441 bytes (16%)
    I: Downloaded 346212/2114441 bytes (16%)
    I: Downloaded 346920/2114441 bytes (16%)
    I: Downloaded 347628/2114441 bytes (16%)
    I: Downloaded 348336/2114441 bytes (16%)
    I: Downloaded 349044/2114441 bytes (16%)
    I: Downloaded 349752/2114441 bytes (16%)
    I: Downloaded 350460/2114441 bytes (16%)
    I: Downloaded 351168/2114441 bytes (16%)
    I: Downloaded 351876/2114441 bytes (16%)
    I: Downloaded 352584/2114441 bytes (16%)
    I: Downloaded 353292/2114441 bytes (16%)
    I: Downloaded 354000/2114441 bytes (16%)
    I: Downloaded 354708/2114441 bytes (16%)
    I: Downloaded 355416/2114441 bytes (16%)
    I: Downloaded 356124/2114441 bytes (16%)
    I: Downloaded 356832/2114441 bytes (16%)
    I: Downloaded 357540/2114441 bytes (16%)
    I: Downloaded 358248/2114441 bytes (16%)
    I: Downloaded 358956/2114441 bytes (16%)
    I: Downloaded 359664/2114441 bytes (17%)
    I: Downloaded 360372/2114441 bytes (17%)
    I: Downloaded 361080/2114441 bytes (17%)
    I: Downloaded 361788/2114441 bytes (17%)
    I: Downloaded 362496/2114441 bytes (17%)
    I: Downloaded 363204/2114441 bytes (17%)
    I: Downloaded 363912/2114441 bytes (17%)
    I: Downloaded 364620/2114441 bytes (17%)
    I: Downloaded 365328/2114441 bytes (17%)
    I: Downloaded 366036/2114441 bytes (17%)
    I: Downloaded 366744/2114441 bytes (17%)
    I: Downloaded 367452/2114441 bytes (17%)
    I: Downloaded 368160/2114441 bytes (17%)
    I: Downloaded 368868/2114441 bytes (17%)
    I: Downloaded 369576/2114441 bytes (17%)
    I: Downloaded 370284/2114441 bytes (17%)
    I: Downloaded 370992/2114441 bytes (17%)
    I: Downloaded 371700/2114441 bytes (17%)
    I: Downloaded 372408/2114441 bytes (17%)
    I: Downloaded 373116/2114441 bytes (17%)
    I: Downloaded 373824/2114441 bytes (17%)
    I: Downloaded 374532/2114441 bytes (17%)
    I: Downloaded 375240/2114441 bytes (17%)
    I: Downloaded 375948/2114441 bytes (17%)
    I: Downloaded 376656/2114441 bytes (17%)
    I: Downloaded 377364/2114441 bytes (17%)
    I: Downloaded 378072/2114441 bytes (17%)
    I: Downloaded 378780/2114441 bytes (17%)
    I: Downloaded 379488/2114441 bytes (17%)
    I: Downloaded 380196/2114441 bytes (17%)
    I: Downloaded 380904/2114441 bytes (18%)
    I: Downloaded 381612/2114441 bytes (18%)
    I: Downloaded 382320/2114441 bytes (18%)
    I: Downloaded 383028/2114441 bytes (18%)
    I: Downloaded 383736/2114441 bytes (18%)
    I: Downloaded 384444/2114441 bytes (18%)
    I: Downloaded 385152/2114441 bytes (18%)
    I: Downloaded 385860/2114441 bytes (18%)
    I: Downloaded 386568/2114441 bytes (18%)
    I: Downloaded 387276/2114441 bytes (18%)
    I: Downloaded 387984/2114441 bytes (18%)
    I: Downloaded 388692/2114441 bytes (18%)
    I: Downloaded 389400/2114441 bytes (18%)
    I: Downloaded 390108/2114441 bytes (18%)
    I: Downloaded 390816/2114441 bytes (18%)
    I: Downloaded 391524/2114441 bytes (18%)
    I: Downloaded 392232/2114441 bytes (18%)
    I: Downloaded 392940/2114441 bytes (18%)
    I: Downloaded 393648/2114441 bytes (18%)
    I: Downloaded 394356/2114441 bytes (18%)
    I: Downloaded 395064/2114441 bytes (18%)
    I: Downloaded 395772/2114441 bytes (18%)
    I: Downloaded 396480/2114441 bytes (18%)
    I: Downloaded 397188/2114441 bytes (18%)
    I: Downloaded 397896/2114441 bytes (18%)
    I: Downloaded 399944/2114441 bytes (18%)
    I: Downloaded 401992/2114441 bytes (19%)
    I: Downloaded 404040/2114441 bytes (19%)
    I: Downloaded 404976/2114441 bytes (19%)
    I: Downloaded 405684/2114441 bytes (19%)
    I: Downloaded 406392/2114441 bytes (19%)
    I: Downloaded 407100/2114441 bytes (19%)
    I: Downloaded 407808/2114441 bytes (19%)
    I: Downloaded 408516/2114441 bytes (19%)
    I: Downloaded 409224/2114441 bytes (19%)
    I: Downloaded 409932/2114441 bytes (19%)
    I: Downloaded 410640/2114441 bytes (19%)
    I: Downloaded 411348/2114441 bytes (19%)
    I: Downloaded 412056/2114441 bytes (19%)
    I: Downloaded 412764/2114441 bytes (19%)
    I: Downloaded 413472/2114441 bytes (19%)
    I: Downloaded 414180/2114441 bytes (19%)
    I: Downloaded 414888/2114441 bytes (19%)
    I: Downloaded 415596/2114441 bytes (19%)
    I: Downloaded 416304/2114441 bytes (19%)
    I: Downloaded 417012/2114441 bytes (19%)
    I: Downloaded 417720/2114441 bytes (19%)
    I: Downloaded 418428/2114441 bytes (19%)
    I: Downloaded 419136/2114441 bytes (19%)
    I: Downloaded 419844/2114441 bytes (19%)
    I: Downloaded 420552/2114441 bytes (19%)
    I: Downloaded 421260/2114441 bytes (19%)
    I: Downloaded 421968/2114441 bytes (19%)
    I: Downloaded 422676/2114441 bytes (19%)
    I: Downloaded 423384/2114441 bytes (20%)
    I: Downloaded 424092/2114441 bytes (20%)
    I: Downloaded 424800/2114441 bytes (20%)
    I: Downloaded 425508/2114441 bytes (20%)
    I: Downloaded 426216/2114441 bytes (20%)
    I: Downloaded 426924/2114441 bytes (20%)
    I: Downloaded 427632/2114441 bytes (20%)
    I: Downloaded 428340/2114441 bytes (20%)
    I: Downloaded 429048/2114441 bytes (20%)
    I: Downloaded 429756/2114441 bytes (20%)
    I: Downloaded 430464/2114441 bytes (20%)
    I: Downloaded 431172/2114441 bytes (20%)
    I: Downloaded 431880/2114441 bytes (20%)
    I: Downloaded 432588/2114441 bytes (20%)
    I: Downloaded 433296/2114441 bytes (20%)
    I: Downloaded 434004/2114441 bytes (20%)
    I: Downloaded 434712/2114441 bytes (20%)
    I: Downloaded 435420/2114441 bytes (20%)
    I: Downloaded 436128/2114441 bytes (20%)
    I: Downloaded 436836/2114441 bytes (20%)
    I: Downloaded 437544/2114441 bytes (20%)
    I: Downloaded 438252/2114441 bytes (20%)
    I: Downloaded 438960/2114441 bytes (20%)
    I: Downloaded 439668/2114441 bytes (20%)
    I: Downloaded 440376/2114441 bytes (20%)
    I: Downloaded 441084/2114441 bytes (20%)
    I: Downloaded 441792/2114441 bytes (20%)
    I: Downloaded 442500/2114441 bytes (20%)
    I: Downloaded 443208/2114441 bytes (20%)
    I: Downloaded 443916/2114441 bytes (20%)
    I: Downloaded 444624/2114441 bytes (21%)
    I: Downloaded 445332/2114441 bytes (21%)
    I: Downloaded 446040/2114441 bytes (21%)
    I: Downloaded 446748/2114441 bytes (21%)
    I: Downloaded 447456/2114441 bytes (21%)
    I: Downloaded 448164/2114441 bytes (21%)
    I: Downloaded 448872/2114441 bytes (21%)
    I: Downloaded 449580/2114441 bytes (21%)
    I: Downloaded 450288/2114441 bytes (21%)
    I: Downloaded 450996/2114441 bytes (21%)
    I: Downloaded 451704/2114441 bytes (21%)
    I: Downloaded 452412/2114441 bytes (21%)
    I: Downloaded 453120/2114441 bytes (21%)
    I: Downloaded 453828/2114441 bytes (21%)
    I: Downloaded 454536/2114441 bytes (21%)
    I: Downloaded 455244/2114441 bytes (21%)
    I: Downloaded 455952/2114441 bytes (21%)
    I: Downloaded 456660/2114441 bytes (21%)
    I: Downloaded 457368/2114441 bytes (21%)
    I: Downloaded 458076/2114441 bytes (21%)
    I: Downloaded 458784/2114441 bytes (21%)
    I: Downloaded 459492/2114441 bytes (21%)
    I: Downloaded 460200/2114441 bytes (21%)
    I: Downloaded 460908/2114441 bytes (21%)
    I: Downloaded 461616/2114441 bytes (21%)
    I: Downloaded 462324/2114441 bytes (21%)
    I: Downloaded 463032/2114441 bytes (21%)
    I: Downloaded 465080/2114441 bytes (21%)
    I: Downloaded 467128/2114441 bytes (22%)
    I: Downloaded 469176/2114441 bytes (22%)
    I: Downloaded 470820/2114441 bytes (22%)
    I: Downloaded 472868/2114441 bytes (22%)
    I: Downloaded 472944/2114441 bytes (22%)
    I: Downloaded 474992/2114441 bytes (22%)
    I: Downloaded 475068/2114441 bytes (22%)
    I: Downloaded 475776/2114441 bytes (22%)
    I: Downloaded 476484/2114441 bytes (22%)
    I: Downloaded 477192/2114441 bytes (22%)
    I: Downloaded 477900/2114441 bytes (22%)
    I: Downloaded 478608/2114441 bytes (22%)
    I: Downloaded 479316/2114441 bytes (22%)
    I: Downloaded 480024/2114441 bytes (22%)
    I: Downloaded 480732/2114441 bytes (22%)
    I: Downloaded 481440/2114441 bytes (22%)
    I: Downloaded 482148/2114441 bytes (22%)
    I: Downloaded 482856/2114441 bytes (22%)
    I: Downloaded 483564/2114441 bytes (22%)
    I: Downloaded 484272/2114441 bytes (22%)
    I: Downloaded 484980/2114441 bytes (22%)
    I: Downloaded 485688/2114441 bytes (22%)
    I: Downloaded 486396/2114441 bytes (23%)
    I: Downloaded 487104/2114441 bytes (23%)
    I: Downloaded 487812/2114441 bytes (23%)
    I: Downloaded 488520/2114441 bytes (23%)
    I: Downloaded 489228/2114441 bytes (23%)
    I: Downloaded 489936/2114441 bytes (23%)
    I: Downloaded 490644/2114441 bytes (23%)
    I: Downloaded 491352/2114441 bytes (23%)
    I: Downloaded 492060/2114441 bytes (23%)
    I: Downloaded 492768/2114441 bytes (23%)
    I: Downloaded 493476/2114441 bytes (23%)
    I: Downloaded 494184/2114441 bytes (23%)
    I: Downloaded 494892/2114441 bytes (23%)
    I: Downloaded 495600/2114441 bytes (23%)
    I: Downloaded 496308/2114441 bytes (23%)
    I: Downloaded 497016/2114441 bytes (23%)
    I: Downloaded 497724/2114441 bytes (23%)
    I: Downloaded 498432/2114441 bytes (23%)
    I: Downloaded 499140/2114441 bytes (23%)
    I: Downloaded 499848/2114441 bytes (23%)
    I: Downloaded 500556/2114441 bytes (23%)
    I: Downloaded 501264/2114441 bytes (23%)
    I: Downloaded 501972/2114441 bytes (23%)
    I: Downloaded 502680/2114441 bytes (23%)
    I: Downloaded 503388/2114441 bytes (23%)
    I: Downloaded 504096/2114441 bytes (23%)
    I: Downloaded 504804/2114441 bytes (23%)
    I: Downloaded 505512/2114441 bytes (23%)
    I: Downloaded 506220/2114441 bytes (23%)
    I: Downloaded 506928/2114441 bytes (23%)
    I: Downloaded 507636/2114441 bytes (24%)
    I: Downloaded 508344/2114441 bytes (24%)
    I: Downloaded 509052/2114441 bytes (24%)
    I: Downloaded 509760/2114441 bytes (24%)
    I: Downloaded 510468/2114441 bytes (24%)
    I: Downloaded 511176/2114441 bytes (24%)
    I: Downloaded 511884/2114441 bytes (24%)
    I: Downloaded 512592/2114441 bytes (24%)
    I: Downloaded 513300/2114441 bytes (24%)
    I: Downloaded 514008/2114441 bytes (24%)
    I: Downloaded 514716/2114441 bytes (24%)
    I: Downloaded 515424/2114441 bytes (24%)
    I: Downloaded 516132/2114441 bytes (24%)
    I: Downloaded 516840/2114441 bytes (24%)
    I: Downloaded 517548/2114441 bytes (24%)
    I: Downloaded 518256/2114441 bytes (24%)
    I: Downloaded 518964/2114441 bytes (24%)
    I: Downloaded 519672/2114441 bytes (24%)
    I: Downloaded 520380/2114441 bytes (24%)
    I: Downloaded 521088/2114441 bytes (24%)
    I: Downloaded 521796/2114441 bytes (24%)
    I: Downloaded 522504/2114441 bytes (24%)
    I: Downloaded 523212/2114441 bytes (24%)
    I: Downloaded 523920/2114441 bytes (24%)
    I: Downloaded 524628/2114441 bytes (24%)
    I: Downloaded 525336/2114441 bytes (24%)
    I: Downloaded 526044/2114441 bytes (24%)
    I: Downloaded 526752/2114441 bytes (24%)
    I: Downloaded 527460/2114441 bytes (24%)
    I: Downloaded 528168/2114441 bytes (24%)
    I: Downloaded 528876/2114441 bytes (25%)
    I: Downloaded 530924/2114441 bytes (25%)
    I: Downloaded 532972/2114441 bytes (25%)
    I: Downloaded 535020/2114441 bytes (25%)
    I: Downloaded 536664/2114441 bytes (25%)
    I: Downloaded 538080/2114441 bytes (25%)
    I: Downloaded 538788/2114441 bytes (25%)
    I: Downloaded 539812/2114441 bytes (25%)
    I: Downloaded 540912/2114441 bytes (25%)
    I: Downloaded 541620/2114441 bytes (25%)
    I: Downloaded 543036/2114441 bytes (25%)
    I: Downloaded 543744/2114441 bytes (25%)
    I: Downloaded 544452/2114441 bytes (25%)
    I: Downloaded 545868/2114441 bytes (25%)
    I: Downloaded 546576/2114441 bytes (25%)
    I: Downloaded 547284/2114441 bytes (25%)
    I: Downloaded 547992/2114441 bytes (25%)
    I: Downloaded 548700/2114441 bytes (25%)
    I: Downloaded 549408/2114441 bytes (25%)
    I: Downloaded 550116/2114441 bytes (26%)
    I: Downloaded 550824/2114441 bytes (26%)
    I: Downloaded 551532/2114441 bytes (26%)
    I: Downloaded 552240/2114441 bytes (26%)
    I: Downloaded 552948/2114441 bytes (26%)
    I: Downloaded 553656/2114441 bytes (26%)
    I: Downloaded 554364/2114441 bytes (26%)
    I: Downloaded 555072/2114441 bytes (26%)
    I: Downloaded 555780/2114441 bytes (26%)
    I: Downloaded 556488/2114441 bytes (26%)
    I: Downloaded 557196/2114441 bytes (26%)
    I: Downloaded 557904/2114441 bytes (26%)
    I: Downloaded 558612/2114441 bytes (26%)
    I: Downloaded 559320/2114441 bytes (26%)
    I: Downloaded 560028/2114441 bytes (26%)
    I: Downloaded 560736/2114441 bytes (26%)
    I: Downloaded 561444/2114441 bytes (26%)
    I: Downloaded 562152/2114441 bytes (26%)
    I: Downloaded 562860/2114441 bytes (26%)
    I: Downloaded 563568/2114441 bytes (26%)
    I: Downloaded 564276/2114441 bytes (26%)
    I: Downloaded 564984/2114441 bytes (26%)
    I: Downloaded 565692/2114441 bytes (26%)
    I: Downloaded 566400/2114441 bytes (26%)
    I: Downloaded 567108/2114441 bytes (26%)
    I: Downloaded 567816/2114441 bytes (26%)
    I: Downloaded 568524/2114441 bytes (26%)
    I: Downloaded 569232/2114441 bytes (26%)
    I: Downloaded 569940/2114441 bytes (26%)
    I: Downloaded 570648/2114441 bytes (26%)
    I: Downloaded 571356/2114441 bytes (27%)
    I: Downloaded 572064/2114441 bytes (27%)
    I: Downloaded 572772/2114441 bytes (27%)
    I: Downloaded 573480/2114441 bytes (27%)
    I: Downloaded 574188/2114441 bytes (27%)
    I: Downloaded 574896/2114441 bytes (27%)
    I: Downloaded 575604/2114441 bytes (27%)
    I: Downloaded 576312/2114441 bytes (27%)
    I: Downloaded 577020/2114441 bytes (27%)
    I: Downloaded 577728/2114441 bytes (27%)
    I: Downloaded 578436/2114441 bytes (27%)
    I: Downloaded 579144/2114441 bytes (27%)
    I: Downloaded 579852/2114441 bytes (27%)
    I: Downloaded 580560/2114441 bytes (27%)
    I: Downloaded 581268/2114441 bytes (27%)
    I: Downloaded 581976/2114441 bytes (27%)
    I: Downloaded 582684/2114441 bytes (27%)
    I: Downloaded 583392/2114441 bytes (27%)
    I: Downloaded 584100/2114441 bytes (27%)
    I: Downloaded 584808/2114441 bytes (27%)
    I: Downloaded 585516/2114441 bytes (27%)
    I: Downloaded 586224/2114441 bytes (27%)
    I: Downloaded 586932/2114441 bytes (27%)
    I: Downloaded 587640/2114441 bytes (27%)
    I: Downloaded 588348/2114441 bytes (27%)
    I: Downloaded 589056/2114441 bytes (27%)
    I: Downloaded 589764/2114441 bytes (27%)
    I: Downloaded 590472/2114441 bytes (27%)
    I: Downloaded 591180/2114441 bytes (27%)
    I: Downloaded 591888/2114441 bytes (27%)
    I: Downloaded 592596/2114441 bytes (28%)
    I: Downloaded 593304/2114441 bytes (28%)
    I: Downloaded 594012/2114441 bytes (28%)
    I: Downloaded 596060/2114441 bytes (28%)
    I: Downloaded 598108/2114441 bytes (28%)
    I: Downloaded 600156/2114441 bytes (28%)
    I: Downloaded 600384/2114441 bytes (28%)
    I: Downloaded 601092/2114441 bytes (28%)
    I: Downloaded 601800/2114441 bytes (28%)
    I: Downloaded 602508/2114441 bytes (28%)
    I: Downloaded 603216/2114441 bytes (28%)
    I: Downloaded 603924/2114441 bytes (28%)
    I: Downloaded 604632/2114441 bytes (28%)
    I: Downloaded 605340/2114441 bytes (28%)
    I: Downloaded 606048/2114441 bytes (28%)
    I: Downloaded 606756/2114441 bytes (28%)
    I: Downloaded 607464/2114441 bytes (28%)
    I: Downloaded 608172/2114441 bytes (28%)
    I: Downloaded 608880/2114441 bytes (28%)
    I: Downloaded 609588/2114441 bytes (28%)
    I: Downloaded 610296/2114441 bytes (28%)
    I: Downloaded 611004/2114441 bytes (28%)
    I: Downloaded 611712/2114441 bytes (28%)
    I: Downloaded 612420/2114441 bytes (28%)
    I: Downloaded 613128/2114441 bytes (28%)
    I: Downloaded 613836/2114441 bytes (29%)
    I: Downloaded 614544/2114441 bytes (29%)
    I: Downloaded 615252/2114441 bytes (29%)
    I: Downloaded 615960/2114441 bytes (29%)
    I: Downloaded 616668/2114441 bytes (29%)
    I: Downloaded 617376/2114441 bytes (29%)
    I: Downloaded 618084/2114441 bytes (29%)
    I: Downloaded 618792/2114441 bytes (29%)
    I: Downloaded 619500/2114441 bytes (29%)
    I: Downloaded 620208/2114441 bytes (29%)
    I: Downloaded 620916/2114441 bytes (29%)
    I: Downloaded 621624/2114441 bytes (29%)
    I: Downloaded 622332/2114441 bytes (29%)
    I: Downloaded 623040/2114441 bytes (29%)
    I: Downloaded 623748/2114441 bytes (29%)
    I: Downloaded 624456/2114441 bytes (29%)
    I: Downloaded 625164/2114441 bytes (29%)
    I: Downloaded 625872/2114441 bytes (29%)
    I: Downloaded 626580/2114441 bytes (29%)
    I: Downloaded 627288/2114441 bytes (29%)
    I: Downloaded 627996/2114441 bytes (29%)
    I: Downloaded 628704/2114441 bytes (29%)
    I: Downloaded 629412/2114441 bytes (29%)
    I: Downloaded 630120/2114441 bytes (29%)
    I: Downloaded 630828/2114441 bytes (29%)
    I: Downloaded 631536/2114441 bytes (29%)
    I: Downloaded 632244/2114441 bytes (29%)
    I: Downloaded 632952/2114441 bytes (29%)
    I: Downloaded 633660/2114441 bytes (29%)
    I: Downloaded 634368/2114441 bytes (30%)
    I: Downloaded 635076/2114441 bytes (30%)
    I: Downloaded 635784/2114441 bytes (30%)
    I: Downloaded 636492/2114441 bytes (30%)
    I: Downloaded 637200/2114441 bytes (30%)
    I: Downloaded 637908/2114441 bytes (30%)
    I: Downloaded 638616/2114441 bytes (30%)
    I: Downloaded 639324/2114441 bytes (30%)
    I: Downloaded 640032/2114441 bytes (30%)
    I: Downloaded 640740/2114441 bytes (30%)
    I: Downloaded 641448/2114441 bytes (30%)
    I: Downloaded 642156/2114441 bytes (30%)
    I: Downloaded 642864/2114441 bytes (30%)
    I: Downloaded 643572/2114441 bytes (30%)
    I: Downloaded 644280/2114441 bytes (30%)
    I: Downloaded 644988/2114441 bytes (30%)
    I: Downloaded 645696/2114441 bytes (30%)
    I: Downloaded 646404/2114441 bytes (30%)
    I: Downloaded 647112/2114441 bytes (30%)
    I: Downloaded 647820/2114441 bytes (30%)
    I: Downloaded 648528/2114441 bytes (30%)
    I: Downloaded 649236/2114441 bytes (30%)
    I: Downloaded 649944/2114441 bytes (30%)
    I: Downloaded 650652/2114441 bytes (30%)
    I: Downloaded 651360/2114441 bytes (30%)
    I: Downloaded 652068/2114441 bytes (30%)
    I: Downloaded 652776/2114441 bytes (30%)
    I: Downloaded 653484/2114441 bytes (30%)
    I: Downloaded 654192/2114441 bytes (30%)
    I: Downloaded 654900/2114441 bytes (30%)
    I: Downloaded 655608/2114441 bytes (31%)
    I: Downloaded 656316/2114441 bytes (31%)
    I: Downloaded 657024/2114441 bytes (31%)
    I: Downloaded 657732/2114441 bytes (31%)
    I: Downloaded 658440/2114441 bytes (31%)
    I: Downloaded 659148/2114441 bytes (31%)
    I: Downloaded 659856/2114441 bytes (31%)
    I: Downloaded 661904/2114441 bytes (31%)
    I: Downloaded 663952/2114441 bytes (31%)
    I: Downloaded 665520/2114441 bytes (31%)
    I: Downloaded 666228/2114441 bytes (31%)
    I: Downloaded 666936/2114441 bytes (31%)
    I: Downloaded 667644/2114441 bytes (31%)
    I: Downloaded 668352/2114441 bytes (31%)
    I: Downloaded 669060/2114441 bytes (31%)
    I: Downloaded 669768/2114441 bytes (31%)
    I: Downloaded 670476/2114441 bytes (31%)
    I: Downloaded 671184/2114441 bytes (31%)
    I: Downloaded 671892/2114441 bytes (31%)
    I: Downloaded 672600/2114441 bytes (31%)
    I: Downloaded 673308/2114441 bytes (31%)
    I: Downloaded 674016/2114441 bytes (31%)
    I: Downloaded 674724/2114441 bytes (31%)
    I: Downloaded 675432/2114441 bytes (31%)
    I: Downloaded 676140/2114441 bytes (31%)
    I: Downloaded 676848/2114441 bytes (32%)
    I: Downloaded 677556/2114441 bytes (32%)
    I: Downloaded 678264/2114441 bytes (32%)
    I: Downloaded 678972/2114441 bytes (32%)
    I: Downloaded 679680/2114441 bytes (32%)
    I: Downloaded 680388/2114441 bytes (32%)
    I: Downloaded 681096/2114441 bytes (32%)
    I: Downloaded 681804/2114441 bytes (32%)
    I: Downloaded 682512/2114441 bytes (32%)
    I: Downloaded 683220/2114441 bytes (32%)
    I: Downloaded 683928/2114441 bytes (32%)
    I: Downloaded 684636/2114441 bytes (32%)
    I: Downloaded 685344/2114441 bytes (32%)
    I: Downloaded 686052/2114441 bytes (32%)
    I: Downloaded 686760/2114441 bytes (32%)
    I: Downloaded 687468/2114441 bytes (32%)
    I: Downloaded 688176/2114441 bytes (32%)
    I: Downloaded 688884/2114441 bytes (32%)
    I: Downloaded 689592/2114441 bytes (32%)
    I: Downloaded 690300/2114441 bytes (32%)
    I: Downloaded 691008/2114441 bytes (32%)
    I: Downloaded 691716/2114441 bytes (32%)
    I: Downloaded 692424/2114441 bytes (32%)
    I: Downloaded 693132/2114441 bytes (32%)
    I: Downloaded 693840/2114441 bytes (32%)
    I: Downloaded 694548/2114441 bytes (32%)
    I: Downloaded 695256/2114441 bytes (32%)
    I: Downloaded 695964/2114441 bytes (32%)
    I: Downloaded 696672/2114441 bytes (32%)
    I: Downloaded 697380/2114441 bytes (32%)
    I: Downloaded 698088/2114441 bytes (33%)
    I: Downloaded 698796/2114441 bytes (33%)
    I: Downloaded 699504/2114441 bytes (33%)
    I: Downloaded 700212/2114441 bytes (33%)
    I: Downloaded 700920/2114441 bytes (33%)
    I: Downloaded 701628/2114441 bytes (33%)
    I: Downloaded 702336/2114441 bytes (33%)
    I: Downloaded 703044/2114441 bytes (33%)
    I: Downloaded 703752/2114441 bytes (33%)
    I: Downloaded 704460/2114441 bytes (33%)
    I: Downloaded 705168/2114441 bytes (33%)
    I: Downloaded 705876/2114441 bytes (33%)
    I: Downloaded 706584/2114441 bytes (33%)
    I: Downloaded 707292/2114441 bytes (33%)
    I: Downloaded 708000/2114441 bytes (33%)
    I: Downloaded 708708/2114441 bytes (33%)
    I: Downloaded 709416/2114441 bytes (33%)
    I: Downloaded 710124/2114441 bytes (33%)
    I: Downloaded 710832/2114441 bytes (33%)
    I: Downloaded 711540/2114441 bytes (33%)
    I: Downloaded 712248/2114441 bytes (33%)
    I: Downloaded 712956/2114441 bytes (33%)
    I: Downloaded 713664/2114441 bytes (33%)
    I: Downloaded 714372/2114441 bytes (33%)
    I: Downloaded 715080/2114441 bytes (33%)
    I: Downloaded 715788/2114441 bytes (33%)
    I: Downloaded 716496/2114441 bytes (33%)
    I: Downloaded 717204/2114441 bytes (33%)
    I: Downloaded 717912/2114441 bytes (33%)
    I: Downloaded 718620/2114441 bytes (33%)
    I: Downloaded 719328/2114441 bytes (34%)
    I: Downloaded 720036/2114441 bytes (34%)
    I: Downloaded 720744/2114441 bytes (34%)
    I: Downloaded 721452/2114441 bytes (34%)
    I: Downloaded 722160/2114441 bytes (34%)
    I: Downloaded 722868/2114441 bytes (34%)
    I: Downloaded 723576/2114441 bytes (34%)
    I: Downloaded 724284/2114441 bytes (34%)
    I: Downloaded 724992/2114441 bytes (34%)
    I: Downloaded 727040/2114441 bytes (34%)
    I: Downloaded 729088/2114441 bytes (34%)
    I: Downloaded 731136/2114441 bytes (34%)
    I: Downloaded 732780/2114441 bytes (34%)
    I: Downloaded 734196/2114441 bytes (34%)
    I: Downloaded 734904/2114441 bytes (34%)
    I: Downloaded 736320/2114441 bytes (34%)
    I: Downloaded 737028/2114441 bytes (34%)
    I: Downloaded 737736/2114441 bytes (34%)
    I: Downloaded 739152/2114441 bytes (34%)
    I: Downloaded 739860/2114441 bytes (34%)
    I: Downloaded 740568/2114441 bytes (35%)
    I: Downloaded 741276/2114441 bytes (35%)
    I: Downloaded 741984/2114441 bytes (35%)
    I: Downloaded 742692/2114441 bytes (35%)
    I: Downloaded 743400/2114441 bytes (35%)
    I: Downloaded 744108/2114441 bytes (35%)
    I: Downloaded 744816/2114441 bytes (35%)
    I: Downloaded 745524/2114441 bytes (35%)
    I: Downloaded 746232/2114441 bytes (35%)
    I: Downloaded 746940/2114441 bytes (35%)
    I: Downloaded 747648/2114441 bytes (35%)
    I: Downloaded 748356/2114441 bytes (35%)
    I: Downloaded 749064/2114441 bytes (35%)
    I: Downloaded 749772/2114441 bytes (35%)
    I: Downloaded 750480/2114441 bytes (35%)
    I: Downloaded 751188/2114441 bytes (35%)
    I: Downloaded 751896/2114441 bytes (35%)
    I: Downloaded 752604/2114441 bytes (35%)
    I: Downloaded 753312/2114441 bytes (35%)
    I: Downloaded 754020/2114441 bytes (35%)
    I: Downloaded 754728/2114441 bytes (35%)
    I: Downloaded 755436/2114441 bytes (35%)
    I: Downloaded 756144/2114441 bytes (35%)
    I: Downloaded 756852/2114441 bytes (35%)
    I: Downloaded 757560/2114441 bytes (35%)
    I: Downloaded 758268/2114441 bytes (35%)
    I: Downloaded 758976/2114441 bytes (35%)
    I: Downloaded 759684/2114441 bytes (35%)
    I: Downloaded 760392/2114441 bytes (35%)
    I: Downloaded 761100/2114441 bytes (35%)
    I: Downloaded 761808/2114441 bytes (36%)
    I: Downloaded 762516/2114441 bytes (36%)
    I: Downloaded 763224/2114441 bytes (36%)
    I: Downloaded 763932/2114441 bytes (36%)
    I: Downloaded 764640/2114441 bytes (36%)
    I: Downloaded 765348/2114441 bytes (36%)
    I: Downloaded 766056/2114441 bytes (36%)
    I: Downloaded 766764/2114441 bytes (36%)
    I: Downloaded 767472/2114441 bytes (36%)
    I: Downloaded 768180/2114441 bytes (36%)
    I: Downloaded 768888/2114441 bytes (36%)
    I: Downloaded 769596/2114441 bytes (36%)
    I: Downloaded 770304/2114441 bytes (36%)
    I: Downloaded 771012/2114441 bytes (36%)
    I: Downloaded 771720/2114441 bytes (36%)
    I: Downloaded 772428/2114441 bytes (36%)
    I: Downloaded 773136/2114441 bytes (36%)
    I: Downloaded 773844/2114441 bytes (36%)
    I: Downloaded 774552/2114441 bytes (36%)
    I: Downloaded 775260/2114441 bytes (36%)
    I: Downloaded 775968/2114441 bytes (36%)
    I: Downloaded 776676/2114441 bytes (36%)
    I: Downloaded 777384/2114441 bytes (36%)
    I: Downloaded 778092/2114441 bytes (36%)
    I: Downloaded 778800/2114441 bytes (36%)
    I: Downloaded 779508/2114441 bytes (36%)
    I: Downloaded 780216/2114441 bytes (36%)
    I: Downloaded 780924/2114441 bytes (36%)
    I: Downloaded 781632/2114441 bytes (36%)
    I: Downloaded 782340/2114441 bytes (36%)
    I: Downloaded 783048/2114441 bytes (37%)
    I: Downloaded 783756/2114441 bytes (37%)
    I: Downloaded 784464/2114441 bytes (37%)
    I: Downloaded 785172/2114441 bytes (37%)
    I: Downloaded 785880/2114441 bytes (37%)
    I: Downloaded 786588/2114441 bytes (37%)
    I: Downloaded 787296/2114441 bytes (37%)
    I: Downloaded 788004/2114441 bytes (37%)
    I: Downloaded 788712/2114441 bytes (37%)
    I: Downloaded 789420/2114441 bytes (37%)
    I: Downloaded 790128/2114441 bytes (37%)
    I: Downloaded 790836/2114441 bytes (37%)
    I: Downloaded 792884/2114441 bytes (37%)
    I: Downloaded 794932/2114441 bytes (37%)
    I: Downloaded 796980/2114441 bytes (37%)
    I: Downloaded 797208/2114441 bytes (37%)
    I: Downloaded 797916/2114441 bytes (37%)
    I: Downloaded 798624/2114441 bytes (37%)
    I: Downloaded 799332/2114441 bytes (37%)
    I: Downloaded 800040/2114441 bytes (37%)
    I: Downloaded 800748/2114441 bytes (37%)
    I: Downloaded 801456/2114441 bytes (37%)
    I: Downloaded 802164/2114441 bytes (37%)
    I: Downloaded 802872/2114441 bytes (37%)
    I: Downloaded 803580/2114441 bytes (38%)
    I: Downloaded 804288/2114441 bytes (38%)
    I: Downloaded 804996/2114441 bytes (38%)
    I: Downloaded 805704/2114441 bytes (38%)
    I: Downloaded 806412/2114441 bytes (38%)
    I: Downloaded 807120/2114441 bytes (38%)
    I: Downloaded 807828/2114441 bytes (38%)
    I: Downloaded 808536/2114441 bytes (38%)
    I: Downloaded 809244/2114441 bytes (38%)
    I: Downloaded 809952/2114441 bytes (38%)
    I: Downloaded 810660/2114441 bytes (38%)
    I: Downloaded 811368/2114441 bytes (38%)
    I: Downloaded 812076/2114441 bytes (38%)
    I: Downloaded 812784/2114441 bytes (38%)
    I: Downloaded 813492/2114441 bytes (38%)
    I: Downloaded 814200/2114441 bytes (38%)
    I: Downloaded 814908/2114441 bytes (38%)
    I: Downloaded 815616/2114441 bytes (38%)
    I: Downloaded 816324/2114441 bytes (38%)
    I: Downloaded 817032/2114441 bytes (38%)
    I: Downloaded 817740/2114441 bytes (38%)
    I: Downloaded 818448/2114441 bytes (38%)
    I: Downloaded 819156/2114441 bytes (38%)
    I: Downloaded 819864/2114441 bytes (38%)
    I: Downloaded 820572/2114441 bytes (38%)
    I: Downloaded 821280/2114441 bytes (38%)
    I: Downloaded 821988/2114441 bytes (38%)
    I: Downloaded 822696/2114441 bytes (38%)
    I: Downloaded 823404/2114441 bytes (38%)
    I: Downloaded 824112/2114441 bytes (38%)
    I: Downloaded 824820/2114441 bytes (39%)
    I: Downloaded 825528/2114441 bytes (39%)
    I: Downloaded 826236/2114441 bytes (39%)
    I: Downloaded 826944/2114441 bytes (39%)
    I: Downloaded 827652/2114441 bytes (39%)
    I: Downloaded 828360/2114441 bytes (39%)
    I: Downloaded 829068/2114441 bytes (39%)
    I: Downloaded 829776/2114441 bytes (39%)
    I: Downloaded 830484/2114441 bytes (39%)
    I: Downloaded 831192/2114441 bytes (39%)
    I: Downloaded 831900/2114441 bytes (39%)
    I: Downloaded 832608/2114441 bytes (39%)
    I: Downloaded 833316/2114441 bytes (39%)
    I: Downloaded 834024/2114441 bytes (39%)
    I: Downloaded 834732/2114441 bytes (39%)
    I: Downloaded 835440/2114441 bytes (39%)
    I: Downloaded 836148/2114441 bytes (39%)
    I: Downloaded 836856/2114441 bytes (39%)
    I: Downloaded 837564/2114441 bytes (39%)
    I: Downloaded 838272/2114441 bytes (39%)
    I: Downloaded 838980/2114441 bytes (39%)
    I: Downloaded 839688/2114441 bytes (39%)
    I: Downloaded 840396/2114441 bytes (39%)
    I: Downloaded 841104/2114441 bytes (39%)
    I: Downloaded 841812/2114441 bytes (39%)
    I: Downloaded 842520/2114441 bytes (39%)
    I: Downloaded 843228/2114441 bytes (39%)
    I: Downloaded 843936/2114441 bytes (39%)
    I: Downloaded 844644/2114441 bytes (39%)
    I: Downloaded 845352/2114441 bytes (39%)
    I: Downloaded 846060/2114441 bytes (40%)
    I: Downloaded 846768/2114441 bytes (40%)
    I: Downloaded 847476/2114441 bytes (40%)
    I: Downloaded 848184/2114441 bytes (40%)
    I: Downloaded 848892/2114441 bytes (40%)
    I: Downloaded 849600/2114441 bytes (40%)
    I: Downloaded 850308/2114441 bytes (40%)
    I: Downloaded 851016/2114441 bytes (40%)
    I: Downloaded 851724/2114441 bytes (40%)
    I: Downloaded 852432/2114441 bytes (40%)
    I: Downloaded 853140/2114441 bytes (40%)
    I: Downloaded 853848/2114441 bytes (40%)
    I: Downloaded 854556/2114441 bytes (40%)
    I: Downloaded 855264/2114441 bytes (40%)
    I: Downloaded 855972/2114441 bytes (40%)
    I: Downloaded 856680/2114441 bytes (40%)
    I: Downloaded 858728/2114441 bytes (40%)
    I: Downloaded 860776/2114441 bytes (40%)
    I: Downloaded 862824/2114441 bytes (40%)
    I: Downloaded 864468/2114441 bytes (40%)
    I: Downloaded 865176/2114441 bytes (40%)
    I: Downloaded 865884/2114441 bytes (40%)
    I: Downloaded 866592/2114441 bytes (40%)
    I: Downloaded 867300/2114441 bytes (41%)
    I: Downloaded 868008/2114441 bytes (41%)
    I: Downloaded 868716/2114441 bytes (41%)
    I: Downloaded 869424/2114441 bytes (41%)
    I: Downloaded 870132/2114441 bytes (41%)
    I: Downloaded 870840/2114441 bytes (41%)
    I: Downloaded 871548/2114441 bytes (41%)
    I: Downloaded 872256/2114441 bytes (41%)
    I: Downloaded 872964/2114441 bytes (41%)
    I: Downloaded 873672/2114441 bytes (41%)
    I: Downloaded 874380/2114441 bytes (41%)
    I: Downloaded 875088/2114441 bytes (41%)
    I: Downloaded 875796/2114441 bytes (41%)
    I: Downloaded 876504/2114441 bytes (41%)
    I: Downloaded 877212/2114441 bytes (41%)
    I: Downloaded 877920/2114441 bytes (41%)
    I: Downloaded 878628/2114441 bytes (41%)
    I: Downloaded 879336/2114441 bytes (41%)
    I: Downloaded 880044/2114441 bytes (41%)
    I: Downloaded 880752/2114441 bytes (41%)
    I: Downloaded 881460/2114441 bytes (41%)
    I: Downloaded 882168/2114441 bytes (41%)
    I: Downloaded 882876/2114441 bytes (41%)
    I: Downloaded 883584/2114441 bytes (41%)
    I: Downloaded 884292/2114441 bytes (41%)
    I: Downloaded 885000/2114441 bytes (41%)
    I: Downloaded 885708/2114441 bytes (41%)
    I: Downloaded 886416/2114441 bytes (41%)
    I: Downloaded 887124/2114441 bytes (41%)
    I: Downloaded 887832/2114441 bytes (41%)
    I: Downloaded 888540/2114441 bytes (42%)
    I: Downloaded 889248/2114441 bytes (42%)
    I: Downloaded 889956/2114441 bytes (42%)
    I: Downloaded 890664/2114441 bytes (42%)
    I: Downloaded 891372/2114441 bytes (42%)
    I: Downloaded 892080/2114441 bytes (42%)
    I: Downloaded 892788/2114441 bytes (42%)
    I: Downloaded 893496/2114441 bytes (42%)
    I: Downloaded 894204/2114441 bytes (42%)
    I: Downloaded 894912/2114441 bytes (42%)
    I: Downloaded 895620/2114441 bytes (42%)
    I: Downloaded 896328/2114441 bytes (42%)
    I: Downloaded 897036/2114441 bytes (42%)
    I: Downloaded 897744/2114441 bytes (42%)
    I: Downloaded 898452/2114441 bytes (42%)
    I: Downloaded 899160/2114441 bytes (42%)
    I: Downloaded 899868/2114441 bytes (42%)
    I: Downloaded 900576/2114441 bytes (42%)
    I: Downloaded 901284/2114441 bytes (42%)
    I: Downloaded 901992/2114441 bytes (42%)
    I: Downloaded 902700/2114441 bytes (42%)
    I: Downloaded 903408/2114441 bytes (42%)
    I: Downloaded 904116/2114441 bytes (42%)
    I: Downloaded 904824/2114441 bytes (42%)
    I: Downloaded 905532/2114441 bytes (42%)
    I: Downloaded 906240/2114441 bytes (42%)
    I: Downloaded 906948/2114441 bytes (42%)
    I: Downloaded 907656/2114441 bytes (42%)
    I: Downloaded 908364/2114441 bytes (42%)
    I: Downloaded 909072/2114441 bytes (42%)
    I: Downloaded 909780/2114441 bytes (43%)
    I: Downloaded 910488/2114441 bytes (43%)
    I: Downloaded 911196/2114441 bytes (43%)
    I: Downloaded 911904/2114441 bytes (43%)
    I: Downloaded 912612/2114441 bytes (43%)
    I: Downloaded 913320/2114441 bytes (43%)
    I: Downloaded 914028/2114441 bytes (43%)
    I: Downloaded 914736/2114441 bytes (43%)
    I: Downloaded 915444/2114441 bytes (43%)
    I: Downloaded 916152/2114441 bytes (43%)
    I: Downloaded 916860/2114441 bytes (43%)
    I: Downloaded 917568/2114441 bytes (43%)
    I: Downloaded 918276/2114441 bytes (43%)
    I: Downloaded 918984/2114441 bytes (43%)
    I: Downloaded 919692/2114441 bytes (43%)
    I: Downloaded 920400/2114441 bytes (43%)
    I: Downloaded 921108/2114441 bytes (43%)
    I: Downloaded 921816/2114441 bytes (43%)
    I: Downloaded 923864/2114441 bytes (43%)
    I: Downloaded 925912/2114441 bytes (43%)
    I: Downloaded 927960/2114441 bytes (43%)
    I: Downloaded 929604/2114441 bytes (43%)
    I: Downloaded 931652/2114441 bytes (44%)
    I: Downloaded 931728/2114441 bytes (44%)
    I: Downloaded 933144/2114441 bytes (44%)
    I: Downloaded 933852/2114441 bytes (44%)
    I: Downloaded 934560/2114441 bytes (44%)
    I: Downloaded 935268/2114441 bytes (44%)
    I: Downloaded 935976/2114441 bytes (44%)
    I: Downloaded 936684/2114441 bytes (44%)
    I: Downloaded 937392/2114441 bytes (44%)
    I: Downloaded 938100/2114441 bytes (44%)
    I: Downloaded 938808/2114441 bytes (44%)
    I: Downloaded 939516/2114441 bytes (44%)
    I: Downloaded 940224/2114441 bytes (44%)
    I: Downloaded 940932/2114441 bytes (44%)
    I: Downloaded 941640/2114441 bytes (44%)
    I: Downloaded 942348/2114441 bytes (44%)
    I: Downloaded 943056/2114441 bytes (44%)
    I: Downloaded 943764/2114441 bytes (44%)
    I: Downloaded 944472/2114441 bytes (44%)
    I: Downloaded 945180/2114441 bytes (44%)
    I: Downloaded 945888/2114441 bytes (44%)
    I: Downloaded 946596/2114441 bytes (44%)
    I: Downloaded 947304/2114441 bytes (44%)
    I: Downloaded 948012/2114441 bytes (44%)
    I: Downloaded 948720/2114441 bytes (44%)
    I: Downloaded 949428/2114441 bytes (44%)
    I: Downloaded 950136/2114441 bytes (44%)
    I: Downloaded 950844/2114441 bytes (44%)
    I: Downloaded 951552/2114441 bytes (45%)
    I: Downloaded 952260/2114441 bytes (45%)
    I: Downloaded 952968/2114441 bytes (45%)
    I: Downloaded 953676/2114441 bytes (45%)
    I: Downloaded 954384/2114441 bytes (45%)
    I: Downloaded 955092/2114441 bytes (45%)
    I: Downloaded 955800/2114441 bytes (45%)
    I: Downloaded 956508/2114441 bytes (45%)
    I: Downloaded 957216/2114441 bytes (45%)
    I: Downloaded 957924/2114441 bytes (45%)
    I: Downloaded 958632/2114441 bytes (45%)
    I: Downloaded 959340/2114441 bytes (45%)
    I: Downloaded 960048/2114441 bytes (45%)
    I: Downloaded 960756/2114441 bytes (45%)
    I: Downloaded 961464/2114441 bytes (45%)
    I: Downloaded 962172/2114441 bytes (45%)
    I: Downloaded 962880/2114441 bytes (45%)
    I: Downloaded 963588/2114441 bytes (45%)
    I: Downloaded 964296/2114441 bytes (45%)
    I: Downloaded 965004/2114441 bytes (45%)
    I: Downloaded 965712/2114441 bytes (45%)
    I: Downloaded 966420/2114441 bytes (45%)
    I: Downloaded 967128/2114441 bytes (45%)
    I: Downloaded 967836/2114441 bytes (45%)
    I: Downloaded 968544/2114441 bytes (45%)
    I: Downloaded 969252/2114441 bytes (45%)
    I: Downloaded 969960/2114441 bytes (45%)
    I: Downloaded 970668/2114441 bytes (45%)
    I: Downloaded 971376/2114441 bytes (45%)
    I: Downloaded 972084/2114441 bytes (45%)
    I: Downloaded 972792/2114441 bytes (46%)
    I: Downloaded 973500/2114441 bytes (46%)
    I: Downloaded 974208/2114441 bytes (46%)
    I: Downloaded 974916/2114441 bytes (46%)
    I: Downloaded 975624/2114441 bytes (46%)
    I: Downloaded 976332/2114441 bytes (46%)
    I: Downloaded 977040/2114441 bytes (46%)
    I: Downloaded 977748/2114441 bytes (46%)
    I: Downloaded 978456/2114441 bytes (46%)
    I: Downloaded 979164/2114441 bytes (46%)
    I: Downloaded 979872/2114441 bytes (46%)
    I: Downloaded 980580/2114441 bytes (46%)
    I: Downloaded 981288/2114441 bytes (46%)
    I: Downloaded 981996/2114441 bytes (46%)
    I: Downloaded 982704/2114441 bytes (46%)
    I: Downloaded 983412/2114441 bytes (46%)
    I: Downloaded 984120/2114441 bytes (46%)
    I: Downloaded 984828/2114441 bytes (46%)
    I: Downloaded 985536/2114441 bytes (46%)
    I: Downloaded 986244/2114441 bytes (46%)
    I: Downloaded 986952/2114441 bytes (46%)
    I: Downloaded 987660/2114441 bytes (46%)
    I: Downloaded 989708/2114441 bytes (46%)
    I: Downloaded 991756/2114441 bytes (46%)
    I: Downloaded 993804/2114441 bytes (47%)
    I: Downloaded 995448/2114441 bytes (47%)
    I: Downloaded 996472/2114441 bytes (47%)
    I: Downloaded 997572/2114441 bytes (47%)
    I: Downloaded 998988/2114441 bytes (47%)
    I: Downloaded 999696/2114441 bytes (47%)
    I: Downloaded 1000404/2114441 bytes (47%)
    I: Downloaded 1001112/2114441 bytes (47%)
    I: Downloaded 1001820/2114441 bytes (47%)
    I: Downloaded 1002528/2114441 bytes (47%)
    I: Downloaded 1003236/2114441 bytes (47%)
    I: Downloaded 1003868/2114441 bytes (47%)
    I: Downloaded 1004576/2114441 bytes (47%)
    I: Downloaded 1005360/2114441 bytes (47%)
    I: Downloaded 1006068/2114441 bytes (47%)
    I: Downloaded 1006776/2114441 bytes (47%)
    I: Downloaded 1007484/2114441 bytes (47%)
    I: Downloaded 1008192/2114441 bytes (47%)
    I: Downloaded 1008900/2114441 bytes (47%)
    I: Downloaded 1009608/2114441 bytes (47%)
    I: Downloaded 1010316/2114441 bytes (47%)
    I: Downloaded 1010948/2114441 bytes (47%)
    I: Downloaded 1011024/2114441 bytes (47%)
    I: Downloaded 1011732/2114441 bytes (47%)
    I: Downloaded 1012440/2114441 bytes (47%)
    I: Downloaded 1013148/2114441 bytes (47%)
    I: Downloaded 1013856/2114441 bytes (47%)
    I: Downloaded 1014564/2114441 bytes (47%)
    I: Downloaded 1015272/2114441 bytes (48%)
    I: Downloaded 1015980/2114441 bytes (48%)
    I: Downloaded 1016688/2114441 bytes (48%)
    I: Downloaded 1017396/2114441 bytes (48%)
    I: Downloaded 1018104/2114441 bytes (48%)
    I: Downloaded 1018812/2114441 bytes (48%)
    I: Downloaded 1019520/2114441 bytes (48%)
    I: Downloaded 1020228/2114441 bytes (48%)
    I: Downloaded 1020936/2114441 bytes (48%)
    I: Downloaded 1021644/2114441 bytes (48%)
    I: Downloaded 1022352/2114441 bytes (48%)
    I: Downloaded 1023060/2114441 bytes (48%)
    I: Downloaded 1023768/2114441 bytes (48%)
    I: Downloaded 1024476/2114441 bytes (48%)
    I: Downloaded 1025184/2114441 bytes (48%)
    I: Downloaded 1025892/2114441 bytes (48%)
    I: Downloaded 1026600/2114441 bytes (48%)
    I: Downloaded 1027308/2114441 bytes (48%)
    I: Downloaded 1028016/2114441 bytes (48%)
    I: Downloaded 1028724/2114441 bytes (48%)
    I: Downloaded 1029432/2114441 bytes (48%)
    I: Downloaded 1030140/2114441 bytes (48%)
    I: Downloaded 1030848/2114441 bytes (48%)
    I: Downloaded 1031556/2114441 bytes (48%)
    I: Downloaded 1032264/2114441 bytes (48%)
    I: Downloaded 1032972/2114441 bytes (48%)
    I: Downloaded 1033680/2114441 bytes (48%)
    I: Downloaded 1034388/2114441 bytes (48%)
    I: Downloaded 1035096/2114441 bytes (48%)
    I: Downloaded 1035804/2114441 bytes (48%)
    I: Downloaded 1036512/2114441 bytes (49%)
    I: Downloaded 1037220/2114441 bytes (49%)
    I: Downloaded 1037928/2114441 bytes (49%)
    I: Downloaded 1038636/2114441 bytes (49%)
    I: Downloaded 1039344/2114441 bytes (49%)
    I: Downloaded 1040052/2114441 bytes (49%)
    I: Downloaded 1040760/2114441 bytes (49%)
    I: Downloaded 1041468/2114441 bytes (49%)
    I: Downloaded 1042176/2114441 bytes (49%)
    I: Downloaded 1042884/2114441 bytes (49%)
    I: Downloaded 1043592/2114441 bytes (49%)
    I: Downloaded 1044300/2114441 bytes (49%)
    I: Downloaded 1045008/2114441 bytes (49%)
    I: Downloaded 1045716/2114441 bytes (49%)
    I: Downloaded 1046424/2114441 bytes (49%)
    I: Downloaded 1047132/2114441 bytes (49%)
    I: Downloaded 1047840/2114441 bytes (49%)
    I: Downloaded 1048548/2114441 bytes (49%)
    I: Downloaded 1049256/2114441 bytes (49%)
    I: Downloaded 1049964/2114441 bytes (49%)
    I: Downloaded 1050672/2114441 bytes (49%)
    I: Downloaded 1051380/2114441 bytes (49%)
    I: Downloaded 1052088/2114441 bytes (49%)
    I: Downloaded 1052796/2114441 bytes (49%)
    I: Downloaded 1054844/2114441 bytes (49%)
    I: Downloaded 1056892/2114441 bytes (49%)
    I: Downloaded 1058940/2114441 bytes (50%)
    I: Downloaded 1059168/2114441 bytes (50%)
    I: Downloaded 1059876/2114441 bytes (50%)
    I: Downloaded 1060584/2114441 bytes (50%)
    I: Downloaded 1061292/2114441 bytes (50%)
    I: Downloaded 1062000/2114441 bytes (50%)
    I: Downloaded 1062708/2114441 bytes (50%)
    I: Downloaded 1063416/2114441 bytes (50%)
    I: Downloaded 1064124/2114441 bytes (50%)
    I: Downloaded 1064832/2114441 bytes (50%)
    I: Downloaded 1065540/2114441 bytes (50%)
    I: Downloaded 1066248/2114441 bytes (50%)
    I: Downloaded 1066956/2114441 bytes (50%)
    I: Downloaded 1067664/2114441 bytes (50%)
    I: Downloaded 1068372/2114441 bytes (50%)
    I: Downloaded 1069080/2114441 bytes (50%)
    I: Downloaded 1069788/2114441 bytes (50%)
    I: Downloaded 1070496/2114441 bytes (50%)
    I: Downloaded 1071204/2114441 bytes (50%)
    I: Downloaded 1071912/2114441 bytes (50%)
    I: Downloaded 1072620/2114441 bytes (50%)
    I: Downloaded 1073328/2114441 bytes (50%)
    I: Downloaded 1074036/2114441 bytes (50%)
    I: Downloaded 1074744/2114441 bytes (50%)
    I: Downloaded 1075452/2114441 bytes (50%)
    I: Downloaded 1076160/2114441 bytes (50%)
    I: Downloaded 1076868/2114441 bytes (50%)
    I: Downloaded 1077576/2114441 bytes (50%)
    I: Downloaded 1078284/2114441 bytes (50%)
    I: Downloaded 1078992/2114441 bytes (51%)
    I: Downloaded 1079700/2114441 bytes (51%)
    I: Downloaded 1080408/2114441 bytes (51%)
    I: Downloaded 1081116/2114441 bytes (51%)
    I: Downloaded 1081824/2114441 bytes (51%)
    I: Downloaded 1082532/2114441 bytes (51%)
    I: Downloaded 1083240/2114441 bytes (51%)
    I: Downloaded 1083948/2114441 bytes (51%)
    I: Downloaded 1084656/2114441 bytes (51%)
    I: Downloaded 1085364/2114441 bytes (51%)
    I: Downloaded 1086072/2114441 bytes (51%)
    I: Downloaded 1086780/2114441 bytes (51%)
    I: Downloaded 1087488/2114441 bytes (51%)
    I: Downloaded 1088196/2114441 bytes (51%)
    I: Downloaded 1088904/2114441 bytes (51%)
    I: Downloaded 1089612/2114441 bytes (51%)
    I: Downloaded 1090320/2114441 bytes (51%)
    I: Downloaded 1091028/2114441 bytes (51%)
    I: Downloaded 1091736/2114441 bytes (51%)
    I: Downloaded 1092444/2114441 bytes (51%)
    I: Downloaded 1093152/2114441 bytes (51%)
    I: Downloaded 1093860/2114441 bytes (51%)
    I: Downloaded 1094568/2114441 bytes (51%)
    I: Downloaded 1095276/2114441 bytes (51%)
    I: Downloaded 1095984/2114441 bytes (51%)
    I: Downloaded 1096692/2114441 bytes (51%)
    I: Downloaded 1097400/2114441 bytes (51%)
    I: Downloaded 1098108/2114441 bytes (51%)
    I: Downloaded 1098816/2114441 bytes (51%)
    I: Downloaded 1099524/2114441 bytes (52%)
    I: Downloaded 1100232/2114441 bytes (52%)
    I: Downloaded 1100940/2114441 bytes (52%)
    I: Downloaded 1101648/2114441 bytes (52%)
    I: Downloaded 1102356/2114441 bytes (52%)
    I: Downloaded 1103064/2114441 bytes (52%)
    I: Downloaded 1103772/2114441 bytes (52%)
    I: Downloaded 1104480/2114441 bytes (52%)
    I: Downloaded 1105188/2114441 bytes (52%)
    I: Downloaded 1105896/2114441 bytes (52%)
    I: Downloaded 1106604/2114441 bytes (52%)
    I: Downloaded 1107312/2114441 bytes (52%)
    I: Downloaded 1108020/2114441 bytes (52%)
    I: Downloaded 1108728/2114441 bytes (52%)
    I: Downloaded 1109436/2114441 bytes (52%)
    I: Downloaded 1110144/2114441 bytes (52%)
    I: Downloaded 1110852/2114441 bytes (52%)
    I: Downloaded 1111560/2114441 bytes (52%)
    I: Downloaded 1112268/2114441 bytes (52%)
    I: Downloaded 1112976/2114441 bytes (52%)
    I: Downloaded 1113684/2114441 bytes (52%)
    I: Downloaded 1114392/2114441 bytes (52%)
    I: Downloaded 1115100/2114441 bytes (52%)
    I: Downloaded 1115808/2114441 bytes (52%)
    I: Downloaded 1116516/2114441 bytes (52%)
    I: Downloaded 1117224/2114441 bytes (52%)
    I: Downloaded 1117932/2114441 bytes (52%)
    I: Downloaded 1118640/2114441 bytes (52%)
    I: Downloaded 1120688/2114441 bytes (53%)
    I: Downloaded 1122736/2114441 bytes (53%)
    I: Downloaded 1124784/2114441 bytes (53%)
    I: Downloaded 1126428/2114441 bytes (53%)
    I: Downloaded 1127844/2114441 bytes (53%)
    I: Downloaded 1128552/2114441 bytes (53%)
    I: Downloaded 1129968/2114441 bytes (53%)
    I: Downloaded 1130676/2114441 bytes (53%)
    I: Downloaded 1131384/2114441 bytes (53%)
    I: Downloaded 1132092/2114441 bytes (53%)
    I: Downloaded 1132800/2114441 bytes (53%)
    I: Downloaded 1133508/2114441 bytes (53%)
    I: Downloaded 1134216/2114441 bytes (53%)
    I: Downloaded 1134924/2114441 bytes (53%)
    I: Downloaded 1135632/2114441 bytes (53%)
    I: Downloaded 1136340/2114441 bytes (53%)
    I: Downloaded 1137048/2114441 bytes (53%)
    I: Downloaded 1137756/2114441 bytes (53%)
    I: Downloaded 1138464/2114441 bytes (53%)
    I: Downloaded 1139172/2114441 bytes (53%)
    I: Downloaded 1139880/2114441 bytes (53%)
    I: Downloaded 1140588/2114441 bytes (53%)
    I: Downloaded 1141296/2114441 bytes (53%)
    I: Downloaded 1142004/2114441 bytes (54%)
    I: Downloaded 1142712/2114441 bytes (54%)
    I: Downloaded 1143420/2114441 bytes (54%)
    I: Downloaded 1144128/2114441 bytes (54%)
    I: Downloaded 1144836/2114441 bytes (54%)
    I: Downloaded 1145544/2114441 bytes (54%)
    I: Downloaded 1146252/2114441 bytes (54%)
    I: Downloaded 1146960/2114441 bytes (54%)
    I: Downloaded 1147668/2114441 bytes (54%)
    I: Downloaded 1148376/2114441 bytes (54%)
    I: Downloaded 1149084/2114441 bytes (54%)
    I: Downloaded 1149792/2114441 bytes (54%)
    I: Downloaded 1150500/2114441 bytes (54%)
    I: Downloaded 1151208/2114441 bytes (54%)
    I: Downloaded 1151916/2114441 bytes (54%)
    I: Downloaded 1152624/2114441 bytes (54%)
    I: Downloaded 1153332/2114441 bytes (54%)
    I: Downloaded 1154040/2114441 bytes (54%)
    I: Downloaded 1154748/2114441 bytes (54%)
    I: Downloaded 1155456/2114441 bytes (54%)
    I: Downloaded 1156164/2114441 bytes (54%)
    I: Downloaded 1156872/2114441 bytes (54%)
    I: Downloaded 1157580/2114441 bytes (54%)
    I: Downloaded 1158288/2114441 bytes (54%)
    I: Downloaded 1158996/2114441 bytes (54%)
    I: Downloaded 1159704/2114441 bytes (54%)
    I: Downloaded 1160412/2114441 bytes (54%)
    I: Downloaded 1161120/2114441 bytes (54%)
    I: Downloaded 1161828/2114441 bytes (54%)
    I: Downloaded 1162536/2114441 bytes (54%)
    I: Downloaded 1163244/2114441 bytes (55%)
    I: Downloaded 1163952/2114441 bytes (55%)
    I: Downloaded 1164660/2114441 bytes (55%)
    I: Downloaded 1165368/2114441 bytes (55%)
    I: Downloaded 1166076/2114441 bytes (55%)
    I: Downloaded 1166784/2114441 bytes (55%)
    I: Downloaded 1167492/2114441 bytes (55%)
    I: Downloaded 1168200/2114441 bytes (55%)
    I: Downloaded 1168908/2114441 bytes (55%)
    I: Downloaded 1169616/2114441 bytes (55%)
    I: Downloaded 1170324/2114441 bytes (55%)
    I: Downloaded 1171032/2114441 bytes (55%)
    I: Downloaded 1171740/2114441 bytes (55%)
    I: Downloaded 1172448/2114441 bytes (55%)
    I: Downloaded 1173156/2114441 bytes (55%)
    I: Downloaded 1173864/2114441 bytes (55%)
    I: Downloaded 1174572/2114441 bytes (55%)
    I: Downloaded 1175280/2114441 bytes (55%)
    I: Downloaded 1175988/2114441 bytes (55%)
    I: Downloaded 1176696/2114441 bytes (55%)
    I: Downloaded 1177404/2114441 bytes (55%)
    I: Downloaded 1178112/2114441 bytes (55%)
    I: Downloaded 1178820/2114441 bytes (55%)
    I: Downloaded 1179528/2114441 bytes (55%)
    I: Downloaded 1180236/2114441 bytes (55%)
    I: Downloaded 1180944/2114441 bytes (55%)
    I: Downloaded 1181652/2114441 bytes (55%)
    I: Downloaded 1182360/2114441 bytes (55%)
    I: Downloaded 1183068/2114441 bytes (55%)
    I: Downloaded 1183776/2114441 bytes (55%)
    I: Downloaded 1185824/2114441 bytes (56%)
    I: Downloaded 1187872/2114441 bytes (56%)
    I: Downloaded 1189920/2114441 bytes (56%)
    I: Downloaded 1191564/2114441 bytes (56%)
    I: Downloaded 1193612/2114441 bytes (56%)
    I: Downloaded 1193688/2114441 bytes (56%)
    I: Downloaded 1194712/2114441 bytes (56%)
    I: Downloaded 1195812/2114441 bytes (56%)
    I: Downloaded 1196520/2114441 bytes (56%)
    I: Downloaded 1197936/2114441 bytes (56%)
    I: Downloaded 1198644/2114441 bytes (56%)
    I: Downloaded 1199352/2114441 bytes (56%)
    I: Downloaded 1200060/2114441 bytes (56%)
    I: Downloaded 1200768/2114441 bytes (56%)
    I: Downloaded 1201476/2114441 bytes (56%)
    I: Downloaded 1202184/2114441 bytes (56%)
    I: Downloaded 1202892/2114441 bytes (56%)
    I: Downloaded 1203600/2114441 bytes (56%)
    I: Downloaded 1204308/2114441 bytes (56%)
    I: Downloaded 1205016/2114441 bytes (56%)
    I: Downloaded 1205724/2114441 bytes (57%)
    I: Downloaded 1206432/2114441 bytes (57%)
    I: Downloaded 1207140/2114441 bytes (57%)
    I: Downloaded 1207848/2114441 bytes (57%)
    I: Downloaded 1208556/2114441 bytes (57%)
    I: Downloaded 1209264/2114441 bytes (57%)
    I: Downloaded 1209972/2114441 bytes (57%)
    I: Downloaded 1210680/2114441 bytes (57%)
    I: Downloaded 1211388/2114441 bytes (57%)
    I: Downloaded 1212096/2114441 bytes (57%)
    I: Downloaded 1212804/2114441 bytes (57%)
    I: Downloaded 1213512/2114441 bytes (57%)
    I: Downloaded 1214220/2114441 bytes (57%)
    I: Downloaded 1214928/2114441 bytes (57%)
    I: Downloaded 1215636/2114441 bytes (57%)
    I: Downloaded 1216344/2114441 bytes (57%)
    I: Downloaded 1217052/2114441 bytes (57%)
    I: Downloaded 1217760/2114441 bytes (57%)
    I: Downloaded 1218468/2114441 bytes (57%)
    I: Downloaded 1219176/2114441 bytes (57%)
    I: Downloaded 1219884/2114441 bytes (57%)
    I: Downloaded 1220592/2114441 bytes (57%)
    I: Downloaded 1221300/2114441 bytes (57%)
    I: Downloaded 1222008/2114441 bytes (57%)
    I: Downloaded 1222716/2114441 bytes (57%)
    I: Downloaded 1223424/2114441 bytes (57%)
    I: Downloaded 1224132/2114441 bytes (57%)
    I: Downloaded 1224840/2114441 bytes (57%)
    I: Downloaded 1225548/2114441 bytes (57%)
    I: Downloaded 1226256/2114441 bytes (57%)
    I: Downloaded 1226964/2114441 bytes (58%)
    I: Downloaded 1227672/2114441 bytes (58%)
    I: Downloaded 1228380/2114441 bytes (58%)
    I: Downloaded 1229088/2114441 bytes (58%)
    I: Downloaded 1229796/2114441 bytes (58%)
    I: Downloaded 1230504/2114441 bytes (58%)
    I: Downloaded 1231212/2114441 bytes (58%)
    I: Downloaded 1231920/2114441 bytes (58%)
    I: Downloaded 1232628/2114441 bytes (58%)
    I: Downloaded 1233336/2114441 bytes (58%)
    I: Downloaded 1234044/2114441 bytes (58%)
    I: Downloaded 1234752/2114441 bytes (58%)
    I: Downloaded 1235460/2114441 bytes (58%)
    I: Downloaded 1236168/2114441 bytes (58%)
    I: Downloaded 1236876/2114441 bytes (58%)
    I: Downloaded 1237584/2114441 bytes (58%)
    I: Downloaded 1238292/2114441 bytes (58%)
    I: Downloaded 1239000/2114441 bytes (58%)
    I: Downloaded 1239708/2114441 bytes (58%)
    I: Downloaded 1240416/2114441 bytes (58%)
    I: Downloaded 1241124/2114441 bytes (58%)
    I: Downloaded 1241832/2114441 bytes (58%)
    I: Downloaded 1242540/2114441 bytes (58%)
    I: Downloaded 1243248/2114441 bytes (58%)
    I: Downloaded 1243956/2114441 bytes (58%)
    I: Downloaded 1244664/2114441 bytes (58%)
    I: Downloaded 1245372/2114441 bytes (58%)
    I: Downloaded 1246080/2114441 bytes (58%)
    I: Downloaded 1246788/2114441 bytes (58%)
    I: Downloaded 1247496/2114441 bytes (58%)
    I: Downloaded 1248204/2114441 bytes (59%)
    I: Downloaded 1248912/2114441 bytes (59%)
    I: Downloaded 1249620/2114441 bytes (59%)
    I: Downloaded 1251668/2114441 bytes (59%)
    I: Downloaded 1253716/2114441 bytes (59%)
    I: Downloaded 1255764/2114441 bytes (59%)
    I: Downloaded 1257408/2114441 bytes (59%)
    I: Downloaded 1258116/2114441 bytes (59%)
    I: Downloaded 1258824/2114441 bytes (59%)
    I: Downloaded 1259532/2114441 bytes (59%)
    I: Downloaded 1260240/2114441 bytes (59%)
    I: Downloaded 1260948/2114441 bytes (59%)
    I: Downloaded 1261656/2114441 bytes (59%)
    I: Downloaded 1262364/2114441 bytes (59%)
    I: Downloaded 1263072/2114441 bytes (59%)
    I: Downloaded 1263780/2114441 bytes (59%)
    I: Downloaded 1264488/2114441 bytes (59%)
    I: Downloaded 1265196/2114441 bytes (59%)
    I: Downloaded 1265904/2114441 bytes (59%)
    I: Downloaded 1266612/2114441 bytes (59%)
    I: Downloaded 1267320/2114441 bytes (59%)
    I: Downloaded 1268028/2114441 bytes (59%)
    I: Downloaded 1268736/2114441 bytes (60%)
    I: Downloaded 1269444/2114441 bytes (60%)
    I: Downloaded 1270152/2114441 bytes (60%)
    I: Downloaded 1270860/2114441 bytes (60%)
    I: Downloaded 1271568/2114441 bytes (60%)
    I: Downloaded 1272276/2114441 bytes (60%)
    I: Downloaded 1272984/2114441 bytes (60%)
    I: Downloaded 1273692/2114441 bytes (60%)
    I: Downloaded 1274400/2114441 bytes (60%)
    I: Downloaded 1275108/2114441 bytes (60%)
    I: Downloaded 1275816/2114441 bytes (60%)
    I: Downloaded 1276524/2114441 bytes (60%)
    I: Downloaded 1277232/2114441 bytes (60%)
    I: Downloaded 1277940/2114441 bytes (60%)
    I: Downloaded 1278648/2114441 bytes (60%)
    I: Downloaded 1279356/2114441 bytes (60%)
    I: Downloaded 1280064/2114441 bytes (60%)
    I: Downloaded 1280772/2114441 bytes (60%)
    I: Downloaded 1281480/2114441 bytes (60%)
    I: Downloaded 1282188/2114441 bytes (60%)
    I: Downloaded 1282896/2114441 bytes (60%)
    I: Downloaded 1283604/2114441 bytes (60%)
    I: Downloaded 1284312/2114441 bytes (60%)
    I: Downloaded 1285020/2114441 bytes (60%)
    I: Downloaded 1285728/2114441 bytes (60%)
    I: Downloaded 1286436/2114441 bytes (60%)
    I: Downloaded 1287144/2114441 bytes (60%)
    I: Downloaded 1287852/2114441 bytes (60%)
    I: Downloaded 1288560/2114441 bytes (60%)
    I: Downloaded 1289268/2114441 bytes (60%)
    I: Downloaded 1289976/2114441 bytes (61%)
    I: Downloaded 1290684/2114441 bytes (61%)
    I: Downloaded 1291392/2114441 bytes (61%)
    I: Downloaded 1292100/2114441 bytes (61%)
    I: Downloaded 1292808/2114441 bytes (61%)
    I: Downloaded 1293516/2114441 bytes (61%)
    I: Downloaded 1294224/2114441 bytes (61%)
    I: Downloaded 1294932/2114441 bytes (61%)
    I: Downloaded 1295640/2114441 bytes (61%)
    I: Downloaded 1296348/2114441 bytes (61%)
    I: Downloaded 1297056/2114441 bytes (61%)
    I: Downloaded 1297764/2114441 bytes (61%)
    I: Downloaded 1298472/2114441 bytes (61%)
    I: Downloaded 1299180/2114441 bytes (61%)
    I: Downloaded 1299888/2114441 bytes (61%)
    I: Downloaded 1300596/2114441 bytes (61%)
    I: Downloaded 1301304/2114441 bytes (61%)
    I: Downloaded 1302012/2114441 bytes (61%)
    I: Downloaded 1302720/2114441 bytes (61%)
    I: Downloaded 1303428/2114441 bytes (61%)
    I: Downloaded 1304136/2114441 bytes (61%)
    I: Downloaded 1304844/2114441 bytes (61%)
    I: Downloaded 1305552/2114441 bytes (61%)
    I: Downloaded 1306260/2114441 bytes (61%)
    I: Downloaded 1306968/2114441 bytes (61%)
    I: Downloaded 1307676/2114441 bytes (61%)
    I: Downloaded 1308384/2114441 bytes (61%)
    I: Downloaded 1309092/2114441 bytes (61%)
    I: Downloaded 1309800/2114441 bytes (61%)
    I: Downloaded 1310508/2114441 bytes (61%)
    I: Downloaded 1311216/2114441 bytes (62%)
    I: Downloaded 1311924/2114441 bytes (62%)
    I: Downloaded 1312632/2114441 bytes (62%)
    I: Downloaded 1313340/2114441 bytes (62%)
    I: Downloaded 1314048/2114441 bytes (62%)
    I: Downloaded 1314756/2114441 bytes (62%)
    I: Downloaded 1315464/2114441 bytes (62%)
    I: Downloaded 1317512/2114441 bytes (62%)
    I: Downloaded 1319560/2114441 bytes (62%)
    I: Downloaded 1321608/2114441 bytes (62%)
    I: Downloaded 1323252/2114441 bytes (62%)
    I: Downloaded 1323960/2114441 bytes (62%)
    I: Downloaded 1324668/2114441 bytes (62%)
    I: Downloaded 1325376/2114441 bytes (62%)
    I: Downloaded 1326084/2114441 bytes (62%)
    I: Downloaded 1326792/2114441 bytes (62%)
    I: Downloaded 1327500/2114441 bytes (62%)
    I: Downloaded 1328208/2114441 bytes (62%)
    I: Downloaded 1328916/2114441 bytes (62%)
    I: Downloaded 1329624/2114441 bytes (62%)
    I: Downloaded 1330332/2114441 bytes (62%)
    I: Downloaded 1331040/2114441 bytes (62%)
    I: Downloaded 1331748/2114441 bytes (62%)
    I: Downloaded 1332456/2114441 bytes (63%)
    I: Downloaded 1333164/2114441 bytes (63%)
    I: Downloaded 1333872/2114441 bytes (63%)
    I: Downloaded 1334580/2114441 bytes (63%)
    I: Downloaded 1335288/2114441 bytes (63%)
    I: Downloaded 1335996/2114441 bytes (63%)
    I: Downloaded 1336704/2114441 bytes (63%)
    I: Downloaded 1337412/2114441 bytes (63%)
    I: Downloaded 1338120/2114441 bytes (63%)
    I: Downloaded 1338828/2114441 bytes (63%)
    I: Downloaded 1339536/2114441 bytes (63%)
    I: Downloaded 1340244/2114441 bytes (63%)
    I: Downloaded 1340952/2114441 bytes (63%)
    I: Downloaded 1341660/2114441 bytes (63%)
    I: Downloaded 1342368/2114441 bytes (63%)
    I: Downloaded 1343076/2114441 bytes (63%)
    I: Downloaded 1343784/2114441 bytes (63%)
    I: Downloaded 1344492/2114441 bytes (63%)
    I: Downloaded 1345200/2114441 bytes (63%)
    I: Downloaded 1345908/2114441 bytes (63%)
    I: Downloaded 1346616/2114441 bytes (63%)
    I: Downloaded 1347324/2114441 bytes (63%)
    I: Downloaded 1348032/2114441 bytes (63%)
    I: Downloaded 1348740/2114441 bytes (63%)
    I: Downloaded 1349448/2114441 bytes (63%)
    I: Downloaded 1350156/2114441 bytes (63%)
    I: Downloaded 1350864/2114441 bytes (63%)
    I: Downloaded 1351572/2114441 bytes (63%)
    I: Downloaded 1352280/2114441 bytes (63%)
    I: Downloaded 1352988/2114441 bytes (63%)
    I: Downloaded 1353696/2114441 bytes (64%)
    I: Downloaded 1354404/2114441 bytes (64%)
    I: Downloaded 1355112/2114441 bytes (64%)
    I: Downloaded 1355820/2114441 bytes (64%)
    I: Downloaded 1356528/2114441 bytes (64%)
    I: Downloaded 1357236/2114441 bytes (64%)
    I: Downloaded 1357944/2114441 bytes (64%)
    I: Downloaded 1358652/2114441 bytes (64%)
    I: Downloaded 1359360/2114441 bytes (64%)
    I: Downloaded 1360068/2114441 bytes (64%)
    I: Downloaded 1360776/2114441 bytes (64%)
    I: Downloaded 1361484/2114441 bytes (64%)
    I: Downloaded 1362192/2114441 bytes (64%)
    I: Downloaded 1362900/2114441 bytes (64%)
    I: Downloaded 1363608/2114441 bytes (64%)
    I: Downloaded 1364316/2114441 bytes (64%)
    I: Downloaded 1365024/2114441 bytes (64%)
    I: Downloaded 1365732/2114441 bytes (64%)
    I: Downloaded 1366440/2114441 bytes (64%)
    I: Downloaded 1367148/2114441 bytes (64%)
    I: Downloaded 1367856/2114441 bytes (64%)
    I: Downloaded 1368564/2114441 bytes (64%)
    I: Downloaded 1369272/2114441 bytes (64%)
    I: Downloaded 1369980/2114441 bytes (64%)
    I: Downloaded 1370688/2114441 bytes (64%)
    I: Downloaded 1371396/2114441 bytes (64%)
    I: Downloaded 1372104/2114441 bytes (64%)
    I: Downloaded 1372812/2114441 bytes (64%)
    I: Downloaded 1373520/2114441 bytes (64%)
    I: Downloaded 1374228/2114441 bytes (64%)
    I: Downloaded 1374936/2114441 bytes (65%)
    I: Downloaded 1375644/2114441 bytes (65%)
    I: Downloaded 1376352/2114441 bytes (65%)
    I: Downloaded 1377060/2114441 bytes (65%)
    I: Downloaded 1377768/2114441 bytes (65%)
    I: Downloaded 1378476/2114441 bytes (65%)
    I: Downloaded 1379184/2114441 bytes (65%)
    I: Downloaded 1379892/2114441 bytes (65%)
    I: Downloaded 1380600/2114441 bytes (65%)
    I: Downloaded 1382648/2114441 bytes (65%)
    I: Downloaded 1384696/2114441 bytes (65%)
    I: Downloaded 1386744/2114441 bytes (65%)
    I: Downloaded 1386972/2114441 bytes (65%)
    I: Downloaded 1387680/2114441 bytes (65%)
    I: Downloaded 1388388/2114441 bytes (65%)
    I: Downloaded 1389096/2114441 bytes (65%)
    I: Downloaded 1389804/2114441 bytes (65%)
    I: Downloaded 1390512/2114441 bytes (65%)
    I: Downloaded 1391220/2114441 bytes (65%)
    I: Downloaded 1391928/2114441 bytes (65%)
    I: Downloaded 1392636/2114441 bytes (65%)
    I: Downloaded 1393344/2114441 bytes (65%)
    I: Downloaded 1394052/2114441 bytes (65%)
    I: Downloaded 1394760/2114441 bytes (65%)
    I: Downloaded 1395468/2114441 bytes (65%)
    I: Downloaded 1396176/2114441 bytes (66%)
    I: Downloaded 1396884/2114441 bytes (66%)
    I: Downloaded 1397592/2114441 bytes (66%)
    I: Downloaded 1398300/2114441 bytes (66%)
    I: Downloaded 1399008/2114441 bytes (66%)
    I: Downloaded 1399716/2114441 bytes (66%)
    I: Downloaded 1400424/2114441 bytes (66%)
    I: Downloaded 1401132/2114441 bytes (66%)
    I: Downloaded 1401840/2114441 bytes (66%)
    I: Downloaded 1402548/2114441 bytes (66%)
    I: Downloaded 1403256/2114441 bytes (66%)
    I: Downloaded 1403964/2114441 bytes (66%)
    I: Downloaded 1404672/2114441 bytes (66%)
    I: Downloaded 1405380/2114441 bytes (66%)
    I: Downloaded 1406088/2114441 bytes (66%)
    I: Downloaded 1406796/2114441 bytes (66%)
    I: Downloaded 1407504/2114441 bytes (66%)
    I: Downloaded 1408212/2114441 bytes (66%)
    I: Downloaded 1408920/2114441 bytes (66%)
    I: Downloaded 1409628/2114441 bytes (66%)
    I: Downloaded 1410336/2114441 bytes (66%)
    I: Downloaded 1411044/2114441 bytes (66%)
    I: Downloaded 1411752/2114441 bytes (66%)
    I: Downloaded 1412460/2114441 bytes (66%)
    I: Downloaded 1413168/2114441 bytes (66%)
    I: Downloaded 1413876/2114441 bytes (66%)
    I: Downloaded 1414584/2114441 bytes (66%)
    I: Downloaded 1415292/2114441 bytes (66%)
    I: Downloaded 1416000/2114441 bytes (66%)
    I: Downloaded 1416708/2114441 bytes (67%)
    I: Downloaded 1417416/2114441 bytes (67%)
    I: Downloaded 1418124/2114441 bytes (67%)
    I: Downloaded 1418832/2114441 bytes (67%)
    I: Downloaded 1419540/2114441 bytes (67%)
    I: Downloaded 1420248/2114441 bytes (67%)
    I: Downloaded 1420956/2114441 bytes (67%)
    I: Downloaded 1421664/2114441 bytes (67%)
    I: Downloaded 1422372/2114441 bytes (67%)
    I: Downloaded 1423080/2114441 bytes (67%)
    I: Downloaded 1423788/2114441 bytes (67%)
    I: Downloaded 1424496/2114441 bytes (67%)
    I: Downloaded 1425204/2114441 bytes (67%)
    I: Downloaded 1425912/2114441 bytes (67%)
    I: Downloaded 1426620/2114441 bytes (67%)
    I: Downloaded 1427328/2114441 bytes (67%)
    I: Downloaded 1428036/2114441 bytes (67%)
    I: Downloaded 1428744/2114441 bytes (67%)
    I: Downloaded 1429452/2114441 bytes (67%)
    I: Downloaded 1430160/2114441 bytes (67%)
    I: Downloaded 1430868/2114441 bytes (67%)
    I: Downloaded 1431576/2114441 bytes (67%)
    I: Downloaded 1432284/2114441 bytes (67%)
    I: Downloaded 1432992/2114441 bytes (67%)
    I: Downloaded 1433700/2114441 bytes (67%)
    I: Downloaded 1434408/2114441 bytes (67%)
    I: Downloaded 1435116/2114441 bytes (67%)
    I: Downloaded 1435824/2114441 bytes (67%)
    I: Downloaded 1436532/2114441 bytes (67%)
    I: Downloaded 1437240/2114441 bytes (67%)
    I: Downloaded 1437948/2114441 bytes (68%)
    I: Downloaded 1438656/2114441 bytes (68%)
    I: Downloaded 1439364/2114441 bytes (68%)
    I: Downloaded 1440072/2114441 bytes (68%)
    I: Downloaded 1440780/2114441 bytes (68%)
    I: Downloaded 1441488/2114441 bytes (68%)
    I: Downloaded 1442196/2114441 bytes (68%)
    I: Downloaded 1442904/2114441 bytes (68%)
    I: Downloaded 1443612/2114441 bytes (68%)
    I: Downloaded 1444320/2114441 bytes (68%)
    I: Downloaded 1445028/2114441 bytes (68%)
    I: Downloaded 1445736/2114441 bytes (68%)
    I: Downloaded 1446444/2114441 bytes (68%)
    I: Downloaded 1448492/2114441 bytes (68%)
    I: Downloaded 1450540/2114441 bytes (68%)
    I: Downloaded 1452588/2114441 bytes (68%)
    I: Downloaded 1454232/2114441 bytes (68%)
    I: Downloaded 1455648/2114441 bytes (68%)
    I: Downloaded 1456356/2114441 bytes (68%)
    I: Downloaded 1457380/2114441 bytes (68%)
    I: Downloaded 1458480/2114441 bytes (68%)
    I: Downloaded 1459188/2114441 bytes (69%)
    I: Downloaded 1460604/2114441 bytes (69%)
    I: Downloaded 1461312/2114441 bytes (69%)
    I: Downloaded 1462020/2114441 bytes (69%)
    I: Downloaded 1462728/2114441 bytes (69%)
    I: Downloaded 1463436/2114441 bytes (69%)
    I: Downloaded 1464144/2114441 bytes (69%)
    I: Downloaded 1464852/2114441 bytes (69%)
    I: Downloaded 1465560/2114441 bytes (69%)
    I: Downloaded 1466268/2114441 bytes (69%)
    I: Downloaded 1466976/2114441 bytes (69%)
    I: Downloaded 1467684/2114441 bytes (69%)
    I: Downloaded 1468392/2114441 bytes (69%)
    I: Downloaded 1469100/2114441 bytes (69%)
    I: Downloaded 1469808/2114441 bytes (69%)
    I: Downloaded 1470516/2114441 bytes (69%)
    I: Downloaded 1471224/2114441 bytes (69%)
    I: Downloaded 1471932/2114441 bytes (69%)
    I: Downloaded 1472640/2114441 bytes (69%)
    I: Downloaded 1473348/2114441 bytes (69%)
    I: Downloaded 1474056/2114441 bytes (69%)
    I: Downloaded 1474764/2114441 bytes (69%)
    I: Downloaded 1475472/2114441 bytes (69%)
    I: Downloaded 1476180/2114441 bytes (69%)
    I: Downloaded 1476888/2114441 bytes (69%)
    I: Downloaded 1477596/2114441 bytes (69%)
    I: Downloaded 1478304/2114441 bytes (69%)
    I: Downloaded 1479012/2114441 bytes (69%)
    I: Downloaded 1479720/2114441 bytes (69%)
    I: Downloaded 1480428/2114441 bytes (70%)
    I: Downloaded 1481136/2114441 bytes (70%)
    I: Downloaded 1481844/2114441 bytes (70%)
    I: Downloaded 1482552/2114441 bytes (70%)
    I: Downloaded 1483260/2114441 bytes (70%)
    I: Downloaded 1483968/2114441 bytes (70%)
    I: Downloaded 1484676/2114441 bytes (70%)
    I: Downloaded 1485384/2114441 bytes (70%)
    I: Downloaded 1486092/2114441 bytes (70%)
    I: Downloaded 1486800/2114441 bytes (70%)
    I: Downloaded 1487508/2114441 bytes (70%)
    I: Downloaded 1488216/2114441 bytes (70%)
    I: Downloaded 1488924/2114441 bytes (70%)
    I: Downloaded 1489632/2114441 bytes (70%)
    I: Downloaded 1490340/2114441 bytes (70%)
    I: Downloaded 1491048/2114441 bytes (70%)
    I: Downloaded 1491756/2114441 bytes (70%)
    I: Downloaded 1492464/2114441 bytes (70%)
    I: Downloaded 1493172/2114441 bytes (70%)
    I: Downloaded 1493880/2114441 bytes (70%)
    I: Downloaded 1494588/2114441 bytes (70%)
    I: Downloaded 1495296/2114441 bytes (70%)
    I: Downloaded 1496004/2114441 bytes (70%)
    I: Downloaded 1496712/2114441 bytes (70%)
    I: Downloaded 1497420/2114441 bytes (70%)
    I: Downloaded 1498128/2114441 bytes (70%)
    I: Downloaded 1498836/2114441 bytes (70%)
    I: Downloaded 1499544/2114441 bytes (70%)
    I: Downloaded 1500252/2114441 bytes (70%)
    I: Downloaded 1500960/2114441 bytes (70%)
    I: Downloaded 1501668/2114441 bytes (71%)
    I: Downloaded 1502376/2114441 bytes (71%)
    I: Downloaded 1503084/2114441 bytes (71%)
    I: Downloaded 1503792/2114441 bytes (71%)
    I: Downloaded 1504500/2114441 bytes (71%)
    I: Downloaded 1505208/2114441 bytes (71%)
    I: Downloaded 1505916/2114441 bytes (71%)
    I: Downloaded 1506624/2114441 bytes (71%)
    I: Downloaded 1507332/2114441 bytes (71%)
    I: Downloaded 1508040/2114441 bytes (71%)
    I: Downloaded 1508748/2114441 bytes (71%)
    I: Downloaded 1509456/2114441 bytes (71%)
    I: Downloaded 1510164/2114441 bytes (71%)
    I: Downloaded 1510872/2114441 bytes (71%)
    I: Downloaded 1511580/2114441 bytes (71%)
    I: Downloaded 1513628/2114441 bytes (71%)
    I: Downloaded 1515676/2114441 bytes (71%)
    I: Downloaded 1517724/2114441 bytes (71%)
    I: Downloaded 1519368/2114441 bytes (71%)
    I: Downloaded 1520784/2114441 bytes (71%)
    I: Downloaded 1521492/2114441 bytes (71%)
    I: Downloaded 1522908/2114441 bytes (72%)
    I: Downloaded 1523616/2114441 bytes (72%)
    I: Downloaded 1524324/2114441 bytes (72%)
    I: Downloaded 1525032/2114441 bytes (72%)
    I: Downloaded 1525740/2114441 bytes (72%)
    I: Downloaded 1526448/2114441 bytes (72%)
    I: Downloaded 1527156/2114441 bytes (72%)
    I: Downloaded 1527864/2114441 bytes (72%)
    I: Downloaded 1528572/2114441 bytes (72%)
    I: Downloaded 1529280/2114441 bytes (72%)
    I: Downloaded 1529988/2114441 bytes (72%)
    I: Downloaded 1530696/2114441 bytes (72%)
    I: Downloaded 1531404/2114441 bytes (72%)
    I: Downloaded 1532112/2114441 bytes (72%)
    I: Downloaded 1532820/2114441 bytes (72%)
    I: Downloaded 1533528/2114441 bytes (72%)
    I: Downloaded 1534236/2114441 bytes (72%)
    I: Downloaded 1534944/2114441 bytes (72%)
    I: Downloaded 1535652/2114441 bytes (72%)
    I: Downloaded 1536360/2114441 bytes (72%)
    I: Downloaded 1537068/2114441 bytes (72%)
    I: Downloaded 1537776/2114441 bytes (72%)
    I: Downloaded 1538484/2114441 bytes (72%)
    I: Downloaded 1539192/2114441 bytes (72%)
    I: Downloaded 1539900/2114441 bytes (72%)
    I: Downloaded 1540608/2114441 bytes (72%)
    I: Downloaded 1541316/2114441 bytes (72%)
    I: Downloaded 1542024/2114441 bytes (72%)
    I: Downloaded 1542732/2114441 bytes (72%)
    I: Downloaded 1543440/2114441 bytes (72%)
    I: Downloaded 1544148/2114441 bytes (73%)
    I: Downloaded 1544856/2114441 bytes (73%)
    I: Downloaded 1545564/2114441 bytes (73%)
    I: Downloaded 1546272/2114441 bytes (73%)
    I: Downloaded 1546980/2114441 bytes (73%)
    I: Downloaded 1547688/2114441 bytes (73%)
    I: Downloaded 1548396/2114441 bytes (73%)
    I: Downloaded 1549104/2114441 bytes (73%)
    I: Downloaded 1549812/2114441 bytes (73%)
    I: Downloaded 1550520/2114441 bytes (73%)
    I: Downloaded 1551228/2114441 bytes (73%)
    I: Downloaded 1551936/2114441 bytes (73%)
    I: Downloaded 1552644/2114441 bytes (73%)
    I: Downloaded 1553352/2114441 bytes (73%)
    I: Downloaded 1554060/2114441 bytes (73%)
    I: Downloaded 1554768/2114441 bytes (73%)
    I: Downloaded 1555476/2114441 bytes (73%)
    I: Downloaded 1556184/2114441 bytes (73%)
    I: Downloaded 1556892/2114441 bytes (73%)
    I: Downloaded 1557600/2114441 bytes (73%)
    I: Downloaded 1558308/2114441 bytes (73%)
    I: Downloaded 1559016/2114441 bytes (73%)
    I: Downloaded 1559724/2114441 bytes (73%)
    I: Downloaded 1560432/2114441 bytes (73%)
    I: Downloaded 1561140/2114441 bytes (73%)
    I: Downloaded 1561848/2114441 bytes (73%)
    I: Downloaded 1562556/2114441 bytes (73%)
    I: Downloaded 1563264/2114441 bytes (73%)
    I: Downloaded 1563972/2114441 bytes (73%)
    I: Downloaded 1564680/2114441 bytes (73%)
    I: Downloaded 1565388/2114441 bytes (74%)
    I: Downloaded 1566096/2114441 bytes (74%)
    I: Downloaded 1566804/2114441 bytes (74%)
    I: Downloaded 1567512/2114441 bytes (74%)
    I: Downloaded 1568220/2114441 bytes (74%)
    I: Downloaded 1568928/2114441 bytes (74%)
    I: Downloaded 1569636/2114441 bytes (74%)
    I: Downloaded 1570344/2114441 bytes (74%)
    I: Downloaded 1571052/2114441 bytes (74%)
    I: Downloaded 1571760/2114441 bytes (74%)
    I: Downloaded 1572468/2114441 bytes (74%)
    I: Downloaded 1573176/2114441 bytes (74%)
    I: Downloaded 1573884/2114441 bytes (74%)
    I: Downloaded 1574592/2114441 bytes (74%)
    I: Downloaded 1575300/2114441 bytes (74%)
    I: Downloaded 1576008/2114441 bytes (74%)
    I: Downloaded 1576716/2114441 bytes (74%)
    I: Downloaded 1577424/2114441 bytes (74%)
    I: Downloaded 1579472/2114441 bytes (74%)
    I: Downloaded 1581520/2114441 bytes (74%)
    I: Downloaded 1583568/2114441 bytes (74%)
    I: Downloaded 1583796/2114441 bytes (74%)
    I: Downloaded 1584504/2114441 bytes (74%)
    I: Downloaded 1585212/2114441 bytes (74%)
    I: Downloaded 1585920/2114441 bytes (75%)
    I: Downloaded 1586628/2114441 bytes (75%)
    I: Downloaded 1587336/2114441 bytes (75%)
    I: Downloaded 1588044/2114441 bytes (75%)
    I: Downloaded 1588752/2114441 bytes (75%)
    I: Downloaded 1589460/2114441 bytes (75%)
    I: Downloaded 1590168/2114441 bytes (75%)
    I: Downloaded 1590876/2114441 bytes (75%)
    I: Downloaded 1591584/2114441 bytes (75%)
    I: Downloaded 1592292/2114441 bytes (75%)
    I: Downloaded 1593000/2114441 bytes (75%)
    I: Downloaded 1593708/2114441 bytes (75%)
    I: Downloaded 1594416/2114441 bytes (75%)
    I: Downloaded 1595124/2114441 bytes (75%)
    I: Downloaded 1595832/2114441 bytes (75%)
    I: Downloaded 1596540/2114441 bytes (75%)
    I: Downloaded 1597248/2114441 bytes (75%)
    I: Downloaded 1597956/2114441 bytes (75%)
    I: Downloaded 1598664/2114441 bytes (75%)
    I: Downloaded 1599372/2114441 bytes (75%)
    I: Downloaded 1600080/2114441 bytes (75%)
    I: Downloaded 1600788/2114441 bytes (75%)
    I: Downloaded 1601496/2114441 bytes (75%)
    I: Downloaded 1602204/2114441 bytes (75%)
    I: Downloaded 1602912/2114441 bytes (75%)
    I: Downloaded 1603620/2114441 bytes (75%)
    I: Downloaded 1604328/2114441 bytes (75%)
    I: Downloaded 1605036/2114441 bytes (75%)
    I: Downloaded 1605744/2114441 bytes (75%)
    I: Downloaded 1606452/2114441 bytes (75%)
    I: Downloaded 1607160/2114441 bytes (76%)
    I: Downloaded 1607868/2114441 bytes (76%)
    I: Downloaded 1608576/2114441 bytes (76%)
    I: Downloaded 1609284/2114441 bytes (76%)
    I: Downloaded 1609992/2114441 bytes (76%)
    I: Downloaded 1610700/2114441 bytes (76%)
    I: Downloaded 1611408/2114441 bytes (76%)
    I: Downloaded 1612116/2114441 bytes (76%)
    I: Downloaded 1612824/2114441 bytes (76%)
    I: Downloaded 1613532/2114441 bytes (76%)
    I: Downloaded 1614240/2114441 bytes (76%)
    I: Downloaded 1614948/2114441 bytes (76%)
    I: Downloaded 1615656/2114441 bytes (76%)
    I: Downloaded 1616364/2114441 bytes (76%)
    I: Downloaded 1617072/2114441 bytes (76%)
    I: Downloaded 1617780/2114441 bytes (76%)
    I: Downloaded 1618488/2114441 bytes (76%)
    I: Downloaded 1619196/2114441 bytes (76%)
    I: Downloaded 1619904/2114441 bytes (76%)
    I: Downloaded 1620612/2114441 bytes (76%)
    I: Downloaded 1621320/2114441 bytes (76%)
    I: Downloaded 1622028/2114441 bytes (76%)
    I: Downloaded 1622736/2114441 bytes (76%)
    I: Downloaded 1623444/2114441 bytes (76%)
    I: Downloaded 1624152/2114441 bytes (76%)
    I: Downloaded 1624860/2114441 bytes (76%)
    I: Downloaded 1625568/2114441 bytes (76%)
    I: Downloaded 1626276/2114441 bytes (76%)
    I: Downloaded 1626984/2114441 bytes (76%)
    I: Downloaded 1627692/2114441 bytes (76%)
    I: Downloaded 1628400/2114441 bytes (77%)
    I: Downloaded 1629108/2114441 bytes (77%)
    I: Downloaded 1629816/2114441 bytes (77%)
    I: Downloaded 1630524/2114441 bytes (77%)
    I: Downloaded 1631232/2114441 bytes (77%)
    I: Downloaded 1631940/2114441 bytes (77%)
    I: Downloaded 1632648/2114441 bytes (77%)
    I: Downloaded 1633356/2114441 bytes (77%)
    I: Downloaded 1634064/2114441 bytes (77%)
    I: Downloaded 1634772/2114441 bytes (77%)
    I: Downloaded 1635480/2114441 bytes (77%)
    I: Downloaded 1636188/2114441 bytes (77%)
    I: Downloaded 1636896/2114441 bytes (77%)
    I: Downloaded 1637604/2114441 bytes (77%)
    I: Downloaded 1638312/2114441 bytes (77%)
    I: Downloaded 1639020/2114441 bytes (77%)
    I: Downloaded 1639728/2114441 bytes (77%)
    I: Downloaded 1640436/2114441 bytes (77%)
    I: Downloaded 1641144/2114441 bytes (77%)
    I: Downloaded 1641852/2114441 bytes (77%)
    I: Downloaded 1642560/2114441 bytes (77%)
    I: Downloaded 1644608/2114441 bytes (77%)
    I: Downloaded 1646656/2114441 bytes (77%)
    I: Downloaded 1648704/2114441 bytes (77%)
    I: Downloaded 1650348/2114441 bytes (78%)
    I: Downloaded 1652396/2114441 bytes (78%)
    I: Downloaded 1652472/2114441 bytes (78%)
    I: Downloaded 1653496/2114441 bytes (78%)
    I: Downloaded 1654596/2114441 bytes (78%)
    I: Downloaded 1655304/2114441 bytes (78%)
    I: Downloaded 1656012/2114441 bytes (78%)
    I: Downloaded 1656720/2114441 bytes (78%)
    I: Downloaded 1657428/2114441 bytes (78%)
    I: Downloaded 1658136/2114441 bytes (78%)
    I: Downloaded 1658844/2114441 bytes (78%)
    I: Downloaded 1659552/2114441 bytes (78%)
    I: Downloaded 1660260/2114441 bytes (78%)
    I: Downloaded 1660968/2114441 bytes (78%)
    I: Downloaded 1661676/2114441 bytes (78%)
    I: Downloaded 1662384/2114441 bytes (78%)
    I: Downloaded 1663092/2114441 bytes (78%)
    I: Downloaded 1663800/2114441 bytes (78%)
    I: Downloaded 1664508/2114441 bytes (78%)
    I: Downloaded 1665216/2114441 bytes (78%)
    I: Downloaded 1665924/2114441 bytes (78%)
    I: Downloaded 1666632/2114441 bytes (78%)
    I: Downloaded 1667340/2114441 bytes (78%)
    I: Downloaded 1668048/2114441 bytes (78%)
    I: Downloaded 1668756/2114441 bytes (78%)
    I: Downloaded 1669464/2114441 bytes (78%)
    I: Downloaded 1670172/2114441 bytes (78%)
    I: Downloaded 1670880/2114441 bytes (79%)
    I: Downloaded 1671588/2114441 bytes (79%)
    I: Downloaded 1672296/2114441 bytes (79%)
    I: Downloaded 1673004/2114441 bytes (79%)
    I: Downloaded 1673712/2114441 bytes (79%)
    I: Downloaded 1674420/2114441 bytes (79%)
    I: Downloaded 1675128/2114441 bytes (79%)
    I: Downloaded 1675836/2114441 bytes (79%)
    I: Downloaded 1676544/2114441 bytes (79%)
    I: Downloaded 1677252/2114441 bytes (79%)
    I: Downloaded 1677960/2114441 bytes (79%)
    I: Downloaded 1678668/2114441 bytes (79%)
    I: Downloaded 1679376/2114441 bytes (79%)
    I: Downloaded 1680084/2114441 bytes (79%)
    I: Downloaded 1680792/2114441 bytes (79%)
    I: Downloaded 1681500/2114441 bytes (79%)
    I: Downloaded 1682208/2114441 bytes (79%)
    I: Downloaded 1682916/2114441 bytes (79%)
    I: Downloaded 1683624/2114441 bytes (79%)
    I: Downloaded 1684332/2114441 bytes (79%)
    I: Downloaded 1685040/2114441 bytes (79%)
    I: Downloaded 1685748/2114441 bytes (79%)
    I: Downloaded 1686456/2114441 bytes (79%)
    I: Downloaded 1687164/2114441 bytes (79%)
    I: Downloaded 1687872/2114441 bytes (79%)
    I: Downloaded 1688580/2114441 bytes (79%)
    I: Downloaded 1689288/2114441 bytes (79%)
    I: Downloaded 1689996/2114441 bytes (79%)
    I: Downloaded 1690704/2114441 bytes (79%)
    I: Downloaded 1691412/2114441 bytes (79%)
    I: Downloaded 1692120/2114441 bytes (80%)
    I: Downloaded 1692828/2114441 bytes (80%)
    I: Downloaded 1693536/2114441 bytes (80%)
    I: Downloaded 1694244/2114441 bytes (80%)
    I: Downloaded 1694952/2114441 bytes (80%)
    I: Downloaded 1695660/2114441 bytes (80%)
    I: Downloaded 1696368/2114441 bytes (80%)
    I: Downloaded 1697076/2114441 bytes (80%)
    I: Downloaded 1697784/2114441 bytes (80%)
    I: Downloaded 1698492/2114441 bytes (80%)
    I: Downloaded 1699200/2114441 bytes (80%)
    I: Downloaded 1699908/2114441 bytes (80%)
    I: Downloaded 1700616/2114441 bytes (80%)
    I: Downloaded 1701324/2114441 bytes (80%)
    I: Downloaded 1702032/2114441 bytes (80%)
    I: Downloaded 1702740/2114441 bytes (80%)
    I: Downloaded 1703448/2114441 bytes (80%)
    I: Downloaded 1704156/2114441 bytes (80%)
    I: Downloaded 1704864/2114441 bytes (80%)
    I: Downloaded 1705572/2114441 bytes (80%)
    I: Downloaded 1706280/2114441 bytes (80%)
    I: Downloaded 1706988/2114441 bytes (80%)
    I: Downloaded 1707696/2114441 bytes (80%)
    I: Downloaded 1708404/2114441 bytes (80%)
    I: Downloaded 1710452/2114441 bytes (80%)
    I: Downloaded 1712500/2114441 bytes (80%)
    I: Downloaded 1714068/2114441 bytes (81%)
    I: Downloaded 1714776/2114441 bytes (81%)
    I: Downloaded 1715484/2114441 bytes (81%)
    I: Downloaded 1716192/2114441 bytes (81%)
    I: Downloaded 1716900/2114441 bytes (81%)
    I: Downloaded 1717608/2114441 bytes (81%)
    I: Downloaded 1718316/2114441 bytes (81%)
    I: Downloaded 1719024/2114441 bytes (81%)
    I: Downloaded 1719732/2114441 bytes (81%)
    I: Downloaded 1720440/2114441 bytes (81%)
    I: Downloaded 1721148/2114441 bytes (81%)
    I: Downloaded 1721856/2114441 bytes (81%)
    I: Downloaded 1722564/2114441 bytes (81%)
    I: Downloaded 1723272/2114441 bytes (81%)
    I: Downloaded 1723980/2114441 bytes (81%)
    I: Downloaded 1724688/2114441 bytes (81%)
    I: Downloaded 1725396/2114441 bytes (81%)
    I: Downloaded 1726104/2114441 bytes (81%)
    I: Downloaded 1726812/2114441 bytes (81%)
    I: Downloaded 1727520/2114441 bytes (81%)
    I: Downloaded 1728228/2114441 bytes (81%)
    I: Downloaded 1728936/2114441 bytes (81%)
    I: Downloaded 1729644/2114441 bytes (81%)
    I: Downloaded 1730352/2114441 bytes (81%)
    I: Downloaded 1731060/2114441 bytes (81%)
    I: Downloaded 1731768/2114441 bytes (81%)
    I: Downloaded 1732476/2114441 bytes (81%)
    I: Downloaded 1733184/2114441 bytes (81%)
    I: Downloaded 1733892/2114441 bytes (82%)
    I: Downloaded 1734600/2114441 bytes (82%)
    I: Downloaded 1735308/2114441 bytes (82%)
    I: Downloaded 1736016/2114441 bytes (82%)
    I: Downloaded 1736724/2114441 bytes (82%)
    I: Downloaded 1737432/2114441 bytes (82%)
    I: Downloaded 1738140/2114441 bytes (82%)
    I: Downloaded 1738848/2114441 bytes (82%)
    I: Downloaded 1739556/2114441 bytes (82%)
    I: Downloaded 1740264/2114441 bytes (82%)
    I: Downloaded 1740972/2114441 bytes (82%)
    I: Downloaded 1741680/2114441 bytes (82%)
    I: Downloaded 1742388/2114441 bytes (82%)
    I: Downloaded 1743096/2114441 bytes (82%)
    I: Downloaded 1743804/2114441 bytes (82%)
    I: Downloaded 1744512/2114441 bytes (82%)
    I: Downloaded 1745220/2114441 bytes (82%)
    I: Downloaded 1745928/2114441 bytes (82%)
    I: Downloaded 1746636/2114441 bytes (82%)
    I: Downloaded 1747344/2114441 bytes (82%)
    I: Downloaded 1748052/2114441 bytes (82%)
    I: Downloaded 1748760/2114441 bytes (82%)
    I: Downloaded 1749468/2114441 bytes (82%)
    I: Downloaded 1750176/2114441 bytes (82%)
    I: Downloaded 1750884/2114441 bytes (82%)
    I: Downloaded 1751592/2114441 bytes (82%)
    I: Downloaded 1752300/2114441 bytes (82%)
    I: Downloaded 1753008/2114441 bytes (82%)
    I: Downloaded 1753716/2114441 bytes (82%)
    I: Downloaded 1754424/2114441 bytes (82%)
    I: Downloaded 1755132/2114441 bytes (83%)
    I: Downloaded 1755840/2114441 bytes (83%)
    I: Downloaded 1756548/2114441 bytes (83%)
    I: Downloaded 1757256/2114441 bytes (83%)
    I: Downloaded 1757964/2114441 bytes (83%)
    I: Downloaded 1758672/2114441 bytes (83%)
    I: Downloaded 1759380/2114441 bytes (83%)
    I: Downloaded 1760088/2114441 bytes (83%)
    I: Downloaded 1760796/2114441 bytes (83%)
    I: Downloaded 1761504/2114441 bytes (83%)
    I: Downloaded 1762212/2114441 bytes (83%)
    I: Downloaded 1762920/2114441 bytes (83%)
    I: Downloaded 1763628/2114441 bytes (83%)
    I: Downloaded 1764336/2114441 bytes (83%)
    I: Downloaded 1765044/2114441 bytes (83%)
    I: Downloaded 1765752/2114441 bytes (83%)
    I: Downloaded 1766460/2114441 bytes (83%)
    I: Downloaded 1767168/2114441 bytes (83%)
    I: Downloaded 1767876/2114441 bytes (83%)
    I: Downloaded 1768584/2114441 bytes (83%)
    I: Downloaded 1769292/2114441 bytes (83%)
    I: Downloaded 1770000/2114441 bytes (83%)
    I: Downloaded 1770708/2114441 bytes (83%)
    I: Downloaded 1771416/2114441 bytes (83%)
    I: Downloaded 1772124/2114441 bytes (83%)
    I: Downloaded 1772832/2114441 bytes (83%)
    I: Downloaded 1773540/2114441 bytes (83%)
    I: Downloaded 1774248/2114441 bytes (83%)
    I: Downloaded 1776296/2114441 bytes (84%)
    I: Downloaded 1778344/2114441 bytes (84%)
    I: Downloaded 1780392/2114441 bytes (84%)
    I: Downloaded 1781328/2114441 bytes (84%)
    I: Downloaded 1782036/2114441 bytes (84%)
    I: Downloaded 1783452/2114441 bytes (84%)
    I: Downloaded 1784160/2114441 bytes (84%)
    I: Downloaded 1785576/2114441 bytes (84%)
    I: Downloaded 1786284/2114441 bytes (84%)
    I: Downloaded 1786992/2114441 bytes (84%)
    I: Downloaded 1788408/2114441 bytes (84%)
    I: Downloaded 1789116/2114441 bytes (84%)
    I: Downloaded 1789824/2114441 bytes (84%)
    I: Downloaded 1790532/2114441 bytes (84%)
    I: Downloaded 1791240/2114441 bytes (84%)
    I: Downloaded 1791948/2114441 bytes (84%)
    I: Downloaded 1792656/2114441 bytes (84%)
    I: Downloaded 1793364/2114441 bytes (84%)
    I: Downloaded 1794072/2114441 bytes (84%)
    I: Downloaded 1794780/2114441 bytes (84%)
    I: Downloaded 1795488/2114441 bytes (84%)
    I: Downloaded 1796196/2114441 bytes (84%)
    I: Downloaded 1796904/2114441 bytes (84%)
    I: Downloaded 1797612/2114441 bytes (85%)
    I: Downloaded 1798320/2114441 bytes (85%)
    I: Downloaded 1799028/2114441 bytes (85%)
    I: Downloaded 1799736/2114441 bytes (85%)
    I: Downloaded 1800444/2114441 bytes (85%)
    I: Downloaded 1801152/2114441 bytes (85%)
    I: Downloaded 1801860/2114441 bytes (85%)
    I: Downloaded 1802568/2114441 bytes (85%)
    I: Downloaded 1803276/2114441 bytes (85%)
    I: Downloaded 1803984/2114441 bytes (85%)
    I: Downloaded 1804692/2114441 bytes (85%)
    I: Downloaded 1805400/2114441 bytes (85%)
    I: Downloaded 1806108/2114441 bytes (85%)
    I: Downloaded 1806816/2114441 bytes (85%)
    I: Downloaded 1807524/2114441 bytes (85%)
    I: Downloaded 1808232/2114441 bytes (85%)
    I: Downloaded 1808940/2114441 bytes (85%)
    I: Downloaded 1809648/2114441 bytes (85%)
    I: Downloaded 1810356/2114441 bytes (85%)
    I: Downloaded 1811064/2114441 bytes (85%)
    I: Downloaded 1811772/2114441 bytes (85%)
    I: Downloaded 1812480/2114441 bytes (85%)
    I: Downloaded 1813188/2114441 bytes (85%)
    I: Downloaded 1813896/2114441 bytes (85%)
    I: Downloaded 1814604/2114441 bytes (85%)
    I: Downloaded 1815312/2114441 bytes (85%)
    I: Downloaded 1816020/2114441 bytes (85%)
    I: Downloaded 1816728/2114441 bytes (85%)
    I: Downloaded 1817436/2114441 bytes (85%)
    I: Downloaded 1818144/2114441 bytes (85%)
    I: Downloaded 1818852/2114441 bytes (86%)
    I: Downloaded 1819560/2114441 bytes (86%)
    I: Downloaded 1820268/2114441 bytes (86%)
    I: Downloaded 1820976/2114441 bytes (86%)
    I: Downloaded 1821684/2114441 bytes (86%)
    I: Downloaded 1822392/2114441 bytes (86%)
    I: Downloaded 1823100/2114441 bytes (86%)
    I: Downloaded 1823808/2114441 bytes (86%)
    I: Downloaded 1824516/2114441 bytes (86%)
    I: Downloaded 1825224/2114441 bytes (86%)
    I: Downloaded 1825932/2114441 bytes (86%)
    I: Downloaded 1826640/2114441 bytes (86%)
    I: Downloaded 1827348/2114441 bytes (86%)
    I: Downloaded 1828056/2114441 bytes (86%)
    I: Downloaded 1828764/2114441 bytes (86%)
    I: Downloaded 1829472/2114441 bytes (86%)
    I: Downloaded 1830180/2114441 bytes (86%)
    I: Downloaded 1830888/2114441 bytes (86%)
    I: Downloaded 1831596/2114441 bytes (86%)
    I: Downloaded 1832304/2114441 bytes (86%)
    I: Downloaded 1833012/2114441 bytes (86%)
    I: Downloaded 1833720/2114441 bytes (86%)
    I: Downloaded 1834428/2114441 bytes (86%)
    I: Downloaded 1835136/2114441 bytes (86%)
    I: Downloaded 1835844/2114441 bytes (86%)
    I: Downloaded 1836552/2114441 bytes (86%)
    I: Downloaded 1837260/2114441 bytes (86%)
    I: Downloaded 1837968/2114441 bytes (86%)
    I: Downloaded 1838676/2114441 bytes (86%)
    I: Downloaded 1839384/2114441 bytes (86%)
    I: Downloaded 1841432/2114441 bytes (87%)
    I: Downloaded 1843480/2114441 bytes (87%)
    I: Downloaded 1845528/2114441 bytes (87%)
    I: Downloaded 1845756/2114441 bytes (87%)
    I: Downloaded 1846464/2114441 bytes (87%)
    I: Downloaded 1847172/2114441 bytes (87%)
    I: Downloaded 1847880/2114441 bytes (87%)
    I: Downloaded 1848588/2114441 bytes (87%)
    I: Downloaded 1849296/2114441 bytes (87%)
    I: Downloaded 1850004/2114441 bytes (87%)
    I: Downloaded 1850712/2114441 bytes (87%)
    I: Downloaded 1851420/2114441 bytes (87%)
    I: Downloaded 1852128/2114441 bytes (87%)
    I: Downloaded 1852836/2114441 bytes (87%)
    I: Downloaded 1853544/2114441 bytes (87%)
    I: Downloaded 1854252/2114441 bytes (87%)
    I: Downloaded 1854960/2114441 bytes (87%)
    I: Downloaded 1855668/2114441 bytes (87%)
    I: Downloaded 1856376/2114441 bytes (87%)
    I: Downloaded 1857084/2114441 bytes (87%)
    I: Downloaded 1857792/2114441 bytes (87%)
    I: Downloaded 1858500/2114441 bytes (87%)
    I: Downloaded 1859208/2114441 bytes (87%)
    I: Downloaded 1859916/2114441 bytes (87%)
    I: Downloaded 1860624/2114441 bytes (87%)
    I: Downloaded 1861332/2114441 bytes (88%)
    I: Downloaded 1862040/2114441 bytes (88%)
    I: Downloaded 1862748/2114441 bytes (88%)
    I: Downloaded 1863456/2114441 bytes (88%)
    I: Downloaded 1864164/2114441 bytes (88%)
    I: Downloaded 1864872/2114441 bytes (88%)
    I: Downloaded 1865580/2114441 bytes (88%)
    I: Downloaded 1866288/2114441 bytes (88%)
    I: Downloaded 1866996/2114441 bytes (88%)
    I: Downloaded 1867704/2114441 bytes (88%)
    I: Downloaded 1868412/2114441 bytes (88%)
    I: Downloaded 1869120/2114441 bytes (88%)
    I: Downloaded 1869828/2114441 bytes (88%)
    I: Downloaded 1870536/2114441 bytes (88%)
    I: Downloaded 1871244/2114441 bytes (88%)
    I: Downloaded 1871952/2114441 bytes (88%)
    I: Downloaded 1872660/2114441 bytes (88%)
    I: Downloaded 1873368/2114441 bytes (88%)
    I: Downloaded 1874076/2114441 bytes (88%)
    I: Downloaded 1874784/2114441 bytes (88%)
    I: Downloaded 1875492/2114441 bytes (88%)
    I: Downloaded 1876200/2114441 bytes (88%)
    I: Downloaded 1876908/2114441 bytes (88%)
    I: Downloaded 1877616/2114441 bytes (88%)
    I: Downloaded 1878324/2114441 bytes (88%)
    I: Downloaded 1879032/2114441 bytes (88%)
    I: Downloaded 1879740/2114441 bytes (88%)
    I: Downloaded 1880448/2114441 bytes (88%)
    I: Downloaded 1881156/2114441 bytes (88%)
    I: Downloaded 1881864/2114441 bytes (89%)
    I: Downloaded 1882572/2114441 bytes (89%)
    I: Downloaded 1883280/2114441 bytes (89%)
    I: Downloaded 1883988/2114441 bytes (89%)
    I: Downloaded 1884696/2114441 bytes (89%)
    I: Downloaded 1885404/2114441 bytes (89%)
    I: Downloaded 1886112/2114441 bytes (89%)
    I: Downloaded 1886820/2114441 bytes (89%)
    I: Downloaded 1887528/2114441 bytes (89%)
    I: Downloaded 1888236/2114441 bytes (89%)
    I: Downloaded 1888944/2114441 bytes (89%)
    I: Downloaded 1889652/2114441 bytes (89%)
    I: Downloaded 1890360/2114441 bytes (89%)
    I: Downloaded 1891068/2114441 bytes (89%)
    I: Downloaded 1891776/2114441 bytes (89%)
    I: Downloaded 1892484/2114441 bytes (89%)
    I: Downloaded 1893192/2114441 bytes (89%)
    I: Downloaded 1893900/2114441 bytes (89%)
    I: Downloaded 1894608/2114441 bytes (89%)
    I: Downloaded 1895316/2114441 bytes (89%)
    I: Downloaded 1896024/2114441 bytes (89%)
    I: Downloaded 1896732/2114441 bytes (89%)
    I: Downloaded 1897440/2114441 bytes (89%)
    I: Downloaded 1898148/2114441 bytes (89%)
    I: Downloaded 1898856/2114441 bytes (89%)
    I: Downloaded 1899564/2114441 bytes (89%)
    I: Downloaded 1900272/2114441 bytes (89%)
    I: Downloaded 1900980/2114441 bytes (89%)
    I: Downloaded 1901688/2114441 bytes (89%)
    I: Downloaded 1902396/2114441 bytes (89%)
    I: Downloaded 1903104/2114441 bytes (90%)
    I: Downloaded 1903812/2114441 bytes (90%)
    I: Downloaded 1904520/2114441 bytes (90%)
    I: Downloaded 1905228/2114441 bytes (90%)
    I: Downloaded 1907276/2114441 bytes (90%)
    I: Downloaded 1909324/2114441 bytes (90%)
    I: Downloaded 1910892/2114441 bytes (90%)
    I: Downloaded 1911600/2114441 bytes (90%)
    I: Downloaded 1912308/2114441 bytes (90%)
    I: Downloaded 1913016/2114441 bytes (90%)
    I: Downloaded 1913724/2114441 bytes (90%)
    I: Downloaded 1914432/2114441 bytes (90%)
    I: Downloaded 1915140/2114441 bytes (90%)
    I: Downloaded 1915848/2114441 bytes (90%)
    I: Downloaded 1916556/2114441 bytes (90%)
    I: Downloaded 1917264/2114441 bytes (90%)
    I: Downloaded 1917972/2114441 bytes (90%)
    I: Downloaded 1918680/2114441 bytes (90%)
    I: Downloaded 1919388/2114441 bytes (90%)
    I: Downloaded 1920096/2114441 bytes (90%)
    I: Downloaded 1920804/2114441 bytes (90%)
    I: Downloaded 1921512/2114441 bytes (90%)
    I: Downloaded 1922220/2114441 bytes (90%)
    I: Downloaded 1922928/2114441 bytes (90%)
    I: Downloaded 1923636/2114441 bytes (90%)
    I: Downloaded 1924344/2114441 bytes (91%)
    I: Downloaded 1925052/2114441 bytes (91%)
    I: Downloaded 1925760/2114441 bytes (91%)
    I: Downloaded 1926468/2114441 bytes (91%)
    I: Downloaded 1927176/2114441 bytes (91%)
    I: Downloaded 1927884/2114441 bytes (91%)
    I: Downloaded 1928592/2114441 bytes (91%)
    I: Downloaded 1929300/2114441 bytes (91%)
    I: Downloaded 1930008/2114441 bytes (91%)
    I: Downloaded 1930716/2114441 bytes (91%)
    I: Downloaded 1931424/2114441 bytes (91%)
    I: Downloaded 1932132/2114441 bytes (91%)
    I: Downloaded 1932840/2114441 bytes (91%)
    I: Downloaded 1933548/2114441 bytes (91%)
    I: Downloaded 1934256/2114441 bytes (91%)
    I: Downloaded 1934964/2114441 bytes (91%)
    I: Downloaded 1935672/2114441 bytes (91%)
    I: Downloaded 1936380/2114441 bytes (91%)
    I: Downloaded 1937088/2114441 bytes (91%)
    I: Downloaded 1937796/2114441 bytes (91%)
    I: Downloaded 1938504/2114441 bytes (91%)
    I: Downloaded 1939212/2114441 bytes (91%)
    I: Downloaded 1939920/2114441 bytes (91%)
    I: Downloaded 1940628/2114441 bytes (91%)
    I: Downloaded 1941336/2114441 bytes (91%)
    I: Downloaded 1942044/2114441 bytes (91%)
    I: Downloaded 1942752/2114441 bytes (91%)
    I: Downloaded 1943460/2114441 bytes (91%)
    I: Downloaded 1944168/2114441 bytes (91%)
    I: Downloaded 1944876/2114441 bytes (91%)
    I: Downloaded 1945584/2114441 bytes (92%)
    I: Downloaded 1946292/2114441 bytes (92%)
    I: Downloaded 1947000/2114441 bytes (92%)
    I: Downloaded 1947708/2114441 bytes (92%)
    I: Downloaded 1948416/2114441 bytes (92%)
    I: Downloaded 1949124/2114441 bytes (92%)
    I: Downloaded 1949832/2114441 bytes (92%)
    I: Downloaded 1950540/2114441 bytes (92%)
    I: Downloaded 1951248/2114441 bytes (92%)
    I: Downloaded 1951956/2114441 bytes (92%)
    I: Downloaded 1952664/2114441 bytes (92%)
    I: Downloaded 1953372/2114441 bytes (92%)
    I: Downloaded 1954080/2114441 bytes (92%)
    I: Downloaded 1954788/2114441 bytes (92%)
    I: Downloaded 1955496/2114441 bytes (92%)
    I: Downloaded 1956204/2114441 bytes (92%)
    I: Downloaded 1956912/2114441 bytes (92%)
    I: Downloaded 1957620/2114441 bytes (92%)
    I: Downloaded 1958328/2114441 bytes (92%)
    I: Downloaded 1959036/2114441 bytes (92%)
    I: Downloaded 1959744/2114441 bytes (92%)
    I: Downloaded 1960452/2114441 bytes (92%)
    I: Downloaded 1961160/2114441 bytes (92%)
    I: Downloaded 1961868/2114441 bytes (92%)
    I: Downloaded 1962576/2114441 bytes (92%)
    I: Downloaded 1963284/2114441 bytes (92%)
    I: Downloaded 1963992/2114441 bytes (92%)
    I: Downloaded 1964700/2114441 bytes (92%)
    I: Downloaded 1965408/2114441 bytes (92%)
    I: Downloaded 1966116/2114441 bytes (92%)
    I: Downloaded 1966824/2114441 bytes (93%)
    I: Downloaded 1967532/2114441 bytes (93%)
    I: Downloaded 1968240/2114441 bytes (93%)
    I: Downloaded 1968948/2114441 bytes (93%)
    I: Downloaded 1969656/2114441 bytes (93%)
    I: Downloaded 1970364/2114441 bytes (93%)
    I: Downloaded 1972412/2114441 bytes (93%)
    I: Downloaded 1974460/2114441 bytes (93%)
    I: Downloaded 1976508/2114441 bytes (93%)
    I: Downloaded 1976736/2114441 bytes (93%)
    I: Downloaded 1977444/2114441 bytes (93%)
    I: Downloaded 1978152/2114441 bytes (93%)
    I: Downloaded 1978860/2114441 bytes (93%)
    I: Downloaded 1979568/2114441 bytes (93%)
    I: Downloaded 1980276/2114441 bytes (93%)
    I: Downloaded 1980984/2114441 bytes (93%)
    I: Downloaded 1981692/2114441 bytes (93%)
    I: Downloaded 1982400/2114441 bytes (93%)
    I: Downloaded 1983108/2114441 bytes (93%)
    I: Downloaded 1983816/2114441 bytes (93%)
    I: Downloaded 1984524/2114441 bytes (93%)
    I: Downloaded 1985232/2114441 bytes (93%)
    I: Downloaded 1985940/2114441 bytes (93%)
    I: Downloaded 1986648/2114441 bytes (93%)
    I: Downloaded 1987356/2114441 bytes (93%)
    I: Downloaded 1988064/2114441 bytes (94%)
    I: Downloaded 1988772/2114441 bytes (94%)
    I: Downloaded 1989480/2114441 bytes (94%)
    I: Downloaded 1990188/2114441 bytes (94%)
    I: Downloaded 1990896/2114441 bytes (94%)
    I: Downloaded 1991604/2114441 bytes (94%)
    I: Downloaded 1992312/2114441 bytes (94%)
    I: Downloaded 1993020/2114441 bytes (94%)
    I: Downloaded 1993728/2114441 bytes (94%)
    I: Downloaded 1994436/2114441 bytes (94%)
    I: Downloaded 1995144/2114441 bytes (94%)
    I: Downloaded 1995852/2114441 bytes (94%)
    I: Downloaded 1996560/2114441 bytes (94%)
    I: Downloaded 1997268/2114441 bytes (94%)
    I: Downloaded 1997976/2114441 bytes (94%)
    I: Downloaded 1998684/2114441 bytes (94%)
    I: Downloaded 1999392/2114441 bytes (94%)
    I: Downloaded 2000100/2114441 bytes (94%)
    I: Downloaded 2000808/2114441 bytes (94%)
    I: Downloaded 2001516/2114441 bytes (94%)
    I: Downloaded 2002224/2114441 bytes (94%)
    I: Downloaded 2002932/2114441 bytes (94%)
    I: Downloaded 2003640/2114441 bytes (94%)
    I: Downloaded 2004348/2114441 bytes (94%)
    I: Downloaded 2005056/2114441 bytes (94%)
    I: Downloaded 2005764/2114441 bytes (94%)
    I: Downloaded 2006472/2114441 bytes (94%)
    I: Downloaded 2007180/2114441 bytes (94%)
    I: Downloaded 2007888/2114441 bytes (94%)
    I: Downloaded 2008596/2114441 bytes (94%)
    I: Downloaded 2009304/2114441 bytes (95%)
    I: Downloaded 2010012/2114441 bytes (95%)
    I: Downloaded 2010720/2114441 bytes (95%)
    I: Downloaded 2011428/2114441 bytes (95%)
    I: Downloaded 2012136/2114441 bytes (95%)
    I: Downloaded 2012844/2114441 bytes (95%)
    I: Downloaded 2013552/2114441 bytes (95%)
    I: Downloaded 2014260/2114441 bytes (95%)
    I: Downloaded 2014968/2114441 bytes (95%)
    I: Downloaded 2015676/2114441 bytes (95%)
    I: Downloaded 2016384/2114441 bytes (95%)
    I: Downloaded 2017092/2114441 bytes (95%)
    I: Downloaded 2017800/2114441 bytes (95%)
    I: Downloaded 2018508/2114441 bytes (95%)
    I: Downloaded 2019216/2114441 bytes (95%)
    I: Downloaded 2019924/2114441 bytes (95%)
    I: Downloaded 2020632/2114441 bytes (95%)
    I: Downloaded 2021340/2114441 bytes (95%)
    I: Downloaded 2022048/2114441 bytes (95%)
    I: Downloaded 2022756/2114441 bytes (95%)
    I: Downloaded 2023464/2114441 bytes (95%)
    I: Downloaded 2024172/2114441 bytes (95%)
    I: Downloaded 2024880/2114441 bytes (95%)
    I: Downloaded 2025588/2114441 bytes (95%)
    I: Downloaded 2026296/2114441 bytes (95%)
    I: Downloaded 2027004/2114441 bytes (95%)
    I: Downloaded 2027712/2114441 bytes (95%)
    I: Downloaded 2028420/2114441 bytes (95%)
    I: Downloaded 2029128/2114441 bytes (95%)
    I: Downloaded 2029836/2114441 bytes (95%)
    I: Downloaded 2030544/2114441 bytes (96%)
    I: Downloaded 2031252/2114441 bytes (96%)
    I: Downloaded 2031960/2114441 bytes (96%)
    I: Downloaded 2032668/2114441 bytes (96%)
    I: Downloaded 2033376/2114441 bytes (96%)
    I: Downloaded 2034084/2114441 bytes (96%)
    I: Downloaded 2034792/2114441 bytes (96%)
    I: Downloaded 2035500/2114441 bytes (96%)
    I: Downloaded 2036208/2114441 bytes (96%)
    I: Downloaded 2038256/2114441 bytes (96%)
    I: Downloaded 2040304/2114441 bytes (96%)
    I: Downloaded 2042352/2114441 bytes (96%)
    I: Downloaded 2043996/2114441 bytes (96%)
    I: Downloaded 2046044/2114441 bytes (96%)
    I: Downloaded 2046120/2114441 bytes (96%)
    I: Downloaded 2047144/2114441 bytes (96%)
    I: Downloaded 2048244/2114441 bytes (96%)
    I: Downloaded 2048952/2114441 bytes (96%)
    I: Downloaded 2050368/2114441 bytes (96%)
    I: Downloaded 2051076/2114441 bytes (97%)
    I: Downloaded 2051784/2114441 bytes (97%)
    I: Downloaded 2052492/2114441 bytes (97%)
    I: Downloaded 2053200/2114441 bytes (97%)
    I: Downloaded 2053908/2114441 bytes (97%)
    I: Downloaded 2054616/2114441 bytes (97%)
    I: Downloaded 2055324/2114441 bytes (97%)
    I: Downloaded 2056032/2114441 bytes (97%)
    I: Downloaded 2056740/2114441 bytes (97%)
    I: Downloaded 2057448/2114441 bytes (97%)
    I: Downloaded 2058156/2114441 bytes (97%)
    I: Downloaded 2058864/2114441 bytes (97%)
    I: Downloaded 2059572/2114441 bytes (97%)
    I: Downloaded 2060280/2114441 bytes (97%)
    I: Downloaded 2060988/2114441 bytes (97%)
    I: Downloaded 2061696/2114441 bytes (97%)
    I: Downloaded 2062404/2114441 bytes (97%)
    I: Downloaded 2063112/2114441 bytes (97%)
    I: Downloaded 2063820/2114441 bytes (97%)
    I: Downloaded 2064528/2114441 bytes (97%)
    I: Downloaded 2065236/2114441 bytes (97%)
    I: Downloaded 2065944/2114441 bytes (97%)
    I: Downloaded 2066652/2114441 bytes (97%)
    I: Downloaded 2067360/2114441 bytes (97%)
    I: Downloaded 2068068/2114441 bytes (97%)
    I: Downloaded 2068776/2114441 bytes (97%)
    I: Downloaded 2069484/2114441 bytes (97%)
    I: Downloaded 2070192/2114441 bytes (97%)
    I: Downloaded 2070900/2114441 bytes (97%)
    I: Downloaded 2071608/2114441 bytes (97%)
    I: Downloaded 2072316/2114441 bytes (98%)
    I: Downloaded 2073024/2114441 bytes (98%)
    I: Downloaded 2073732/2114441 bytes (98%)
    I: Downloaded 2074440/2114441 bytes (98%)
    I: Downloaded 2075148/2114441 bytes (98%)
    I: Downloaded 2075856/2114441 bytes (98%)
    I: Downloaded 2076564/2114441 bytes (98%)
    I: Downloaded 2077272/2114441 bytes (98%)
    I: Downloaded 2077980/2114441 bytes (98%)
    I: Downloaded 2078688/2114441 bytes (98%)
    I: Downloaded 2079396/2114441 bytes (98%)
    I: Downloaded 2080104/2114441 bytes (98%)
    I: Downloaded 2080812/2114441 bytes (98%)
    I: Downloaded 2081520/2114441 bytes (98%)
    I: Downloaded 2082228/2114441 bytes (98%)
    I: Downloaded 2082936/2114441 bytes (98%)
    I: Downloaded 2083644/2114441 bytes (98%)
    I: Downloaded 2084352/2114441 bytes (98%)
    I: Downloaded 2085060/2114441 bytes (98%)
    I: Downloaded 2085768/2114441 bytes (98%)
    I: Downloaded 2086476/2114441 bytes (98%)
    I: Downloaded 2087184/2114441 bytes (98%)
    I: Downloaded 2087892/2114441 bytes (98%)
    I: Downloaded 2088600/2114441 bytes (98%)
    I: Downloaded 2089308/2114441 bytes (98%)
    I: Downloaded 2090016/2114441 bytes (98%)
    I: Downloaded 2090724/2114441 bytes (98%)
    I: Downloaded 2091432/2114441 bytes (98%)
    I: Downloaded 2092140/2114441 bytes (98%)
    I: Downloaded 2092848/2114441 bytes (98%)
    I: Downloaded 2093556/2114441 bytes (99%)
    I: Downloaded 2094264/2114441 bytes (99%)
    I: Downloaded 2094972/2114441 bytes (99%)
    I: Downloaded 2095680/2114441 bytes (99%)
    I: Downloaded 2096388/2114441 bytes (99%)
    I: Downloaded 2097096/2114441 bytes (99%)
    I: Downloaded 2097804/2114441 bytes (99%)
    I: Downloaded 2098512/2114441 bytes (99%)
    I: Downloaded 2099220/2114441 bytes (99%)
    I: Downloaded 2099928/2114441 bytes (99%)
    I: Downloaded 2100636/2114441 bytes (99%)
    I: Downloaded 2101344/2114441 bytes (99%)
    I: Downloaded 2103392/2114441 bytes (99%)
    I: Downloaded 2105440/2114441 bytes (99%)
    I: Downloaded 2107488/2114441 bytes (99%)
    I: Downloaded 2109132/2114441 bytes (99%)
    I: Downloaded 2109840/2114441 bytes (99%)
    I: Downloaded 2110548/2114441 bytes (99%)
    I: Downloaded 2111256/2114441 bytes (99%)
    I: Downloaded 2111964/2114441 bytes (99%)
    I: Downloaded 2112672/2114441 bytes (99%)
    I: Downloaded 2113380/2114441 bytes (99%)
    I: Downloaded 2114088/2114441 bytes (99%)
    I: Downloaded 2114441/2114441 bytes (100%)
    I: Download complete
    I: Modem firmware downloaded to flash device
    Press Button 2 or enter 'apply' to apply modem firmware update from flash
    apply
    Applying full modem firmware update from external flash
    uart:~$ I: Writing segment 1/5, Target addr: 0x2000000c, size: 018b0
    W: [WARNING] Skipping prevalidation, this should only be done during development
    I: Writing segment 2/5, Target addr: 0x59602000, size: 097c
    I: Writing segment 3/5, Target addr: 0x6000, size: 0a000
    I: Writing segment 4/5, Target addr: 0x38000, size: 01f4000
    I: Writing segment 5/5, Target addr: 0x27c000, size: 04000
    I: FMFU finished
    Modem firmware update completed, reinitializing in normal mode
    Current modem firmware version: mfw_nrf91x1_2.0.0
    LTE Link Connecting ...
    LTE network is disconnected.
    LTE Link Connected!
    Press Button 1 or enter 'download' to download firmware update
    Nordic, please confirm my findings and if this is a bug in the sample.
    Derek
  • Another update. When I tried to perform the update again, it failed. See log below. Seems like this sample is all kinds of broken. From the log below:
    E: Invalid hash
    fmfu_fdev_load failed: -22
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2025.11.03 17:45:08 =~=~=~=~=~=~=~=~=~=~=~=
    W: Protocol not specified for nrfconnectsdk.s3.eu-central-1.amazonaws.com/fmfu_2.0.1.cbor, attempting http://
    I: Failed to resolve hostname nrfconnectsdk.s3.eu-central-1.amazonaws.com on IPv6, err -2
    I: Host lookup failed for hostname nrfconnectsdk.s3.eu-central-1.amazonaws.com on IPv6 (err -118), attempting IPv4
    I: Connecting to 52.219.46.73
    I: Downloaded 708/2114729 bytes (0%)
    I: Downloaded 1416/2114729 bytes (0%)
    I: Downloaded 2124/2114729 bytes (0%)
    I: Downloaded 2832/2114729 bytes (0%)
    I: Downloaded 3540/2114729 bytes (0%)
    I: Downloaded 4248/2114729 bytes (0%)
    I: Downloaded 4956/2114729 bytes (0%)
    I: Downloaded 5664/2114729 bytes (0%)
    I: Downloaded 6372/2114729 bytes (0%)
    I: Downloaded 7080/2114729 bytes (0%)
    I: Downloaded 7788/2114729 bytes (0%)
    I: Downloaded 8496/2114729 bytes (0%)
    I: Downloaded 9204/2114729 bytes (0%)
    I: Downloaded 9912/2114729 bytes (0%)
    I: Downloaded 10620/2114729 bytes (0%)
    I: Downloaded 11328/2114729 bytes (0%)
    I: Downloaded 12036/2114729 bytes (0%)
    I: Downloaded 12744/2114729 bytes (0%)
    I: Downloaded 13452/2114729 bytes (0%)
    I: Downloaded 14160/2114729 bytes (0%)
    I: Downloaded 14868/2114729 bytes (0%)
    I: Downloaded 15576/2114729 bytes (0%)
    I: Downloaded 16284/2114729 bytes (0%)
    I: Downloaded 16992/2114729 bytes (0%)
    I: Downloaded 17700/2114729 bytes (0%)
    I: Downloaded 18408/2114729 bytes (0%)
    I: Downloaded 19116/2114729 bytes (0%)
    I: Downloaded 19824/2114729 bytes (0%)
    I: Downloaded 20532/2114729 bytes (0%)
    I: Downloaded 21240/2114729 bytes (1%)
    I: Downloaded 21948/2114729 bytes (1%)
    I: Downloaded 22656/2114729 bytes (1%)
    I: Downloaded 23364/2114729 bytes (1%)
    I: Downloaded 24072/2114729 bytes (1%)
    I: Downloaded 24780/2114729 bytes (1%)
    I: Downloaded 25488/2114729 bytes (1%)
    I: Downloaded 26196/2114729 bytes (1%)
    I: Downloaded 26904/2114729 bytes (1%)
    I: Downloaded 27612/2114729 bytes (1%)
    I: Downloaded 28320/2114729 bytes (1%)
    I: Downloaded 29028/2114729 bytes (1%)
    I: Downloaded 29736/2114729 bytes (1%)
    I: Downloaded 30444/2114729 bytes (1%)
    I: Downloaded 31152/2114729 bytes (1%)
    I: Downloaded 31860/2114729 bytes (1%)
    I: Downloaded 32568/2114729 bytes (1%)
    I: Downloaded 33276/2114729 bytes (1%)
    I: Downloaded 33984/2114729 bytes (1%)
    I: Downloaded 34692/2114729 bytes (1%)
    I: Downloaded 35400/2114729 bytes (1%)
    I: Downloaded 36108/2114729 bytes (1%)
    I: Downloaded 36816/2114729 bytes (1%)
    I: Downloaded 37524/2114729 bytes (1%)
    I: Downloaded 38232/2114729 bytes (1%)
    I: Downloaded 38940/2114729 bytes (1%)
    I: Downloaded 39648/2114729 bytes (1%)
    I: Downloaded 40356/2114729 bytes (1%)
    I: Downloaded 41064/2114729 bytes (1%)
    I: Downloaded 41772/2114729 bytes (1%)
    I: Downloaded 42480/2114729 bytes (2%)
    I: Downloaded 43188/2114729 bytes (2%)
    I: Downloaded 43896/2114729 bytes (2%)
    I: Downloaded 44604/2114729 bytes (2%)
    I: Downloaded 45312/2114729 bytes (2%)
    I: Downloaded 46020/2114729 bytes (2%)
    I: Downloaded 46728/2114729 bytes (2%)
    I: Downloaded 47436/2114729 bytes (2%)
    I: Downloaded 48144/2114729 bytes (2%)
    I: Downloaded 48852/2114729 bytes (2%)
    I: Downloaded 49560/2114729 bytes (2%)
    I: Downloaded 50268/2114729 bytes (2%)
    I: Downloaded 50976/2114729 bytes (2%)
    I: Downloaded 51684/2114729 bytes (2%)
    I: Downloaded 52392/2114729 bytes (2%)
    I: Downloaded 53100/2114729 bytes (2%)
    I: Downloaded 53808/2114729 bytes (2%)
    I: Downloaded 54516/2114729 bytes (2%)
    I: Downloaded 55224/2114729 bytes (2%)
    I: Downloaded 55932/2114729 bytes (2%)
    I: Downloaded 56640/2114729 bytes (2%)
    I: Downloaded 57348/2114729 bytes (2%)
    I: Downloaded 58056/2114729 bytes (2%)
    I: Downloaded 58764/2114729 bytes (2%)
    I: Downloaded 59472/2114729 bytes (2%)
    I: Downloaded 60180/2114729 bytes (2%)
    I: Downloaded 60888/2114729 bytes (2%)
    I: Downloaded 61596/2114729 bytes (2%)
    I: Downloaded 62304/2114729 bytes (2%)
    I: Downloaded 63012/2114729 bytes (2%)
    I: Downloaded 63720/2114729 bytes (3%)
    I: Downloaded 64428/2114729 bytes (3%)
    I: Downloaded 65136/2114729 bytes (3%)
    I: Downloaded 65844/2114729 bytes (3%)
    I: Downloaded 66552/2114729 bytes (3%)
    I: Downloaded 67260/2114729 bytes (3%)
    I: Downloaded 67968/2114729 bytes (3%)
    I: Downloaded 68676/2114729 bytes (3%)
    I: Downloaded 69384/2114729 bytes (3%)
    I: Downloaded 70092/2114729 bytes (3%)
    I: Downloaded 70800/2114729 bytes (3%)
    I: Downloaded 71508/2114729 bytes (3%)
    I: Downloaded 72216/2114729 bytes (3%)
    I: Downloaded 72924/2114729 bytes (3%)
    I: Downloaded 73632/2114729 bytes (3%)
    I: Downloaded 74340/2114729 bytes (3%)
    I: Downloaded 75048/2114729 bytes (3%)
    I: Downloaded 75756/2114729 bytes (3%)
    I: Downloaded 76464/2114729 bytes (3%)
    I: Downloaded 77172/2114729 bytes (3%)
    I: Downloaded 77880/2114729 bytes (3%)
    I: Downloaded 78588/2114729 bytes (3%)
    I: Downloaded 79296/2114729 bytes (3%)
    I: Downloaded 80004/2114729 bytes (3%)
    I: Downloaded 80712/2114729 bytes (3%)
    I: Downloaded 81420/2114729 bytes (3%)
    I: Downloaded 82128/2114729 bytes (3%)
    I: Downloaded 82836/2114729 bytes (3%)
    I: Downloaded 83544/2114729 bytes (3%)
    I: Downloaded 84252/2114729 bytes (3%)
    I: Downloaded 84960/2114729 bytes (4%)
    I: Downloaded 85668/2114729 bytes (4%)
    I: Downloaded 86376/2114729 bytes (4%)
    I: Downloaded 87084/2114729 bytes (4%)
    I: Downloaded 87792/2114729 bytes (4%)
    I: Downloaded 88500/2114729 bytes (4%)
    I: Downloaded 89208/2114729 bytes (4%)
    I: Downloaded 89916/2114729 bytes (4%)
    I: Downloaded 90624/2114729 bytes (4%)
    I: Downloaded 91332/2114729 bytes (4%)
    I: Downloaded 92040/2114729 bytes (4%)
    I: Downloaded 92748/2114729 bytes (4%)
    I: Downloaded 93456/2114729 bytes (4%)
    I: Downloaded 94164/2114729 bytes (4%)
    I: Downloaded 94872/2114729 bytes (4%)
    I: Downloaded 95580/2114729 bytes (4%)
    I: Downloaded 96288/2114729 bytes (4%)
    I: Downloaded 96996/2114729 bytes (4%)
    I: Downloaded 97704/2114729 bytes (4%)
    I: Downloaded 98412/2114729 bytes (4%)
    I: Downloaded 99120/2114729 bytes (4%)
    I: Downloaded 99828/2114729 bytes (4%)
    I: Downloaded 100536/2114729 bytes (4%)
    I: Downloaded 101244/2114729 bytes (4%)
    I: Downloaded 101952/2114729 bytes (4%)
    I: Downloaded 102660/2114729 bytes (4%)
    I: Downloaded 103368/2114729 bytes (4%)
    I: Downloaded 104076/2114729 bytes (4%)
    I: Downloaded 104784/2114729 bytes (4%)
    I: Downloaded 105492/2114729 bytes (4%)
    I: Downloaded 106200/2114729 bytes (5%)
    I: Downloaded 106908/2114729 bytes (5%)
    I: Downloaded 107616/2114729 bytes (5%)
    I: Downloaded 108324/2114729 bytes (5%)
    I: Downloaded 109032/2114729 bytes (5%)
    I: Downloaded 109740/2114729 bytes (5%)
    I: Downloaded 110448/2114729 bytes (5%)
    I: Downloaded 111156/2114729 bytes (5%)
    I: Downloaded 111864/2114729 bytes (5%)
    I: Downloaded 112572/2114729 bytes (5%)
    I: Downloaded 113280/2114729 bytes (5%)
    I: Downloaded 113988/2114729 bytes (5%)
    I: Downloaded 114696/2114729 bytes (5%)
    I: Downloaded 115404/2114729 bytes (5%)
    I: Downloaded 116112/2114729 bytes (5%)
    I: Downloaded 116820/2114729 bytes (5%)
    I: Downloaded 117528/2114729 bytes (5%)
    I: Downloaded 118236/2114729 bytes (5%)
    I: Downloaded 118944/2114729 bytes (5%)
    I: Downloaded 119652/2114729 bytes (5%)
    I: Downloaded 120360/2114729 bytes (5%)
    I: Downloaded 121068/2114729 bytes (5%)
    I: Downloaded 121776/2114729 bytes (5%)
    I: Downloaded 122484/2114729 bytes (5%)
    I: Downloaded 123192/2114729 bytes (5%)
    I: Downloaded 123900/2114729 bytes (5%)
    I: Downloaded 124608/2114729 bytes (5%)
    I: Downloaded 125316/2114729 bytes (5%)
    I: Downloaded 126024/2114729 bytes (5%)
    I: Downloaded 126732/2114729 bytes (5%)
    I: Downloaded 127440/2114729 bytes (6%)
    I: Downloaded 128148/2114729 bytes (6%)
    I: Downloaded 128856/2114729 bytes (6%)
    I: Downloaded 129564/2114729 bytes (6%)
    I: Downloaded 130272/2114729 bytes (6%)
    I: Downloaded 130980/2114729 bytes (6%)
    I: Downloaded 131688/2114729 bytes (6%)
    I: Downloaded 132396/2114729 bytes (6%)
    I: Downloaded 133104/2114729 bytes (6%)
    I: Downloaded 133812/2114729 bytes (6%)
    I: Downloaded 134520/2114729 bytes (6%)
    I: Downloaded 135228/2114729 bytes (6%)
    I: Downloaded 135936/2114729 bytes (6%)
    I: Downloaded 136644/2114729 bytes (6%)
    I: Downloaded 137352/2114729 bytes (6%)
    I: Downloaded 138060/2114729 bytes (6%)
    I: Downloaded 138768/2114729 bytes (6%)
    I: Downloaded 139476/2114729 bytes (6%)
    I: Downloaded 140184/2114729 bytes (6%)
    I: Downloaded 140892/2114729 bytes (6%)
    I: Downloaded 141600/2114729 bytes (6%)
    I: Downloaded 142308/2114729 bytes (6%)
    I: Downloaded 143016/2114729 bytes (6%)
    I: Downloaded 143724/2114729 bytes (6%)
    I: Downloaded 144432/2114729 bytes (6%)
    I: Downloaded 145140/2114729 bytes (6%)
    I: Downloaded 145848/2114729 bytes (6%)
    I: Downloaded 146556/2114729 bytes (6%)
    I: Downloaded 147264/2114729 bytes (6%)
    I: Downloaded 147972/2114729 bytes (6%)
    I: Downloaded 148680/2114729 bytes (7%)
    I: Downloaded 149388/2114729 bytes (7%)
    I: Downloaded 150096/2114729 bytes (7%)
    I: Downloaded 150804/2114729 bytes (7%)
    I: Downloaded 151512/2114729 bytes (7%)
    I: Downloaded 152220/2114729 bytes (7%)
    I: Downloaded 152928/2114729 bytes (7%)
    I: Downloaded 153636/2114729 bytes (7%)
    I: Downloaded 154344/2114729 bytes (7%)
    I: Downloaded 155052/2114729 bytes (7%)
    I: Downloaded 155760/2114729 bytes (7%)
    I: Downloaded 156468/2114729 bytes (7%)
    I: Downloaded 157176/2114729 bytes (7%)
    I: Downloaded 157884/2114729 bytes (7%)
    I: Downloaded 158592/2114729 bytes (7%)
    I: Downloaded 159300/2114729 bytes (7%)
    I: Downloaded 160008/2114729 bytes (7%)
    I: Downloaded 160716/2114729 bytes (7%)
    I: Downloaded 161424/2114729 bytes (7%)
    I: Downloaded 162132/2114729 bytes (7%)
    I: Downloaded 162840/2114729 bytes (7%)
    I: Downloaded 163548/2114729 bytes (7%)
    I: Downloaded 164256/2114729 bytes (7%)
    I: Downloaded 164964/2114729 bytes (7%)
    I: Downloaded 165672/2114729 bytes (7%)
    I: Downloaded 166380/2114729 bytes (7%)
    I: Downloaded 167088/2114729 bytes (7%)
    I: Downloaded 167796/2114729 bytes (7%)
    I: Downloaded 168504/2114729 bytes (7%)
    I: Downloaded 169212/2114729 bytes (8%)
    I: Downloaded 169920/2114729 bytes (8%)
    I: Downloaded 170628/2114729 bytes (8%)
    I: Downloaded 171336/2114729 bytes (8%)
    I: Downloaded 172044/2114729 bytes (8%)
    I: Downloaded 172752/2114729 bytes (8%)
    I: Downloaded 173460/2114729 bytes (8%)
    I: Downloaded 174168/2114729 bytes (8%)
    I: Downloaded 174876/2114729 bytes (8%)
    I: Downloaded 175584/2114729 bytes (8%)
    I: Downloaded 176292/2114729 bytes (8%)
    I: Downloaded 177000/2114729 bytes (8%)
    I: Downloaded 177708/2114729 bytes (8%)
    I: Downloaded 178416/2114729 bytes (8%)
    I: Downloaded 179124/2114729 bytes (8%)
    I: Downloaded 179832/2114729 bytes (8%)
    I: Downloaded 180540/2114729 bytes (8%)
    I: Downloaded 181248/2114729 bytes (8%)
    I: Downloaded 181956/2114729 bytes (8%)
    I: Downloaded 182664/2114729 bytes (8%)
    I: Downloaded 183372/2114729 bytes (8%)
    I: Downloaded 184080/2114729 bytes (8%)
    I: Downloaded 184788/2114729 bytes (8%)
    I: Downloaded 185496/2114729 bytes (8%)
    I: Downloaded 186204/2114729 bytes (8%)
    I: Downloaded 186912/2114729 bytes (8%)
    I: Downloaded 187620/2114729 bytes (8%)
    I: Downloaded 188328/2114729 bytes (8%)
    I: Downloaded 189036/2114729 bytes (8%)
    I: Downloaded 189744/2114729 bytes (8%)
    I: Downloaded 190452/2114729 bytes (9%)
    I: Downloaded 191160/2114729 bytes (9%)
    I: Downloaded 191868/2114729 bytes (9%)
    I: Downloaded 192576/2114729 bytes (9%)
    I: Downloaded 193284/2114729 bytes (9%)
    I: Downloaded 193992/2114729 bytes (9%)
    I: Downloaded 194700/2114729 bytes (9%)
    I: Downloaded 195408/2114729 bytes (9%)
    I: Downloaded 196116/2114729 bytes (9%)
    I: Downloaded 196824/2114729 bytes (9%)
    I: Downloaded 197532/2114729 bytes (9%)
    I: Downloaded 198240/2114729 bytes (9%)
    I: Downloaded 198948/2114729 bytes (9%)
    I: Downloaded 199656/2114729 bytes (9%)
    I: Downloaded 200364/2114729 bytes (9%)
    I: Downloaded 201072/2114729 bytes (9%)
    I: Downloaded 201780/2114729 bytes (9%)
    I: Downloaded 202488/2114729 bytes (9%)
    I: Downloaded 203196/2114729 bytes (9%)
    I: Downloaded 203904/2114729 bytes (9%)
    I: Downloaded 204612/2114729 bytes (9%)
    I: Downloaded 205320/2114729 bytes (9%)
    I: Downloaded 206028/2114729 bytes (9%)
    I: Downloaded 206736/2114729 bytes (9%)
    I: Downloaded 207444/2114729 bytes (9%)
    I: Downloaded 208152/2114729 bytes (9%)
    I: Downloaded 208860/2114729 bytes (9%)
    I: Downloaded 209568/2114729 bytes (9%)
    I: Downloaded 210276/2114729 bytes (9%)
    I: Downloaded 210984/2114729 bytes (9%)
    I: Downloaded 211692/2114729 bytes (10%)
    I: Downloaded 212400/2114729 bytes (10%)
    I: Downloaded 213108/2114729 bytes (10%)
    I: Downloaded 213816/2114729 bytes (10%)
    I: Downloaded 214524/2114729 bytes (10%)
    I: Downloaded 215232/2114729 bytes (10%)
    I: Downloaded 215940/2114729 bytes (10%)
    I: Downloaded 216648/2114729 bytes (10%)
    I: Downloaded 217356/2114729 bytes (10%)
    I: Downloaded 218064/2114729 bytes (10%)
    I: Downloaded 218772/2114729 bytes (10%)
    I: Downloaded 219480/2114729 bytes (10%)
    I: Downloaded 220188/2114729 bytes (10%)
    I: Downloaded 220896/2114729 bytes (10%)
    I: Downloaded 221604/2114729 bytes (10%)
    I: Downloaded 222312/2114729 bytes (10%)
    I: Downloaded 223020/2114729 bytes (10%)
    I: Downloaded 223728/2114729 bytes (10%)
    I: Downloaded 224436/2114729 bytes (10%)
    I: Downloaded 225144/2114729 bytes (10%)
    I: Downloaded 225852/2114729 bytes (10%)
    I: Downloaded 226560/2114729 bytes (10%)
    I: Downloaded 227268/2114729 bytes (10%)
    I: Downloaded 227976/2114729 bytes (10%)
    I: Downloaded 228684/2114729 bytes (10%)
    I: Downloaded 229392/2114729 bytes (10%)
    I: Downloaded 230100/2114729 bytes (10%)
    I: Downloaded 230808/2114729 bytes (10%)
    I: Downloaded 231516/2114729 bytes (10%)
    I: Downloaded 232224/2114729 bytes (10%)
    I: Downloaded 232932/2114729 bytes (11%)
    I: Downloaded 233640/2114729 bytes (11%)
    I: Downloaded 234348/2114729 bytes (11%)
    I: Downloaded 235056/2114729 bytes (11%)
    I: Downloaded 235764/2114729 bytes (11%)
    I: Downloaded 236472/2114729 bytes (11%)
    I: Downloaded 237180/2114729 bytes (11%)
    I: Downloaded 237888/2114729 bytes (11%)
    I: Downloaded 238596/2114729 bytes (11%)
    I: Downloaded 239304/2114729 bytes (11%)
    I: Downloaded 240012/2114729 bytes (11%)
    I: Downloaded 240720/2114729 bytes (11%)
    I: Downloaded 241428/2114729 bytes (11%)
    I: Downloaded 242136/2114729 bytes (11%)
    I: Downloaded 242844/2114729 bytes (11%)
    I: Downloaded 243552/2114729 bytes (11%)
    I: Downloaded 244260/2114729 bytes (11%)
    I: Downloaded 244968/2114729 bytes (11%)
    I: Downloaded 245676/2114729 bytes (11%)
    I: Downloaded 246384/2114729 bytes (11%)
    I: Downloaded 247092/2114729 bytes (11%)
    I: Downloaded 247800/2114729 bytes (11%)
    I: Downloaded 248508/2114729 bytes (11%)
    I: Downloaded 249216/2114729 bytes (11%)
    I: Downloaded 249570/2114729 bytes (11%)
    I: Downloaded 249924/2114729 bytes (11%)
    I: Downloaded 250278/2114729 bytes (11%)
    I: Downloaded 250632/2114729 bytes (11%)
    I: Downloaded 250986/2114729 bytes (11%)
    I: Downloaded 251340/2114729 bytes (11%)
    I: Downloaded 251694/2114729 bytes (11%)
    I: Downloaded 252048/2114729 bytes (11%)
    I: Downloaded 252402/2114729 bytes (11%)
    I: Downloaded 252756/2114729 bytes (11%)
    I: Downloaded 253110/2114729 bytes (11%)
    I: Downloaded 253464/2114729 bytes (11%)
    I: Downloaded 253818/2114729 bytes (12%)
    I: Downloaded 254172/2114729 bytes (12%)
    I: Downloaded 255588/2114729 bytes (12%)
    I: Downloaded 255942/2114729 bytes (12%)
    I: Downloaded 256296/2114729 bytes (12%)
    I: Downloaded 256650/2114729 bytes (12%)
    I: Downloaded 257004/2114729 bytes (12%)
    I: Downloaded 257358/2114729 bytes (12%)
    I: Downloaded 257712/2114729 bytes (12%)
    I: Downloaded 258066/2114729 bytes (12%)
    I: Downloaded 258420/2114729 bytes (12%)
    I: Downloaded 258774/2114729 bytes (12%)
    I: Downloaded 259305/2114729 bytes (12%)
    I: Downloaded 259659/2114729 bytes (12%)
    I: Downloaded 260013/2114729 bytes (12%)
    I: Downloaded 260367/2114729 bytes (12%)
    I: Downloaded 260544/2114729 bytes (12%)
    I: Downloaded 260898/2114729 bytes (12%)
    I: Downloaded 261252/2114729 bytes (12%)
    I: Downloaded 261606/2114729 bytes (12%)
    I: Downloaded 261960/2114729 bytes (12%)
    I: Downloaded 262314/2114729 bytes (12%)
    I: Downloaded 263022/2114729 bytes (12%)
    I: Downloaded 263641/2114729 bytes (12%)
    I: Downloaded 264172/2114729 bytes (12%)
    I: Downloaded 264703/2114729 bytes (12%)
    I: Downloaded 265234/2114729 bytes (12%)
    I: Downloaded 265765/2114729 bytes (12%)
    I: Downloaded 266208/2114729 bytes (12%)
    I: Downloaded 266739/2114729 bytes (12%)
    I: Downloaded 267270/2114729 bytes (12%)
    I: Downloaded 267801/2114729 bytes (12%)
    I: Downloaded 268332/2114729 bytes (12%)
    I: Downloaded 268686/2114729 bytes (12%)
    I: Downloaded 269349/2114729 bytes (12%)
    I: Downloaded 269968/2114729 bytes (12%)
    I: Downloaded 270587/2114729 bytes (12%)
    I: Downloaded 271206/2114729 bytes (12%)
    I: Downloaded 271825/2114729 bytes (12%)
    I: Downloaded 271872/2114729 bytes (12%)
    I: Downloaded 272491/2114729 bytes (12%)
    I: Downloaded 273110/2114729 bytes (12%)
    I: Downloaded 273729/2114729 bytes (12%)
    I: Downloaded 274348/2114729 bytes (12%)
    I: Downloaded 274704/2114729 bytes (12%)
    I: Downloaded 275389/2114729 bytes (13%)
    I: Downloaded 276052/2114729 bytes (13%)
    I: Downloaded 276715/2114729 bytes (13%)
    I: Downloaded 277378/2114729 bytes (13%)
    I: Downloaded 277536/2114729 bytes (13%)
    I: Downloaded 278199/2114729 bytes (13%)
    I: Downloaded 278862/2114729 bytes (13%)
    I: Downloaded 279525/2114729 bytes (13%)
    I: Downloaded 280101/2114729 bytes (13%)
    I: Downloaded 280797/2114729 bytes (13%)
    I: Downloaded 281482/2114729 bytes (13%)
    I: Downloaded 282167/2114729 bytes (13%)
    I: Downloaded 282852/2114729 bytes (13%)
    I: Downloaded 283200/2114729 bytes (13%)
    I: Downloaded 283885/2114729 bytes (13%)
    I: Downloaded 284570/2114729 bytes (13%)
    I: Downloaded 285272/2114729 bytes (13%)
    I: Downloaded 286032/2114729 bytes (13%)
    I: Downloaded 286728/2114729 bytes (13%)
    I: Downloaded 287424/2114729 bytes (13%)
    I: Downloaded 288120/2114729 bytes (13%)
    I: Downloaded 288816/2114729 bytes (13%)
    I: Downloaded 288864/2114729 bytes (13%)
    I: Downloaded 289560/2114729 bytes (13%)
    I: Downloaded 290256/2114729 bytes (13%)
    I: Downloaded 290958/2114729 bytes (13%)
    I: Downloaded 291696/2114729 bytes (13%)
    I: Downloaded 292398/2114729 bytes (13%)
    I: Downloaded 293100/2114729 bytes (13%)
    I: Downloaded 293802/2114729 bytes (13%)
    I: Downloaded 294504/2114729 bytes (13%)
    I: Downloaded 295230/2114729 bytes (13%)
    I: Downloaded 295932/2114729 bytes (13%)
    I: Downloaded 296634/2114729 bytes (14%)
    I: Downloaded 297330/2114729 bytes (14%)
    I: Downloaded 298062/2114729 bytes (14%)
    I: Downloaded 298764/2114729 bytes (14%)
    I: Downloaded 299466/2114729 bytes (14%)
    I: Downloaded 300192/2114729 bytes (14%)
    I: Downloaded 300894/2114729 bytes (14%)
    I: Downloaded 301596/2114729 bytes (14%)
    I: Downloaded 302298/2114729 bytes (14%)
    I: Downloaded 303024/2114729 bytes (14%)
    I: Downloaded 303726/2114729 bytes (14%)
    I: Downloaded 304428/2114729 bytes (14%)
    I: Downloaded 305130/2114729 bytes (14%)
    I: Downloaded 305832/2114729 bytes (14%)
    I: Downloaded 306558/2114729 bytes (14%)
    I: Downloaded 307260/2114729 bytes (14%)
    I: Downloaded 307962/2114729 bytes (14%)
    I: Downloaded 308664/2114729 bytes (14%)
    I: Downloaded 309042/2114729 bytes (14%)
    I: Downloaded 309744/2114729 bytes (14%)
    I: Downloaded 310446/2114729 bytes (14%)
    I: Downloaded 311148/2114729 bytes (14%)
    I: Downloaded 311694/2114729 bytes (14%)
    I: Downloaded 312396/2114729 bytes (14%)
    I: Downloaded 313098/2114729 bytes (14%)
    I: Downloaded 313800/2114729 bytes (14%)
    I: Downloaded 314346/2114729 bytes (14%)
    I: Downloaded 315048/2114729 bytes (14%)
    I: Downloaded 315750/2114729 bytes (14%)
    I: Downloaded 316452/2114729 bytes (14%)
    I: Downloaded 316998/2114729 bytes (14%)
    I: Downloaded 317700/2114729 bytes (15%)
    I: Downloaded 318402/2114729 bytes (15%)
    I: Downloaded 319104/2114729 bytes (15%)
    I: Downloaded 319650/2114729 bytes (15%)
    I: Downloaded 320352/2114729 bytes (15%)
    I: Downloaded 321054/2114729 bytes (15%)
    I: Downloaded 321756/2114729 bytes (15%)
    I: Downloaded 322122/2114729 bytes (15%)
    I: Downloaded 322302/2114729 bytes (15%)
    I: Downloaded 323004/2114729 bytes (15%)
    I: Downloaded 323706/2114729 bytes (15%)
    I: Downloaded 324408/2114729 bytes (15%)
    I: Downloaded 324954/2114729 bytes (15%)
    I: Downloaded 325656/2114729 bytes (15%)
    I: Downloaded 326022/2114729 bytes (15%)
    I: Downloaded 326724/2114729 bytes (15%)
    I: Downloaded 327426/2114729 bytes (15%)
    I: Downloaded 327606/2114729 bytes (15%)
    I: Downloaded 328308/2114729 bytes (15%)
    I: Downloaded 329010/2114729 bytes (15%)
    I: Downloaded 329712/2114729 bytes (15%)
    I: Downloaded 330414/2114729 bytes (15%)
    I: Downloaded 331116/2114729 bytes (15%)
    I: Downloaded 331818/2114729 bytes (15%)
    I: Downloaded 332520/2114729 bytes (15%)
    I: Downloaded 333096/2114729 bytes (15%)
    I: Downloaded 333222/2114729 bytes (15%)
    I: Downloaded 333924/2114729 bytes (15%)
    I: Downloaded 334626/2114729 bytes (15%)
    I: Downloaded 335328/2114729 bytes (15%)
    I: Downloaded 336030/2114729 bytes (15%)
    I: Downloaded 336732/2114729 bytes (15%)
    I: Downloaded 337434/2114729 bytes (15%)
    I: Downloaded 338136/2114729 bytes (15%)
    I: Downloaded 338838/2114729 bytes (16%)
    I: Downloaded 339540/2114729 bytes (16%)
    I: Downloaded 340242/2114729 bytes (16%)
    I: Downloaded 340944/2114729 bytes (16%)
    I: Downloaded 341646/2114729 bytes (16%)
    I: Downloaded 342348/2114729 bytes (16%)
    I: Downloaded 343050/2114729 bytes (16%)
    I: Downloaded 343752/2114729 bytes (16%)
    I: Downloaded 344454/2114729 bytes (16%)
    I: Downloaded 345156/2114729 bytes (16%)
    I: Downloaded 345858/2114729 bytes (16%)
    I: Downloaded 346560/2114729 bytes (16%)
    I: Downloaded 347262/2114729 bytes (16%)
    I: Downloaded 347964/2114729 bytes (16%)
    I: Downloaded 348666/2114729 bytes (16%)
    I: Downloaded 349368/2114729 bytes (16%)
    I: Downloaded 350070/2114729 bytes (16%)
    I: Downloaded 350772/2114729 bytes (16%)
    I: Downloaded 351474/2114729 bytes (16%)
    I: Downloaded 352176/2114729 bytes (16%)
    I: Downloaded 352878/2114729 bytes (16%)
    I: Downloaded 353580/2114729 bytes (16%)
    I: Downloaded 354282/2114729 bytes (16%)
    I: Downloaded 354984/2114729 bytes (16%)
    I: Downloaded 355686/2114729 bytes (16%)
    I: Downloaded 356388/2114729 bytes (16%)
    I: Downloaded 357090/2114729 bytes (16%)
    I: Downloaded 357792/2114729 bytes (16%)
    I: Downloaded 358494/2114729 bytes (16%)
    I: Downloaded 359196/2114729 bytes (16%)
    I: Downloaded 359898/2114729 bytes (17%)
    I: Downloaded 360600/2114729 bytes (17%)
    I: Downloaded 361302/2114729 bytes (17%)
    I: Downloaded 362004/2114729 bytes (17%)
    I: Downloaded 362706/2114729 bytes (17%)
    I: Downloaded 363408/2114729 bytes (17%)
    I: Downloaded 364110/2114729 bytes (17%)
    I: Downloaded 364812/2114729 bytes (17%)
    I: Downloaded 365514/2114729 bytes (17%)
    I: Downloaded 366216/2114729 bytes (17%)
    I: Downloaded 366918/2114729 bytes (17%)
    I: Downloaded 367674/2114729 bytes (17%)
    I: Downloaded 368376/2114729 bytes (17%)
    I: Downloaded 369078/2114729 bytes (17%)
    I: Downloaded 369726/2114729 bytes (17%)
    I: Downloaded 370428/2114729 bytes (17%)
    I: Downloaded 371130/2114729 bytes (17%)
    I: Downloaded 371832/2114729 bytes (17%)
    I: Downloaded 371886/2114729 bytes (17%)
    I: Downloaded 372534/2114729 bytes (17%)
    I: Downloaded 373236/2114729 bytes (17%)
    I: Downloaded 373938/2114729 bytes (17%)
    I: Downloaded 374640/2114729 bytes (17%)
    I: Downloaded 375342/2114729 bytes (17%)
    I: Downloaded 376044/2114729 bytes (17%)
    I: Downloaded 376746/2114729 bytes (17%)
    I: Downloaded 377502/2114729 bytes (17%)
    I: Downloaded 378150/2114729 bytes (17%)
    I: Downloaded 378852/2114729 bytes (17%)
    I: Downloaded 379554/2114729 bytes (17%)
    I: Downloaded 380256/2114729 bytes (17%)
    I: Downloaded 380958/2114729 bytes (18%)
    I: Downloaded 381660/2114729 bytes (18%)
    I: Downloaded 382362/2114729 bytes (18%)
    I: Downloaded 383064/2114729 bytes (18%)
    I: Downloaded 383766/2114729 bytes (18%)
    I: Downloaded 384468/2114729 bytes (18%)
    I: Downloaded 385170/2114729 bytes (18%)
    I: Downloaded 385872/2114729 bytes (18%)
    I: Downloaded 386574/2114729 bytes (18%)
    I: Downloaded 387276/2114729 bytes (18%)
    I: Downloaded 387978/2114729 bytes (18%)
    I: Downloaded 388680/2114729 bytes (18%)
    I: Downloaded 389382/2114729 bytes (18%)
    I: Downloaded 390084/2114729 bytes (18%)
    I: Downloaded 390786/2114729 bytes (18%)
    I: Downloaded 391488/2114729 bytes (18%)
    I: Downloaded 392190/2114729 bytes (18%)
    I: Downloaded 392892/2114729 bytes (18%)
    I: Downloaded 393594/2114729 bytes (18%)
    I: Downloaded 394350/2114729 bytes (18%)
    I: Downloaded 394998/2114729 bytes (18%)
    I: Downloaded 395700/2114729 bytes (18%)
    I: Downloaded 396402/2114729 bytes (18%)
    I: Downloaded 397104/2114729 bytes (18%)
    I: Downloaded 397806/2114729 bytes (18%)
    I: Downloaded 398562/2114729 bytes (18%)
    I: Downloaded 399264/2114729 bytes (18%)
    I: Downloaded 399966/2114729 bytes (18%)
    I: Downloaded 400614/2114729 bytes (18%)
    I: Downloaded 401316/2114729 bytes (18%)
    I: Downloaded 402018/2114729 bytes (19%)
    I: Downloaded 402720/2114729 bytes (19%)
    I: Downloaded 403422/2114729 bytes (19%)
    I: Downloaded 404124/2114729 bytes (19%)
    I: Downloaded 404826/2114729 bytes (19%)
    I: Downloaded 405636/2114729 bytes (19%)
    I: Downloaded 406230/2114729 bytes (19%)
    I: Downloaded 406932/2114729 bytes (19%)
    I: Downloaded 407634/2114729 bytes (19%)
    I: Downloaded 408336/2114729 bytes (19%)
    I: Downloaded 409038/2114729 bytes (19%)
    I: Downloaded 409794/2114729 bytes (19%)
    I: Downloaded 410496/2114729 bytes (19%)
    I: Downloaded 411198/2114729 bytes (19%)
    I: Downloaded 411846/2114729 bytes (19%)
    I: Downloaded 412548/2114729 bytes (19%)
    I: Downloaded 413250/2114729 bytes (19%)
    I: Downloaded 413952/2114729 bytes (19%)
    I: Downloaded 414654/2114729 bytes (19%)
    I: Downloaded 415356/2114729 bytes (19%)
    I: Downloaded 416058/2114729 bytes (19%)
    I: Downloaded 416760/2114729 bytes (19%)
    I: Downloaded 417462/2114729 bytes (19%)
    I: Downloaded 418164/2114729 bytes (19%)
    I: Downloaded 418866/2114729 bytes (19%)
    I: Downloaded 419568/2114729 bytes (19%)
    I: Downloaded 420270/2114729 bytes (19%)
    I: Downloaded 420972/2114729 bytes (19%)
    I: Downloaded 421674/2114729 bytes (19%)
    I: Downloaded 422430/2114729 bytes (19%)
    I: Downloaded 423078/2114729 bytes (20%)
    I: Downloaded 423780/2114729 bytes (20%)
    I: Downloaded 424482/2114729 bytes (20%)
    I: Downloaded 425184/2114729 bytes (20%)
    I: Downloaded 425886/2114729 bytes (20%)
    I: Downloaded 426588/2114729 bytes (20%)
    I: Downloaded 427290/2114729 bytes (20%)
    I: Downloaded 427992/2114729 bytes (20%)
    I: Downloaded 428694/2114729 bytes (20%)
    I: Downloaded 429396/2114729 bytes (20%)
    I: Downloaded 430098/2114729 bytes (20%)
    I: Downloaded 430800/2114729 bytes (20%)
    I: Downloaded 431502/2114729 bytes (20%)
    I: Downloaded 432204/2114729 bytes (20%)
    I: Downloaded 432906/2114729 bytes (20%)
    I: Downloaded 433608/2114729 bytes (20%)
    I: Downloaded 434310/2114729 bytes (20%)
    I: Downloaded 435012/2114729 bytes (20%)
    I: Downloaded 435714/2114729 bytes (20%)
    I: Downloaded 436416/2114729 bytes (20%)
    I: Downloaded 437118/2114729 bytes (20%)
    I: Downloaded 437820/2114729 bytes (20%)
    I: Downloaded 438522/2114729 bytes (20%)
    I: Downloaded 439224/2114729 bytes (20%)
    I: Downloaded 439926/2114729 bytes (20%)
    I: Downloaded 440628/2114729 bytes (20%)
    I: Downloaded 441330/2114729 bytes (20%)
    I: Downloaded 442032/2114729 bytes (20%)
    I: Downloaded 442086/2114729 bytes (20%)
    I: Downloaded 442734/2114729 bytes (20%)
    I: Downloaded 443436/2114729 bytes (20%)
    I: Downloaded 444138/2114729 bytes (21%)
    I: Downloaded 444840/2114729 bytes (21%)
    I: Downloaded 445542/2114729 bytes (21%)
    I: Downloaded 446244/2114729 bytes (21%)
    I: Downloaded 446298/2114729 bytes (21%)
    I: Downloaded 447000/2114729 bytes (21%)
    I: Downloaded 447702/2114729 bytes (21%)
    I: Downloaded 448350/2114729 bytes (21%)
    I: Downloaded 449052/2114729 bytes (21%)
    I: Downloaded 449754/2114729 bytes (21%)
    I: Downloaded 450456/2114729 bytes (21%)
    I: Downloaded 451158/2114729 bytes (21%)
    I: Downloaded 451860/2114729 bytes (21%)
    I: Downloaded 452562/2114729 bytes (21%)
    I: Downloaded 453264/2114729 bytes (21%)
    I: Downloaded 453372/2114729 bytes (21%)
    I: Downloaded 453966/2114729 bytes (21%)
    I: Downloaded 454668/2114729 bytes (21%)
    I: Downloaded 455370/2114729 bytes (21%)
    I: Downloaded 456072/2114729 bytes (21%)
    I: Downloaded 456774/2114729 bytes (21%)
    I: Downloaded 457476/2114729 bytes (21%)
    I: Downloaded 458178/2114729 bytes (21%)
    I: Downloaded 458880/2114729 bytes (21%)
    I: Downloaded 459582/2114729 bytes (21%)
    I: Downloaded 460284/2114729 bytes (21%)
    I: Downloaded 460986/2114729 bytes (21%)
    I: Downloaded 461688/2114729 bytes (21%)
    I: Downloaded 462390/2114729 bytes (21%)
    I: Downloaded 463092/2114729 bytes (21%)
    I: Downloaded 463794/2114729 bytes (21%)
    I: Downloaded 464496/2114729 bytes (21%)
    I: Downloaded 465198/2114729 bytes (21%)
    I: Downloaded 465900/2114729 bytes (22%)
    I: Downloaded 466602/2114729 bytes (22%)
    I: Downloaded 467304/2114729 bytes (22%)
    I: Downloaded 468006/2114729 bytes (22%)
    I: Downloaded 468708/2114729 bytes (22%)
    I: Downloaded 469410/2114729 bytes (22%)
    I: Downloaded 470112/2114729 bytes (22%)
    I: Downloaded 470814/2114729 bytes (22%)
    I: Downloaded 471516/2114729 bytes (22%)
    I: Downloaded 472218/2114729 bytes (22%)
    I: Downloaded 472920/2114729 bytes (22%)
    I: Downloaded 473622/2114729 bytes (22%)
    I: Downloaded 474324/2114729 bytes (22%)
    I: Downloaded 475026/2114729 bytes (22%)
    I: Downloaded 475728/2114729 bytes (22%)
    I: Downloaded 476430/2114729 bytes (22%)
    I: Downloaded 477132/2114729 bytes (22%)
    I: Downloaded 477834/2114729 bytes (22%)
    I: Downloaded 478536/2114729 bytes (22%)
    I: Downloaded 479238/2114729 bytes (22%)
    I: Downloaded 479940/2114729 bytes (22%)
    I: Downloaded 480642/2114729 bytes (22%)
    I: Downloaded 481344/2114729 bytes (22%)
    I: Downloaded 482046/2114729 bytes (22%)
    I: Downloaded 482748/2114729 bytes (22%)
    I: Downloaded 483450/2114729 bytes (22%)
    I: Downloaded 484152/2114729 bytes (22%)
    I: Downloaded 484854/2114729 bytes (22%)
    I: Downloaded 485556/2114729 bytes (22%)
    I: Downloaded 486258/2114729 bytes (22%)
    I: Downloaded 486960/2114729 bytes (23%)
    I: Downloaded 487662/2114729 bytes (23%)
    I: Downloaded 488364/2114729 bytes (23%)
    I: Downloaded 489066/2114729 bytes (23%)
    I: Downloaded 489768/2114729 bytes (23%)
    I: Downloaded 490470/2114729 bytes (23%)
    I: Downloaded 491172/2114729 bytes (23%)
    I: Downloaded 491874/2114729 bytes (23%)
    I: Downloaded 492576/2114729 bytes (23%)
    I: Downloaded 493278/2114729 bytes (23%)
    I: Downloaded 493980/2114729 bytes (23%)
    I: Downloaded 494682/2114729 bytes (23%)
    I: Downloaded 495384/2114729 bytes (23%)
    I: Downloaded 496086/2114729 bytes (23%)
    I: Downloaded 496788/2114729 bytes (23%)
    I: Downloaded 497490/2114729 bytes (23%)
    I: Downloaded 498192/2114729 bytes (23%)
    I: Downloaded 498894/2114729 bytes (23%)
    I: Downloaded 499596/2114729 bytes (23%)
    I: Downloaded 500298/2114729 bytes (23%)
    I: Downloaded 501000/2114729 bytes (23%)
    I: Downloaded 501702/2114729 bytes (23%)
    I: Downloaded 502404/2114729 bytes (23%)
    I: Downloaded 503106/2114729 bytes (23%)
    I: Downloaded 503808/2114729 bytes (23%)
    I: Downloaded 504510/2114729 bytes (23%)
    I: Downloaded 505212/2114729 bytes (23%)
    I: Downloaded 505914/2114729 bytes (23%)
    I: Downloaded 506616/2114729 bytes (23%)
    I: Downloaded 507318/2114729 bytes (23%)
    I: Downloaded 508020/2114729 bytes (24%)
    I: Downloaded 508722/2114729 bytes (24%)
    I: Downloaded 509424/2114729 bytes (24%)
    I: Downloaded 510126/2114729 bytes (24%)
    I: Downloaded 510828/2114729 bytes (24%)
    I: Downloaded 511530/2114729 bytes (24%)
    I: Downloaded 512232/2114729 bytes (24%)
    I: Downloaded 512934/2114729 bytes (24%)
    I: Downloaded 513636/2114729 bytes (24%)
    I: Downloaded 514338/2114729 bytes (24%)
    I: Downloaded 515040/2114729 bytes (24%)
    I: Downloaded 515742/2114729 bytes (24%)
    I: Downloaded 516444/2114729 bytes (24%)
    I: Downloaded 517146/2114729 bytes (24%)
    I: Downloaded 517848/2114729 bytes (24%)
    I: Downloaded 518550/2114729 bytes (24%)
    I: Downloaded 519252/2114729 bytes (24%)
    I: Downloaded 519954/2114729 bytes (24%)
    I: Downloaded 520656/2114729 bytes (24%)
    I: Downloaded 521358/2114729 bytes (24%)
    I: Downloaded 522060/2114729 bytes (24%)
    I: Downloaded 522762/2114729 bytes (24%)
    I: Downloaded 523464/2114729 bytes (24%)
    I: Downloaded 524166/2114729 bytes (24%)
    I: Downloaded 524868/2114729 bytes (24%)
    I: Downloaded 525570/2114729 bytes (24%)
    I: Downloaded 526272/2114729 bytes (24%)
    I: Downloaded 526974/2114729 bytes (24%)
    I: Downloaded 527676/2114729 bytes (24%)
    I: Downloaded 528378/2114729 bytes (24%)
    I: Downloaded 529080/2114729 bytes (25%)
    I: Downloaded 529782/2114729 bytes (25%)
    I: Downloaded 530484/2114729 bytes (25%)
    I: Downloaded 531186/2114729 bytes (25%)
    I: Downloaded 531888/2114729 bytes (25%)
    I: Downloaded 532590/2114729 bytes (25%)
    I: Downloaded 533292/2114729 bytes (25%)
    I: Downloaded 533994/2114729 bytes (25%)
    I: Downloaded 534696/2114729 bytes (25%)
    I: Downloaded 535398/2114729 bytes (25%)
    I: Downloaded 536100/2114729 bytes (25%)
    I: Downloaded 536802/2114729 bytes (25%)
    I: Downloaded 537558/2114729 bytes (25%)
    I: Downloaded 538206/2114729 bytes (25%)
    I: Downloaded 538908/2114729 bytes (25%)
    I: Downloaded 539610/2114729 bytes (25%)
    I: Downloaded 540312/2114729 bytes (25%)
    I: Downloaded 541014/2114729 bytes (25%)
    I: Downloaded 541770/2114729 bytes (25%)
    I: Downloaded 542472/2114729 bytes (25%)
    I: Downloaded 543174/2114729 bytes (25%)
    I: Downloaded 543822/2114729 bytes (25%)
    I: Downloaded 544524/2114729 bytes (25%)
    I: Downloaded 545226/2114729 bytes (25%)
    I: Downloaded 545928/2114729 bytes (25%)
    I: Downloaded 546630/2114729 bytes (25%)
    I: Downloaded 547332/2114729 bytes (25%)
    I: Downloaded 548034/2114729 bytes (25%)
    I: Downloaded 548736/2114729 bytes (25%)
    I: Downloaded 549438/2114729 bytes (25%)
    I: Downloaded 550140/2114729 bytes (26%)
    I: Downloaded 550842/2114729 bytes (26%)
    I: Downloaded 551544/2114729 bytes (26%)
    I: Downloaded 552246/2114729 bytes (26%)
    I: Downloaded 552948/2114729 bytes (26%)
    I: Downloaded 553650/2114729 bytes (26%)
    I: Downloaded 554352/2114729 bytes (26%)
    I: Downloaded 555054/2114729 bytes (26%)
    I: Downloaded 555756/2114729 bytes (26%)
    I: Downloaded 556458/2114729 bytes (26%)
    I: Downloaded 557160/2114729 bytes (26%)
    I: Downloaded 557862/2114729 bytes (26%)
    I: Downloaded 558564/2114729 bytes (26%)
    I: Downloaded 559266/2114729 bytes (26%)
    I: Downloaded 559968/2114729 bytes (26%)
    I: Downloaded 560670/2114729 bytes (26%)
    I: Downloaded 561372/2114729 bytes (26%)
    I: Downloaded 562074/2114729 bytes (26%)
    I: Downloaded 562776/2114729 bytes (26%)
    I: Downloaded 563478/2114729 bytes (26%)
    I: Downloaded 564180/2114729 bytes (26%)
    I: Downloaded 564882/2114729 bytes (26%)
    I: Downloaded 565584/2114729 bytes (26%)
    I: Downloaded 566286/2114729 bytes (26%)
    I: Downloaded 566988/2114729 bytes (26%)
    I: Downloaded 567690/2114729 bytes (26%)
    I: Downloaded 568392/2114729 bytes (26%)
    I: Downloaded 569094/2114729 bytes (26%)
    I: Downloaded 569796/2114729 bytes (26%)
    I: Downloaded 570498/2114729 bytes (26%)
    I: Downloaded 571200/2114729 bytes (27%)
    I: Downloaded 571902/2114729 bytes (27%)
    I: Downloaded 572604/2114729 bytes (27%)
    I: Downloaded 573306/2114729 bytes (27%)
    I: Downloaded 574008/2114729 bytes (27%)
    I: Downloaded 574710/2114729 bytes (27%)
    I: Downloaded 575412/2114729 bytes (27%)
    I: Downloaded 576114/2114729 bytes (27%)
    I: Downloaded 576816/2114729 bytes (27%)
    I: Downloaded 577518/2114729 bytes (27%)
    I: Downloaded 578220/2114729 bytes (27%)
    I: Downloaded 578922/2114729 bytes (27%)
    I: Downloaded 579624/2114729 bytes (27%)
    I: Downloaded 580326/2114729 bytes (27%)
    I: Downloaded 581028/2114729 bytes (27%)
    I: Downloaded 581730/2114729 bytes (27%)
    I: Downloaded 582432/2114729 bytes (27%)
    I: Downloaded 583134/2114729 bytes (27%)
    I: Downloaded 583836/2114729 bytes (27%)
    I: Downloaded 584538/2114729 bytes (27%)
    I: Downloaded 585240/2114729 bytes (27%)
    I: Downloaded 585942/2114729 bytes (27%)
    I: Downloaded 586644/2114729 bytes (27%)
    I: Downloaded 587346/2114729 bytes (27%)
    I: Downloaded 588048/2114729 bytes (27%)
    I: Downloaded 588750/2114729 bytes (27%)
    I: Downloaded 589452/2114729 bytes (27%)
    I: Downloaded 590154/2114729 bytes (27%)
    I: Downloaded 590856/2114729 bytes (27%)
    I: Downloaded 591558/2114729 bytes (27%)
    I: Downloaded 592260/2114729 bytes (28%)
    I: Downloaded 592962/2114729 bytes (28%)
    I: Downloaded 593664/2114729 bytes (28%)
    I: Downloaded 594366/2114729 bytes (28%)
    I: Downloaded 595068/2114729 bytes (28%)
    I: Downloaded 595770/2114729 bytes (28%)
    I: Downloaded 596472/2114729 bytes (28%)
    I: Downloaded 597174/2114729 bytes (28%)
    I: Downloaded 597876/2114729 bytes (28%)
    I: Downloaded 598578/2114729 bytes (28%)
    I: Downloaded 599280/2114729 bytes (28%)
    I: Downloaded 599982/2114729 bytes (28%)
    I: Downloaded 600684/2114729 bytes (28%)
    I: Downloaded 601386/2114729 bytes (28%)
    I: Downloaded 602088/2114729 bytes (28%)
    I: Downloaded 602790/2114729 bytes (28%)
    I: Downloaded 603492/2114729 bytes (28%)
    I: Downloaded 604194/2114729 bytes (28%)
    I: Downloaded 604896/2114729 bytes (28%)
    I: Downloaded 605598/2114729 bytes (28%)
    I: Downloaded 606300/2114729 bytes (28%)
    I: Downloaded 607002/2114729 bytes (28%)
    I: Downloaded 607704/2114729 bytes (28%)
    I: Downloaded 608406/2114729 bytes (28%)
    I: Downloaded 609108/2114729 bytes (28%)
    I: Downloaded 609810/2114729 bytes (28%)
    I: Downloaded 610512/2114729 bytes (28%)
    I: Downloaded 611214/2114729 bytes (28%)
    I: Downloaded 611916/2114729 bytes (28%)
    I: Downloaded 612618/2114729 bytes (28%)
    I: Downloaded 613320/2114729 bytes (29%)
    I: Downloaded 614022/2114729 bytes (29%)
    I: Downloaded 614724/2114729 bytes (29%)
    I: Downloaded 615426/2114729 bytes (29%)
    I: Downloaded 616128/2114729 bytes (29%)
    I: Downloaded 616830/2114729 bytes (29%)
    I: Downloaded 617532/2114729 bytes (29%)
    I: Downloaded 618234/2114729 bytes (29%)
    I: Downloaded 618936/2114729 bytes (29%)
    I: Downloaded 619638/2114729 bytes (29%)
    I: Downloaded 620340/2114729 bytes (29%)
    I: Downloaded 621042/2114729 bytes (29%)
    I: Downloaded 621744/2114729 bytes (29%)
    I: Downloaded 622446/2114729 bytes (29%)
    I: Downloaded 623202/2114729 bytes (29%)
    I: Downloaded 623904/2114729 bytes (29%)
    I: Downloaded 624606/2114729 bytes (29%)
    I: Downloaded 625254/2114729 bytes (29%)
    I: Downloaded 625956/2114729 bytes (29%)
    I: Downloaded 626658/2114729 bytes (29%)
    I: Downloaded 627414/2114729 bytes (29%)
    I: Downloaded 628062/2114729 bytes (29%)
    I: Downloaded 628764/2114729 bytes (29%)
    I: Downloaded 629466/2114729 bytes (29%)
    I: Downloaded 630168/2114729 bytes (29%)
    I: Downloaded 630870/2114729 bytes (29%)
    I: Downloaded 631572/2114729 bytes (29%)
    I: Downloaded 632274/2114729 bytes (29%)
    I: Downloaded 632976/2114729 bytes (29%)
    I: Downloaded 633678/2114729 bytes (29%)
    I: Downloaded 634434/2114729 bytes (30%)
    I: Downloaded 635136/2114729 bytes (30%)
    I: Downloaded 635838/2114729 bytes (30%)
    I: Downloaded 636486/2114729 bytes (30%)
    I: Downloaded 637188/2114729 bytes (30%)
    I: Downloaded 637890/2114729 bytes (30%)
    I: Downloaded 638646/2114729 bytes (30%)
    I: Downloaded 639294/2114729 bytes (30%)
    I: Downloaded 639996/2114729 bytes (30%)
    I: Downloaded 640698/2114729 bytes (30%)
    I: Downloaded 641400/2114729 bytes (30%)
    I: Downloaded 642102/2114729 bytes (30%)
    I: Downloaded 642804/2114729 bytes (30%)
    I: Downloaded 643506/2114729 bytes (30%)
    I: Downloaded 644208/2114729 bytes (30%)
    I: Downloaded 644910/2114729 bytes (30%)
    I: Downloaded 645612/2114729 bytes (30%)
    I: Downloaded 646314/2114729 bytes (30%)
    I: Downloaded 647016/2114729 bytes (30%)
    I: Downloaded 647718/2114729 bytes (30%)
    I: Downloaded 648420/2114729 bytes (30%)
    I: Downloaded 649122/2114729 bytes (30%)
    I: Downloaded 649824/2114729 bytes (30%)
    I: Downloaded 650526/2114729 bytes (30%)
    I: Downloaded 651228/2114729 bytes (30%)
    I: Downloaded 651930/2114729 bytes (30%)
    I: Downloaded 652632/2114729 bytes (30%)
    I: Downloaded 653334/2114729 bytes (30%)
    I: Downloaded 654036/2114729 bytes (30%)
    I: Downloaded 654738/2114729 bytes (30%)
    I: Downloaded 655440/2114729 bytes (30%)
    I: Downloaded 656142/2114729 bytes (31%)
    I: Downloaded 656844/2114729 bytes (31%)
    I: Downloaded 657546/2114729 bytes (31%)
    I: Downloaded 658248/2114729 bytes (31%)
    I: Downloaded 658950/2114729 bytes (31%)
    I: Downloaded 659652/2114729 bytes (31%)
    I: Downloaded 660354/2114729 bytes (31%)
    I: Downloaded 661056/2114729 bytes (31%)
    I: Downloaded 661758/2114729 bytes (31%)
    I: Downloaded 662460/2114729 bytes (31%)
    I: Downloaded 663162/2114729 bytes (31%)
    I: Downloaded 663864/2114729 bytes (31%)
    I: Downloaded 664566/2114729 bytes (31%)
    I: Downloaded 665268/2114729 bytes (31%)
    I: Downloaded 665970/2114729 bytes (31%)
    I: Downloaded 666672/2114729 bytes (31%)
    I: Downloaded 667374/2114729 bytes (31%)
    I: Downloaded 668076/2114729 bytes (31%)
    I: Downloaded 668130/2114729 bytes (31%)
    I: Downloaded 668832/2114729 bytes (31%)
    I: Downloaded 669534/2114729 bytes (31%)
    I: Downloaded 670182/2114729 bytes (31%)
    I: Downloaded 670884/2114729 bytes (31%)
    I: Downloaded 671586/2114729 bytes (31%)
    I: Downloaded 672288/2114729 bytes (31%)
    I: Downloaded 672342/2114729 bytes (31%)
    I: Downloaded 672990/2114729 bytes (31%)
    I: Downloaded 673692/2114729 bytes (31%)
    I: Downloaded 674394/2114729 bytes (31%)
    I: Downloaded 675096/2114729 bytes (31%)
    I: Downloaded 675798/2114729 bytes (31%)
    I: Downloaded 676500/2114729 bytes (31%)
    I: Downloaded 677202/2114729 bytes (32%)
    I: Downloaded 677904/2114729 bytes (32%)
    I: Downloaded 678606/2114729 bytes (32%)
    I: Downloaded 679308/2114729 bytes (32%)
    I: Downloaded 680010/2114729 bytes (32%)
    I: Downloaded 680766/2114729 bytes (32%)
    I: Downloaded 681414/2114729 bytes (32%)
    I: Downloaded 682116/2114729 bytes (32%)
    I: Downloaded 682818/2114729 bytes (32%)
    I: Downloaded 683520/2114729 bytes (32%)
    I: Downloaded 684222/2114729 bytes (32%)
    I: Downloaded 684978/2114729 bytes (32%)
    I: Downloaded 685680/2114729 bytes (32%)
    I: Downloaded 686382/2114729 bytes (32%)
    I: Downloaded 687030/2114729 bytes (32%)
    I: Downloaded 687732/2114729 bytes (32%)
    I: Downloaded 688434/2114729 bytes (32%)
    I: Downloaded 689136/2114729 bytes (32%)
    I: Downloaded 689838/2114729 bytes (32%)
    I: Downloaded 690540/2114729 bytes (32%)
    I: Downloaded 691242/2114729 bytes (32%)
    I: Downloaded 691944/2114729 bytes (32%)
    I: Downloaded 692052/2114729 bytes (32%)
    I: Downloaded 692646/2114729 bytes (32%)
    I: Downloaded 693348/2114729 bytes (32%)
    I: Downloaded 694050/2114729 bytes (32%)
    I: Downloaded 694806/2114729 bytes (32%)
    I: Downloaded 695454/2114729 bytes (32%)
    I: Downloaded 696156/2114729 bytes (32%)
    I: Downloaded 696858/2114729 bytes (32%)
    I: Downloaded 697560/2114729 bytes (32%)
    I: Downloaded 698262/2114729 bytes (33%)
    I: Downloaded 698964/2114729 bytes (33%)
    I: Downloaded 699666/2114729 bytes (33%)
    I: Downloaded 700368/2114729 bytes (33%)
    I: Downloaded 701070/2114729 bytes (33%)
    I: Downloaded 701826/2114729 bytes (33%)
    I: Downloaded 702528/2114729 bytes (33%)
    I: Downloaded 703230/2114729 bytes (33%)
    I: Downloaded 703878/2114729 bytes (33%)
    I: Downloaded 704580/2114729 bytes (33%)
    I: Downloaded 705282/2114729 bytes (33%)
    I: Downloaded 705984/2114729 bytes (33%)
    I: Downloaded 706038/2114729 bytes (33%)
    I: Downloaded 706686/2114729 bytes (33%)
    I: Downloaded 707388/2114729 bytes (33%)
    I: Downloaded 708090/2114729 bytes (33%)
    I: Downloaded 708792/2114729 bytes (33%)
    I: Downloaded 709494/2114729 bytes (33%)
    I: Downloaded 710196/2114729 bytes (33%)
    I: Downloaded 710898/2114729 bytes (33%)
    I: Downloaded 711600/2114729 bytes (33%)
    I: Downloaded 712302/2114729 bytes (33%)
    I: Downloaded 713004/2114729 bytes (33%)
    I: Downloaded 713706/2114729 bytes (33%)
    I: Downloaded 714462/2114729 bytes (33%)
    I: Downloaded 715110/2114729 bytes (33%)
    I: Downloaded 715812/2114729 bytes (33%)
    I: Downloaded 716514/2114729 bytes (33%)
    I: Downloaded 717216/2114729 bytes (33%)
    I: Downloaded 717918/2114729 bytes (33%)
    I: Downloaded 718620/2114729 bytes (33%)
    I: Downloaded 718674/2114729 bytes (33%)
    I: Downloaded 719376/2114729 bytes (34%)
    I: Downloaded 720078/2114729 bytes (34%)
    I: Downloaded 720726/2114729 bytes (34%)
    I: Downloaded 721428/2114729 bytes (34%)
    I: Downloaded 722130/2114729 bytes (34%)
    I: Downloaded 722832/2114729 bytes (34%)
    I: Downloaded 723534/2114729 bytes (34%)
    I: Downloaded 724236/2114729 bytes (34%)
    I: Downloaded 724290/2114729 bytes (34%)
    I: Downloaded 724992/2114729 bytes (34%)
    I: Downloaded 725694/2114729 bytes (34%)
    I: Downloaded 726342/2114729 bytes (34%)
    I: Downloaded 727044/2114729 bytes (34%)
    I: Downloaded 727746/2114729 bytes (34%)
    I: Downloaded 728448/2114729 bytes (34%)
    I: Downloaded 729150/2114729 bytes (34%)
    I: Downloaded 729852/2114729 bytes (34%)
    I: Downloaded 730554/2114729 bytes (34%)
    I: Downloaded 731256/2114729 bytes (34%)
    I: Downloaded 731958/2114729 bytes (34%)
    I: Downloaded 732660/2114729 bytes (34%)
    I: Downloaded 733362/2114729 bytes (34%)
    I: Downloaded 734064/2114729 bytes (34%)
    I: Downloaded 734766/2114729 bytes (34%)
    I: Downloaded 735468/2114729 bytes (34%)
    I: Downloaded 736170/2114729 bytes (34%)
    I: Downloaded 736872/2114729 bytes (34%)
    I: Downloaded 737574/2114729 bytes (34%)
    I: Downloaded 738276/2114729 bytes (34%)
    I: Downloaded 738978/2114729 bytes (34%)
    I: Downloaded 739680/2114729 bytes (34%)
    I: Downloaded 740382/2114729 bytes (35%)
    I: Downloaded 741084/2114729 bytes (35%)
    I: Downloaded 741786/2114729 bytes (35%)
    I: Downloaded 742488/2114729 bytes (35%)
    I: Downloaded 743190/2114729 bytes (35%)
    I: Downloaded 743892/2114729 bytes (35%)
    I: Downloaded 744594/2114729 bytes (35%)
    I: Downloaded 745296/2114729 bytes (35%)
    I: Downloaded 745998/2114729 bytes (35%)
    I: Downloaded 746700/2114729 bytes (35%)
    I: Downloaded 747402/2114729 bytes (35%)
    I: Downloaded 748104/2114729 bytes (35%)
    I: Downloaded 748806/2114729 bytes (35%)
    I: Downloaded 749508/2114729 bytes (35%)
    I: Downloaded 750210/2114729 bytes (35%)
    I: Downloaded 750912/2114729 bytes (35%)
    I: Downloaded 751614/2114729 bytes (35%)
    I: Downloaded 752316/2114729 bytes (35%)
    I: Downloaded 753018/2114729 bytes (35%)
    I: Downloaded 753774/2114729 bytes (35%)
    I: Downloaded 754422/2114729 bytes (35%)
    I: Downloaded 755124/2114729 bytes (35%)
    I: Downloaded 755826/2114729 bytes (35%)
    I: Downloaded 756528/2114729 bytes (35%)
    I: Downloaded 757230/2114729 bytes (35%)
    I: Downloaded 757986/2114729 bytes (35%)
    I: Downloaded 758688/2114729 bytes (35%)
    I: Downloaded 759390/2114729 bytes (35%)
    I: Downloaded 760038/2114729 bytes (35%)
    I: Downloaded 760740/2114729 bytes (35%)
    I: Downloaded 761442/2114729 bytes (36%)
    I: Downloaded 762144/2114729 bytes (36%)
    I: Downloaded 762846/2114729 bytes (36%)
    I: Downloaded 763548/2114729 bytes (36%)
    I: Downloaded 764250/2114729 bytes (36%)
    I: Downloaded 764952/2114729 bytes (36%)
    I: Downloaded 765654/2114729 bytes (36%)
    I: Downloaded 766356/2114729 bytes (36%)
    I: Downloaded 767058/2114729 bytes (36%)
    I: Downloaded 767760/2114729 bytes (36%)
    I: Downloaded 768462/2114729 bytes (36%)
    I: Downloaded 769164/2114729 bytes (36%)
    I: Downloaded 769866/2114729 bytes (36%)
    I: Downloaded 770568/2114729 bytes (36%)
    I: Downloaded 771270/2114729 bytes (36%)
    I: Downloaded 771972/2114729 bytes (36%)
    I: Downloaded 772674/2114729 bytes (36%)
    I: Downloaded 773376/2114729 bytes (36%)
    I: Downloaded 774078/2114729 bytes (36%)
    I: Downloaded 774780/2114729 bytes (36%)
    I: Downloaded 775482/2114729 bytes (36%)
    I: Downloaded 776184/2114729 bytes (36%)
    I: Downloaded 776886/2114729 bytes (36%)
    I: Downloaded 777588/2114729 bytes (36%)
    I: Downloaded 778290/2114729 bytes (36%)
    I: Downloaded 778992/2114729 bytes (36%)
    I: Downloaded 779694/2114729 bytes (36%)
    I: Downloaded 780396/2114729 bytes (36%)
    I: Downloaded 781098/2114729 bytes (36%)
    I: Downloaded 781800/2114729 bytes (36%)
    I: Downloaded 782502/2114729 bytes (37%)
    I: Downloaded 783204/2114729 bytes (37%)
    I: Downloaded 783906/2114729 bytes (37%)
    I: Downloaded 784608/2114729 bytes (37%)
    I: Downloaded 785310/2114729 bytes (37%)
    I: Downloaded 786012/2114729 bytes (37%)
    I: Downloaded 786714/2114729 bytes (37%)
    I: Downloaded 787416/2114729 bytes (37%)
    I: Downloaded 788118/2114729 bytes (37%)
    I: Downloaded 788820/2114729 bytes (37%)
    I: Downloaded 789522/2114729 bytes (37%)
    I: Downloaded 790224/2114729 bytes (37%)
    I: Downloaded 790926/2114729 bytes (37%)
    I: Downloaded 791628/2114729 bytes (37%)
    I: Downloaded 791682/2114729 bytes (37%)
    I: Downloaded 792384/2114729 bytes (37%)
    I: Downloaded 793086/2114729 bytes (37%)
    I: Downloaded 793734/2114729 bytes (37%)
    I: Downloaded 794436/2114729 bytes (37%)
    I: Downloaded 795138/2114729 bytes (37%)
    I: Downloaded 795894/2114729 bytes (37%)
    I: Downloaded 796542/2114729 bytes (37%)
    I: Downloaded 797244/2114729 bytes (37%)
    I: Downloaded 797946/2114729 bytes (37%)
    I: Downloaded 798648/2114729 bytes (37%)
    I: Downloaded 799350/2114729 bytes (37%)
    I: Downloaded 800052/2114729 bytes (37%)
    I: Downloaded 800754/2114729 bytes (37%)
    I: Downloaded 801456/2114729 bytes (37%)
    I: Downloaded 802158/2114729 bytes (37%)
    I: Downloaded 802860/2114729 bytes (37%)
    I: Downloaded 803562/2114729 bytes (37%)
    I: Downloaded 804264/2114729 bytes (38%)
    I: Downloaded 804318/2114729 bytes (38%)
    I: Downloaded 804966/2114729 bytes (38%)
    I: Downloaded 805668/2114729 bytes (38%)
    I: Downloaded 806370/2114729 bytes (38%)
    I: Downloaded 807072/2114729 bytes (38%)
    I: Downloaded 807774/2114729 bytes (38%)
    I: Downloaded 808476/2114729 bytes (38%)
    I: Downloaded 809178/2114729 bytes (38%)
    I: Downloaded 809880/2114729 bytes (38%)
    I: Downloaded 810582/2114729 bytes (38%)
    I: Downloaded 811284/2114729 bytes (38%)
    I: Downloaded 811986/2114729 bytes (38%)
    I: Downloaded 812742/2114729 bytes (38%)
    I: Downloaded 813390/2114729 bytes (38%)
    I: Downloaded 814092/2114729 bytes (38%)
    I: Downloaded 814794/2114729 bytes (38%)
    I: Downloaded 815496/2114729 bytes (38%)
    I: Downloaded 816198/2114729 bytes (38%)
    I: Downloaded 816900/2114729 bytes (38%)
    I: Downloaded 816954/2114729 bytes (38%)
    I: Downloaded 817656/2114729 bytes (38%)
    I: Downloaded 818358/2114729 bytes (38%)
    I: Downloaded 819006/2114729 bytes (38%)
    I: Downloaded 819708/2114729 bytes (38%)
    I: Downloaded 820410/2114729 bytes (38%)
    I: Downloaded 821112/2114729 bytes (38%)
    I: Downloaded 821814/2114729 bytes (38%)
    I: Downloaded 822516/2114729 bytes (38%)
    I: Downloaded 823218/2114729 bytes (38%)
    I: Downloaded 823920/2114729 bytes (38%)
    I: Downloaded 824622/2114729 bytes (38%)
    I: Downloaded 825324/2114729 bytes (39%)
    I: Downloaded 826026/2114729 bytes (39%)
    I: Downloaded 826728/2114729 bytes (39%)
    I: Downloaded 827430/2114729 bytes (39%)
    I: Downloaded 828132/2114729 bytes (39%)
    I: Downloaded 828834/2114729 bytes (39%)
    I: Downloaded 829536/2114729 bytes (39%)
    I: Downloaded 830238/2114729 bytes (39%)
    I: Downloaded 830940/2114729 bytes (39%)
    I: Downloaded 831642/2114729 bytes (39%)
    I: Downloaded 832344/2114729 bytes (39%)
    I: Downloaded 833046/2114729 bytes (39%)
    I: Downloaded 833748/2114729 bytes (39%)
    I: Downloaded 834450/2114729 bytes (39%)
    I: Downloaded 835152/2114729 bytes (39%)
    I: Downloaded 835854/2114729 bytes (39%)
    I: Downloaded 836610/2114729 bytes (39%)
    I: Downloaded 837312/2114729 bytes (39%)
    I: Downloaded 838014/2114729 bytes (39%)
    I: Downloaded 838662/2114729 bytes (39%)
    I: Downloaded 839364/2114729 bytes (39%)
    I: Downloaded 840066/2114729 bytes (39%)
    I: Downloaded 840822/2114729 bytes (39%)
    I: Downloaded 841470/2114729 bytes (39%)
    I: Downloaded 842172/2114729 bytes (39%)
    I: Downloaded 842874/2114729 bytes (39%)
    I: Downloaded 843576/2114729 bytes (39%)
    I: Downloaded 844278/2114729 bytes (39%)
    I: Downloaded 844980/2114729 bytes (39%)
    I: Downloaded 845682/2114729 bytes (39%)
    I: Downloaded 846384/2114729 bytes (40%)
    I: Downloaded 847086/2114729 bytes (40%)
    I: Downloaded 847842/2114729 bytes (40%)
    I: Downloaded 848544/2114729 bytes (40%)
    I: Downloaded 849246/2114729 bytes (40%)
    I: Downloaded 849894/2114729 bytes (40%)
    I: Downloaded 850596/2114729 bytes (40%)
    I: Downloaded 851298/2114729 bytes (40%)
    I: Downloaded 852000/2114729 bytes (40%)
    I: Downloaded 852054/2114729 bytes (40%)
    I: Downloaded 852702/2114729 bytes (40%)
    I: Downloaded 853404/2114729 bytes (40%)
    I: Downloaded 854106/2114729 bytes (40%)
    I: Downloaded 854808/2114729 bytes (40%)
    I: Downloaded 855510/2114729 bytes (40%)
    I: Downloaded 856212/2114729 bytes (40%)
    I: Downloaded 856914/2114729 bytes (40%)
    I: Downloaded 857616/2114729 bytes (40%)
    I: Downloaded 858318/2114729 bytes (40%)
    I: Downloaded 859020/2114729 bytes (40%)
    I: Downloaded 859722/2114729 bytes (40%)
    I: Downloaded 860424/2114729 bytes (40%)
    I: Downloaded 861126/2114729 bytes (40%)
    I: Downloaded 861828/2114729 bytes (40%)
    I: Downloaded 862530/2114729 bytes (40%)
    I: Downloaded 863286/2114729 bytes (40%)
    I: Downloaded 863934/2114729 bytes (40%)
    I: Downloaded 864636/2114729 bytes (40%)
    I: Downloaded 865338/2114729 bytes (40%)
    I: Downloaded 866040/2114729 bytes (40%)
    I: Downloaded 866742/2114729 bytes (40%)
    I: Downloaded 867498/2114729 bytes (41%)
    I: Downloaded 868200/2114729 bytes (41%)
    I: Downloaded 868902/2114729 bytes (41%)
    I: Downloaded 869550/2114729 bytes (41%)
    I: Downloaded 870252/2114729 bytes (41%)
    I: Downloaded 870954/2114729 bytes (41%)
    I: Downloaded 871656/2114729 bytes (41%)
    I: Downloaded 872358/2114729 bytes (41%)
    I: Downloaded 873060/2114729 bytes (41%)
    I: Downloaded 873762/2114729 bytes (41%)
    I: Downloaded 874572/2114729 bytes (41%)
    I: Downloaded 875166/2114729 bytes (41%)
    I: Downloaded 875868/2114729 bytes (41%)
    I: Downloaded 876570/2114729 bytes (41%)
    I: Downloaded 877272/2114729 bytes (41%)
    I: Downloaded 877974/2114729 bytes (41%)
    I: Downloaded 878676/2114729 bytes (41%)
    I: Downloaded 878730/2114729 bytes (41%)
    I: Downloaded 879432/2114729 bytes (41%)
    I: Downloaded 880134/2114729 bytes (41%)
    I: Downloaded 880782/2114729 bytes (41%)
    I: Downloaded 881484/2114729 bytes (41%)
    I: Downloaded 882186/2114729 bytes (41%)
    I: Downloaded 882888/2114729 bytes (41%)
    I: Downloaded 883590/2114729 bytes (41%)
    I: Downloaded 884292/2114729 bytes (41%)
    I: Downloaded 884994/2114729 bytes (41%)
    I: Downloaded 885696/2114729 bytes (41%)
    I: Downloaded 885804/2114729 bytes (41%)
    I: Downloaded 886398/2114729 bytes (41%)
    I: Downloaded 887100/2114729 bytes (41%)
    I: Downloaded 887802/2114729 bytes (41%)
    I: Downloaded 888558/2114729 bytes (42%)
    I: Downloaded 889206/2114729 bytes (42%)
    I: Downloaded 889908/2114729 bytes (42%)
    I: Downloaded 890610/2114729 bytes (42%)
    I: Downloaded 891312/2114729 bytes (42%)
    I: Downloaded 892014/2114729 bytes (42%)
    I: Downloaded 892716/2114729 bytes (42%)
    I: Downloaded 893418/2114729 bytes (42%)
    I: Downloaded 894120/2114729 bytes (42%)
    I: Downloaded 894822/2114729 bytes (42%)
    I: Downloaded 895578/2114729 bytes (42%)
    I: Downloaded 896280/2114729 bytes (42%)
    I: Downloaded 896982/2114729 bytes (42%)
    I: Downloaded 897630/2114729 bytes (42%)
    I: Downloaded 898332/2114729 bytes (42%)
    I: Downloaded 899034/2114729 bytes (42%)
    I: Downloaded 899736/2114729 bytes (42%)
    I: Downloaded 899790/2114729 bytes (42%)
    I: Downloaded 900438/2114729 bytes (42%)
    I: Downloaded 901140/2114729 bytes (42%)
    I: Downloaded 901842/2114729 bytes (42%)
    I: Downloaded 902544/2114729 bytes (42%)
    I: Downloaded 903246/2114729 bytes (42%)
    I: Downloaded 903948/2114729 bytes (42%)
    I: Downloaded 904650/2114729 bytes (42%)
    I: Downloaded 905352/2114729 bytes (42%)
    I: Downloaded 906054/2114729 bytes (42%)
    I: Downloaded 906756/2114729 bytes (42%)
    I: Downloaded 907458/2114729 bytes (42%)
    I: Downloaded 908160/2114729 bytes (42%)
    I: Downloaded 908862/2114729 bytes (42%)
    I: Downloaded 909564/2114729 bytes (43%)
    I: Downloaded 910266/2114729 bytes (43%)
    I: Downloaded 910968/2114729 bytes (43%)
    I: Downloaded 911670/2114729 bytes (43%)
    I: Downloaded 912372/2114729 bytes (43%)
    I: Downloaded 913074/2114729 bytes (43%)
    I: Downloaded 913776/2114729 bytes (43%)
    I: Downloaded 914478/2114729 bytes (43%)
    I: Downloaded 915180/2114729 bytes (43%)
    I: Downloaded 915882/2114729 bytes (43%)
    I: Downloaded 916584/2114729 bytes (43%)
    I: Downloaded 917286/2114729 bytes (43%)
    I: Downloaded 917988/2114729 bytes (43%)
    I: Downloaded 918690/2114729 bytes (43%)
    I: Downloaded 919392/2114729 bytes (43%)
    I: Downloaded 920094/2114729 bytes (43%)
    I: Downloaded 920796/2114729 bytes (43%)
    I: Downloaded 921498/2114729 bytes (43%)
    I: Downloaded 922200/2114729 bytes (43%)
    I: Downloaded 922902/2114729 bytes (43%)
    I: Downloaded 923604/2114729 bytes (43%)
    I: Downloaded 924306/2114729 bytes (43%)
    I: Downloaded 925008/2114729 bytes (43%)
    I: Downloaded 925710/2114729 bytes (43%)
    I: Downloaded 926412/2114729 bytes (43%)
    I: Downloaded 927114/2114729 bytes (43%)
    I: Downloaded 927816/2114729 bytes (43%)
    I: Downloaded 928518/2114729 bytes (43%)
    I: Downloaded 929220/2114729 bytes (43%)
    I: Downloaded 929274/2114729 bytes (43%)
    I: Downloaded 929976/2114729 bytes (43%)
    I: Downloaded 930678/2114729 bytes (44%)
    I: Downloaded 931326/2114729 bytes (44%)
    I: Downloaded 932028/2114729 bytes (44%)
    I: Downloaded 932730/2114729 bytes (44%)
    I: Downloaded 933432/2114729 bytes (44%)
    I: Downloaded 933486/2114729 bytes (44%)
    I: Downloaded 934134/2114729 bytes (44%)
    I: Downloaded 934836/2114729 bytes (44%)
    I: Downloaded 935538/2114729 bytes (44%)
    I: Downloaded 936240/2114729 bytes (44%)
    I: Downloaded 936942/2114729 bytes (44%)
    I: Downloaded 937644/2114729 bytes (44%)
    I: Downloaded 938346/2114729 bytes (44%)
    I: Downloaded 939048/2114729 bytes (44%)
    I: Downloaded 939750/2114729 bytes (44%)
    I: Downloaded 940452/2114729 bytes (44%)
    I: Downloaded 941154/2114729 bytes (44%)
    I: Downloaded 941856/2114729 bytes (44%)
    I: Downloaded 941910/2114729 bytes (44%)
    I: Downloaded 942558/2114729 bytes (44%)
    I: Downloaded 943260/2114729 bytes (44%)
    I: Downloaded 943962/2114729 bytes (44%)
    I: Downloaded 944664/2114729 bytes (44%)
    I: Downloaded 945366/2114729 bytes (44%)
    I: Downloaded 946068/2114729 bytes (44%)
    I: Downloaded 946122/2114729 bytes (44%)
    I: Downloaded 946824/2114729 bytes (44%)
    I: Downloaded 947526/2114729 bytes (44%)
    I: Downloaded 948174/2114729 bytes (44%)
    I: Downloaded 948876/2114729 bytes (44%)
    I: Downloaded 949578/2114729 bytes (44%)
    I: Downloaded 950280/2114729 bytes (44%)
    I: Downloaded 950982/2114729 bytes (44%)
    I: Downloaded 951684/2114729 bytes (45%)
    I: Downloaded 952386/2114729 bytes (45%)
    I: Downloaded 953088/2114729 bytes (45%)
    I: Downloaded 953196/2114729 bytes (45%)
    I: Downloaded 953790/2114729 bytes (45%)
    I: Downloaded 954492/2114729 bytes (45%)
    I: Downloaded 955194/2114729 bytes (45%)
    I: Downloaded 955896/2114729 bytes (45%)
    I: Downloaded 955950/2114729 bytes (45%)
    I: Downloaded 956598/2114729 bytes (45%)
    I: Downloaded 957300/2114729 bytes (45%)
    I: Downloaded 958002/2114729 bytes (45%)
    I: Downloaded 958704/2114729 bytes (45%)
    I: Downloaded 959406/2114729 bytes (45%)
    I: Downloaded 960108/2114729 bytes (45%)
    I: Downloaded 960810/2114729 bytes (45%)
    I: Downloaded 961512/2114729 bytes (45%)
    I: Downloaded 962214/2114729 bytes (45%)
    I: Downloaded 962916/2114729 bytes (45%)
    I: Downloaded 963618/2114729 bytes (45%)
    I: Downloaded 964320/2114729 bytes (45%)
    I: Downloaded 964374/2114729 bytes (45%)
    I: Downloaded 965022/2114729 bytes (45%)
    I: Downloaded 965724/2114729 bytes (45%)
    I: Downloaded 966426/2114729 bytes (45%)
    I: Downloaded 967128/2114729 bytes (45%)
    I: Downloaded 967830/2114729 bytes (45%)
    I: Downloaded 968532/2114729 bytes (45%)
    I: Downloaded 968586/2114729 bytes (45%)
    I: Downloaded 969288/2114729 bytes (45%)
    I: Downloaded 969990/2114729 bytes (45%)
    I: Downloaded 970638/2114729 bytes (45%)
    I: Downloaded 971340/2114729 bytes (45%)
    I: Downloaded 972042/2114729 bytes (45%)
    I: Downloaded 972744/2114729 bytes (45%)
    I: Downloaded 973446/2114729 bytes (46%)
    I: Downloaded 974148/2114729 bytes (46%)
    I: Downloaded 974850/2114729 bytes (46%)
    I: Downloaded 975552/2114729 bytes (46%)
    I: Downloaded 976254/2114729 bytes (46%)
    I: Downloaded 976956/2114729 bytes (46%)
    I: Downloaded 977658/2114729 bytes (46%)
    I: Downloaded 978360/2114729 bytes (46%)
    I: Downloaded 979062/2114729 bytes (46%)
    I: Downloaded 979764/2114729 bytes (46%)
    I: Downloaded 980466/2114729 bytes (46%)
    I: Downloaded 981168/2114729 bytes (46%)
    I: Downloaded 981870/2114729 bytes (46%)
    I: Downloaded 982572/2114729 bytes (46%)
    I: Downloaded 982626/2114729 bytes (46%)
    I: Downloaded 983328/2114729 bytes (46%)
    I: Downloaded 984030/2114729 bytes (46%)
    I: Downloaded 984678/2114729 bytes (46%)
    I: Downloaded 985380/2114729 bytes (46%)
    I: Downloaded 986082/2114729 bytes (46%)
    I: Downloaded 986784/2114729 bytes (46%)
    I: Downloaded 986838/2114729 bytes (46%)
    I: Downloaded 987486/2114729 bytes (46%)
    I: Downloaded 988188/2114729 bytes (46%)
    I: Downloaded 988890/2114729 bytes (46%)
    I: Downloaded 989592/2114729 bytes (46%)
    I: Downloaded 990294/2114729 bytes (46%)
    I: Downloaded 990996/2114729 bytes (46%)
    I: Downloaded 991698/2114729 bytes (46%)
    I: Downloaded 992400/2114729 bytes (46%)
    I: Downloaded 993102/2114729 bytes (46%)
    I: Downloaded 993804/2114729 bytes (46%)
    I: Downloaded 994506/2114729 bytes (47%)
    I: Downloaded 995262/2114729 bytes (47%)
    I: Downloaded 995910/2114729 bytes (47%)
    I: Downloaded 996612/2114729 bytes (47%)
    I: Downloaded 997314/2114729 bytes (47%)
    I: Downloaded 998016/2114729 bytes (47%)
    I: Downloaded 998718/2114729 bytes (47%)
    I: Downloaded 999420/2114729 bytes (47%)
    I: Downloaded 999474/2114729 bytes (47%)
    I: Downloaded 1000176/2114729 bytes (47%)
    I: Downloaded 1000878/2114729 bytes (47%)
    I: Downloaded 1001526/2114729 bytes (47%)
    I: Downloaded 1002228/2114729 bytes (47%)
    I: Downloaded 1002930/2114729 bytes (47%)
    I: Downloaded 1003632/2114729 bytes (47%)
    I: Downloaded 1004334/2114729 bytes (47%)
    I: Downloaded 1005036/2114729 bytes (47%)
    I: Downloaded 1005738/2114729 bytes (47%)
    I: Downloaded 1006440/2114729 bytes (47%)
    I: Downloaded 1006548/2114729 bytes (47%)
    I: Downloaded 1007142/2114729 bytes (47%)
    I: Downloaded 1007844/2114729 bytes (47%)
    I: Downloaded 1008546/2114729 bytes (47%)
    I: Downloaded 1009248/2114729 bytes (47%)
    I: Downloaded 1009950/2114729 bytes (47%)
    I: Downloaded 1010652/2114729 bytes (47%)
    I: Downloaded 1011354/2114729 bytes (47%)
    I: Downloaded 1012056/2114729 bytes (47%)
    I: Downloaded 1012758/2114729 bytes (47%)
    I: Downloaded 1013460/2114729 bytes (47%)
    I: Downloaded 1014162/2114729 bytes (47%)
    I: Downloaded 1014864/2114729 bytes (47%)
    I: Downloaded 1015566/2114729 bytes (48%)
    I: Downloaded 1016268/2114729 bytes (48%)
    I: Downloaded 1016970/2114729 bytes (48%)
    I: Downloaded 1017672/2114729 bytes (48%)
    I: Downloaded 1018374/2114729 bytes (48%)
    I: Downloaded 1019076/2114729 bytes (48%)
    I: Downloaded 1019778/2114729 bytes (48%)
    I: Downloaded 1020480/2114729 bytes (48%)
    I: Downloaded 1021182/2114729 bytes (48%)
    I: Downloaded 1021884/2114729 bytes (48%)
    I: Downloaded 1022586/2114729 bytes (48%)
    I: Downloaded 1023288/2114729 bytes (48%)
    I: Downloaded 1023990/2114729 bytes (48%)
    I: Downloaded 1024692/2114729 bytes (48%)
    I: Downloaded 1025394/2114729 bytes (48%)
    I: Downloaded 1026096/2114729 bytes (48%)
    I: Downloaded 1026798/2114729 bytes (48%)
    I: Downloaded 1027500/2114729 bytes (48%)
    I: Downloaded 1028202/2114729 bytes (48%)
    I: Downloaded 1028904/2114729 bytes (48%)
    I: Downloaded 1029606/2114729 bytes (48%)
    I: Downloaded 1030308/2114729 bytes (48%)
    I: Downloaded 1031010/2114729 bytes (48%)
    I: Downloaded 1031712/2114729 bytes (48%)
    I: Downloaded 1032414/2114729 bytes (48%)
    I: Downloaded 1033116/2114729 bytes (48%)
    I: Downloaded 1033818/2114729 bytes (48%)
    I: Downloaded 1034520/2114729 bytes (48%)
    I: Downloaded 1035222/2114729 bytes (48%)
    I: Downloaded 1035924/2114729 bytes (48%)
    I: Downloaded 1036626/2114729 bytes (49%)
    I: Downloaded 1037328/2114729 bytes (49%)
    I: Downloaded 1038030/2114729 bytes (49%)
    I: Downloaded 1038786/2114729 bytes (49%)
    I: Downloaded 1039488/2114729 bytes (49%)
    I: Downloaded 1040190/2114729 bytes (49%)
    I: Downloaded 1040838/2114729 bytes (49%)
    I: Downloaded 1041540/2114729 bytes (49%)
    I: Downloaded 1042242/2114729 bytes (49%)
    I: Downloaded 1042944/2114729 bytes (49%)
    I: Downloaded 1042998/2114729 bytes (49%)
    I: Downloaded 1043646/2114729 bytes (49%)
    I: Downloaded 1044348/2114729 bytes (49%)
    I: Downloaded 1045050/2114729 bytes (49%)
    I: Downloaded 1045752/2114729 bytes (49%)
    I: Downloaded 1046454/2114729 bytes (49%)
    I: Downloaded 1047156/2114729 bytes (49%)
    I: Downloaded 1047858/2114729 bytes (49%)
    I: Downloaded 1048560/2114729 bytes (49%)
    I: Downloaded 1049262/2114729 bytes (49%)
    I: Downloaded 1049964/2114729 bytes (49%)
    I: Downloaded 1050666/2114729 bytes (49%)
    I: Downloaded 1051422/2114729 bytes (49%)
    I: Downloaded 1052070/2114729 bytes (49%)
    I: Downloaded 1052772/2114729 bytes (49%)
    I: Downloaded 1053474/2114729 bytes (49%)
    I: Downloaded 1054176/2114729 bytes (49%)
    I: Downloaded 1054878/2114729 bytes (49%)
    I: Downloaded 1055580/2114729 bytes (49%)
    I: Downloaded 1055634/2114729 bytes (49%)
    I: Downloaded 1056336/2114729 bytes (49%)
    I: Downloaded 1057038/2114729 bytes (49%)
    I: Downloaded 1057686/2114729 bytes (50%)
    I: Downloaded 1058388/2114729 bytes (50%)
    I: Downloaded 1059090/2114729 bytes (50%)
    I: Downloaded 1059792/2114729 bytes (50%)
    I: Downloaded 1060494/2114729 bytes (50%)
    I: Downloaded 1061196/2114729 bytes (50%)
    I: Downloaded 1061898/2114729 bytes (50%)
    I: Downloaded 1062600/2114729 bytes (50%)
    I: Downloaded 1062708/2114729 bytes (50%)
    I: Downloaded 1063302/2114729 bytes (50%)
    I: Downloaded 1064004/2114729 bytes (50%)
    I: Downloaded 1064706/2114729 bytes (50%)
    I: Downloaded 1065462/2114729 bytes (50%)
    I: Downloaded 1066110/2114729 bytes (50%)
    I: Downloaded 1066812/2114729 bytes (50%)
    I: Downloaded 1067514/2114729 bytes (50%)
    I: Downloaded 1068216/2114729 bytes (50%)
    I: Downloaded 1068918/2114729 bytes (50%)
    I: Downloaded 1069620/2114729 bytes (50%)
    I: Downloaded 1070322/2114729 bytes (50%)
    I: Downloaded 1071024/2114729 bytes (50%)
    I: Downloaded 1071726/2114729 bytes (50%)
    I: Downloaded 1072482/2114729 bytes (50%)
    I: Downloaded 1073184/2114729 bytes (50%)
    I: Downloaded 1073886/2114729 bytes (50%)
    I: Downloaded 1074534/2114729 bytes (50%)
    I: Downloaded 1075236/2114729 bytes (50%)
    I: Downloaded 1075938/2114729 bytes (50%)
    I: Downloaded 1076640/2114729 bytes (50%)
    I: Downloaded 1076694/2114729 bytes (50%)
    I: Downloaded 1077342/2114729 bytes (50%)
    I: Downloaded 1078044/2114729 bytes (50%)
    I: Downloaded 1078746/2114729 bytes (51%)
    I: Downloaded 1079448/2114729 bytes (51%)
    I: Downloaded 1080150/2114729 bytes (51%)
    I: Downloaded 1080852/2114729 bytes (51%)
    I: Downloaded 1081554/2114729 bytes (51%)
    I: Downloaded 1082256/2114729 bytes (51%)
    I: Downloaded 1082310/2114729 bytes (51%)
    I: Downloaded 1082958/2114729 bytes (51%)
    I: Downloaded 1083660/2114729 bytes (51%)
    I: Downloaded 1084362/2114729 bytes (51%)
    I: Downloaded 1085064/2114729 bytes (51%)
    I: Downloaded 1085766/2114729 bytes (51%)
    I: Downloaded 1086468/2114729 bytes (51%)
    I: Downloaded 1087170/2114729 bytes (51%)
    I: Downloaded 1087872/2114729 bytes (51%)
    I: Downloaded 1088574/2114729 bytes (51%)
    I: Downloaded 1089276/2114729 bytes (51%)
    I: Downloaded 1089978/2114729 bytes (51%)
    I: Downloaded 1090680/2114729 bytes (51%)
    I: Downloaded 1091382/2114729 bytes (51%)
    I: Downloaded 1092084/2114729 bytes (51%)
    I: Downloaded 1092786/2114729 bytes (51%)
    I: Downloaded 1093488/2114729 bytes (51%)
    I: Downloaded 1094190/2114729 bytes (51%)
    I: Downloaded 1094892/2114729 bytes (51%)
    I: Downloaded 1095594/2114729 bytes (51%)
    I: Downloaded 1096296/2114729 bytes (51%)
    I: Downloaded 1096998/2114729 bytes (51%)
    I: Downloaded 1097700/2114729 bytes (51%)
    I: Downloaded 1098402/2114729 bytes (51%)
    I: Downloaded 1099104/2114729 bytes (51%)
    I: Downloaded 1099806/2114729 bytes (52%)
    I: Downloaded 1100508/2114729 bytes (52%)
    I: Downloaded 1101210/2114729 bytes (52%)
    I: Downloaded 1101912/2114729 bytes (52%)
    I: Downloaded 1102614/2114729 bytes (52%)
    I: Downloaded 1103316/2114729 bytes (52%)
    I: Downloaded 1104018/2114729 bytes (52%)
    I: Downloaded 1104720/2114729 bytes (52%)
    I: Downloaded 1105422/2114729 bytes (52%)
    I: Downloaded 1106124/2114729 bytes (52%)
    I: Downloaded 1106826/2114729 bytes (52%)
    I: Downloaded 1107528/2114729 bytes (52%)
    I: Downloaded 1108230/2114729 bytes (52%)
    I: Downloaded 1108932/2114729 bytes (52%)
    I: Downloaded 1109634/2114729 bytes (52%)
    I: Downloaded 1110336/2114729 bytes (52%)
    I: Downloaded 1111038/2114729 bytes (52%)
    I: Downloaded 1111794/2114729 bytes (52%)
    I: Downloaded 1112496/2114729 bytes (52%)
    I: Downloaded 1113198/2114729 bytes (52%)
    I: Downloaded 1113846/2114729 bytes (52%)
    I: Downloaded 1114548/2114729 bytes (52%)
    I: Downloaded 1115250/2114729 bytes (52%)
    I: Downloaded 1115952/2114729 bytes (52%)
    I: Downloaded 1116006/2114729 bytes (52%)
    I: Downloaded 1116654/2114729 bytes (52%)
    I: Downloaded 1117356/2114729 bytes (52%)
    I: Downloaded 1118058/2114729 bytes (52%)
    I: Downloaded 1118760/2114729 bytes (52%)
    I: Downloaded 1119462/2114729 bytes (52%)
    I: Downloaded 1120164/2114729 bytes (52%)
    I: Downloaded 1120866/2114729 bytes (53%)
    I: Downloaded 1121568/2114729 bytes (53%)
    I: Downloaded 1121622/2114729 bytes (53%)
    I: Downloaded 1122270/2114729 bytes (53%)
    I: Downloaded 1122972/2114729 bytes (53%)
    I: Downloaded 1123674/2114729 bytes (53%)
    I: Downloaded 1124376/2114729 bytes (53%)
    I: Downloaded 1125078/2114729 bytes (53%)
    I: Downloaded 1125780/2114729 bytes (53%)
    I: Downloaded 1126482/2114729 bytes (53%)
    I: Downloaded 1127184/2114729 bytes (53%)
    I: Downloaded 1127886/2114729 bytes (53%)
    I: Downloaded 1128588/2114729 bytes (53%)
    I: Downloaded 1129290/2114729 bytes (53%)
    I: Downloaded 1129992/2114729 bytes (53%)
    I: Downloaded 1130694/2114729 bytes (53%)
    I: Downloaded 1131396/2114729 bytes (53%)
    I: Downloaded 1132098/2114729 bytes (53%)
    I: Downloaded 1132800/2114729 bytes (53%)
    I: Downloaded 1133502/2114729 bytes (53%)
    I: Downloaded 1134204/2114729 bytes (53%)
    I: Downloaded 1134906/2114729 bytes (53%)
    I: Downloaded 1135608/2114729 bytes (53%)
    I: Downloaded 1136310/2114729 bytes (53%)
    I: Downloaded 1137012/2114729 bytes (53%)
    I: Downloaded 1137714/2114729 bytes (53%)
    I: Downloaded 1138416/2114729 bytes (53%)
    I: Downloaded 1139118/2114729 bytes (53%)
    I: Downloaded 1139820/2114729 bytes (53%)
    I: Downloaded 1140522/2114729 bytes (53%)
    I: Downloaded 1141224/2114729 bytes (53%)
    I: Downloaded 1141926/2114729 bytes (53%)
    I: Downloaded 1142628/2114729 bytes (54%)
    I: Downloaded 1143330/2114729 bytes (54%)
    I: Downloaded 1144032/2114729 bytes (54%)
    I: Downloaded 1144734/2114729 bytes (54%)
    I: Downloaded 1145436/2114729 bytes (54%)
    I: Downloaded 1146138/2114729 bytes (54%)
    I: Downloaded 1146840/2114729 bytes (54%)
    I: Downloaded 1147542/2114729 bytes (54%)
    I: Downloaded 1148244/2114729 bytes (54%)
    I: Downloaded 1148946/2114729 bytes (54%)
    I: Downloaded 1149648/2114729 bytes (54%)
    I: Downloaded 1150350/2114729 bytes (54%)
    I: Downloaded 1151052/2114729 bytes (54%)
    I: Downloaded 1151754/2114729 bytes (54%)
    I: Downloaded 1152456/2114729 bytes (54%)
    I: Downloaded 1153158/2114729 bytes (54%)
    I: Downloaded 1153860/2114729 bytes (54%)
    I: Downloaded 1154562/2114729 bytes (54%)
    I: Downloaded 1155264/2114729 bytes (54%)
    I: Downloaded 1155966/2114729 bytes (54%)
    I: Downloaded 1156668/2114729 bytes (54%)
    I: Downloaded 1157370/2114729 bytes (54%)
    I: Downloaded 1158072/2114729 bytes (54%)
    I: Downloaded 1158774/2114729 bytes (54%)
    I: Downloaded 1159476/2114729 bytes (54%)
    I: Downloaded 1160178/2114729 bytes (54%)
    I: Downloaded 1160880/2114729 bytes (54%)
    I: Downloaded 1161582/2114729 bytes (54%)
    I: Downloaded 1162284/2114729 bytes (54%)
    I: Downloaded 1162986/2114729 bytes (54%)
    I: Downloaded 1163688/2114729 bytes (55%)
    I: Downloaded 1164390/2114729 bytes (55%)
    I: Downloaded 1165092/2114729 bytes (55%)
    I: Downloaded 1165794/2114729 bytes (55%)
    I: Downloaded 1166496/2114729 bytes (55%)
    I: Downloaded 1167198/2114729 bytes (55%)
    I: Downloaded 1167900/2114729 bytes (55%)
    I: Downloaded 1168602/2114729 bytes (55%)
    I: Downloaded 1169304/2114729 bytes (55%)
    I: Downloaded 1170006/2114729 bytes (55%)
    I: Downloaded 1170708/2114729 bytes (55%)
    I: Downloaded 1171410/2114729 bytes (55%)
    I: Downloaded 1172112/2114729 bytes (55%)
    I: Downloaded 1172814/2114729 bytes (55%)
    I: Downloaded 1173516/2114729 bytes (55%)
    I: Downloaded 1174218/2114729 bytes (55%)
    I: Downloaded 1174920/2114729 bytes (55%)
    I: Downloaded 1175622/2114729 bytes (55%)
    I: Downloaded 1176324/2114729 bytes (55%)
    I: Downloaded 1177026/2114729 bytes (55%)
    I: Downloaded 1177728/2114729 bytes (55%)
    I: Downloaded 1178430/2114729 bytes (55%)
    I: Downloaded 1179132/2114729 bytes (55%)
    I: Downloaded 1179834/2114729 bytes (55%)
    I: Downloaded 1180536/2114729 bytes (55%)
    I: Downloaded 1181238/2114729 bytes (55%)
    I: Downloaded 1181940/2114729 bytes (55%)
    I: Downloaded 1182642/2114729 bytes (55%)
    I: Downloaded 1183344/2114729 bytes (55%)
    I: Downloaded 1184046/2114729 bytes (55%)
    I: Downloaded 1184748/2114729 bytes (56%)
    I: Downloaded 1185450/2114729 bytes (56%)
    I: Downloaded 1186152/2114729 bytes (56%)
    I: Downloaded 1186854/2114729 bytes (56%)
    I: Downloaded 1187556/2114729 bytes (56%)
    I: Downloaded 1188258/2114729 bytes (56%)
    I: Downloaded 1188960/2114729 bytes (56%)
    I: Downloaded 1189662/2114729 bytes (56%)
    I: Downloaded 1190364/2114729 bytes (56%)
    I: Downloaded 1191066/2114729 bytes (56%)
    I: Downloaded 1191768/2114729 bytes (56%)
    I: Downloaded 1192470/2114729 bytes (56%)
    I: Downloaded 1193172/2114729 bytes (56%)
    I: Downloaded 1193874/2114729 bytes (56%)
    I: Downloaded 1194576/2114729 bytes (56%)
    I: Downloaded 1195278/2114729 bytes (56%)
    I: Downloaded 1195980/2114729 bytes (56%)
    I: Downloaded 1196682/2114729 bytes (56%)
    I: Downloaded 1197384/2114729 bytes (56%)
    I: Downloaded 1198086/2114729 bytes (56%)
    I: Downloaded 1198788/2114729 bytes (56%)
    I: Downloaded 1199490/2114729 bytes (56%)
    I: Downloaded 1200192/2114729 bytes (56%)
    I: Downloaded 1200894/2114729 bytes (56%)
    I: Downloaded 1201596/2114729 bytes (56%)
    I: Downloaded 1202298/2114729 bytes (56%)
    I: Downloaded 1203000/2114729 bytes (56%)
    I: Downloaded 1203702/2114729 bytes (56%)
    I: Downloaded 1204404/2114729 bytes (56%)
    I: Downloaded 1205106/2114729 bytes (56%)
    I: Downloaded 1205808/2114729 bytes (57%)
    I: Downloaded 1206510/2114729 bytes (57%)
    I: Downloaded 1207266/2114729 bytes (57%)
    I: Downloaded 1207968/2114729 bytes (57%)
    I: Downloaded 1208670/2114729 bytes (57%)
    I: Downloaded 1209318/2114729 bytes (57%)
    I: Downloaded 1210020/2114729 bytes (57%)
    I: Downloaded 1210722/2114729 bytes (57%)
    I: Downloaded 1211478/2114729 bytes (57%)
    I: Downloaded 1212126/2114729 bytes (57%)
    I: Downloaded 1212828/2114729 bytes (57%)
    I: Downloaded 1213530/2114729 bytes (57%)
    I: Downloaded 1214232/2114729 bytes (57%)
    I: Downloaded 1214934/2114729 bytes (57%)
    I: Downloaded 1215636/2114729 bytes (57%)
    I: Downloaded 1216338/2114729 bytes (57%)
    I: Downloaded 1217040/2114729 bytes (57%)
    I: Downloaded 1217742/2114729 bytes (57%)
    I: Downloaded 1218498/2114729 bytes (57%)
    I: Downloaded 1219200/2114729 bytes (57%)
    I: Downloaded 1219902/2114729 bytes (57%)
    I: Downloaded 1220550/2114729 bytes (57%)
    I: Downloaded 1221252/2114729 bytes (57%)
    I: Downloaded 1221954/2114729 bytes (57%)
    I: Downloaded 1222656/2114729 bytes (57%)
    I: Downloaded 1223358/2114729 bytes (57%)
    I: Downloaded 1224060/2114729 bytes (57%)
    I: Downloaded 1224762/2114729 bytes (57%)
    I: Downloaded 1225572/2114729 bytes (57%)
    I: Downloaded 1226166/2114729 bytes (57%)
    I: Downloaded 1226868/2114729 bytes (58%)
    I: Downloaded 1227570/2114729 bytes (58%)
    I: Downloaded 1228272/2114729 bytes (58%)
    I: Downloaded 1228974/2114729 bytes (58%)
    I: Downloaded 1229676/2114729 bytes (58%)
    I: Downloaded 1229730/2114729 bytes (58%)
    I: Downloaded 1230432/2114729 bytes (58%)
    I: Downloaded 1231134/2114729 bytes (58%)
    I: Downloaded 1231782/2114729 bytes (58%)
    I: Downloaded 1232484/2114729 bytes (58%)
    I: Downloaded 1233186/2114729 bytes (58%)
    I: Downloaded 1233942/2114729 bytes (58%)
    I: Downloaded 1234590/2114729 bytes (58%)
    I: Downloaded 1235292/2114729 bytes (58%)
    I: Downloaded 1235994/2114729 bytes (58%)
    I: Downloaded 1236696/2114729 bytes (58%)
    I: Downloaded 1237398/2114729 bytes (58%)
    I: Downloaded 1238100/2114729 bytes (58%)
    I: Downloaded 1238802/2114729 bytes (58%)
    I: Downloaded 1239504/2114729 bytes (58%)
    I: Downloaded 1240206/2114729 bytes (58%)
    I: Downloaded 1240908/2114729 bytes (58%)
    I: Downloaded 1241610/2114729 bytes (58%)
    I: Downloaded 1242312/2114729 bytes (58%)
    I: Downloaded 1242366/2114729 bytes (58%)
    I: Downloaded 1243014/2114729 bytes (58%)
    I: Downloaded 1243716/2114729 bytes (58%)
    I: Downloaded 1244418/2114729 bytes (58%)
    I: Downloaded 1245120/2114729 bytes (58%)
    I: Downloaded 1245822/2114729 bytes (58%)
    I: Downloaded 1246578/2114729 bytes (58%)
    I: Downloaded 1247280/2114729 bytes (58%)
    I: Downloaded 1247982/2114729 bytes (59%)
    I: Downloaded 1248630/2114729 bytes (59%)
    I: Downloaded 1249332/2114729 bytes (59%)
    I: Downloaded 1250034/2114729 bytes (59%)
    I: Downloaded 1250790/2114729 bytes (59%)
    I: Downloaded 1251438/2114729 bytes (59%)
    I: Downloaded 1252140/2114729 bytes (59%)
    I: Downloaded 1252842/2114729 bytes (59%)
    I: Downloaded 1253544/2114729 bytes (59%)
    I: Downloaded 1254246/2114729 bytes (59%)
    I: Downloaded 1254948/2114729 bytes (59%)
    I: Downloaded 1255650/2114729 bytes (59%)
    I: Downloaded 1256352/2114729 bytes (59%)
    I: Downloaded 1257054/2114729 bytes (59%)
    I: Downloaded 1257810/2114729 bytes (59%)
    I: Downloaded 1258512/2114729 bytes (59%)
    I: Downloaded 1259214/2114729 bytes (59%)
    I: Downloaded 1259862/2114729 bytes (59%)
    I: Downloaded 1260564/2114729 bytes (59%)
    I: Downloaded 1261266/2114729 bytes (59%)
    I: Downloaded 1261968/2114729 bytes (59%)
    I: Downloaded 1262022/2114729 bytes (59%)
    I: Downloaded 1262670/2114729 bytes (59%)
    I: Downloaded 1263372/2114729 bytes (59%)
    I: Downloaded 1264074/2114729 bytes (59%)
    I: Downloaded 1264776/2114729 bytes (59%)
    I: Downloaded 1265478/2114729 bytes (59%)
    I: Downloaded 1266180/2114729 bytes (59%)
    I: Downloaded 1266882/2114729 bytes (59%)
    I: Downloaded 1267584/2114729 bytes (59%)
    I: Downloaded 1268286/2114729 bytes (59%)
    I: Downloaded 1268988/2114729 bytes (60%)
    I: Downloaded 1269690/2114729 bytes (60%)
    I: Downloaded 1270392/2114729 bytes (60%)
    I: Downloaded 1271094/2114729 bytes (60%)
    I: Downloaded 1271796/2114729 bytes (60%)
    I: Downloaded 1272498/2114729 bytes (60%)
    I: Downloaded 1273200/2114729 bytes (60%)
    I: Downloaded 1273902/2114729 bytes (60%)
    I: Downloaded 1274604/2114729 bytes (60%)
    I: Downloaded 1275306/2114729 bytes (60%)
    I: Downloaded 1276008/2114729 bytes (60%)
    I: Downloaded 1276710/2114729 bytes (60%)
    I: Downloaded 1277412/2114729 bytes (60%)
    I: Downloaded 1278114/2114729 bytes (60%)
    I: Downloaded 1278870/2114729 bytes (60%)
    I: Downloaded 1279518/2114729 bytes (60%)
    I: Downloaded 1280220/2114729 bytes (60%)
    I: Downloaded 1280922/2114729 bytes (60%)
    I: Downloaded 1281624/2114729 bytes (60%)
    I: Downloaded 1282326/2114729 bytes (60%)
    I: Downloaded 1283082/2114729 bytes (60%)
    I: Downloaded 1283784/2114729 bytes (60%)
    I: Downloaded 1284486/2114729 bytes (60%)
    I: Downloaded 1285134/2114729 bytes (60%)
    I: Downloaded 1285836/2114729 bytes (60%)
    I: Downloaded 1286538/2114729 bytes (60%)
    I: Downloaded 1287240/2114729 bytes (60%)
    I: Downloaded 1287942/2114729 bytes (60%)
    I: Downloaded 1288644/2114729 bytes (60%)
    I: Downloaded 1289346/2114729 bytes (60%)
    I: Downloaded 1290156/2114729 bytes (61%)
    I: Downloaded 1290750/2114729 bytes (61%)
    I: Downloaded 1291452/2114729 bytes (61%)
    I: Downloaded 1292154/2114729 bytes (61%)
    I: Downloaded 1292856/2114729 bytes (61%)
    I: Downloaded 1293558/2114729 bytes (61%)
    I: Downloaded 1294260/2114729 bytes (61%)
    I: Downloaded 1294314/2114729 bytes (61%)
    I: Downloaded 1295016/2114729 bytes (61%)
    I: Downloaded 1295718/2114729 bytes (61%)
    I: Downloaded 1296366/2114729 bytes (61%)
    I: Downloaded 1297068/2114729 bytes (61%)
    I: Downloaded 1297770/2114729 bytes (61%)
    I: Downloaded 1298472/2114729 bytes (61%)
    I: Downloaded 1299174/2114729 bytes (61%)
    I: Downloaded 1299876/2114729 bytes (61%)
    I: Downloaded 1300578/2114729 bytes (61%)
    I: Downloaded 1301388/2114729 bytes (61%)
    I: Downloaded 1301982/2114729 bytes (61%)
    I: Downloaded 1302684/2114729 bytes (61%)
    I: Downloaded 1303386/2114729 bytes (61%)
    I: Downloaded 1304088/2114729 bytes (61%)
    I: Downloaded 1304790/2114729 bytes (61%)
    I: Downloaded 1305492/2114729 bytes (61%)
    I: Downloaded 1306194/2114729 bytes (61%)
    I: Downloaded 1306896/2114729 bytes (61%)
    I: Downloaded 1307598/2114729 bytes (61%)
    I: Downloaded 1308300/2114729 bytes (61%)
    I: Downloaded 1309002/2114729 bytes (61%)
    I: Downloaded 1309704/2114729 bytes (61%)
    I: Downloaded 1310406/2114729 bytes (61%)
    I: Downloaded 1311108/2114729 bytes (61%)
    I: Downloaded 1311810/2114729 bytes (62%)
    I: Downloaded 1312512/2114729 bytes (62%)
    I: Downloaded 1313214/2114729 bytes (62%)
    I: Downloaded 1313916/2114729 bytes (62%)
    I: Downloaded 1314618/2114729 bytes (62%)
    I: Downloaded 1315320/2114729 bytes (62%)
    I: Downloaded 1316022/2114729 bytes (62%)
    I: Downloaded 1316724/2114729 bytes (62%)
    I: Downloaded 1317426/2114729 bytes (62%)
    I: Downloaded 1318128/2114729 bytes (62%)
    I: Downloaded 1318830/2114729 bytes (62%)
    I: Downloaded 1319532/2114729 bytes (62%)
    I: Downloaded 1320234/2114729 bytes (62%)
    I: Downloaded 1320936/2114729 bytes (62%)
    I: Downloaded 1321638/2114729 bytes (62%)
    I: Downloaded 1322340/2114729 bytes (62%)
    I: Downloaded 1323042/2114729 bytes (62%)
    I: Downloaded 1323744/2114729 bytes (62%)
    I: Downloaded 1324446/2114729 bytes (62%)
    I: Downloaded 1325148/2114729 bytes (62%)
    I: Downloaded 1325850/2114729 bytes (62%)
    I: Downloaded 1326552/2114729 bytes (62%)
    I: Downloaded 1327254/2114729 bytes (62%)
    I: Downloaded 1327956/2114729 bytes (62%)
    I: Downloaded 1328658/2114729 bytes (62%)
    I: Downloaded 1329360/2114729 bytes (62%)
    I: Downloaded 1330062/2114729 bytes (62%)
    I: Downloaded 1330764/2114729 bytes (62%)
    I: Downloaded 1331466/2114729 bytes (62%)
    I: Downloaded 1332168/2114729 bytes (62%)
    I: Downloaded 1332870/2114729 bytes (63%)
    I: Downloaded 1333572/2114729 bytes (63%)
    I: Downloaded 1334274/2114729 bytes (63%)
    I: Downloaded 1334976/2114729 bytes (63%)
    I: Downloaded 1335678/2114729 bytes (63%)
    I: Downloaded 1336380/2114729 bytes (63%)
    I: Downloaded 1337082/2114729 bytes (63%)
    I: Downloaded 1337784/2114729 bytes (63%)
    I: Downloaded 1338486/2114729 bytes (63%)
    I: Downloaded 1339188/2114729 bytes (63%)
    I: Downloaded 1339890/2114729 bytes (63%)
    I: Downloaded 1340592/2114729 bytes (63%)
    I: Downloaded 1341294/2114729 bytes (63%)
    I: Downloaded 1341996/2114729 bytes (63%)
    I: Downloaded 1342698/2114729 bytes (63%)
    I: Downloaded 1343400/2114729 bytes (63%)
    I: Downloaded 1344102/2114729 bytes (63%)
    I: Downloaded 1344804/2114729 bytes (63%)
    I: Downloaded 1345506/2114729 bytes (63%)
    I: Downloaded 1346208/2114729 bytes (63%)
    I: Downloaded 1346910/2114729 bytes (63%)
    I: Downloaded 1347612/2114729 bytes (63%)
    I: Downloaded 1348314/2114729 bytes (63%)
    I: Downloaded 1349016/2114729 bytes (63%)
    I: Downloaded 1349718/2114729 bytes (63%)
    I: Downloaded 1350420/2114729 bytes (63%)
    I: Downloaded 1351122/2114729 bytes (63%)
    I: Downloaded 1351824/2114729 bytes (63%)
    I: Downloaded 1352526/2114729 bytes (63%)
    I: Downloaded 1353228/2114729 bytes (63%)
    I: Downloaded 1353930/2114729 bytes (64%)
    I: Downloaded 1354632/2114729 bytes (64%)
    I: Downloaded 1355334/2114729 bytes (64%)
    I: Downloaded 1356036/2114729 bytes (64%)
    I: Downloaded 1356738/2114729 bytes (64%)
    I: Downloaded 1357440/2114729 bytes (64%)
    I: Downloaded 1358142/2114729 bytes (64%)
    I: Downloaded 1358844/2114729 bytes (64%)
    I: Downloaded 1359546/2114729 bytes (64%)
    I: Downloaded 1360248/2114729 bytes (64%)
    I: Downloaded 1360950/2114729 bytes (64%)
    I: Downloaded 1361652/2114729 bytes (64%)
    I: Downloaded 1362354/2114729 bytes (64%)
    I: Downloaded 1363056/2114729 bytes (64%)
    I: Downloaded 1363110/2114729 bytes (64%)
    I: Downloaded 1363758/2114729 bytes (64%)
    I: Downloaded 1364460/2114729 bytes (64%)
    I: Downloaded 1365162/2114729 bytes (64%)
    I: Downloaded 1365864/2114729 bytes (64%)
    I: Downloaded 1366566/2114729 bytes (64%)
    I: Downloaded 1367322/2114729 bytes (64%)
    I: Downloaded 1368024/2114729 bytes (64%)
    I: Downloaded 1368726/2114729 bytes (64%)
    I: Downloaded 1369374/2114729 bytes (64%)
    I: Downloaded 1370076/2114729 bytes (64%)
    I: Downloaded 1370778/2114729 bytes (64%)
    I: Downloaded 1371480/2114729 bytes (64%)
    I: Downloaded 1372182/2114729 bytes (64%)
    I: Downloaded 1372884/2114729 bytes (64%)
    I: Downloaded 1373586/2114729 bytes (64%)
    I: Downloaded 1374396/2114729 bytes (64%)
    I: Downloaded 1374990/2114729 bytes (65%)
    I: Downloaded 1375692/2114729 bytes (65%)
    I: Downloaded 1376394/2114729 bytes (65%)
    I: Downloaded 1377096/2114729 bytes (65%)
    I: Downloaded 1377798/2114729 bytes (65%)
    I: Downloaded 1378500/2114729 bytes (65%)
    I: Downloaded 1378554/2114729 bytes (65%)
    I: Downloaded 1379256/2114729 bytes (65%)
    I: Downloaded 1379958/2114729 bytes (65%)
    I: Downloaded 1380606/2114729 bytes (65%)
    I: Downloaded 1381308/2114729 bytes (65%)
    I: Downloaded 1382010/2114729 bytes (65%)
    I: Downloaded 1382712/2114729 bytes (65%)
    I: Downloaded 1383414/2114729 bytes (65%)
    I: Downloaded 1384116/2114729 bytes (65%)
    I: Downloaded 1384818/2114729 bytes (65%)
    I: Downloaded 1385628/2114729 bytes (65%)
    I: Downloaded 1386222/2114729 bytes (65%)
    I: Downloaded 1386924/2114729 bytes (65%)
    I: Downloaded 1387626/2114729 bytes (65%)
    I: Downloaded 1388328/2114729 bytes (65%)
    I: Downloaded 1389030/2114729 bytes (65%)
    I: Downloaded 1389732/2114729 bytes (65%)
    I: Downloaded 1389786/2114729 bytes (65%)
    I: Downloaded 1390488/2114729 bytes (65%)
    I: Downloaded 1391190/2114729 bytes (65%)
    I: Downloaded 1391838/2114729 bytes (65%)
    I: Downloaded 1392540/2114729 bytes (65%)
    I: Downloaded 1393242/2114729 bytes (65%)
    I: Downloaded 1393944/2114729 bytes (65%)
    I: Downloaded 1394646/2114729 bytes (65%)
    I: Downloaded 1395348/2114729 bytes (65%)
    I: Downloaded 1396050/2114729 bytes (66%)
    I: Downloaded 1396752/2114729 bytes (66%)
    I: Downloaded 1396860/2114729 bytes (66%)
    I: Downloaded 1397454/2114729 bytes (66%)
    I: Downloaded 1398156/2114729 bytes (66%)
    I: Downloaded 1398858/2114729 bytes (66%)
    I: Downloaded 1399560/2114729 bytes (66%)
    I: Downloaded 1400262/2114729 bytes (66%)
    I: Downloaded 1400964/2114729 bytes (66%)
    I: Downloaded 1401666/2114729 bytes (66%)
    I: Downloaded 1402368/2114729 bytes (66%)
    I: Downloaded 1403070/2114729 bytes (66%)
    I: Downloaded 1403772/2114729 bytes (66%)
    I: Downloaded 1404474/2114729 bytes (66%)
    I: Downloaded 1405176/2114729 bytes (66%)
    I: Downloaded 1405878/2114729 bytes (66%)
    I: Downloaded 1406580/2114729 bytes (66%)
    I: Downloaded 1407282/2114729 bytes (66%)
    I: Downloaded 1407984/2114729 bytes (66%)
    I: Downloaded 1408686/2114729 bytes (66%)
    I: Downloaded 1409388/2114729 bytes (66%)
    I: Downloaded 1410090/2114729 bytes (66%)
    I: Downloaded 1410792/2114729 bytes (66%)
    I: Downloaded 1411494/2114729 bytes (66%)
    I: Downloaded 1412196/2114729 bytes (66%)
    I: Downloaded 1412898/2114729 bytes (66%)
    I: Downloaded 1413600/2114729 bytes (66%)
    I: Downloaded 1414302/2114729 bytes (66%)
    I: Downloaded 1415004/2114729 bytes (66%)
    I: Downloaded 1415706/2114729 bytes (66%)
    I: Downloaded 1416408/2114729 bytes (66%)
    I: Downloaded 1417110/2114729 bytes (67%)
    I: Downloaded 1417812/2114729 bytes (67%)
    I: Downloaded 1418514/2114729 bytes (67%)
    I: Downloaded 1419216/2114729 bytes (67%)
    I: Downloaded 1419918/2114729 bytes (67%)
    I: Downloaded 1420620/2114729 bytes (67%)
    I: Downloaded 1421322/2114729 bytes (67%)
    I: Downloaded 1422024/2114729 bytes (67%)
    I: Downloaded 1422726/2114729 bytes (67%)
    I: Downloaded 1423428/2114729 bytes (67%)
    I: Downloaded 1424130/2114729 bytes (67%)
    I: Downloaded 1424832/2114729 bytes (67%)
    I: Downloaded 1425534/2114729 bytes (67%)
    I: Downloaded 1426236/2114729 bytes (67%)
    I: Downloaded 1426938/2114729 bytes (67%)
    I: Downloaded 1427640/2114729 bytes (67%)
    I: Downloaded 1428342/2114729 bytes (67%)
    I: Downloaded 1429044/2114729 bytes (67%)
    I: Downloaded 1429746/2114729 bytes (67%)
    I: Downloaded 1430448/2114729 bytes (67%)
    I: Downloaded 1431150/2114729 bytes (67%)
    I: Downloaded 1431852/2114729 bytes (67%)
    I: Downloaded 1432554/2114729 bytes (67%)
    I: Downloaded 1433256/2114729 bytes (67%)
    I: Downloaded 1433958/2114729 bytes (67%)
    I: Downloaded 1434660/2114729 bytes (67%)
    I: Downloaded 1435362/2114729 bytes (67%)
    I: Downloaded 1436064/2114729 bytes (67%)
    I: Downloaded 1436766/2114729 bytes (67%)
    I: Downloaded 1437468/2114729 bytes (67%)
    I: Downloaded 1438170/2114729 bytes (68%)
    I: Downloaded 1438872/2114729 bytes (68%)
    I: Downloaded 1439574/2114729 bytes (68%)
    I: Downloaded 1440276/2114729 bytes (68%)
    I: Downloaded 1440978/2114729 bytes (68%)
    I: Downloaded 1441680/2114729 bytes (68%)
    I: Downloaded 1442382/2114729 bytes (68%)
    I: Downloaded 1443084/2114729 bytes (68%)
    I: Downloaded 1443786/2114729 bytes (68%)
    I: Downloaded 1444488/2114729 bytes (68%)
    I: Downloaded 1445190/2114729 bytes (68%)
    I: Downloaded 1445892/2114729 bytes (68%)
    I: Downloaded 1446594/2114729 bytes (68%)
    I: Downloaded 1447296/2114729 bytes (68%)
    I: Downloaded 1447998/2114729 bytes (68%)
    I: Downloaded 1448700/2114729 bytes (68%)
    I: Downloaded 1449402/2114729 bytes (68%)
    I: Downloaded 1450104/2114729 bytes (68%)
    I: Downloaded 1450806/2114729 bytes (68%)
    I: Downloaded 1451508/2114729 bytes (68%)
    I: Downloaded 1452210/2114729 bytes (68%)
    I: Downloaded 1452912/2114729 bytes (68%)
    I: Downloaded 1453614/2114729 bytes (68%)
    I: Downloaded 1454316/2114729 bytes (68%)
    I: Downloaded 1455018/2114729 bytes (68%)
    I: Downloaded 1455720/2114729 bytes (68%)
    I: Downloaded 1456422/2114729 bytes (68%)
    I: Downloaded 1457124/2114729 bytes (68%)
    I: Downloaded 1457826/2114729 bytes (68%)
    I: Downloaded 1458528/2114729 bytes (68%)
    I: Downloaded 1459230/2114729 bytes (69%)
    I: Downloaded 1459932/2114729 bytes (69%)
    I: Downloaded 1460634/2114729 bytes (69%)
    I: Downloaded 1461336/2114729 bytes (69%)
    I: Downloaded 1462038/2114729 bytes (69%)
    I: Downloaded 1462740/2114729 bytes (69%)
    I: Downloaded 1463442/2114729 bytes (69%)
    I: Downloaded 1464198/2114729 bytes (69%)
    I: Downloaded 1464846/2114729 bytes (69%)
    I: Downloaded 1465548/2114729 bytes (69%)
    I: Downloaded 1466250/2114729 bytes (69%)
    I: Downloaded 1466952/2114729 bytes (69%)
    I: Downloaded 1467654/2114729 bytes (69%)
    I: Downloaded 1468356/2114729 bytes (69%)
    I: Downloaded 1468410/2114729 bytes (69%)
    I: Downloaded 1469112/2114729 bytes (69%)
    I: Downloaded 1469814/2114729 bytes (69%)
    I: Downloaded 1470462/2114729 bytes (69%)
    I: Downloaded 1471164/2114729 bytes (69%)
    I: Downloaded 1471866/2114729 bytes (69%)
    I: Downloaded 1472568/2114729 bytes (69%)
    I: Downloaded 1473270/2114729 bytes (69%)
    I: Downloaded 1473972/2114729 bytes (69%)
    I: Downloaded 1474674/2114729 bytes (69%)
    I: Downloaded 1475376/2114729 bytes (69%)
    I: Downloaded 1475484/2114729 bytes (69%)
    I: Downloaded 1476078/2114729 bytes (69%)
    I: Downloaded 1476780/2114729 bytes (69%)
    I: Downloaded 1477482/2114729 bytes (69%)
    I: Downloaded 1478184/2114729 bytes (69%)
    I: Downloaded 1478886/2114729 bytes (69%)
    I: Downloaded 1479588/2114729 bytes (69%)
    I: Downloaded 1480290/2114729 bytes (69%)
    I: Downloaded 1480992/2114729 bytes (70%)
    I: Downloaded 1481694/2114729 bytes (70%)
    I: Downloaded 1482396/2114729 bytes (70%)
    I: Downloaded 1483098/2114729 bytes (70%)
    I: Downloaded 1483800/2114729 bytes (70%)
    I: Downloaded 1484502/2114729 bytes (70%)
    I: Downloaded 1485204/2114729 bytes (70%)
    I: Downloaded 1485906/2114729 bytes (70%)
    I: Downloaded 1486608/2114729 bytes (70%)
    I: Downloaded 1487310/2114729 bytes (70%)
    I: Downloaded 1488012/2114729 bytes (70%)
    I: Downloaded 1488714/2114729 bytes (70%)
    I: Downloaded 1489416/2114729 bytes (70%)
    I: Downloaded 1490118/2114729 bytes (70%)
    I: Downloaded 1490820/2114729 bytes (70%)
    I: Downloaded 1491522/2114729 bytes (70%)
    I: Downloaded 1492224/2114729 bytes (70%)
    I: Downloaded 1492926/2114729 bytes (70%)
    I: Downloaded 1493628/2114729 bytes (70%)
    I: Downloaded 1494330/2114729 bytes (70%)
    I: Downloaded 1495032/2114729 bytes (70%)
    I: Downloaded 1495734/2114729 bytes (70%)
    I: Downloaded 1496436/2114729 bytes (70%)
    I: Downloaded 1497138/2114729 bytes (70%)
    I: Downloaded 1497840/2114729 bytes (70%)
    I: Downloaded 1498542/2114729 bytes (70%)
    I: Downloaded 1499244/2114729 bytes (70%)
    I: Downloaded 1499946/2114729 bytes (70%)
    I: Downloaded 1500648/2114729 bytes (70%)
    I: Downloaded 1501350/2114729 bytes (70%)
    I: Downloaded 1502052/2114729 bytes (71%)
    I: Downloaded 1502754/2114729 bytes (71%)
    I: Downloaded 1503456/2114729 bytes (71%)
    I: Downloaded 1504158/2114729 bytes (71%)
    I: Downloaded 1504914/2114729 bytes (71%)
    I: Downloaded 1505616/2114729 bytes (71%)
    I: Downloaded 1506318/2114729 bytes (71%)
    I: Downloaded 1506966/2114729 bytes (71%)
    I: Downloaded 1507668/2114729 bytes (71%)
    I: Downloaded 1508370/2114729 bytes (71%)
    I: Downloaded 1509126/2114729 bytes (71%)
    I: Downloaded 1509774/2114729 bytes (71%)
    I: Downloaded 1510476/2114729 bytes (71%)
    I: Downloaded 1511178/2114729 bytes (71%)
    I: Downloaded 1511880/2114729 bytes (71%)
    I: Downloaded 1512582/2114729 bytes (71%)
    I: Downloaded 1513284/2114729 bytes (71%)
    I: Downloaded 1513986/2114729 bytes (71%)
    I: Downloaded 1514688/2114729 bytes (71%)
    I: Downloaded 1515390/2114729 bytes (71%)
    I: Downloaded 1516092/2114729 bytes (71%)
    I: Downloaded 1516794/2114729 bytes (71%)
    I: Downloaded 1517496/2114729 bytes (71%)
    I: Downloaded 1518198/2114729 bytes (71%)
    I: Downloaded 1518900/2114729 bytes (71%)
    I: Downloaded 1519602/2114729 bytes (71%)
    I: Downloaded 1520304/2114729 bytes (71%)
    I: Downloaded 1521006/2114729 bytes (71%)
    I: Downloaded 1521708/2114729 bytes (71%)
    I: Downloaded 1522410/2114729 bytes (71%)
    I: Downloaded 1523112/2114729 bytes (72%)
    I: Downloaded 1523814/2114729 bytes (72%)
    I: Downloaded 1524516/2114729 bytes (72%)
    I: Downloaded 1525218/2114729 bytes (72%)
    I: Downloaded 1525920/2114729 bytes (72%)
    I: Downloaded 1526622/2114729 bytes (72%)
    I: Downloaded 1527324/2114729 bytes (72%)
    I: Downloaded 1528026/2114729 bytes (72%)
    I: Downloaded 1528728/2114729 bytes (72%)
    I: Downloaded 1529430/2114729 bytes (72%)
    I: Downloaded 1530132/2114729 bytes (72%)
    I: Downloaded 1530834/2114729 bytes (72%)
    I: Downloaded 1531536/2114729 bytes (72%)
    I: Downloaded 1532238/2114729 bytes (72%)
    I: Downloaded 1532940/2114729 bytes (72%)
    I: Downloaded 1533642/2114729 bytes (72%)
    I: Downloaded 1534344/2114729 bytes (72%)
    I: Downloaded 1535046/2114729 bytes (72%)
    I: Downloaded 1535748/2114729 bytes (72%)
    I: Downloaded 1536450/2114729 bytes (72%)
    I: Downloaded 1537152/2114729 bytes (72%)
    I: Downloaded 1537854/2114729 bytes (72%)
    I: Downloaded 1538556/2114729 bytes (72%)
    I: Downloaded 1539258/2114729 bytes (72%)
    I: Downloaded 1539960/2114729 bytes (72%)
    I: Downloaded 1540662/2114729 bytes (72%)
    I: Downloaded 1541364/2114729 bytes (72%)
    I: Downloaded 1542066/2114729 bytes (72%)
    I: Downloaded 1542768/2114729 bytes (72%)
    I: Downloaded 1543470/2114729 bytes (72%)
    I: Downloaded 1544226/2114729 bytes (73%)
    I: Downloaded 1544928/2114729 bytes (73%)
    I: Downloaded 1545630/2114729 bytes (73%)
    I: Downloaded 1546278/2114729 bytes (73%)
    I: Downloaded 1546980/2114729 bytes (73%)
    I: Downloaded 1547682/2114729 bytes (73%)
    I: Downloaded 1548438/2114729 bytes (73%)
    I: Downloaded 1549086/2114729 bytes (73%)
    I: Downloaded 1549788/2114729 bytes (73%)
    I: Downloaded 1550490/2114729 bytes (73%)
    I: Downloaded 1551192/2114729 bytes (73%)
    I: Downloaded 1551894/2114729 bytes (73%)
    I: Downloaded 1552596/2114729 bytes (73%)
    I: Downloaded 1553298/2114729 bytes (73%)
    I: Downloaded 1554000/2114729 bytes (73%)
    I: Downloaded 1554702/2114729 bytes (73%)
    I: Downloaded 1555404/2114729 bytes (73%)
    I: Downloaded 1556106/2114729 bytes (73%)
    I: Downloaded 1556808/2114729 bytes (73%)
    I: Downloaded 1557510/2114729 bytes (73%)
    I: Downloaded 1558212/2114729 bytes (73%)
    I: Downloaded 1558914/2114729 bytes (73%)
    I: Downloaded 1559616/2114729 bytes (73%)
    I: Downloaded 1560318/2114729 bytes (73%)
    I: Downloaded 1561020/2114729 bytes (73%)
    I: Downloaded 1561722/2114729 bytes (73%)
    I: Downloaded 1562424/2114729 bytes (73%)
    I: Downloaded 1563126/2114729 bytes (73%)
    I: Downloaded 1563828/2114729 bytes (73%)
    I: Downloaded 1564530/2114729 bytes (73%)
    I: Downloaded 1565232/2114729 bytes (74%)
    I: Downloaded 1565934/2114729 bytes (74%)
    I: Downloaded 1566636/2114729 bytes (74%)
    I: Downloaded 1567338/2114729 bytes (74%)
    I: Downloaded 1568040/2114729 bytes (74%)
    I: Downloaded 1568742/2114729 bytes (74%)
    I: Downloaded 1569444/2114729 bytes (74%)
    I: Downloaded 1570146/2114729 bytes (74%)
    I: Downloaded 1570848/2114729 bytes (74%)
    I: Downloaded 1571550/2114729 bytes (74%)
    I: Downloaded 1572252/2114729 bytes (74%)
    I: Downloaded 1572954/2114729 bytes (74%)
    I: Downloaded 1573656/2114729 bytes (74%)
    I: Downloaded 1574358/2114729 bytes (74%)
    I: Downloaded 1575060/2114729 bytes (74%)
    I: Downloaded 1575762/2114729 bytes (74%)
    I: Downloaded 1576464/2114729 bytes (74%)
    I: Downloaded 1577166/2114729 bytes (74%)
    I: Downloaded 1577868/2114729 bytes (74%)
    I: Downloaded 1578570/2114729 bytes (74%)
    I: Downloaded 1579272/2114729 bytes (74%)
    I: Downloaded 1579974/2114729 bytes (74%)
    I: Downloaded 1580676/2114729 bytes (74%)
    I: Downloaded 1581378/2114729 bytes (74%)
    I: Downloaded 1582080/2114729 bytes (74%)
    I: Downloaded 1582782/2114729 bytes (74%)
    I: Downloaded 1583484/2114729 bytes (74%)
    I: Downloaded 1584186/2114729 bytes (74%)
    I: Downloaded 1584888/2114729 bytes (74%)
    I: Downloaded 1585590/2114729 bytes (74%)
    I: Downloaded 1586292/2114729 bytes (75%)
    I: Downloaded 1586994/2114729 bytes (75%)
    I: Downloaded 1587696/2114729 bytes (75%)
    I: Downloaded 1588398/2114729 bytes (75%)
    I: Downloaded 1589154/2114729 bytes (75%)
    I: Downloaded 1589856/2114729 bytes (75%)
    I: Downloaded 1590558/2114729 bytes (75%)
    I: Downloaded 1591206/2114729 bytes (75%)
    I: Downloaded 1591908/2114729 bytes (75%)
    I: Downloaded 1592610/2114729 bytes (75%)
    I: Downloaded 1593366/2114729 bytes (75%)
    I: Downloaded 1594014/2114729 bytes (75%)
    I: Downloaded 1594716/2114729 bytes (75%)
    I: Downloaded 1595418/2114729 bytes (75%)
    I: Downloaded 1596120/2114729 bytes (75%)
    I: Downloaded 1596822/2114729 bytes (75%)
    I: Downloaded 1597524/2114729 bytes (75%)
    I: Downloaded 1598226/2114729 bytes (75%)
    I: Downloaded 1598928/2114729 bytes (75%)
    I: Downloaded 1599630/2114729 bytes (75%)
    I: Downloaded 1600332/2114729 bytes (75%)
    I: Downloaded 1601034/2114729 bytes (75%)
    I: Downloaded 1601736/2114729 bytes (75%)
    I: Downloaded 1602438/2114729 bytes (75%)
    I: Downloaded 1603140/2114729 bytes (75%)
    I: Downloaded 1603842/2114729 bytes (75%)
    I: Downloaded 1604544/2114729 bytes (75%)
    I: Downloaded 1605246/2114729 bytes (75%)
    I: Downloaded 1605948/2114729 bytes (75%)
    I: Downloaded 1606650/2114729 bytes (75%)
    I: Downloaded 1607352/2114729 bytes (76%)
    I: Downloaded 1608054/2114729 bytes (76%)
    I: Downloaded 1608756/2114729 bytes (76%)
    I: Downloaded 1609458/2114729 bytes (76%)
    I: Downloaded 1610160/2114729 bytes (76%)
    I: Downloaded 1610862/2114729 bytes (76%)
    I: Downloaded 1611564/2114729 bytes (76%)
    I: Downloaded 1612266/2114729 bytes (76%)
    I: Downloaded 1612968/2114729 bytes (76%)
    I: Downloaded 1613670/2114729 bytes (76%)
    I: Downloaded 1614372/2114729 bytes (76%)
    I: Downloaded 1615074/2114729 bytes (76%)
    I: Downloaded 1615776/2114729 bytes (76%)
    I: Downloaded 1616478/2114729 bytes (76%)
    I: Downloaded 1617180/2114729 bytes (76%)
    I: Downloaded 1617882/2114729 bytes (76%)
    I: Downloaded 1618584/2114729 bytes (76%)
    I: Downloaded 1619286/2114729 bytes (76%)
    I: Downloaded 1619988/2114729 bytes (76%)
    I: Downloaded 1620690/2114729 bytes (76%)
    I: Downloaded 1621392/2114729 bytes (76%)
    I: Downloaded 1622094/2114729 bytes (76%)
    I: Downloaded 1622796/2114729 bytes (76%)
    I: Downloaded 1623498/2114729 bytes (76%)
    I: Downloaded 1624200/2114729 bytes (76%)
    I: Downloaded 1624902/2114729 bytes (76%)
    I: Downloaded 1625604/2114729 bytes (76%)
    I: Downloaded 1626306/2114729 bytes (76%)
    I: Downloaded 1627008/2114729 bytes (76%)
    I: Downloaded 1627710/2114729 bytes (76%)
    I: Downloaded 1628412/2114729 bytes (77%)
    I: Downloaded 1629114/2114729 bytes (77%)
    I: Downloaded 1629816/2114729 bytes (77%)
    I: Downloaded 1630518/2114729 bytes (77%)
    I: Downloaded 1631220/2114729 bytes (77%)
    I: Downloaded 1631922/2114729 bytes (77%)
    I: Downloaded 1632624/2114729 bytes (77%)
    I: Downloaded 1633326/2114729 bytes (77%)
    I: Downloaded 1634028/2114729 bytes (77%)
    I: Downloaded 1634730/2114729 bytes (77%)
    I: Downloaded 1635432/2114729 bytes (77%)
    I: Downloaded 1636134/2114729 bytes (77%)
    I: Downloaded 1636836/2114729 bytes (77%)
    I: Downloaded 1637538/2114729 bytes (77%)
    I: Downloaded 1638240/2114729 bytes (77%)
    I: Downloaded 1638942/2114729 bytes (77%)
    I: Downloaded 1639644/2114729 bytes (77%)
    I: Downloaded 1640346/2114729 bytes (77%)
    I: Downloaded 1641048/2114729 bytes (77%)
    I: Downloaded 1641750/2114729 bytes (77%)
    I: Downloaded 1642452/2114729 bytes (77%)
    I: Downloaded 1643154/2114729 bytes (77%)
    I: Downloaded 1643856/2114729 bytes (77%)
    I: Downloaded 1644558/2114729 bytes (77%)
    I: Downloaded 1645260/2114729 bytes (77%)
    I: Downloaded 1645962/2114729 bytes (77%)
    I: Downloaded 1646664/2114729 bytes (77%)
    I: Downloaded 1647366/2114729 bytes (77%)
    I: Downloaded 1648068/2114729 bytes (77%)
    I: Downloaded 1648770/2114729 bytes (77%)
    I: Downloaded 1649472/2114729 bytes (77%)
    I: Downloaded 1650174/2114729 bytes (78%)
    I: Downloaded 1650876/2114729 bytes (78%)
    I: Downloaded 1651578/2114729 bytes (78%)
    I: Downloaded 1652280/2114729 bytes (78%)
    I: Downloaded 1652982/2114729 bytes (78%)
    I: Downloaded 1653684/2114729 bytes (78%)
    I: Downloaded 1654386/2114729 bytes (78%)
    I: Downloaded 1655088/2114729 bytes (78%)
    I: Downloaded 1655790/2114729 bytes (78%)
    I: Downloaded 1656492/2114729 bytes (78%)
    I: Downloaded 1657194/2114729 bytes (78%)
    I: Downloaded 1657896/2114729 bytes (78%)
    I: Downloaded 1658598/2114729 bytes (78%)
    I: Downloaded 1659300/2114729 bytes (78%)
    I: Downloaded 1660002/2114729 bytes (78%)
    I: Downloaded 1660704/2114729 bytes (78%)
    I: Downloaded 1661406/2114729 bytes (78%)
    I: Downloaded 1662108/2114729 bytes (78%)
    I: Downloaded 1662810/2114729 bytes (78%)
    I: Downloaded 1663512/2114729 bytes (78%)
    I: Downloaded 1664214/2114729 bytes (78%)
    I: Downloaded 1664916/2114729 bytes (78%)
    I: Downloaded 1665618/2114729 bytes (78%)
    I: Downloaded 1666320/2114729 bytes (78%)
    I: Downloaded 1667022/2114729 bytes (78%)
    I: Downloaded 1667724/2114729 bytes (78%)
    I: Downloaded 1668426/2114729 bytes (78%)
    I: Downloaded 1669128/2114729 bytes (78%)
    I: Downloaded 1669830/2114729 bytes (78%)
    I: Downloaded 1670532/2114729 bytes (78%)
    I: Downloaded 1671234/2114729 bytes (79%)
    I: Downloaded 1671936/2114729 bytes (79%)
    I: Downloaded 1672638/2114729 bytes (79%)
    I: Downloaded 1673340/2114729 bytes (79%)
    I: Downloaded 1674042/2114729 bytes (79%)
    I: Downloaded 1674798/2114729 bytes (79%)
    I: Downloaded 1675446/2114729 bytes (79%)
    I: Downloaded 1676148/2114729 bytes (79%)
    I: Downloaded 1676850/2114729 bytes (79%)
    I: Downloaded 1677552/2114729 bytes (79%)
    I: Downloaded 1678254/2114729 bytes (79%)
    I: Downloaded 1679010/2114729 bytes (79%)
    I: Downloaded 1679712/2114729 bytes (79%)
    I: Downloaded 1680414/2114729 bytes (79%)
    I: Downloaded 1681062/2114729 bytes (79%)
    I: Downloaded 1681764/2114729 bytes (79%)
    I: Downloaded 1682466/2114729 bytes (79%)
    I: Downloaded 1683168/2114729 bytes (79%)
    I: Downloaded 1683870/2114729 bytes (79%)
    I: Downloaded 1684572/2114729 bytes (79%)
    I: Downloaded 1685274/2114729 bytes (79%)
    I: Downloaded 1686084/2114729 bytes (79%)
    I: Downloaded 1686678/2114729 bytes (79%)
    I: Downloaded 1687380/2114729 bytes (79%)
    I: Downloaded 1688082/2114729 bytes (79%)
    I: Downloaded 1688784/2114729 bytes (79%)
    I: Downloaded 1689486/2114729 bytes (79%)
    I: Downloaded 1690188/2114729 bytes (79%)
    I: Downloaded 1690242/2114729 bytes (79%)
    I: Downloaded 1690944/2114729 bytes (79%)
    I: Downloaded 1691646/2114729 bytes (79%)
    I: Downloaded 1692294/2114729 bytes (80%)
    I: Downloaded 1692996/2114729 bytes (80%)
    I: Downloaded 1693698/2114729 bytes (80%)
    I: Downloaded 1694400/2114729 bytes (80%)
    I: Downloaded 1695102/2114729 bytes (80%)
    I: Downloaded 1695804/2114729 bytes (80%)
    I: Downloaded 1696506/2114729 bytes (80%)
    I: Downloaded 1697208/2114729 bytes (80%)
    I: Downloaded 1697316/2114729 bytes (80%)
    I: Downloaded 1697910/2114729 bytes (80%)
    I: Downloaded 1698612/2114729 bytes (80%)
    I: Downloaded 1699314/2114729 bytes (80%)
    I: Downloaded 1700016/2114729 bytes (80%)
    I: Downloaded 1700718/2114729 bytes (80%)
    I: Downloaded 1701420/2114729 bytes (80%)
    I: Downloaded 1702122/2114729 bytes (80%)
    I: Downloaded 1702824/2114729 bytes (80%)
    I: Downloaded 1703526/2114729 bytes (80%)
    I: Downloaded 1704228/2114729 bytes (80%)
    I: Downloaded 1704930/2114729 bytes (80%)
    I: Downloaded 1705632/2114729 bytes (80%)
    I: Downloaded 1706334/2114729 bytes (80%)
    I: Downloaded 1707036/2114729 bytes (80%)
    I: Downloaded 1707738/2114729 bytes (80%)
    I: Downloaded 1708440/2114729 bytes (80%)
    I: Downloaded 1709142/2114729 bytes (80%)
    I: Downloaded 1709844/2114729 bytes (80%)
    I: Downloaded 1710546/2114729 bytes (80%)
    I: Downloaded 1711248/2114729 bytes (80%)
    I: Downloaded 1711950/2114729 bytes (80%)
    I: Downloaded 1712652/2114729 bytes (80%)
    I: Downloaded 1713354/2114729 bytes (81%)
    I: Downloaded 1714056/2114729 bytes (81%)
    I: Downloaded 1714758/2114729 bytes (81%)
    I: Downloaded 1715460/2114729 bytes (81%)
    I: Downloaded 1716162/2114729 bytes (81%)
    I: Downloaded 1716864/2114729 bytes (81%)
    I: Downloaded 1717566/2114729 bytes (81%)
    I: Downloaded 1718268/2114729 bytes (81%)
    I: Downloaded 1718970/2114729 bytes (81%)
    I: Downloaded 1719672/2114729 bytes (81%)
    I: Downloaded 1720374/2114729 bytes (81%)
    I: Downloaded 1721076/2114729 bytes (81%)
    I: Downloaded 1721778/2114729 bytes (81%)
    I: Downloaded 1722480/2114729 bytes (81%)
    I: Downloaded 1723182/2114729 bytes (81%)
    I: Downloaded 1723884/2114729 bytes (81%)
    I: Downloaded 1724586/2114729 bytes (81%)
    I: Downloaded 1725288/2114729 bytes (81%)
    I: Downloaded 1725990/2114729 bytes (81%)
    I: Downloaded 1726692/2114729 bytes (81%)
    I: Downloaded 1727394/2114729 bytes (81%)
    I: Downloaded 1728096/2114729 bytes (81%)
    I: Downloaded 1728798/2114729 bytes (81%)
    I: Downloaded 1729500/2114729 bytes (81%)
    I: Downloaded 1730202/2114729 bytes (81%)
    I: Downloaded 1730904/2114729 bytes (81%)
    I: Downloaded 1731606/2114729 bytes (81%)
    I: Downloaded 1732308/2114729 bytes (81%)
    I: Downloaded 1733010/2114729 bytes (81%)
    I: Downloaded 1733712/2114729 bytes (81%)
    I: Downloaded 1734414/2114729 bytes (82%)
    I: Downloaded 1735116/2114729 bytes (82%)
    I: Downloaded 1735818/2114729 bytes (82%)
    I: Downloaded 1736520/2114729 bytes (82%)
    I: Downloaded 1737222/2114729 bytes (82%)
    I: Downloaded 1737924/2114729 bytes (82%)
    I: Downloaded 1738626/2114729 bytes (82%)
    I: Downloaded 1739328/2114729 bytes (82%)
    I: Downloaded 1740030/2114729 bytes (82%)
    I: Downloaded 1740732/2114729 bytes (82%)
    I: Downloaded 1741434/2114729 bytes (82%)
    I: Downloaded 1742136/2114729 bytes (82%)
    I: Downloaded 1742838/2114729 bytes (82%)
    I: Downloaded 1743540/2114729 bytes (82%)
    I: Downloaded 1744242/2114729 bytes (82%)
    I: Downloaded 1744944/2114729 bytes (82%)
    I: Downloaded 1745646/2114729 bytes (82%)
    I: Downloaded 1746348/2114729 bytes (82%)
    I: Downloaded 1747050/2114729 bytes (82%)
    I: Downloaded 1747752/2114729 bytes (82%)
    I: Downloaded 1748454/2114729 bytes (82%)
    I: Downloaded 1749156/2114729 bytes (82%)
    I: Downloaded 1749858/2114729 bytes (82%)
    I: Downloaded 1750560/2114729 bytes (82%)
    I: Downloaded 1751262/2114729 bytes (82%)
    I: Downloaded 1751964/2114729 bytes (82%)
    I: Downloaded 1752666/2114729 bytes (82%)
    I: Downloaded 1753368/2114729 bytes (82%)
    I: Downloaded 1754070/2114729 bytes (82%)
    I: Downloaded 1754772/2114729 bytes (82%)
    I: Downloaded 1755474/2114729 bytes (83%)
    I: Downloaded 1756176/2114729 bytes (83%)
    I: Downloaded 1756878/2114729 bytes (83%)
    I: Downloaded 1757580/2114729 bytes (83%)
    I: Downloaded 1758282/2114729 bytes (83%)
    I: Downloaded 1758984/2114729 bytes (83%)
    I: Downloaded 1759686/2114729 bytes (83%)
    I: Downloaded 1760388/2114729 bytes (83%)
    I: Downloaded 1761090/2114729 bytes (83%)
    I: Downloaded 1761792/2114729 bytes (83%)
    I: Downloaded 1762494/2114729 bytes (83%)
    I: Downloaded 1763196/2114729 bytes (83%)
    I: Downloaded 1763898/2114729 bytes (83%)
    I: Downloaded 1764600/2114729 bytes (83%)
    I: Downloaded 1765302/2114729 bytes (83%)
    I: Downloaded 1766004/2114729 bytes (83%)
    I: Downloaded 1766706/2114729 bytes (83%)
    I: Downloaded 1767408/2114729 bytes (83%)
    I: Downloaded 1768110/2114729 bytes (83%)
    I: Downloaded 1768812/2114729 bytes (83%)
    I: Downloaded 1769514/2114729 bytes (83%)
    I: Downloaded 1770216/2114729 bytes (83%)
    I: Downloaded 1770918/2114729 bytes (83%)
    I: Downloaded 1771620/2114729 bytes (83%)
    I: Downloaded 1772322/2114729 bytes (83%)
    I: Downloaded 1773024/2114729 bytes (83%)
    I: Downloaded 1773726/2114729 bytes (83%)
    I: Downloaded 1774428/2114729 bytes (83%)
    I: Downloaded 1775130/2114729 bytes (83%)
    I: Downloaded 1775832/2114729 bytes (83%)
    I: Downloaded 1776534/2114729 bytes (84%)
    I: Downloaded 1777236/2114729 bytes (84%)
    I: Downloaded 1777938/2114729 bytes (84%)
    I: Downloaded 1778640/2114729 bytes (84%)
    I: Downloaded 1779342/2114729 bytes (84%)
    I: Downloaded 1780044/2114729 bytes (84%)
    I: Downloaded 1780746/2114729 bytes (84%)
    I: Downloaded 1781448/2114729 bytes (84%)
    I: Downloaded 1782150/2114729 bytes (84%)
    I: Downloaded 1782852/2114729 bytes (84%)
    I: Downloaded 1783554/2114729 bytes (84%)
    I: Downloaded 1784256/2114729 bytes (84%)
    I: Downloaded 1784958/2114729 bytes (84%)
    I: Downloaded 1785660/2114729 bytes (84%)
    I: Downloaded 1786362/2114729 bytes (84%)
    I: Downloaded 1787064/2114729 bytes (84%)
    I: Downloaded 1787118/2114729 bytes (84%)
    I: Downloaded 1787766/2114729 bytes (84%)
    I: Downloaded 1788468/2114729 bytes (84%)
    I: Downloaded 1789170/2114729 bytes (84%)
    I: Downloaded 1789872/2114729 bytes (84%)
    I: Downloaded 1790574/2114729 bytes (84%)
    I: Downloaded 1791330/2114729 bytes (84%)
    I: Downloaded 1792032/2114729 bytes (84%)
    I: Downloaded 1792734/2114729 bytes (84%)
    I: Downloaded 1793382/2114729 bytes (84%)
    I: Downloaded 1794084/2114729 bytes (84%)
    I: Downloaded 1794786/2114729 bytes (84%)
    I: Downloaded 1795488/2114729 bytes (84%)
    I: Downloaded 1796190/2114729 bytes (84%)
    I: Downloaded 1796892/2114729 bytes (84%)
    I: Downloaded 1797594/2114729 bytes (85%)
    I: Downloaded 1798296/2114729 bytes (85%)
    I: Downloaded 1798998/2114729 bytes (85%)
    I: Downloaded 1799700/2114729 bytes (85%)
    I: Downloaded 1800402/2114729 bytes (85%)
    I: Downloaded 1801104/2114729 bytes (85%)
    I: Downloaded 1801806/2114729 bytes (85%)
    I: Downloaded 1802508/2114729 bytes (85%)
    I: Downloaded 1803210/2114729 bytes (85%)
    I: Downloaded 1803912/2114729 bytes (85%)
    I: Downloaded 1804614/2114729 bytes (85%)
    I: Downloaded 1805316/2114729 bytes (85%)
    I: Downloaded 1806018/2114729 bytes (85%)
    I: Downloaded 1806720/2114729 bytes (85%)
    I: Downloaded 1807422/2114729 bytes (85%)
    I: Downloaded 1808124/2114729 bytes (85%)
    I: Downloaded 1808826/2114729 bytes (85%)
    I: Downloaded 1809528/2114729 bytes (85%)
    I: Downloaded 1810230/2114729 bytes (85%)
    I: Downloaded 1810932/2114729 bytes (85%)
    I: Downloaded 1811634/2114729 bytes (85%)
    I: Downloaded 1812336/2114729 bytes (85%)
    I: Downloaded 1813038/2114729 bytes (85%)
    I: Downloaded 1813740/2114729 bytes (85%)
    I: Downloaded 1814442/2114729 bytes (85%)
    I: Downloaded 1815198/2114729 bytes (85%)
    I: Downloaded 1815846/2114729 bytes (85%)
    I: Downloaded 1816548/2114729 bytes (85%)
    I: Downloaded 1817250/2114729 bytes (85%)
    I: Downloaded 1817952/2114729 bytes (85%)
    I: Downloaded 1818654/2114729 bytes (85%)
    I: Downloaded 1819410/2114729 bytes (86%)
    I: Downloaded 1820112/2114729 bytes (86%)
    I: Downloaded 1820814/2114729 bytes (86%)
    I: Downloaded 1821462/2114729 bytes (86%)
    I: Downloaded 1822164/2114729 bytes (86%)
    I: Downloaded 1822866/2114729 bytes (86%)
    I: Downloaded 1823568/2114729 bytes (86%)
    I: Downloaded 1824270/2114729 bytes (86%)
    I: Downloaded 1824972/2114729 bytes (86%)
    I: Downloaded 1825674/2114729 bytes (86%)
    I: Downloaded 1826484/2114729 bytes (86%)
    I: Downloaded 1827078/2114729 bytes (86%)
    I: Downloaded 1827780/2114729 bytes (86%)
    I: Downloaded 1828482/2114729 bytes (86%)
    I: Downloaded 1829184/2114729 bytes (86%)
    I: Downloaded 1829886/2114729 bytes (86%)
    I: Downloaded 1830588/2114729 bytes (86%)
    I: Downloaded 1830642/2114729 bytes (86%)
    I: Downloaded 1831344/2114729 bytes (86%)
    I: Downloaded 1832046/2114729 bytes (86%)
    I: Downloaded 1832694/2114729 bytes (86%)
    I: Downloaded 1833396/2114729 bytes (86%)
    I: Downloaded 1834098/2114729 bytes (86%)
    I: Downloaded 1834800/2114729 bytes (86%)
    I: Downloaded 1835502/2114729 bytes (86%)
    I: Downloaded 1836204/2114729 bytes (86%)
    I: Downloaded 1836906/2114729 bytes (86%)
    I: Downloaded 1837608/2114729 bytes (86%)
    I: Downloaded 1837716/2114729 bytes (86%)
    I: Downloaded 1838310/2114729 bytes (86%)
    I: Downloaded 1839012/2114729 bytes (86%)
    I: Downloaded 1839714/2114729 bytes (86%)
    I: Downloaded 1840470/2114729 bytes (87%)
    I: Downloaded 1841118/2114729 bytes (87%)
    I: Downloaded 1841820/2114729 bytes (87%)
    I: Downloaded 1842522/2114729 bytes (87%)
    I: Downloaded 1843224/2114729 bytes (87%)
    I: Downloaded 1843926/2114729 bytes (87%)
    I: Downloaded 1844628/2114729 bytes (87%)
    I: Downloaded 1845330/2114729 bytes (87%)
    I: Downloaded 1846032/2114729 bytes (87%)
    I: Downloaded 1846734/2114729 bytes (87%)
    I: Downloaded 1847490/2114729 bytes (87%)
    I: Downloaded 1848192/2114729 bytes (87%)
    I: Downloaded 1848894/2114729 bytes (87%)
    I: Downloaded 1849542/2114729 bytes (87%)
    I: Downloaded 1850244/2114729 bytes (87%)
    I: Downloaded 1850946/2114729 bytes (87%)
    I: Downloaded 1851648/2114729 bytes (87%)
    I: Downloaded 1851702/2114729 bytes (87%)
    I: Downloaded 1852350/2114729 bytes (87%)
    I: Downloaded 1853052/2114729 bytes (87%)
    I: Downloaded 1853754/2114729 bytes (87%)
    I: Downloaded 1854456/2114729 bytes (87%)
    I: Downloaded 1855158/2114729 bytes (87%)
    I: Downloaded 1855860/2114729 bytes (87%)
    I: Downloaded 1856562/2114729 bytes (87%)
    I: Downloaded 1857264/2114729 bytes (87%)
    I: Downloaded 1857966/2114729 bytes (87%)
    I: Downloaded 1858668/2114729 bytes (87%)
    I: Downloaded 1859370/2114729 bytes (87%)
    I: Downloaded 1860126/2114729 bytes (87%)
    I: Downloaded 1860774/2114729 bytes (87%)
    I: Downloaded 1861476/2114729 bytes (88%)
    I: Downloaded 1862178/2114729 bytes (88%)
    I: Downloaded 1862880/2114729 bytes (88%)
    I: Downloaded 1863582/2114729 bytes (88%)
    I: Downloaded 1864338/2114729 bytes (88%)
    I: Downloaded 1865040/2114729 bytes (88%)
    I: Downloaded 1865742/2114729 bytes (88%)
    I: Downloaded 1866390/2114729 bytes (88%)
    I: Downloaded 1867092/2114729 bytes (88%)
    I: Downloaded 1867794/2114729 bytes (88%)
    I: Downloaded 1868496/2114729 bytes (88%)
    I: Downloaded 1869198/2114729 bytes (88%)
    I: Downloaded 1869900/2114729 bytes (88%)
    I: Downloaded 1870602/2114729 bytes (88%)
    I: Downloaded 1871304/2114729 bytes (88%)
    I: Downloaded 1872006/2114729 bytes (88%)
    I: Downloaded 1872708/2114729 bytes (88%)
    I: Downloaded 1873410/2114729 bytes (88%)
    I: Downloaded 1874112/2114729 bytes (88%)
    I: Downloaded 1874814/2114729 bytes (88%)
    I: Downloaded 1875516/2114729 bytes (88%)
    I: Downloaded 1876218/2114729 bytes (88%)
    I: Downloaded 1876920/2114729 bytes (88%)
    I: Downloaded 1877622/2114729 bytes (88%)
    I: Downloaded 1878324/2114729 bytes (88%)
    I: Downloaded 1879026/2114729 bytes (88%)
    I: Downloaded 1879728/2114729 bytes (88%)
    I: Downloaded 1880430/2114729 bytes (88%)
    I: Downloaded 1881132/2114729 bytes (88%)
    I: Downloaded 1881834/2114729 bytes (88%)
    I: Downloaded 1882536/2114729 bytes (89%)
    I: Downloaded 1883238/2114729 bytes (89%)
    I: Downloaded 1883940/2114729 bytes (89%)
    I: Downloaded 1884642/2114729 bytes (89%)
    I: Downloaded 1885344/2114729 bytes (89%)
    I: Downloaded 1886046/2114729 bytes (89%)
    I: Downloaded 1886748/2114729 bytes (89%)
    I: Downloaded 1887450/2114729 bytes (89%)
    I: Downloaded 1888152/2114729 bytes (89%)
    I: Downloaded 1888854/2114729 bytes (89%)
    I: Downloaded 1889556/2114729 bytes (89%)
    I: Downloaded 1890258/2114729 bytes (89%)
    I: Downloaded 1890960/2114729 bytes (89%)
    I: Downloaded 1891662/2114729 bytes (89%)
    I: Downloaded 1892364/2114729 bytes (89%)
    I: Downloaded 1893066/2114729 bytes (89%)
    I: Downloaded 1893768/2114729 bytes (89%)
    I: Downloaded 1894470/2114729 bytes (89%)
    I: Downloaded 1895172/2114729 bytes (89%)
    I: Downloaded 1895874/2114729 bytes (89%)
    I: Downloaded 1896576/2114729 bytes (89%)
    I: Downloaded 1897278/2114729 bytes (89%)
    I: Downloaded 1897980/2114729 bytes (89%)
    I: Downloaded 1898682/2114729 bytes (89%)
    I: Downloaded 1899438/2114729 bytes (89%)
    I: Downloaded 1900086/2114729 bytes (89%)
    I: Downloaded 1900788/2114729 bytes (89%)
    I: Downloaded 1901490/2114729 bytes (89%)
    I: Downloaded 1902192/2114729 bytes (89%)
    I: Downloaded 1902894/2114729 bytes (89%)
    I: Downloaded 1903650/2114729 bytes (90%)
    I: Downloaded 1904352/2114729 bytes (90%)
    I: Downloaded 1905054/2114729 bytes (90%)
    I: Downloaded 1905702/2114729 bytes (90%)
    I: Downloaded 1906404/2114729 bytes (90%)
    I: Downloaded 1907106/2114729 bytes (90%)
    I: Downloaded 1907808/2114729 bytes (90%)
    I: Downloaded 1908510/2114729 bytes (90%)
    I: Downloaded 1909212/2114729 bytes (90%)
    I: Downloaded 1909914/2114729 bytes (90%)
    I: Downloaded 1910724/2114729 bytes (90%)
    I: Downloaded 1911318/2114729 bytes (90%)
    I: Downloaded 1912020/2114729 bytes (90%)
    I: Downloaded 1912722/2114729 bytes (90%)
    I: Downloaded 1913424/2114729 bytes (90%)
    I: Downloaded 1914126/2114729 bytes (90%)
    I: Downloaded 1914828/2114729 bytes (90%)
    I: Downloaded 1914882/2114729 bytes (90%)
    I: Downloaded 1915584/2114729 bytes (90%)
    I: Downloaded 1916286/2114729 bytes (90%)
    I: Downloaded 1916934/2114729 bytes (90%)
    I: Downloaded 1917636/2114729 bytes (90%)
    I: Downloaded 1918338/2114729 bytes (90%)
    I: Downloaded 1919040/2114729 bytes (90%)
    I: Downloaded 1919742/2114729 bytes (90%)
    I: Downloaded 1920444/2114729 bytes (90%)
    I: Downloaded 1921146/2114729 bytes (90%)
    I: Downloaded 1921956/2114729 bytes (90%)
    I: Downloaded 1922550/2114729 bytes (90%)
    I: Downloaded 1923252/2114729 bytes (90%)
    I: Downloaded 1923954/2114729 bytes (90%)
    I: Downloaded 1924656/2114729 bytes (91%)
    I: Downloaded 1925358/2114729 bytes (91%)
    I: Downloaded 1926060/2114729 bytes (91%)
    I: Downloaded 1926762/2114729 bytes (91%)
    I: Downloaded 1927464/2114729 bytes (91%)
    I: Downloaded 1928166/2114729 bytes (91%)
    I: Downloaded 1928868/2114729 bytes (91%)
    I: Downloaded 1929570/2114729 bytes (91%)
    I: Downloaded 1930272/2114729 bytes (91%)
    I: Downloaded 1930974/2114729 bytes (91%)
    I: Downloaded 1931676/2114729 bytes (91%)
    I: Downloaded 1932378/2114729 bytes (91%)
    I: Downloaded 1933080/2114729 bytes (91%)
    I: Downloaded 1933782/2114729 bytes (91%)
    I: Downloaded 1934484/2114729 bytes (91%)
    I: Downloaded 1935186/2114729 bytes (91%)
    I: Downloaded 1935888/2114729 bytes (91%)
    I: Downloaded 1936590/2114729 bytes (91%)
    I: Downloaded 1937292/2114729 bytes (91%)
    I: Downloaded 1937994/2114729 bytes (91%)
    I: Downloaded 1938696/2114729 bytes (91%)
    I: Downloaded 1939398/2114729 bytes (91%)
    I: Downloaded 1940100/2114729 bytes (91%)
    I: Downloaded 1940802/2114729 bytes (91%)
    I: Downloaded 1941504/2114729 bytes (91%)
    I: Downloaded 1942206/2114729 bytes (91%)
    I: Downloaded 1942908/2114729 bytes (91%)
    I: Downloaded 1943610/2114729 bytes (91%)
    I: Downloaded 1944312/2114729 bytes (91%)
    I: Downloaded 1945014/2114729 bytes (91%)
    I: Downloaded 1945716/2114729 bytes (92%)
    I: Downloaded 1946418/2114729 bytes (92%)
    I: Downloaded 1947120/2114729 bytes (92%)
    I: Downloaded 1947822/2114729 bytes (92%)
    I: Downloaded 1948524/2114729 bytes (92%)
    I: Downloaded 1949226/2114729 bytes (92%)
    I: Downloaded 1949928/2114729 bytes (92%)
    I: Downloaded 1950630/2114729 bytes (92%)
    I: Downloaded 1951332/2114729 bytes (92%)
    I: Downloaded 1952034/2114729 bytes (92%)
    I: Downloaded 1952736/2114729 bytes (92%)
    I: Downloaded 1953438/2114729 bytes (92%)
    I: Downloaded 1954140/2114729 bytes (92%)
    I: Downloaded 1954842/2114729 bytes (92%)
    I: Downloaded 1955598/2114729 bytes (92%)
    I: Downloaded 1956246/2114729 bytes (92%)
    I: Downloaded 1956948/2114729 bytes (92%)
    I: Downloaded 1957650/2114729 bytes (92%)
    I: Downloaded 1958352/2114729 bytes (92%)
    I: Downloaded 1959054/2114729 bytes (92%)
    I: Downloaded 1959756/2114729 bytes (92%)
    I: Downloaded 1959810/2114729 bytes (92%)
    I: Downloaded 1960512/2114729 bytes (92%)
    I: Downloaded 1961214/2114729 bytes (92%)
    I: Downloaded 1961862/2114729 bytes (92%)
    I: Downloaded 1962564/2114729 bytes (92%)
    I: Downloaded 1963266/2114729 bytes (92%)
    I: Downloaded 1963968/2114729 bytes (92%)
    I: Downloaded 1964670/2114729 bytes (92%)
    I: Downloaded 1965426/2114729 bytes (92%)
    I: Downloaded 1966128/2114729 bytes (92%)
    I: Downloaded 1966830/2114729 bytes (93%)
    I: Downloaded 1967478/2114729 bytes (93%)
    I: Downloaded 1968180/2114729 bytes (93%)
    I: Downloaded 1968882/2114729 bytes (93%)
    I: Downloaded 1969584/2114729 bytes (93%)
    I: Downloaded 1970286/2114729 bytes (93%)
    I: Downloaded 1970988/2114729 bytes (93%)
    I: Downloaded 1971690/2114729 bytes (93%)
    I: Downloaded 1972392/2114729 bytes (93%)
    I: Downloaded 1973094/2114729 bytes (93%)
    I: Downloaded 1973796/2114729 bytes (93%)
    I: Downloaded 1974498/2114729 bytes (93%)
    I: Downloaded 1975200/2114729 bytes (93%)
    I: Downloaded 1975902/2114729 bytes (93%)
    I: Downloaded 1976604/2114729 bytes (93%)
    I: Downloaded 1977306/2114729 bytes (93%)
    I: Downloaded 1978008/2114729 bytes (93%)
    I: Downloaded 1978710/2114729 bytes (93%)
    I: Downloaded 1979412/2114729 bytes (93%)
    I: Downloaded 1980114/2114729 bytes (93%)
    I: Downloaded 1980816/2114729 bytes (93%)
    I: Downloaded 1981518/2114729 bytes (93%)
    I: Downloaded 1982220/2114729 bytes (93%)
    I: Downloaded 1982922/2114729 bytes (93%)
    I: Downloaded 1983624/2114729 bytes (93%)
    I: Downloaded 1984326/2114729 bytes (93%)
    I: Downloaded 1985028/2114729 bytes (93%)
    I: Downloaded 1985730/2114729 bytes (93%)
    I: Downloaded 1986432/2114729 bytes (93%)
    I: Downloaded 1987134/2114729 bytes (93%)
    I: Downloaded 1987836/2114729 bytes (93%)
    I: Downloaded 1988538/2114729 bytes (94%)
    I: Downloaded 1989240/2114729 bytes (94%)
    I: Downloaded 1989942/2114729 bytes (94%)
    I: Downloaded 1990644/2114729 bytes (94%)
    I: Downloaded 1991346/2114729 bytes (94%)
    I: Downloaded 1992048/2114729 bytes (94%)
    I: Downloaded 1992750/2114729 bytes (94%)
    I: Downloaded 1993452/2114729 bytes (94%)
    I: Downloaded 1993506/2114729 bytes (94%)
    I: Downloaded 1994208/2114729 bytes (94%)
    I: Downloaded 1994910/2114729 bytes (94%)
    I: Downloaded 1995558/2114729 bytes (94%)
    I: Downloaded 1996260/2114729 bytes (94%)
    I: Downloaded 1996962/2114729 bytes (94%)
    I: Downloaded 1997664/2114729 bytes (94%)
    I: Downloaded 1997718/2114729 bytes (94%)
    I: Downloaded 1998366/2114729 bytes (94%)
    I: Downloaded 1999068/2114729 bytes (94%)
    I: Downloaded 1999770/2114729 bytes (94%)
    I: Downloaded 2000472/2114729 bytes (94%)
    I: Downloaded 2001174/2114729 bytes (94%)
    I: Downloaded 2001876/2114729 bytes (94%)
    I: Downloaded 2002578/2114729 bytes (94%)
    I: Downloaded 2003280/2114729 bytes (94%)
    I: Downloaded 2003982/2114729 bytes (94%)
    I: Downloaded 2004684/2114729 bytes (94%)
    I: Downloaded 2005386/2114729 bytes (94%)
    I: Downloaded 2006142/2114729 bytes (94%)
    I: Downloaded 2006790/2114729 bytes (94%)
    I: Downloaded 2007492/2114729 bytes (94%)
    I: Downloaded 2008194/2114729 bytes (94%)
    I: Downloaded 2008896/2114729 bytes (94%)
    I: Downloaded 2009598/2114729 bytes (95%)
    I: Downloaded 2010300/2114729 bytes (95%)
    I: Downloaded 2010354/2114729 bytes (95%)
    I: Downloaded 2011056/2114729 bytes (95%)
    I: Downloaded 2011758/2114729 bytes (95%)
    I: Downloaded 2012406/2114729 bytes (95%)
    I: Downloaded 2013108/2114729 bytes (95%)
    I: Downloaded 2013810/2114729 bytes (95%)
    I: Downloaded 2014512/2114729 bytes (95%)
    I: Downloaded 2015214/2114729 bytes (95%)
    I: Downloaded 2015916/2114729 bytes (95%)
    I: Downloaded 2016618/2114729 bytes (95%)
    I: Downloaded 2017320/2114729 bytes (95%)
    I: Downloaded 2017428/2114729 bytes (95%)
    I: Downloaded 2018022/2114729 bytes (95%)
    I: Downloaded 2018724/2114729 bytes (95%)
    I: Downloaded 2019426/2114729 bytes (95%)
    I: Downloaded 2020182/2114729 bytes (95%)
    I: Downloaded 2020830/2114729 bytes (95%)
    I: Downloaded 2021532/2114729 bytes (95%)
    I: Downloaded 2022234/2114729 bytes (95%)
    I: Downloaded 2022936/2114729 bytes (95%)
    I: Downloaded 2023638/2114729 bytes (95%)
    I: Downloaded 2024340/2114729 bytes (95%)
    I: Downloaded 2025042/2114729 bytes (95%)
    I: Downloaded 2025744/2114729 bytes (95%)
    I: Downloaded 2026446/2114729 bytes (95%)
    I: Downloaded 2027202/2114729 bytes (95%)
    I: Downloaded 2027904/2114729 bytes (95%)
    I: Downloaded 2028606/2114729 bytes (95%)
    I: Downloaded 2029254/2114729 bytes (95%)
    I: Downloaded 2029956/2114729 bytes (95%)
    I: Downloaded 2030658/2114729 bytes (96%)
    I: Downloaded 2031414/2114729 bytes (96%)
    I: Downloaded 2032062/2114729 bytes (96%)
    I: Downloaded 2032764/2114729 bytes (96%)
    I: Downloaded 2033466/2114729 bytes (96%)
    I: Downloaded 2034168/2114729 bytes (96%)
    I: Downloaded 2034870/2114729 bytes (96%)
    I: Downloaded 2035572/2114729 bytes (96%)
    I: Downloaded 2036274/2114729 bytes (96%)
    I: Downloaded 2036976/2114729 bytes (96%)
    I: Downloaded 2037678/2114729 bytes (96%)
    I: Downloaded 2038380/2114729 bytes (96%)
    I: Downloaded 2039082/2114729 bytes (96%)
    I: Downloaded 2039838/2114729 bytes (96%)
    I: Downloaded 2040486/2114729 bytes (96%)
    I: Downloaded 2041188/2114729 bytes (96%)
    I: Downloaded 2041890/2114729 bytes (96%)
    I: Downloaded 2042592/2114729 bytes (96%)
    I: Downloaded 2043294/2114729 bytes (96%)
    I: Downloaded 2043996/2114729 bytes (96%)
    I: Downloaded 2044050/2114729 bytes (96%)
    I: Downloaded 2044752/2114729 bytes (96%)
    I: Downloaded 2045454/2114729 bytes (96%)
    I: Downloaded 2046102/2114729 bytes (96%)
    I: Downloaded 2046804/2114729 bytes (96%)
    I: Downloaded 2047506/2114729 bytes (96%)
    I: Downloaded 2048208/2114729 bytes (96%)
    I: Downloaded 2048910/2114729 bytes (96%)
    I: Downloaded 2049612/2114729 bytes (96%)
    I: Downloaded 2050314/2114729 bytes (96%)
    I: Downloaded 2051016/2114729 bytes (96%)
    I: Downloaded 2051718/2114729 bytes (97%)
    I: Downloaded 2052420/2114729 bytes (97%)
    I: Downloaded 2053122/2114729 bytes (97%)
    I: Downloaded 2053824/2114729 bytes (97%)
    I: Downloaded 2054526/2114729 bytes (97%)
    I: Downloaded 2055228/2114729 bytes (97%)
    I: Downloaded 2055930/2114729 bytes (97%)
    I: Downloaded 2056632/2114729 bytes (97%)
    I: Downloaded 2057334/2114729 bytes (97%)
    I: Downloaded 2058036/2114729 bytes (97%)
    I: Downloaded 2058738/2114729 bytes (97%)
    I: Downloaded 2059440/2114729 bytes (97%)
    I: Downloaded 2060142/2114729 bytes (97%)
    I: Downloaded 2060844/2114729 bytes (97%)
    I: Downloaded 2061546/2114729 bytes (97%)
    I: Downloaded 2062248/2114729 bytes (97%)
    I: Downloaded 2062302/2114729 bytes (97%)
    I: Downloaded 2062950/2114729 bytes (97%)
    I: Downloaded 2063652/2114729 bytes (97%)
    I: Downloaded 2064354/2114729 bytes (97%)
    I: Downloaded 2065056/2114729 bytes (97%)
    I: Downloaded 2065758/2114729 bytes (97%)
    I: Downloaded 2066460/2114729 bytes (97%)
    I: Downloaded 2066514/2114729 bytes (97%)
    I: Downloaded 2067216/2114729 bytes (97%)
    I: Downloaded 2067918/2114729 bytes (97%)
    I: Downloaded 2068566/2114729 bytes (97%)
    I: Downloaded 2069268/2114729 bytes (97%)
    I: Downloaded 2069970/2114729 bytes (97%)
    I: Downloaded 2070672/2114729 bytes (97%)
    I: Downloaded 2071374/2114729 bytes (97%)
    I: Downloaded 2072076/2114729 bytes (97%)
    I: Downloaded 2072778/2114729 bytes (98%)
    I: Downloaded 2073480/2114729 bytes (98%)
    I: Downloaded 2073588/2114729 bytes (98%)
    I: Downloaded 2074182/2114729 bytes (98%)
    I: Downloaded 2074884/2114729 bytes (98%)
    I: Downloaded 2075586/2114729 bytes (98%)
    I: Downloaded 2076288/2114729 bytes (98%)
    I: Downloaded 2076990/2114729 bytes (98%)
    I: Downloaded 2077746/2114729 bytes (98%)
    I: Downloaded 2078448/2114729 bytes (98%)
    I: Downloaded 2079150/2114729 bytes (98%)
    I: Downloaded 2079798/2114729 bytes (98%)
    I: Downloaded 2080500/2114729 bytes (98%)
    I: Downloaded 2081202/2114729 bytes (98%)
    I: Downloaded 2081904/2114729 bytes (98%)
    I: Downloaded 2082606/2114729 bytes (98%)
    I: Downloaded 2083308/2114729 bytes (98%)
    I: Downloaded 2084010/2114729 bytes (98%)
    I: Downloaded 2084712/2114729 bytes (98%)
    I: Downloaded 2084820/2114729 bytes (98%)
    I: Downloaded 2085414/2114729 bytes (98%)
    I: Downloaded 2086116/2114729 bytes (98%)
    I: Downloaded 2086818/2114729 bytes (98%)
    I: Downloaded 2087520/2114729 bytes (98%)
    I: Downloaded 2088222/2114729 bytes (98%)
    I: Downloaded 2088924/2114729 bytes (98%)
    I: Downloaded 2089626/2114729 bytes (98%)
    I: Downloaded 2090328/2114729 bytes (98%)
    I: Downloaded 2091030/2114729 bytes (98%)
    I: Downloaded 2091732/2114729 bytes (98%)
    I: Downloaded 2092434/2114729 bytes (98%)
    I: Downloaded 2093190/2114729 bytes (98%)
    I: Downloaded 2093838/2114729 bytes (99%)
    I: Downloaded 2094540/2114729 bytes (99%)
    I: Downloaded 2095242/2114729 bytes (99%)
    I: Downloaded 2095944/2114729 bytes (99%)
    I: Downloaded 2096646/2114729 bytes (99%)
    I: Downloaded 2097402/2114729 bytes (99%)
    I: Downloaded 2098104/2114729 bytes (99%)
    I: Downloaded 2098806/2114729 bytes (99%)
    I: Downloaded 2099454/2114729 bytes (99%)
    I: Downloaded 2100156/2114729 bytes (99%)
    I: Downloaded 2100858/2114729 bytes (99%)
    I: Downloaded 2101560/2114729 bytes (99%)
    I: Downloaded 2102262/2114729 bytes (99%)
    I: Downloaded 2102964/2114729 bytes (99%)
    I: Downloaded 2103666/2114729 bytes (99%)
    I: Downloaded 2104476/2114729 bytes (99%)
    I: Downloaded 2105070/2114729 bytes (99%)
    I: Downloaded 2105772/2114729 bytes (99%)
    I: Downloaded 2106474/2114729 bytes (99%)
    I: Downloaded 2107176/2114729 bytes (99%)
    I: Downloaded 2107878/2114729 bytes (99%)
    I: Downloaded 2108580/2114729 bytes (99%)
    I: Downloaded 2108634/2114729 bytes (99%)
    I: Downloaded 2109336/2114729 bytes (99%)
    I: Downloaded 2110038/2114729 bytes (99%)
    I: Downloaded 2110686/2114729 bytes (99%)
    I: Downloaded 2111388/2114729 bytes (99%)
    I: Downloaded 2112090/2114729 bytes (99%)
    I: Downloaded 2112792/2114729 bytes (99%)
    I: Downloaded 2113494/2114729 bytes (99%)
    I: Downloaded 2114196/2114729 bytes (99%)
    I: Downloaded 2114729/2114729 bytes (100%)
    I: Download complete
    I: Modem firmware downloaded to flash device
    Press Button 2 or enter 'apply' to apply modem firmware update from flash
    Applying full modem firmware update from external flash
    E: Invalid hash
    fmfu_fdev_load failed: -22
    Current modem firmware version: mfw_nrf91x1_2.0.0
    LTE Link Connecting ...
    LTE network is disconnected.
    LTE Link Connected!
    Press Button 1 or enter 'download' to download firmware update
    Derek
  • Hi Derek,
    Thank you for testing the sample and reporting this potential problem.
    I have replicated this issue. We will look into this further internally. I expect to get back to you with status update by the end of the week.
    Dejan
  • Hi Derek,
    I can confirm that the sample does not work as expected. The issue has been reported and will be further looked into.
    It seems that it was not initial intention for the sample to support second download. It seems that previous download is still in external flash when performing second download. CRC failure is probably caused by writing additional image to external flash while the first one still exists.
    Clearing external flash (after the update has been applied) is expected to resolve the issue with multiple updates. Alternatively, you could try to reboot application core between updates.
    Full modem update is expected to be applied from external flash as the update is bigger than internal flash on nrf9151.
    Dejan
  • Hey Dejan,
    Thanks for confirming! Also good to know that this sample doesn't support multiple downloads and that you must reset the board after each update. I have tested and confirmed this.
    I guess I will leave this ticket open until the sample is fixed.
    Derek
