SEGGER RTT Viewer is not working for the nRF9160 on my nRF9160DK board
Hi, I am pretty certain I have used RTTViewer before on the nRF9160, albeit not frequently. I cannot remember if I only used it on custom nRF9160 boards or if I used it on the nRF9160DK. The problem now is that it gives me 3 choices for Target Device: NRF52, CORTEX-M33, and CORTEX-M4. Past experience tells me that CORTEX-M33 is not what I am looking for. What I need is NRF9160, and it is not in the list. Okay, I understand now that I have to enter the nRF9160_xxAA manually. Why does it know about the NRF52 automatically but not the 9160? I think it would automatically show me the 9160 on my custom boards that do not have an NRF52. This is certainly confusing but is this normal? But I have a more pressing concern...
I am using both UART backend and RTT backend for logging. RTT is useless--at least as it is configured here. I did a build with the UART backend disabled, but that did not help things. It made them worse, as a timeout ASSERT related to BLE HCI occurred and I was dead in the water. I had to reconnect--even though there were no indications that a disconnect had occurred.
With both backends enabled, here is what I am seeing from RTT
*** Booting nRF Connect SDK v3.1.1-e2a97fe2578a ***
*** Using Zephyr OS v4.1.99-ff8f0c579eeb ***
[00:00:00.359,283] <inf> central_uart: ble_init() entered... Initializing Bluetooth..
[00:00:00.365,234] <inf> fs_nvs: 2 Sectors of 4096 bytes
[00:00:00.365,264] <inf> fs_nvs: alloc wra: 0, fd0
[00:00:00.365,264] <inf> fs_nvs: data wra: 0, 1c
bt_init() entered...
[00:00:00.375,854] <inf> central_uart: ble_init() exited
[00:00:00.375,885] <inf> central_uart: Bluetooth initialized
[00:00:01.093,688] <wrn> bt_id: Read Static Addresses command not available
[00:00:01.094,024] <inf> bt_hci_core: HCI transport: H:4
[00:00:01.094,207] <inf> bt_hci_core: Identity: C6:BD:27:D3:7F:87 (random)
[00:00:01.094,238] <inf> bt_hci_core: HCI: version 1.0b (0x00) revision 0x0000, manufacturer 0x0000
[00:00:01.094,268] <inf> bt_hci_core: LMP: version 1.0b (0x00) subver 0x0000
[00:00:01.095,336] <dbg> central_uart: uart_
249
and here is what I am seeing from the UART
[00:00:01.095,336] <dbg> central_uart: uart_cb: UART_RX_BUF_REQUEST
[00:00:01.095,367] <inf> central_uart: UART initialized successfully
[00:00:01.095,367] <inf> central_uart: NUS Client module initialized
Starting Bluetooth Central UART example
[00:00:01.162,506] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:01.162,719] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
[00:00:01.162,750] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 252.16862 Build 1121034987
bt_init() line:4249
bt_init() line:4257
bt_init() line:4265
bt_init() line:4276
[00:00:01.169,128] <inf> bt_hci_core: HCI transport: H:4
[00:00:01.169,525] <inf> bt_hci_core: Identity: C6:BD:27:D3:7F:87 (random)
[00:00:01.169,555] <inf> bt_hci_core: HCI: version 6.1 (0x0f) revision 0x1069, manufacturer 0x0059
[00:00:01.169,799] <inf> bt_hci_core: LMP: version 6.1 (0x0f) subver 0x1069
[00:00:01.169,830] <inf> central_uart: Bluetooth ready
ble_ready() finished bt_conn_cb_register()
scan_start() finished bt_scan_init()
scan_start() finished bt_scan_cb_register()
scan_start() finished bt_scan_filter_add()
scan_start() finished bt_scan_filter_enable()
[00:00:01.185,974] <inf> central_uart: Scanning...
[00:00:01.231,689] <inf> central_uart: Filters matched. Address: E8:37:D4:53:1F:AC (random) connectable: 0
scan_connecting() entered...
connected() entered... conn_err=0
[00:00:01.332,885] <inf> central_uart: Connected: E8:37:D4:53:1F:AC (random)
gatt_req_send() encode() returns err=0
[00:00:01.433,837] <inf> central_uart: MTU exchange done
[00:00:01.633,941] <err> bt_smp: pairing failed (peer reason 0x8)
smp_pairing_complete() security_err=9 9==BT_SECURITY_ERR_UNSPECIFIED
bt_conn_security_changed() entered hci_err=31(31==BT_HCI_ERR_UNSPECIFIED) err=9
[00:00:01.634,857] <wrn> central_uart: Security failed: E8:37:D4:53:1F:AC (random) level 1 err 9
gatt_discover() entered...
[00:00:02.333,862] <inf> central_uart: Service discovery completed
bt_nus_handles_assign() entered...
Please help me learn how to make the RTT backend something other than a joke. Thank you.
Burt S.
    I suspect there might have been some changes in your environment related to RTT Viewer. nrf9160 should be listed in the Target Device Settings.
    Is there any specific reason why you have both UART and RTT logging enabled at the same time?
    Can you check if you see the same logging output when using only one (either UART or RTT) logging backend?
    Dejan
  • Hi Dejans,
    I thought I had answered your questions, but I don't see the answer. I am having horrible results with the RTT logging backend, with or without the UART backend enabled at the same time. I have been working with the UART backend disabled most recently. But I did see the same output on the RTT backend regardless of whether I had enabled the UART backend. RTTViewer seems to lock up or disconnect without any indication to the user
    Burt
  • I am trying to work with complicated code, the central_uart sample, but let's start with something simple so I can learn how to use RTT logging backend.
    Here is my program,
    #include <zephyr/kernel.h>
            while(1){
                    printk("The simplified AT host sample started\n");
                    printk("Ready\n");
                    k_sleep(K_SECONDS(1));
            return 0;
    and here is my prj.conf
    # General config
    CONFIG_ASSERT=y
    # Stacks and heaps
    CONFIG_MAIN_STACK_SIZE=3072
    CONFIG_HEAP_MEM_POOL_SIZE=16384
    CONFIG_LOG=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_LOG_BACKEND_UART=n
    CONFIG_LOG_PRINTK=y
    As long as I know when I have to connect (which is pretty retarded behavior, I mean, the fact that if I wrote the program to return, or if I push reset, the RTTViewer does not tell me that I am disconnected--sheesh, Loueesh, that's crazy!!!) anyway, so given I know when to connect, then the problem is that instead of printing the two printk's once per second, it stores them up and prints them twice once every two seconds. And that's the default behavior--not to match normal printk behavior at all? Please help me figure out how to get RTT logging to behave like normal logging as a step 1 (or step 0) to where I need to get to. Thanks, Dejan. --Burt
  • Please forgive my terrible mistake: I thought that everything got delayed about the same amount when using LOG_MODE_DEFERRED. Okay, so that should get me over the first hump: if I can use LOG_MODE_IMMEDIATE I will do so; otherwise I will know what to expect. I also see  that the blinking green light near the big chip at the left of the nRF9160DK correlates with RTT viewer connected, even though it's all misleading that this does not match up with logging connected to the terminal I view on my computer. That's annoying.
    Pretty soon I will leave my simple program and try again to work with central_uart.
    Burt
  • Anyway, the problem is exactly like I described it when I submitted this ticket. Most messages get dropped, and I cannot connect RTTViewer before the central_uart program has finished initializing.
