SEGGER RTT Viewer is not working for the nRF9160 on my nRF9160DK board
Hi, I am pretty certain I have used RTTViewer before on the nRF9160, albeit not frequently. I cannot remember if I only used it on custom nRF9160 boards or if I used it on the nRF9160DK. The problem now is that it gives me 3 choices for Target Device: NRF52, CORTEX-M33, and CORTEX-M4. Past experience tells me that CORTEX-M33 is not what I am looking for. What I need is NRF9160, and it is not in the list. Okay, I understand now that I have to enter the nRF9160_xxAA manually. Why does it know about the NRF52 automatically but not the 9160? I think it would automatically show me the 9160 on my custom boards that do not have an NRF52. This is certainly confusing but is this normal? But I have a more pressing concern...
I am using both UART backend and RTT backend for logging. RTT is useless--at least as it is configured here. I did a build with the UART backend disabled, but that did not help things. It made them worse, as a timeout ASSERT related to BLE HCI occurred and I was dead in the water. I had to reconnect--even though there were no indications that a disconnect had occurred.
With both backends enabled, here is what I am seeing from RTT
*** Booting nRF Connect SDK v3.1.1-e2a97fe2578a ***
*** Using Zephyr OS v4.1.99-ff8f0c579eeb ***
[00:00:00.359,283] <inf> central_uart: ble_init() entered... Initializing Bluetooth..
[00:00:00.365,234] <inf> fs_nvs: 2 Sectors of 4096 bytes
[00:00:00.365,264] <inf> fs_nvs: alloc wra: 0, fd0
[00:00:00.365,264] <inf> fs_nvs: data wra: 0, 1c
bt_init() entered...
[00:00:00.375,854] <inf> central_uart: ble_init() exited
[00:00:00.375,885] <inf> central_uart: Bluetooth initialized
[00:00:01.093,688] <wrn> bt_id: Read Static Addresses command not available
[00:00:01.094,024] <inf> bt_hci_core: HCI transport: H:4
[00:00:01.094,207] <inf> bt_hci_core: Identity: C6:BD:27:D3:7F:87 (random)
[00:00:01.094,238] <inf> bt_hci_core: HCI: version 1.0b (0x00) revision 0x0000, manufacturer 0x0000
[00:00:01.094,268] <inf> bt_hci_core: LMP: version 1.0b (0x00) subver 0x0000
[00:00:01.095,336] <dbg> central_uart: uart_
249
and here is what I am seeing from the UART
[00:00:01.095,336] <dbg> central_uart: uart_cb: UART_RX_BUF_REQUEST
[00:00:01.095,367] <inf> central_uart: UART initialized successfully
[00:00:01.095,367] <inf> central_uart: NUS Client module initialized
Starting Bluetooth Central UART example
[00:00:01.162,506] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:01.162,719] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
[00:00:01.162,750] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 252.16862 Build 1121034987
bt_init() line:4249
bt_init() line:4257
bt_init() line:4265
bt_init() line:4276
[00:00:01.169,128] <inf> bt_hci_core: HCI transport: H:4
[00:00:01.169,525] <inf> bt_hci_core: Identity: C6:BD:27:D3:7F:87 (random)
[00:00:01.169,555] <inf> bt_hci_core: HCI: version 6.1 (0x0f) revision 0x1069, manufacturer 0x0059
[00:00:01.169,799] <inf> bt_hci_core: LMP: version 6.1 (0x0f) subver 0x1069
[00:00:01.169,830] <inf> central_uart: Bluetooth ready
ble_ready() finished bt_conn_cb_register()
scan_start() finished bt_scan_init()
scan_start() finished bt_scan_cb_register()
scan_start() finished bt_scan_filter_add()
scan_start() finished bt_scan_filter_enable()
[00:00:01.185,974] <inf> central_uart: Scanning...
[00:00:01.231,689] <inf> central_uart: Filters matched. Address: E8:37:D4:53:1F:AC (random) connectable: 0
scan_connecting() entered...
connected() entered... conn_err=0
[00:00:01.332,885] <inf> central_uart: Connected: E8:37:D4:53:1F:AC (random)
gatt_req_send() encode() returns err=0
[00:00:01.433,837] <inf> central_uart: MTU exchange done
[00:00:01.633,941] <err> bt_smp: pairing failed (peer reason 0x8)
smp_pairing_complete() security_err=9 9==BT_SECURITY_ERR_UNSPECIFIED
bt_conn_security_changed() entered hci_err=31(31==BT_HCI_ERR_UNSPECIFIED) err=9
[00:00:01.634,857] <wrn> central_uart: Security failed: E8:37:D4:53:1F:AC (random) level 1 err 9
gatt_discover() entered...
[00:00:02.333,862] <inf> central_uart: Service discovery completed
bt_nus_handles_assign() entered...
Please help me learn how to make the RTT backend something other than a joke. Thank you.
Burt S.
  • I found another unadvertised trick. Not quite as squeaky clean as my 4 step process, but if you set
    CONFIG_LOG_MODE_IMMEDIATE=y
    CONFIG_LOG_BACKEND_RTT_RETRY_CNT=0
    then you can click the reset button and take your time somewhat prior to connecting RTT Viewer.
    The RTT buffer in RAM holds almost 1024 characters by default. I say almost because maybe there are some control characters and a few others that take a bit of the 1024 byte buffer. I mean "bit" in the non computer sense. When that fills up, the RTT backend logging software will keep trying and failing to write the next piece of data. ...CNT 0 is equivalent to 2**32 in this case. The main thread of your program will just wait for the 2**32 tries. If the beginning of your program has something time critical, then you can work around that by logging some dummy strings that fill up the buffer at the start of main. Unless there are other threads that start early and need main to start with them. My untested hunch is most of the time everything will just work even without the extra phony log messages and so forth. More correctly stated, your program will wait the 2**32 tries or until you connect RTT Viewer, allowing the buffered messages to escape to your RTT VIewer.
    Burt
  • Hi Burt,
    Thank you for additional comments.
    Burt said:
    I will close the ticket.
    Please do so if you do not have any further questions.
    Dejan
