Issues with XIP execution from external QSPI on nRF with MCUBOOT
Hi all,
I am trying to execute an application in XIP mode from an external QSPI flash on an nRF device (nRF5340, Zephyr + MCUBOOT). The setup is:
  • Partition file:pm_static.yml
#### Internal flash layout ####
mcuboot:
  address: 0x0
  end_address: 0x10000
  region: flash_primary
mcuboot_pad:
  address: 0x10000
  end_address: 0x10200
# unused_1:
#   address: 0x10200
#   end_address: 0xf0000
#   region: flash_primary
#   size: 0xdfe00
settings_storage:
  address: 0xf0000
  end_address: 0x100000
#### QSPI flash layout ####
app:
  address: 0x10000200
  end_address: 0x10200000
  region: external_flash
mcuboot_primary:
  address: 0x10000000
  device: external_flash
mcuboot_primary_pad:
  address: 0x10000000
  end_address: 0x10000200
mcuboot_primary_app:
  address: 0x10000200
  device: MX25R64
mcuboot_secondary:
  address: 0x10200000
  device: MX25R64
  end_address: 0x10400000
mcuboot_secondary_pad:
  address: 0x10200000
  end_address: 0x10200200
mcuboot_secondary_app:
  address: 0x10200200
  device: MX25R64
unused_qspi_1:
  address: 0x10400000
  device: MX25R64
  end_address: 0x10800000
#### OTP flash layout ####
otp:
  address: 0xff8100
  end_address: 0xff83fc
  region: otp
#### SRAM layout ####
rpmsg_nrf53_sram:
  address: 0x20070000
  end_address: 0x20080000
  placement:
    before:
    - end
  region: sram_primary
sram_primary:
  address: 0x20000000
  end_address: 0x20070000
  • prj.conf snippet:
CONFIG_PM_EXTERNAL_FLASH_BASE=0x10000000
  • The QSPI is correctly flashed using west flash.
I am facing multiple issues and would appreciate guidance on the correct procedures.
Problem 1: MCUBOOT fails to boot
  • Symptom: MCUBOOT crashes at startup because it cannot find the image.
  • Investigation:
    • boot_rom_address_check() identifies the image that should execute at 0x10000200.
    • However, f_off is 0x0 and IMAGE_F_ROM_FIXED is set
  • Questions:
    1. What is the proper procedure to fix this?
    2. Is my pm_static.yml incorrect?
    3. Is f_off misconfigured?
    4. Should I remove IMAGE_F_ROM_FIXED?
Problem 2: Application hardfault when starting manually
  • Symptom: When starting the application manually (setting SP and PC after QSPI initialization in MCUBOOT), it crashes during QSPI initialization.
  • Cause: qspi_workaround_215_43_apply() temporarily disconnects the QSPI by modifying pinmux. As we are executing from flahs
  • Attempted solution: Relocate QSPI driver code to RAM:
    zephyr_code_relocate(FILES
    ${ZEPHYR_BASE}/../modules/hal/nordic/nrfx/drivers/src/nrfx_qspi.c
    LOCATION RAM_TEXT
  • Outcome: The code is relocated, but jumping to it causes a hardfault (likely MPU related).
  • Question: What is the recommended way to safely relocate functions to RAM for QSPI initialization? Should certain MPU configurations or function attributes be used?
Problem 3: XIP offset strategy
  • Goal: Adjust xip_offset to avoid swapping two images in QSPI.
  • Question: Is there a recommended approach or best practice for using xip_offset in this scenario?
Thanks for your help
Rémi
