MCUboot build error with custom board with nrf52832 for SDK v2.9.0
I'm trying to build my program for a custom board with FOTA BLE.
Im using v2.9.0 for the SDK and the toolchain. The custom board has a nrf52832.
When building this gives the following error:
 *  Executing task: nRF Connect: Generate config [email protected]/nrf52832 for e:\BolsaNordic\hello_world_DFU
Building hello_world_DFU
west build --build-dir e:/BolsaNordic/hello_world_DFU/build e:/BolsaNordic/hello_world_DFU --pristine --board [email protected]/nrf52832 --sysbuild -- -DNCS_TOOLCHAIN_VERSION="NONE" -DBOARD_ROOT="e:/bolsanordic/zephyr_finalblepawr_peripheral"
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: C:/ncs/toolchains/b620d30767/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.9.0/zephyr/.cache
-- Board: packagetag, Revision: 8.4.0, qualifiers: nrf52832
Parsing C:/ncs/v2.9.0/zephyr/share/sysbuild/Kconfig
Loaded configuration 'E:/BolsaNordic/hello_world_DFU/build/_sysbuild/empty.conf'
Merged configuration 'E:/BolsaNordic/hello_world_DFU/build/_sysbuild/empty.conf'
Merged configuration 'e:/BolsaNordic/hello_world_DFU/sysbuild.conf'
Configuration saved to 'E:/BolsaNordic/hello_world_DFU/build/zephyr/.config'
Kconfig header saved to 'E:/BolsaNordic/hello_world_DFU/build/_sysbuild/autoconf.h'
   * Running CMake for mcuboot *
-- Application: C:/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr
-- CMake version: 3.21.0
-- Zephyr version: 3.7.99 (C:/ncs/v2.9.0/zephyr)
-- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/b620d30767/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: E:/BolsaNordic/Zephyr_FinalBLEPAwR_Peripheral/boards/TheLittleFish/packagetag/packagetag.dts
-- Found devicetree overlay: E:/BolsaNordic/Zephyr_FinalBLEPAwR_Peripheral/boards/TheLittleFish/packagetag/packagetag_8_4_0.overlay
-- Found devicetree overlay: C:/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/app.overlay
-- Generated zephyr.dts: E:/BolsaNordic/hello_world_DFU/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_generated.h: E:/BolsaNordic/hello_world_DFU/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: E:/BolsaNordic/hello_world_DFU/build/mcuboot/zephyr/dts.cmake
Parsing C:/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/Kconfig
Loaded configuration 'E:/BolsaNordic/Zephyr_FinalBLEPAwR_Peripheral/boards/TheLittleFish/packagetag/packagetag_defconfig'
Merged configuration 'E:/BolsaNordic/Zephyr_FinalBLEPAwR_Peripheral/boards/TheLittleFish/packagetag/packagetag_8_4_0_defconfig'
Merged configuration 'C:/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'E:/BolsaNordic/hello_world_DFU/build/mcuboot/zephyr/.config.sysbuild'
Configuration saved to 'E:/BolsaNordic/hello_world_DFU/build/mcuboot/zephyr/.config'
Kconfig header saved to 'E:/BolsaNordic/hello_world_DFU/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
-- Found GnuLd: c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
-- Setting build type to 'MinSizeRel' as none was specified.
CMake Warning at C:/ncs/v2.9.0/zephyr/CMakeLists.txt:952 (message):
  No SOURCES given to Zephyr library: drivers__spi
  Excluding target from build.
MCUBoot bootloader key file: C:/ncs/v2.9.0/bootloader/mcuboot/root-rsa-2048.pem
-- Configuring done
-- Generating done
-- Build files have been written to: E:/BolsaNordic/hello_world_DFU/build/mcuboot
   * Running CMake for hello_world_DFU *
-- Application: E:/BolsaNordic/hello_world_DFU
-- Found devicetree overlay: E:/BolsaNordic/hello_world_DFU/app.overlay
-- Generated zephyr.dts: E:/BolsaNordic/hello_world_DFU/build/hello_world_DFU/zephyr/zephyr.dts
-- Generated devicetree_generated.h: E:/BolsaNordic/hello_world_DFU/build/hello_world_DFU/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: E:/BolsaNordic/hello_world_DFU/build/hello_world_DFU/zephyr/dts.cmake
Parsing C:/ncs/v2.9.0/zephyr/Kconfig
Merged configuration 'E:/BolsaNordic/hello_world_DFU/prj.conf'
Merged configuration 'E:/BolsaNordic/hello_world_DFU/build/hello_world_DFU/zephyr/.config.sysbuild'
Configuration saved to 'E:/BolsaNordic/hello_world_DFU/build/hello_world_DFU/zephyr/.config'
Kconfig header saved to 'E:/BolsaNordic/hello_world_DFU/build/hello_world_DFU/zephyr/include/generated/zephyr/autoconf.h'
-- Including signing script: C:/ncs/v2.9.0/nrf/cmake/sysbuild/image_signing.cmake
-- Configuring done
-- Generating done
-- Build files have been written to: E:/BolsaNordic/hello_world_DFU/build/hello_world_DFU
CMake Warning at C:/ncs/v2.9.0/nrf/cmake/sysbuild/partition_manager.cmake:106 (message):
        --- WARNING: Using a bootloader without pm_static.yml.            ---
        --- There are cases where a deployed product can consist of       ---
        --- multiple images, and only a subset of these images can be     ---
        --- upgraded through a firmware update mechanism. In such cases,  ---
        --- the upgradable images must have partitions that are static    ---
        --- and are matching the partition map used by the bootloader     ---
        --- programmed onto the device.                                   ---
  C:/ncs/v2.9.0/nrf/cmake/sysbuild/partition_manager.cmake:634 (partition_manager)
  C:/ncs/v2.9.0/nrf/sysbuild/CMakeLists.txt:703 (include)
  cmake/modules/sysbuild_extensions.cmake:583 (nrf_POST_CMAKE)
  cmake/modules/sysbuild_extensions.cmake:583 (cmake_language)
  cmake/modules/sysbuild_images.cmake:23 (sysbuild_module_call)
  cmake/modules/sysbuild_default.cmake:20 (include)
  C:/ncs/v2.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
  C:/ncs/v2.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  C:/ncs/v2.9.0/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
  template/CMakeLists.txt:10 (find_package)
-- Configuring done
-- Generating done
←[92m-- west build: building application
[9/20] Performing build step for 'hello_world_DFU'
[0/1] Re-running CMake...
Loading Zephyr default modules (Zephyr base (cached)).
Loaded configuration 'E:/BolsaNordic/hello_world_DFU/build/hello_world_DFU/zephyr/.config'
No change to configuration in 'E:/BolsaNordic/hello_world_DFU/build/hello_world_DFU/zephyr/.config'
No change to Kconfig header in 'E:/BolsaNordic/hello_world_DFU/build/hello_world_DFU/zephyr/include/generated/zephyr/autoconf.h'
-- Configuring done
-- Generating done
[4/254] Generating include/generated/zephyr/version.h
-- Zephyr version: 3.7.99 (C:/ncs/v2.9.0/zephyr), build: v3.7.99-ncs2
[7/254] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, inc[33/254] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/C_/ncs/v2.9.0/b[34/254] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.9.0/m[45/254] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.9.0/m[46/254] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.9.0/m[49/254] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.9.0/m[51/254] Building C object modules/segger/CMakeFiles/modules__segger.dir/C_/ncs/v2.9.0/modules/debug/segger[53/254] Building C object modules/zcbor/CMakeFiles/modules__zcbor.dir/C_/ncs/v2.9.0/modules/lib/zcbor/src/[54/254] Building C object modules/zcbor/CMakeFiles/modules__zcbor.dir/C_/ncs/v2.9.0/modules/lib/zcbor/src/[97/254] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.9.0/modules/crypto/tinycrypt/lib/source/a[105/254] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu_regio[119/254] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/scb[122/254] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fau[125/254] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq[129/254] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/s[130/254] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thr[134/254] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu[149/254] Building C object zephyr/subsys/mgmt/mcumgr/smp/CMakeFiles/subsys__mgmt__mcumgr__smp.dir/src/smp.[151/254] Building C object zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__im[154/254] Building C object zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__im[161/254] Building C object zephyr/subsys/mgmt/mcumgr/transport/CMakeFiles/subsys__mgmt__mcumgr__transport.[168/254] Linking C static library zephyr\subsys\mgmt\mcumgr\grp\os_mgmt\libsubsys__mgmt__mcumgr__grp__os_m[169/254] Linking C static library zephyr\subsys\mgmt\mcumgr\grp\img_mgmt\libsubsys__mgmt__mcumgr__grp__img[170/254] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/dummy.c[175/254] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/long_wq.c.o[184/254] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_core.c.[211/254] Building C object zephyr/drivers/sensor/bosch/bme280/CMakeFiles/drivers__sensor__bosch__bme280.di[215/254] Building C object zephyr/drivers/sensor/st/lis2dh/CMakeFiles/drivers__sensor__st__lis2dh.dir/lis2[227/254] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__[231/254] Linking C static library modules\nrf\lib\multithreading_lock\lib..__nrf__lib__multithreading_lock[232/254] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__[236/254] Linking C static library modules\nrf\lib\multithreading_lock\lib..__nrf__lib__multithreading_lock[237/254] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__[239/254] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__[240/254] Linking C static library modules\nrf\subsys\bluetooth\controller\lib..__nrf__subsys__bluetooth__c[243/254] Linking C static library modules\nrf\subsys\bluetooth\controller\lib..__nrf__subsys__bluetooth__c[254/254] Linking C executable zephyr\zephyr.elf
Memory region         Used Size  Region Size  %age Used
           FLASH:      141504 B     237056 B     59.69%
             RAM:       44372 B        64 KB     67.71%
        IDT_LIST:          0 GB        32 KB      0.00%
Generating files from E:/BolsaNordic/hello_world_DFU/build/hello_world_DFU/zephyr/zephyr.elf for board: packagetag
image.py: sign the payload
[11/20] Performing build step for 'mcuboot'
[6/301] Generating include/generated/zephyr/version.h
[7/301] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, inc[19/301] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu_[21/301] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/isr_[26/301] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/C_/ncs/v2.9.0/modules/crypto/mbedtls/[32/301] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/C_/ncs/v2.9.0/modules/crypto/mbedtls/[36/301] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/C_/ncs/v2.9.0/modules/crypto/mbedtls/[38/301] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/C_/ncs/v2.9.0/modules/crypto/mbedtls/[44/301] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/C_/ncs/v2.9.0/modules/crypto/mbedtls/[47/301] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/C_/ncs/v2.9.0/modules/crypto/mbedtls/[53/301] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/C_/ncs/v2.9.0/modules/crypto/mbedtls/[59/301] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/C_/ncs/v2.9.0/modules/crypto/mbedtls/[61/301] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/C_/ncs/v2.9.0/modules/crypto/mbedtls/[66/301] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/C_/ncs/v2.9.0/modules/crypto/mbedtls/[78/301] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.9.0/m[92/301] Building C object CMakeFiles/app.dir/C_/ncs/v2.9.0/bootloader/mcuboot/boot/bootutil/src/bootutil_m[94/301] Building C object CMakeFiles/app.dir/C_/ncs/v2.9.0/bootloader/mcuboot/boot/bootutil/src/loader.c.o[97/301] Building C object CMakeFiles/app.dir/C_/ncs/v2.9.0/bootloader/mcuboot/boot/bootutil/src/swap_scrat[103/301] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.9.0/[105/301] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/C_/ncs/v2.9.0/modules/crypto/mbedtls[111/301] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/C_/ncs/v2.9.0/modules/crypto/mbedtls[115/301] Building C object modules/mbedtls/CMakeFiles/mbedTLSBase.dir/C_/ncs/v2.9.0/modules/crypto/mbedtls[128/301] Building C object modules/mbedtls/CMakeFiles/mbedTLSCrypto.dir/C_/ncs/v2.9.0/modules/crypto/mbedt[134/301] Building C object modules/mbedtls/CMakeFiles/mbedTLSX509.dir/C_/ncs/v2.9.0/modules/crypto/mbedtls[146/301] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.9.0/modules/crypto/mb[151/301] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.9.0/modules/crypto/mb[156/301] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.9.0/modules/crypto/mb[173/301] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fpu[176/301] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/pre[186/301] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/string/strnlen.c[189/301] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/time/asctime.c.o[200/301] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul[204/301] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c[209/301] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.[214/301] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.[217/301] Building C object zephyr/soc/soc/nrf52832/CMakeFiles/soc__nordic.dir/validate_base_addresses.c.ob[241/301] Building C object zephyr/drivers/sensor/bosch/bme280/CMakeFiles/drivers__sensor__bosch__bme280.di[243/301] Building C object zephyr/drivers/sensor/st/lis2dh/CMakeFiles/drivers__sensor__st__lis2dh.dir/lis2[256/301] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.9.0/[260/301] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.9.0/[261/301] Building C object modules/segger/CMakeFiles/modules__segger.dir/C_/ncs/v2.9.0/modules/debug/segge[296/301] Linking C executable zephyr\zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map E:/BolsaNordic/hello_world_DFU/build/mcuboot/zephyr/zephyr_pre0.map
cmd.exe /C "cd . && C:\ncs\toolchains\b620d30767\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -Os -DNDEBUG -gdwarf-4 -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o
zephyr\zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=E:/BolsaNordic/hello_world_DFU/build/mcuboot/zephyr/zephyr_pre0
.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core
__cortex_m.a  zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/soc/soc/nrf52832/libsoc__n
ordic.a  zephyr/drivers/adc/libdrivers__adc.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/
drivers/gpio/libdrivers__gpio.a  zephyr/drivers/led/libdrivers__led.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  zephyr/drivers/pwm/libdrivers__pwm.a  zephyr/drivers/sensor/bosch/bme280/libdrivers
__sensor__bosch__bme280.a  zephyr/drivers/sensor/st/lis2dh/libdrivers__sensor__st__lis2dh.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/fprot
ect/lib..__nrf__lib__fprotect.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  modules/mbedtls/libmbedTLSBase.a  modules/mbedtls/libmbedTLSCrypto.a  modules/mbedtls/libmbedTLSX509.a  modules
/mbedtls/libmodules__mbedtls.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/segger/libmodules__segger.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -LE:/BolsaNordic/hello_w
orld_DFU/build/mcuboot/zephyr  zephyr/arch/common/libisr_tables.a  modules/mbedtls/libmbedTLSBase.a  modules/mbedtls/libmbedTLSCrypto.a  modules/mbedtls/libmbedTLSX509.a  -mcpu=cortex-m4  -mthumb  -ma
bi=aapcs  -mfp16-format=ieee  -fuse-ld=bfd  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib
 -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie -L"c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m/nofp" -lc -lgcc && cm
d.exe /C "cd /D E:\BolsaNordic\hello_world_DFU\build\mcuboot\zephyr && C:\ncs\toolchains\b620d30767\opt\bin\cmake.exe -E true""
c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr/drivers/adc/libdrivers__adc.a(adc_nrfx_saadc.c.obj)
: in function `k_sem_take':
E:/BolsaNordic/hello_world_DFU/build/mcuboot/zephyr/include/generated/zephyr/syscalls/kernel.h:1103: undefined reference to `z_impl_k_sem_take'
: in function `k_sem_give':
E:/BolsaNordic/hello_world_DFU/build/mcuboot/zephyr/include/generated/zephyr/syscalls/kernel.h:1120: undefined reference to `z_impl_k_sem_give'
c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: E:/BolsaNordic/hello_world_DFU/build/mcuboot/zephyr/includ
c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr/drivers/sensor/bosch/bme280/libdrivers__sensor__bos
ch__bme280.a(bme280.c.obj):(.rodata.bme280_config_0+0x0): undefined reference to `__device_dts_ord_93'
c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr/drivers/sensor/st/lis2dh/libdrivers__sensor__st__li
s2dh.a(lis2dh.c.obj):(.rodata.lis2dh_config_0+0x4): undefined reference to `__device_dts_ord_91'
s2dh.a(lis2dh_trigger.c.obj): in function `lis2dh_trigger_anym_tap_set':
C:/ncs/v2.9.0/zephyr/drivers/sensor/st/lis2dh/lis2dh_trigger.c:203: undefined reference to `k_work_submit'
s2dh.a(lis2dh_trigger.c.obj): in function `lis2dh_gpio_int1_callback':
C:/ncs/v2.9.0/zephyr/drivers/sensor/st/lis2dh/lis2dh_trigger.c:396: undefined reference to `k_work_submit'
s2dh.a(lis2dh_trigger.c.obj): in function `lis2dh_gpio_int2_callback':
C:/ncs/v2.9.0/zephyr/drivers/sensor/st/lis2dh/lis2dh_trigger.c:416: undefined reference to `k_work_submit'
s2dh.a(lis2dh_trigger.c.obj): in function `lis2dh_trigger_drdy_set':
C:/ncs/v2.9.0/zephyr/drivers/sensor/st/lis2dh/lis2dh_trigger.c:77: undefined reference to `k_work_submit'
collect2.exe: error: ld returned 1 exit status
[15/20] Generating ../dfu_application.zip
FAILED: _sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build E:/BolsaNordic/hello_world_DFU/build/_sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/m
cuboot-build
cmd.exe /C "cd /D E:\BolsaNordic\hello_world_DFU\build\mcuboot && C:\ncs\toolchains\b620d30767\opt\bin\cmake.exe --build ."
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\b620d30767\opt\bin\cmake.EXE' --build E:/BolsaNordic/hello_world_DFU/build
I tried building a clean new hello world for the custom board, but the problems persistes.
I also tried following "Lesson 9 – Bootloaders and DFU/FOTA" of the nordic academy with no success.
I also found simillar problems in other question but I could not fix my problem.
Bellow are my files for the hello world program:
prj.conf
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y
sysbuild.conf
SB_CONFIG_BOOTLOADER_MCUBOOT=y
My board (I'm building for the 8.4.0 version):
8540.packagetag.zip
Feel free to ask for any information.
Thank you.
    Try to add CONFIG_MULTITHREADING=y to sysbuild/mcuboot.conf.
    Amanda H.
  • Thank you for the fast reply.
    I tried adding the config and it no longer shows the error, but a new error surfaced:
    __sensor__bosch__bme280.a  zephyr/drivers/sensor/nordic/temp/libdrivers__sensor__nordic__temp.a  zephyr/drivers/sensor/st/lis2dh/libdrivers__sensor__st__lis2dh.a  zephyr/drivers/serial/libdrivers__ser
    ial.a  zephyr/drivers/spi/libdrivers__spi.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  mod
    ules/mbedtls/libmbedTLSBase.a  modules/mbedtls/libmbedTLSCrypto.a  modules/mbedtls/libmbedTLSX509.a  modules/mbedtls/libmodules__mbedtls.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modu
    les/segger/libmodules__segger.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -LE:/BolsaNordic/hello_world_DFU/build/mcuboot/zephyr  zephyr/arch/common/libisr_tables.a  modules/mbedtls/libmbedTL
    SBase.a  modules/mbedtls/libmbedTLSCrypto.a  modules/mbedtls/libmbedTLSX509.a  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -fuse-ld=bfd  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--so
    rt-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie -L"c:/ncs/toolchains/b620d
    30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m/nofp" -lc -lgcc && cmd.exe /C "cd /D E:\BolsaNordic\hello_world_DFU\build\mcuboot\zephyr && C:\ncs\toolchains\b62
    c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr\zephyr_pre0.elf section `rodata' will not fit in re
    gion `FLASH'
    c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: region `FLASH' overflowed by 988 bytes
    cuboot-build
    From what I understand the program overflowed the FLASH size by 988 bytes. But this makes no sense since I'm building an empty hello_world.
    So did the mcuboot overflow?
    See my colleague's explanation in this post. Although it's for nRF52833, it also applies to nRF52832.
    Amanda H.
    Disabling the LOGs and printks reduced the size so that the MCUboot fitted into de allocated 48 KB.
    With this the program compiled.
               FLASH:       45816 B        48 KB     93.21%
                 RAM:       26687 B        64 KB     40.72%
    My question is why does the LOG need to be disabled in a custom, board for the MCUboot to fit, and not in a developer board, like the nRF52DK?
    Also the default size used for the MCUboot is 48 KB, did the size increase because of the FOTA?
    I also noticed that the sum of the RAM usage for the MCUboot and the program is bigger than the available RAM. Can this be a problem?
    The LOG is disabled by default for nRF52DK.
    It's increased according to the enabled features.
    See this post.
