Unable to use LDO power on NRF52840
I want to use only LDO (not DC/DC) regulation on my nRF52840 design. The documentation states that LDO is the default for both REG0 and REG1, and that DC/DC should only be enabled if the external LC filter is present. Based on this, I removed the LC filter from my hardware.
However, after removing the LC filter, behavior is unstable:
  • Sometimes the chip fails to program,
  • Sometimes it programs but does not run.
My questions:
  1. What is the correct way to ensure the nRF52840 always uses LDO mode for both REG0 and REG1, both in hardware and firmware?
  2. Are there specific devicetree or Kconfig settings required to guarantee LDO mode and prevent the firmware from enabling DC/DC by default?
  3. Is it safe to remove the LC filter if LDO mode is always used, or could there be other issues?
  4. What could cause programming or boot failures after removing the LC filter, even though LDO should be the default?
What I have tried:
  • In the devicetree, I set:
    &reg1 { regulator-initial-mode = <NRF5X_REG_MODE_LDO>; };
Is there a checklist or best practice to ensure the nRF52840 is always in LDO mode and safe to run without the DC/DC LC filter? What else should I check if I still see programming or boot issues?
Thank you!
