6431.central_uart program from Vidar Berg with updates not working reliably in v3.1.1
We are using Vidar's program that is the basic samples/bluetooth/central_uart sample but with 3 board files so the program can be run on the nrf9160dk/nrf9160/ns board, in conjunction with bluetooth/samples/nci_lpuart running on the nRF52840 on the nRF9160DK board.
Depending upon when I reset the nrf9160, I frequently see the following, where I have added a few printk's to the code. I will show here the successful run followed by a failure. Please ignore the ECC key errors--they can be fixed with two extra config options. To make the error happen frequently, in pracitice I am push button resetting the nRF9160 soon after
Starting Bluetooth Central UART sample
Each time I see the "draining bytes from the uart" printk's that I added to bt_hci_transport_setup(), that's when the program times out and crashes.
*** Booting nRF Connect SDK v3.1.1-e2a97fe2578a ***
*** Using Zephyr OS v4.1.99-ff8f0c579eeb ***
[00:00:00.382,415] <err> bt_hci_core: HCI driver is not ready
[00:00:00.382,446] <err> central_uart: Bluetooth init failed (err -19)
[00:00:00.285,797] <err> bt_hci_core: HCI driver is not ready
[00:00:00.285,827] <err> central_uart: Bluetooth init failed (err -19)
[00:00:00.286,865] <err> bt_hci_core: HCI driver is not ready
[00:00:00.286,895] <err> central_uart: Bluetooth init failed (err -19)
[00:00:00.479,858] <inf> fs_nvs: 2 Sectors of 4096 bytes
[00:00:00.479,858] <inf> fs_nvs: alloc wra: 0, fe8
[00:00:00.479,888] <inf> fs_nvs: data wra: 0, 0
h4_open() entered...
bt_hci_transport_setup() entered...
bt_hci_transport_setup() about to gpio_pin_set(port, RESET_GPIO_PIN=24, 0)
bt_hci_transport_setup() exit success
h4_open() exit
bt_init() entered...
hci_init() entered...
common_init() entered...
common_init() about to  BT_HCI_OP_RESET
[00:00:01.192,993] <err> bt_driver: Unknown H:4 type 0x00
[00:00:01.193,084] <wrn> lpuart: RX: End detected at unexpected state (1).
common_init() after BT_HCI_OP_RESET
common_init() after drv_quirk_no_reset()
common_init() after read_local_ver_complete()
common_init() exit, good
hci_init() just finished common_init()
hci_init() just finished le_init()
[00:00:01.225,341] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:01.225,372] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
[00:00:01.225,433] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 252.16862 Build 1121034987
hci_init() exit, no error
bt_init() line:4260
bt_init() line:4268
bt_init() line:4276
[00:00:01.227,966] <inf> bt_hci_core: No ID address. App must call settings_load()
[00:00:01.227,996] <inf> central_uart: Bluetooth initialized
[00:00:01.228,363] <err> bt_ecc: Failed to generate ECC key -134
[00:00:01.228,363] <wrn> bt_smp: Public key not available
[00:00:01.231,567] <inf> bt_hci_core: HCI transport: H:4
[00:00:01.231,658] <inf> bt_hci_core: Identity: F1:B2:BA:28:C5:6D (random)
[00:00:01.231,689] <inf> bt_hci_core: HCI: version 6.1 (0x0f) revision 0x1069, manufacturer 0x0059
[00:00:01.231,719] <inf> bt_hci_core: LMP: version 6.1 (0x0f) subver 0x1069
[00:00:01.231,842] <err> bt_gatt: Unable to import the key for AES CMAC -134
[00:00:01.231,964] <inf> central_uart: NUS Client module initialized
[00:00:01.231,994] <inf> central_uart: Scan module initialized
[00:00:01.237,304] <inf> central_uart: Scan started
[00:00:01.238,098] <err> bt_gatt: Unable to import the key for AES CMAC -134
[00:00:00.287,353] <inf> fs_nvs: 2 Sectors of 4096 bytes
[00:00:00.287,353] <inf> fs_nvs: alloc wra: 0, fd0
[00:00:00.287,384] <inf> fs_nvs: data wra: 0, 1c
bt_hci_transport_setup(): draining bytes from uart, c=04
bt_hci_transport_setup(): draining bytes from uart, c=3E
bt_hci_transport_setup(): draining bytes from uart, c=29
bt_hci_transport_setup(): draining bytes from uart, c=02
bt_hci_transport_setup(): draining bytes from uart, c=01
bt_hci_transport_setup(): draining bytes from uart, c=00
bt_hci_transport_setup(): draining bytes from uart, c=A4
bt_hci_transport_setup(): draining bytes from uart, c=FA
bt_hci_transport_setup(): draining bytes from uart, c=2A
bt_hci_transport_setup(): draining bytes from uart, c=6A
bt_hci_transport_setup(): draining bytes from uart, c=B4
bt_hci_transport_setup(): draining bytes from uart, c=1D
bt_hci_transport_setup(): draining bytes from uart, c=06
bt_hci_transport_setup(): draining bytes from uart, c=19
bt_hci_transport_setup(): draining bytes from uart, c=16
bt_hci_transport_setup(): draining bytes from uart, c=F7
bt_hci_transport_setup(): draining bytes from uart, c=FD
bt_hci_transport_setup(): draining bytes from uart, c=DF
bt_hci_transport_setup(): draining bytes from uart, c=FF
bt_hci_transport_setup(): draining bytes from uart, c=7D
bt_hci_transport_setup(): draining bytes from uart, c=84
bt_hci_transport_setup(): draining bytes from uart, c=DB
bt_hci_transport_setup(): draining bytes from uart, c=25
bt_hci_transport_setup(): draining bytes from uart, c=54
bt_hci_transport_setup(): draining bytes from uart, c=F4
bt_hci_transport_setup(): draining bytes from uart, c=1B
bt_hci_transport_setup(): draining bytes from uart, c=D0
bt_hci_transport_setup(): draining bytes from uart, c=77
bt_hci_transport_setup(): draining bytes from uart, c=2D
bt_hci_transport_setup(): draining bytes from uart, c=0F
bt_hci_transport_setup(): draining bytes from uart, c=45
bt_hci_transport_setup(): draining bytes from uart, c=C3
bt_hci_transport_setup(): draining bytes from uart, c=65
bt_hci_transport_setup(): draining bytes from uart, c=03
bt_hci_transport_setup(): draining bytes from uart, c=A6
h4_open() exit
ASSERTION FAIL [err == 0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:505
        Controller unresponsive, command opcode 0x0c03 timeout with err -11
[00:00:10.300,109] <err> os: r0/a1:  0x00000003  r1/a2:  0x00000000  r2/a3:  0x00000002
[00:00:10.300,140] <err> os: r3/a4:  0x00000003 r12/ip:  0x200124dc r14/lr:  0x000104c5
[00:00:10.300,140] <err> os:  xpsr:  0x01000000
[00:00:10.300,170] <err> os: Faulting instruction address (r15/pc): 0x000104d4
[00:00:10.300,201] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
[00:00:10.300,231] <err> os: Current thread: 0x2000e7e0 (unknown)
[00:00:10.358,123] <err> os: Halting system
The central_uart code and prj.conf have no changes I am aware of other than the CONFIG_LOG... options added for BACKEND_UART.
The board files are modified from the original Vidar code like follows
(v3.1.1) burt@P51:~/ncs/v3.1.1/nrf/samples/bluetooth/central_uart$  diff -rw ~/6431.central_uart/boards boards
Only in boards: nrf5340dk_nrf5340_cpuapp.conf
Only in boards: nrf54h20dk_nrf54h20_cpuapp.conf
Only in boards: nrf54h20dk_nrf54h20_cpuapp.overlay
Only in boards: nrf54l15dk_nrf54l05_cpuapp.conf
Only in boards: nrf54l15dk_nrf54l05_cpuapp.overlay
Only in boards: nrf54l15dk_nrf54l10_cpuapp.conf
Only in boards: nrf54l15dk_nrf54l10_cpuapp.overlay
Only in boards: nrf54l15dk_nrf54l15_cpuapp.conf
Only in boards: nrf54l15dk_nrf54l15_cpuapp.overlay
Only in boards: nrf54lm20dk_nrf54lm20a_cpuapp.conf
Only in boards: nrf54lm20dk_nrf54lm20a_cpuapp.overlay
Only in boards: nrf54lm20pdk_nrf54lm20a_cpuapp.conf
Only in boards: nrf54lm20pdk_nrf54lm20a_cpuapp.overlay
Only in boards: nrf54lv10dk_nrf54lv10a_cpuapp.conf
Only in boards: nrf54lv10dk_nrf54lv10a_cpuapp.overlay
diff -rw /home/burt/6431.central_uart/boards/nrf9160dk_nrf9160_ns_0_14_0.overlay boards/nrf9160dk_nrf9160_ns_0_14_0.overlay
2c2
< #include <nrf9160dk_nrf52840_reset_on_if9.dtsi>
> #include <nrf9160/nrf9160dk_nrf52840_reset_on_if9.dtsi>
diff -rw /home/burt/6431.central_uart/boards/nrf9160dk_nrf9160_ns.conf boards/nrf9160dk_nrf9160_ns.conf
10a11,13
> #BMS CONFIG_TFM_PROFILE_TYPE_MINIMAL=n
> #BMS CONFIG_TFM_PROFILE_TYPE_NOT_SET=y
diff -rw /home/burt/6431.central_uart/boards/nrf9160dk_nrf9160_ns.overlay boards/nrf9160dk_nrf9160_ns.overlay
1c1
< #include <nrf9160dk_nrf52840_reset_on_if5.dtsi>
> #include <nrf9160/nrf9160dk_nrf52840_reset_on_if5.dtsi>
6a7,8
>         zephyr,bt-hci = &bt_hci_uart;
26a29,34
>               //following 4 lines are added from lte_ble_gateway
>                 bt_hci_uart: bt_hci_uart {
>                         compatible = "zephyr,bt-hci-uart";
>                         status = "okay";
Thank you for help with this. Note that I am testing with my external custom nRF52832 board off. That board runs bluetooth/samples/peripheral_uart normally.
Burt Silverman
