nRF9151 doesn't flash anymore
Hello I'm working on a nRF9151 DK using nRF Connect plugin for VC.
I was able to program and run my  without any problem... but then suddenly the flash process stopped to work.
On VC console I get:
-- west flash: rebuilding
[0/5] Performing build step for 'dtls_upload'
[0/14] Performing build step for 'tfm'
ninja: no work to do.
[4/5] cmd.exe /C "cd /D C:\ncs\MyApp\dtls_upload\build\_sysbuild && C:\ncs\toolchains\b8b84efebd\opt\bin\cmake.exe -E true"
-- west flash: using runner nrfutil
-- runners.nrfutil: reset after flashing requested
-- runners.nrfutil: Flashing file: C:\ncs\MyApp\dtls_upload\build\merged.hex
Error: One or more batch tasks failed:
 * 1051290792: Timed out waiting for response from worker. (Generic)
FATAL ERROR: command exited with status 1: nrfutil --json device x-execute-batch --batch-path 'C:\ncs\MyApp\dtls_upload\build\generated_nrfutil_batch.json' --serial-number 1051290792
 *  The terminal process terminated with exit code: 1.
 *  Terminal will be reused by tasks, press any key to close it.
I tried to reset the status using  nRF Connect Desktop -> Programmer -> reset but the status of nRF9151 seems to be unrecoverable:
06:52:43.602	Initialising the bundled nrfutil device
06:52:43.736	Using the bundled core version for nrfutil device: 8.0.0
06:52:43.769	Using nrfutil-device version: 2.12.3
06:52:43.769	Using nrf-device-lib version: 0.17.81
06:52:43.769	Using nrf-probe version: 0.40.1
06:52:43.769	Using JLink version: JLink_V8.84
06:52:43.770	Your version of SEGGER J-Link (8.84) is newer than the one this app was tested with (8.18). The tested version is not required, and your J-Link version will most likely work fine. If you get issues related to J-Link with your devices, use the tested version.
06:52:43.782	Getting serial port options from the persistent store for 001051290792.pc-nrfconnect-programmer
06:52:43.782	Device connected with the serial number 001051290792
06:52:46.031	Selecting device with the serial number 001051290792
06:53:00.383	Error: Failed with exit code 1. One or more device info tasks failed: * 1051290792: Timed out waiting for response from worker. (Generic) Message: Operation device-info failed, Timed out waiting for response from worker.
06:53:00.383	Selected device with the serial number 001051290792
06:53:00.383	Using nrfutil device to communicate with target via JLink
06:53:03.334	Device connected with the serial number 001051290792
06:53:03.509	Error: Failed with exit code 1. One or more device info tasks failed: * 1051290792: Timed out waiting for response from worker. (Generic) Message: Operation device-info failed, Timed out waiting for response from worker.
06:53:03.588	Reading readback protection status for Application core
06:53:03.588	Failed "reading readback protection status for application core". Error: code: 1, description: Generic, message: Batch task protection-get failed, Emulator error: Failed to open connection
06:53:03.596	Error: Failed with exit code 1. One or more batch tasks failed: * 1051290792: Emulator error: Failed to open connection (Generic) Message: Batch task protection-get failed, Emulator error: Failed to open connection.
06:53:03.702	Error: Failed with exit code 1. No devices with requested serial number(s) or trait(s) found
06:53:04.283	Getting serial port options from the persistent store for 001051290792.pc-nrfconnect-programmer
06:53:04.283	Device connected with the serial number 001051290792
Please, help me to come out form this blocking status.
Thanks, Joel
