S132 nrfutil DFU package generation
Hello everyone,
I'm having trouble with nrfutil (python version from github.com/.../pc-nrfutil). Here is the command line I use:
$ nrfutil dfu genpkg --application app_debug.hex --application-version 9 --bootloader bootloader_debug.hex --sd-req 0x6D,0x00 --softdevice s132_nrf52_1.0.0-3.alpha_softdevice.hex --dev-revision 1 dfu_debug.zip
Using the generated zip package, I can load the SD on the device but the problem is it's loaded at 0x5000 (0x3000 (MBR) + 0x2000). When I look into the sd_bl.bin file generated, I can see the 0x2000 offset (hexdump) :
0000000 ffff ffff ffff ffff ffff ffff ffff ffff
0002000 21f0 2000 d5c9 0001 41e1 0000 d527 0001
0002010 41e1 0000 41e1 0000 41e1 0000 0000 0000
0x2000 is also the SOFTDEVICE_INFO_STRUCT_OFFSET.
Is everything normal so far?
I checked dfu_types.h etc and it looks okay. I want to make sure that the generated binary is correct before continuing the investigations..
Thanks!
