FLASH overflow when merging AWS IoT MQTT sample into existing project (TF-M overflow issue)
We have an existing nRF91 (nRF9151) project (NCS 2.9.0) that already includes multiple modules such as ECG, external flash, RTC, modem, etc.
Now we want to integrate AWS IoT MQTT functionality directly into our main application.
Since our original project did not have a prj.conf for AWS IoT, we manually merged the Kconfig and options from the aws_iot_mqtt sample into our existing configuration.
The project builds until TF-M, but after merging AWS configs, the build fails with a FLASH overflow inside TF-M
EMPTY_0:
  address: 0xc000
  end_address: 0x10000
  placement:
    before:
    - mcuboot_pad
  region: flash_primary
EMPTY_1:
  address: 0xfe000
  end_address: 0x100000
  placement:
    after:
    - nvs_storage
EMPTY_2:
  address: 0xf0000
  end_address: 0xf8000
  placement:
    after:
    - mcuboot_secondary
app:
  address: 0x18000
  end_address: 0x80000
mcuboot:
  address: 0x0
  end_address: 0xc000
  placement:
    align:
      end: 0x1000
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0x10000
  end_address: 0x10200
  placement:
    align:
      start: 0x8000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0x10000
  orig_span: &id001
  - mcuboot_pad
  - app
  - tfm
  sharers: 0x1
  span: *id001
mcuboot_primary_app:
  address: 0x10200
  orig_span: &id002
  - app
  - tfm
  span: *id002
mcuboot_secondary:
  address: 0x80000
  end_address: 0xf0000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x8000
  share_size:
  - mcuboot_primary
mcuboot_sram:
  address: 0x20000000
  end_address: 0x20008000
  orig_span: &id003
  - tfm_sram
  region: sram_primary
  span: *id003
nonsecure_storage:
  address: 0xf8000
  end_address: 0xfe000
  orig_span: &id004
  - nvs_storage
  span: *id004
nrf_modem_lib_ctrl:
  address: 0x20008000
  end_address: 0x200084e8
  inside:
  - sram_nonsecure
  placement:
    after:
    - tfm_sram
    - start
nrf_modem_lib_rx:
  address: 0x2000a568
  end_address: 0x2000c568
  inside:
  - sram_nonsecure
  placement:
    after:
    - nrf_modem_lib_tx
nrf_modem_lib_sram:
  address: 0x20008000
  orig_span: &id005
  - nrf_modem_lib_ctrl
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id005
nrf_modem_lib_tx:
  address: 0x200084e8
  end_address: 0x2000a568
  inside:
  - sram_nonsecure
  placement:
    after:
nvs_storage:
  address: 0xf8000
  inside:
  - nonsecure_storage
  placement:
    align:
      start: 0x8000
    before:
    - end
otp:
  address: 0xff8108
  end_address: 0xff83fc
  region: otp
sram_nonsecure:
  address: 0x20008000
  end_address: 0x20040000
  orig_span: &id006
  - sram_primary
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id006
sram_primary:
  address: 0x2000c568
sram_secure:
  address: 0x20000000
  orig_span: &id007
  - tfm_sram
  span: *id007
tfm:
  address: 0x10200
  end_address: 0x18000
  inside:
  placement:
    before:
    - app
tfm_nonsecure:
  address: 0x18000
  orig_span: &id008
  - app
  span: *id008
tfm_secure:
  address: 0x10000
  orig_span: &id009
  - mcuboot_pad
  - tfm
  span: *id009
tfm_sram:
  address: 0x20000000
  inside:
  - sram_secure
  placement:
    after:
    - start
# log
CONFIG_LOG=y
CONFIG_LOG_MODE_DEFERRED=y # for non-bloking mode
CONFIG_LOG_BUFFER_SIZE=4096
CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=10
CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=2048
CONFIG_CBPRINTF_FP_SUPPORT=y
# LOG ON RTT NOT UART0
CONFIG_CONSOLE=n #for wifi uart keep this n
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_UART_CONSOLE=n
# stack_size
# CONFIG_MAIN_STACK_SIZE=14336
CONFIG_MAIN_STACK_SIZE=6144
# by default 2048
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=5120
# clock
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=n
# configuration of i2c and spi
CONFIG_I2C=y
CONFIG_SPI=y
CONFIG_SENSOR=y
# tfm disable for use uart1 as spi1
CONFIG_TFM_SECURE_UART=n
CONFIG_TFM_LOG_LEVEL_SILENCE=y
# configuration for LIS2DW12
# CONFIG_LIS2DW12=y
# CONFIG_LIS2DW12_TRIGGER_GLOBAL_THREAD=y
# CONFIG_LIS2DW12_THRESHOLD=y
CONFIG_LIS2DW12=y
CONFIG_LIS2DW12_TAP=y
CONFIG_LIS2DW12_TRIGGER_OWN_THREAD=y
# configuration for hw id
CONFIG_HW_ID_LIBRARY=y
CONFIG_HW_ID_LIBRARY_SOURCE_DEVICE_ID=y
# configuration for fuel gauge npm1300
CONFIG_REGULATOR=y
CONFIG_NRF_FUEL_GAUGE=y
CONFIG_LED=y
# Date and time configuration
CONFIG_DATE_TIME=y
CONFIG_DATE_TIME_UPDATE_INTERVAL_SECONDS=0
CONFIG_DATE_TIME_TOO_OLD_SECONDS=0
CONFIG_DATE_TIME_NTP=y
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS=y
# for nand flash
CONFIG_DISK_ACCESS=y
# systemoff
CONFIG_PM_DEVICE=y
CONFIG_POWEROFF=y
CONFIG_DISABLE_FLASH_PATCH=y
# json
CONFIG_CJSON_LIB=y
# siw917y uart
CONFIG_SERIAL=y
CONFIG_UART_ASYNC_API=y
CONFIG_UART_0_INTERRUPT_DRIVEN=y
CONFIG_UART_0_ASYNC=y
CONFIG_NRFX_UARTE0=y
# nvs
CONFIG_NVS=y
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_FLASH_PAGE_LAYOUT=y
# Enable mcumgr DFU in application
# Enable MCUMGR
CONFIG_MCUMGR=y
# Enable MCUMGR management for both OS and Images
CONFIG_MCUMGR_GRP_OS=y
CONFIG_MCUMGR_GRP_IMG=y
# Configure MCUMGR transport to UART
CONFIG_MCUMGR_TRANSPORT_UART=y
# Dependencies
# Configure dependencies for CONFIG_MCUMGR
CONFIG_NET_BUF=y
CONFIG_ZCBOR=y
CONFIG_CRC=y
# Configure dependencies for CONFIG_MCUMGR_GRP_IMG
CONFIG_IMG_MANAGER=y
# Configure dependencies for CONFIG_IMG_MANAGER
CONFIG_STREAM_FLASH=y
# Configure dependencies for CONFIG_MCUMGR_TRANSPORT_UART
CONFIG_BASE64=y
CONFIG_REBOOT=y
CONFIG_DFU_TARGET=y
CONFIG_DFU_TARGET_MCUBOOT=y
#_________________cellular_part_started_______________________
CONFIG_AWS_IOT_LOG_LEVEL_DBG=y
CONFIG_AWS_TEST_SUITE_DQP=n
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_ENTROPY_GENERATOR=y
CONFIG_TEST_RANDOM_GENERATOR=y
CONFIG_INIT_STACKS=y
CONFIG_HW_STACK_PROTECTION=y
CONFIG_REQUIRES_FULL_LIBC=y
CONFIG_SNTP=y
CONFIG_JSON_LIBRARY=y
CONFIG_POSIX_API=y
# DNS
CONFIG_DNS_RESOLVER=y
CONFIG_DNS_RESOLVER_ADDITIONAL_BUF_CTR=2
CONFIG_DNS_RESOLVER_MAX_SERVERS=1
CONFIG_DNS_SERVER_IP_ADDRESSES=y
CONFIG_DNS_SERVER1="8.8.8.8"
CONFIG_NET_SOCKETS_DNS_TIMEOUT=5000
CONFIG_DNS_RESOLVER_LOG_LEVEL_DBG=n
# Generic networking options
CONFIG_NETWORKING=y
CONFIG_NET_UDP=y
CONFIG_NET_TCP=y
CONFIG_NET_IPV6=y
CONFIG_NET_IPV4=y
CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
# Logging
CONFIG_LOG=y
# Network buffers
CONFIG_NET_PKT_RX_COUNT=32
CONFIG_NET_PKT_TX_COUNT=16
CONFIG_NET_BUF_RX_COUNT=64
CONFIG_NET_BUF_TX_COUNT=32
# MQTT
CONFIG_MQTT_LIB=y
CONFIG_MQTT_LIB_TLS=y
CONFIG_MQTT_KEEPALIVE=600
CONFIG_MQTT_LIB_TLS_USE_ALPN=y
# TLS
CONFIG_NRF_SECURITY=y
CONFIG_MBEDTLS_TLS_LIBRARY=y
CONFIG_MBEDTLS_LEGACY_CRYPTO_C=y
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_HEAP_SIZE=4096
CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=8192
CONFIG_MBEDTLS_PEM_CERTIFICATE_FORMAT=y
CONFIG_MBEDTLS_SERVER_NAME_INDICATION=y
CONFIG_MBEDTLS_AES_ROM_TABLES=y
CONFIG_MBEDTLS_TLS_VERSION_1_2=y
CONFIG_MBEDTLS_MEMORY_DEBUG=y
CONFIG_MBEDTLS_HAVE_TIME_DATE=y
CONFIG_MBEDTLS_SSL_ALPN=y
CONFIG_MBEDTLS_SSL_CLI_C=y
CONFIG_MBEDTLS_X509_CRT_PARSE_C=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED=y
CONFIG_MBEDTLS_KEY_EXCHANGE_PSK_ENABLED=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_PSK_ENABLED=y
CONFIG_MBEDTLS_SSL_SRV_C=y
CONFIG_MBEDTLS_KEY_EXCHANGE_RSA_ENABLED=y
CONFIG_HEAP_MEM_POOL_SIZE=8192
CONFIG_MBEDTLS_CIPHER=y
CONFIG_MBEDTLS_MD=y
# Required mbedTLS dependencies
CONFIG_MBEDTLS_PK_C=y
CONFIG_MBEDTLS_PK_PARSE_C=y
CONFIG_MBEDTLS_PK_WRITE_C=y
CONFIG_MBEDTLS_RSA_C=y
CONFIG_MBEDTLS_PKCS1_V15=y
CONFIG_MBEDTLS_ECP_C=y
CONFIG_MBEDTLS_ECDSA_C=y
CONFIG_MBEDTLS_ECDH_C=y
CONFIG_MBEDTLS_DHM_C=y
CONFIG_MBEDTLS_GCM_C=y
CONFIG_MBEDTLS_SHA256_C=y
CONFIG_MBEDTLS_X509_USE_C=y
CONFIG_MBEDTLS_SSL_CONTEXT_SERIALIZATION=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y
CONFIG_CONSOLE=n
CONFIG_NRF_MODEM_LIB=y
CONFIG_LTE_LINK_CONTROL=y
# Let the modem handle sockets, DNS, and SNTP
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_SNTP_LOG_LEVEL_DBG=y
CONFIG_MQTT_HELPER_SEC_TAG=212
# Copyright (c) 2023 Lucas Dietrich <[email protected]>
menu "AWS"
mainmenu "AWS IoT Core MQTT sample application"
config AWS_ENDPOINT
	string "AWS endpoint"
	default ""
	help
	  Endpoint (hostname) of the AWS MQTT broker.
	  Note that the endpoint is different when using AWS Device Advisor.
config AWS_MQTT_PORT
	int "MQTT Port"
	default 8883
	help
	  Set port of AWS MQTT broker.
config AWS_THING_NAME
	string "AWS Thing name"
	default "myThingName"
	help
	  Set the AWS Thing name created on IoT Console
config AWS_SUBSCRIBE_TOPIC
	string "MQTT subscribe topic"
	default "myThingName/downlink"
	help
	  MQTT topic the client should subscribe to.
config AWS_PUBLISH_TOPIC
	string "MQTT publish topic"
	default "myThingName/data"
	help
	  MQTT topic the client should publish to.
choice AWS_TEST_SUITE
	prompt "Device Advisor test suite"
	default AWS_TEST_SUITE_NONE
	help
	  Select the AWS Device Advisor test suite to run.
config AWS_TEST_SUITE_NONE
	bool "No test suite running"
config AWS_TEST_SUITE_DQP
	bool "Device Qualification Program (DQP)"
	help
	  Make sure your region supports AWS Device Advisor for DQP
config AWS_TEST_SUITE_RECV_QOS1
	bool "Test suite for receiving QoS 1 messages"
	help
	  For single test case "MQTT Client Puack QoS1"
endchoice
config AWS_QOS
	int "MQTT QoS"
	default 0 if AWS_TEST_SUITE_DQP
	default 1 if AWS_TEST_SUITE_RECV_QOS1
	default 0
	range 0 1
	help
	  Quality of Service to use for publishing and subscribing to topics.
	  Notes:
	  	- Use QoS 0 when passing DQP test suite
	  	- QoS 2 is not supported by AWS MQTT broker
config AWS_EXPONENTIAL_BACKOFF
	bool "enable exponential backoff"
	default n if AWS_TEST_SUITE_DQP || AWS_TEST_SUITE_RECV_QOS1
	default y
	help
	  Enable AWS exponential backoff for reconnecting to AWS MQTT broker.
endmenu
source "Kconfig.zephyr"
 * Copyright (C) 2023 Nordic Semiconductor ASA
 #include <dt-bindings/regulator/npm1300.h>
 #include <zephyr/dt-bindings/input/input-event-codes.h>
 &gpio0 {status = "okay";};
 &i2c0 {status = "disabled";};
 &i2c1 {status = "disabled";};
 &spi0 {status = "disabled";};
 &spi2 {status = "disabled";};
 &pwm0 {status = "disabled";};
 // &led1 {status = "disabled";};
 // &led2 {status = "disabled";};
 // &led3 {status = "disabled";};
 &uart1 {status = "disabled";};
 &button0 {status = "disabled";};
 &button1 {status = "disabled";};
     chosen {
         /delete-property/ zephyr,console;
         zephyr,uart-mcumgr = &uart0;
     leds {
         compatible = "gpio-leds";
         led2: led_2 {
             gpios = <&gpio0 3 GPIO_ACTIVE_HIGH>;
             label = "Green LED 3";
         led3: led_3 {
             gpios = <&gpio0 4 GPIO_ACTIVE_HIGH>;
             label = "Green LED 4";
     buttons {
         button4: button_4 {
             gpios = <&gpio0 2 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>;
         button5: button_5 {
             gpios = <&gpio0 5 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
         sil23: sil_23 {
             gpios = <&gpio0 23 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
         sil24: sil_24 {
             gpios = <&gpio0 24 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
         fl_hld: fl_hld_1 {
             gpios = <&gpio0 10 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
         fl_wp: fl_wp_1 {
             gpios = <&gpio0 7 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
         // buck: buck_1 {
         //     gpios = <&gpio0 1 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
     aliases {
         sw4 = &button4; //for rtc interrupt
         sw5 = &button5; //for wifi interrupt
         sw6 = &sil23; //for wifi
         sw7 = &sil24; //for wifi interrupt
         sw8 = &fl_hld; //for wifi interrupt
         sw9 = &fl_wp; //for wifi interrupt
         // sw10 = &buck; //for wifi interrupt
         lis2dw12 = &lis2dw12;
         max30001g = &max30001g;
 &pinctrl {
     uart0_default: uart0_default {
         group1 {
             psels = <NRF_PSEL(UART_TX, 0, 27)>;
         group2 {
             psels = <NRF_PSEL(UART_RX, 0, 26)>;
             bias-pull-up;
     uart0_sleep: uart0_sleep {
         group1 {
             psels = <NRF_PSEL(UART_TX, 0, 27)>,
             low-power-enable;
     i2c2_default {
         group1 {
             /delete-property/ bias-pull-up;
     spi1_default: spi1_default {
         group1 {
             psels = <NRF_PSEL(SPIM_SCK, 0, 16)>,
                     <NRF_PSEL(SPIM_MISO, 0, 29)>,
                     <NRF_PSEL(SPIM_MOSI, 0, 28)>;
             nordic,drive-mode = <NRF_DRIVE_H0H1>;
     spi1_sleep: spi1_sleep {
         group1 {
             low-power-enable;
 &uart0 {
     current-speed = <115200>;
 &i2c2 {
     status = "okay";
     lis2dw12: lis2dw12@19 {
         compatible = "st,lis2dw12";
         reg = <0x19>;
         label = "LIS2DW12";
         irq-gpios = <&gpio0 8 (GPIO_ACTIVE_HIGH|GPIO_PULL_UP)>,
                     <&gpio0 9 (GPIO_ACTIVE_HIGH)>;
         odr = <100>; /* Set Output Data Rate to 100Hz (adjust as needed) */
         range = <2>; /* ±2g sensitivity */
         power-mode = <4>; /* High-performance mode */
         bw-filt = <0>; /* Set digital filter bandwidth to ODR/2 */
         tap-mode = <1>; /* Enable both single and double tap detection */
         tap-threshold = <12 12 12>; /* Set X, Y, Z tap threshold (adjust as needed) */
         tap-shock = <1>; /* Tap shock duration */
         tap-latency = <3>; /* Time between two taps for double tap detection */
         tap-quiet = <1>; /* Quiet time after a tap */
         wakeup-duration = <3>; /* Wakeup duration = 4 ODR cycles (adjust as needed) */
 &i2c2 {
     status = "okay";
     max31341: max31341@69 {
         compatible = "i2c-device";
         reg = <0x69>;
 &arduino_i2c {
     npm1300_ek_pmic: pmic@6b {
         compatible = "nordic,npm1300";
         reg = <0x6b>;
         npm1300_ek_gpio: gpio-controller {
             compatible = "nordic,npm1300-gpio";
             gpio-controller;
             #gpio-cells = <2>;
             ngpios = <5>;
         npm1300_ek_regulators: regulators {
             compatible = "nordic,npm1300-regulator";
             npm1300_ek_buck1: BUCK1 {
                 // regulator-min-microvolt = <3300000>;
                 // regulator-max-microvolt = <3300000>;
                 // regulator-init-microvolt = <3300000>;
                 regulator-min-microvolt = <1800000>;
                 regulator-max-microvolt = <1800000>;
                 regulator-init-microvolt = <1800000>;
                 // regulator-always-on; // Optional: Keeps BUCK1 on
             npm1300_ek_buck2: BUCK2 {
                 regulator-min-microvolt = <1000000>;
                 // regulator-min-microvolt = <1800000>;
                 // regulator-max-microvolt = <1800000>;
                 // regulator-init-microvolt = <1800000>;
                 // regulator-always-on; // Optional: Keeps BUCK2 on
                 /delete-property/ enable-gpios;
                 /delete-property/ retention-gpios;
                 /delete-property/ pwm-gpios;
             npm1300_ek_ldo1: LDO1 {
                 regulator-initial-mode = <NPM1300_LDSW_MODE_LDSW>;
             npm1300_ek_ldo2: LDO2 {
         npm1300_ek_charger: charger {
             compatible = "nordic,npm1300-charger";
             term-microvolt = <3600000>;
             term-warm-microvolt = <4000000>;
             current-microamp = <150000>;
             dischg-limit-microamp = <1000000>;
             vbus-limit-microamp = <500000>;
             thermistor-ohms = <10000>;
             thermistor-beta = <3380>;
             charging-enable;
         npm1300_ek_buttons: buttons {
             compatible = "gpio-keys";
             pmic_button0: pmic_button_0 {
                 gpios = <&npm1300_ek_gpio 0 GPIO_ACTIVE_HIGH>;
                 label = "Pmic button switch 0";
                 zephyr,code = <INPUT_KEY_0>;
         npm1300_ek_leds: leds {
             compatible = "nordic,npm1300-led";
             nordic,led0-mode = "charging";
             nordic,led1-mode = "host";
             nordic,led2-mode = "host";
 &spi1 {
     clock-frequency = <DT_FREQ_M(12)>;
     status = "okay";
     cs-gpios = <&gpio0 17 GPIO_ACTIVE_LOW>;
     pinctrl-0 = <&spi1_default>;
     pinctrl-1 = <&spi1_sleep>;
     max30001g: max30001g@0 {
         compatible = "maxim,max30001g";
         status = "okay";
         reg = <0x0>;
         spi-max-frequency = <DT_FREQ_M(12)>;
         ecg-enabled;
         rtor-enabled;
         ecg-dcloff-enable;
         ecg-dcloff-current = <4>;
 &spi3 {
     status = "okay";
     clock-frequency = <DT_FREQ_M(83)>;
     /delete-property/ cs-gpios;
so please guide us how we solve this issue
best regards
  • Hi Milan,
    It is not clear to me if you managed to build and flash your project successfully or your build failed with the error due to flash overflow? Can you clarify this?
    Dejan
  • merge time we check different scinarios check like
    1) when we we one of paripheral disable that time build but flash is full thats why not boot
    2) when we multiple 2 or 3 paripheral disable that time build flash and boot also
    so my concern is after merge aws_iot_mqtt example to our main code that time our flash is overflow due to above reason as i mantion my firmware is nearly 400KB but partitions.yml dynamically set 384KB thats why flash overflow is final conclusion
    so please guide us how to manage it
  • Hi Milan,
    Can you elaborate on 2 mentioned scenarios?
    Are there any other differences between 2 mentioned scenarios apart from different number of peripherals disabled?
    Dejan
  • here means is
    when one paripheral disable that time my nearly 99% flash use that time not boot and more 2 paripheral disable that time 94% flash usage in primary app usage that time build ,flash,boot successfully
    it means flash overflow issue
    when i secondary app partition remove so primary app total 800KB available and its working with all paripheral my firmware use 400 KB its perfectly working
    so when we primary and secondary parition that time flash overflow after adding this aws_iot_mqtt part it use huge flash usage so any solution for reduce flash usage
  • Hi Milan,
    You could check if there are any unused features and drivers that can be disabled in your application. You could also consider disabling logging. Additionally, you can look at this guide for some hints.
    Dejan
