Die temperature sensor conflict
I’m using an nRF52810 with nRF Connect SDK v2.5.1. I want to read the internal temperature sensor. I started from the LBS sample and added NSMS to report the temperature.
I have a concern after reading these two threads:
SW got stuck during reading internal TEMP sensor
 accessing the nRF5340 temperature sensor
My question is: Is it safe to read the internal temperature sensor from the application as long as I enable CONFIG_TEMP_NRF5_MPSL=y?
I’m not fully sure in which situations MPSL accesses the TEMP peripheral and could cause a conflict. Does MPSL only use the TEMP sensor when LFRC calibration is enabled, or is it used in other cases as well?
Thanks
