Can't use ECDHE_RSA w/o MBEDTLS_LEGACY_CRYPTO_C
To use ECDHE_RSA you need to enable the following Kconfig symbol:
Prompt: ECDHE RSA
Prompt: ECDHE-RSA based ciphersuite modes
Type: bool
Value: n
Direct dependencies (=n):
MBEDTLS_HAS_CIPHER_MODE_CIPHERSUITE_REQUIREMENTS(=y) && MBEDTLS_HAS_ECDH_CIPHERSUITE_REQUIREMENTS(=y) && MBEDTLS_HAS_RSA_CIPHERSUITE_REQUIREMENTS(=n) && MBEDTLS_TLS_LIBRARY(=y) && NRF_SECURITY(=y) (=n)
|| (MBEDTLS_PKCS1_V15(=n) || MBEDTLS_PKCS1_V21(=n)) && MBEDTLS_ECDH_C(=n) && !(NRF_SECURITY(=y) || NORDIC_SECURITY_BACKEND(=n)) && MBEDTLS_BUILTIN(=n) && MBEDTLS_CFG_FILE(=nrf-config.h) = "config-mbedtls.h" && MBEDTLS(=y) (=n)
|| (MBEDTLS_PKCS1_V15(=n) || MBEDTLS_PKCS1_V21(=n)) && MBEDTLS_ECDH_C(=n) && !(NRF_SECURITY(=y) || NORDIC_SECURITY_BACKEND(=n)) && MBEDTLS_BUILTIN(=n) && MBEDTLS_CFG_FILE(=nrf-config.h) = "config-mbedtls.h" && MBEDTLS(=y) && 0 (=n)
This symbol depends on MBEDTLS_HAS_RSA_CIPHERSUITE_REQUIREMENTS:
Type: bool
Value: n
MBEDTLS_RSA_C(=n)
&& MBEDTLS_PKCS1_V15(=n)
&& NRF_SECURITY(=y)
This symbol depends on MBEDTLS_RSA_C:
Prompt: RSA - Rivest-Shamir-Adleman cryptosystem
Prompt: RSA base support
Type: bool
Value: n
Help:
Enable RSA cryptosystem support.
MBEDTLS_RSA_C setting in mbed TLS config file.
OPENTHREAD(=n)
|| MBEDTLS_LEGACY_CRYPTO_C(=n) && NRF_SECURITY(=y) (=n)
Which depends on MBEDTLS_LEGACY_CRYPTO_C.
I saw a similar post created about this  nRF9160: Offloaded sockets can't use MBEDTLS_USE_PSA_CRYPTO with RSA Certificates
However, this affects not only nRF91xx, but also nRF54Lx and potentially other device series.
Question: If I enable MBEDTLS_LEGACY_CRYPTO_C is it going to use it only for RSA (& won't use the PSA API) or for everything else too?
We can compare this with MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED:
Prompt: ECDHE ECDSA
Prompt: ECDHE-ECDSA based ciphersuite modes
Type: bool
Value: y
Direct dependencies (=y):
MBEDTLS_HAS_CIPHER_MODE_CIPHERSUITE_REQUIREMENTS(=y) && MBEDTLS_HAS_ECDH_CIPHERSUITE_REQUIREMENTS(=y) && MBEDTLS_HAS_ECDSA_CIPHERSUITE_REQUIREMENTS(=y) && MBEDTLS_TLS_LIBRARY(=y) && NRF_SECURITY(=y) (=y)
|| ((MBEDTLS_ECDH_C(=n) && MBEDTLS_ECDSA_C(=n)) || (PSA_WANT_ALG_ECDH(=y) && PSA_WANT_ALG_ECDSA(=y))) && !(NRF_SECURITY(=y) || NORDIC_SECURITY_BACKEND(=n)) && MBEDTLS_BUILTIN(=n) && MBEDTLS_CFG_FILE(=nrf-config.h) = "config-mbedtls.h" && MBEDTLS(=y) (=n)
|| ((MBEDTLS_ECDH_C(=n) && MBEDTLS_ECDSA_C(=n)) || (PSA_WANT_ALG_ECDH(=y) && PSA_WANT_ALG_ECDSA(=y))) && !(NRF_SECURITY(=y) || NORDIC_SECURITY_BACKEND(=n)) && MBEDTLS_BUILTIN(=n) && MBEDTLS_CFG_FILE(=nrf-config.h) = "config-mbedtls.h" && MBEDTLS(=y) && 0 (=n)
Type: bool
Value: y
(MBEDTLS_ECP_C(=n) && MBEDTLS_ECDSA_C(=n) && MBEDTLS_SHA256_C(=n)) || (PSA_WANT_ALG_ECDSA(=y) && PSA_WANT_ALG_SHA_256(=y) && MBEDTLS_USE_PSA_CRYPTO(=y)) (=y)
&& NRF_SECURITY(=y)
We can see it's possible to have a combination of options that enable this Kconfig symbol:
  • 1. TLS/DTLS and X.509 making use of RSA requires legacy configurations (Configurations with suffix _C, like MBEDTLS_RSA_C). Support for elliptic curves is better (ECDSA and ECDH). This changes with Mbed TLS 4.0.0 (and TF-PSA-Crypto 1.0.0) when that is introduced in Zephyr and nRF Connect SDK.
    2. Mbed TLS will favor PSA crypto APIs when enabled for as much as possible in TLS/DTLS and X.509. You are not required to enable legacy features as long as check_config.h doesn't complain. The code in TLS/DTLS and X.509 is shaped so that PSA crypto API is called first, and legacy APIs are only used as a SW fallback
    As an example (ECDSA and ECDHE) is dependent on MBEDTLS_CAN_ECDH and MBEDTLS_PK_CAN_ECDSA_SIGN:
    #if defined(MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED) &&                \
        ( !defined(MBEDTLS_CAN_ECDH) ||                                       \
          !defined(MBEDTLS_PK_CAN_ECDSA_SIGN) ||                                \
          !defined(MBEDTLS_X509_CRT_PARSE_C) )
    #error "MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED defined, but not all prerequisites"
    /* Helper symbol to state that there is support for ECDH, either through
     * library implementation (ECDH_C) or through PSA. */
    #if (defined(MBEDTLS_USE_PSA_CRYPTO) && defined(PSA_WANT_ALG_ECDH)) || \
        (!defined(MBEDTLS_USE_PSA_CRYPTO) && defined(MBEDTLS_ECDH_C))
    #define MBEDTLS_CAN_ECDH
    /* PK module can achieve ECDSA functionalities by means of either software
     * implementations (ECDSA_C) or through a PSA driver. The following defines
     * are meant to list these capabilities in a general way which abstracts how
     * they are implemented under the hood. */
    #if !defined(MBEDTLS_USE_PSA_CRYPTO)
    #if defined(MBEDTLS_ECDSA_C)
    #define MBEDTLS_PK_CAN_ECDSA_SIGN
    #define MBEDTLS_PK_CAN_ECDSA_VERIFY
    #endif /* MBEDTLS_ECDSA_C */
    #else /* MBEDTLS_USE_PSA_CRYPTO */
    #if defined(PSA_WANT_ALG_ECDSA)
    #if defined(PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_BASIC)
    #endif /* PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_BASIC */
    #if defined(PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY)
    #endif /* PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY */
    #endif /* PSA_WANT_ALG_ECDSA */
    #endif /* MBEDTLS_USE_PSA_CRYPTO */
  • check_config.h showing that legacy APIs is required in Mbed TLS 3.6.5 (MBEDTLS_RSA_C)
    https://github.com/Mbed-TLS/mbedtls/blob/e185d7fd85499c8ce5ca2a54f5cf8fe7dbe3f8df/include/mbedtls/check_config.h#L347
    mbedtls_check_config.h showing PSA APis are used for Mbed TLS 4.0.0 (PSA_WANT_XXXX):
    github.com/.../mbedtls_check_config.h
  • This is the configuration that worked for me:
    # Enable TLS credentials
    CONFIG_TLS_CREDENTIALS=y
    CONFIG_TLS_CREDENTIALS_BACKEND_VOLATILE=y
    # Cryptography (mbed TLS general)
    CONFIG_NRF_SECURITY=y
    CONFIG_MBEDTLS=y
    CONFIG_MBEDTLS_MD=y
    CONFIG_MBEDTLS_TLS_LIBRARY=y
    CONFIG_MBEDTLS_X509_LIBRARY=y
    CONFIG_MBEDTLS_ENABLE_HEAP=y
    CONFIG_MBEDTLS_HEAP_SIZE=49152
    # Cryptography (mbed TLS options)
    CONFIG_MBEDTLS_SSL_KEEP_PEER_CERTIFICATE=n
    CONFIG_MBEDTLS_SSL_SERVER_NAME_INDICATION=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED=y
    # CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=16384
    CONFIG_MBEDTLS_MPI_MAX_SIZE=512
    # @todo: This is required for 'CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA_ENABLED'.
    CONFIG_MBEDTLS_LEGACY_CRYPTO_C=y
    # PSA API (General)
    CONFIG_MBEDTLS_USE_PSA_CRYPTO=y
    CONFIG_MBEDTLS_PSA_CRYPTO_C=y
    # PSA API (Drivers)
    CONFIG_PSA_CRYPTO_DRIVER_CRACEN=y
    CONFIG_PSA_USE_CRACEN_KEY_MANAGEMENT_DRIVER=y
    CONFIG_PSA_USE_CRACEN_KEY_DERIVATION_DRIVER=y
    CONFIG_PSA_USE_CRACEN_MAC_DRIVER=y
    CONFIG_PSA_USE_CRACEN_CIPHER_DRIVER=y
    CONFIG_PSA_USE_CRACEN_KEY_AGREEMENT_DRIVER=y
    CONFIG_PSA_USE_CRACEN_AEAD_DRIVER=y
    CONFIG_PSA_USE_CRACEN_ASYMMETRIC_SIGNATURE_DRIVER=y
    CONFIG_PSA_USE_CRACEN_ASYMMETRIC_ENCRYPTION_DRIVER=y
    CONFIG_PSA_USE_CRACEN_HASH_DRIVER=y
    # PSA API (Key types)
    CONFIG_PSA_WANT_KEY_TYPE_AES=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_DERIVE=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY=y
    CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT=y
    CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE=y
    CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY=y
    CONFIG_PSA_WANT_KEY_TYPE_HMAC=y
    # PSA API (Algorithms)
    CONFIG_PSA_WANT_ALG_ECDH=y
    CONFIG_PSA_WANT_ALG_HMAC=y
    CONFIG_PSA_WANT_ALG_CCM=y
    CONFIG_PSA_WANT_ALG_GCM=y
    CONFIG_PSA_WANT_ALG_HKDF=y
    CONFIG_PSA_WANT_ALG_TLS12_PRF=y
    CONFIG_PSA_WANT_ALG_ECDSA=y
    CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN=y
    # PSA API (Elliptic curves)
    CONFIG_PSA_WANT_ECC_SECP_R1_256=y
    CONFIG_PSA_WANT_ECC_SECP_R1_384=y
    # PSA API (Random)
    CONFIG_PSA_WANT_GENERATE_RANDOM=y
    CONFIG_PSA_WANT_ALG_CTR_DRBG=y
    # PSA API (Hash algorithms)
    CONFIG_PSA_WANT_ALG_SHA_256=y
    CONFIG_PSA_WANT_ALG_SHA_384=y
    # PSA API (Key sizes)
    CONFIG_PSA_WANT_AES_KEY_SIZE_128=y
    CONFIG_PSA_WANT_AES_KEY_SIZE_256=y
    CONFIG_PSA_WANT_RSA_KEY_SIZE_2048=y
    CONFIG_PSA_WANT_RSA_KEY_SIZE_3072=y
    CONFIG_PSA_WANT_RSA_KEY_SIZE_4096=y
