Dynamically setting the LPCOMP REFSEL
Is there a way to change the LPCOMP reference level in Zephyr other than what is set in the devicetree overlay?
I'm happy to disable it, change it and re-enable it if that's what's needed I just can't see how that can be done through Zephyr.
Example code I currently have is basic, in premise the change I'd like is to go from reference VDD_4_8 to VDD_3_8 when the first reference is passed/a callback is triggered.
Here's the basic code I already have, thank you -
#include <zephyr/drivers/comparator.h>
#include <zephyr/kernel.h>
#include <zephyr/pm/device_runtime.h>
static const struct device *test_dev = DEVICE_DT_GET(DT_ALIAS(test_comp));
static const struct gpio_dt_spec test_pin = GPIO_DT_SPEC_GET(DT_PATH(zephyr_user), test_gpios);
volatile int counter;
static void test_callback(const struct device *dev, void *user_data)
    counter++;
    printk("Comparator triggered, counter=%d\n", counter);
void main(void)
    int rc;
    pm_device_runtime_enable(test_dev);
    pm_device_runtime_get(test_dev);
    rc = comparator_set_trigger_callback(test_dev, test_callback, NULL);
    __ASSERT_NO_MSG(rc == 0);
    rc = comparator_set_trigger(test_dev, COMPARATOR_TRIGGER_FALLING_EDGE);
    counter = 0;
    while (1) {
        __WFE();  // Wait for event (comparator interrupt)
  • Dunno if its documented, but you can just #include <zephyr/drivers/comparator/nrf_lpcomp.h> in your source file.
    This header exposes the functions required to (re-) configure the peripherial. There is another file nrf_lpcomp.h in the same folder for the low power comparator.
  • Thanks, I tried to go down the nrf_lpcomp route but couldn't figure out how to get it to work, only examples I could find were Zephyr, using teh devicetree overlay to set it up. Would you have any examples on how to setup a simple lpcomp with the nrf/nrfx drivers?
    Thanks again
  • Hi Rhys,
    Zephyr driver is not made for dynamically change the  REFSEL. You may need to use what Jorg suggested.
    I found a sample here LPCOMP in NCS-Zephyr on NRF52 It's quite old but I guess you can give it a try.
  • Hi Hung,
    I've got it working now thanks to that thread. Thank you for sharing that.
    Below is a working snippet for anyone else trying to do this (ncs v3.1.1 and NRF54L15)
    No device overlay
    prj.conf simply contains "CONFIG_NRFX_LPCOMP=y"
    Main.c is:
    #include <hal/nrf_lpcomp.h>
    #include <hal/nrf_gpio.h>
    #include <nrfx_lpcomp.h>
    #include <nrfx_gpiote.h>
    #include <nrfx.h>
    static nrfx_lpcomp_config_t config =
        NRFX_LPCOMP_DEFAULT_CONFIG(NRF_GPIO_PIN_MAP(1, 11));
    static nrfx_err_t err;
    static void lpcomp_event_handler(nrf_lpcomp_event_t event)
        if (event == NRF_LPCOMP_EVENT_DOWN) {
            printk("DOWN event! Lowering Threshold...\n");
            // Shutdown LPCOMP to make changes
            nrfx_lpcomp_disable();
            nrfx_lpcomp_uninit();
            // change reference
            config.reference = NRF_LPCOMP_REF_SUPPLY_3_8;
            // clear latched LPCOMP events before re-init
            NRF_LPCOMP->EVENTS_DOWN  = 0;
            NRF_LPCOMP->EVENTS_UP    = 0;
            NRF_LPCOMP->EVENTS_CROSS = 0;
            NRF_LPCOMP->EVENTS_READY = 0;
            err = nrfx_lpcomp_init(&config, lpcomp_event_handler);
            if (err != NRFX_SUCCESS) {
                printk("nrfx_lpcomp_init error: %08x\n", err);
                return;
            nrfx_lpcomp_enable();
    void main(void)
        IRQ_DIRECT_CONNECT(COMP_LPCOMP_IRQn, 5, nrfx_lpcomp_irq_handler, 0);
        // initial configuration
        config.reference = NRF_LPCOMP_REF_SUPPLY_4_8;
        config.detection = NRF_LPCOMP_DETECT_DOWN;
        config.hyst      = NRF_LPCOMP_HYST_ENABLED;
            return;
        printk("LPCOMP initialized\n");
