subsequent build attempts fail
I am developing a project for the Thingy91:X making use of the Asset Tracker Template.
Following the Getting Started guide, I successfully build for the Thingy91:X.
However, the second time I try to build, I get the errors as per the attached file.
Could you please tell me what I am doing wrong.
(v3.1.0) C:\Users\franc\asset-tracker-template\project\app> west build -p -b thingy91x/nrf9151/ns
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: C:/ncs/toolchains/b8b84efebd/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
-- Cache files will be written to: C:/Users/franc/asset-tracker-template/zephyr/.cache
-- Found west (found suitable version "1.4.0", minimum required is "0.14.0")
-- Board: thingy91x, qualifiers: nrf9151/ns
Parsing C:/Users/franc/asset-tracker-template/project/app/Kconfig.sysbuild
Loaded configuration 'C:/Users/franc/asset-tracker-template/project/app/build/_sysbuild/empty.conf'
Merged configuration 'C:/Users/franc/asset-tracker-template/project/app/build/_sysbuild/empty.conf'
Configuration saved to 'C:/Users/franc/asset-tracker-template/project/app/build/zephyr/.config'
Kconfig header saved to 'C:/Users/franc/asset-tracker-template/project/app/build/_sysbuild/autoconf.h'
-- Sysbuild assigned MCUboot image IDs:
   * Application: 0
   * MCUboot b0 update: 1
   * Running CMake for mcuboot *
-- Application: C:/Users/franc/asset-tracker-template/bootloader/mcuboot/boot/zephyr
-- CMake version: 3.21.0
-- Zephyr version: 4.2.99 (C:/Users/franc/asset-tracker-template/zephyr)
CMake Error at C:/Users/franc/asset-tracker-template/zephyr/cmake/modules/hwm_v2.cmake:56 (message):
  Error listing hardware.
  Error message: Traceback (most recent call last):
    File "C:\Users\franc\asset-tracker-template\zephyr\scripts\list_hardware.py", line 348, in <module>
      dump_v2_systems(args)
    File "C:\Users\franc\asset-tracker-template\zephyr\scripts\list_hardware.py", line 333, in dump_v2_systems
      systems = find_v2_systems(args)
    File "C:\Users\franc\asset-tracker-template\zephyr\scripts\list_hardware.py", line 247, in find_v2_systems
      systems.extend(Systems.from_file(soc_yml))
    File "C:\Users\franc\asset-tracker-template\zephyr\scripts\list_hardware.py", line 128, in from_file
      return Systems(str(socs_file.parent), socs_yaml)
    File "C:\Users\franc\asset-tracker-template\zephyr\scripts\list_hardware.py", line-- Configuring incomplete, errors occurred!
 50, in __init__
      SOC_VALIDATOR.validate()
    File "C:\ncs\toolchains\b8b84efebd\opt\bin\Lib\site-packages\pykwalify\core.py", line 183, in validate
      self._start_validate(self.source)
    File "C:\ncs\toolchains\b8b84efebd\opt\bin\Lib\site-packages\pykwalify\core.py", line 230, in _start_validate
      self._validate(value, root_rule, path, done)
    File "C:\ncs\toolchains\b8b84efebd\opt\bin\Lib\site-packages\pykwalify\core.py", line 264, in _validate
      self._validate_mapping(value, rule, path, done=None)
    File "C:\ncs\toolchains\b8b84efebd\opt\bin\Lib\site-packages\pykwalify\core.py", line 604, in _validate_mapping
      self._validate(v, r, u"{0}/{1}".format(path, k), done)
    File "C:\ncs\toolchains\b8b84efebd\opt\bin\Lib\site-packages\pykwalify\core.py", line 612, in _validate_mapping
      self._validate(v, mm[0], "{0}/{1}".format(path, k), done)
    File "C:\ncs\toolchains\b8b84efebd\opt\bin\Lib\site-packages\pykwalify\core.py", line 262, in _validate
      self._validate_sequence(value, rule, path, done=None)
    File "C:\ncs\toolchains\b8b84efebd\opt\bin\Lib\site-packages\pykwalify\core.py", line 380, in _validate_sequence
      tmp_core._validate(item, r, "{0}/{1}".format(path, i), done)
    File "C:\ncs\toolchains\b8b84efebd\opt\bin\Lib\site-packages\pykwalify\core.py", line 375, in _validate_sequence
      tmp_core = Core(source_data={}, schema_data={})
    File "C:\ncs\toolchains\b8b84efebd\opt\bin\Lib\site-packages\pykwalify\core.py", line 74, in __init__
      yml.constructor.add_constructor('tag:yaml.org,2002:python/long', Constructor.construct_python_long)
    File "C:\ncs\toolchains\b8b84efebd\opt\bin\Lib\site-packages\ruamel\yaml\main.py", line 229, in constructor
      attr = '_' + sys._getframe().f_code.co_name
  TypeError: unsupported operand type(s) for +: 'YAML' and 'str'
  C:/Users/franc/asset-tracker-template/zephyr/cmake/modules/zephyr_default.cmake:131 (include)
  C:/Users/franc/asset-tracker-template/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
  C:/Users/franc/asset-tracker-template/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  CMakeLists.txt:18 (find_package)
CMake Error at cmake/modules/sysbuild_extensions.cmake:530 (message):
  CMake configure failed for Zephyr project: mcuboot
  C:/Users/franc/asset-tracker-template/bootloader/mcuboot/boot/zephyr/
  cmake/modules/sysbuild_images.cmake:43 (ExternalZephyrProject_Cmake)
  cmake/modules/sysbuild_default.cmake:21 (include)
  C:/Users/franc/asset-tracker-template/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
  C:/Users/franc/asset-tracker-template/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
  template/CMakeLists.txt:10 (find_package)
See also "C:/Users/franc/asset-tracker-template/project/app/build/CMakeFiles/CMakeOutput.log".
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\b8b84efebd\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/b8b84efebd/opt/bin/python.exe '-BC:\Users\franc\asset-tracker-template\project\app\build' -GNinja -DBOARD=thingy91x/nrf9151/ns '-SC:\Users\franc\asset-tracker-template\zephyr\share\sysbuild' '-DAPP_DIR:PATH=C:\Users\franc\asset-tracker-template\project\app'
