Encrypted DFU on 5340
I'm stuck implementing encrypted firmwares on the nrf5340, ncs 3.0.2., with NSIB and MCUBoot.
I got signed DFU to work as described in Exercise 3 – DFU with external flash.
However, as soon as I also enable encryption by setting
SB_CONFIG_BOOT_ENCRYPTION_KEY_FILE="\${APP_DIR}/firmware-encryption-key.pem"
SB_CONFIG_BOOT_ENCRYPTION=y
in sysbuild.conf
I get compilation errors, starting with
fatal error: tinycrypt/aes.h: No such file or directory
I've also added
CONFIG_BOOT_ECDSA_TINYCRYPT=y
to sysbuild/mcuboot.conf, but to no avail.
  • Still looks like the same behavior to me.
    Here's the configuration when merged like this:
    prj.conf:
    CONFIG_APP_LOG_LEVEL_DBG=y
    CONFIG_ASSERT=n
    CONFIG_BASE64=y
    CONFIG_BT_MESH_SHELL=n
    CONFIG_COAP_SERVER_SHELL=n
    CONFIG_COMPILER_OPT="-Wall"
    CONFIG_COMPILER_WARNINGS_AS_ERRORS=y
    CONFIG_CPP=y
    CONFIG_CRC=y
    CONFIG_DEBUG_OPTIMIZATIONS=n
    CONFIG_FLASH_INIT_PRIORITY=40
    CONFIG_FLASH_MAP=y
    CONFIG_FLASH=y
    CONFIG_GLIBCXX_LIBCPP=y
    CONFIG_IMG_MANAGER=y
    CONFIG_INIT_STACKS=y
    CONFIG_ISR_TABLES_LOCAL_DECLARATION=y
    CONFIG_KERNEL_SHELL=n
    CONFIG_LOG_BACKEND_SHOW_COLOR=y
    CONFIG_LOG_BACKEND_UART=y
    CONFIG_LOG_DEFAULT_LEVEL=2
    CONFIG_LOG=y
    CONFIG_LTO=y
    CONFIG_MAIN_STACK_SIZE=3072
    CONFIG_MAIN_THREAD_PRIORITY=-2
    CONFIG_MCUMGR_GRP_IMG=y
    CONFIG_MCUMGR_GRP_OS=y
    CONFIG_MCUMGR_TRANSPORT_UART=y
    CONFIG_MCUMGR=y
    CONFIG_NET_BUF=y
    CONFIG_NET_SHELL=n
    CONFIG_NORDIC_QSPI_NOR_XIP=y
    CONFIG_NORDIC_QSPI_NOR=y
    CONFIG_NVS=y
    CONFIG_REBOOT=y
    CONFIG_SETTINGS=y
    CONFIG_SHELL=n
    CONFIG_SIZE_OPTIMIZATIONS=y
    CONFIG_STD_CPP20=y
    CONFIG_STREAM_FLASH=y
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2560
    CONFIG_TFM_PARTITION_INITIAL_ATTESTATION=n
    CONFIG_TFM_PARTITION_PROTECTED_STORAGE=n
    CONFIG_TFM_PROFILE_TYPE_MEDIUM=y
    CONFIG_THREAD_MONITOR=n
    CONFIG_THREAD_NAME=n
    CONFIG_THREAD_STACK_INFO=n
    CONFIG_UART_CONSOLE=y
    CONFIG_XIP=y
    CONFIG_ZCBOR=y
    sysbuild.conf:
    SB_CONFIG_NETCORE_IPC_RADIO=y
    SB_CONFIG_NETCORE_IPC_RADIO_BT_HCI_IPC=y
    SB_CONFIG_NETCORE_IPC_RADIO_BT_RPC=n
    SB_CONFIG_NETCORE_IPC_RADIO_IEEE802154=n
    SB_CONFIG_SECURE_BOOT_APPCORE=y
    SB_CONFIG_BOOTLOADER_MCUBOOT=y
    SB_CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
    SB_CONFIG_SECURE_BOOT_SIGNING_KEY_FILE="\${APP_DIR}/firmware-signing-key.pem"
    SB_CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y
    sysbuild/mcuboot.conf:
    CONFIG_BOOT_MAX_IMG_SECTORS=256
    CONFIG_BOOT_PREFER_SWAP_MOVE=n
    CONFIG_BOOT_PREFER_SWAP_OFFSET=y
    CONFIG_BOOT_SERIAL_UART=y
    CONFIG_BOOT_SWAP_USING_MOVE=n
    CONFIG_BOOT_SWAP_USING_OFFSET=y
    CONFIG_LOG=y
    CONFIG_MCUBOOT_INDICATION_LED=y
    CONFIG_MCUBOOT_LOG_LEVEL_INF=y
    CONFIG_MCUBOOT_SERIAL=y
    CONFIG_UART_CONSOLE=n
    build_nrf5340dk_help/mcuboot/zephyr/.config:
    # CONFIG_BOOT_SIGNATURE_TYPE_NONE is not set
    # CONFIG_BOOT_SIGNATURE_TYPE_RSA is not set
    # CONFIG_BOOT_ECDSA_TINYCRYPT is not set
    # CONFIG_BOOT_SIGNATURE_TYPE_ED25519 is not set
    CONFIG_BOOT_ENCRYPTION_SUPPORT=y
    CONFIG_BOOT_ENCRYPT_IMAGE=y
    CONFIG_BOOT_ENCRYPT_EC256=y
    CONFIG_BOOT_ENCRYPTION_KEY_FILE="…/app/firmware-encryption-key.pem"
    Build log
    (v3.0.2) HC709JKT7R% rm -rf app/build_nrf5340dk_help && west build --board nrf5340dk/nrf5340/cpuapp/ns --build-dir app/build_nrf5340dk_help app
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: /opt/nordic/ncs/toolchains/ef4fc6722e/opt/[email protected]/bin/python3.12 (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: $HOME/Library/Caches/zephyr
    -- Board: nrf5340dk, qualifiers: nrf5340/cpuapp/ns
    Parsing $WORKSPACE/zephyr/share/sysbuild/Kconfig
    Loaded configuration '$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/_sysbuild/empty.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/sysbuild.conf'
    Configuration saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/zephyr/.config'
    Kconfig header saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/_sysbuild/autoconf.h'
       * Running CMake for mcuboot *
    -- Application: $WORKSPACE/bootloader/mcuboot/boot/zephyr
    -- CMake version: 3.21.0
    -- Found Python3: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/python (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Zephyr version: 4.0.99 ($WORKSPACE/zephyr)
    -- Found host-tools: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk)
    -- Found Dtc: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
    -- Found BOARD.dts: $WORKSPACE/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp.dts
    -- Found devicetree overlay: $WORKSPACE/$PROJECT/app/sysbuild/mcuboot.overlay
    -- Generated zephyr.dts: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/mcuboot/zephyr/zephyr.dts
    -- Generated pickled edt: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/mcuboot/zephyr/edt.pickle
    -- Generated devicetree_generated.h: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/mcuboot/zephyr/dts.cmake
    Parsing $WORKSPACE/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration '$WORKSPACE/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp_defconfig'
    Merged configuration '$WORKSPACE/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/sysbuild/mcuboot.conf'
    Merged configuration '$WORKSPACE/nrf/modules/mcuboot/tfm.conf'
    Merged configuration '$WORKSPACE/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf'
    Merged configuration '$WORKSPACE/nrf/subsys/bootloader/image/log_minimal.conf'
    Merged configuration '$WORKSPACE/bootloader/mcuboot/boot/zephyr/external_crypto.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/mcuboot/zephyr/.config.sysbuild'
    Configuration saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/mcuboot/zephyr/.config'
    Kconfig header saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
    -- Found assembler: /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    -- Using ccache: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/ccache
    CMake Warning at $WORKSPACE/zephyr/CMakeLists.txt:1002 (message):
      No SOURCES given to Zephyr library: drivers__console
      Excluding target from build.
    MCUBoot bootloader key file: $WORKSPACE/bootloader/mcuboot/root-ec-p256.pem
    CMake Warning at CMakeLists.txt:393 (message):
      WARNING: Using default MCUboot signing key file, this file is for debug use
      only and is not secure!
    MCUBoot bootloader encryption key file: $WORKSPACE/$PROJECT/app/firmware-encryption-key.pem
    -- Configuring done
    -- Generating done
    -- Build files have been written to: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/mcuboot
       * Running CMake for ipc_radio *
    -- Application: $WORKSPACE/nrf/applications/ipc_radio
    -- Board: nrf5340dk, qualifiers: nrf5340/cpunet
    -- Found BOARD.dts: $WORKSPACE/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpunet.dts
    -- Generated zephyr.dts: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/ipc_radio/zephyr/zephyr.dts
    -- Generated pickled edt: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/ipc_radio/zephyr/edt.pickle
    -- Generated devicetree_generated.h: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/ipc_radio/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/ipc_radio/zephyr/dts.cmake
    Parsing $WORKSPACE/nrf/applications/ipc_radio/Kconfig
    Loaded configuration '$WORKSPACE/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpunet_defconfig'
    Merged configuration '$WORKSPACE/$PROJECT/app/sysbuild/ipc_radio/prj.conf'
    Merged configuration '$WORKSPACE/nrf/applications/ipc_radio/overlay-bt_hci_ipc.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/ipc_radio/zephyr/.config.sysbuild'
    Configuration saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/ipc_radio/zephyr/.config'
    Kconfig header saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/ipc_radio/zephyr/include/generated/zephyr/autoconf.h'
    -- libmetal version: 1.7.0 ($WORKSPACE/nrf/applications/ipc_radio)
    -- Build type:
    -- Host:    Darwin/arm64
    -- Target:  Generic/arm
    -- Machine: arm
    -- Vendor: none
    -- Looking for include file stdatomic.h
    -- Looking for include file stdatomic.h - found
    -- open-amp version: 1.7.0 ($WORKSPACE/modules/lib/open-amp/open-amp)
    -- Machine: arm
    -- C_FLAGS :  -Wall -Wextra
    -- Looking for include file fcntl.h
    -- Looking for include file fcntl.h - found
    CMake Warning at $WORKSPACE/zephyr/CMakeLists.txt:2180 (message):
    -- Configuring done
    -- Generating done
    -- Build files have been written to: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/ipc_radio
       * Running CMake for b0 *
    -- Application: $WORKSPACE/nrf/samples/bootloader
    -- Generated zephyr.dts: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/b0/zephyr/zephyr.dts
    -- Generated pickled edt: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/b0/zephyr/edt.pickle
    -- Generated devicetree_generated.h: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/b0/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/b0/zephyr/dts.cmake
    Parsing $WORKSPACE/zephyr/Kconfig
    Merged configuration '$WORKSPACE/nrf/samples/bootloader/prj.conf'
    Merged configuration '$WORKSPACE/nrf/samples/bootloader/boards/nrf5340dk_nrf5340_cpuapp.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/b0/zephyr/.config.sysbuild'
    Configuration saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/b0/zephyr/.config'
    Kconfig header saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/b0/zephyr/include/generated/zephyr/autoconf.h'
    -- Configuring done
    -- Generating done
    -- Build files have been written to: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/b0
       * Running CMake for app *
    -- Application: $WORKSPACE/$PROJECT/app
    -- Shield(s): seeed_w5500
    -- Found BOARD.dts: $WORKSPACE/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp_ns.dts
    -- Found devicetree overlay: $WORKSPACE/zephyr/boards/shields/seeed_w5500/seeed_w5500.overlay
    -- Found devicetree overlay: $WORKSPACE/$PROJECT/app/conf/boards/nrf5340dk_nrf5340_cpuapp_ns.overlay
    -- Generated zephyr.dts: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/app/zephyr/zephyr.dts
    -- Generated pickled edt: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/app/zephyr/edt.pickle
    -- Generated devicetree_generated.h: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/app/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/app/zephyr/dts.cmake
    warning: THREAD_STACK_INFO (defined at kernel/Kconfig:189) was assigned the value 'n' but got the
    value 'y'. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_THREAD_STACK_INFO and/or
    look up THREAD_STACK_INFO in the menuconfig/guiconfig interface. The Application Development Primer,
    Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
    helpful too.
    warning: Experimental symbol TFM_EXPERIMENTAL is enabled.
    warning: Experimental symbol COAP_SERVER is enabled.
    Parsing $WORKSPACE/$PROJECT/app/Kconfig
    Loaded configuration '$WORKSPACE/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp_ns_defconfig'
    Merged configuration '$WORKSPACE/$PROJECT/app/conf/prj.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/conf/boards/nrf5340dk_nrf5340_cpuapp_ns.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/conf/bluetooth.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/conf/bluetooth_mesh.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/conf/coap.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/conf/networking.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/app/zephyr/.config.sysbuild'
    Configuration saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/app/zephyr/.config'
    Kconfig header saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/app/zephyr/include/generated/zephyr/autoconf.h'
    =========== Generating psa_crypto_config ===============
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Backup: CONFIG_MBEDTLS_THREADING: False
    Backup: CONFIG_MBEDTLS_THREADING_ALT: False
    =========== Checkpoint: backup ===============
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Restore: CONFIG_MBEDTLS_THREADING: False
    Restore: CONFIG_MBEDTLS_THREADING_ALT: False
    =========== End psa_crypto_config ===============
    =========== Generating psa_crypto_library_config ===============
    Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    =========== End psa_crypto_library_config ===============
    -- libmetal version: 1.7.0 ($WORKSPACE/$PROJECT/app)
    -- Build type:
    -- Machine: arm
    -- Vendor: none
    -- Machine: arm
    -- Including signing script: $WORKSPACE/nrf/cmake/sysbuild/image_signing.cmake
    ### Extracting entry_types from CDDL ###
    ### Extracted entry_types: UuidBytes;UnprovisionedDevice;Device;Actions;Light;LightProperties;OnOff;ScanStatus;DimLevel;TransitionTime;DimCommand;Node;MacBytes;Discovery;AttentionDuration;IdentifyUnprovisionedDevice ###
    ### Generating code from CDDLs via zcbor... ###
    Parsing files: $WORKSPACE/$PROJECT/app/lib/api_cbor/schemas/api_cbor.cddl, $WORKSPACE/$PROJECT/app/lib/api_cbor/../../../../modules/lib/zcbor/zcbor/prelude.cddl
    Writing to $WORKSPACE/$PROJECT/app/lib/api_cbor/autogen/src/api_cbor_decode.c
    Writing to $WORKSPACE/$PROJECT/app/lib/api_cbor/autogen/include/api_cbor_decode.h
    Writing to $WORKSPACE/$PROJECT/app/lib/api_cbor/autogen/src/api_cbor_encode.c
    Writing to $WORKSPACE/$PROJECT/app/lib/api_cbor/autogen/include/api_cbor_encode.h
    Writing to $WORKSPACE/$PROJECT/app/lib/api_cbor/autogen/include/api_cbor_types.h
    ### Generating code from CDDLs via zcbor done. ###
    -- All lib dependencies of app:
    -- > zephyr_interface
    -- > FS
    -- > mbedTLS
    -- > mesh_adapters
    --   > mesh_domain
    --   > core_entities
    -- > mesh_domain
    -- > core_adapters
    --   > api_cbor
    -- > core_entities
    -- > core_domain
    -- Configuring done
    -- Generating done
    -- Build files have been written to: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/app
       * Running CMake for s1_image *
    -- Generated zephyr.dts: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/s1_image/zephyr/zephyr.dts
    -- Generated pickled edt: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/s1_image/zephyr/edt.pickle
    -- Generated devicetree_generated.h: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/s1_image/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/s1_image/zephyr/dts.cmake
    -- Configuring done
    -- Generating done
    CMake Warning:
      Manually-specified variables were not used by the project:
        EXTRA_KCONFIG_TARGETS
        FORCED_CONF_FILE
    -- Build files have been written to: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/s1_image
    CMake Warning at $WORKSPACE/nrf/cmake/sysbuild/partition_manager.cmake:121 (message):
            --- WARNING: Using a bootloader without pm_static.yml.            ---
            --- There are cases where a deployed product can consist of       ---
            --- multiple images, and only a subset of these images can be     ---
            --- upgraded through a firmware update mechanism. In such cases,  ---
            --- the upgradable images must have partitions that are static    ---
            --- and are matching the partition map used by the bootloader     ---
            --- programmed onto the device.                                   ---
      $WORKSPACE/nrf/cmake/sysbuild/partition_manager.cmake:620 (partition_manager)
      $WORKSPACE/nrf/sysbuild/CMakeLists.txt:779 (include)
      cmake/modules/sysbuild_extensions.cmake:583 (nrf_POST_CMAKE)
      cmake/modules/sysbuild_extensions.cmake:583 (cmake_language)
      cmake/modules/sysbuild_images.cmake:46 (sysbuild_module_call)
      cmake/modules/sysbuild_default.cmake:21 (include)
      $WORKSPACE/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      $WORKSPACE/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      $WORKSPACE/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    Dropping partition 'tfm_otp_nv_counters' since its size is 0.
    Dropping partition 'tfm_ps' since its size is 0.
    -- Configuring done
    -- Generating done
    [0/67] Creating public key from private key used for signing
    [22/67] Performing build step for 'ipc_radio'
    [1/218] Preparing syscall dependency handling
    [13/218] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.0.99 ($WORKSPACE/zephyr), build: 9c5b2d0faa44
    [218/218] Linking C executable zephyr/zephyr.elf
               FLASH:      172976 B       256 KB     65.99%
                 RAM:       53736 B        64 KB     81.99%
               SRAM1:          0 GB        64 KB      0.00%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/ipc_radio/zephyr/zephyr.elf for board: nrf5340dk
    [27/67] Performing build step for 'app'
    [0/1] Re-running CMake...
    Loading Zephyr default modules (Zephyr base (cached)).
    Loaded configuration '$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/app/zephyr/.config'
    No change to configuration in '$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/app/zephyr/.config'
    No change to Kconfig header in '$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/app/zephyr/include/generated/zephyr/autoconf.h'
    -- Build type:
    -- Machine: arm
    -- Vendor: none
    -- Machine: arm
    -- > FS
    -- > mbedTLS
    -- > mesh_adapters
    --   > mesh_domain
    --   > core_entities
    -- > mesh_domain
    -- > core_adapters
    --   > api_cbor
    -- > core_entities
    -- > core_domain
    -- Configuring done
    -- Generating done
    [1/546] Preparing syscall dependency handling
    [13/546] Generating include/generated/zephyr/version.h
    [14/546] Generating ../../tfm/CMakeCache.txt
    -- Found Git: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/git (found version "2.37.3")
    -- Found Python3: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/python (found version "3.12.4") found components: Interpreter
    -- Configuring done
    -- Generating done
    -- Build files have been written to: $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/app/tfm
    [19/546] Performing build step for 'tfm'
    [172/176] Linking C executable bin/tfm_s.axf
               FLASH:       80792 B     261632 B     30.88%
                 RAM:       43840 B       192 KB     22.30%
    [176/176] Linking C static library secure_fw/libtfm_s_veneers.a
    [21/546] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    ----- Installing platform NS -----
    [546/546] Linking CXX executable zephyr/zephyr.elf
               FLASH:      424968 B       608 KB     68.26%
                 RAM:      131912 B       256 KB     50.32%
    Generating files from $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/app/zephyr/zephyr.elf for board: nrf5340dk
    image.py: sign the payload
    [32/67] Performing build step for 'mcuboot'
    [1/222] Preparing syscall dependency handling
    [15/222] Generating include/generated/zephyr/version.h
    [129/222] Building C object modules/mcuboot/boot/bootutil/ze...e/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
    FAILED: modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk_help/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf53/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/lib/zcbor/include -I/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/boot/boot_serial/include -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/src -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc312_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj -MF modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj.d -o modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj -c $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c
    In file included from $WORKSPACE/bootloader/mcuboot/boot/bootutil/include/bootutil/enc_key.h:33,
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_priv.h:43,
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c:51:
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/include/bootutil/crypto/aes_ctr.h:19:6: error: #error "NONE!!!One crypto backend must be defined: either MBED_TLS or TINYCRYPT or PSA"
       19 |     #error "NONE!!!One crypto backend must be defined: either MBED_TLS or TINYCRYPT or PSA"
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/include/bootutil/crypto/aes_ctr.h:29:6: error: #error "One crypto backend must be defined: either MBED_TLS or TINYCRYPT or PSA"
       29 |     #error "One crypto backend must be defined: either MBED_TLS or TINYCRYPT or PSA"
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/include/bootutil/crypto/aes_ctr.h:34:6: error: #error "One crypto backend must be defined: either MBED_TLS or TINYCRYPT or PSA"
       34 |     #error "One crypto backend must be defined: either MBED_TLS or TINYCRYPT or PSA"
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/include/bootutil/enc_key.h:46:5: error: unknown type name 'bootutil_aes_ctr_context'
       46 |     bootutil_aes_ctr_context aes_ctr;
    [142/222] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [40/67] Generating ../mcuboot_primary_app.hex
    FAILED: _sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/_sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build
    cd $WORKSPACE/$PROJECT/app/build_nrf5340dk_help/mcuboot && /opt/nordic/ncs/toolchains/ef4fc6722e/Cellar/cmake/3.21.0/bin/cmake --build .
    FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/cmake --build $WORKSPACE/$PROJECT/app/build_nrf5340dk_help
  • I tried out the l9/l9_e3_sol/qspi project now. Adding encryption works fine, but only as long as I don't also add
    After that, I also get the same error
    Loading Zephyr module(s) (Zephyr base (cached)): sysbuild_default
    -- Board: nrf52840dk, qualifiers: nrf52840
    Loaded configuration '$WORKSPACE/build/zephyr/.config'
    No change to configuration in '$WORKSPACE/build/zephyr/.config'
    No change to Kconfig header in '$WORKSPACE/build/_sysbuild/autoconf.h'
    -- Found BOARD.dts: $WORKSPACE/zephyr/boards/nordic/nrf52840dk/nrf52840dk_nrf52840.dts
    -- Found devicetree overlay: $WORKSPACE/ncs-inter/l9/l9_e3_sol/qspi/sysbuild/mcuboot.overlay
    -- Generated zephyr.dts: $WORKSPACE/build/mcuboot/zephyr/zephyr.dts
    -- Generated pickled edt: $WORKSPACE/build/mcuboot/zephyr/edt.pickle
    -- Generated devicetree_generated.h: $WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: $WORKSPACE/build/mcuboot/zephyr/dts.cmake
    Loaded configuration '$WORKSPACE/build/mcuboot/zephyr/.config'
    Merged configuration '$WORKSPACE/build/mcuboot/zephyr/.config.sysbuild'
    No change to configuration in '$WORKSPACE/build/mcuboot/zephyr/.config'
    No change to Kconfig header in '$WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
    CMake Warning at $WORKSPACE/nrf/lib/flash_patch/CMakeLists.txt:8 (message):
            --- WARNING: To maintain the integrity of secure boot, ---
            --- enable CONFIG_DISABLE_FLASH_PATCH in production.   ---
    MCUBoot bootloader encryption key file: $WORKSPACE/bootloader/mcuboot/enc-ec256-priv.pem
    CMake Warning at CMakeLists.txt:447 (message):
      WARNING: Using default MCUboot encryption key file, this file is for debug
      use only and is not secure!
    -- Configuring done
    -- Generating done
    -- Build files have been written to: $WORKSPACE/build/mcuboot
       * Running CMake for qspi *
    -- Application: $WORKSPACE/ncs-inter/l9/l9_e3_sol/qspi
    -- Found devicetree overlay: $WORKSPACE/ncs-inter/l9/l9_e3_sol/qspi/app.overlay
    -- Generated zephyr.dts: $WORKSPACE/build/qspi/zephyr/zephyr.dts
    -- Generated pickled edt: $WORKSPACE/build/qspi/zephyr/edt.pickle
    -- Generated devicetree_generated.h: $WORKSPACE/build/qspi/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: $WORKSPACE/build/qspi/zephyr/dts.cmake
    Loaded configuration '$WORKSPACE/build/qspi/zephyr/.config'
    Merged configuration '$WORKSPACE/build/qspi/zephyr/.config.sysbuild'
    No change to configuration in '$WORKSPACE/build/qspi/zephyr/.config'
    No change to Kconfig header in '$WORKSPACE/build/qspi/zephyr/include/generated/zephyr/autoconf.h'
    -- Configuring done
    -- Generating done
    -- Build files have been written to: $WORKSPACE/build/qspi
      $WORKSPACE/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:97 (include_boilerplate)
    -- Configuring done
    -- Generating done
    [0/10] Performing build step for 'mcuboot'
    [0/187] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [1/187] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [1/186] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
    [1/186] Building C object CMakeFiles/app.dir/main.c.obj
    [1/186] Building C object CMakeFiles/ap.../boot/bootutil/src/image_validate.c.obj
    [1/186] Building C object CMakeFiles/ap...uboot/boot/bootutil/src/encrypted.c.obj
    [1/186] Building C object CMakeFiles/ap...der/mcuboot/boot/bootutil/src/tlv.c.obj
    [1/186] Building C object CMakeFiles/ap...oot/boot/bootutil/src/image_ecdsa.c.obj
    [1/186] Building C object CMakeFiles/ap...t/boot/bootutil/src/bootutil_misc.c.obj
    [1/186] Building C object CMakeFiles/ap.../mcuboot/boot/bootutil/src/loader.c.obj
    [1/186] Building C object CMakeFiles/ap...uboot/boot/bootutil/src/swap_misc.c.obj
    [1/186] Building C object CMakeFiles/ap...uboot/boot/bootutil/src/swap_move.c.obj
    [1/186] Building C object CMakeFiles/ap...ext/tinycrypt/lib/source/ctr_mode.c.obj
    [1/186] Building C object CMakeFiles/ap.../tinycrypt/lib/source/aes_encrypt.c.obj
    [1/186] Building C object CMakeFiles/ap.../tinycrypt/lib/source/aes_decrypt.c.obj
    [1/186] Building C object CMakeFiles/ap...oot/ext/tinycrypt/lib/source/hmac.c.obj
    [2/186] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
    [2/186] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
    [3/186] Building C object CMakeFiles/app.dir/main.c.obj
    [3/186] Building C object CMakeFiles/ap...t/ext/tinycrypt/lib/source/ecc_dh.c.obj
    [4/186] Building C object CMakeFiles/ap...ext/tinycrypt/lib/source/ctr_mode.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ctr_mode.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13314 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13314 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf52/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/debug/segger/SEGGER -I$WORKSPACE/modules/debug/segger/Config -I/../include -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ctr_mode.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ctr_mode.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ctr_mode.c.obj -c $WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ctr_mode.c
    $WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ctr_mode.c:33:10: fatal error: tinycrypt/constants.h: No such file or directory
       33 | #include <tinycrypt/constants.h>
    compilation terminated.
    [5/186] Building C object CMakeFiles/ap.../tinycrypt/lib/source/aes_encrypt.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_encrypt.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13314 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13314 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf52/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/debug/segger/SEGGER -I$WORKSPACE/modules/debug/segger/Config -I/../include -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_encrypt.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_encrypt.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_encrypt.c.obj -c $WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_encrypt.c
    $WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_encrypt.c:33:10: fatal error: tinycrypt/aes.h: No such file or directory
       33 | #include <tinycrypt/aes.h>
    [6/186] Building C object CMakeFiles/ap.../tinycrypt/lib/source/aes_decrypt.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_decrypt.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13314 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13314 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf52/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/debug/segger/SEGGER -I$WORKSPACE/modules/debug/segger/Config -I/../include -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_decrypt.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_decrypt.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_decrypt.c.obj -c $WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_decrypt.c
    $WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_decrypt.c:33:10: fatal error: tinycrypt/aes.h: No such file or directory
    [7/186] Building C object CMakeFiles/ap...oot/ext/tinycrypt/lib/source/hmac.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/hmac.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13314 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13314 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf52/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/debug/segger/SEGGER -I$WORKSPACE/modules/debug/segger/Config -I/../include -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/hmac.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/hmac.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/hmac.c.obj -c $WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/hmac.c
    $WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/hmac.c:33:10: fatal error: tinycrypt/hmac.h: No such file or directory
       33 | #include <tinycrypt/hmac.h>
    [8/186] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
    [9/186] Building C object CMakeFiles/ap...t/ext/tinycrypt/lib/source/ecc_dh.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ecc_dh.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13314 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13314 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf52/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/debug/segger/SEGGER -I$WORKSPACE/modules/debug/segger/Config -I/../include -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ecc_dh.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ecc_dh.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ecc_dh.c.obj -c $WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ecc_dh.c
    $WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ecc_dh.c:57:10: fatal error: tinycrypt/constants.h: No such file or directory
       57 | #include <tinycrypt/constants.h>
    [10/186] Building C object CMakeFiles/a...der/mcuboot/boot/bootutil/src/tlv.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13314 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13314 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf52/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/debug/segger/SEGGER -I$WORKSPACE/modules/debug/segger/Config -I/../include -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj -c $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/tlv.c
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/tlv.c:25:
    [11/186] Building C object CMakeFiles/a...oot/boot/bootutil/src/image_ecdsa.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_ecdsa.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13314 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13314 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf52/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/debug/segger/SEGGER -I$WORKSPACE/modules/debug/segger/Config -I/../include -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_ecdsa.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_ecdsa.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_ecdsa.c.obj -c $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_ecdsa.c
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_ecdsa.c:34:
    [12/186] Building C object CMakeFiles/a.../boot/bootutil/src/image_validate.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13314 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13314 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf52/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/debug/segger/SEGGER -I$WORKSPACE/modules/debug/segger/Config -I/../include -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj -c $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_validate.c
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_validate.c:55:
    [13/186] Building C object CMakeFiles/a...uboot/boot/bootutil/src/swap_misc.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13314 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13314 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf52/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/debug/segger/SEGGER -I$WORKSPACE/modules/debug/segger/Config -I/../include -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj -c $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_misc.c
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_misc.c:25:
    [14/186] Building C object CMakeFiles/a...t/boot/bootutil/src/bootutil_misc.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13314 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13314 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf52/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/debug/segger/SEGGER -I$WORKSPACE/modules/debug/segger/Config -I/../include -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj -c $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c:37:
    [15/186] Building C object CMakeFiles/a.../mcuboot/boot/bootutil/src/loader.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13314 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13314 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf52/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/debug/segger/SEGGER -I$WORKSPACE/modules/debug/segger/Config -I/../include -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/loader.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/loader.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/loader.c.obj -c $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/loader.c
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/loader.c:42:
    [16/186] Building C object CMakeFiles/a...uboot/boot/bootutil/src/swap_move.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13314 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13314 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf52/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/debug/segger/SEGGER -I$WORKSPACE/modules/debug/segger/Config -I/../include -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj -c $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_move.c
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_move.c:25:
    [17/186] Building C object CMakeFiles/a...uboot/boot/bootutil/src/encrypted.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13314 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13314 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/build/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf52/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/debug/segger/SEGGER -I$WORKSPACE/modules/debug/segger/Config -I/../include -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj -c $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c
    In file included from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:26:
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/include/bootutil/crypto/ecdh_p256.h:18:6: error: #error "NONE!!! One crypto backend must be defined: either MBED_TLS or TINYCRYPT"
       18 |     #error "NONE!!! One crypto backend must be defined: either MBED_TLS or TINYCRYPT"
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/include/bootutil/crypto/ecdh_p256.h:28:6: error: #error "One crypto backend must be defined: either MBED_TLS or TINYCRYPT"
       28 |     #error "One crypto backend must be defined: either MBED_TLS or TINYCRYPT"
    In file included from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:36:
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/include/bootutil/crypto/hmac_sha256.h:17:6: error: #error "One crypto backend must be defined: either MBED_TLS or TINYCRYPT"
       17 |     #error "One crypto backend must be defined: either MBED_TLS or TINYCRYPT"
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:43:
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c: In function 'parse_ec256_enckey':
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:187:16: error: 'NUM_ECC_BYTES' undeclared (first use in this function)
      187 |     if (len != NUM_ECC_BYTES) {
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:187:16: note: each undeclared identifier is reported only once for each function it appears in
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c: In function 'hkdf':
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:270:5: error: unknown type name 'bootutil_hmac_sha256_context'; did you mean 'bootutil_sha_context'?
      270 |     bootutil_hmac_sha256_context hmac;
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:288:5: warning: implicit declaration of function 'bootutil_hmac_sha256_init'; did you mean 'bootutil_sha_init'? [-Wimplicit-function-declaration]
      288 |     bootutil_hmac_sha256_init(&hmac);
          |     bootutil_sha_init
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:291:10: warning: implicit declaration of function 'bootutil_hmac_sha256_set_key' [-Wimplicit-function-declaration]
      291 |     rc = bootutil_hmac_sha256_set_key(&hmac, salt, BOOTUTIL_CRYPTO_SHA256_DIGEST_SIZE);
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:296:10: warning: implicit declaration of function 'bootutil_hmac_sha256_update'; did you mean 'bootutil_sha_update'? [-Wimplicit-function-declaration]
      296 |     rc = bootutil_hmac_sha256_update(&hmac, ikm, ikm_len);
          |          bootutil_sha_update
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:301:10: warning: implicit declaration of function 'bootutil_hmac_sha256_finish'; did you mean 'bootutil_sha_finish'? [-Wimplicit-function-declaration]
      301 |     rc = bootutil_hmac_sha256_finish(&hmac, prk, BOOTUTIL_CRYPTO_SHA256_DIGEST_SIZE);
          |          bootutil_sha_finish
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:306:5: warning: implicit declaration of function 'bootutil_hmac_sha256_drop'; did you mean 'bootutil_sha_drop'? [-Wimplicit-function-declaration]
      306 |     bootutil_hmac_sha256_drop(&hmac);
          |     bootutil_sha_drop
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c: In function 'boot_decrypt_key':
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:415:5: error: unknown type name 'bootutil_ecdh_p256_context'; did you mean 'bootutil_sha_context'?
      415 |     bootutil_ecdh_p256_context ecdh_p256;
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:421:5: error: unknown type name 'bootutil_hmac_sha256_context'; did you mean 'bootutil_sha_context'?
      421 |     bootutil_hmac_sha256_context hmac;
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:422:5: error: unknown type name 'bootutil_aes_ctr_context'; did you mean 'bootutil_sha_context'?
      422 |     bootutil_aes_ctr_context aes_ctr;
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:122:24: error: 'NUM_ECC_BYTES' undeclared (first use in this function)
      122 | #define SHARED_KEY_LEN NUM_ECC_BYTES
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:424:20: note: in expansion of macro 'SHARED_KEY_LEN'
      424 |     uint8_t shared[SHARED_KEY_LEN];
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:425:25: error: 'BOOTUTIL_CRYPTO_AES_CTR_KEY_SIZE' undeclared (first use in this function); did you mean 'BOOTUTIL_CRYPTO_SHA256_BLOCK_SIZE'?
      425 |     uint8_t derived_key[BOOTUTIL_CRYPTO_AES_CTR_KEY_SIZE + BOOTUTIL_CRYPTO_SHA256_DIGEST_SIZE];
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:429:21: error: 'BOOTUTIL_CRYPTO_AES_CTR_BLOCK_SIZE' undeclared (first use in this function); did you mean 'BOOTUTIL_CRYPTO_SHA256_BLOCK_SIZE'?
      429 |     uint8_t counter[BOOTUTIL_CRYPTO_AES_CTR_BLOCK_SIZE];
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:489:5: warning: implicit declaration of function 'bootutil_ecdh_p256_init'; did you mean 'bootutil_sha_init'? [-Wimplicit-function-declaration]
      489 |     bootutil_ecdh_p256_init(&ecdh_p256);
          |     bootutil_sha_init
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:491:10: warning: implicit declaration of function 'bootutil_ecdh_p256_shared_secret' [-Wimplicit-function-declaration]
      491 |     rc = bootutil_ecdh_p256_shared_secret(&ecdh_p256, &buf[EC_PUBK_INDEX], private_key, shared);
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:492:5: warning: implicit declaration of function 'bootutil_ecdh_p256_drop'; did you mean 'bootutil_sha_drop'? [-Wimplicit-function-declaration]
      492 |     bootutil_ecdh_p256_drop(&ecdh_p256);
          |     bootutil_sha_drop
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:576:5: warning: implicit declaration of function 'bootutil_aes_ctr_init'; did you mean 'bootutil_sha_init'? [-Wimplicit-function-declaration]
      576 |     bootutil_aes_ctr_init(&aes_ctr);
          |     bootutil_sha_init
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:578:9: warning: implicit declaration of function 'bootutil_aes_ctr_drop'; did you mean 'bootutil_sha_drop'? [-Wimplicit-function-declaration]
      578 |         bootutil_aes_ctr_drop(&aes_ctr);
          |         bootutil_sha_drop
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:582:10: warning: implicit declaration of function 'bootutil_aes_ctr_set_key' [-Wimplicit-function-declaration]
      582 |     rc = bootutil_aes_ctr_set_key(&aes_ctr, derived_key);
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:589:10: warning: implicit declaration of function 'bootutil_aes_ctr_decrypt' [-Wimplicit-function-declaration]
      589 |     rc = bootutil_aes_ctr_decrypt(&aes_ctr, counter, &buf[EC_CIPHERKEY_INDEX], BOOTUTIL_CRYPTO_AES_CTR_KEY_SIZE, 0, enckey);
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:429:13: warning: unused variable 'counter' [-Wunused-variable]
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:428:13: warning: unused variable 'private_key' [-Wunused-variable]
      428 |     uint8_t private_key[PRIV_KEY_LEN];
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:425:13: warning: unused variable 'derived_key' [-Wunused-variable]
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:424:13: warning: unused variable 'shared' [-Wunused-variable]
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c: In function 'boot_enc_encrypt':
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:729:5: warning: implicit declaration of function 'bootutil_aes_ctr_encrypt' [-Wimplicit-function-declaration]
      729 |     bootutil_aes_ctr_encrypt(&enc->aes_ctr, nonce, buf, sz, blk_off, buf);
    FAILED: _sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build $WORKSPACE/build/_sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build
    cd $WORKSPACE/build/mcuboot && /opt/nordic/ncs/toolchains/ef4fc6722e/Cellar/cmake/3.21.0/bin/cmake --build .
    FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/cmake --build $WORKSPACE/build
    And build/mcuboot/zephyr/.config again has
    # CONFIG_BOOT_ECDSA_TINYCRYPT is not set
    If I remove SB_CONFIG_SECURE_BOOT_APPCORE=y again, it builds and CONFIG_BOOT_ECDSA_TINYCRYPT=y
    Here's the full diff I applied to
    diff --git a/l9/l9_e3_sol/qspi/sysbuild.conf b/l9/l9_e3_sol/qspi/sysbuild.conf
    index 7814026..0e74d92 100644
    --- a/l9/l9_e3_sol/qspi/sysbuild.conf
    +++ b/l9/l9_e3_sol/qspi/sysbuild.conf
    @@ -2,3 +2,7 @@
     SB_CONFIG_BOOTLOADER_MCUBOOT=y
     # Step 3.1 - MCUboot should use external flash
     SB_CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
    +SB_CONFIG_BOOT_ENCRYPTION=y
    +SB_CONFIG_SECURE_BOOT_APPCORE=y
    diff --git a/l9/l9_e3_sol/qspi/sysbuild/mcuboot.conf b/l9/l9_e3_sol/qspi/sysbuild/mcuboot.conf
    index 3e304b5..007a215 100644
    --- a/l9/l9_e3_sol/qspi/sysbuild/mcuboot.conf
    +++ b/l9/l9_e3_sol/qspi/sysbuild/mcuboot.conf
    @@ -11,3 +11,5 @@ CONFIG_NORDIC_QSPI_NOR=y
     # This is 512 for the nRF54L15 but can be smaller for other chips
     CONFIG_BOOT_MAX_IMG_SECTORS=512
    +CONFIG_BOOT_ECDSA_TINYCRYPT=y
    Is there a way to have encrypted images while also using NSIB?
    I discussed this with a colleague of mine who has worked a bit more with encrypted DFU. Actually, no. Encrypted OTA + NSIB is not a possible combination. At least not at this point in time. He did some work on this, but it is not fully working. They were able to encrypt the application image, but it does not work for enctypted network images, and not for encrypted MCUBOOT images. So I don't know if that really is what you are looking for. If it is, you can check out this github repo:
    https://github.com/aHaugl/samples_for_NCS/tree/main/bootloader/sysbuild/7_encrypted_dfu/3_chain_ble_fota_ft_ext_flash
    Together with this loader.c:
    https://github.com/aHaugl/samples_for_NCS/blob/main/bootloader/sysbuild/7_encrypted_dfu/3_chain_ble_fota_ft_ext_flash/loader.c_diff.txt
    Edvin
  • Thanks for the pointer!
    After making the adjustments necessary for the 5340, I get the same compilation errors as above.
    For now we've decided to defer or maybe completely drop encryption.
    For the record, here are the changes I made to the example
    Index: bootloader/sysbuild/7_encrypted_dfu/3_chain_ble_fota_ft_ext_flash/sysbuild.conf
    IDEA additional info:
    Subsystem: com.intellij.openapi.diff.impl.patch.CharsetEP
    <+>UTF-8
    diff --git a/bootloader/sysbuild/7_encrypted_dfu/3_chain_ble_fota_ft_ext_flash/sysbuild.conf b/bootloader/sysbuild/7_encrypted_dfu/3_chain_ble_fota_ft_ext_flash/sysbuild.conf
    --- a/bootloader/sysbuild/7_encrypted_dfu/3_chain_ble_fota_ft_ext_flash/sysbuild.conf	(revision 88bc9d2eb56510214f0d576e22ef1cae2a8a223e)
    +++ b/bootloader/sysbuild/7_encrypted_dfu/3_chain_ble_fota_ft_ext_flash/sysbuild.conf	(date 1767882323100)
    @@ -1,26 +1,26 @@
     # Enable MCUboot
     # Configure project to use external flash for DFU
     SB_CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
     #State we will use KMU
    -SB_CONFIG_MCUBOOT_SIGNATURE_USING_KMU=y
    +SB_CONFIG_MCUBOOT_SIGNATURE_USING_KMU=n
     #Specify key type
    -SB_CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=n
    -SB_CONFIG_BOOT_SIGNATURE_TYPE_ED25519=y
    +SB_CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y
    +SB_CONFIG_BOOT_SIGNATURE_TYPE_ED25519=n
     #Add private key for MCUboot
     SB_CONFIG_BOOT_SIGNATURE_KEY_FILE="\${APP_DIR}/keys/mcuboot_ed25519_priv_a.pem"
     #Add NSIB
    -SB_CONFIG_SECURE_BOOT_SIGNATURE_TYPE_ECDSA=n
    -SB_CONFIG_SECURE_BOOT_SIGNATURE_TYPE_ED25519=y
    -SB_CONFIG_SECURE_BOOT_SIGNING_KEY_FILE="\${APP_DIR}/keys/nsib_ed25519_priv_a.pem"
    +SB_CONFIG_SECURE_BOOT_SIGNATURE_TYPE_ECDSA=y
    +SB_CONFIG_SECURE_BOOT_SIGNATURE_TYPE_ED25519=n
    +#SB_CONFIG_SECURE_BOOT_SIGNING_KEY_FILE="\${APP_DIR}/keys/nsib_ed25519_priv_a.pem"
     #Add public key files that will be fine to use later
    -SB_CONFIG_SECURE_BOOT_PUBLIC_KEY_FILES="\${APP_DIR}/keys/ed25519_pub_b.pem,\${APP_DIR}/keys/ed25519_pub_c.pem"
    +#SB_CONFIG_SECURE_BOOT_PUBLIC_KEY_FILES="\${APP_DIR}/keys/ed25519_pub_b.pem,\${APP_DIR}/keys/ed25519_pub_c.pem"
     #Encryption
    -SB_CONFIG_BOOT_ENCRYPTION=y
    -SB_CONFIG_BOOT_ENCRYPTION_KEY_FILE="\${APP_DIR}/keys/x255519_enc_priv.pem"
    +#SB_CONFIG_BOOT_ENCRYPTION_KEY_FILE="\${APP_DIR}/keys/x255519_enc_priv.pem"
    Index: bootloader/sysbuild/7_encrypted_dfu/3_chain_ble_fota_ft_ext_flash/prj.conf
    <+>UTF-8
    diff --git a/bootloader/sysbuild/7_encrypted_dfu/3_chain_ble_fota_ft_ext_flash/prj.conf b/bootloader/sysbuild/7_encrypted_dfu/3_chain_ble_fota_ft_ext_flash/prj.conf
    --- a/bootloader/sysbuild/7_encrypted_dfu/3_chain_ble_fota_ft_ext_flash/prj.conf	(revision 88bc9d2eb56510214f0d576e22ef1cae2a8a223e)
    +++ b/bootloader/sysbuild/7_encrypted_dfu/3_chain_ble_fota_ft_ext_flash/prj.conf	(date 1765975297977)
    @@ -34,28 +34,31 @@
     CONFIG_MCUMGR_TRANSPORT_UART=y
     # Dependencies
    -# Configure dependencies for CONFIG_MCUMGR
    +# Configure dependencies for CONFIG_MCUMGR
     CONFIG_NET_BUF=y
     CONFIG_ZCBOR=y
     CONFIG_CRC=y
    -# Configure dependencies for CONFIG_MCUMGR_GRP_IMG
    +# Configure dependencies for CONFIG_MCUMGR_GRP_IMG
     CONFIG_FLASH=y
     CONFIG_IMG_MANAGER=y
    -# Configure dependencies for CONFIG_IMG_MANAGER
    +# Configure dependencies for CONFIG_IMG_MANAGER
     CONFIG_STREAM_FLASH=y
     CONFIG_FLASH_MAP=y
    -# Configure dependencies for CONFIG_MCUMGR_TRANSPORT_UART
    +# Configure dependencies for CONFIG_MCUMGR_TRANSPORT_UART
     CONFIG_BASE64=y
     # Enable SPI driver for the application
     CONFIG_GPIO=y
    -CONFIG_SPI=y
    -CONFIG_SPI_NOR=y
    -CONFIG_SPI_NOR_SFDP_DEVICETREE=y
    -CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    +#CONFIG_SPI=y
    +#CONFIG_SPI_NOR=y
    +#CONFIG_SPI_NOR_SFDP_DEVICETREE=y
    +#CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
     # QSPI drivers are enabled by defualt for some chips.
     # Disable it explicitly to be sure QSPI is disabled.
    -CONFIG_NORDIC_QSPI_NOR=n
    +CONFIG_NORDIC_QSPI_NOR=y
    +# CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y
    +#CONFIG_BOOT_ECDSA_TINYCRYPT=y
    Index: bootloader/sysbuild/7_encrypted_dfu/3_chain_ble_fota_ft_ext_flash/sysbuild/mcuboot.conf
    <+>UTF-8
    diff --git a/bootloader/sysbuild/7_encrypted_dfu/3_chain_ble_fota_ft_ext_flash/sysbuild/mcuboot.conf b/bootloader/sysbuild/7_encrypted_dfu/3_chain_ble_fota_ft_ext_flash/sysbuild/mcuboot.conf
    --- a/bootloader/sysbuild/7_encrypted_dfu/3_chain_ble_fota_ft_ext_flash/sysbuild/mcuboot.conf	(revision 88bc9d2eb56510214f0d576e22ef1cae2a8a223e)
    +++ b/bootloader/sysbuild/7_encrypted_dfu/3_chain_ble_fota_ft_ext_flash/sysbuild/mcuboot.conf	(date 1765975658921)
    @@ -7,21 +7,27 @@
     # Enable SPI driver for MCUboot
     CONFIG_GPIO=y
    -CONFIG_SPI=y
    -CONFIG_SPI_NOR=y
    +# CONFIG_SPI=y
    +# CONFIG_SPI_NOR=y
    +# CONFIG_SPI_NOR_SFDP_DEVICETREE=y
    +# CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
     # required by SPI driver
     CONFIG_MULTITHREADING=y
     # Increase number of sectors
    -CONFIG_BOOT_MAX_IMG_SECTORS=512
    +CONFIG_BOOT_MAX_IMG_SECTORS=256
     # nRF54L15 needs some more space for MCUboot. 0x20000 is chosen somewhat arbitrarily, because 0x10000 was too small with encryption(??)
     # so remember to optimize this size in your own project
    -CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x10800
    +#CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x10800
    +CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y
    +CONFIG_BOOT_ECDSA_CC310=n
  • Hi Edvin,
    Thanks for the information!
    We are looking for a solution that has the NSIB and upgradeable MCUBoot, with support for encrypted application image OTA on nRF5340 without an external flash. Is there any update regarding this topic since sdk-mcuboot ncs-v3.3.0 has been released yesterday?
    Yue
