Encrypted DFU on 5340
I'm stuck implementing encrypted firmwares on the nrf5340, ncs 3.0.2., with NSIB and MCUBoot.
I got signed DFU to work as described in Exercise 3 – DFU with external flash.
However, as soon as I also enable encryption by setting
SB_CONFIG_BOOT_ENCRYPTION_KEY_FILE="\${APP_DIR}/firmware-encryption-key.pem"
SB_CONFIG_BOOT_ENCRYPTION=y
in sysbuild.conf
I get compilation errors, starting with
fatal error: tinycrypt/aes.h: No such file or directory
I've also added
CONFIG_BOOT_ECDSA_TINYCRYPT=y
to sysbuild/mcuboot.conf, but to no avail.
    Can you please share your full build log, and the application you are trying to build?
    Edvin
  • I can unfortunately not share the whole app, it has already a lot of implementation, I'm only evaluating adding DFU/FOTA.
    The build log is
    Setting $BOARD = nrf5340dk/nrf5340/cpuapp/ns
    Running command: west build --board nrf5340dk/nrf5340/cpuapp/ns --build-dir app/build_nrf5340dk app -- -DSB_CONF_FILE=$WORKSPACE/$PROJECT/app/sysbuild_release.conf -DEXTRA_CONF_FILE='release.conf'
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: /opt/nordic/ncs/toolchains/ef4fc6722e/opt/[email protected]/bin/python3.12 (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: /Users/theuser/Library/Caches/zephyr
    -- Board: nrf5340dk, qualifiers: nrf5340/cpuapp/ns
    Parsing $WORKSPACE/zephyr/share/sysbuild/Kconfig
    Loaded configuration '$WORKSPACE/$PROJECT/app/build_nrf5340dk/_sysbuild/empty.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/sysbuild_release.conf'
    Configuration saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk/zephyr/.config'
    Kconfig header saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk/_sysbuild/autoconf.h'
       * Running CMake for mcuboot *
    -- Application: $WORKSPACE/bootloader/mcuboot/boot/zephyr
    -- CMake version: 3.21.0
    -- Found Python3: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/python (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Zephyr version: 4.0.99 ($WORKSPACE/zephyr)
    -- Found host-tools: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk)
    -- Found Dtc: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
    -- Found BOARD.dts: $WORKSPACE/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp.dts
    -- Found devicetree overlay: $WORKSPACE/$PROJECT/app/sysbuild/mcuboot.overlay
    -- Generated zephyr.dts: $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/zephyr.dts
    -- Generated pickled edt: $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/edt.pickle
    -- Generated devicetree_generated.h: $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/dts.cmake
    Parsing $WORKSPACE/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration '$WORKSPACE/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp_defconfig'
    Merged configuration '$WORKSPACE/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/sysbuild/mcuboot.conf'
    Merged configuration '$WORKSPACE/nrf/modules/mcuboot/tfm.conf'
    Merged configuration '$WORKSPACE/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf'
    Merged configuration '$WORKSPACE/nrf/subsys/bootloader/image/log_minimal.conf'
    Merged configuration '$WORKSPACE/bootloader/mcuboot/boot/zephyr/external_crypto.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/.config.sysbuild'
    Configuration saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/.config'
    Kconfig header saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
    -- Found assembler: /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    -- Using ccache: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/ccache
    CMake Warning at $WORKSPACE/zephyr/CMakeLists.txt:1002 (message):
      No SOURCES given to Zephyr library: drivers__console
      Excluding target from build.
    MCUBoot bootloader key file: $WORKSPACE/bootloader/mcuboot/root-ec-p256.pem
    CMake Warning at CMakeLists.txt:393 (message):
      WARNING: Using default MCUboot signing key file, this file is for debug use
      only and is not secure!
    MCUBoot bootloader encryption key file: $WORKSPACE/$PROJECT/app/firmware-encryption-key.pem
    -- Configuring done
    -- Generating done
    -- Build files have been written to: $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot
       * Running CMake for ipc_radio *
    -- Application: $WORKSPACE/nrf/applications/ipc_radio
    -- Board: nrf5340dk, qualifiers: nrf5340/cpunet
    -- Found BOARD.dts: $WORKSPACE/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpunet.dts
    -- Generated zephyr.dts: $WORKSPACE/$PROJECT/app/build_nrf5340dk/ipc_radio/zephyr/zephyr.dts
    -- Generated pickled edt: $WORKSPACE/$PROJECT/app/build_nrf5340dk/ipc_radio/zephyr/edt.pickle
    -- Generated devicetree_generated.h: $WORKSPACE/$PROJECT/app/build_nrf5340dk/ipc_radio/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: $WORKSPACE/$PROJECT/app/build_nrf5340dk/ipc_radio/zephyr/dts.cmake
    Parsing $WORKSPACE/nrf/applications/ipc_radio/Kconfig
    Loaded configuration '$WORKSPACE/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpunet_defconfig'
    Merged configuration '$WORKSPACE/$PROJECT/app/sysbuild/ipc_radio/prj.conf'
    Merged configuration '$WORKSPACE/nrf/applications/ipc_radio/overlay-bt_hci_ipc.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/build_nrf5340dk/ipc_radio/zephyr/.config.sysbuild'
    Configuration saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk/ipc_radio/zephyr/.config'
    Kconfig header saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk/ipc_radio/zephyr/include/generated/zephyr/autoconf.h'
    -- libmetal version: 1.7.0 ($WORKSPACE/nrf/applications/ipc_radio)
    -- Build type:
    -- Host:    Darwin/arm64
    -- Target:  Generic/arm
    -- Machine: arm
    -- Vendor: none
    -- Looking for include file stdatomic.h
    -- Looking for include file stdatomic.h - found
    -- open-amp version: 1.7.0 ($WORKSPACE/modules/lib/open-amp/open-amp)
    -- Machine: arm
    -- C_FLAGS :  -Wall -Wextra
    -- Looking for include file fcntl.h
    -- Looking for include file fcntl.h - found
    CMake Warning at $WORKSPACE/zephyr/CMakeLists.txt:2180 (message):
    -- Configuring done
    -- Generating done
    -- Build files have been written to: $WORKSPACE/$PROJECT/app/build_nrf5340dk/ipc_radio
       * Running CMake for b0 *
    -- Application: $WORKSPACE/nrf/samples/bootloader
    -- Generated zephyr.dts: $WORKSPACE/$PROJECT/app/build_nrf5340dk/b0/zephyr/zephyr.dts
    -- Generated pickled edt: $WORKSPACE/$PROJECT/app/build_nrf5340dk/b0/zephyr/edt.pickle
    -- Generated devicetree_generated.h: $WORKSPACE/$PROJECT/app/build_nrf5340dk/b0/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: $WORKSPACE/$PROJECT/app/build_nrf5340dk/b0/zephyr/dts.cmake
    Parsing $WORKSPACE/zephyr/Kconfig
    Merged configuration '$WORKSPACE/nrf/samples/bootloader/prj.conf'
    Merged configuration '$WORKSPACE/nrf/samples/bootloader/boards/nrf5340dk_nrf5340_cpuapp.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/build_nrf5340dk/b0/zephyr/.config.sysbuild'
    Configuration saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk/b0/zephyr/.config'
    Kconfig header saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk/b0/zephyr/include/generated/zephyr/autoconf.h'
    -- Configuring done
    -- Generating done
    -- Build files have been written to: $WORKSPACE/$PROJECT/app/build_nrf5340dk/b0
       * Running CMake for app *
    -- Application: $WORKSPACE/$PROJECT/app
    -- Found BOARD.dts: $WORKSPACE/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp_ns.dts
    -- Found devicetree overlay: $WORKSPACE/$PROJECT/app/conf/boards/nrf5340dk_nrf5340_cpuapp_ns.overlay
    -- Generated zephyr.dts: $WORKSPACE/$PROJECT/app/build_nrf5340dk/app/zephyr/zephyr.dts
    -- Generated pickled edt: $WORKSPACE/$PROJECT/app/build_nrf5340dk/app/zephyr/edt.pickle
    -- Generated devicetree_generated.h: $WORKSPACE/$PROJECT/app/build_nrf5340dk/app/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: $WORKSPACE/$PROJECT/app/build_nrf5340dk/app/zephyr/dts.cmake
    warning: THREAD_STACK_INFO (defined at kernel/Kconfig:189) was assigned the value 'n' but got the
    value 'y'. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_THREAD_STACK_INFO and/or
    look up THREAD_STACK_INFO in the menuconfig/guiconfig interface. The Application Development Primer,
    Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
    helpful too.
    warning: Experimental symbol TFM_EXPERIMENTAL is enabled.
    warning: Experimental symbol COAP_SERVER is enabled.
    Parsing $WORKSPACE/$PROJECT/app/Kconfig
    Loaded configuration '$WORKSPACE/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp_ns_defconfig'
    Merged configuration '$WORKSPACE/$PROJECT/app/conf/prj.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/conf/boards/nrf5340dk_nrf5340_cpuapp_ns.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/conf/bluetooth.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/conf/bluetooth_mesh.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/conf/coap.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/conf/networking.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/conf/release.conf'
    Merged configuration '$WORKSPACE/$PROJECT/app/build_nrf5340dk/app/zephyr/.config.sysbuild'
    Configuration saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk/app/zephyr/.config'
    Kconfig header saved to '$WORKSPACE/$PROJECT/app/build_nrf5340dk/app/zephyr/include/generated/zephyr/autoconf.h'
    =========== Generating psa_crypto_config ===============
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Backup: CONFIG_MBEDTLS_THREADING: False
    Backup: CONFIG_MBEDTLS_THREADING_ALT: False
    =========== Checkpoint: backup ===============
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Restore: CONFIG_MBEDTLS_THREADING: False
    Restore: CONFIG_MBEDTLS_THREADING_ALT: False
    =========== End psa_crypto_config ===============
    =========== Generating psa_crypto_library_config ===============
    Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    =========== End psa_crypto_library_config ===============
    -- libmetal version: 1.7.0 ($WORKSPACE/$PROJECT/app)
    -- Build type:
    -- Machine: arm
    -- Vendor: none
    -- Machine: arm
    -- Including signing script: $WORKSPACE/nrf/cmake/sysbuild/image_signing.cmake
    ### Extracting entry_types from CDDL ###
    ### Extracted entry_types: UuidBytes;UnprovisionedDevice;Device;Actions;Light;LightProperties;OnOff;ScanStatus;DimLevel;TransitionTime;DimCommand;Node;MacBytes;Discovery;AttentionDuration;IdentifyUnprovisionedDevice ###
    ### Generating code from CDDLs via zcbor... ###
    Parsing files: $WORKSPACE/$PROJECT/app/lib/api_cbor/schemas/api_cbor.cddl, $WORKSPACE/$PROJECT/app/lib/api_cbor/../../../../modules/lib/zcbor/zcbor/prelude.cddl
    Writing to $WORKSPACE/$PROJECT/app/lib/api_cbor/autogen/src/api_cbor_decode.c
    Writing to $WORKSPACE/$PROJECT/app/lib/api_cbor/autogen/include/api_cbor_decode.h
    Writing to $WORKSPACE/$PROJECT/app/lib/api_cbor/autogen/src/api_cbor_encode.c
    Writing to $WORKSPACE/$PROJECT/app/lib/api_cbor/autogen/include/api_cbor_encode.h
    Writing to $WORKSPACE/$PROJECT/app/lib/api_cbor/autogen/include/api_cbor_types.h
    ### Generating code from CDDLs via zcbor done. ###
    -- All lib dependencies of app:
    -- > zephyr_interface
    -- > FS
    -- > mbedTLS
    -- > mesh_adapters
    --   > mesh_domain
    --   > core_entities
    -- > mesh_domain
    -- > core_adapters
    --   > api_cbor
    -- > core_entities
    -- > core_domain
    -- Configuring done
    -- Generating done
    -- Build files have been written to: $WORKSPACE/$PROJECT/app/build_nrf5340dk/app
       * Running CMake for s1_image *
    -- Generated zephyr.dts: $WORKSPACE/$PROJECT/app/build_nrf5340dk/s1_image/zephyr/zephyr.dts
    -- Generated pickled edt: $WORKSPACE/$PROJECT/app/build_nrf5340dk/s1_image/zephyr/edt.pickle
    -- Generated devicetree_generated.h: $WORKSPACE/$PROJECT/app/build_nrf5340dk/s1_image/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: $WORKSPACE/$PROJECT/app/build_nrf5340dk/s1_image/zephyr/dts.cmake
    -- Configuring done
    -- Generating done
    CMake Warning:
      Manually-specified variables were not used by the project:
        EXTRA_KCONFIG_TARGETS
        FORCED_CONF_FILE
    -- Build files have been written to: $WORKSPACE/$PROJECT/app/build_nrf5340dk/s1_image
    CMake Warning at $WORKSPACE/nrf/cmake/sysbuild/partition_manager.cmake:121 (message):
            --- WARNING: Using a bootloader without pm_static.yml.            ---
            --- There are cases where a deployed product can consist of       ---
            --- multiple images, and only a subset of these images can be     ---
            --- upgraded through a firmware update mechanism. In such cases,  ---
            --- the upgradable images must have partitions that are static    ---
            --- and are matching the partition map used by the bootloader     ---
            --- programmed onto the device.                                   ---
      $WORKSPACE/nrf/cmake/sysbuild/partition_manager.cmake:620 (partition_manager)
      $WORKSPACE/nrf/sysbuild/CMakeLists.txt:779 (include)
      cmake/modules/sysbuild_extensions.cmake:583 (nrf_POST_CMAKE)
      cmake/modules/sysbuild_extensions.cmake:583 (cmake_language)
      cmake/modules/sysbuild_images.cmake:46 (sysbuild_module_call)
      cmake/modules/sysbuild_default.cmake:21 (include)
      $WORKSPACE/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      $WORKSPACE/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      $WORKSPACE/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    Dropping partition 'tfm_ps' since its size is 0.
    Dropping partition 'tfm_otp_nv_counters' since its size is 0.
    -- Configuring done
    -- Generating done
    [0/67] Creating public key from private key used for signing
    [16/67] No patch step for 'b0'
    [18/67] No patch step for 'app'
    [19/67] No patch step for 's1_image'
    [20/67] No patch step for 'ipc_radio'
    [21/67] No patch step for 'mcuboot'
    [22/67] No configure step for 'b0'
    [22/67] Performing build step for 'b0'
    [1/144] Preparing syscall dependency handling
    [2/144] Generating ../../zephyr/include/generated/zephyr_commit.h
    [3/144] Generating ../../zephyr/include/generated/ncs_commit.h
    [4/144] Generating misc/generated/syscalls_subdirs.trigger
    [5/144] Generating ../../zephyr/include/generated/ncs_version.h
    [6/144] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [7/144] Generating include/generated/device-api-sections.ld, include/generated/device-api-sections.cmake
    [8/144] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, include/generated/zephyr/syscall_list.h
    [9/144] Generating include/generated/zephyr/driver-validation.h
    [10/144] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-size.h
    [11/144] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [12/144] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.0.99 ($WORKSPACE/zephyr), build: 9c5b2d0faa44
    [13/144] Generating include/generated/zephyr/offsets.h
    [14/144] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault_s.S.obj
    [15/144] Building ASM object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi_on_reset.S.obj
    [16/144] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [17/144] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi.c.obj
    [18/144] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [19/144] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/exc_exit.c.obj
    [20/144] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fpu.c.obj
    [21/144] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/reset.S.obj
    [22/144] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/tls.c.obj
    [23/144] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault.c.obj
    [24/144] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/fatal.c.obj
    [25/144] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/scb.c.obj
    [26/144] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread_abort.c.obj
    [27/144] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/vector_table.S.obj
    [28/144] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/swap_helper.S.obj
    [29/144] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/__aeabi_read_tp.S.obj
    [30/144] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/prep_c.c.obj
    [31/144] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_manage.c.obj
    [32/144] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_init.c.obj
    [33/144] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu_idle.c.obj
    [34/144] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread.c.obj
    [35/144] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/isr_wrapper.c.obj
    [36/144] Generating linker_zephyr_pre0.cmd
    [37/144] Building C object zephyr/arch/arch/arm/core/cortex_m/cmse/CMakeFiles/arch__arm__core__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [38/144] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/assert.c.obj
    [39/144] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/cbprintf.c.obj
    [40/144] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/chk_fail.c.obj
    [41/144] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/errno_wrap.c.obj
    [42/144] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/locks.c.obj
    [43/144] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/stdio.c.obj
    [44/144] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/exit.c.obj
    [45/144] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/abort.c.obj
    [46/144] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_base_addresses.c.obj
    [47/144] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/malloc.c.obj
    [48/144] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_binding_headers.c.obj
    [49/144] Linking C static library zephyr/arch/common/libisr_tables.a
    [50/144] Linking C static library zephyr/arch/arch/arm/core/libarch__arm__core.a
    [51/144] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/nrf53/soc.c.obj
    [52/144] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [53/144] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/nrf53/nrf53_cpunet_mgmt.c.obj
    [54/144] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_enabled_instances.c.obj
    [55/144] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/common/reboot.c.obj
    [56/144] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [57/144] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [58/144] Linking C static library zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a
    [59/144] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [60/144] Building C object modules/nrf/subsys/bootloader/bl_boot/CMakeFiles/..__nrf__subsys__bootloader__bl_boot.dir/bl_boot.c.obj
    [61/144] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_spu.c.obj
    [62/144] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [63/144] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto.c.obj
    [64/144] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto_oberon_ecdsa.c.obj
    [65/144] Linking C static library zephyr/lib/libc/common/liblib__libc__common.a
    [66/144] Linking C static library zephyr/lib/libc/picolibc/liblib__libc__picolibc.a
    [67/144] Linking C static library zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a
    [68/144] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto_oberon_hash.c.obj
    [69/144] Linking C static library zephyr/arch/common/libarch__common.a
    [70/144] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/mdk/system_nrf5340_application.c.obj
    [71/144] Linking C static library zephyr/drivers/console/libdrivers__console.a
    [72/144] Building C object modules/nrf/subsys/bootloader/bl_storage/CMakeFiles/..__nrf__subsys__bootloader__bl_storage.dir/bl_storage.c.obj
    [73/144] Linking C static library zephyr/soc/soc/nrf5340/libsoc__nordic.a
    [74/144] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [75/144] Building C object modules/nrf/subsys/bootloader/bl_validation/CMakeFiles/..__nrf__subsys__bootloader__bl_validation.dir/bl_validation.c.obj
    [76/144] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
    [77/144] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    [78/144] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [79/144] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
    [80/144] Linking C static library modules/nrf/subsys/bootloader/bl_boot/lib..__nrf__subsys__bootloader__bl_boot.a
    [81/144] Linking C static library modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a
    [82/144] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [83/144] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [84/144] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/helpers/nrfx_gppi_dppi.c.obj
    [85/144] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/helpers/nrfx_gppi_ppi.c.obj
    [86/144] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj
    [87/144] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [88/144] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [89/144] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [90/144] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [91/144] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [92/144] Building C object zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj
    [93/144] Linking C static library modules/nrf/subsys/bootloader/bl_crypto/lib..__nrf__subsys__bootloader__bl_crypto.a
    [94/144] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init_static.c.obj
    [95/144] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [96/144] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [97/144] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [98/144] Linking C static library modules/nrf/subsys/bootloader/bl_storage/lib..__nrf__subsys__bootloader__bl_storage.a
    [99/144] Linking C static library modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a
    [100/144] Linking C static library modules/nrf/subsys/bootloader/bl_validation/lib..__nrf__subsys__bootloader__bl_validation.a
    [101/144] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [102/144] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [103/144] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [104/144] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [105/144] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [106/144] Building C object zephyr/kernel/CMakeFiles/kernel.dir/nothread.c.obj
    [107/144] Building C object zephyr/kernel/CMakeFiles/kernel.dir/float.c.obj
    [108/144] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [109/144] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [110/144] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [111/144] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/hex.c.obj
    [112/144] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/timeutil.c.obj
    [113/144] Building C object zephyr/kernel/CMakeFiles/kernel.dir/dynamic_disabled.c.obj
    [114/144] Building C object CMakeFiles/app.dir/src/main.c.obj
    [115/144] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [116/144] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [117/144] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/dec.c.obj
    [118/144] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [119/144] Building C object zephyr/CMakeFiles/zephyr.dir/lib/heap/heap.c.obj
    [120/144] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/rb.c.obj
    [121/144] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [122/144] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [123/144] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/last_section_id.c.obj
    [124/144] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [125/144] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [126/144] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [127/144] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [128/144] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [129/144] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/bitarray.c.obj
    [130/144] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/notify.c.obj
    [131/144] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/onoff.c.obj
    [132/144] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
    [133/144] Linking C static library modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [134/144] Building C object zephyr/CMakeFiles/zephyr.dir$WORKSPACE/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [135/144] Building C object zephyr/CMakeFiles/zephyr.dir$WORKSPACE/nrf/lib/boot_banner/banner.c.obj
    [136/144] Linking C static library app/libapp.a
    [137/144] Linking C static library zephyr/kernel/libkernel.a
    [138/144] Linking C static library zephyr/libzephyr.a
    [139/144] Linking C executable zephyr/zephyr_pre0.elf
    [140/144] Generating linker.cmd
    [141/144] Generating isr_tables.c, isr_tables_vt.ld, isr_tables_swi.ld
    [142/144] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [143/144] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [144/144] Linking C executable zephyr/zephyr.elf
               FLASH:       23220 B        32 KB     70.86%
                 RAM:        4496 B       256 KB      1.72%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from $WORKSPACE/$PROJECT/app/build_nrf5340dk/b0/zephyr/zephyr.elf for board: nrf5340dk
    [26/67] No configure step for 'ipc_radio'
    [27/67] Performing build step for 'app'
    [0/1] Re-running CMake...
    Loading Zephyr default modules (Zephyr base (cached)).
    Loaded configuration '$WORKSPACE/$PROJECT/app/build_nrf5340dk/app/zephyr/.config'
    No change to configuration in '$WORKSPACE/$PROJECT/app/build_nrf5340dk/app/zephyr/.config'
    No change to Kconfig header in '$WORKSPACE/$PROJECT/app/build_nrf5340dk/app/zephyr/include/generated/zephyr/autoconf.h'
    -- Build type:
    -- Machine: arm
    -- Vendor: none
    -- Machine: arm
    -- > FS
    -- > mbedTLS
    -- > mesh_adapters
    --   > mesh_domain
    --   > core_entities
    -- > mesh_domain
    -- > core_adapters
    --   > api_cbor
    -- > core_entities
    -- > core_domain
    -- Configuring done
    -- Generating done
    [1/546] Preparing syscall dependency handling
    [2/546] Generating ../../zephyr/include/generated/zephyr_commit.h
    [3/546] Generating ../../zephyr/include/generated/app_commit.h
    [4/546] Generating include/generated/zephyr/app_version.h
    [5/546] Generating ../../zephyr/include/generated/ncs_commit.h
    [6/546] Generating misc/generated/syscalls_subdirs.trigger
    [7/546] Generating ../../zephyr/include/generated/ncs_version.h
    [8/546] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [9/546] Generating include/generated/device-api-sections.ld, include/generated/device-api-sections.cmake
    [10/546] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, include/generated/zephyr/syscall_list.h
    [11/546] Generating include/generated/zephyr/driver-validation.h
    [12/546] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-size.h
    [13/546] Generating include/generated/zephyr/version.h
    [14/546] Generating ../../tfm/CMakeCache.txt
    -- Found Git: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/git (found version "2.37.3")
    -- Found Python3: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/python (found version "3.12.4") found components: Interpreter
    -- Configuring done
    -- Generating done
    -- Build files have been written to: $WORKSPACE/$PROJECT/app/build_nrf5340dk/app/tfm
    [15/546] Creating directories for 'tfm'
    [16/546] No download step for 'tfm'
    [17/546] No update step for 'tfm'
    [18/546] No patch step for 'tfm'
    [19/546] No configure step for 'tfm'
    [19/546] Performing build step for 'tfm'
    [1/176] Building C object lib/fih/CMakeFiles/tfm_fih.dir/src/fih.o
    [2/176] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/common/syscalls_stub.o
    [3/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/core/utilities.o
    [4/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/core/spm_log.o
    [5/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/core/arch/tfm_arch.o
    [6/176] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/psa_api_veneers_v80m.o
    [7/176] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/core/startup.o
    [8/176] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/core/startup_nrf5340.o
    [9/176] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/common/faults.o
    [10/176] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/load_info_ns_agent_tz.o
    [11/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/core/tfm_boot_data.o
    [12/176] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [13/176] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [14/176] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/internal_trusted_storage/auto_generated/load_info_tfm_internal_trusted_storage.o
    [15/176] Linking C static library lib/fih/libtfm_fih.a
    [16/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/core/psa_version_api.o
    [17/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/core/psa_call_api.o
    [18/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/core/psa_api.o
    [19/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/core/spm_connection_pool.o
    [20/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/core/main.o
    [21/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ns_client_ext/tfm_spm_ns_ctx.o
    [22/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/core/arch/tfm_arch_v8m_main.o
    [23/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/core/thread.o
    [24/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/core/psa_read_write_skip_api.o
    [25/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/core/rom_loader.o
    [26/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/core/backend_ipc.o
    [27/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/common/tfm_hal_nvic.o
    [28/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/core/tfm_pools.o
    [29/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/ns_agent_tz_v80m.o
    [30/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/tfm_hal_platform_common.o
    [31/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/platform/ext/common/syscalls_stub.o
    [32/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/core/spm_ipc.o
    [33/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/common/syscalls_stub.o
    [34/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/core/tfm_svcalls.o
    [35/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/crt_memcmp.o
    [36/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/faults.o
    [37/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/crt_memmove.o
    [38/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/load_info_ns_agent_tz.o
    [39/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/crt_strnlen.o
    [40/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [41/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/shared/crt_memcpy.o
    [42/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/tfm_hal_isolation.o
    [43/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/sprt_partition_metadata_indicator.o
    [44/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/shared/crt_memset.o
    [45/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [46/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/internal_trusted_storage/auto_generated/load_info_tfm_internal_trusted_storage.o
    [47/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/service_api.o
    [48/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/sfn_common_thread.o
    [49/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/psa_api_ipc.o
    [50/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/tfm_sp_log_raw.o
    [51/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/platform/ext/common/tfm_hal_sp_logdev_periph.o
    [52/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_its_api.o
    [53/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/spm/core/psa_interface_svc.o
    [54/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_platform_api.o
    [55/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_psa_call.o
    [56/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sp_log.dir/tfm_sp_log_raw.o
    [57/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sp_log.dir/__/__/__/__/platform/ext/common/tfm_hal_sp_logdev_periph.o
    [58/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/spm/core/psa_interface_thread_fn_call.o
    [59/176] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_asymmetric.o
    [60/176] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_hash.o
    [61/176] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_aead.o
    [62/176] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/generated/secure_fw/partitions/crypto/auto_generated/intermedia_tfm_crypto.o
    [63/176] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_rng.o
    [64/176] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_derivation.o
    [65/176] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_library.o
    [66/176] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_alloc.o
    [67/176] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_cipher.o
    [68/176] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_mac.o
    [69/176] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_pake.o
    [70/176] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_management.o
    [71/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/constant_time.o
    [72/176] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_init.o
    [73/176] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/psa_driver_api/tfm_builtin_key_loader.o
    [74/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/bignum.o
    [75/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/nist_kw.o
    [76/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/bignum_core.o
    [77/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/block_cipher.o
    [78/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/version.o
    [79/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/padlock.o
    [80/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/asn1write.o
    [81/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_mutexes.o
    [82/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/base64.o
    [83/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_events.o
    [84/176] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/target_cfg.o
    [85/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/library/platform_util.o
    [86/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/library/platform.o
    [87/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/library/psa_crypto_client.o
    [88/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_helpers.o
    [89/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_ecdh.o
    [90/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_ecdsa.o
    [91/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/asn1parse.o
    [92/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/oid.o
    [93/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_ec_keys.o
    [94/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_key_management.o
    [95/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/memory_buffer_alloc.o
    [96/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_jpake.o
    [97/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/library/psa_crypto_storage.o
    [98/176] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_crypto_api.o
    [99/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_key_derivation.o
    [100/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_aead.o
    [101/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_cipher.o
    [102/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_wpa3_sae.o
    [103/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_rsa.o
    [104/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_hash.o
    [105/176] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/its_utils.o
    [106/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_spake2p.o
    [107/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_key_agreement.o
    [108/176] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/tfm_its_req_mngr.o
    [109/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_srp.o
    [110/176] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/tfm_internal_trusted_storage.o
    [111/176] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/flash/its_flash.o
    [112/176] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/__/__/__/generated/secure_fw/partitions/internal_trusted_storage/auto_generated/intermedia_tfm_internal_trusted_storage.o
    [113/176] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/flash/its_flash_nand.o
    [114/176] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/flash/its_flash_ram.o
    [115/176] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/flash_fs/its_flash_fs_dblock.o
    [116/176] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/flash/its_flash_nor.o
    [117/176] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/platform/ext/common/syscalls_stub.o
    [118/176] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/__/__/__/platform/ext/common/syscalls_stub.o
    [119/176] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/platform_sp.o
    [120/176] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/generated/secure_fw/partitions/platform/auto_generated/intermedia_tfm_platform.o
    [121/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/library/psa_crypto_slot_management.o
    [122/176] Building C object platform/CMakeFiles/platform_crypto_keys.dir/ext/common/syscalls_stub.o
    [123/176] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/flash_fs/its_flash_fs.o
    [124/176] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/mpu_armv8m_drv.o
    [125/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_mac.o
    [126/176] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/nrf_exception_info.o
    [127/176] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_ioctl_core_s_api.o
    [128/176] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/nrfx_glue.o
    [129/176] Building C object platform/CMakeFiles/platform_crypto_keys.dir$WORKSPACE/nrf/modules/trusted-firmware-m/tfm_boards/common/crypto_keys.o
    [130/176] Building C object platform/CMakeFiles/platform_s.dir$WORKSPACE/nrf/modules/trusted-firmware-m/tfm_boards/common/assert.o
    [131/176] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/cmsis_drivers/Driver_Flash.o
    [132/176] Building C object platform/CMakeFiles/platform_s.dir$WORKSPACE/modules/hal/nordic/nrfx/mdk/system_nrf5340_application.o
    [133/176] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/spu.o
    [134/176] Building C object platform/CMakeFiles/platform_s.dir$WORKSPACE/nrf/modules/trusted-firmware-m/tfm_boards/common/dummy_otp.o
    [135/176] Building C object platform/CMakeFiles/platform_s.dir$WORKSPACE/nrf/modules/trusted-firmware-m/tfm_boards/common/dummy_provisioning.o
    [136/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir$WORKSPACE/nrf/subsys/nrf_security/src/psa_crypto_driver_wrappers.o
    [137/176] Building C object platform/CMakeFiles/platform_s.dir$WORKSPACE/nrf/modules/trusted-firmware-m/tfm_boards/common/tfm_hal_platform.o
    [138/176] Building C object platform/CMakeFiles/platform_s.dir$WORKSPACE/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.o
    [139/176] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/flash_fs/its_flash_fs_mblock.o
    [140/176] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_its.o
    [141/176] Building C object platform/CMakeFiles/platform_s.dir$WORKSPACE/nrf/lib/hw_unique_key/hw_unique_key_cc3xx.o
    [142/176] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_spm_logdev_peripheral.o
    [143/176] Building C object platform/CMakeFiles/platform_s.dir/ext/common/template/tfm_rotpk.o
    [144/176] Building C object platform/CMakeFiles/platform_s.dir/ext/common/exception_info.o
    [145/176] Building C object platform/CMakeFiles/platform_s.dir/ext/common/uart_stdout.o
    [146/176] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_fatal_error.o
    [147/176] Building C object platform/CMakeFiles/platform_s.dir/ext/common/syscalls_stub.o
    [148/176] Building C object platform/target/nrf5340/nrf_common/CMakeFiles/tfm_s_scatter.dir/__/__/__/__/common/gcc/tfm_common_s.ld
    [149/176] Building C object platform/CMakeFiles/platform_s.dir$WORKSPACE/nrf/lib/hw_unique_key/hw_unique_key_cc3xx_kmu.o
    [150/176] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/cmsis_drivers/Driver_USART.o
    [151/176] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_platform_hal_ioctl.o
    [152/176] Building C object platform/CMakeFiles/platform_s.dir$WORKSPACE/nrf/modules/trusted-firmware-m/tfm_boards/common/tfm_hal_reset_halt.o
    [153/176] Building C object platform/CMakeFiles/platform_s.dir$WORKSPACE/nrf/modules/trusted-firmware-m/tfm_boards/src/tfm_platform_system.o
    [154/176] Building C object platform/CMakeFiles/platform_s.dir$WORKSPACE/nrf/modules/trusted-firmware-m/tfm_boards/src/tfm_ioctl_s_api.o
    [155/176] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/hw_init.o
    [156/176] Building C object platform/CMakeFiles/platform_s.dir$WORKSPACE/nrf/modules/trusted-firmware-m/tfm_boards/common/ns_fault_service.o
    [157/176] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/library/psa_crypto.o
    [158/176] Building C object platform/CMakeFiles/platform_s.dir$WORKSPACE/modules/hal/nordic/nrfx/drivers/src/nrfx_uarte.o
    [159/176] Linking C static library platform/libplatform_s.a
    [160/176] Linking C static library platform/libplatform_crypto_keys.a
    [161/176] Linking C static library secure_fw/partitions/platform/libtfm_psa_rot_partition_platform.a
    [162/176] Linking C static library secure_fw/partitions/internal_trusted_storage/libtfm_psa_rot_partition_its.a
    [163/176] Linking C static library secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/liboberon_psa_driver.a
    [164/176] Linking C static library secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/liboberon_psa_core.a
    [165/176] Linking C static library secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/libcrypto_service_mbedcrypto.a
    [166/176] Linking C static library secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/libnrf_security_utils.a
    [167/176] Linking C static library secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/libmbedcrypto_base.a
    [168/176] Linking C static library secure_fw/partitions/crypto/libtfm_psa_rot_partition_crypto.a
    [169/176] Linking C static library secure_fw/partitions/lib/runtime/libtfm_sp_log.a
    [170/176] Linking C static library secure_fw/partitions/lib/runtime/libtfm_sprt.a
    [171/176] Linking C static library secure_fw/spm/libtfm_spm.a
    [172/176] Linking C executable bin/tfm_s.axf
               FLASH:       80792 B     261632 B     30.88%
                 RAM:       43840 B       192 KB     22.30%
    [173/176] Generating ../bin/tfm_s.bin
    [174/176] Generating ../bin/tfm_s.hex
    [175/176] Generating ../bin/tfm_s.elf
    [176/176] Linking C static library secure_fw/libtfm_s_veneers.a
    [21/546] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    ----- Installing platform NS -----
    [22/546] Completed 'tfm'
    [23/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/base64.c.obj
    [24/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/bignum_core.c.obj
    [25/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/nist_kw.c.obj
    [26/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/constant_time.c.obj
    [27/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/bignum.c.obj
    [28/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/padlock.c.obj
    [29/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/version.c.obj
    [30/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/block_cipher.c.obj
    [31/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/asn1write.c.obj
    [32/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/asn1parse.c.obj
    [33/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/mbedtls/library/oid.c.obj
    [34/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/library/platform.c.obj
    [35/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/pem.c.obj
    [36/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/pkcs12.c.obj
    [37/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/pkcs5.c.obj
    [38/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/pkparse.c.obj
    [39/546] Building C object lib/api_cbor/CMakeFiles/api_cbor.dir/autogen/src/api_cbor_decode.c.obj
    [40/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/library/platform_util.c.obj
    [41/546] Building C object lib/api_cbor/CMakeFiles/api_cbor.dir/autogen/src/api_cbor_encode.c.obj
    [42/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/memory_buffer_alloc.c.obj
    [43/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/dhm.c.obj
    [44/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_mutexes.c.obj
    [45/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_events.c.obj
    [46/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/pkwrite.c.obj
    [47/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/cipher.c.obj
    [48/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/cipher_wrap.c.obj
    [49/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/md.c.obj
    [50/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/psa_util.c.obj
    [51/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/pk_wrap.c.obj
    [52/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/sha1.c.obj
    [53/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/pk_ecc.c.obj
    [54/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/oberon-psa-crypto/programs/ssl/library/pk.c.obj
    [55/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/sha256.c.obj
    [56/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/sha512.c.obj
    [57/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/sha3.c.obj
    [58/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/aesce.c.obj
    [59/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/md5.c.obj
    [60/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/aes.c.obj
    [61/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/cmac.c.obj
    [62/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/aesni.c.obj
    [63/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/ccm.c.obj
    [64/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/ecdh.c.obj
    [65/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/chachapoly.c.obj
    [66/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/ecp.c.obj
    [67/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/ecp_curves.c.obj
    [68/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/gcm.c.obj
    [69/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/ecp_curves_new.c.obj
    [70/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/hkdf.c.obj
    [71/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/rsa.c.obj
    [72/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecdsa_oberon.c.obj
    [73/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/ctr_drbg.c.obj
    [74/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/hmac_drbg.c.obj
    [75/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/rsa_alt_helpers.c.obj
    [76/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/md_ext.c.obj
    [77/546] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [78/546] Building CXX object lib/core/entities/CMakeFiles/core_entities.dir/empty.cpp.obj
    [79/546] Building CXX object lib/mesh/domain/CMakeFiles/mesh_domain.dir/usecases/identify_unprovisioned_device_usecase.cpp.obj
    [80/546] Building CXX object lib/mesh/domain/CMakeFiles/mesh_domain.dir/mesh_device_descriptor_container.cpp.obj
    [81/546] Building CXX object lib/mesh/domain/CMakeFiles/mesh_domain.dir/composition_data_service_utility.cpp.obj
    [82/546] Building CXX object lib/mesh/domain/CMakeFiles/mesh_domain.dir/usecases/remove_node_usecase.cpp.obj
    [83/546] Building CXX object lib/mesh/domain/CMakeFiles/mesh_domain.dir/generic_nlc_decomposer.cpp.obj
    [84/546] Building CXX object lib/core/domain/CMakeFiles/core_domain.dir/device_descriptor_repository.cpp.obj
    [85/546] Building CXX object lib/mesh/domain/CMakeFiles/mesh_domain.dir/generic_lightness_decomposer.cpp.obj
    [86/546] Building CXX object lib/core/domain/CMakeFiles/core_domain.dir/device_provisioning.cpp.obj
    [87/546] Building CXX object lib/core/domain/CMakeFiles/core_domain.dir/models/actions/action_id.cpp.obj
    [88/546] Building CXX object lib/mesh/domain/CMakeFiles/mesh_domain.dir/usecases/reset_nodes_usecase.cpp.obj
    [89/546] Building CXX object lib/mesh/domain/CMakeFiles/mesh_domain.dir/usecases/identify_node_usecase.cpp.obj
    [90/546] Building CXX object lib/core/domain/CMakeFiles/core_domain.dir/models/properties/property_id.cpp.obj
    [91/546] Building CXX object lib/mesh/domain/CMakeFiles/mesh_domain.dir/usecases/product_decomposition_usecase.cpp.obj
    [92/546] Building CXX object lib/core/domain/CMakeFiles/core_domain.dir/repositories/node_additional_info_repository.cpp.obj
    [93/546] Linking C static library modules/nrf/subsys/nrf_security/src/libnrf_security_utils.a
    [94/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir$WORKSPACE/modules/crypto/mbedtls/library/entropy.c.obj
    [95/546] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecjpake_oberon.c.obj
    [96/546] Building CXX object lib/core/domain/CMakeFiles/core_domain.dir/parse_helpers.cpp.obj
    [97/546] Building CXX object lib/core/adapters/CMakeFiles/core_adapters.dir/mesh/mesh_device_repository.cpp.obj
    [98/546] Building CXX object lib/core/adapters/CMakeFiles/core_adapters.dir/factory_reset_signal_manager.cpp.obj
    [99/546] Linking C static library modules/nrf/subsys/nrf_security/src/libmbedcrypto_base.a
    [100/546] Linking C static library modules/nrf/subsys/nrf_security/src/libmbedcrypto.a
    [101/546] Building CXX object lib/core/adapters/CMakeFiles/core_adapters.dir/coap/coap_controller_discovery.cpp.obj
    [102/546] Building CXX object lib/core/adapters/CMakeFiles/core_adapters.dir/mesh/mesh_scan_provisioning_coap_controller.cpp.obj
    [103/546] Linking C static library lib/api_cbor/libapi_cbor.a
    [104/546] Linking CXX static library lib/core/entities/libcore_entities.a
    [105/546] Linking CXX static library lib/core/domain/libcore_domain.a
    [106/546] Generating include/generated/zephyr/offsets.h
    [107/546] Linking CXX static library lib/mesh/domain/libmesh_domain.a
    [108/546] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/bt_str.c.obj
    [109/546] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/addr.c.obj
    [110/546] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_common.c.obj
    [111/546] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/crypto_psa.c.obj
    [112/546] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/id.c.obj
    [113/546] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/settings.c.obj
    [114/546] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/long_wq.c.obj
    [115/546] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/adv.c.obj
    [116/546] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/l2cap.c.obj
    [117/546] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/gatt.c.obj
    [118/546] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/scan.c.obj
    [119/546] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/conn.c.obj
    [120/546] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/uuid.c.obj
    [121/546] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [122/546] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/dummy.c.obj
    [123/546] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/att.c.obj
    [124/546] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [125/546] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/smp_null.c.obj
    [126/546] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [127/546] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/psa_crypto_init.c.obj
    [128/546] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj
    [129/546] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [130/546] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [131/546] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/src/zephyr_tfm_log.c.obj
    [132/546] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/api_ns/interface/src/tfm_its_api.c.obj
    [133/546] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/api_ns/interface/src/tfm_platform_api.c.obj
    [134/546] Building C object modules/nrf/modules/trusted-firmware-m/CMakeFiles/..__nrf__modules__trusted-firmware-m.dir/fault.c.obj
    [135/546] Building C object modules/nrf/modules/trusted-firmware-m/CMakeFiles/tfm_api_nrf.dir/tfm_boards/src/tfm_ioctl_ns_api.c.obj
    [136/546] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
    [137/546] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/interface/interface.c.obj
    [138/546] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/api_ns/interface/src/tfm_tz_psa_ns_api.c.obj
    [139/546] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/api_ns/interface/src/tfm_ioctl_core_ns_api.c.obj
    [140/546] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/api_ns/interface/src/tfm_crypto_api.c.obj
    [141/546] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/mbedtls_heap.c.obj
    [142/546] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/mdk/system_nrf5340_application.c.obj
    [143/546] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_common.c.obj
    [144/546] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [145/546] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    [146/546] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj
    [147/546] Linking C static library zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a
    [148/546] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [149/546] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [150/546] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/helpers/nrfx_gppi_dppi.c.obj
    [151/546] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
    [152/546] Linking C static library modules/nrf/modules/trusted-firmware-m/lib..__nrf__modules__trusted-firmware-m.a
    [153/546] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/helpers/nrfx_gppi_ppi.c.obj
    [154/546] Linking C static library modules/nrf/modules/trusted-firmware-m/libtfm_api_nrf.a
    [155/546] Linking C static library modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a
    [156/546] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [157/546] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [158/546] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [159/546] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [160/546] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/drivers/src/nrfx_ipc.c.obj
    [161/546] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/__aeabi_atexit.c.obj
    [162/546] Building ASM object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi_on_reset.S.obj
    [163/546] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [164/546] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/fatal.c.obj
    [165/546] Linking C static library modules/trusted-firmware-m/libtfm_api.a
    [166/546] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [167/546] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi.c.obj
    [168/546] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/tls.c.obj
    [169/546] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault_s.S.obj
    [170/546] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/exc_exit.c.obj
    [171/546] Linking C static library zephyr/drivers/spi/libdrivers__spi.a
    [172/546] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/reset.S.obj
    [173/546] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/vector_table.S.obj
    [174/546] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fpu.c.obj
    [175/546] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault.c.obj
    [176/546] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/scb.c.obj
    [177/546] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/swap_helper.S.obj
    [178/546] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread_abort.c.obj
    [179/546] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/__aeabi_read_tp.S.obj
    [180/546] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_manage.c.obj
    [181/546] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread.c.obj
    [182/546] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu_idle.c.obj
    [183/546] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_init.c.obj
    [184/546] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/isr_wrapper.c.obj
    [185/546] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_core_mpu.c.obj
    [186/546] Building C object zephyr/arch/arch/arm/core/cortex_m/cmse/CMakeFiles/arch__arm__core__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [187/546] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu_regions.c.obj
    [188/546] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/prep_c.c.obj
    [189/546] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu.c.obj
    [190/546] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/chk_fail.c.obj
    [191/546] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/errno_wrap.c.obj
    [192/546] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/assert.c.obj
    [193/546] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/cbprintf.c.obj
    [194/546] Linking C static library zephyr/arch/common/libisr_tables.a
    [195/546] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/stdio.c.obj
    [196/546] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdio/remove.c.obj
    [197/546] Linking C static library zephyr/arch/arch/arm/core/libarch__arm__core.a
    [198/546] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/exit.c.obj
    [199/546] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/abort.c.obj
    [200/546] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/locks.c.obj
    [201/546] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/malloc.c.obj
    [202/546] Building C object zephyr/lib/net_buf/CMakeFiles/lib__net_buf.dir/buf_simple.c.obj
    [203/546] Building C object zephyr/lib/net_buf/CMakeFiles/lib__net_buf.dir/buf.c.obj
    [204/546] Building C object zephyr/lib/os/zvfs/CMakeFiles/lib__os__zvfs.dir/zvfs_eventfd.c.obj
    [205/546] Generating ../../../include/generated/posix/strsignal_table.h
    [206/546] Building C object zephyr/lib/os/zvfs/CMakeFiles/lib__os__zvfs.dir/zvfs_select.c.obj
    [207/546] Linking C static library zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a
    [208/546] Linking C static library zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a
    [209/546] Linking C static library zephyr/arch/common/libarch__common.a
    [210/546] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_base_addresses.c.obj
    [211/546] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_enabled_instances.c.obj
    [212/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/eventfd.c.obj
    [213/546] Linking C static library zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a
    [214/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/aio.c.obj
    [215/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/barrier.c.obj
    [216/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/perror.c.obj
    [217/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/file_system_r.c.obj
    [218/546] Linking C static library zephyr/lib/libc/picolibc/liblib__libc__picolibc.a
    [219/546] Linking C static library zephyr/lib/libc/common/liblib__libc__common.a
    [220/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/fd_mgmt.c.obj
    [221/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/fs.c.obj
    [222/546] Linking C static library zephyr/lib/net_buf/liblib__net_buf.a
    [223/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/fsync.c.obj
    [224/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/mqueue.c.obj
    [225/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/sleep.c.obj
    [226/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/net.c.obj
    [227/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/multi_process.c.obj
    [228/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/env.c.obj
    [229/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/device_io.c.obj
    [230/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/signal.c.obj
    [231/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/sysconf.c.obj
    [232/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/clock.c.obj
    [233/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/spinlock.c.obj
    [234/546] Generating linker_zephyr_pre0.cmd
    [235/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/timer.c.obj
    [236/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/semaphore.c.obj
    [237/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/confstr.c.obj
    [238/546] Building C object zephyr/lib/os/zvfs/CMakeFiles/lib__os__zvfs.dir/zvfs_poll.c.obj
    [239/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/timespec_to_timeout.c.obj
    [240/546] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_binding_headers.c.obj
    [241/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/rwlock.c.obj
    [242/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/cond.c.obj
    [243/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/grp.c.obj
    [244/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/pthread.c.obj
    [245/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/mutex.c.obj
    [246/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/pwd.c.obj
    [247/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/key.c.obj
    [248/546] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/nrf53/soc.c.obj
    [249/546] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/nrf53/nrf53_cpunet_mgmt.c.obj
    [250/546] Building C object zephyr/subsys/mgmt/mcumgr/util/CMakeFiles/subsys__mgmt__mcumgr__util.dir/src/zcbor_bulk.c.obj
    [251/546] Building C object zephyr/subsys/fs/CMakeFiles/subsys__fs.dir/fs.c.obj
    [252/546] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/common/soc_secure.c.obj
    [253/546] Building C object zephyr/subsys/mgmt/mcumgr/mgmt/CMakeFiles/subsys__mgmt__mcumgr__mgmt.dir/src/mgmt.c.obj
    [254/546] Building C object zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__img_mgmt.dir/src/img_mgmt.c.obj
    [255/546] Building C object zephyr/subsys/mgmt/mcumgr/smp/CMakeFiles/subsys__mgmt__mcumgr__smp.dir/src/smp.c.obj
    [256/546] Building C object zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__img_mgmt.dir/src/zephyr_img_mgmt.c.obj
    [257/546] Building C object zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__img_mgmt.dir/src/img_mgmt_state.c.obj
    [258/546] Building C object zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__img_mgmt.dir/src/img_mgmt_util.c.obj
    [259/546] Building C object zephyr/subsys/fs/CMakeFiles/subsys__fs.dir/fs_impl.c.obj
    [260/546] Building CXX object lib/core/adapters/CMakeFiles/core_adapters.dir/devices/devices_coap_controller.cpp.obj
    [261/546] Building C object zephyr/subsys/mgmt/mcumgr/grp/os_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__os_mgmt.dir/src/os_mgmt.c.obj
    [262/546] Building C object zephyr/subsys/mgmt/mcumgr/transport/CMakeFiles/subsys__mgmt__mcumgr__transport.dir/src/smp.c.obj
    [263/546] Building C object zephyr/subsys/mgmt/mcumgr/transport/CMakeFiles/subsys__mgmt__mcumgr__transport.dir/src/smp_uart.c.obj
    [264/546] Linking C static library zephyr/lib/os/zvfs/liblib__os__zvfs.a
    [265/546] Building C object zephyr/subsys/mgmt/mcumgr/transport/CMakeFiles/subsys__mgmt__mcumgr__transport.dir/src/serial_util.c.obj
    [266/546] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/random_entropy_device.c.obj
    [267/546] Linking C static library zephyr/subsys/mgmt/mcumgr/util/libsubsys__mgmt__mcumgr__util.a
    [268/546] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/random_xoshiro128.c.obj
    [269/546] Building C object modules/nrf/lib/dk_buttons_and_leds/CMakeFiles/..__nrf__lib__dk_buttons_and_leds.dir/dk_buttons_and_leds.c.obj
    [270/546] Linking C static library zephyr/soc/soc/nrf5340/libsoc__nordic.a
    [271/546] Linking C static library zephyr/subsys/mgmt/mcumgr/mgmt/libsubsys__mgmt__mcumgr__mgmt.a
    [272/546] Linking C static library zephyr/subsys/mgmt/mcumgr/smp/libsubsys__mgmt__mcumgr__smp.a
    [273/546] Building C object modules/nrf/subsys/bluetooth/mesh/CMakeFiles/..__nrf__subsys__bluetooth__mesh.dir/gen_onoff_cli.c.obj
    [274/546] Building C object modules/nrf/subsys/bluetooth/mesh/CMakeFiles/..__nrf__subsys__bluetooth__mesh.dir/model_utils.c.obj
    [275/546] Building C object modules/nrf/subsys/bluetooth/mesh/CMakeFiles/..__nrf__subsys__bluetooth__mesh.dir/lightness_cli.c.obj
    [276/546] Linking C static library zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/libsubsys__mgmt__mcumgr__grp__img_mgmt.a
    [277/546] Linking C static library zephyr/subsys/fs/libsubsys__fs.a
    [278/546] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/drivers/src/nrfx_qspi.c.obj
    [279/546] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir$WORKSPACE/modules/hal/nordic/nrfx/drivers/src/nrfx_spim.c.obj
    [280/546] Linking C static library zephyr/subsys/mgmt/mcumgr/grp/os_mgmt/libsubsys__mgmt__mcumgr__grp__os_mgmt.a
    [281/546] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/dma.c.obj
    [282/546] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/device.c.obj
    [283/546] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/init.c.obj
    [284/546] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/io.c.obj
    [285/546] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/irq.c.obj
    [286/546] Linking C static library zephyr/subsys/mgmt/mcumgr/transport/libsubsys__mgmt__mcumgr__transport.a
    [287/546] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/log.c.obj
    [288/546] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/shmem.c.obj
    [289/546] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/version.c.obj
    [290/546] Linking C static library zephyr/subsys/random/libsubsys__random.a
    [291/546] Linking C static library modules/nrf/lib/dk_buttons_and_leds/lib..__nrf__lib__dk_buttons_and_leds.a
    [292/546] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/softirq.c.obj
    [293/546] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/condition.c.obj
    [294/546] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/alloc.c.obj
    [295/546] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/log.c.obj
    [296/546] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/shmem.c.obj
    [297/546] Linking C static library modules/nrf/subsys/bluetooth/mesh/lib..__nrf__subsys__bluetooth__mesh.a
    [298/546] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/device.c.obj
    [299/546] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/init.c.obj
    [300/546] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/time.c.obj
    [301/546] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/irq.c.obj
    [302/546] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir$WORKSPACE/modules/crypto/mbedtls/library/platform.c.obj
    [303/546] Building CXX object CMakeFiles/app.dir/src/service_container.cpp.obj
    [304/546] Building CXX object CMakeFiles/app.dir/src/network_init.cpp.obj
    [305/546] Building CXX object CMakeFiles/app.dir/src/coap/coap_service_gateway.cpp.obj
    [306/546] Building CXX object CMakeFiles/app.dir/src/coap/coap_service_discovery.cpp.obj
    [307/546] Building CXX object CMakeFiles/app.dir/src/coap/server.cpp.obj
    [308/546] Building CXX object CMakeFiles/app.dir/src/coap/coap_service_nodes.cpp.obj
    [309/546] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/sys.c.obj
    [310/546] Building CXX object CMakeFiles/app.dir/src/coap/generics.cpp.obj
    [311/546] Linking C static library modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [312/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc32c_sw.c.obj
    [313/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc32_sw.c.obj
    [314/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc16_sw.c.obj
    [315/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc24_sw.c.obj
    [316/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc8_sw.c.obj
    [317/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc7_sw.c.obj
    [318/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc4_sw.c.obj
    [319/546] Building CXX object CMakeFiles/app.dir/src/coap/events.cpp.obj
    [320/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/cpp/abi/cpp_dtors.c.obj
    [321/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [322/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [323/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [324/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/heap/heap.c.obj
    [325/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [326/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
    [327/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [328/546] Building CXX object CMakeFiles/app.dir/src/coap/coap_service_mesh.cpp.obj
    [329/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/base64.c.obj
    [330/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [331/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [332/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [333/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/dec.c.obj
    [334/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj
    [335/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/hex.c.obj
    [336/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/last_section_id.c.obj
    [337/546] Linking C static library modules/nrf/subsys/nrf_security/src/zephyr/libmbedtls_zephyr.a
    [338/546] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [339/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/rb.c.obj
    [340/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/bitarray.c.obj
    [341/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/timeutil.c.obj
    [342/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/notify.c.obj
    [343/546] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/onoff.c.obj
    [344/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/nvs/nvs.c.obj
    [345/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/ipc_service.c.obj
    [346/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/lib/ipc_static_vrings.c.obj
    [347/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_mgmt.c.obj
    [348/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_cache.c.obj
    [349/546] Linking C static library modules/libmetal/libmetal/lib/libmetal.a
    [350/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/backends/ipc_rpmsg_static_vrings.c.obj
    [351/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/backends/log_backend_uart.c.obj
    [352/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj
    [353/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj
    [354/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/lib/ipc_rpmsg.c.obj
    [355/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [356/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/mem_mgmt/mem_attr.c.obj
    [357/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/mgmt/mcumgr/bootutil_hooks/nrf53_hooks.c.obj
    [358/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
    [359/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [360/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/dfu/img_util/flash_img.c.obj
    [361/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/stream/stream_flash.c.obj
    [362/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
    [363/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/coap/coap_link_format.c.obj
    [364/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/coap/coap_server.c.obj
    [365/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_store.c.obj
    [366/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/coap/coap.c.obj
    [367/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings.c.obj
    [368/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_init.c.obj
    [369/546] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/flash/flash_util.c.obj
    [370/546] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [371/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_nvs.c.obj
    [372/546] Building C object zephyr/CMakeFiles/zephyr.dir$WORKSPACE/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [373/546] Building C object zephyr/CMakeFiles/zephyr.dir$WORKSPACE/nrf/subsys/bluetooth/hci_vs_sdc.c.obj
    [374/546] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/addr.c.obj
    [375/546] Building C object zephyr/CMakeFiles/zephyr.dir$WORKSPACE/nrf/subsys/bluetooth/host_extensions/host_extensions.c.obj
    [376/546] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/data.c.obj
    [377/546] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_line.c.obj
    [378/546] Building C object zephyr/CMakeFiles/zephyr.dir$WORKSPACE/nrf/lib/boot_banner/banner.c.obj
    [379/546] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_core.c.obj
    [380/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/main.c.obj
    [381/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/cfg.c.obj
    [382/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/adv.c.obj
    [383/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/beacon.c.obj
    [384/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/net.c.obj
    [385/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/heartbeat.c.obj
    [386/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/app_keys.c.obj
    [387/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/msg.c.obj
    [388/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/access.c.obj
    [389/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/health_srv.c.obj
    [390/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/cfg_srv.c.obj
    [391/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/va.c.obj
    [392/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/transport.c.obj
    [393/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/adv_ext.c.obj
    [394/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/settings.c.obj
    [395/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/subnet.c.obj
    [396/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/crypto.c.obj
    [397/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/prov.c.obj
    [398/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/rpl.c.obj
    [399/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/provisioner.c.obj
    [400/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/pb_gatt.c.obj
    [401/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/provisionee.c.obj
    [402/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/pb_adv.c.obj
    [403/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/proxy_srv.c.obj
    [404/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/gatt_cli.c.obj
    [405/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/proxy_msg.c.obj
    [406/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/pb_gatt_cli.c.obj
    [407/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/cfg_cli.c.obj
    [408/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/health_cli.c.obj
    [409/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/cdb.c.obj
    [410/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/delayable_msg.c.obj
    [411/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/crypto_psa.c.obj
    [412/546] Building C object zephyr/subsys/dfu/boot/CMakeFiles/subsys__dfu__boot.dir/mcuboot.c.obj
    [413/546] Linking C static library zephyr/libzephyr.a
    [414/546] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/getnameinfo.c.obj
    [415/546] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/hostname.c.obj
    [416/546] Building C object zephyr/subsys/bluetooth/mesh/CMakeFiles/subsys__bluetooth__mesh.dir/rpr_cli.c.obj
    [417/546] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/getaddrinfo.c.obj
    [418/546] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/sockets.c.obj
    [419/546] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/sockets_misc.c.obj
    [420/546] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/socketpair.c.obj
    [421/546] Building C object zephyr/subsys/net/l2/ethernet/CMakeFiles/subsys__net__l2__ethernet.dir/ethernet.c.obj
    [422/546] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/sockets_inet.c.obj
    [423/546] Building C object zephyr/subsys/net/l2/ethernet/CMakeFiles/subsys__net__l2__ethernet.dir/arp.c.obj
    [424/546] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_timeout.c.obj
    [425/546] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_core.c.obj
    [426/546] Building C object zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/uname.c.obj
    [427/546] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_if.c.obj
    [428/546] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_mgmt.c.obj
    [429/546] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/utils.c.obj
    [430/546] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_pkt.c.obj
    [431/546] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_context.c.obj
    [432/546] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_tc.c.obj
    [433/546] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/icmp.c.obj
    [434/546] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/connection.c.obj
    [435/546] Linking C static library zephyr/subsys/dfu/boot/libsubsys__dfu__boot.a
    [436/546] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/ipv4.c.obj
    [437/546] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/icmpv4.c.obj
    [438/546] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/udp.c.obj
    [439/546] Building C object zephyr/subsys/net/lib/config/CMakeFiles/subsys__net__lib__config.dir/init.c.obj
    [440/546] Linking C static library zephyr/subsys/net/libsubsys__net.a
    [441/546] Building C object zephyr/drivers/bluetooth/CMakeFiles/drivers__bluetooth.dir/hci/ipc.c.obj
    [442/546] Building C object zephyr/subsys/net/lib/dhcpv4/CMakeFiles/subsys__net__lib__dhcpv4.dir/dhcpv4.c.obj
    [443/546] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [444/546] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_mcumgr.c.obj
    [445/546] Building C object zephyr/drivers/bluetooth/CMakeFiles/drivers__bluetooth.dir/hci/nrf53_support.c.obj
    [446/546] Linking C static library zephyr/subsys/net/l2/ethernet/libsubsys__net__l2__ethernet.a
    [447/546] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [448/546] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_psa_crypto.c.obj
    [449/546] Building C object zephyr/drivers/ethernet/CMakeFiles/drivers__ethernet.dir/eth_w5500.c.obj
    [450/546] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_bt_hci.c.obj
    [451/546] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/jesd216.c.obj
    [452/546] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [453/546] Linking C static library zephyr/lib/posix/options/liblib__posix__options.a
    [454/546] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/nrf_qspi_nor.c.obj
    [455/546] Linking C static library zephyr/subsys/bluetooth/mesh/libsubsys__bluetooth__mesh.a
    [456/546] Linking C static library zephyr/subsys/net/lib/config/libsubsys__net__lib__config.a
    [457/546] Linking C static library zephyr/subsys/net/lib/dhcpv4/libsubsys__net__lib__dhcpv4.a
    [458/546] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
    [459/546] Linking C static library zephyr/drivers/console/libdrivers__console.a
    [460/546] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/version.c.obj
    [461/546] Linking C static library zephyr/subsys/net/ip/libsubsys__net__ip.a
    [462/546] Linking C static library zephyr/drivers/bluetooth/libdrivers__bluetooth.a
    [463/546] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [464/546] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [465/546] Building C object zephyr/drivers/mbox/CMakeFiles/drivers__mbox.dir/mbox_nrfx_ipc.c.obj
    [466/546] Linking C static library zephyr/drivers/ethernet/libdrivers__ethernet.a
    [467/546] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/rpmsg/rpmsg_virtio.c.obj
    [468/546] Linking C static library zephyr/drivers/entropy/libdrivers__entropy.a
    [469/546] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/virtio/virtio.c.obj
    [470/546] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/virtio/virtqueue.c.obj
    [471/546] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/remoteproc_virtio.c.obj
    [472/546] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/remoteproc.c.obj
    [473/546] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/rpmsg/rpmsg.c.obj
    [474/546] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/elf_loader.c.obj
    [475/546] Building C object modules/zcbor/CMakeFiles/modules__zcbor.dir$WORKSPACE/modules/lib/zcbor/src/zcbor_common.c.obj
    [476/546] Building C object modules/zcbor/CMakeFiles/modules__zcbor.dir$WORKSPACE/modules/lib/zcbor/src/zcbor_decode.c.obj
    [477/546] Building C object modules/zcbor/CMakeFiles/modules__zcbor.dir$WORKSPACE/modules/lib/zcbor/src/zcbor_encode.c.obj
    [478/546] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/rsc_table_parser.c.obj
    [479/546] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/utils/utilities.c.obj
    [480/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj
    [481/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [482/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [483/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [484/546] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
    [485/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [486/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [487/546] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [488/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [489/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init_static.c.obj
    [490/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [491/546] Linking C static library zephyr/drivers/mbox/libdrivers__mbox.a
    [492/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [493/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/float.c.obj
    [494/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [495/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [496/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [497/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [498/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [499/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [500/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [501/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [502/546] Linking C static library modules/zcbor/libmodules__zcbor.a
    [503/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [504/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/priority_queues.c.obj
    [505/546] Linking C static library modules/open-amp/open-amp/lib/libopen_amp.a
    [506/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [507/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [508/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [509/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeslicing.c.obj
    [510/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [511/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [512/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [513/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [514/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
    [515/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
    [516/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [517/546] Building C object zephyr/kernel/CMakeFiles/kernel.dir/dynamic_disabled.c.obj
    [518/546] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/buf.c.obj
    [519/546] Building CXX object lib/mesh/adapters/CMakeFiles/mesh_adapters.dir/composition_data_service.cpp.obj
    [520/546] Building CXX object lib/mesh/adapters/CMakeFiles/mesh_adapters.dir/mesh_gateway.cpp.obj
    [521/546] Building CXX object lib/mesh/adapters/CMakeFiles/mesh_adapters.dir/node_repository_impl.cpp.obj
    [522/546] Building CXX object lib/mesh/adapters/CMakeFiles/mesh_adapters.dir/sources/identify_mesh_source.cpp.obj
    [523/546] Building CXX object lib/mesh/adapters/CMakeFiles/mesh_adapters.dir/new_node_controller.cpp.obj
    [524/546] Building CXX object lib/mesh/adapters/CMakeFiles/mesh_adapters.dir/sources/dimming_value_mesh_source.cpp.obj
    [525/546] Building CXX object lib/mesh/adapters/CMakeFiles/mesh_adapters.dir/sources/onoff_mesh_source.cpp.obj
    [526/546] Building CXX object lib/mesh/adapters/CMakeFiles/mesh_adapters.dir/sources/dimming_range_mesh_source.cpp.obj
    [527/546] Building CXX object lib/mesh/adapters/CMakeFiles/mesh_adapters.dir/mesh_manager.cpp.obj
    [528/546] Building CXX object lib/mesh/adapters/CMakeFiles/mesh_adapters.dir/register_actions_properties.cpp.obj
    [529/546] Building CXX object lib/mesh/adapters/CMakeFiles/mesh_adapters.dir/mesh_scanner.cpp.obj
    [530/546] Building C object lib/mesh/adapters/CMakeFiles/mesh_adapters.dir/gateway_composition_data.c.obj
    [531/546] Building CXX object CMakeFiles/app.dir/src/coap/coap_service_devices.cpp.obj
    [532/546] Linking C static library zephyr/kernel/libkernel.a
    [533/546] Linking CXX static library lib/core/adapters/libcore_adapters.a
    [534/546] Linking C static library zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a
    [535/546] Building CXX object CMakeFiles/app.dir/src/main.cpp.obj
    [536/546] Building CXX object lib/mesh/adapters/CMakeFiles/mesh_adapters.dir/cbor_converter.cpp.obj
    [537/546] Building CXX object lib/mesh/adapters/CMakeFiles/mesh_adapters.dir/coap/coap_controller_nodes.cpp.obj
    [538/546] Building CXX object lib/mesh/adapters/CMakeFiles/mesh_adapters.dir/coap/coap_controller_scan.cpp.obj
    [539/546] Linking CXX static library lib/mesh/adapters/libmesh_adapters.a
    [540/546] Linking CXX static library app/libapp.a
    [541/546] Linking CXX executable zephyr/zephyr_pre0.elf
    [542/546] Generating linker.cmd
    [543/546] Generating isr_tables.c, isr_tables_vt.ld, isr_tables_swi.ld
    [544/546] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [545/546] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [546/546] Linking CXX executable zephyr/zephyr.elf
               FLASH:      327436 B       608 KB     52.59%
                 RAM:      129960 B       256 KB     49.58%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from $WORKSPACE/$PROJECT/app/build_nrf5340dk/app/zephyr/zephyr.elf for board: nrf5340dk
    image.py: sign the payload
    [31/67] Generating ../b0_container.hex
    [32/67] Performing build step for 'mcuboot'
    [1/222] Preparing syscall dependency handling
    [2/222] Generating ../../zephyr/include/generated/app_commit.h
    [3/222] Generating ../../zephyr/include/generated/ncs_commit.h
    [4/222] Generating ../../zephyr/include/generated/zephyr_commit.h
    [5/222] Generating include/generated/zephyr/app_version.h
    [6/222] Generating misc/generated/syscalls_subdirs.trigger
    [7/222] Generating ../../zephyr/include/generated/ncs_version.h
    [8/222] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [9/222] Generating include/generated/device-api-sections.ld, include/generated/device-api-sections.cmake
    [10/222] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, include/generated/zephyr/syscall_list.h
    [11/222] Generating include/generated/zephyr/driver-validation.h
    [12/222] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-size.h
    [13/222] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [14/222] Generating include/generated/zephyr/offsets.h
    [15/222] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.0.99 ($WORKSPACE/zephyr), build: 9c5b2d0faa44
    [16/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc7_sw.c.obj
    [17/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc4_sw.c.obj
    [18/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc24_sw.c.obj
    [19/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc32_sw.c.obj
    [20/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc8_sw.c.obj
    [21/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc32c_sw.c.obj
    [22/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/crc/crc16_sw.c.obj
    [23/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [24/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/heap/heap.c.obj
    [25/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [26/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [27/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [28/222] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [29/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj
    [30/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [31/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/base64.c.obj
    [32/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/dec.c.obj
    [33/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/hex.c.obj
    [34/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/timeutil.c.obj
    [35/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [36/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [37/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/last_section_id.c.obj
    [38/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/bitarray.c.obj
    [39/222] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [40/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/rb.c.obj
    [41/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/notify.c.obj
    [42/222] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
    [43/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/onoff.c.obj
    [44/222] Building C object zephyr/CMakeFiles/zephyr.dir$WORKSPACE/nrf/lib/boot_banner/banner.c.obj
    [45/222] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
    [46/222] Building C object zephyr/CMakeFiles/zephyr.dir$WORKSPACE/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [47/222] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [48/222] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/flash/flash_util.c.obj
    [49/222] Building C object zephyr/CMakeFiles/zephyr.dir$WORKSPACE/nrfxlib/crypto/nrf_cc312_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
    [50/222] Building C object zephyr/CMakeFiles/zephyr.dir$WORKSPACE/nrfxlib/crypto/nrf_cc312_platform/src/nrf_cc3xx_platform_no_mutex_zephyr.c.obj
    [51/222] Building C object zephyr/CMakeFiles/zephyr.dir$WORKSPACE/bootloader/mcuboot/boot/boot_serial/src/zcbor_bulk.c.obj
    [52/222] Building ASM object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi_on_reset.S.obj
    [53/222] Generating zephyr/autogen-enckey.c
    [54/222] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault_s.S.obj
    [55/222] Generating zephyr/autogen-pubkey.c
    [56/222] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/fatal.c.obj
    [57/222] Building C object zephyr/CMakeFiles/zephyr.dir$WORKSPACE/bootloader/mcuboot/boot/zephyr/serial_adapter.c.obj
    [58/222] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi.c.obj
    [59/222] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault.c.obj
    [60/222] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/exc_exit.c.obj
    [61/222] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [62/222] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread_abort.c.obj
    [63/222] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [64/222] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/reset.S.obj
    [65/222] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/scb.c.obj
    [66/222] Building C object CMakeFiles/app.dir/io.c.obj
    [67/222] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fpu.c.obj
    [68/222] Building C object CMakeFiles/app.dir/os.c.obj
    [69/222] Building C object CMakeFiles/app.dir/keys.c.obj
    [70/222] Building C object CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
    [71/222] Building C object CMakeFiles/app.dir/main.c.obj
    [72/222] Building C object CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
    [73/222] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
    [74/222] Building C object CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
    [75/222] Generating linker_zephyr_pre0.cmd
    [76/222] Building C object CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/src/platform_util.c.obj
    [77/222] Building C object CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
    [78/222] Building C object CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/src/asn1parse.c.obj
    [79/222] Building C object CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_decrypt.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_decrypt.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf53/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/lib/zcbor/include -I/../include -I$WORKSPACE/bootloader/mcuboot/boot/boot_serial/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/src -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc312_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_decrypt.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_decrypt.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_decrypt.c.obj -c $WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_decrypt.c
    $WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_decrypt.c:33:10: fatal error: tinycrypt/aes.h: No such file or directory
       33 | #include <tinycrypt/aes.h>
    compilation terminated.
    [80/222] Building C object CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_encrypt.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_encrypt.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf53/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/lib/zcbor/include -I/../include -I$WORKSPACE/bootloader/mcuboot/boot/boot_serial/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/src -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc312_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_encrypt.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_encrypt.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_encrypt.c.obj -c $WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_encrypt.c
    $WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/aes_encrypt.c:33:10: fatal error: tinycrypt/aes.h: No such file or directory
    [81/222] Building C object CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ctr_mode.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ctr_mode.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf53/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/lib/zcbor/include -I/../include -I$WORKSPACE/bootloader/mcuboot/boot/boot_serial/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/src -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc312_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ctr_mode.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ctr_mode.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ctr_mode.c.obj -c $WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ctr_mode.c
    $WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ctr_mode.c:33:10: fatal error: tinycrypt/constants.h: No such file or directory
       33 | #include <tinycrypt/constants.h>
    [82/222] Building C object CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ecc_dh.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ecc_dh.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf53/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/lib/zcbor/include -I/../include -I$WORKSPACE/bootloader/mcuboot/boot/boot_serial/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/src -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc312_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ecc_dh.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ecc_dh.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ecc_dh.c.obj -c $WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ecc_dh.c
    $WORKSPACE/bootloader/mcuboot/ext/tinycrypt/lib/source/ecc_dh.c:57:10: fatal error: tinycrypt/constants.h: No such file or directory
       57 | #include <tinycrypt/constants.h>
    [83/222] Building C object CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf53/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/lib/zcbor/include -I/../include -I$WORKSPACE/bootloader/mcuboot/boot/boot_serial/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/src -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc312_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj -c $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/tlv.c
    In file included from $WORKSPACE/bootloader/mcuboot/boot/bootutil/include/bootutil/enc_key.h:33,
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_priv.h:43,
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/tlv.c:25:
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/include/bootutil/crypto/aes_ctr.h:19:6: error: #error "NONE!!!One crypto backend must be defined: either MBED_TLS or TINYCRYPT or PSA"
       19 |     #error "NONE!!!One crypto backend must be defined: either MBED_TLS or TINYCRYPT or PSA"
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/include/bootutil/crypto/aes_ctr.h:29:6: error: #error "One crypto backend must be defined: either MBED_TLS or TINYCRYPT or PSA"
       29 |     #error "One crypto backend must be defined: either MBED_TLS or TINYCRYPT or PSA"
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/include/bootutil/crypto/aes_ctr.h:34:6: error: #error "One crypto backend must be defined: either MBED_TLS or TINYCRYPT or PSA"
       34 |     #error "One crypto backend must be defined: either MBED_TLS or TINYCRYPT or PSA"
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/include/bootutil/enc_key.h:46:5: error: unknown type name 'bootutil_aes_ctr_context'
       46 |     bootutil_aes_ctr_context aes_ctr;
    [84/222] Building C object CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_ecdsa.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_ecdsa.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf53/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/lib/zcbor/include -I/../include -I$WORKSPACE/bootloader/mcuboot/boot/boot_serial/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/src -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc312_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_ecdsa.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_ecdsa.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_ecdsa.c.obj -c $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_ecdsa.c
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_ecdsa.c:34:
    [85/222] Building C object CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf53/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/lib/zcbor/include -I/../include -I$WORKSPACE/bootloader/mcuboot/boot/boot_serial/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/src -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc312_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj -c $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_validate.c
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/image_validate.c:55:
    [86/222] Building C object CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf53/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/lib/zcbor/include -I/../include -I$WORKSPACE/bootloader/mcuboot/boot/boot_serial/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/src -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc312_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj -c $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_misc.c
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_misc.c:25:
    [87/222] Building C object CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_nsib.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_nsib.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf53/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/lib/zcbor/include -I/../include -I$WORKSPACE/bootloader/mcuboot/boot/boot_serial/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/src -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc312_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_nsib.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_nsib.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_nsib.c.obj -c $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_nsib.c
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_nsib.c:25:
    [88/222] Building C object zephyr/CMakeFiles/zephyr.dir$WORKSPACE/bootloader/mcuboot/boot/boot_serial/src/boot_serial.c.obj
    FAILED: zephyr/CMakeFiles/zephyr.dir$WORKSPACE/bootloader/mcuboot/boot/boot_serial/src/boot_serial.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/zephyr/kernel/include -I$WORKSPACE/zephyr/arch/arm/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf53/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/lib/zcbor/include -I/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/boot/boot_serial/include -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/src -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc312_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT zephyr/CMakeFiles/zephyr.dir$WORKSPACE/bootloader/mcuboot/boot/boot_serial/src/boot_serial.c.obj -MF zephyr/CMakeFiles/zephyr.dir$WORKSPACE/bootloader/mcuboot/boot/boot_serial/src/boot_serial.c.obj.d -o zephyr/CMakeFiles/zephyr.dir$WORKSPACE/bootloader/mcuboot/boot/boot_serial/src/boot_serial.c.obj -c $WORKSPACE/bootloader/mcuboot/boot/boot_serial/src/boot_serial.c
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/include/../src/bootutil_priv.h:43,
                     from $WORKSPACE/bootloader/mcuboot/boot/boot_serial/src/boot_serial.c:70:
    [89/222] Building C object CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf53/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/lib/zcbor/include -I/../include -I$WORKSPACE/bootloader/mcuboot/boot/boot_serial/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/src -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc312_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj -c $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c:37:
    [90/222] Building C object CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf53/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/lib/zcbor/include -I/../include -I$WORKSPACE/bootloader/mcuboot/boot/boot_serial/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/src -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc312_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj -c $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_move.c
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/swap_move.c:25:
    [91/222] Building C object CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf53/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/lib/zcbor/include -I/../include -I$WORKSPACE/bootloader/mcuboot/boot/boot_serial/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/src -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc312_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/loader.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/loader.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/loader.c.obj -c $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/loader.c
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/loader.c:42:
    [92/222] Building C object CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
    FAILED: CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
    ccache /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMCUBOOT_SLOT0_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT0_EXPECTED_WRITE_SIZE=4 -DMCUBOOT_SLOT1_EXPECTED_ERASE_SIZE=4096 -DMCUBOOT_SLOT1_EXPECTED_WRITE_SIZE=4 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I$WORKSPACE/bootloader/mcuboot/boot/zephyr/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/include -I$WORKSPACE/bootloader/mcuboot/ext/mbedtls-asn1/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr -I$WORKSPACE/zephyr/include -I$WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated -I$WORKSPACE/zephyr/soc/nordic -I$WORKSPACE/zephyr/soc/nordic/nrf53/. -I$WORKSPACE/zephyr/soc/nordic/common/. -I$WORKSPACE/nrf/include -I$WORKSPACE/nrf/tests/include -I$WORKSPACE/modules/hal/cmsis/CMSIS/Core/Include -I$WORKSPACE/zephyr/modules/cmsis/. -I$WORKSPACE/nrf/modules/hal_nordic/. -I$WORKSPACE/modules/hal/nordic/nrfx -I$WORKSPACE/modules/hal/nordic/nrfx/drivers/include -I$WORKSPACE/modules/hal/nordic/nrfx/mdk -I$WORKSPACE/zephyr/modules/hal_nordic/nrfx/. -I$WORKSPACE/modules/lib/zcbor/include -I/../include -I$WORKSPACE/bootloader/mcuboot/boot/boot_serial/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/src -I$WORKSPACE/nrfxlib/crypto/nrf_oberon/include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/.. -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../include -I$WORKSPACE/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem $WORKSPACE/zephyr/lib/libc/minimal/include -isystem $WORKSPACE/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem $WORKSPACE/nrfxlib/crypto/nrf_cc312_platform/include -fno-strict-aliasing -Os -imacros $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot/zephyr/include/generated/zephyr/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/ef4fc6722e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros $WORKSPACE/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=$WORKSPACE/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=$WORKSPACE/zephyr=ZEPHYR_BASE -fmacro-prefix-map=$WORKSPACE=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj -MF CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj.d -o CMakeFiles/app.dir$WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj -c $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c
    In file included from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:26:
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/include/bootutil/crypto/ecdh_p256.h:18:6: error: #error "NONE!!! One crypto backend must be defined: either MBED_TLS or TINYCRYPT"
       18 |     #error "NONE!!! One crypto backend must be defined: either MBED_TLS or TINYCRYPT"
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/include/bootutil/crypto/ecdh_p256.h:28:6: error: #error "One crypto backend must be defined: either MBED_TLS or TINYCRYPT"
       28 |     #error "One crypto backend must be defined: either MBED_TLS or TINYCRYPT"
    In file included from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:36:
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/include/bootutil/crypto/hmac_sha256.h:17:6: error: #error "One crypto backend must be defined: either MBED_TLS or TINYCRYPT"
       17 |     #error "One crypto backend must be defined: either MBED_TLS or TINYCRYPT"
                     from $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:43:
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c: In function 'parse_ec256_enckey':
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:187:16: error: 'NUM_ECC_BYTES' undeclared (first use in this function)
      187 |     if (len != NUM_ECC_BYTES) {
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:187:16: note: each undeclared identifier is reported only once for each function it appears in
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c: In function 'hkdf':
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:270:5: error: unknown type name 'bootutil_hmac_sha256_context'; did you mean 'bootutil_sha_context'?
      270 |     bootutil_hmac_sha256_context hmac;
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:288:5: warning: implicit declaration of function 'bootutil_hmac_sha256_init'; did you mean 'bootutil_sha_init'? [-Wimplicit-function-declaration]
      288 |     bootutil_hmac_sha256_init(&hmac);
          |     bootutil_sha_init
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:291:10: warning: implicit declaration of function 'bootutil_hmac_sha256_set_key' [-Wimplicit-function-declaration]
      291 |     rc = bootutil_hmac_sha256_set_key(&hmac, salt, BOOTUTIL_CRYPTO_SHA256_DIGEST_SIZE);
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:296:10: warning: implicit declaration of function 'bootutil_hmac_sha256_update'; did you mean 'bootutil_sha_update'? [-Wimplicit-function-declaration]
      296 |     rc = bootutil_hmac_sha256_update(&hmac, ikm, ikm_len);
          |          bootutil_sha_update
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:301:10: warning: implicit declaration of function 'bootutil_hmac_sha256_finish'; did you mean 'bootutil_sha_finish'? [-Wimplicit-function-declaration]
      301 |     rc = bootutil_hmac_sha256_finish(&hmac, prk, BOOTUTIL_CRYPTO_SHA256_DIGEST_SIZE);
          |          bootutil_sha_finish
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:306:5: warning: implicit declaration of function 'bootutil_hmac_sha256_drop'; did you mean 'bootutil_sha_drop'? [-Wimplicit-function-declaration]
      306 |     bootutil_hmac_sha256_drop(&hmac);
          |     bootutil_sha_drop
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c: In function 'boot_decrypt_key':
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:415:5: error: unknown type name 'bootutil_ecdh_p256_context'; did you mean 'bootutil_sha_context'?
      415 |     bootutil_ecdh_p256_context ecdh_p256;
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:421:5: error: unknown type name 'bootutil_hmac_sha256_context'; did you mean 'bootutil_sha_context'?
      421 |     bootutil_hmac_sha256_context hmac;
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:422:5: error: unknown type name 'bootutil_aes_ctr_context'; did you mean 'bootutil_sha_context'?
      422 |     bootutil_aes_ctr_context aes_ctr;
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:122:24: error: 'NUM_ECC_BYTES' undeclared (first use in this function)
      122 | #define SHARED_KEY_LEN NUM_ECC_BYTES
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:424:20: note: in expansion of macro 'SHARED_KEY_LEN'
      424 |     uint8_t shared[SHARED_KEY_LEN];
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:425:25: error: 'BOOTUTIL_CRYPTO_AES_CTR_KEY_SIZE' undeclared (first use in this function); did you mean 'BOOTUTIL_CRYPTO_SHA256_BLOCK_SIZE'?
      425 |     uint8_t derived_key[BOOTUTIL_CRYPTO_AES_CTR_KEY_SIZE + BOOTUTIL_CRYPTO_SHA256_DIGEST_SIZE];
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:429:21: error: 'BOOTUTIL_CRYPTO_AES_CTR_BLOCK_SIZE' undeclared (first use in this function); did you mean 'BOOTUTIL_CRYPTO_SHA256_BLOCK_SIZE'?
      429 |     uint8_t counter[BOOTUTIL_CRYPTO_AES_CTR_BLOCK_SIZE];
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:489:5: warning: implicit declaration of function 'bootutil_ecdh_p256_init'; did you mean 'bootutil_sha_init'? [-Wimplicit-function-declaration]
      489 |     bootutil_ecdh_p256_init(&ecdh_p256);
          |     bootutil_sha_init
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:491:10: warning: implicit declaration of function 'bootutil_ecdh_p256_shared_secret' [-Wimplicit-function-declaration]
      491 |     rc = bootutil_ecdh_p256_shared_secret(&ecdh_p256, &buf[EC_PUBK_INDEX], private_key, shared);
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:492:5: warning: implicit declaration of function 'bootutil_ecdh_p256_drop'; did you mean 'bootutil_sha_drop'? [-Wimplicit-function-declaration]
      492 |     bootutil_ecdh_p256_drop(&ecdh_p256);
          |     bootutil_sha_drop
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:576:5: warning: implicit declaration of function 'bootutil_aes_ctr_init'; did you mean 'bootutil_sha_init'? [-Wimplicit-function-declaration]
      576 |     bootutil_aes_ctr_init(&aes_ctr);
          |     bootutil_sha_init
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:578:9: warning: implicit declaration of function 'bootutil_aes_ctr_drop'; did you mean 'bootutil_sha_drop'? [-Wimplicit-function-declaration]
      578 |         bootutil_aes_ctr_drop(&aes_ctr);
          |         bootutil_sha_drop
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:582:10: warning: implicit declaration of function 'bootutil_aes_ctr_set_key' [-Wimplicit-function-declaration]
      582 |     rc = bootutil_aes_ctr_set_key(&aes_ctr, derived_key);
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:589:10: warning: implicit declaration of function 'bootutil_aes_ctr_decrypt' [-Wimplicit-function-declaration]
      589 |     rc = bootutil_aes_ctr_decrypt(&aes_ctr, counter, &buf[EC_CIPHERKEY_INDEX], BOOTUTIL_CRYPTO_AES_CTR_KEY_SIZE, 0, enckey);
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:429:13: warning: unused variable 'counter' [-Wunused-variable]
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:428:13: warning: unused variable 'private_key' [-Wunused-variable]
      428 |     uint8_t private_key[PRIV_KEY_LEN];
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:425:13: warning: unused variable 'derived_key' [-Wunused-variable]
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:424:13: warning: unused variable 'shared' [-Wunused-variable]
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c: In function 'boot_enc_encrypt':
    $WORKSPACE/bootloader/mcuboot/boot/bootutil/src/encrypted.c:729:5: warning: implicit declaration of function 'bootutil_aes_ctr_encrypt' [-Wimplicit-function-declaration]
      729 |     bootutil_aes_ctr_encrypt(&enc->aes_ctr, nonce, buf, sz, blk_off, buf);
    [40/67] Generating ../tfm_nonsecure.hex
    FAILED: _sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build $WORKSPACE/$PROJECT/app/build_nrf5340dk/_sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build
    cd $WORKSPACE/$PROJECT/app/build_nrf5340dk/mcuboot && /opt/nordic/ncs/toolchains/ef4fc6722e/Cellar/cmake/3.21.0/bin/cmake --build .
    FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/cmake --build $WORKSPACE/$PROJECT/app/build_nrf5340dk
    I also noted that adding
    CONFIG_TINYCRYPT=y
    Changes the error to conflicting declarations.
    Does that clarify things, or is more needed?
  • Ok, perhaps you can evaluate adding DFU to one of the samples in the SDK then, such as v3.0.2\nrf\samples\bluetooth\peripheral_uart, and see if you run into the same issue?
    If you do, can you then compare the implementation with the solution from the github repository from DevAcademy:
    https://github.com/NordicDeveloperAcademy/ncs-inter/tree/main/l9/l9_e3_sol
    Make sure that you have all the files, such as sysbuild.conf, sysbuild\mcuboot.conf and sysbuild\mcuboot.overlay.
    Edvin
  • Thanks, I'll try that.
    One thing I noticed is that app/build/mcuboot/zephyr/.config will always contain
    # CONFIG_BOOT_ECDSA_TINYCRYPT is not set
    regardless of the settings in my app/sysbuild/mcuboot.conf, even if I set it via mcuboot_menuconfig and save the minimal config to app/sysbuild/mcuboot.conf.
    Looking at the build log I see
    Parsing $WORKSPACE/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration '$WORKSPACE/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp_defconfig'
    Merged configuration '$WORKSPACE/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration '$WORKSPACE/ble-mesh-gateway/app/sysbuild/mcuboot.conf'
    Merged configuration '$WORKSPACE/nrf/modules/mcuboot/tfm.conf'
    Merged configuration '$WORKSPACE/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf'
    Merged configuration '$WORKSPACE/nrf/subsys/bootloader/image/log_minimal.conf'
    Merged configuration '$WORKSPACE/bootloader/mcuboot/boot/zephyr/external_crypto.conf'
    Merged configuration '$WORKSPACE/$PROJ/app/build_nrf5340dk/mcuboot/zephyr/.config.sysbuild'
    Configuration saved to '$WORKSPACE/$PROJ/app/build_nrf5340dk/mcuboot/zephyr/.config'
    when I grep "BOOT_ECDSA_TINYCRYPT" on those files, I only see it in my mcuboot.conf and it's set to y.
    $WORKSPACE/$PROJ/app/sysbuild/mcuboot.conf:CONFIG_BOOT_ECDSA_TINYCRYPT=y
    $WORKSPACE/$PROJ/app/build_nrf5340dk/mcuboot/zephyr/.config:# CONFIG_BOOT_ECDSA_TINYCRYPT is not set
    That doesn't make any sense to me.
  • Can you please try to copy all the content from release.conf, and paste it in prj.conf, for debugging purposes. Then build without the command:
    -- -DSB_CONF_FILE=$WORKSPACE/$PROJECT/app/sysbuild_release.conf -DEXTRA_CONF_FILE='release.conf'
    Can you provide the build log in this case?
    Edvin
