Connection error/loop using IOS central
I'm getting exactly the same as this ticket now I've switched to extended advertising. Was there any resolution?
Android is fine, iOS 18.5 phone sits in a connect/error/disconnect loop. I've tried with my own app and with nRF Connect app.
[00:20:07.866,281] <inf> app: Disconnected (reason: 62)
[00:20:07.866,307] <inf> app: BT Recycle
[00:20:07.866,324] <inf> remote: Starting Extended Advertising
[00:20:07.879,200] <inf> app: Connected.
[00:20:08.046,400] <wrn> bt_conn: conn 0x20002c08 failed to establish. RF noise?
[00:20:08.046,597] <inf> app: Disconnected (reason: 62)
[00:20:08.046,623] <inf> app: BT Recycle
[00:20:08.046,640] <inf> remote: Starting Extended Advertising
[00:20:08.052,527] <inf> app: Connected.
Here is my connect/disconnect code, nothing special here. Note I also get similar results with the advertiser sample, this gives "Disconnected, reason 0x3E" error.
 void on_connected(struct bt_conn *conn, uint8_t err)
	int rc;
	if(err) {
		 LOG_ERR("connection err: %d", err);
		 return;
	 current_conn = bt_conn_ref(conn);
	 LOG_INF("Connected.");
 void on_disconnected(struct bt_conn *conn, uint8_t reason)
	 LOG_INF("Disconnected (reason: %d)", reason);
	 if(current_conn) {
		 bt_conn_unref(current_conn);
		 current_conn = NULL;
