OpenThread Periodic Parent Search
I have been trying to get Periodic Parent Search active on my nRF54L15DK (and also on an nRF52840DK) without success. My approach has been:
  • Use the OpenThread CLI sample project provided in the nRF Connect SDK (v3.1.1) as the base
  • Changed the `prj.conf`to the following
# Enable OpenThread
CONFIG_OPENTHREAD=y
# Network shell
CONFIG_SHELL=y
CONFIG_OPENTHREAD_SHELL=y
CONFIG_SHELL_ARGC_MAX=26
CONFIG_SHELL_CMD_BUFF_SIZE=416
# Increase Settings storage size
CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x8000
# Enable OpenThread features set
CONFIG_OPENTHREAD_NORDIC_LIBRARY_MASTER=y
CONFIG_GPIO_SHELL=y
CONFIG_LOG=y
# Use separate thread for logging
CONFIG_LOG_MODE_DEFERRED=y
# Increase max log level to informative
CONFIG_LOG_MAX_LEVEL=4
# Option for configuring log level in this sample
CONFIG_OT_COMMAND_LINE_INTERFACE_LOG_LEVEL_DBG=y
# Enable OpenThread logging
CONFIG_OPENTHREAD_DEBUG=y
# Option for configuring log level in OpenThread
CONFIG_OPENTHREAD_LOG_LEVEL_DEBG=y
# Disable UART logging backend
CONFIG_LOG_BACKEND_UART=y
CONFIG_SHELL_LOG_BACKEND=y
CONFIG_OPENTHREAD_PARENT_SEARCH=y
CONFIG_OPENTHREAD_PARENT_SEARCH_CHECK_INTERVAL=10
CONFIG_OPENTHREAD_PARENT_SEARCH_BACKOFF_INTERVAL=1
  • Flashed that firmware after a pristine build
  • Use the CLI to connect to an existing Thread network
ot ifconfig down
ot thread stop
ot dataset clear
ot dataset set active [TLV]
ot ifconfig up
ot thread start
ot routereligible disable
  • Confirmed succesfull connection both on the device, and in the OpenThread Border Router UI (using the topology tab)
  • Moved the freshly flashed nordic DK entirely out of the network's range; observed no mention of parent search in the cli debug logs
  • Also moved it out of range of its parent, and moved it in range to another router (potential new parent)
    • Again no mention of parent searching, nor a new connection to the potential parent
I did see this documentation that metions that it might be a good idea to use the OpenThread API and IPv6 stack directly, but I do not know whether that's the culprit, nor do I know how to switch to it.
Am I missing something?
