npmx drivers
I am using a STM32 with the NPMX drivers.
I am having a few issues and wanted to see if there are recommendations.
Issue 1:
disabling the interrupts does not seem to work
	// Clear all events before enabling interrupts, just in case other interrupt source was configured before.
	for (uint32_t i = 0; i < NPMX_EVENT_GROUP_COUNT; i++) {
	        npmx_err = npmx_core_event_interrupt_disable(&npm1300_instance, (npmx_event_group_t)i, NPMX_EVENT_GROUP_ALL_EVENTS_MASK);
	        if(npmx_err == NPMX_SUCCESS)
	        		printf("Event Cleared\n");
	        		osDelay(100);
the above code comes from the PORTING Guide.
when i run that block it looks like it never reaches the NPMX_SUCCESS
I have attached the I2C transactions
it looks like it is writing 0x00 and not 0xFF as I would expect.
Issue 2:
I am trying to set a GPIO as an Interrupt.
	npmx_error_t ret;
	npmx_gpio_t *npmx_gpio_struct;
	// Set GPIO 3 as GPIO Interrupt.
	npmx_gpio_struct = npmx_gpio_get(&npm1300_instance, 3);
	ret = npmx_gpio_mode_set(&npmx_gpio_struct, NPMX_GPIO_MODE_OUTPUT_IRQ);
when i run this it does not look like I get the Index of 3 and I cannot tell about the pointer to the I2C Instance
then the call to npmx_gpio_mode_set throws a hard Fault.
I have tried it with declaring a separate npmx_gpio_t structure and inline declaration like the porting guide.  They both throw faults.
which I guess I should ask if the init function call from the porting guide
static npmx_error_t my_i2c_write_function(void * p_context, uint32_t register_address, uint8_t * p_data, size_t num_of_bytes);
static npmx_error_t my_i2c_read_function(void * p_context, uint32_t register_address, uint8_t * p_data, size_t num_of_bytes);
static void my_npmx_initialization_function(void)
    npm1300_backend.p_read = my_i2c_read_function;
    npm1300_backend.p_write = my_i2c_write_function;
    npm1300_backend.p_context = NULL; // Optional context for our use
    npmx_error_t npmx_err = npmx_core_init(&npm1300_instance, &npm1300_backend, NULL, true);
    // TODO: Verify that npmx_err == NPMX_SUCCESS
should give me a I2C like this
it appears to write 0x05 and 0x09, then read 0x00.
is this expected from the init Function?
I am looking more into it, but any guidance can help
  • I have everything "working" but i have a few issues and questions.
    Let me describe my configuration:
    I have a STM32 running FreeRTOS.  I have the PMIC configured for the ADC to automeasure every 1 Second.  all USB, VBAT, ADC, Charger will generate an Interrupt on GPIO3 from the PMIC.
    The STM has a ISR that simply sets a flag the an interrupt occured.
    I have one thread that runs this:
      for(;;)
    	printf("\n myTask01 \n"); //WRC print Task
    	if (pmic_interrupt) {
    		  npmx_core_interrupt(&npm1300_instance);
    		  npmx_core_proc(&npm1300_instance);
    		  pmic_interrupt = false;
    		  osDelay(1000);
    I have a second code that runs the Fuel Gauge
      for(;;)
    	printf("\n myTask02 \n"); //WRC print Task
    	fuel_gauge_update(&npm1300_instance);
    	osDelay(1000);
    I have been playing with thread priorities and delay numbers, but i cant get a consistent result.
    The first task sometimes reports the battery voltage or events if I pull the USB.  like this:
    myTask01
    Battery: 4125 mV.
    State: VBUS_CONNECTED_CHARGING_CC.
    State: BATTERY_CONNECTED.
    but most of the time it only prints
    myTask01
    so i know it is entering the task, but not reading the ADC for VBAT.
    either missing the interrupt or the threads are not allotted enough time
    the Fuel Gauge task only prints
    myTask02
    Constant current charging
    Reading ADC measurements failed.
    V: -0.000, I: 0.000, T: -0.00, SoC: 0.00, TTE: nan, TTF: nan
    I guess my questions are
    what is the timing needed for each task to complete the PMIC and Fuel Gauge procedures?
    any thought on why I always get "adc failed" in the Fuel Gauge?
    do i need to configure the ADC different?
  • A new update.  I have the Fuel Gauge responding with actual data.
    I am still having the issue with Task o1 only responding with the battery voltage once.  but now I have the code getting trapped in task 2.
    I guess I need to understand the configuration of the PMIC to correctly operate.
    I have the PMIC generating an interrupt on events from the battery, USB, and charger.  this event toggles a gpio that sets a flag in the STM ISR that is read by a task to run the npmx_core_interrupt() and npmx_Core_proc() functions.
    is this the correct way to do it?  how should I configure the PMIC to guarantee the works correctly? (ADC settings, Event settings, ..)?
    I am not sure why the Fuel gauge only responds once and holds the device in the second task.  is there a specific config that is needed that is conflicted with how i set up for the other task?
    I have been testing for a while, but not making much progress.  any thought are helpful
    thanks
  • Is the interrupt level- or edge-triggered?
    Level-triggered: you should get another interrupt automatically if another event occurred while processing the current events. No additional logic should be needed in this case besides setting the flag in the interrupt handler and disabling the interrupt source until after you have called the processing function. Then it needs to be re-enabled.
    Edge-triggered: the interrupt source doesn't have to be disabled here, but the processing function must be called until the interrupt pin is in the inactive state AND the flag is false. Only ensuring this, the interrupt will be able to fire again.
    I would recommend using the first option. I don't see you re-enabling the interrupt after you call npmx_core_proc. Something to look into.
    As for the potential concurrency issues, I don't have much experience with FreeRTOS to recommend anything specific, but some things to look into are:
    Are threads preemptive or cooperative? If a thread can be preempted, you need to ensure that the I2C access is exclusive to prevent any issues there, e.g. with a mutex.
    Same goes for interrupt handlers. Ideally they should not do any I2C activity at all. But from your description it already seems to be the case.
    The time required to read out the ADC conversion results would depend on your I2C bus frequency. Generally, it is just a few milliseconds. The fuel gauge process function should take even less.
    Overall, guessing the source of the issues here is maybe not the best approach. Are you able to just attach a debugger to your program and do some investigations that way?
    And without seeing any of the actual code you're writing I'm not able to do more specific suggestions here. There is no one correct way to configure everything on the PMIC, this would largely depend on the use case. But there are definitely wrong ways to do that, which would be much easier to identify having code at hand.
  • Sergei;
    Thanks for the response.
    The interrupt is edge driven.  I disable it when i enter the ISR and enable it after the call to npmx_core_proc().
    My 1st thread seems to be working fine.
    the issue is the 2nd thread.
    it finished the fule_gauge_update() and hangs int he 2nd thread.  never exiting.
    I will continue to work on that.
    but one question i have is that i enable the GPIO interrupt on the nPM1300 for the ADC, Changer, USB, Battery.
    but it looks like the Fuel_gauge is using a polling event system.  is this true?  Is this causing an issue between the 2?  should i disable the interrupts for the adc, usb, ... when i exit thread one then enable them again when i enter?
    I am stepping through the code, but I am still trying to get a grasp on what is going on.
    I will be on vacation until January, so I will get back to this then.
    Again I appreciate your help
  • Is the fuel_gauge_update() function you're referring to was copied from the fuel_gauge sample in the npmx-zephyr repository? I'll base my answer on this assumption.
    If you look at the function, you can see that it does multiple things:
    1. Get (this involves npmx driver/I2C) and report VBUS state to the fuel gauge library
    2. Get (npmx/I2C) and report Charger state to the fuel gauge library
    3. Get the ADC results (npmx/I2C)
    4. Trigger VBAT/IBAT, trigger NTC measurements (npmx/I2C). Yes, in this order, that's why we trigger the very first measurement before we init fuel gauge in the sample (see main.c)
    5. Call nrf_fuel_gauge_process() with the gotten results.
    As you see, there's a lot of I2C communication involved in this function call. Since you have a dedicated ADC task in your program, I don't recommend to blindly copy this function. There is no point in having an automatically triggered ADC configuration with a pin interrupt on measurement result readiness and then manually trigger the measurements again in the fuel_gauge_update() function.
    Overall, the samples are just that - they are sample code. They are intended to show examples of how different PMIC components could be used in an application. They are a good starting point for development, but you cannot treat their functions (like fuel_gauge_update in this case) as some sort of library code. This is just a reference implementation which must be adapted to your needs.
