ncs-zigbee - Configuration issue with custom cluster
I write this information for the sake of completeness. I don´t need Zigbee2MQTT support from you. Instead, support with the Zigbee firmware is required.
I´m working on an open-source Zigbee environment sensor, based on an nRF54L14, and I have a problem with a customized cluster for VOC. You can find the complete repo with the firmware here:
https://github.com/Kampi/BeeLight
I use Zigbee2MQTT for the Zigbee network, and I get a configuration error when starting the service. The Zigbee2MQTT team told me that this issue is firmware-based. You can see the ticket for this problem here:
https://github.com/Koenkk/zigbee-herdsman-converters/issues/10831#issuecomment-3568319658
I don´t understand why this issue is related to the VOC cluster only, because the cluster looks basically the same. But I don´t have a deep understanding of ZBOSS and the underlying mechanism, so I need some help to understand the issue and a potential solution. The complete VOC cluster looks like this
#ifndef ZB_ZCL_BEELIGHT_VOC_MEASUREMENT_H_
#define ZB_ZCL_BEELIGHT_VOC_MEASUREMENT_H_
#include <zcl/zb_zcl_common.h>
#include <zcl/zb_zcl_commands.h>
enum zb_zcl_voc_cluster_attr_e
    ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_VALUE_ID        = 0x0000,
    ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_ID    = 0x0001,
    ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_ID    = 0x0002,
    ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_TOLERANCE_ID    = 0x0003,
/** @brief Default value for VOC Measurement cluster revision global attribute */
#define ZB_ZCL_BEELIGHT_VOC_MEASUREMENT_CLUSTER_REVISION_DEFAULT             ((zb_uint16_t)0x0001U)
/** @brief MeasuredValue attribute unknown value */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_VALUE_UNKNOWN                   ((zb_uint16_t)0x8000)
/** @brief MinMeasuredValue attribute minimum value */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_MIN_VALUE             ((zb_uint16_t)0x0000)
/** @brief MinMeasuredValue attribute maximum value */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_MAX_VALUE             ((zb_uint16_t)0x2710)
/** @brief MinMeasuredValue attribute invalid value */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_INVALID               ((zb_uint16_t)0x8000)
/** @brief MaxMeasuredValue attribute minimum value */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_MIN_VALUE             ((zb_uint16_t)0x0000)
/** @brief MaxMeasuredValue attribute maximum value */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_MAX_VALUE             ((zb_uint16_t)0x2710)
/** @brief MaxMeasuredValue attribute invalid value */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_INVALID               ((zb_uint16_t)0x8000)
/** @brief Tolerance attribute minimum value */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_TOLERANCE_MIN_VALUE             ((zb_uint16_t)0x0000)
/** @brief Tolerance attribute maximum value */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_TOLERANCE_MAX_VALUE             ((zb_uint16_t)0x000F)
/** @brief Default value for Value attribute */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_VALUE_DEFAULT_VALUE             ((zb_uint16_t)0x0000)
#define ZB_SET_ATTR_DESCR_WITH_ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_VALUE_ID(data_ptr)          \
    ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_VALUE_ID,                                              \
    ZB_ZCL_ATTR_TYPE_U16,        \
    ZB_ZCL_ATTR_ACCESS_READ_ONLY | ZB_ZCL_ATTR_ACCESS_REPORTING,                                \
    (ZB_ZCL_NON_MANUFACTURER_SPECIFIC),                                                         \
    (void*) data_ptr        \
#define ZB_SET_ATTR_DESCR_WITH_ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_ID(data_ptr)      \
    ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_ID,                                          \
    ZB_ZCL_ATTR_ACCESS_READ_ONLY,                                                               \
    (void*) data_ptr        \
#define ZB_SET_ATTR_DESCR_WITH_ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_ID(data_ptr)      \
    ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_ID,                                          \
    (void*) data_ptr        \
#define ZB_SET_ATTR_DESCR_WITH_ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_TOLERANCE_ID(data_ptr)      \
    ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_TOLERANCE_ID,                                          \
    ZB_ZCL_ATTR_TYPE_U8,        \
    (void*) data_ptr        \
/** @brief Number of attributes mandatory for reporting in BeeLight VOC Measurement cluster */
#define ZB_ZCL_BEELIGHT_VOC_MEASUREMENT_REPORT_ATTR_COUNT 1
/** @brief Declare attribute list for BeeLight VOC Measurement cluster - server side
    @param attr_list - attribute list name
    @param value - pointer to variable to store MeasuredValue attribute
    @param min_value - pointer to variable to store MinMeasuredValue attribute
    @param max_value - pointer to variable to store MAxMeasuredValue attribute
    @param tolerance - pointer to variable to store Tolerance attribute
#define ZB_ZCL_DECLARE_BEELIGHT_VOC_MEASUREMENT_ATTRIB_LIST(attr_list, value, min_value, max_value, tolerance)  \
    ZB_ZCL_START_DECLARE_ATTRIB_LIST_CLUSTER_REVISION(attr_list, ZB_ZCL_BEELIGHT_VOC_MEASUREMENT)               \
    ZB_ZCL_SET_ATTR_DESC(ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_VALUE_ID, (value))                                \
    ZB_ZCL_SET_ATTR_DESC(ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_ID, (min_value))                        \
    ZB_ZCL_SET_ATTR_DESC(ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_ID, (max_value))                        \
    ZB_ZCL_SET_ATTR_DESC(ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_TOLERANCE_ID, (tolerance))                        \
    ZB_ZCL_FINISH_DECLARE_ATTRIB_LIST
void zb_zcl_beelight_voc_measurement_init_server(void);
void zb_zcl_beelight_voc_measurement_init_client(void);
#define ZB_ZCL_CLUSTER_ID_BEELIGHT_VOC_MEASUREMENT_SERVER_ROLE_INIT zb_zcl_beelight_voc_measurement_init_server
#define ZB_ZCL_CLUSTER_ID_BEELIGHT_VOC_MEASUREMENT_CLIENT_ROLE_INIT zb_zcl_beelight_voc_measurement_init_client
#endif /* ZB_ZCL_BEELIGHT_VOC_MEASUREMENT_H_ */
#include "zb_common.h"
#if defined (ZB_ZCL_SUPPORT_CLUSTER_BEELIGHT_VOC_MEASUREMENT)
#include "zb_zcl.h"
#include "zb_aps.h"
#include "zcl/zb_zcl_common.h"
zb_ret_t check_value_beelight_voc_measurement_server(zb_uint16_t attr_id, zb_uint8_t endpoint, zb_uint8_t *value);
void zb_zcl_beelight_voc_measurement_write_attr_hook_server(zb_uint8_t endpoint, zb_uint16_t attr_id, zb_uint8_t *new_value, zb_uint16_t manuf_code);
    zb_zcl_add_cluster_handlers(ZB_ZCL_CLUSTER_ID_BEELIGHT_VOC_MEASUREMENT,
                                ZB_ZCL_CLUSTER_SERVER_ROLE,
                                check_value_beelight_voc_measurement_server,
                                zb_zcl_beelight_voc_measurement_write_attr_hook_server,
                                (zb_zcl_cluster_handler_t)NULL);
void zb_zcl_voc_measurement_init_client(void)
                                ZB_ZCL_CLUSTER_CLIENT_ROLE,
                                (zb_zcl_cluster_check_value_t)NULL,
                                (zb_zcl_cluster_write_attr_hook_t)NULL,
    zb_ret_t ret = RET_OK;
    zb_int16_t val = ZB_ZCL_ATTR_GET16(value);
    TRACE_MSG(TRACE_ZCL1, "> check_value_beelight_voc_measurement, attr_id %d, val %d", (FMT__D_D, attr_id, val));
    switch (attr_id)
        case ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_VALUE_ID:
            if (ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_VALUE_UNKNOWN == val)
                ret = RET_OK;
                zb_zcl_attr_t *attr_desc = zb_zcl_get_attr_desc_a(endpoint,
                    ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_ID);
                ZB_ASSERT(attr_desc);
                ret = (ZB_ZCL_GET_ATTRIBUTE_VAL_16(attr_desc) == ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_INVALID ||
                    ZB_ZCL_GET_ATTRIBUTE_VAL_16(attr_desc) <= val)
                    ? RET_OK : RET_ERROR;
                if (ret)
                        ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_ID);
                    ret = ZB_ZCL_GET_ATTRIBUTE_VAL_16(attr_desc) == ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_INVALID ||
                            val <= ZB_ZCL_GET_ATTRIBUTE_VAL_16(attr_desc)
        case ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_ID:
            ret = ((ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_MIN_VALUE <= val) &&
                    (val <= ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_MAX_VALUE)) ||
                    (ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_INVALID == val)
        case ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_ID:
            ret = ( (ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_MIN_VALUE <= ZB_ZCL_ATTR_GET16(value)) &&
                    (ZB_ZCL_ATTR_GET16(value) <= ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_MAX_VALUE) )
    TRACE_MSG(TRACE_ZCL1, "< check_value_beelight_voc_measurement ret %hd", (FMT__H, ret));
    return ret;
    ZVUNUSED(new_value);
    ZVUNUSED(endpoint);
    ZVUNUSED(manuf_code);
    ZVUNUSED(attr_id);
    TRACE_MSG(TRACE_ZCL1, ">> zb_zcl_beelight_voc_measurement_write_attr_hook endpoint %hd, attr_id 0x%x, manuf_code 0x%x",
                (FMT__H_D_D, endpoint, attr_id, manuf_code));
    /* All attributes in this cluster are read-only. Do nothing */
    TRACE_MSG(TRACE_ZCL1, "<< zb_zcl_beelight_voc_measurement_write_attr_hook", (FMT__0));
#endif /* ZB_ZCL_SUPPORT_CLUSTER_VOC_MEASUREMENT */
As far as I understand the error message, the error happens somewhere during the configuration of this cluster. Where does this configuration happen and how can I enable debug outputs to see the issue in the firmware? Or is something wrong with the cluster definition (it´s based on the temperature measurement cluster). The current firmware doesn´t output any Zigbee-related errors yet.
  • Is there any log from your nRF indicating that the bind request failed?
    Based on this:
    Can you please try (on the zigbee2MQTT side) to set up the report for 5000ms (or an interval that includes 5000ms) to see if that helps?
    Edvin
    This change doesn´t help. I´ve asked Copilot today and he suggested me the following:
    The error still occurs even with the new interval values. The problem appears to be on the firmware side—the device does not accept the reporting configuration. Let me check the firmware implementation of the VOC cluster:
    I’ve found the issue! The ZB_ZCL_ATTR_ACCESS_REPORTING flag is set in the cluster, but that alone is not sufficient. I took a closer look at the cluster implementation:
    0001-Add-cluster-for-IAQ-VOC-and-CO2.patch
    The root cause is on the firmware side. The cluster has ZB_ZCL_ATTR_ACCESS_REPORTING set, but this does not automatically enable the ability to accept reporting configurations. The device must explicitly support configureReporting commands.
    Since the firmware does not appear to fully support this, the workaround on the Zigbee2MQTT side is to completely disable reporting. Instead, Zigbee2MQTT can periodically poll the values:
    Change:
    beelight.mjs +1 -1
    I set reporting: null for all three affected clusters (IAQ, CO₂, VOC). This disables the configureReporting calls for these clusters.
    Summary:
    The firmware supports the ZB_ZCL_ATTR_ACCESS_REPORTING flag (i.e., the device is capable of sending reports), but it apparently does not implement the configureReporting command handler to receive and store reporting configurations.
    Possible solutions:
    1. Zigbee2MQTT side (implemented now):
    reporting: null disables configureReporting calls. The values are still received when the device sends them (e.g., on change or periodically).
    2. Firmware side (long-term solution):
    You need to implement a zb_zcl_cluster_handler_t handler in the firmware that processes ZCL_CMD_CONFIG_REPORT and stores the reporting configuration.
    After this change:
    Restart Zigbee2MQTT
    “Reconfigure” the device or re-pair it
    import * as m from "zigbee-herdsman-converters/lib/modernExtend";
    export default {
        zigbeeModel: ["BeeLight_v2"],
        model: "BeeLight_v2",
        vendor: "Kampi",
        description: "Zigbee-based Light and Environment Sensor (https://github.com/Kampi/BeeLight)",
        extend: [m.BeeLight_iaq({reporting: null}), m.BeeLight_co2({reporting: null}), m.BeeLight_voc({reporting: null}), m.battery(), m.illuminance(), m.temperature(), m.pressure(), m.humidity()],
    So, with this change, I don´t get any errors but I don´t have reporting. So the issue is located somewhere in the reporting stuff. He suggested this change to me:
    Does it make sense? It seems to be working for the other clusters and these clusters don´t set the parameter to "True".
  • Setting this last parameter to false will skip the "is this writable" check.
    "You need to implement a zb_zcl_cluster_handler_t handler in the firmware that processes ZCL_CMD_CONFIG_REPORT and stores the reporting configuration."
    Did you do this? What does it look like?
    Have you tried debugging the zb_zcl_status_t zb_zcl_set_attr_val() function, to see if it encounters any errors?
    Edvin
  • Hi Edwin,
    the only thing I have is this for all of the three clusters:
    I´ve used the humidity cluster as an example. But these clusters also don´t set the handler, so I assume that these clusters don´t support reporting as well?
    This doesn't tell me much, I am afraid.
    You do have an app running on the nRF54L15, and it is not identical to any of our samples, right? In this application, did you implement a zb_zcl_cluster_handler_t handler that processes the ZCL_CMD_CONFIG_REPORT and stores the reporting configuration? If so, can you point me to it?
    BR,
    Edvin
