ncs-zigbee - Configuration issue with custom cluster
I write this information for the sake of completeness. I don´t need Zigbee2MQTT support from you. Instead, support with the Zigbee firmware is required.
I´m working on an open-source Zigbee environment sensor, based on an nRF54L14, and I have a problem with a customized cluster for VOC. You can find the complete repo with the firmware here:
https://github.com/Kampi/BeeLight
I use Zigbee2MQTT for the Zigbee network, and I get a configuration error when starting the service. The Zigbee2MQTT team told me that this issue is firmware-based. You can see the ticket for this problem here:
https://github.com/Koenkk/zigbee-herdsman-converters/issues/10831#issuecomment-3568319658
I don´t understand why this issue is related to the VOC cluster only, because the cluster looks basically the same. But I don´t have a deep understanding of ZBOSS and the underlying mechanism, so I need some help to understand the issue and a potential solution. The complete VOC cluster looks like this
#ifndef ZB_ZCL_BEELIGHT_VOC_MEASUREMENT_H_
#define ZB_ZCL_BEELIGHT_VOC_MEASUREMENT_H_
#include <zcl/zb_zcl_common.h>
#include <zcl/zb_zcl_commands.h>
enum zb_zcl_voc_cluster_attr_e
    ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_VALUE_ID        = 0x0000,
    ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_ID    = 0x0001,
    ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_ID    = 0x0002,
    ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_TOLERANCE_ID    = 0x0003,
/** @brief Default value for VOC Measurement cluster revision global attribute */
#define ZB_ZCL_BEELIGHT_VOC_MEASUREMENT_CLUSTER_REVISION_DEFAULT             ((zb_uint16_t)0x0001U)
/** @brief MeasuredValue attribute unknown value */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_VALUE_UNKNOWN                   ((zb_uint16_t)0x8000)
/** @brief MinMeasuredValue attribute minimum value */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_MIN_VALUE             ((zb_uint16_t)0x0000)
/** @brief MinMeasuredValue attribute maximum value */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_MAX_VALUE             ((zb_uint16_t)0x2710)
/** @brief MinMeasuredValue attribute invalid value */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_INVALID               ((zb_uint16_t)0x8000)
/** @brief MaxMeasuredValue attribute minimum value */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_MIN_VALUE             ((zb_uint16_t)0x0000)
/** @brief MaxMeasuredValue attribute maximum value */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_MAX_VALUE             ((zb_uint16_t)0x2710)
/** @brief MaxMeasuredValue attribute invalid value */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_INVALID               ((zb_uint16_t)0x8000)
/** @brief Tolerance attribute minimum value */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_TOLERANCE_MIN_VALUE             ((zb_uint16_t)0x0000)
/** @brief Tolerance attribute maximum value */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_TOLERANCE_MAX_VALUE             ((zb_uint16_t)0x000F)
/** @brief Default value for Value attribute */
#define ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_VALUE_DEFAULT_VALUE             ((zb_uint16_t)0x0000)
#define ZB_SET_ATTR_DESCR_WITH_ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_VALUE_ID(data_ptr)          \
    ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_VALUE_ID,                                              \
    ZB_ZCL_ATTR_TYPE_U16,        \
    ZB_ZCL_ATTR_ACCESS_READ_ONLY | ZB_ZCL_ATTR_ACCESS_REPORTING,                                \
    (ZB_ZCL_NON_MANUFACTURER_SPECIFIC),                                                         \
    (void*) data_ptr        \
#define ZB_SET_ATTR_DESCR_WITH_ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_ID(data_ptr)      \
    ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_ID,                                          \
    ZB_ZCL_ATTR_ACCESS_READ_ONLY,                                                               \
    (void*) data_ptr        \
#define ZB_SET_ATTR_DESCR_WITH_ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_ID(data_ptr)      \
    ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_ID,                                          \
    (void*) data_ptr        \
#define ZB_SET_ATTR_DESCR_WITH_ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_TOLERANCE_ID(data_ptr)      \
    ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_TOLERANCE_ID,                                          \
    ZB_ZCL_ATTR_TYPE_U8,        \
    (void*) data_ptr        \
/** @brief Number of attributes mandatory for reporting in BeeLight VOC Measurement cluster */
#define ZB_ZCL_BEELIGHT_VOC_MEASUREMENT_REPORT_ATTR_COUNT 1
/** @brief Declare attribute list for BeeLight VOC Measurement cluster - server side
    @param attr_list - attribute list name
    @param value - pointer to variable to store MeasuredValue attribute
    @param min_value - pointer to variable to store MinMeasuredValue attribute
    @param max_value - pointer to variable to store MAxMeasuredValue attribute
    @param tolerance - pointer to variable to store Tolerance attribute
#define ZB_ZCL_DECLARE_BEELIGHT_VOC_MEASUREMENT_ATTRIB_LIST(attr_list, value, min_value, max_value, tolerance)  \
    ZB_ZCL_START_DECLARE_ATTRIB_LIST_CLUSTER_REVISION(attr_list, ZB_ZCL_BEELIGHT_VOC_MEASUREMENT)               \
    ZB_ZCL_SET_ATTR_DESC(ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_VALUE_ID, (value))                                \
    ZB_ZCL_SET_ATTR_DESC(ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_ID, (min_value))                        \
    ZB_ZCL_SET_ATTR_DESC(ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_ID, (max_value))                        \
    ZB_ZCL_SET_ATTR_DESC(ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_TOLERANCE_ID, (tolerance))                        \
    ZB_ZCL_FINISH_DECLARE_ATTRIB_LIST
void zb_zcl_beelight_voc_measurement_init_server(void);
void zb_zcl_beelight_voc_measurement_init_client(void);
#define ZB_ZCL_CLUSTER_ID_BEELIGHT_VOC_MEASUREMENT_SERVER_ROLE_INIT zb_zcl_beelight_voc_measurement_init_server
#define ZB_ZCL_CLUSTER_ID_BEELIGHT_VOC_MEASUREMENT_CLIENT_ROLE_INIT zb_zcl_beelight_voc_measurement_init_client
#endif /* ZB_ZCL_BEELIGHT_VOC_MEASUREMENT_H_ */
#include "zb_common.h"
#if defined (ZB_ZCL_SUPPORT_CLUSTER_BEELIGHT_VOC_MEASUREMENT)
#include "zb_zcl.h"
#include "zb_aps.h"
#include "zcl/zb_zcl_common.h"
zb_ret_t check_value_beelight_voc_measurement_server(zb_uint16_t attr_id, zb_uint8_t endpoint, zb_uint8_t *value);
void zb_zcl_beelight_voc_measurement_write_attr_hook_server(zb_uint8_t endpoint, zb_uint16_t attr_id, zb_uint8_t *new_value, zb_uint16_t manuf_code);
    zb_zcl_add_cluster_handlers(ZB_ZCL_CLUSTER_ID_BEELIGHT_VOC_MEASUREMENT,
                                ZB_ZCL_CLUSTER_SERVER_ROLE,
                                check_value_beelight_voc_measurement_server,
                                zb_zcl_beelight_voc_measurement_write_attr_hook_server,
                                (zb_zcl_cluster_handler_t)NULL);
void zb_zcl_voc_measurement_init_client(void)
                                ZB_ZCL_CLUSTER_CLIENT_ROLE,
                                (zb_zcl_cluster_check_value_t)NULL,
                                (zb_zcl_cluster_write_attr_hook_t)NULL,
    zb_ret_t ret = RET_OK;
    zb_int16_t val = ZB_ZCL_ATTR_GET16(value);
    TRACE_MSG(TRACE_ZCL1, "> check_value_beelight_voc_measurement, attr_id %d, val %d", (FMT__D_D, attr_id, val));
    switch (attr_id)
        case ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_VALUE_ID:
            if (ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_VALUE_UNKNOWN == val)
                ret = RET_OK;
                zb_zcl_attr_t *attr_desc = zb_zcl_get_attr_desc_a(endpoint,
                    ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_ID);
                ZB_ASSERT(attr_desc);
                ret = (ZB_ZCL_GET_ATTRIBUTE_VAL_16(attr_desc) == ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_INVALID ||
                    ZB_ZCL_GET_ATTRIBUTE_VAL_16(attr_desc) <= val)
                    ? RET_OK : RET_ERROR;
                if (ret)
                        ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_ID);
                    ret = ZB_ZCL_GET_ATTRIBUTE_VAL_16(attr_desc) == ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_INVALID ||
                            val <= ZB_ZCL_GET_ATTRIBUTE_VAL_16(attr_desc)
        case ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_ID:
            ret = ((ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_MIN_VALUE <= val) &&
                    (val <= ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_MAX_VALUE)) ||
                    (ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MIN_VALUE_INVALID == val)
        case ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_ID:
            ret = ( (ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_MIN_VALUE <= ZB_ZCL_ATTR_GET16(value)) &&
                    (ZB_ZCL_ATTR_GET16(value) <= ZB_ZCL_ATTR_BEELIGHT_VOC_MEASUREMENT_MAX_VALUE_MAX_VALUE) )
    TRACE_MSG(TRACE_ZCL1, "< check_value_beelight_voc_measurement ret %hd", (FMT__H, ret));
    return ret;
    ZVUNUSED(new_value);
    ZVUNUSED(endpoint);
    ZVUNUSED(manuf_code);
    ZVUNUSED(attr_id);
    TRACE_MSG(TRACE_ZCL1, ">> zb_zcl_beelight_voc_measurement_write_attr_hook endpoint %hd, attr_id 0x%x, manuf_code 0x%x",
                (FMT__H_D_D, endpoint, attr_id, manuf_code));
    /* All attributes in this cluster are read-only. Do nothing */
    TRACE_MSG(TRACE_ZCL1, "<< zb_zcl_beelight_voc_measurement_write_attr_hook", (FMT__0));
#endif /* ZB_ZCL_SUPPORT_CLUSTER_VOC_MEASUREMENT */
As far as I understand the error message, the error happens somewhere during the configuration of this cluster. Where does this configuration happen and how can I enable debug outputs to see the issue in the firmware? Or is something wrong with the cluster definition (it´s based on the temperature measurement cluster). The current firmware doesn´t output any Zigbee-related errors yet.
  • I don't think those patches work for me. They don't output anything. It just fails silently. The only instances I have of ZB_BEELIGHT_DECLARE_CO2_MEASUREMENT_ATTRIB_LIST is in main.c and in the patch file itself.
    That is why I was hoping you could provide them.
  • Ah now I get your point. Are you testing with Windows? AFAIK patching causes trouble on Windows. I will send you the modified files and the locations later.
  • Hi
    please use these modified files. Just replace the folder from your ncs-zigbee addon.
    ncs-zigbee.zip
    Thank you. That was it.
    So I fiddled around with this for a bit.
    There were two issues. One was that the command for enabling subscribtions was wrong (or the configuration of the attribute was incorrect).
    Without any modifications to your application, this command worked:
    uart:~$ zcl subscribe on 0x98e5 10 0x1A0B 0x0104 0x00 33 5 20
    As you can see, I replaced 16 with 33. This parameter in particular, refers to the attribute type, and it is a hexadecimal number. In your zb_beelight_voc_cluster.h:
    #define ZB_SET_ATTR_DESCR_WITH_ZB_BEELIGHT_ATTR_VOC_MEASUREMENT_VALUE_ID(data_ptr)      \
        ZB_BEELIGHT_ATTR_VOC_MEASUREMENT_VALUE_ID,                                          \
        (void*) data_ptr        \
    you state that this attribute is using ZB_ZCL_ATTR_TYPE_U16, which is defined as 0x21 (=33). This is the parameter you should use in your "subscribe on" command.
    However, it still failed, but increasing the BEELIGHT_REPORT_ATTR_COUNT to 10 sovled this issue.
    Now I was able to both bind, read and enable subscriptions on the device.
    Edvin
  • Hi Edvin,
    thanks for testing it! I´m curious. After all, I never checked the attribute count because I was sure it was correct...
    Anyway, I think it was a good lesson for me because this shell application is really helpful, and it looks like Zigbee2Mqtt is now working as well. I also updated the configuration files to the latest version of Z2M (tested with my DK).
    I think we can close the thread here.
    Many thanks for your patience Slight smile.
    Feel free to share the GitHub project from me as a reference for using ncs-zigbee together with Zigbee2Mqtt and custom clusters, if someone faces similar issues.
