Assistance Required: Multiple Matter Certification Failures on nRF54L15 (NCS v3.1.1 / Matter 1.4.2)
Hi, support team,
I am conducting self-testing on a device developed with NCS 3.1.1, using the test versions corresponding to v2.13+summer2025 and Matter 1.4.2.
I have already resolved some of the issues, but there are a few problems that I don't know how to solve.
Here is the log which may help you to analyze the problem:
UI_Test_Run_2025_11_27_06_49_05.log
Here is the matter file:
Valve.matter.txt
And here is my configuration:
  "config": {
    "test_parameters": {
      "endpoint": 0,
      "timeout": 300
    "network": {
      "wifi": {
        "ssid": "testharness",
        "password": "wifi-password"
      "thread": {
        "rcp_serial_path": "/dev/ttyACM0",
        "rcp_baudrate": 115200,
        "on_mesh_prefix": "fd11:22::/64",
        "network_interface": "wlan0",
        "dataset": {
          "channel": "15",
          "panid": "0x1234",
          "extpanid": "1111111122222222",
          "networkkey": "00112233445566778899aabbccddeeff",
          "networkname": "DEMO-EP0"
        "otbr_docker_image": null
    "dut_config": {
      "discriminator": "2002",
      "setup_code": "20022003",
      "pairing_mode": "ble-thread",
      "chip_timeout": null,
      "chip_use_paa_certs": true,
      "trace_log": true,
      "enhanced_setup_flow": null
  "pics": {
    "clusters": {
      "Base": {
        "name": "Base",
        "items": {
          "MCORE.DT_SW_COMP": {
            "number": "MCORE.DT_SW_COMP",
            "enabled": false
          "MCORE.COM.BLE": {
            "number": "MCORE.COM.BLE",
            "enabled": true
          "MCORE.COM.WIFI_2P4GHZ": {
            "number": "MCORE.COM.WIFI_2P4GHZ",
            "enabled": false
          "MCORE.COM.WIFI_5GHZ": {
            "number": "MCORE.COM.WIFI_5GHZ",
            "enabled": false
          "MCORE.COM.WIFI": {
            "number": "MCORE.COM.WIFI",
            "enabled": false
          "MCORE.COM.ETH": {
            "number": "MCORE.COM.ETH",
            "enabled": false
          "MCORE.COM.THR": {
            "number": "MCORE.COM.THR",
            "enabled": true
          "MCORE.COM.WIRELESS": {
            "number": "MCORE.COM.WIRELESS",
            "enabled": true
          "MCORE.ROLE.COMMISSIONER": {
            "number": "MCORE.ROLE.COMMISSIONER",
            "enabled": false
          "MCORE.ROLE.COMMISSIONEE": {
            "number": "MCORE.ROLE.COMMISSIONEE",
            "enabled": true
          "MCORE.ROLE.CONTROLLER": {
            "number": "MCORE.ROLE.CONTROLLER",
            "enabled": false
          "MCORE.DLOG.S.UTCTIMESTAMP": {
            "number": "MCORE.DLOG.S.UTCTIMESTAMP",
            "enabled": false
          "MCORE.DLOG.S.TIMESINCEBOOT": {
            "number": "MCORE.DLOG.S.TIMESINCEBOOT",
            "enabled": false
          "MCORE.DD.CHIP_DEV": {
            "number": "MCORE.DD.CHIP_DEV",
            "enabled": true
          "MCORE.DD.DEV_LOCK": {
            "number": "MCORE.DD.DEV_LOCK",
            "enabled": false
          "MCORE.DD.DEV_BARRIER": {
            "number": "MCORE.DD.DEV_BARRIER",
            "enabled": false
          "MCORE.DD.IE": {
            "number": "MCORE.DD.IE",
            "enabled": false
          "MCORE.DD.QR": {
            "number": "MCORE.DD.QR",
            "enabled": false
          "MCORE.DD.MANUAL_PC": {
            "number": "MCORE.DD.MANUAL_PC",
            "enabled": true
          "MCORE.DD.NFC": {
            "number": "MCORE.DD.NFC",
            "enabled": false
          "MCORE.DD.UI": {
            "number": "MCORE.DD.UI",
            "enabled": false
          "MCORE.DD.COMM_DISCOVERY": {
            "number": "MCORE.DD.COMM_DISCOVERY",
            "enabled": false
          "MCORE.DD.CONCATENATED_QR_CODE": {
            "number": "MCORE.DD.CONCATENATED_QR_CODE",
            "enabled": false
          "MCORE.DD.CTRL_CONCATENATED_QR_CODE_1": {
            "number": "MCORE.DD.CTRL_CONCATENATED_QR_CODE_1",
            "enabled": false
          "MCORE.DD.CTRL_CONCATENATED_QR_CODE_1_INORDER": {
            "number": "MCORE.DD.CTRL_CONCATENATED_QR_CODE_1_INORDER",
            "enabled": false
          "MCORE.DD.CTRL_CONCATENATED_QR_CODE_2": {
            "number": "MCORE.DD.CTRL_CONCATENATED_QR_CODE_2",
            "enabled": false
          "MCORE.DD.DISCOVERY_BLE": {
            "number": "MCORE.DD.DISCOVERY_BLE",
            "enabled": false
          "MCORE.DD.DISCOVERY_PAF": {
            "number": "MCORE.DD.DISCOVERY_PAF",
            "enabled": false
          "MCORE.DD.DISCOVERY_IP": {
            "number": "MCORE.DD.DISCOVERY_IP",
            "enabled": false
          "MCORE.DD.DISCOVERY_SOFTAP": {
            "number": "MCORE.DD.DISCOVERY_SOFTAP",
            "enabled": false
          "MCORE.DD.STANDARD_COMM_FLOW": {
            "number": "MCORE.DD.STANDARD_COMM_FLOW",
            "enabled": false
          "MCORE.DD.NON_CONCURRENT_CONNECTION": {
            "number": "MCORE.DD.NON_CONCURRENT_CONNECTION",
            "enabled": false
          "MCORE.DD.USER_INTENT_COMM_FLOW": {
            "number": "MCORE.DD.USER_INTENT_COMM_FLOW",
            "enabled": false
          "MCORE.DD.CUSTOM_COMM_FLOW": {
            "number": "MCORE.DD.CUSTOM_COMM_FLOW",
            "enabled": false
          "MCORE.DD.MANUAL_PC_COMMISSIONING": {
            "number": "MCORE.DD.MANUAL_PC_COMMISSIONING",
            "enabled": false
          "MCORE.DD.11_MANUAL_PC": {
            "number": "MCORE.DD.11_MANUAL_PC",
            "enabled": false
          "MCORE.DD.21_MANUAL_PC": {
            "number": "MCORE.DD.21_MANUAL_PC",
            "enabled": false
          "MCORE.DD.PHYSICAL_TAMPERING": {
            "number": "MCORE.DD.PHYSICAL_TAMPERING",
            "enabled": true
          "MCORE.DD.SCAN_NFC": {
            "number": "MCORE.DD.SCAN_NFC",
            "enabled": false
          "MCORE.DD.QR_COMMISSIONING": {
            "number": "MCORE.DD.QR_COMMISSIONING",
            "enabled": false
          "MCORE.DD.SCAN_QR_CODE": {
            "number": "MCORE.DD.SCAN_QR_CODE",
            "enabled": false
          "MCORE.DD.EXTENDED_DISCOVERY": {
            "number": "MCORE.DD.EXTENDED_DISCOVERY",
            "enabled": false
          "MCORE.DD.COMMISSIONING_SUBTYPE_V": {
            "number": "MCORE.DD.COMMISSIONING_SUBTYPE_V",
            "enabled": false
          "MCORE.DD.COMMISSIONING_SUBTYPE_T": {
            "number": "MCORE.DD.COMMISSIONING_SUBTYPE_T",
            "enabled": false
          "MCORE.DD.TXT_KEY_VP": {
            "number": "MCORE.DD.TXT_KEY_VP",
            "enabled": false
          "MCORE.DD.TXT_KEY_DT": {
            "number": "MCORE.DD.TXT_KEY_DT",
            "enabled": false
          "MCORE.DD.TXT_KEY_DN": {
            "number": "MCORE.DD.TXT_KEY_DN",
            "enabled": false
          "MCORE.DD.TXT_KEY_RI": {
            "number": "MCORE.DD.TXT_KEY_RI",
            "enabled": false
          "MCORE.DD.TXT_KEY_PH": {
            "number": "MCORE.DD.TXT_KEY_PH",
            "enabled": false
          "MCORE.DD.TXT_KEY_PI": {
            "number": "MCORE.DD.TXT_KEY_PI",
            "enabled": false
          "MCORE.COM.PAF": {
            "number": "MCORE.COM.PAF",
            "enabled": false
          "MCORE.DD.ESF_TC_COMMISSIONER": {
            "number": "MCORE.DD.ESF_TC_COMMISSIONER",
            "enabled": false
          "MCORE.SC.VENDOR_SUBTYPE": {
            "number": "MCORE.SC.VENDOR_SUBTYPE",
            "enabled": false
          "MCORE.SC.DEVTYPE_SUBTYPE": {
            "number": "MCORE.SC.DEVTYPE_SUBTYPE",
            "enabled": false
          "MCORE.SC.VP_KEY": {
            "number": "MCORE.SC.VP_KEY",
            "enabled": false
          "MCORE.SC.DT_KEY": {
            "number": "MCORE.SC.DT_KEY",
            "enabled": false
          "MCORE.SC.DN_KEY": {
            "number": "MCORE.SC.DN_KEY",
            "enabled": false
          "MCORE.SC.RI_KEY": {
            "number": "MCORE.SC.RI_KEY",
            "enabled": false
          "MCORE.SC.PH_KEY": {
            "number": "MCORE.SC.PH_KEY",
            "enabled": false
          "MCORE.SC.PI_KEY": {
            "number": "MCORE.SC.PI_KEY",
            "enabled": false
          "MCORE.SC.SII_OP_DISCOVERY_KEY": {
            "number": "MCORE.SC.SII_OP_DISCOVERY_KEY",
            "enabled": false
          "MCORE.SC.SAI_OP_DISCOVERY_KEY": {
            "number": "MCORE.SC.SAI_OP_DISCOVERY_KEY",
            "enabled": false
          "MCORE.SC.SAT_OP_DISCOVERY_KEY": {
            "number": "MCORE.SC.SAT_OP_DISCOVERY_KEY",
            "enabled": false
          "MCORE.SC.T_KEY": {
            "number": "MCORE.SC.T_KEY",
            "enabled": false
          "MCORE.SC.SII_COMM_DISCOVERY_KEY": {
            "number": "MCORE.SC.SII_COMM_DISCOVERY_KEY",
            "enabled": false
          "MCORE.SC.SAI_COMM_DISCOVERY_KEY": {
            "number": "MCORE.SC.SAI_COMM_DISCOVERY_KEY",
            "enabled": false
          "MCORE.SC.EXTENDED_DISCOVERY": {
            "number": "MCORE.SC.EXTENDED_DISCOVERY",
            "enabled": false
          "MCORE.SC.SIT_ICD": {
            "number": "MCORE.SC.SIT_ICD",
            "enabled": false
          "MCORE.SC.TCP": {
            "number": "MCORE.SC.TCP",
            "enabled": false
          "MCORE.IDM.S": {
            "number": "MCORE.IDM.S",
            "enabled": true
          "MCORE.IDM.C": {
            "number": "MCORE.IDM.C",
            "enabled": false
          "MCORE.IDM.C.InvokeRequest": {
            "number": "MCORE.IDM.C.InvokeRequest",
            "enabled": false
          "MCORE.IDM.C.ReadRequest": {
            "number": "MCORE.IDM.C.ReadRequest",
            "enabled": false
          "MCORE.IDM.C.WriteRequest": {
            "number": "MCORE.IDM.C.WriteRequest",
            "enabled": false
          "MCORE.IDM.C.SubscribeRequest": {
            "number": "MCORE.IDM.C.SubscribeRequest",
            "enabled": false
          "MCORE.IDM.C.InvokeRequest.BatchCommands": {
            "number": "MCORE.IDM.C.InvokeRequest.BatchCommands",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_Bool": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_Bool",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_String": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_String",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_UnsignedInteger": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_UnsignedInteger",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_SignedInteger": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_SignedInteger",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_Struct": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_Struct",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_FloatingPoint": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_FloatingPoint",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_List": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_List",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_OctetString": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_OctetString",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_Enum": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_Enum",
            "enabled": false
          "MCORE.IDM.C.ReadRequest.Attribute.DataType_Bitmap": {
            "number": "MCORE.IDM.C.ReadRequest.Attribute.DataType_Bitmap",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_Bool": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_Bool",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_String": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_String",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_UnsignedInteger": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_UnsignedInteger",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_SignedInteger": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_SignedInteger",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_Struct": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_Struct",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_FloatingPoint": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_FloatingPoint",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_List": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_List",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_OctetString": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_OctetString",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_Enum": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_Enum",
            "enabled": false
          "MCORE.IDM.C.WriteRequest.Attribute.DataType_Bitmap": {
            "number": "MCORE.IDM.C.WriteRequest.Attribute.DataType_Bitmap",
            "enabled": false
          "MCORE.IDM.S.Attribute_W.DataType_Bool": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_Bool",
            "enabled": true
          "MCORE.IDM.S.Attribute_W.DataType_String": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_String",
            "enabled": false
          "MCORE.IDM.S.Attribute_W.DataType_UnsignedInteger": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_UnsignedInteger",
            "enabled": true
          "MCORE.IDM.S.Attribute_W.DataType_SignedInteger": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_SignedInteger",
            "enabled": true
          "MCORE.IDM.S.Attribute_W.DataType_Struct": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_Struct",
            "enabled": false
          "MCORE.IDM.S.Attribute_W.DataType_FloatingPoint": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_FloatingPoint",
            "enabled": false
          "MCORE.IDM.S.Attribute_W.DataType_List": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_List",
            "enabled": false
          "MCORE.IDM.S.Attribute_W.DataType_OctetString": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_OctetString",
            "enabled": false
          "MCORE.IDM.S.Attribute_W.DataType_Enum": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_Enum",
            "enabled": true
          "MCORE.IDM.S.Attribute_W.DataType_Bitmap": {
            "number": "MCORE.IDM.S.Attribute_W.DataType_Bitmap",
            "enabled": true
          "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_Bool": {
            "number": "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_Bool",
            "enabled": false
          "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_String": {
            "number": "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_String",
            "enabled": false
          "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_UnsignedInteger": {
            "number": "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_UnsignedInteger",
            "enabled": false
          "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_Integer": {
            "number": "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_Integer",
            "enabled": false
          "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_FloatingPoint": {
            "number": "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_FloatingPoint",
            "enabled": false
          "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_List": {
            "number": "MCORE.IDM.C.SubscribeRequest.Attribute.DataType_List",
            "enabled": false
          "MCORE.IDM.S.LargeData": {
            "number": "MCORE.IDM.S.LargeData",
            "enabled": false
          "MCORE.IDM.C.SubscribeEvent": {
            "number": "MCORE.IDM.C.SubscribeEvent",
            "enabled": false
          "MCORE.IDM.C.ReadEvent": {
            "number": "MCORE.IDM.C.ReadEvent",
            "enabled": false
          "MCORE.IDM.C.SubscribeRequest.MultipleAttributes": {
            "number": "MCORE.IDM.C.SubscribeRequest.MultipleAttributes",
            "enabled": false
          "MCORE.IDM.S.PersistentSubscription": {
            "number": "MCORE.IDM.S.PersistentSubscription",
            "enabled": false
          "MCORE.BRIDGE": {
            "number": "MCORE.BRIDGE",
            "enabled": false
          "MCORE.BRIDGE.BatInfo": {
            "number": "MCORE.BRIDGE.BatInfo",
            "enabled": false
          "MCORE.BRIDGE.OtherControl": {
            "number": "MCORE.BRIDGE.OtherControl",
            "enabled": false
          "MCORE.BRIDGE.AllowDeviceRename": {
            "number": "MCORE.BRIDGE.AllowDeviceRename",
            "enabled": false
          "MCORE.BRIDGECLIENT": {
            "number": "MCORE.BRIDGECLIENT",
            "enabled": false
          "MCORE.DEVLIST.UseDevices": {
            "number": "MCORE.DEVLIST.UseDevices",
            "enabled": false
          "MCORE.DEVLIST.UseDeviceName": {
            "number": "MCORE.DEVLIST.UseDeviceName",
            "enabled": false
          "MCORE.DEVLIST.UseDeviceState": {
            "number": "MCORE.DEVLIST.UseDeviceState",
            "enabled": false
          "MCORE.DEVLIST.UseBatInfo": {
            "number": "MCORE.DEVLIST.UseBatInfo",
            "enabled": false
          "MCORE.BDX.Sender": {
            "number": "MCORE.BDX.Sender",
            "enabled": false
          "MCORE.BDX.Receiver": {
            "number": "MCORE.BDX.Receiver",
            "enabled": false
          "MCORE.BDX.SynchronousSender": {
            "number": "MCORE.BDX.SynchronousSender",
            "enabled": false
          "MCORE.BDX.SynchronousReceiver": {
            "number": "MCORE.BDX.SynchronousReceiver",
            "enabled": false
          "MCORE.BDX.AsynchronousSender": {
            "number": "MCORE.BDX.AsynchronousSender",
            "enabled": false
          "MCORE.BDX.AsynchronousReceiver": {
            "number": "MCORE.BDX.AsynchronousReceiver",
            "enabled": false
          "MCORE.BDX.Driver": {
            "number": "MCORE.BDX.Driver",
            "enabled": false
          "MCORE.BDX.Initiator": {
            "number": "MCORE.BDX.Initiator",
            "enabled": false
          "MCORE.BDX.Responder": {
            "number": "MCORE.BDX.Responder",
            "enabled": false
          "MCORE.BDX.BlockQueryWithSkip": {
            "number": "MCORE.BDX.BlockQueryWithSkip",
            "enabled": false
          "MCORE.OTA.Requestor": {
            "number": "MCORE.OTA.Requestor",
            "enabled": true
          "MCORE.OTA.Provider": {
            "number": "MCORE.OTA.Provider",
            "enabled": false
          "MCORE.OTA.HTTPS": {
            "number": "MCORE.OTA.HTTPS",
            "enabled": false
          "MCORE.OTA.RequestorConsent": {
            "number": "MCORE.OTA.RequestorConsent",
            "enabled": false
          "MCORE.OTA.Resume": {
            "number": "MCORE.OTA.Resume",
            "enabled": false
          "MCORE.OTA.VendorSpecific": {
            "number": "MCORE.OTA.VendorSpecific",
            "enabled": false
          "MCORE.ACL.Administrator": {
            "number": "MCORE.ACL.Administrator",
            "enabled": false
          "MCORE.OTA.Retry": {
            "number": "MCORE.OTA.Retry",
            "enabled": false
          "MCORE.FS": {
            "number": "MCORE.FS",
            "enabled": false
          "MCORE.SM.S": {
            "number": "MCORE.SM.S",
            "enabled": true
          "MCORE.DT.S": {
            "number": "MCORE.DT.S",
            "enabled": true
          "MCORE.G.MULTIENDPOINT": {
            "number": "MCORE.G.MULTIENDPOINT",
            "enabled": false
      "Access Control Cluster Test Plan": {
        "name": "Access Control Cluster Test Plan",
        "items": {
          "ACL.S": {
            "number": "ACL.S",
            "enabled": true
          "ACL.C": {
            "number": "ACL.C",
            "enabled": false
          "ACL.S.A0000": {
            "number": "ACL.S.A0000",
            "enabled": true
          "ACL.S.A0001": {
            "number": "ACL.S.A0001",
            "enabled": true
          "ACL.S.A0002": {
            "number": "ACL.S.A0002",
            "enabled": true
          "ACL.S.A0003": {
            "number": "ACL.S.A0003",
            "enabled": true
          "ACL.S.A0004": {
            "number": "ACL.S.A0004",
            "enabled": true
          "ACL.S.A0005": {
            "number": "ACL.S.A0005",
            "enabled": false
          "ACL.S.A0006": {
            "number": "ACL.S.A0006",
            "enabled": false
          "ACL.S.E00": {
            "number": "ACL.S.E00",
            "enabled": true
          "ACL.S.E01": {
            "number": "ACL.S.E01",
            "enabled": true
          "ACL.S.E02": {
            "number": "ACL.S.E02",
            "enabled": false
          "ACL.S.C01.Tx": {
            "number": "ACL.S.C01.Tx",
            "enabled": false
          "ACL.S.C00.Rsp": {
            "number": "ACL.S.C00.Rsp",
            "enabled": false
          "ACL.S.F00": {
            "number": "ACL.S.F00",
            "enabled": true
          "ACL.S.F01": {
            "number": "ACL.S.F01",
            "enabled": false
      "Administrator Commissioning Cluster Test Plan": {
        "name": "Administrator Commissioning Cluster Test Plan",
        "items": {
          "CADMIN.S": {
            "number": "CADMIN.S",
            "enabled": true
          "CADMIN.C": {
            "number": "CADMIN.C",
            "enabled": false
          "CADMIN.S.A0000": {
            "number": "CADMIN.S.A0000",
            "enabled": true
          "CADMIN.S.A0001": {
            "number": "CADMIN.S.A0001",
            "enabled": true
          "CADMIN.S.A0002": {
            "number": "CADMIN.S.A0002",
            "enabled": true
          "CADMIN.S.C00.Rsp": {
            "number": "CADMIN.S.C00.Rsp",
            "enabled": true
          "CADMIN.S.C01.Rsp": {
            "number": "CADMIN.S.C01.Rsp",
            "enabled": true
          "CADMIN.S.C02.Rsp": {
            "number": "CADMIN.S.C02.Rsp",
            "enabled": true
          "CADMIN.S.F00": {
            "number": "CADMIN.S.F00",
            "enabled": true
          "CADMIN.C.A0000": {
            "number": "CADMIN.C.A0000",
            "enabled": false
          "CADMIN.C.A0001": {
            "number": "CADMIN.C.A0001",
            "enabled": false
          "CADMIN.C.A0002": {
            "number": "CADMIN.C.A0002",
            "enabled": false
          "CADMIN.C.C00.Tx": {
            "number": "CADMIN.C.C00.Tx",
            "enabled": false
          "CADMIN.C.C01.Tx": {
            "number": "CADMIN.C.C01.Tx",
            "enabled": false
          "CADMIN.C.C02.Tx": {
            "number": "CADMIN.C.C02.Tx",
            "enabled": false
          "CADMIN.M.UserInterfaceDisplay": {
            "number": "CADMIN.M.UserInterfaceDisplay",
            "enabled": false
          "CADMIN.M.AudioInterface": {
            "number": "CADMIN.M.AudioInterface",
            "enabled": false
      "Basic Information Cluster Test Plan": {
        "name": "Basic Information Cluster Test Plan",
        "items": {
          "BINFO.S": {
            "number": "BINFO.S",
            "enabled": true
          "BINFO.S.A0000": {
            "number": "BINFO.S.A0000",
            "enabled": true
          "BINFO.S.A0001": {
            "number": "BINFO.S.A0001",
            "enabled": true
          "BINFO.S.A0002": {
            "number": "BINFO.S.A0002",
            "enabled": true
          "BINFO.S.A0003": {
            "number": "BINFO.S.A0003",
            "enabled": true
          "BINFO.S.A0004": {
            "number": "BINFO.S.A0004",
            "enabled": true
          "BINFO.S.A0005": {
            "number": "BINFO.S.A0005",
            "enabled": true
          "BINFO.S.A0006": {
            "number": "BINFO.S.A0006",
            "enabled": true
          "BINFO.S.A0007": {
            "number": "BINFO.S.A0007",
            "enabled": true
          "BINFO.S.A0008": {
            "number": "BINFO.S.A0008",
            "enabled": true
          "BINFO.S.A0009": {
            "number": "BINFO.S.A0009",
            "enabled": true
          "BINFO.S.A000a": {
            "number": "BINFO.S.A000a",
            "enabled": true
          "BINFO.S.A000b": {
            "number": "BINFO.S.A000b",
            "enabled": true
          "BINFO.S.A000c": {
            "number": "BINFO.S.A000c",
            "enabled": false
          "BINFO.S.A000d": {
            "number": "BINFO.S.A000d",
            "enabled": false
          "BINFO.S.A000e": {
            "number": "BINFO.S.A000e",
            "enabled": false
          "BINFO.S.A000f": {
            "number": "BINFO.S.A000f",
            "enabled": true
          "BINFO.S.A0010": {
            "number": "BINFO.S.A0010",
            "enabled": false
          "BINFO.S.A0011": {
            "number": "BINFO.S.A0011",
            "enabled": false
          "BINFO.S.A0012": {
            "number": "BINFO.S.A0012",
            "enabled": true
          "BINFO.S.A0013": {
            "number": "BINFO.S.A0013",
            "enabled": true
          "BINFO.S.A0014": {
            "number": "BINFO.S.A0014",
            "enabled": false
          "BINFO.S.A0015": {
            "number": "BINFO.S.A0015",
            "enabled": true
          "BINFO.S.A0016": {
            "number": "BINFO.S.A0016",
            "enabled": true
          "BINFO.S.A0017": {
            "number": "BINFO.S.A0017",
            "enabled": true
          "BINFO.S.A0018": {
            "number": "BINFO.S.A0018",
            "enabled": true
          "BINFO.S.E00": {
            "number": "BINFO.S.E00",
            "enabled": true
          "BINFO.S.E01": {
            "number": "BINFO.S.E01",
            "enabled": true
          "BINFO.S.E02": {
            "number": "BINFO.S.E02",
            "enabled": true
          "BINFO.S.E03": {
            "number": "BINFO.S.E03",
            "enabled": false
          "BINFO.S.M.DeviceConfigurationChange": {
            "number": "BINFO.S.M.DeviceConfigurationChange",
            "enabled": false
          "BINFO.C.A0005": {
            "number": "BINFO.C.A0005",
            "enabled": false
      "Descriptor Cluster Test Plan": {
        "name": "Descriptor Cluster Test Plan",
        "items": {
          "DESC.S": {
            "number": "DESC.S",
            "enabled": true
          "DESC.S.A0000": {
            "number": "DESC.S.A0000",
            "enabled": true
          "DESC.S.A0001": {
            "number": "DESC.S.A0001",
            "enabled": true
          "DESC.S.A0002": {
            "number": "DESC.S.A0002",
            "enabled": true
          "DESC.S.A0003": {
            "number": "DESC.S.A0003",
            "enabled": true
          "DESC.S.A0004": {
            "number": "DESC.S.A0004",
            "enabled": false
          "DESC.S.A0005": {
            "number": "DESC.S.A0005",
            "enabled": false
          "DESC.S.F00": {
            "number": "DESC.S.F00",
            "enabled": false
      "General Commissioning Cluster Test Plan": {
        "name": "General Commissioning Cluster Test Plan",
        "items": {
          "CGEN.S": {
            "number": "CGEN.S",
            "enabled": true
          "CGEN.C": {
            "number": "CGEN.C",
            "enabled": false
          "CGEN.S.A0000": {
            "number": "CGEN.S.A0000",
            "enabled": true
          "CGEN.S.A0001": {
            "number": "CGEN.S.A0001",
            "enabled": true
          "CGEN.S.A0002": {
            "number": "CGEN.S.A0002",
            "enabled": true
          "CGEN.S.A0003": {
            "number": "CGEN.S.A0003",
            "enabled": true
          "CGEN.S.A0004": {
            "number": "CGEN.S.A0004",
            "enabled": true
          "CGEN.S.A0005": {
            "number": "CGEN.S.A0005",
            "enabled": false
          "CGEN.S.A0006": {
            "number": "CGEN.S.A0006",
            "enabled": false
          "CGEN.S.A0007": {
            "number": "CGEN.S.A0007",
            "enabled": false
          "CGEN.S.A0008": {
            "number": "CGEN.S.A0008",
            "enabled": false
          "CGEN.S.A0009": {
            "number": "CGEN.S.A0009",
            "enabled": false
          "CGEN.S.C01.Tx": {
            "number": "CGEN.S.C01.Tx",
            "enabled": true
          "CGEN.S.C03.Tx": {
            "number": "CGEN.S.C03.Tx",
            "enabled": true
          "CGEN.S.C05.Tx": {
            "number": "CGEN.S.C05.Tx",
            "enabled": true
          "CGEN.S.C07.Tx": {
            "number": "CGEN.S.C07.Tx",
            "enabled": false
          "CGEN.S.C00.Rsp": {
            "number": "CGEN.S.C00.Rsp",
            "enabled": true
          "CGEN.S.C02.Rsp": {
            "number": "CGEN.S.C02.Rsp",
            "enabled": true
          "CGEN.S.C04.Rsp": {
            "number": "CGEN.S.C04.Rsp",
            "enabled": true
          "CGEN.S.C06.Rsp": {
            "number": "CGEN.S.C06.Rsp",
            "enabled": false
          "CGEN.S.F00": {
            "number": "CGEN.S.F00",
            "enabled": false
          "{PICS_ESF_TC_CLIENT}": {
            "number": "{PICS_ESF_TC_CLIENT}",
            "enabled": false
      "General Diagnostics Cluster Test Plan": {
        "name": "General Diagnostics Cluster Test Plan",
        "items": {
          "DGGEN.S": {
            "number": "DGGEN.S",
            "enabled": true
          "DGGEN.C": {
            "number": "DGGEN.C",
            "enabled": false
          "DGGEN.S.A0000": {
            "number": "DGGEN.S.A0000",
            "enabled": true
          "DGGEN.S.A0001": {
            "number": "DGGEN.S.A0001",
            "enabled": true
          "DGGEN.S.A0002": {
            "number": "DGGEN.S.A0002",
            "enabled": true
          "DGGEN.S.A0003": {
            "number": "DGGEN.S.A0003",
            "enabled": true
          "DGGEN.S.A0004": {
            "number": "DGGEN.S.A0004",
            "enabled": true
          "DGGEN.S.A0005": {
            "number": "DGGEN.S.A0005",
            "enabled": false
          "DGGEN.S.A0006": {
            "number": "DGGEN.S.A0006",
            "enabled": false
          "DGGEN.S.A0007": {
            "number": "DGGEN.S.A0007",
            "enabled": false
          "DGGEN.S.A0008": {
            "number": "DGGEN.S.A0008",
            "enabled": true
          "DGGEN.S.E00": {
            "number": "DGGEN.S.E00",
            "enabled": false
          "DGGEN.S.E01": {
            "number": "DGGEN.S.E01",
            "enabled": false
          "DGGEN.S.E02": {
            "number": "DGGEN.S.E02",
            "enabled": false
          "DGGEN.S.E03": {
            "number": "DGGEN.S.E03",
            "enabled": true
          "DGGEN.S.C02.Tx": {
            "number": "DGGEN.S.C02.Tx",
            "enabled": true
          "DGGEN.S.C04.Tx": {
            "number": "DGGEN.S.C04.Tx",
            "enabled": false
          "DGGEN.S.C00.Rsp": {
            "number": "DGGEN.S.C00.Rsp",
            "enabled": true
          "DGGEN.S.C01.Rsp": {
            "number": "DGGEN.S.C01.Rsp",
            "enabled": true
          "DGGEN.S.C03.Rsp": {
            "number": "DGGEN.S.C03.Rsp",
            "enabled": false
          "DGGEN.S.F00": {
            "number": "DGGEN.S.F00",
            "enabled": false
          "DGGEN.C.C00.Tx": {
            "number": "DGGEN.C.C00.Tx",
            "enabled": false
          "DGGEN.C.C01.Tx": {
            "number": "DGGEN.C.C01.Tx",
            "enabled": false
      "Group Communication": {
        "name": "Group Communication",
        "items": {
          "G.S": {
            "number": "G.S",
            "enabled": false
          "G.C": {
            "number": "G.C",
            "enabled": false
          "GRPKEY.S": {
            "number": "GRPKEY.S",
            "enabled": true
          "GRPKEY.C": {
            "number": "GRPKEY.C",
            "enabled": false
          "GRPKEY.S.A0000": {
            "number": "GRPKEY.S.A0000",
            "enabled": true
          "GRPKEY.S.A0001": {
            "number": "GRPKEY.S.A0001",
            "enabled": true
          "GRPKEY.S.A0002": {
            "number": "GRPKEY.S.A0002",
            "enabled": true
          "GRPKEY.S.A0003": {
            "number": "GRPKEY.S.A0003",
            "enabled": true
          "GRPKEY.S.C02.Tx": {
            "number": "GRPKEY.S.C02.Tx",
            "enabled": true
          "GRPKEY.S.C05.Tx": {
            "number": "GRPKEY.S.C05.Tx",
            "enabled": true
          "GRPKEY.S.C00.Rsp": {
            "number": "GRPKEY.S.C00.Rsp",
            "enabled": true
          "GRPKEY.S.C01.Rsp": {
            "number": "GRPKEY.S.C01.Rsp",
            "enabled": true
          "GRPKEY.S.C03.Rsp": {
            "number": "GRPKEY.S.C03.Rsp",
            "enabled": true
          "GRPKEY.S.C04.Rsp": {
            "number": "GRPKEY.S.C04.Rsp",
            "enabled": true
          "G.S.C00.Rsp": {
            "number": "G.S.C00.Rsp",
            "enabled": false
          "G.S.C01.Rsp": {
            "number": "G.S.C01.Rsp",
            "enabled": false
          "G.S.C04.Rsp": {
            "number": "G.S.C04.Rsp",
            "enabled": false
          "G.S.F00": {
            "number": "G.S.F00",
            "enabled": false
          "GRPKEY.S.F00": {
            "number": "GRPKEY.S.F00",
            "enabled": false
          "GRPKEY.C.A0000": {
            "number": "GRPKEY.C.A0000",
            "enabled": false
          "GRPKEY.C.A0001": {
            "number": "GRPKEY.C.A0001",
            "enabled": false
          "G.C.C00.Tx": {
            "number": "G.C.C00.Tx",
            "enabled": false
          "G.C.C01.Tx": {
            "number": "G.C.C01.Tx",
            "enabled": false
          "GRPKEY.C.C00.Tx": {
            "number": "GRPKEY.C.C00.Tx",
            "enabled": false
          "GRPKEY.C.C01.Tx": {
            "number": "GRPKEY.C.C01.Tx",
            "enabled": false
          "GRPKEY.C.C03.Tx": {
            "number": "GRPKEY.C.C03.Tx",
            "enabled": false
          "GRPKEY.C.C04.Tx": {
            "number": "GRPKEY.C.C04.Tx",
            "enabled": false
      "Network Commissioning Cluster Test Plan": {
        "name": "Network Commissioning Cluster Test Plan",
        "items": {
          "CNET.S": {
            "number": "CNET.S",
            "enabled": true
          "CNET.C": {
            "number": "CNET.C",
            "enabled": false
          "CNET.S.A0000": {
            "number": "CNET.S.A0000",
            "enabled": true
          "CNET.S.A0001": {
            "number": "CNET.S.A0001",
            "enabled": true
          "CNET.S.A0002": {
            "number": "CNET.S.A0002",
            "enabled": true
          "CNET.S.A0003": {
            "number": "CNET.S.A0003",
            "enabled": true
          "CNET.S.A0004": {
            "number": "CNET.S.A0004",
            "enabled": true
          "CNET.S.A0005": {
            "number": "CNET.S.A0005",
            "enabled": true
          "CNET.S.A0006": {
            "number": "CNET.S.A0006",
            "enabled": true
          "CNET.S.A0007": {
            "number": "CNET.S.A0007",
            "enabled": true
          "CNET.S.A0008": {
            "number": "CNET.S.A0008",
            "enabled": false
          "CNET.S.A0009": {
            "number": "CNET.S.A0009",
            "enabled": true
          "CNET.S.A000a": {
            "number": "CNET.S.A000a",
            "enabled": true
          "CNET.S.C01.Tx": {
            "number": "CNET.S.C01.Tx",
            "enabled": true
          "CNET.S.C05.Tx": {
            "number": "CNET.S.C05.Tx",
            "enabled": true
          "CNET.S.C07.Tx": {
            "number": "CNET.S.C07.Tx",
            "enabled": true
          "CNET.S.C00.Rsp": {
            "number": "CNET.S.C00.Rsp",
            "enabled": true
          "CNET.S.C02.Rsp": {
            "number": "CNET.S.C02.Rsp",
            "enabled": false
          "CNET.S.C03.Rsp": {
            "number": "CNET.S.C03.Rsp",
            "enabled": true
          "CNET.S.C04.Rsp": {
            "number": "CNET.S.C04.Rsp",
            "enabled": true
          "CNET.S.C06.Rsp": {
            "number": "CNET.S.C06.Rsp",
            "enabled": true
          "CNET.S.C08.Rsp": {
            "number": "CNET.S.C08.Rsp",
            "enabled": true
          "CNET.S.F00": {
            "number": "CNET.S.F00",
            "enabled": false
          "CNET.S.F01": {
            "number": "CNET.S.F01",
            "enabled": true
          "CNET.S.F02": {
            "number": "CNET.S.F02",
            "enabled": false
          "CNET.C.C00.Tx": {
            "number": "CNET.C.C00.Tx",
            "enabled": false
          "CNET.C.C02.Tx": {
            "number": "CNET.C.C02.Tx",
            "enabled": false
          "CNET.C.C03.Tx": {
            "number": "CNET.C.C03.Tx",
            "enabled": false
          "CNET.C.C04.Tx": {
            "number": "CNET.C.C04.Tx",
            "enabled": false
          "CNET.C.C06.Tx": {
            "number": "CNET.C.C06.Tx",
            "enabled": false
          "CNET.C.C08.Tx": {
            "number": "CNET.C.C08.Tx",
            "enabled": false
          "CNET.C.F00": {
            "number": "CNET.C.F00",
            "enabled": false
          "CNET.C.F01": {
            "number": "CNET.C.F01",
            "enabled": false
          "CNET.C.F02": {
            "number": "CNET.C.F02",
            "enabled": false
      "Node Operational Credentials Cluster Test Plan": {
        "name": "Node Operational Credentials Cluster Test Plan",
        "items": {
          "OPCREDS.S": {
            "number": "OPCREDS.S",
            "enabled": true
          "OPCREDS.C": {
            "number": "OPCREDS.C",
            "enabled": false
          "OPCREDS.S.A0000": {
            "number": "OPCREDS.S.A0000",
            "enabled": true
          "OPCREDS.S.A0001": {
            "number": "OPCREDS.S.A0001",
            "enabled": true
          "OPCREDS.S.A0002": {
            "number": "OPCREDS.S.A0002",
            "enabled": true
          "OPCREDS.S.A0003": {
            "number": "OPCREDS.S.A0003",
            "enabled": true
          "OPCREDS.S.A0004": {
            "number": "OPCREDS.S.A0004",
            "enabled": true
          "OPCREDS.S.A0005": {
            "number": "OPCREDS.S.A0005",
            "enabled": true
          "OPCREDS.S.C01.Tx": {
            "number": "OPCREDS.S.C01.Tx",
            "enabled": true
          "OPCREDS.S.C03.Tx": {
            "number": "OPCREDS.S.C03.Tx",
            "enabled": true
          "OPCREDS.S.C05.Tx": {
            "number": "OPCREDS.S.C05.Tx",
            "enabled": true
          "OPCREDS.S.C08.Tx": {
            "number": "OPCREDS.S.C08.Tx",
            "enabled": true
          "OPCREDS.S.C0e.Tx": {
            "number": "OPCREDS.S.C0e.Tx",
            "enabled": true
          "OPCREDS.S.C00.Rsp": {
            "number": "OPCREDS.S.C00.Rsp",
            "enabled": true
          "OPCREDS.S.C02.Rsp": {
            "number": "OPCREDS.S.C02.Rsp",
            "enabled": true
          "OPCREDS.S.C04.Rsp": {
            "number": "OPCREDS.S.C04.Rsp",
            "enabled": true
          "OPCREDS.S.C06.Rsp": {
            "number": "OPCREDS.S.C06.Rsp",
            "enabled": true
          "OPCREDS.S.C07.Rsp": {
            "number": "OPCREDS.S.C07.Rsp",
            "enabled": true
          "OPCREDS.S.C09.Rsp": {
            "number": "OPCREDS.S.C09.Rsp",
            "enabled": true
          "OPCREDS.S.C0a.Rsp": {
            "number": "OPCREDS.S.C0a.Rsp",
            "enabled": true
          "OPCREDS.S.C0b.Rsp": {
            "number": "OPCREDS.S.C0b.Rsp",
            "enabled": true
          "OPCREDS.S.C0c.Rsp": {
            "number": "OPCREDS.S.C0c.Rsp",
            "enabled": true
          "OPCREDS.S.C0d.Rsp": {
            "number": "OPCREDS.S.C0d.Rsp",
            "enabled": true
          "OPCREDS.C.A0000": {
            "number": "OPCREDS.C.A0000",
            "enabled": false
          "OPCREDS.C.A0001": {
            "number": "OPCREDS.C.A0001",
            "enabled": false
          "OPCREDS.C.A0002": {
            "number": "OPCREDS.C.A0002",
            "enabled": false
          "OPCREDS.C.A0003": {
            "number": "OPCREDS.C.A0003",
            "enabled": false
          "OPCREDS.C.A0004": {
            "number": "OPCREDS.C.A0004",
            "enabled": false
          "OPCREDS.C.A0005": {
            "number": "OPCREDS.C.A0005",
            "enabled": false
          "OPCREDS.C.C00.Tx": {
            "number": "OPCREDS.C.C00.Tx",
            "enabled": false
          "OPCREDS.C.C02.Tx": {
            "number": "OPCREDS.C.C02.Tx",
            "enabled": false
          "OPCREDS.C.C04.Tx": {
            "number": "OPCREDS.C.C04.Tx",
            "enabled": false
          "OPCREDS.C.C06.Tx": {
            "number": "OPCREDS.C.C06.Tx",
            "enabled": false
          "OPCREDS.C.C07.Tx": {
            "number": "OPCREDS.C.C07.Tx",
            "enabled": false
          "OPCREDS.C.C09.Tx": {
            "number": "OPCREDS.C.C09.Tx",
            "enabled": false
          "OPCREDS.C.C0a.Tx": {
            "number": "OPCREDS.C.C0a.Tx",
            "enabled": false
          "OPCREDS.C.C0b.Tx": {
            "number": "OPCREDS.C.C0b.Tx",
            "enabled": false
          "OPCREDS.C.C01.Rsp": {
            "number": "OPCREDS.C.C01.Rsp",
            "enabled": false
          "OPCREDS.C.C03.Rsp": {
            "number": "OPCREDS.C.C03.Rsp",
            "enabled": false
          "OPCREDS.C.C05.Rsp": {
            "number": "OPCREDS.C.C05.Rsp",
            "enabled": false
          "OPCREDS.C.C08.Rsp": {
            "number": "OPCREDS.C.C08.Rsp",
            "enabled": false
      "OTA Software Update Test Plan": {
        "name": "OTA Software Update Test Plan",
        "items": {
          "OTAP.S.M.DelayedActionTime": {
            "number": "OTAP.S.M.DelayedActionTime",
            "enabled": false
          "OTAP.S.M.UserConsentNeeded": {
            "number": "OTAP.S.M.UserConsentNeeded",
            "enabled": false
          "OTAR.C.M.AnnounceOTAProvider": {
            "number": "OTAR.C.M.AnnounceOTAProvider",
            "enabled": true
          "OTAR.C.M.NotifyUpdateApplied": {
            "number": "OTAR.C.M.NotifyUpdateApplied",
            "enabled": false
      "Time Synchronization Cluster Test Plan": {
        "name": "Time Synchronization Cluster Test Plan",
        "items": {
          "TIMESYNC.S": {
            "number": "TIMESYNC.S",
            "enabled": true
          "TIMESYNC.C": {
            "number": "TIMESYNC.C",
            "enabled": false
          "TIMESYNC.S.A0000": {
            "number": "TIMESYNC.S.A0000",
            "enabled": true
          "TIMESYNC.S.A0001": {
            "number": "TIMESYNC.S.A0001",
            "enabled": true
          "TIMESYNC.S.A0002": {
            "number": "TIMESYNC.S.A0002",
            "enabled": true
          "TIMESYNC.S.A0003": {
            "number": "TIMESYNC.S.A0003",
            "enabled": true
          "TIMESYNC.S.A0004": {
            "number": "TIMESYNC.S.A0004",
            "enabled": true
          "TIMESYNC.S.A0005": {
            "number": "TIMESYNC.S.A0005",
            "enabled": true
          "TIMESYNC.S.A0006": {
            "number": "TIMESYNC.S.A0006",
            "enabled": true
          "TIMESYNC.S.A0007": {
            "number": "TIMESYNC.S.A0007",
            "enabled": true
          "TIMESYNC.S.A0008": {
            "number": "TIMESYNC.S.A0008",
            "enabled": true
          "TIMESYNC.S.A0009": {
            "number": "TIMESYNC.S.A0009",
            "enabled": false
          "TIMESYNC.S.A000a": {
            "number": "TIMESYNC.S.A000a",
            "enabled": true
          "TIMESYNC.S.A000b": {
            "number": "TIMESYNC.S.A000b",
            "enabled": true
          "TIMESYNC.S.A000c": {
            "number": "TIMESYNC.S.A000c",
            "enabled": true
          "TIMESYNC.S.E00": {
            "number": "TIMESYNC.S.E00",
            "enabled": true
          "TIMESYNC.S.E01": {
            "number": "TIMESYNC.S.E01",
            "enabled": true
          "TIMESYNC.S.E02": {
            "number": "TIMESYNC.S.E02",
            "enabled": true
          "TIMESYNC.S.E03": {
            "number": "TIMESYNC.S.E03",
            "enabled": true
          "TIMESYNC.S.E04": {
            "number": "TIMESYNC.S.E04",
            "enabled": true
          "TIMESYNC.S.C03.Tx": {
            "number": "TIMESYNC.S.C03.Tx",
            "enabled": true
          "TIMESYNC.S.C00.Rsp": {
            "number": "TIMESYNC.S.C00.Rsp",
            "enabled": true
          "TIMESYNC.S.C01.Rsp": {
            "number": "TIMESYNC.S.C01.Rsp",
            "enabled": true
          "TIMESYNC.S.C02.Rsp": {
            "number": "TIMESYNC.S.C02.Rsp",
            "enabled": true
          "TIMESYNC.S.C04.Rsp": {
            "number": "TIMESYNC.S.C04.Rsp",
            "enabled": true
          "TIMESYNC.S.C05.Rsp": {
            "number": "TIMESYNC.S.C05.Rsp",
            "enabled": true
          "TIMESYNC.S.F00": {
            "number": "TIMESYNC.S.F00",
            "enabled": true
          "TIMESYNC.S.F01": {
            "number": "TIMESYNC.S.F01",
            "enabled": true
          "TIMESYNC.S.F02": {
            "number": "TIMESYNC.S.F02",
            "enabled": false
          "TIMESYNC.S.F03": {
            "number": "TIMESYNC.S.F03",
            "enabled": true
Xiongwei.Wang
  • Hi, Marte,
    Thanks for the advice. I'll run the tests one by one this weekend.
    Thank you for your help.
    But regarding the AccessControlEntryChanged always failing, I still don't know the reason.
    Xiongwei.Wang
    Does this happen when you run the test on itself as well?
    I see several AccessControlEntryChanged events in the log, so the response from the DUT does contain the expected AccessControlEntryChanged events. However, the test states that it looks for a list of events containing 1 element:
    * Test step:
    *     3: TH1 reads DUT Endpoint 0 AccessControl cluster AccessControlEntryChanged event	Expected outcome: Result is SUCCESS value is list of AccessControlEntryChangedEvent events containing 1 element
    Your DUT returns multiple events. I do not know exactly how the test script is coded, but if it is implemented to look for exactly one event matching the criteria, then it could be that it fails because there are multiple events matching. If that is the case, you can try a factory reset to clear all previously generated events before re-running the test (on its own, not as part of a batch test).
    Marte
  • Hi, Marte,
    I am using NCS v3.1.1 with the nRF54L15DK. I created a project based on the Matter template and copied the .zap file from my original project. However, I am still encountering the same problem with the AccessControlEntryChanged event in TC-ACL-2.5 and TC-ACL-2.8. I tried to test them one by one, but it didn't work. It seems the ACL test cases might depend on each other.
    I have attached the project here for you to try. If you need more information, such as the TH configuration steps or other files, please let me know. I would be happy to provide them.
    Valve.zip
    Xiongwei.Wang
    UL didn't report any problems regarding the ACL test. Perhaps the issue is on my end — maybe something with my network setup?
    Xiongwei.Wang
