We are developing a product based on the nRF54L15, using BT Mesh. We also use the FLPR. For communication between the cores, we use ICMSG.
Separately, ICMSG and BT Mesh work well, but for some reason, when we include BT Mesh, cpuapp cannot set up ICMSG properly, even if the ICMSG setup is done before `bt_enable()`. The callback `ipc_ept_cfg.cb.bound` is never called. We are getting serial logging from the FLPR, so we know that is running and its `ipc_ept_cfg.cb.bound` is called.
This question (The IPC and bt_enable are turned on at the same time, and the chip is not working) about the nRF53 is similar, but there is no IPC Radio Firmware on the nRF54 as far as I can tell.
Here is the relevant part of our prj.conf for cpuapp:CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=8192
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_LOG_BUFFER_SIZE=8192
CONFIG_BT_RX_STACK_SIZE=5120
CONFIG_LOG=y
CONFIG_REQUIRES_FLOAT_PRINTF=y
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_SETTINGS=y
CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE=n
CONFIG_SPI_NOR=n
CONFIG_NVS=n
CONFIG_NVS_LOOKUP_CACHE=n
CONFIG_SETTINGS_NVS_NAME_CACHE=n
CONFIG_ZMS=y
CONFIG_SETTINGS_ZMS_CUSTOM_SECTOR_COUNT=y
CONFIG_SETTINGS_ZMS_SECTOR_COUNT=8
CONFIG_ZMS_LOOKUP_CACHE=y
CONFIG_ZMS_LOOKUP_CACHE_SIZE=512
CONFIG_ZMS_LOOKUP_CACHE_FOR_SETTINGS=y
CONFIG_HWINFO=y
CONFIG_GPIO=y
CONFIG_BT=y
CONFIG_BT_L2CAP_TX_BUF_COUNT=5
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_OBSERVER=y
CONFIG_BT_BROADCASTER=y
CONFIG_BT_CTLR_DUP_FILTER_LEN=0
CONFIG_BT_CTLR_LE_ENC=n
CONFIG_BT_CTLR_LE_PING=n
CONFIG_BT_DATA_LEN_UPDATE=n
CONFIG_BT_PHY_UPDATE=n
CONFIG_BT_CTLR_MIN_USED_CHAN=n
CONFIG_BT_CTLR_PRIVACY=n
CONFIG_BT_CTLR_CHAN_SEL_2=n
CONFIG_BT_MESH=y
CONFIG_BT_MESH_MODEL_EXTENSIONS=y
CONFIG_BT_MESH_RELAY=y
CONFIG_BT_MESH_FRIEND=y
CONFIG_BT_MESH_PB_GATT=y
CONFIG_BT_MESH_PB_ADV=y
CONFIG_BT_MESH_GATT_PROXY=y
CONFIG_BT_MESH_SUBNET_COUNT=2
CONFIG_BT_MESH_APP_KEY_COUNT=2
CONFIG_BT_MESH_MODEL_GROUP_COUNT=2
CONFIG_BT_MESH_LABEL_COUNT=3
CONFIG_BT_MESH_ADV_BUF_COUNT=10
CONFIG_BT_MESH_TX_SEG_MSG_COUNT=3
CONFIG_BT_MESH_RX_SEG_MAX=32
CONFIG_BT_MESH_TX_SEG_MAX=32
CONFIG_MBOX=y
CONFIG_IPC_SERVICE=y
CONFIG_IPC_SERVICE_BACKEND_ICMSG=y
CONFIG_IPC_SERVICE_LOG_LEVEL_DBG=y
Any help is appreciated
- Fridtjof
