I am bringing up a custom board using the nRF54L15 (Fanstel BM15M module) and I am using SPIM00 as the high-speed SPI interface. I am configuring the peripheral through Zephyr (NCS 2.x) using the pinctrl mechanism. While doing this, I encountered unexpected behavior on several Port 2 pins when attempting to use them as general-purpose GPIO. I would like to confirm my understanding of the restrictions on Port 2 when SPIM00 is in use.
Summary of observations
Initially I assigned several display control signals (DISP_RESET, DISP_SPI_RS, etc.) to Port 2 pins, including P2.00 and P2.09.
When I configured these pins as GPIO outputs in Zephyr and attempted to toggle them, the electrical behavior was not reliable:
P2.09 appeared stuck low even though the firmware was driving it as a GPIO.
P2.00 showed some transitions, but did not behave as cleanly or predictably as Port 1 pins when toggled.
I verified these behaviors on the bench using a scope.
Based on the documentation, the HS-SPI (SPIM00) signals use the following Port 2 pins:
P2.05 – SPIM00 CSN
P2.06 – SPIM00 SCK
P2.08 – SPIM00 MOSI
P2.09 – SPIM00 MISO
Given the behavior I observed, I theorized that general-purpose signals (RESET, D/C, etc.) should not be placed on Port 2 when SPIM00 is enabled in Zephyr.
Questions for Nordic
Is it correct that Port 2 pins are effectively reserved for high-speed SPIM00/QSPI functions on the nRF54L15? Are there routing or electrical reasons why these pins should not be used as general-purpose GPIO while SPIM00 is active?
Is the behavior I observed on P2.09 (stuck low when configured as GPIO) expected given that it is also the SPIM00 MISO pin?
Is P2.00 safe to use as a normal GPIO at the same time SPIM00 is enabled on the other Port 2 pins, or is it best practice to avoid using P2.00 for GPIO as well?
In general, is it best practice on nRF54L15 to reserve all of Port 2 exclusively for SPIM00, and place all other control signals on Port 0 or Port 1?
Current Configuration
I have now migrated all non-SPI functions to Port 0 or Port 1, leaving Port 2 exclusively for SPIM00. I would like confirmation from Nordic that this is the recommended approach for the HS-SPI domain.
Any clarification on intended Port 2 usage would be very helpful before I finalize my next hardware revision.
Steve
