Chip : nRF52833 QIAA
Environment : Visual Code + nRF Connect for VC Code V2025.8.654 NCS V3.1.0
I am hoping somebody could assist us with a problem we are having achieving the expected low current operation on the nRF52833 soc on a custom PCB in sys_poweroff() (and also in k_sleep())
In an attempt to narrow this down have depopulated the PCB to contain just the nRF52833 SOC all the other passives and bus peripherals are de-soldered.
I have created a simple application which does nothing other than to set all GPIO as inputs and enter k_sleep () and the current is measured using PPK2 at ~750uAmps. There is spiking activity
It feels like I have read every article on this subject from here and the suggested sample such as \ncs\v3.1.0\zephyr\samples\boards\nordic\system_off. Please can anyone suggest a remedy?
main.c
#include <zephyr/kernel.h>
#include <zephyr/drivers/hwinfo.h>
#include <zephyr/sys/poweroff.h>
#include <hal/nrf_gpio.h>
for (uint8_t idx = 0; idx < NUMBER_OF_PINS; idx++)
nrf_gpio_cfg_default(idx); // Input, no pull up/down, no sense
// k_sleep(K_FOREVER);
hwinfo_clear_reset_cause();
sys_poweroff();
return 0;
prj.conf
#Debug support CONFIG_USB_DEVICE_STACK=n CONFIG_BOOT_BANNER=n CONFIG_PRINTK=n CONFIG_SERIAL=n CONFIG_CONSOLE=n CONFIG_UART_CONSOLE=n CONFIG_LOG=n CONFIG_DEBUG_OPTIMIZATIONS=n CONFIG_DEBUG_THREAD_INFO=n CONFIG_POWEROFF=y CONFIG_PM_DEVICE=y CONFIG_PM_DEVICE_RUNTIME=y CONFIG_MULTITHREADING=y CONFIG_GPIO=y CONFIG_HWINFO=y
I have created a DTS, DTSI, Def Config as attached. (No UARTs enabled, No SPI enabled, No I2C enabled, No Temp controller enabled, No RNG enabled , No external flash etc). No logging, no prink etc.
/dts-v1/;
#include <nordic/nrf52833_qiaa.dtsi>
#include "X30_bare-pinctrl.dtsi"
#include <zephyr/dt-bindings/input/input-event-codes.h>
model = "Bare X30";
compatible = "Extronics,X30-bare";
chosen {
zephyr,sram = &sram0;
zephyr,flash = &flash0;
zephyr,code-partition = &slot0_partition;
&uicr {
nfct-pins-as-gpios;
&gpiote {
status = "okay";
&gpio0 {
status = "okay";
&gpio1 {
status = "okay";
&flash0 {
partitions {
#address-cells = <1>;
#size-cells = <1>;
boot_partition: partition@0 {
label = "mcuboot";
reg = <0x00000000 DT_SIZE_K(48)>;
slot0_partition: partition@c000 {
label = "image-0";
reg = <0x0000c000 DT_SIZE_K(220)>;
slot1_partition: partition@43000 {
label = "image-1";
reg = <0x00043000 DT_SIZE_K(220)>;
storage_partition: partition@7a000 {
label = "storage";
reg = <0x0007a000 DT_SIZE_K(24)>;
&uart0 {
status = "disabled";
&uart1 {
&spi0 {
compatible = "nordic,nrf-spi";
&spi1 {
&spi2 {
&i2c0 {
&i2c1 {
&i2c1 {
&temp {
&rng {
&rng_hci {
&adc {
&wdt0 {
The build files
build-folder/zephyr/zephyr.dts
build-folder/zephyr/.config (.txt to enable attachment)
are attached.
CONFIG_ARM_MPU=y CONFIG_HW_STACK_PROTECTION=y # enable GPIO CONFIG_GPIO=y
