How to access Azure Blob Storage data in nrf7002
I am tried to access the server using http_client .I am tested that my implementation to access the local server works properly but the thing is i am tried to access the .bin file from azure blob storage for that i am gets the server url with SAS token and add the Digicert Global root cert but i got the error -3b00 while connect to the server. why its happened and can you please share is there any procedure to access the blob storage.Thanks in advance.
Goudam
  • Hi Gaudam
    What function exactly is it that returns this -0x3b00  error? It points to the pubkey tag/value that is invalid, so what is this set to in your project?
    Simon
  • Hi simon,
    While using connect() fn to the socket i got this error
  • Please show the full function. What have you set the pubkey tag or value as in the connect() function of your application?
    Simon
  • I am using DigicertGlobalRoot for the handshake
    /* Setup TLS options on a given socket */
    int tls_setup()
        int err = tls_credential_add(HTTP_TLS_SEC_TAG, TLS_CREDENTIAL_CA_CERTIFICATE, DigiCertGlobalRootG2_der,
    				 DigiCertGlobalRootG2_der_len);
    	if (err == -EEXIST){
    		printk("Certificate already exists, sec tag: %d", HTTP_TLS_SEC_TAG);
    	} else if (err < 0) {
    		printk("Failed to provision server certificate: %d", err);
        int sock, ret;
        struct addrinfo *res = NULL;
        struct addrinfo hints = {
    		.ai_family = AF_INET,
            .ai_socktype = SOCK_STREAM
        /* DNS resolve */
        ret = getaddrinfo(SERVER_ADDR, SERVER_PORT, &hints, &res);
        if (ret != 0 || !res) {
            printk("DNS getaddrinfo failed: %d\n", ret);
            return -ENOENT;
    	struct sockaddr_in server;
    	server.sin_addr.s_addr = ((struct sockaddr_in *)res->ai_addr)->sin_addr.s_addr;
    	server.sin_family = AF_INET;
    	server.sin_port = ((struct sockaddr_in *)res->ai_addr)->sin_port;
    	char ipv4_addr[NET_IPV4_ADDR_LEN];
    	inet_ntop(AF_INET, &server.sin_addr.s_addr, ipv4_addr, sizeof(ipv4_addr));
    	freeaddrinfo(res);
        /* TLS socket */
        sock = socket(AF_INET, SOCK_STREAM, IPPROTO_TLS_1_2);
        if (sock < 0) {
            printk("socket() failed: %d\n", sock);
            return -ENOENT;
        /* Configure the socket with the security tag for the certificate */
        sec_tag_t sec_tag_opt[] = {
            HTTP_TLS_SEC_TAG,
        /* Set up TLS peer verification */
    	enum {
    		NONE = 0,
    		OPTIONAL = 1,
    		REQUIRED = 2,
        ret = setsockopt(sock, SOL_TLS, TLS_HOSTNAME,SERVER_ADDR,sizeof(SERVER_ADDR));
    	if (ret) {
    		printk("Failed to setup TLS hostname, err %d\n", ret);
    		return -ENOENT;;
        /* Configure the socket with the hostname of the HTTP server */
        int tls_peer_verify = REQUIRED;
    	ret = setsockopt(sock, SOL_TLS, TLS_PEER_VERIFY, &tls_peer_verify, sizeof(tls_peer_verify));
    	if (ret) {
    		printk("Failed to setup peer verification, err %d\n", errno);
    		return ret;
        /* Associate the socket with the security tag
    	 * we have provisioned the certificate with.
    	ret = setsockopt(sock, SOL_TLS, TLS_SEC_TAG_LIST, sec_tag_opt, sizeof(sec_tag_opt));
    	if (ret) {
    		printk("Failed to setup TLS sec tag, err %d\n", ret);
    		return -ENOENT;
        ret = connect(sock, (struct sockaddr *)&server, sizeof(struct sockaddr_in));
        if (ret < 0) {
            printk("Failed to connect for check: %d (errno: %d)\n", ret, errno);
            close(sock);
            return -ENOENT;
        return 0;
  • Hi
    What is the security tags set to in your project then? Most likely it's the HTTP_TLS_SEC_TAG is set to an invalid value.
    Simon
