Possible bug in nRF Cloud UI display of device shadow null properties
We are seeing weird behavior in the way the nRF Cloud UI displays changes in the device shadow, specifically for properties that are being nulled-out.
Let's say we have propertyA in the "desired" config section:
"config": {
  "cfg":{
     "propertyA": "abc"
This displays as expected in the device shadow panel of the nRF Cloud UI.
We can use the "View Config" button to change propertyA to "def", and commit.
 "cfg": {
     "propertyA": "def"
The shadow panel updates propertyA within a few seconds to "def", as expected.
However, if we want to remove propertyA by setting it to null (as per device shadow semantics) it behaves differently. Again, we use the "View Config" button:
 "cfg": {
     "propertyA": null
Now, this happens:
Briefly, the device shadow panel shows "propertyA": null. However, a few seconds it flips back to the previous value "def". Finally, after several minutes, it updates again and propertyA is removed (as we expected in the first place). Then it stays like that.
To verify, we monitored the shadow messages between nRF Cloud and AWS (via nRF Cloud Message Routing). We confirmed that propertyA is immediately removed from the shadow, as expected. But the nRF Cloud UI doesn't reflect that, at least initially.
This is quite confusing and threw us off for a while because we thought it was due to a bug in our shadow handling implementation. Until we realized it's the way the nRF Cloud UI is displaying it.
