Hi
I have some questions regarding the 32 MHz crystal on the nRF54L15:
If my firmware is configured to use external capacitors, will the very first crystal startup waveform captured after power-on already be using the external capacitors? Or is it still using the internal capacitors at that moment?
The reason I’m asking is that I used the same PCB design but tested it with different firmware settings (external vs. internal capacitors). The measured frequency offset did not match my expectations. My external load capacitors are 12 pF, and the internal setting is the default 15 pF. However, the result I observed is that when using only the external capacitors, the frequency offset is actually 2 ppm slower compared to using the internal capacitors in firmware (with the external capacitors still mounted).
