nRF9151: fcntl() errno 9 EBADF
When we open a TCP socket in our nRF9151 application, we set it to non-blocking.
The flow:
fd = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
setsockopt(fd, SOL_SOCKET, SO_RAI, &rai, sizeof(rai));
nrf_fcntl(fd, NRF_F_SETFL, NRF_O_NONBLOCK);
Sometimes, seemingly at random, nrf_fcntl() returns -1 and errno == 9 (EBADF).
We also check the return values of socket() and setsockopt() and both of those succeed right before fcntl! fd >= 0 and the return value of setsockopt() is 0.
What does it mean when nrf_fcntl returns EBADF here? It appears this happens at random.
    can you provide more information? What SDK, modem firmware, and hardware are you using? Any logs?
  • We use SDK v2.7.0 (working on moving up), modem firmware 2.0.2 on nRF9151.
    It's really this simple piece of code:
    /* fd >= 0 */
    int rai = RAI_ONGOING;
    err = setsockopt(fd, SOL_SOCKET, SO_RAI, &rai, sizeof(rai));
    /* err == 0 */
    /* err == -1 && errno == 9 */
    While Registered and RRC Connected on an NB-IoT network (example 20620), sometimes nrf_fcntl returns this.
    The response is immediate (<1ms).
    In what case does fcntl set errno to EBADF?
  • Using fcntl() instead of nrf_fcntl() seems to work for me. This kinda makes sense since you are using the Zephyr socket API when creating the socket, but you are calling nrf_fcntl() which is the modem lib API. I think you should stick to one API when dealing with sockets.
    Edit; Never mind, it works with the Zephyr stack, but not with the offloaded sockets.
    Edit2; This works for me;
    #include <stdio.h>
    #include <ncs_version.h>
    #include <zephyr/kernel.h>
    #include <zephyr/net/socket.h>
    #include <fcntl.h>
    #include <nrf_socket.h>
    #include <modem/nrf_modem_lib.h>
    #include <modem/lte_lc.h>
    int main(void) {
        int fd;
        int err;
        printk("Starting fcntl test\n");
        err = nrf_modem_lib_init();
        /* fd >= 0 */
        /* err == 0 */
        err = fcntl(fd, NRF_F_SETFL, NRF_O_NONBLOCK);
        printk("%d\n", err);
        printk("%d\n", errno);
        return 0;
