Fluctuating Idle Current when Using SPI1 (nRF52832)
I am using the ANNA-B112 module with nRF52832 to communicate to an AD5940 AFE using SPI1. I am also communicating with three other sensors using I2C0. This project uses nRF Connect SDK v3.0.0. I have posted the .dts and .overlay files that I am using for this project below.
ubx_evkannab1_nrf52832.dts
 * Copyright (c) 2021 u-blox AG
/dts-v1/;
#include <nordic/nrf52832_qfaa.dtsi>
#include "ubx_evkannab1_nrf52832-pinctrl.dtsi"
#include <zephyr/dt-bindings/input/input-event-codes.h>
	model = "u-blox EVK-ANNA-B1 NRF52832";
	compatible = "u-blox,ubx_evkannab1_nrf52832";
	chosen {
		zephyr,console = &uart0;
		zephyr,shell-uart = &uart0;
		zephyr,uart-mcumgr = &uart0;
		zephyr,bt-mon-uart = &uart0;
		zephyr,bt-c2h-uart = &uart0;
		zephyr,sram = &sram0;
		zephyr,flash = &flash0;
		zephyr,code-partition = &slot0_partition;
	leds {
		compatible = "gpio-leds";
		led0: led_0 {
			/* ANNA-B1 GPIO_29 */
			gpios = <&gpio0 27 GPIO_ACTIVE_LOW>;
			label = "Red LED";
		led1: led_1 {
			/* ANNA-B1 GPIO_30 */
			gpios = <&gpio0 25 GPIO_ACTIVE_LOW>;
			label = "Green LED";
		led2: led_2 {
			/*ANNA-B1 GPIO_31 */
			gpios = <&gpio0 26 GPIO_ACTIVE_LOW>;
			label = "Blue LED";
	pwmleds {
		compatible = "pwm-leds";
		red_pwm_led: red_pwm_led {
			pwms = <&pwm0 0 PWM_MSEC(20) PWM_POLARITY_INVERTED>;
		green_pwm_led: green_pwm_led {
			pwms = <&pwm0 1 PWM_MSEC(20) PWM_POLARITY_INVERTED>;
		blue_pwm_led: blue_pwm_led {
			pwms = <&pwm0 2 PWM_MSEC(20) PWM_POLARITY_INVERTED>;
	buttons {
		compatible = "gpio-keys";
		button0: button_0 {
			/*  EVK-ANNA-B1 SW1 button */
			gpios = <&gpio0 25 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "Push button switch SW1";
			zephyr,code = <INPUT_KEY_0>;
		button1: button_1 {
			/* EVK-ANNA-B1 SW2 button */
			gpios = <&gpio0 24 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "Push button switch SW2";
			zephyr,code = <INPUT_KEY_1>;
	arduino_header: connector {
		compatible = "arduino-header-r3";
		#gpio-cells = <2>;
		gpio-map-mask = <0xffffffff 0xffffffc0>;
		gpio-map-pass-thru = <0 0x3f>;
		gpio-map = <0 0 &gpio0 4 0>,	/* A0 */
			   <1 0 &gpio0 5 0>,	/* A1 */
			   <2 0 &gpio0 28 0>,	/* A2 */
			   <3 0 &gpio0 29 0>,	/* A3 */
			   <4 0 &gpio0 30 0>,	/* A4 */
			   <5 0 &gpio0 31 0>,	/* A5 */
			   <6 0 &gpio0 2 0>,	/* D0 */
			   <7 0 &gpio0 3 0>,	/* D1 */
			   <8 0 &gpio0 19 0>,	/* D2 */
			   <9 0 &gpio0 11 0>,	/* D3 */
			   <10 0 &gpio0 27 0>,	/* D4 */
			   <11 0 &gpio0 26 0>,	/* D5 */
			   <12 0 &gpio0 10 0>,	/* D6 */
			   <13 0 &gpio0 9 0>,	/* D7 */
			   <14 0 &gpio0 14 0>,	/* D8 */
			   <15 0 &gpio0 24 0>,	/* D9 */
			   <16 0 &gpio0 22 0>,	/* D10 */
			   <17 0 &gpio0 23 0>,	/* D11 */
			   <18 0 &gpio0 18 0>,	/* D12 */
			   <19 0 &gpio0 20 0>,	/* D13 */
			   <20 0 &gpio0 15 0>,	/* D14 */
			   <21 0 &gpio0 16 0>;	/* D15 */
	arduino_adc: analog-connector {
		compatible = "arduino,uno-adc";
		#io-channel-cells = <1>;
		io-channel-map = <0 &adc 1>,	/* A0 = P0.4 = AIN1 */
				 <1 &adc 2>,	/* A1 = P0.5 = AIN2 */
				 <2 &adc 4>,	/* A2 = P0.28 = AIN4 */
				 <3 &adc 5>,	/* A3 = P0.29 = AIN5 */
				 <4 &adc 6>,	/* A4 = P0.30 = AIN6 */
				 <5 &adc 7>;	/* A5 = P0.31 = AIN7 */
	/* These aliases are provided for compatibility with samples */
	aliases {
		led0 = &led0;
		led1 = &led1;
		led2 = &led2;
		pwm-led0 = &red_pwm_led;
		pwm-led1 = &green_pwm_led;
		pwm-led2 = &blue_pwm_led;
		red-pwm-led = &red_pwm_led;
		green-pwm-led = &green_pwm_led;
		blue-pwm-led = &blue_pwm_led;
		sw0 = &button0;
		sw1 = &button1;
		watchdog0 = &wdt0;
&reg {
	regulator-initial-mode = <NRF5X_REG_MODE_DCDC>;
&adc {
	status = "okay";
&uicr {
	gpio-as-nreset;
&gpiote {
	status = "okay";
&gpio0 {
	status = "okay";
&uart0 {
	status = "okay";
	current-speed = <115200>;
	pinctrl-0 = <&uart0_default>;
	pinctrl-1 = <&uart0_sleep>;
arduino_i2c: &i2c0 {
	compatible = "nordic,nrf-twi";
	status = "okay";
	pinctrl-0 = <&i2c0_default>;
	pinctrl-1 = <&i2c0_sleep>;
&i2c1 {
	/* Cannot be used together with spi1. */
	/* status = "okay"; */
	pinctrl-0 = <&i2c1_default>;
	pinctrl-1 = <&i2c1_sleep>;
&pwm0 {
	status = "okay";
	pinctrl-0 = <&pwm0_default>;
	pinctrl-1 = <&pwm0_sleep>;
arduino_spi: &spi0 {
	compatible = "nordic,nrf-spi";
	/* Cannot be use simultaneously with i2c0 */
	cs-gpios = <&arduino_header 16 GPIO_ACTIVE_LOW>; /* D10 */
	pinctrl-0 = <&spi0_default>;
	pinctrl-1 = <&spi0_sleep>;
&spi1 {
	status = "okay";
	pinctrl-0 = <&spi1_default>;
	pinctrl-1 = <&spi1_sleep>;
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x00000000 0xc000>;
		slot0_partition: partition@c000 {
			label = "image-0";
			reg = <0x0000C000 0x32000>;
		slot1_partition: partition@3e000 {
			label = "image-1";
			reg = <0x0003E000 0x32000>;
		scratch_partition: partition@70000 {
			label = "image-scratch";
			reg = <0x00070000 0xa000>;
		storage_partition: partition@7a000 {
			label = "storage";
			reg = <0x0007a000 0x00006000>;
ubx_evkannab1_nrf52832.overlay
&i2c1 {status = "disabled";};
&i2s0 {status = "disabled";};
&uart0 {status = "disabled";};
&arduino_i2c {status = "disabled";};
&adc {status = "disabled";};
&pwm0 {status = "disabled";};
arduino_spi: &spi0 {status = "disabled";};
    gpiocustom {
		// BQ25155 LP: nRF Pin 3 -> ANNA-B112 Pin 19
        gpiocustom0: gpiocustom_0 {
            label = "GPIO_BQ25155LP";
            gpios = <&gpio0 3 (GPIO_OPEN_SOURCE)>;
		// AD5940 CS: nRF Pin 2 -> ANNA-B112 Pin 20
		gpiocustom1: gpiocustom_1 {
			label = "GPIO_AD5940CS";
			gpios = <&gpio0 2 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
		// AD5940 RESET: nRF Pin 31 -> ANNA-B112 Pin 25
		gpiocustom2: gpiocustom_2 {
			label = "GPIO_AD5940RESET";
			gpios = <&gpio0 31 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
		// AD5940 INT0: nRF Pin 4 -> ANNA-B112 Pin 24
		gpiocustom3: gpiocustom_3 {
			label = "GPIO_AD5940INT0";
			gpios = <&gpio0 4 (GPIO_PULL_DOWN | GPIO_ACTIVE_LOW)>;
    aliases {
        bq25155lp = &gpiocustom0;
		ad5940cs = &gpiocustom1;
		ad5940reset = &gpiocustom2;
		ad5940int0 = &gpiocustom3;
&gpio0 {
	status = "okay";
	sense-edge-mask = < 0xffffffff >;
&spi1 {
    status = "okay";
	// AD5940: Potentiostat
    ad5940: ad5940@0 {
        compatible = "vnd,spi-device";
        reg = <0>;
        spi-max-frequency = <1600000>;
        label = "ad5940";
&i2c0 {
    status = "okay";
	// BQ25155: Battery Management System
    bq25155: bq25155@6B {
		compatible = "i2c-device";
		status = "okay";
		reg = < 0x6B >;
	// HDC2022: Temperature and Humidity Sensor
	hdc20xx: hdc20xx@40 {
		status = "okay";
		reg = < 0x40 >;
	// BMA400: Accelerometer
	bma400: bma400@14 {
		status = "okay";
		reg = < 0x14 >;
&pinctrl {
	// I2C Pin Definition
	// SCL: nRF Pin 16 -> ANNA-B112 Pin 15
	// SDA: nRF Pin 15 -> ANNA-B112 Pin 14
    /omit-if-no-ref/ i2c0_default: i2c0_default {
		group1  {
			psels = <NRF_PSEL(TWIM_SCL, 0, 16)>,
					<NRF_PSEL(TWIM_SDA, 0, 15)>;
	/omit-if-no-ref/ i2c0_sleep: i2c0_sleep {
		group1  {
			low-power-enable;
	// SPI Pin Definitions
	// SCK: nRF Pin 20 -> ANNA-B112 Pin 45
	// MOSI: nRF Pin 19 -> ANNA-B112 Pin 35
	// MISO: nRF Pin 24 -> ANNA-B112 Pin 38
	spi1_default: spi1_default {
		group1 {
			psels = <NRF_PSEL(SPIM_SCK, 0, 20)>,
					<NRF_PSEL(SPIM_MOSI, 0, 19)>,
					<NRF_PSEL(SPIM_MISO, 0, 24)>;
	spi1_sleep: spi1_sleep {
		group1 {
			low-power-enable;
/delete-node/ &slot1_partition;
/delete-node/ &scratch_partition;
/delete-node/ &storage_partition;
&flash0 {
	partitions {
		#size-cells = <1>;
		// Boot Partition: 49152 B
			label = "mcuboot";
		// Slot0 Partition: 204800 B
			label = "image-0";
		// Slot1 Partition: 4096 B
			label = "image-1";
			reg = <0x0003E000 0x1000>;
		// Scratch Partition: 4096 B
		scratch_partition: partition@3f000 {
			reg = <0x0003F000 0x1000>;
		// Storage Partition (For Encryption Keys): 8192 B
		storage_partition: partition@40000 {
			label = "storage";
			reg = <0x00040000 0x0002000>;
		// File System Partition: 253952 B
		fs_partition: partition@42000 {
			label = "fs";
			reg = <0x42000 0x3e000>;
What I am noticing is that initially the idle current of the system will be low as expected around 4-5 uA. However, after a few seconds, the idle current will slowly start to increase and peak at around 500 uA. After some more time the idle current may continue to fluctuate between 4 uA - 500 uA seemingly at random. Functionality of the communication is not affected.
This behavior is observed on both the ANNA-B112 EVK and on a custom PCB board. On the ANNA-B112 EVK, if I touch the button SW2 with my finger (touch the button housing not press the button down) the idle current will very quickly go back down to 4-5 uA as expected and communication functionality is not affected.
(Note ANNA-B112 module IO_38 = nRF52832 P0.24)
I believe the issue is related to SPI and GPIOs communicating with the AD5940. If you notice, I use nRF52832 pin 24 for MISO and the ANNA-B112 EVK uses the same pin for SW2. I tried deleting the buttons definition on the .dts file, but this did not change the idle current fluctuation behavior.
I am not sure this is an EVK related issue because I am also noticing the same behavior on a custom PCB which has no button. For reference I don't use any external pullup or pulldown resistors on SPI, but I do use a 10K pullup for I2C.
What could cause the idle current to fluctuate like this when using SPI?
Thank you,
Crisvin Kadambathil
