pc-ble-driver-py How to use numerical comparison ?
I know that pc-ble-driver-py is archived but as there is no real alternative to it, I'm still using this package...
I'm using BLE nRF52840 dongle to connect to a BLE target.
When using exemple "test_lesc_security.py", I'm able to connect to the target. But when I tried to perform bonding (with keyboard_display and lesc=True), the event 'on_gap_evt_passkey_display' is trigger so I can read the passkey but I didn't understand how to match it. (The BLE target automatically match the key on it's side)
While using nRF Connect Desktop, I have no issue with numerical comparison (and same settings used with adapter.driver.ble_gat_authenticate).
Does someone successfully perform numerical comparison with pc-ble-driver-py ?
Note:
In pc_ble_driver_py/lib.nrf_ble_driver_sd_api_v5.py there is 'ble_gap_evt_passkey_display_t" with "match_request". Does this mean it's possible to match the numerical comparison ?
Antoine
  • Hi
    Can you share some more details on what this BLE target device is exactly? If you're using the passkey display event and want to confirm it using an nRF52840 Dongle, the most common way to do so is to have the Dongle connected to a serial terminal that writes out the passkey as well and you can confirm it's the same like that. Then a button press or similar usually will allow the devices to connect, or if the target expects some sort of confirmation, you need to confirm the passkey on the target side. Most likely via a button.
    Simon
  • Hi Simon,
    Thanks for your replay.
    The BLE target is a custom board (ESP32). This board display the passkey (screen connected) and automatically approved the numerical comparison (no action required from human on the target board).
    And with nRF Connect Desktop (so on the PC side), the numerical comparison work properly (passkey display and button "match"/"no match").
    But to use numerical comparison with pc-ble-driver-py (and not nRF Connect anymore in order to perform production test and automatized the BLE connexion) there is not example.
    I tried the following:
     def on_gap_evt_passkey_display(self, ble_driver, conn_handle, passkey): # Reached with IOCaps = keyboard_display/none/yesno
            self.logger.info("Central on_gap_evt_passkey_display: {}".format(passkey))
            ascii_passkey = ''.join(map(chr, passkey))
            self.logger.info(f"Central on_gap_evt_passekey_display (ASCII): {ascii_passkey}")
            passkeyQueue.put(passkey)
            # Send passkey as it has been printed on display
            pk = util.list_to_uint8_array(b'\0')
            driver.sd_ble_gap_auth_key_reply(self.adapter.driver.rpc_adapter,conn_handle,driver.BLE_GAP_AUTH_KEY_TYPE_PASSKEY, pk.cast())
    and the event trigger with the correct passkey displayed but the auth_status is not successful :
    def check_bond(self):
        result = self.adapter.evt_sync[self.conn_handle].wait(BLEEvtID.gap_evt_auth_status)
        self.logger.info("Check bond result: {}".format(result))
        if result != BLEGapSecStatus.success:
            raise NordicSemiException("Auth Status returned error code: {}".format(result))
    Here "result" is a dict with "bond":0.
    With below the sec_params for adapter.driver.ble_gap_authenticate:
    self.sec_params = BLEGapSecParams(bond=True,
                                              mitm=True,
                                              lesc=True,
                                              keypress=True,
                                              io_caps=BLEGapIOCaps.yesno,
                                              oob=False,
                                              min_key_size=7,
                                              max_key_size=16,
                                              kdist_own=self.kdist_own,
                                              kdist_peer=self.kdist_peer)
    Antoine
  • Hi Antoine,
    Before we proceed further, I would like to point out that there is an alternative in the nRF Connect SDK. It is the Bluetooth Shell.
    Could you please try that first?
    Hieu
  • Hi Hieu,
    Sorry for the late reply. But do you want me to flash the nRF52840 dongle with Bluetooth Shell ? Or the target board ?
    The target board running with ESP32, the Bluetooth Shell cannot be used right ?
    Antoine
  • Bluetooth Shell sample should work on ESP32 if you chose the right board files as this is a Zephyr sample.n the current pc_ble_driver_py sources the GAP passkey event is only half-exposed. When the SoftDevice raises BLE_GAP_EVT_PASSKEY_DISPLAY, the C struct includes a match_request flag that signals “this is numeric comparison; please tell me if the numbers match.” The Python glue strips that bit: pc_ble_driver_py/ble_driver.py (line 919) only copies the six-byte passkey, and when the event is dispatched pc_ble_driver_py/ble_driver.py L2718 observers receive just passkey=….
    Because match_request never reaches Python, the app can’t know it should call sd_ble_gap_auth_key_reply with BLE_GAP_AUTH_KEY_TYPE_PASSKEY (accept) or _NONE (reject), so bonding fails even though the digits match.
    That is why nRF Connect Desktop works (its stack seems to be handling the confirm), while pc-ble-driver-py doesn’t. To support numeric comparison you will have to extend the driver to forward match_request through the observer chain and update your script to send the confirmation key reply. In short, the pc-ble-driver do not seem to support what you want unless you add
