Troubleshooting Remote Provisioning on BLE Mesh
I am developing a feature to add remote provisioning support to a BLE Mesh-based network. In the network, a provisioner node receives, via a serial command, the UUID of the node to be provisioned into the network. Then the provisioner iterates over the nodes in its Configuration Database and requests them to start a remote provisioning scan (bt_mesh_rpr_scan_start). After receiving scan reports from remote provisioner servers that have seen the node to be added, the provisioner calls bt_mesh_provision_remote on the last node that reported seeing the node.
This process works fine most of the time, but sometimes bt_mesh_provision_remote is called; it returns no error, but the node_added callback on the provisioner is never triggered. Thus, I cannot proceed with configuring the node. The solution for this is to retry the procedure.
Aside from this, I occasionally get the following warnings
bt_mesh_transport: No free slots for new incoming segmented messages
bt_mesh_adv: AD malformed
Do you have any insights into why bt_mesh_provision_remote may return no error code, but the node_added callback is occasionally not triggered, as if the node was never remotely provisioned? What may cause the warnings shown above?
The following are the KConfigs related to segmented messages and ADV on the provisioner:
CONFIG_BT_MESH_TX_SEG_MSG_COUNT=3
CONFIG_BT_MESH_RX_SEG_MAX=32
CONFIG_BT_MESH_TX_SEG_MAX=32
CONFIG_BT_EXT_ADV=y
CONFIG_BT_MESH_ADV_BUF_COUNT=10
CONFIG_BT_EXT_ADV_MAX_ADV_SET=6
Current SDK Version: v2.8.0
Any help would be greatly appreciated
    It seems we have a bad description of bt_mesh_provision_remote function. It says:
    Provision a Mesh Node using PB-Remote
    This is not correct. It triggers a remote provisioning procedure that is quite complex and involves multiple communications between the remote client and server, remote server and unprovisioned device, and, as a consequence, remote client and unprovisioned device using the remote server as a proxy.
    Function bt_mesh_provision_remotejust triggers the remote link opening procedure. De facto, it only sends the Remote Link Open message from the remote client to the remote server. If this command was delivered successfully, then the function returns no error. However, it does not guarantee that the remote provisioning procedure will succeed in general. There might be an issue at any stage. Seems the communication issues happen from time to time since you do not always get node_added callback triggered.
    You might need to register link_close callback. If you receive link_close callback but not node_added. Then, remote provisioning has failed. Additionally, you can request the link status with the remote server bt_mesh_rpr_link_getto be sure, or just start remote provisioning one more time, as you already do.
    That means you received a segment, but there are no available buffers to store this segment.
    You can mitigate this by adding more buffers using this KConfig option CONFIG_BT_MESH_SEG_BUFS.
    That means what it says. There is some malformed AD structure in the scanned advertiser frame. The length of this AD structure is set in larger value than the frame length.
    Amanda H.
  • Amanda,
    Thanks for the reply!
    You're right, bt_mesh_provision_remote may return no error, but the provisioning may be unsuccessful.
    In my current implementation, after calling bt_mesh_provision_remote, I wait LINK_ESTABLISHMENT_TIMEOUT (60) seconds for the node_added callback. If that time expires, I conclude that unprovisioning was unsuccessful. I like your proposal of waiting for the link_closed callback as well. As I see it, provisioning is successful if the following sequence occurs: link_open --> node_added --> link_closed. Is it correct to say that provisioning is unsuccessful if the link is opened and closed without the node_added callback being called?
    I think your proposal is equivalent to mine, as I wait for the node_added callback after calling bt_mesh_provision_remote for the duration the link is open.
    In an indoor setup with four nodes, remote provisioning fails frequently. I intend to extend this feature to a network of around twenty nodes. Is there any way to make remote provisioning more robust?
    Many thanks!
    Could you share the ".config" file of the build (under build/app_name/zephyr)?
    Amanda H.
  • Surely, here is the .config file
    # CONFIG_INPUT is not set
    # CONFIG_WIFI is not set
    # CONFIG_MIPI_DSI is not set
    CONFIG_SERIAL=y
    # CONFIG_UART_ASYNC_API is not set
    CONFIG_I2C=y
    CONFIG_SPI=y
    # CONFIG_MODEM is not set
    # CONFIG_BT_SPI is not set
    # CONFIG_BT_HCI_ACL_FLOW_CONTROL is not set
    CONFIG_BT_HCI_VS=y
    CONFIG_BT_CTLR=y
    CONFIG_NUM_IRQS=48
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_FLASH_SIZE=1024
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_MP_MAX_NUM_CPUS=1
    CONFIG_SOC_RESET_HOOK=y
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_ROM_START_OFFSET=0
    CONFIG_PINCTRL=y
    CONFIG_BUILD_OUTPUT_BIN=y
    # CONFIG_BUILD_NO_GAP_FILL is not set
    CONFIG_XIP=y
    CONFIG_MAIN_STACK_SIZE=2176
    CONFIG_IDLE_STACK_SIZE=320
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    # CONFIG_SRAM_VECTOR_TABLE is not set
    CONFIG_CPU_HAS_ARM_MPU=y
    # CONFIG_COUNTER is not set
    # CONFIG_SHARED_INTERRUPTS is not set
    # CONFIG_PM_DEVICE is not set
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_FPU=y
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2304
    CONFIG_CLOCK_CONTROL=y
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    CONFIG_USE_DT_CODE_PARTITION=y
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    CONFIG_GEN_ISR_TABLES=y
    # CONFIG_INIT_STACKS is not set
    CONFIG_TIMESLICE_SIZE=0
    CONFIG_FLASH_LOAD_OFFSET=0xc000
    # CONFIG_REGULATOR is not set
    CONFIG_FLASH_FILL_BUFFER_SIZE=32
    CONFIG_HW_STACK_PROTECTION=y
    # CONFIG_HCI_NXP_ENABLE_AUTO_SLEEP is not set
    # CONFIG_HCI_NXP_SET_CAL_DATA is not set
    # CONFIG_MFD is not set
    CONFIG_GPIO=y
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    CONFIG_TINYCRYPT=y
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    # CONFIG_MBEDTLS is not set
    # CONFIG_MEMC is not set
    CONFIG_KERNEL_ENTRY="__start"
    # CONFIG_CACHE is not set
    CONFIG_LOG=y
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_ROMSTART_RELOCATION_ROM is not set
    CONFIG_DCACHE_LINE_SIZE=32
    CONFIG_SOC="nrf52840"
    # CONFIG_RESET is not set
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    CONFIG_NRF_RTC_TIMER=y
    CONFIG_LOG_DOMAIN_NAME=""
    # CONFIG_ASSERT is not set
    CONFIG_BUILD_OUTPUT_HEX=y
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
    # CONFIG_UART_USE_RUNTIME_CONFIGURE is not set
    # CONFIG_SYSCON is not set
    CONFIG_SERIAL_INIT_PRIORITY=50
    CONFIG_ENTROPY_INIT_PRIORITY=50
    CONFIG_SOC_SERIES="nrf52"
    CONFIG_SOC_FAMILY="nordic_nrf"
    # CONFIG_INTC_MTK_ADSP is not set
    # CONFIG_MTK_ADSP_TIMER is not set
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_REBOOT=y
    CONFIG_FLASH_INIT_PRIORITY=50
    CONFIG_GEN_IRQ_START_VECTOR=0
    CONFIG_SRAM_OFFSET=0
    # CONFIG_POWER_DOMAIN is not set
    CONFIG_CONSOLE=y
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    CONFIG_SPI_NOR=y
    CONFIG_ISR_STACK_SIZE=2048
    # CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set
    # CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set
    # CONFIG_SCHED_CPU_MASK is not set
    # CONFIG_WATCHDOG is not set
    CONFIG_ICACHE_LINE_SIZE=32
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    CONFIG_BT_BUF_ACL_TX_COUNT=3
    CONFIG_BT_BUF_CMD_TX_SIZE=255
    CONFIG_BT_BUF_EVT_RX_SIZE=255
    CONFIG_BT_BUF_ACL_TX_SIZE=502
    CONFIG_BT_BUF_ACL_RX_SIZE=502
    CONFIG_BT_L2CAP_TX_MTU=498
    # Devicetree Info
    CONFIG_DT_HAS_ARDUINO_UNO_ADC_ENABLED=y
    CONFIG_DT_HAS_ARDUINO_HEADER_R3_ENABLED=y
    CONFIG_DT_HAS_ARM_ARMV7M_ITM_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M4F_ENABLED=y
    CONFIG_DT_HAS_ARM_CRYPTOCELL_310_ENABLED=y
    CONFIG_DT_HAS_ARM_V7M_NVIC_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_GNSS_NMEA_GENERIC_ENABLED=y
    CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
    CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
    CONFIG_DT_HAS_JEDEC_SPI_NOR_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_BT_HCI_SDC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_GPIO_PINS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_MWU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PPI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TWI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF52_FLASH_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF52X_REGULATOR_HV_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF5X_REGULATOR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_QSPI_NOR_ENABLED=y
    CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
    # end of Devicetree Info
    # Modules
    # Available modules.
    # nrf (C:/ncs/v2.8.0/nrf)
    CONFIG_NEWLIB_LIBC_NANO=y
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    CONFIG_LOG_BUFFER_SIZE=10240
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    # Nordic nRF Connect
    CONFIG_HIDE_CHILD_PARENT_CONFIG=y
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_MCUMGR_TRANSPORT_NETBUF_SIZE=2475
    CONFIG_BT_BUF_CMD_TX_COUNT=2
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    CONFIG_NORDIC_QSPI_NOR=y
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    # CONFIG_GETOPT is not set
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    # Image build variants
    # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
    # end of Image build variants
    # CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU is not set
    # CONFIG_IMG_ERASE_PROGRESSIVELY is not set
    CONFIG_MCUMGR_GRP_OS_MCUMGR_PARAMS=y
    CONFIG_MCUMGR_GRP_ZBASIC=y
    CONFIG_MCUMGR_GRP_ZBASIC_STORAGE_ERASE=y
    CONFIG_NORDIC_QSPI_NOR_STACK_WRITE_BUFFER_SIZE=4
    CONFIG_UPDATEABLE_IMAGE_NUMBER=1
    # CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP is not set
    # Subsystems
    # Bootloader
    # CONFIG_BUILD_S1_VARIANT is not set
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x1000
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
    # CONFIG_IS_SECURE_BOOTLOADER is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # CONFIG_SECURE_BOOT_STORAGE is not set
    # CONFIG_MCUBOOT_COMPRESSED_IMAGE_SUPPORT_ENABLED is not set
    # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_ED25519 is not set
    # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_PURE is not set
    # end of Bootloader
    # Bluetooth Low Energy
    CONFIG_BT_COMPANY_ID_NORDIC=0x0059
    CONFIG_BT_COMPANY_ID=0x0059
    CONFIG_BT_MAX_CONN=3
    CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE=y
    CONFIG_BT_LL_SOFTDEVICE=y
    # SoftDevice Controller
    CONFIG_BT_LL_SOFTDEVICE_BUILD_TYPE_LIB=y
    CONFIG_BT_HCI_TX_STACK_SIZE=1536
    CONFIG_BT_RX_STACK_SIZE=2600
    # CONFIG_BT_CTLR_SDC_LLPM is not set
    # CONFIG_BT_CTLR_SDC_QOS_CHANNEL_SURVEY is not set
    CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=3
    # CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT_OVERRIDE is not set
    CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=7500
    CONFIG_BT_CTLR_SDC_CONN_EVENT_EXTEND_DEFAULT=y
    CONFIG_BT_CTLR_SDC_CENTRAL_ACL_EVENT_SPACING_DEFAULT=7500
    # CONFIG_BT_CTLR_SDC_PERIODIC_ADV_EVENT_LEN_DEFAULT_OVERRIDE is not set
    CONFIG_BT_CTLR_SDC_PERIODIC_ADV_EVENT_LEN_DEFAULT=7500
    CONFIG_BT_CTLR_SDC_TX_PACKET_COUNT=3
    CONFIG_BT_CTLR_SDC_RX_PACKET_COUNT=2
    CONFIG_BT_CTLR_SDC_SCAN_BUFFER_COUNT=3
    CONFIG_BT_CTLR_SDC_PERIODIC_SYNC_BUFFER_COUNT=3
    CONFIG_BT_CTLR_SDC_RX_PRIO=6
    # CONFIG_BT_CTLR_DF is not set
    CONFIG_BT_LL_SOFTDEVICE_MULTIROLE=y
    CONFIG_BT_CTLR_FAL_SIZE=8
    CONFIG_BT_CTLR_ECDH_LIB_OBERON=y
    # CONFIG_BT_CTLR_ECDH_LIB_TINYCRYPT is not set
    CONFIG_BT_CTLR_ECDH_STACK_SIZE=900
    CONFIG_BT_CTLR_ECDH_IN_MPSL_WORK=y
    # CONFIG_BT_CTLR_SDC_EVENT_TRIGGER is not set
    # CONFIG_BT_CTLR_SDC_CONN_ANCHOR_POINT_REPORT is not set
    CONFIG_BT_CTLR_SDC_BIG_RESERVED_TIME_US=1600
    CONFIG_BT_CTLR_SDC_CIG_RESERVED_TIME_US=1300
    CONFIG_BT_CTLR_SDC_CIS_SUBEVENT_LENGTH_US=0
    # CONFIG_BT_CTLR_CHANNEL_SOUNDING is not set
    # end of SoftDevice Controller
    # CONFIG_BT_RADIO_NOTIFICATION_CONN_CB is not set
    # BLE Libraries
    # CONFIG_BT_GATT_POOL is not set
    # CONFIG_BT_GATT_DM is not set
    # CONFIG_BT_ADV_PROV is not set
    # CONFIG_BT_SCAN is not set
    # CONFIG_BT_CONN_CTX is not set
    # CONFIG_BT_ENOCEAN is not set
    # Bluetooth Mesh
    CONFIG_BT_MESH_SETTINGS_WORKQ_STACK_SIZE=1400
    CONFIG_BT_MESH_RELAY_ADV_SETS=2
    CONFIG_BT_MESH_RELAY_RETRANSMIT_COUNT=3
    CONFIG_BT_MESH_RELAY_BUF_COUNT=10
    # CONFIG_BT_MESH_NLC_PERF_CONF is not set
    CONFIG_BT_MESH_CRPL=255
    CONFIG_BT_MESH_MODEL_GROUP_COUNT=2
    CONFIG_BT_MESH_MSG_CACHE_SIZE=32
    CONFIG_BT_MESH_APP_KEY_COUNT=1
    CONFIG_BT_MESH_SUBNET_COUNT=1
    # nRF BT mesh models
    CONFIG_BT_MESH_NRF_MODELS=y
    # Configuration of the waiting time for acknowledged messages
    CONFIG_BT_MESH_MOD_ACKD_TIMEOUT_BASE=3000
    CONFIG_BT_MESH_MOD_ACKD_TIMEOUT_PER_HOP=50
    # end of Configuration of the waiting time for acknowledged messages
    # Vendor models
    # end of Vendor models
    # CONFIG_BT_MESH_ONOFF_SRV is not set
    # CONFIG_BT_MESH_ONOFF_CLI is not set
    # CONFIG_BT_MESH_TIME_SRV is not set
    # CONFIG_BT_MESH_TIME_CLI is not set
    # CONFIG_BT_MESH_LVL_SRV is not set
    CONFIG_BT_MESH_LVL_CLI=y
    # CONFIG_BT_MESH_DTT_SRV is not set
    # CONFIG_BT_MESH_DTT_CLI is not set
    # CONFIG_BT_MESH_PONOFF_SRV is not set
    # CONFIG_BT_MESH_PONOFF_CLI is not set
    # CONFIG_BT_MESH_PLVL_SRV is not set
    # CONFIG_BT_MESH_PLVL_CLI is not set
    # CONFIG_BT_MESH_BATTERY_SRV is not set
    # CONFIG_BT_MESH_BATTERY_CLI is not set
    # CONFIG_BT_MESH_LOC_SRV is not set
    CONFIG_BT_MESH_LOC_CLI=y
    # CONFIG_BT_MESH_PROP_SRV is not set
    # CONFIG_BT_MESH_PROP_CLI is not set
    # CONFIG_BT_MESH_LIGHTNESS_SRV is not set
    CONFIG_BT_MESH_LIGHTNESS_CLI=y
    # Light Lightness Model configuration
    CONFIG_BT_MESH_LIGHTNESS_ACTUAL=y
    # CONFIG_BT_MESH_LIGHTNESS_LINEAR is not set
    # end of Light Lightness Model configuration
    # CONFIG_BT_MESH_LIGHT_CTRL_REG is not set
    # CONFIG_BT_MESH_LIGHT_CTRL_SRV is not set
    # CONFIG_BT_MESH_LIGHT_CTRL_CLI is not set
    # CONFIG_BT_MESH_LIGHT_CTL_CLI is not set
    # CONFIG_BT_MESH_LIGHT_CTL_SRV is not set
    # CONFIG_BT_MESH_LIGHT_TEMP_SRV is not set
    # CONFIG_BT_MESH_LIGHT_XYL_CLI is not set
    # CONFIG_BT_MESH_LIGHT_XYL_SRV is not set
    # CONFIG_BT_MESH_LIGHT_HSL_CLI is not set
    # CONFIG_BT_MESH_LIGHT_HSL_SRV is not set
    # CONFIG_BT_MESH_LIGHT_SAT_SRV is not set
    # CONFIG_BT_MESH_LIGHT_HUE_SRV is not set
    # CONFIG_BT_MESH_SENSOR_SRV is not set
    CONFIG_BT_MESH_SENSOR_CLI=y
    CONFIG_BT_MESH_SENSOR=y
    # Bluetooth Mesh Sensors
    # CONFIG_BT_MESH_SENSOR_LABELS is not set
    CONFIG_BT_MESH_SENSOR_ALL_TYPES=y
    CONFIG_BT_MESH_SENSOR_CHANNELS_MAX=5
    CONFIG_BT_MESH_SENSOR_CHANNEL_ENCODED_SIZE_MAX=4
    # end of Bluetooth Mesh Sensors
    # CONFIG_BT_MESH_SCENE_SRV is not set
    CONFIG_BT_MESH_SCENE_CLI=y
    CONFIG_BT_MESH_SCHEDULER_CLI=y
    # CONFIG_BT_MESH_SCHEDULER_SRV is not set
    # end of nRF BT mesh models
    # Bluetooth Services
    # CONFIG_BT_AMS_CLIENT is not set
    # CONFIG_BT_ANCS_CLIENT is not set
    # CONFIG_BT_BAS_CLIENT is not set
    # CONFIG_BT_BMS is not set
    # CONFIG_BT_CTS_CLIENT is not set
    # CONFIG_BT_DFU_SMP is not set
    # CONFIG_BT_GATTP is not set
    # CONFIG_BT_HIDS is not set
    # CONFIG_BT_HOGP is not set
    # CONFIG_BT_LBS is not set
    # CONFIG_BT_NSMS is not set
    # CONFIG_BT_NUS is not set
    # CONFIG_BT_NUS_CLIENT is not set
    # CONFIG_BT_RSCS is not set
    # CONFIG_BT_THROUGHPUT is not set
    # CONFIG_BT_LATENCY is not set
    # CONFIG_BT_LATENCY_CLIENT is not set
    # CONFIG_BT_HRS_CLIENT is not set
    # CONFIG_BT_DDFS is not set
    # CONFIG_BT_MDS is not set
    # CONFIG_BT_CGMS is not set
    # CONFIG_BT_FAST_PAIR is not set
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # end of Bluetooth Services
    # BLE over nRF RPC
    CONFIG_HEAP_MEM_POOL_SIZE=0
    CONFIG_BT_DRIVERS=y
    # CONFIG_BT_RPC_STACK is not set
    # CONFIG_BT_CENTRAL is not set
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_OBSERVER=y
    CONFIG_BT_BROADCASTER=y
    CONFIG_BT_CONN=y
    # CONFIG_BT_REMOTE_VERSION is not set
    # CONFIG_BT_PHY_UPDATE is not set
    # CONFIG_BT_DATA_LEN_UPDATE is not set
    CONFIG_BT_EXT_ADV=y
    # CONFIG_BT_EXT_ADV_LEGACY_SUPPORT is not set
    # CONFIG_BT_PER_ADV is not set
    # CONFIG_BT_PER_ADV_SYNC is not set
    # CONFIG_BT_PER_ADV_SYNC_RSP is not set
    CONFIG_BT_LOG=y
    # CONFIG_BT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_LOG_LEVEL_ERR is not set
    CONFIG_BT_LOG_LEVEL_WRN=y
    # CONFIG_BT_LOG_LEVEL_INF is not set
    # CONFIG_BT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_LOG_LEVEL=2
    CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INHERIT=y
    CONFIG_BT_HCI_DRIVER_LOG_LEVEL=2
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INF is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_RPA_LOG_LEVEL_INHERIT=y
    CONFIG_BT_RPA_LOG_LEVEL=2
    # CONFIG_BT_RPA_LOG_LEVEL_OFF is not set
    # CONFIG_BT_RPA_LOG_LEVEL_ERR is not set
    # CONFIG_BT_RPA_LOG_LEVEL_WRN is not set
    # CONFIG_BT_RPA_LOG_LEVEL_INF is not set
    # CONFIG_BT_RPA_LOG_LEVEL_DBG is not set
    # CONFIG_BT_RPA_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_ATT_LOG_LEVEL_INHERIT=y
    CONFIG_BT_ATT_LOG_LEVEL=2
    # CONFIG_BT_ATT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_ATT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_ATT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_ATT_LOG_LEVEL_INF is not set
    # CONFIG_BT_ATT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_ATT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_GATT_LOG_LEVEL_INHERIT=y
    CONFIG_BT_GATT_LOG_LEVEL=2
    # CONFIG_BT_GATT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_GATT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_GATT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_GATT_LOG_LEVEL_INF is not set
    # CONFIG_BT_GATT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_GATT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_L2CAP_LOG_LEVEL_INHERIT=y
    CONFIG_BT_L2CAP_LOG_LEVEL=2
    # CONFIG_BT_L2CAP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_INF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SETTINGS_LOG_LEVEL_INHERIT=y
    CONFIG_BT_SETTINGS_LOG_LEVEL=2
    # CONFIG_BT_SETTINGS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_INF is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HCI_CORE_LOG_LEVEL_INHERIT=y
    CONFIG_BT_HCI_CORE_LOG_LEVEL=2
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_INF is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CONN_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CONN_LOG_LEVEL=2
    # CONFIG_BT_CONN_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CONN_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CONN_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CONN_LOG_LEVEL_INF is not set
    # CONFIG_BT_CONN_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CONN_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_KEYS_LOG_LEVEL_INHERIT=y
    CONFIG_BT_KEYS_LOG_LEVEL=2
    # CONFIG_BT_KEYS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_INF is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SERVICE_LOG_LEVEL_INHERIT=y
    CONFIG_BT_SERVICE_LOG_LEVEL=2
    # CONFIG_BT_SERVICE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_INF is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_MESH_LOG_LEVEL_INHERIT is not set
    CONFIG_BT_MESH_LOG_LEVEL=2
    # CONFIG_BT_MESH_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_LOG_LEVEL_ERR is not set
    CONFIG_BT_MESH_LOG_LEVEL_WRN=y
    # CONFIG_BT_MESH_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_INHERIT is not set
    CONFIG_BT_MESH_NET_LOG_LEVEL=2
    # CONFIG_BT_MESH_NET_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_ERR is not set
    CONFIG_BT_MESH_NET_LOG_LEVEL_WRN=y
    # CONFIG_BT_MESH_NET_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_BRG_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_BRG_LOG_LEVEL=2
    # CONFIG_BT_MESH_BRG_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_BRG_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_BRG_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_BRG_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_BRG_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_BRG_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_RPL_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_RPL_LOG_LEVEL=2
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_INHERIT is not set
    CONFIG_BT_MESH_TRANS_LOG_LEVEL=2
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_ERR is not set
    CONFIG_BT_MESH_TRANS_LOG_LEVEL_WRN=y
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_INHERIT is not set
    CONFIG_BT_MESH_BEACON_LOG_LEVEL=2
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_ERR is not set
    CONFIG_BT_MESH_BEACON_LOG_LEVEL_WRN=y
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_CRYPTO_LOG_LEVEL=2
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_KEYS_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_KEYS_LOG_LEVEL=2
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_PROV_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_PROV_LOG_LEVEL=2
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_INHERIT is not set
    CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL=2
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_ERR is not set
    CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_WRN=y
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL=2
    # CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROVISIONEE_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_INHERIT is not set
    CONFIG_BT_MESH_ACCESS_LOG_LEVEL=2
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_ERR is not set
    CONFIG_BT_MESH_ACCESS_LOG_LEVEL_WRN=y
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_INHERIT is not set
    CONFIG_BT_MESH_MODEL_LOG_LEVEL=2
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_ERR is not set
    CONFIG_BT_MESH_MODEL_LOG_LEVEL_WRN=y
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_DFU_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_DFU_LOG_LEVEL=2
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_ADV_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_ADV_LOG_LEVEL=2
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL=2
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_FRIEND_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_FRIEND_LOG_LEVEL=2
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_PROXY_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_PROXY_LOG_LEVEL=2
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_INHERIT is not set
    CONFIG_BT_MESH_SETTINGS_LOG_LEVEL=2
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_ERR is not set
    CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_WRN=y
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_CDB_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_CDB_LOG_LEVEL=2
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_CFG_LOG_LEVEL_INHERIT=y
    CONFIG_BT_MESH_CFG_LOG_LEVEL=2
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_DIS is not set
    # CONFIG_BT_CTS is not set
    # CONFIG_BT_HRS is not set
    # CONFIG_BT_TPS is not set
    # CONFIG_BT_ZEPHYR_NUS is not set
    # CONFIG_BT_IAS is not set
    # CONFIG_BT_IAS_CLIENT is not set
    # CONFIG_BT_OTS is not set
    # CONFIG_BT_OTS_CLIENT is not set
    # CONFIG_BT_BAS is not set
    # CONFIG_BT_BAS_BLS is not set
    CONFIG_BT_BUF_ACL_RX_COUNT=6
    CONFIG_BT_BUF_EVT_RX_COUNT=10
    CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=58
    CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=20
    CONFIG_BT_HAS_HCI_VS=y
    # CONFIG_BT_HCI_VS_FATAL_ERROR is not set
    # CONFIG_BT_HCI_MESH_EXT is not set
    # CONFIG_BT_WAIT_NOP is not set
    CONFIG_BT_ASSERT=y
    CONFIG_BT_ASSERT_VERBOSE=y
    # CONFIG_BT_ASSERT_PANIC is not set
    # CONFIG_BT_HCI_ERR_TO_STR is not set
    CONFIG_BT_DEBUG_NONE=y
    # CONFIG_BT_DEBUG_MONITOR_UART is not set
    # CONFIG_BT_DEBUG_MONITOR_RTT is not set
    CONFIG_BT_LONG_WQ=y
    CONFIG_BT_LONG_WQ_STACK_SIZE=1300
    CONFIG_BT_LONG_WQ_PRIO=10
    CONFIG_BT_LONG_WQ_INIT_PRIO=50
    CONFIG_BT_HCI_HOST=y
    # CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
    CONFIG_BT_HCI_TX_PRIO=7
    # CONFIG_BT_RECV_WORKQ_SYS is not set
    CONFIG_BT_RECV_WORKQ_BT=y
    CONFIG_BT_RX_PRIO=8
    CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
    # CONFIG_BT_CONN_TX_NOTIFY_WQ is not set
    CONFIG_BT_MESH=y
    CONFIG_BT_MESH_PROV=y
    CONFIG_BT_MESH_ADV_EXT=y
    # CONFIG_BT_MESH_ADV_EXT_RELAY_USING_MAIN_ADV_SET is not set
    # CONFIG_BT_MESH_ADV_EXT_ACCEPT_EXT_ADV_PACKETS is not set
    CONFIG_BT_MESH_ADV_BUF_COUNT=30
    # CONFIG_BT_MESH_DEBUG_USE_ID_ADDR is not set
    CONFIG_BT_MESH_PB_ADV=y
    CONFIG_BT_MESH_UNPROV_BEACON_INT=5
    # CONFIG_BT_MESH_PB_ADV_USE_RELAY_SETS is not set
    CONFIG_BT_MESH_PB_ADV_TRANS_PDU_RETRANSMIT_COUNT=0
    CONFIG_BT_MESH_PB_ADV_TRANS_ACK_RETRANSMIT_COUNT=2
    CONFIG_BT_MESH_PB_ADV_LINK_CLOSE_RETRANSMIT_COUNT=2
    CONFIG_BT_MESH_PB_ADV_RETRANS_TIMEOUT=500
    # CONFIG_BT_MESH_PB_GATT is not set
    # CONFIG_BT_MESH_PROV_DEVICE is not set
    # CONFIG_BT_MESH_PROVISIONEE is not set
    CONFIG_BT_MESH_ECDH_P256_CMAC_AES128_AES_CCM=y
    CONFIG_BT_MESH_ECDH_P256_HMAC_SHA256_AES_CCM=y
    # CONFIG_BT_MESH_OOB_AUTH_REQUIRED is not set
    CONFIG_BT_MESH_PROVISIONER=y
    CONFIG_BT_MESH_CDB=y
    CONFIG_BT_MESH_CDB_NODE_COUNT=100
    CONFIG_BT_MESH_CDB_SUBNET_COUNT=3
    CONFIG_BT_MESH_CDB_APP_KEY_COUNT=3
    CONFIG_BT_MESH_LOOPBACK_BUFS=3
    CONFIG_BT_MESH_NETWORK_TRANSMIT_COUNT=2
    CONFIG_BT_MESH_NETWORK_TRANSMIT_INTERVAL=20
    CONFIG_BT_MESH_RELAY=y
    CONFIG_BT_MESH_RELAY_ENABLED=y
    CONFIG_BT_MESH_RELAY_RETRANSMIT_INTERVAL=20
    CONFIG_BT_MESH_RX_SEG_MSG_COUNT=1
    CONFIG_BT_MESH_SEG_BUFS=1024
    CONFIG_BT_MESH_SAR_TX_SEG_INT_STEP=0x05
    CONFIG_BT_MESH_SAR_TX_UNICAST_RETRANS_COUNT=0x02
    CONFIG_BT_MESH_SAR_TX_UNICAST_RETRANS_WITHOUT_PROG_COUNT=0x02
    CONFIG_BT_MESH_SAR_TX_UNICAST_RETRANS_INT_STEP=0x07
    CONFIG_BT_MESH_SAR_TX_UNICAST_RETRANS_INT_INC=0x01
    CONFIG_BT_MESH_SAR_TX_MULTICAST_RETRANS_COUNT=0x02
    CONFIG_BT_MESH_SAR_TX_MULTICAST_RETRANS_INT=0x09
    CONFIG_BT_MESH_SAR_RX_SEG_THRESHOLD=0x03
    CONFIG_BT_MESH_SAR_RX_ACK_DELAY_INC=0x01
    CONFIG_BT_MESH_SAR_RX_SEG_INT_STEP=0x05
    CONFIG_BT_MESH_SAR_RX_DISCARD_TIMEOUT=0x01
    CONFIG_BT_MESH_SAR_RX_ACK_RETRANS_COUNT=0x00
    CONFIG_BT_MESH_DEFAULT_TTL=7
    CONFIG_BT_MESH_RPL_STORAGE_MODE_SETTINGS=y
    # CONFIG_BT_MESH_ACCESS_LAYER_MSG is not set
    CONFIG_BT_MESH_MODEL_VND_MSG_CID_FORCE=y
    # CONFIG_BT_MESH_MODEL_EXTENSIONS is not set
    CONFIG_BT_MESH_COMP_PAGE_1=y
    CONFIG_BT_MESH_MODEL_EXTENSION_LIST_SIZE=0
    # CONFIG_BT_MESH_COMP_PAGE_2 is not set
    CONFIG_BT_MESH_COMP_PST_BUF_SIZE=100
    CONFIG_BT_MESH_ACCESS_DELAYABLE_MSG=y
    CONFIG_BT_MESH_ACCESS_DELAYABLE_MSG_CTX_ENABLED=y
    CONFIG_BT_MESH_ACCESS_DELAYABLE_MSG_COUNT=4
    CONFIG_BT_MESH_ACCESS_DELAYABLE_MSG_CHUNK_SIZE=10
    CONFIG_BT_MESH_ACCESS_DELAYABLE_MSG_CHUNK_COUNT=40
    CONFIG_BT_MESH_DELAYABLE_PUBLICATION=y
    CONFIG_BT_MESH_CFG_CLI=y
    CONFIG_BT_MESH_CFG_CLI_TIMEOUT=10000
    CONFIG_BT_MESH_HEALTH_CLI=y
    CONFIG_BT_MESH_HEALTH_CLI_TIMEOUT=2000
    # CONFIG_BT_MESH_BLOB_SRV is not set
    # CONFIG_BT_MESH_BLOB_CLI is not set
    CONFIG_BT_MESH_ALIGN_CHUNK_SIZE_TO_MAX_SEGMENT=y
    CONFIG_BT_MESH_BLOB_CHUNK_COUNT_MAX=256
    CONFIG_BT_MESH_DFU_FWID_MAXLEN=16
    CONFIG_BT_MESH_DFU_METADATA_MAXLEN=32
    CONFIG_BT_MESH_DFU_URI_MAXLEN=32
    # CONFIG_BT_MESH_DFU_SLOTS is not set
    # CONFIG_BT_MESH_RPR_SRV is not set
    # CONFIG_BT_MESH_RPR_CLI is not set
    CONFIG_BT_MESH_RPR_AD_TYPES_MAX=1
    CONFIG_BT_MESH_RPR_SRV_SCANNED_ITEMS_MAX=4
    CONFIG_BT_MESH_RPR_SRV_AD_DATA_MAX=31
    # CONFIG_BT_MESH_SAR_CFG_SRV is not set
    # CONFIG_BT_MESH_SAR_CFG_CLI is not set
    # CONFIG_BT_MESH_OP_AGG_SRV is not set
    # CONFIG_BT_MESH_OP_AGG_CLI is not set
    # CONFIG_BT_MESH_LARGE_COMP_DATA_CLI is not set
    # CONFIG_BT_MESH_PRIV_BEACON_CLI is not set
    # CONFIG_BT_MESH_OD_PRIV_PROXY_CLI is not set
    # CONFIG_BT_MESH_SOL_PDU_RPL_CLI is not set
    CONFIG_BT_MESH_BRG_TABLE_ITEMS_MAX=16
    # CONFIG_BT_MESH_BRG_CFG_CLI is not set
    # CONFIG_BT_MESH_GATT_PROXY is not set
    # CONFIG_BT_MESH_PROXY_SOLICITATION is not set
    CONFIG_BT_MESH_USES_TINYCRYPT=y
    # CONFIG_BT_MESH_USES_MBEDTLS_PSA is not set
    # CONFIG_BT_MESH_BEACON_ENABLED is not set
    CONFIG_BT_MESH_PRIV_BEACONS=y
    # CONFIG_BT_MESH_IV_UPDATE_TEST is not set
    CONFIG_BT_MESH_IV_UPDATE_SEQ_LIMIT=0x800000
    CONFIG_BT_MESH_IVU_DIVIDER=4
    # CONFIG_BT_MESH_LOW_POWER is not set
    # CONFIG_BT_MESH_FRIEND is not set
    CONFIG_BT_MESH_MODEL_KEY_COUNT=1
    CONFIG_BT_MESH_LABEL_COUNT=0
    CONFIG_BT_MESH_STORE_TIMEOUT=2
    CONFIG_BT_MESH_SEQ_STORE_RATE=128
    CONFIG_BT_MESH_RPL_STORE_TIMEOUT=600
    CONFIG_BT_MESH_SETTINGS_WORKQ=y
    CONFIG_BT_MESH_SETTINGS_WORKQ_PRIO=1
    # CONFIG_BT_MESH_SHELL is not set
    CONFIG_BT_MESH_MAX_CONN=3
    # CONFIG_BT_MESH_SELF_TEST is not set
    # CONFIG_BT_MESH_STATISTIC is not set
    # CONFIG_BT_AUDIO is not set
    # CONFIG_BT_HOST_CRYPTO is not set
    CONFIG_BT_SETTINGS=y
    CONFIG_BT_SETTINGS_CCC_LAZY_LOADING=y
    CONFIG_BT_SETTINGS_DELAYED_STORE=y
    CONFIG_BT_SETTINGS_DELAYED_STORE_MS=1000
    CONFIG_BT_SETTINGS_CCC_STORE_ON_WRITE=y
    CONFIG_BT_SETTINGS_CF_STORE_ON_WRITE=y
    CONFIG_BT_SETTINGS_CCC_STORE_MAX=48
    # CONFIG_BT_FILTER_ACCEPT_LIST is not set
    CONFIG_BT_LIM_ADV_TIMEOUT=30
    CONFIG_BT_CONN_TX_USER_DATA_SIZE=16
    CONFIG_BT_CONN_FRAG_COUNT=3
    CONFIG_BT_CONN_TX_MAX=3
    # CONFIG_BT_CONN_PARAM_ANY is not set
    # CONFIG_BT_REMOTE_INFO is not set
    # CONFIG_BT_SMP is not set
    CONFIG_BT_L2CAP_TX_BUF_COUNT=3
    CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
    # CONFIG_BT_L2CAP_SEG_RECV is not set
    # CONFIG_BT_L2CAP_RECONFIGURE_EXPLICIT is not set
    # CONFIG_BT_ATT_ERR_TO_STR is not set
    CONFIG_BT_ATT_TX_COUNT=3
    CONFIG_BT_ATT_PREPARE_COUNT=0
    # CONFIG_BT_ATT_SENT_CB_AFTER_TX is not set
    CONFIG_BT_GATT_SERVICE_CHANGED=y
    # CONFIG_BT_GATT_DYNAMIC_DB is not set
    CONFIG_BT_GATT_CACHING=y
    # CONFIG_BT_GATT_NOTIFY_MULTIPLE is not set
    # CONFIG_BT_GATT_ENFORCE_CHANGE_UNAWARE is not set
    CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y
    # CONFIG_BT_GATT_CLIENT is not set
    CONFIG_BT_GATT_READ_MULTIPLE=y
    CONFIG_BT_GATT_READ_MULT_VAR_LEN=y
    CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y
    CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y
    CONFIG_BT_PERIPHERAL_PREF_MIN_INT=24
    CONFIG_BT_PERIPHERAL_PREF_MAX_INT=40
    CONFIG_BT_PERIPHERAL_PREF_LATENCY=0
    CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=42
    # CONFIG_BT_GATT_AUTHORIZATION_CUSTOM is not set
    CONFIG_BT_MAX_PAIRED=0
    CONFIG_BT_CREATE_CONN_TIMEOUT=3
    CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000
    CONFIG_BT_CONN_PARAM_RETRY_COUNT=3
    CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=5000
    CONFIG_BT_BACKGROUND_SCAN_INTERVAL=2048
    CONFIG_BT_BACKGROUND_SCAN_WINDOW=18
    CONFIG_BT_EXT_SCAN_BUF_SIZE=229
    # CONFIG_BT_SCAN_WITH_IDENTITY is not set
    # CONFIG_BT_DEVICE_NAME_DYNAMIC is not set
    CONFIG_BT_DEVICE_NAME="Zephyr"
    # CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set
    CONFIG_BT_DEVICE_APPEARANCE=0
    CONFIG_BT_ID_MAX=2
    # CONFIG_BT_ECC is not set
    CONFIG_BT_HOST_CCM=y
    # CONFIG_BT_LOG_SNIFFER_INFO is not set
    # CONFIG_BT_TESTING is not set
    # CONFIG_BT_CLASSIC is not set
    # CONFIG_BT_HCI_VS_EVT_USER is not set
    # CONFIG_BT_SHELL is not set
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    # CONFIG_DFU_TARGET is not set
    # end of DFU
    # CONFIG_ESB is not set
    # CONFIG_EMDS is not set
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # nRF Cloud
    # Transport
    # CONFIG_NRF_CLOUD_REST is not set
    # end of Transport
    # Credentials
    CONFIG_NRF_CLOUD_SEC_TAG=16842753
    CONFIG_NRF_CLOUD_AWS_CA_CERT_SIZE_THRESHOLD=1150
    CONFIG_NRF_CLOUD_COAP_CA_CERT_SIZE_THRESHOLD=550
    # end of Credentials
    # Client ID (nRF Cloud Device ID)
    CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
    # CONFIG_NRF_CLOUD_CLIENT_ID_SRC_RUNTIME is not set
    CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
    # end of Client ID (nRF Cloud Device ID)
    # Firmware Over-the-Air (FOTA) Updates
    # CONFIG_NRF_CLOUD_FOTA is not set
    CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA=y
    # CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
    # CONFIG_NRF_CLOUD_FOTA_SMP is not set
    # CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL=3
    # end of Firmware Over-the-Air (FOTA) Updates
    # Location
    # Cellular/Wi-Fi
    # CONFIG_NRF_CLOUD_LOCATION_PARSE_ANCHORS is not set
    # CONFIG_NRF_CLOUD_WIFI_LOCATION_ENCODE_OPT_MAC_ONLY is not set
    CONFIG_NRF_CLOUD_WIFI_LOCATION_ENCODE_OPT_MAC_RSSI=y
    # CONFIG_NRF_CLOUD_WIFI_LOCATION_ENCODE_OPT_ALL is not set
    # end of Cellular/Wi-Fi
    # end of Location
    # Alerts
    # CONFIG_NRF_CLOUD_ALERT is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL=3
    # end of Alerts
    # Logging
    CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
    # CONFIG_NRF_CLOUD_LOG_INCLUDE_LEVEL_0 is not set
    CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL=3
    # end of Logging
    # Device Shadow
    # Send shadow info sections on initial connect (MQTT/CoAP)
    # end of Send shadow info sections on initial connect (MQTT/CoAP)
    # end of Device Shadow
    CONFIG_NRF_CLOUD_PRINT_DETAILS=y
    CONFIG_NRF_CLOUD_VERBOSE_DETAILS=y
    # CONFIG_NRF_CLOUD_GATEWAY is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LEVEL=3
    # end of nRF Cloud
    # CONFIG_REST_CLIENT is not set
    # CONFIG_DOWNLOAD_CLIENT is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    # CONFIG_WIFI_CREDENTIALS is not set
    # CONFIG_WIFI_CREDENTIALS_STATIC is not set
    # CONFIG_MQTT_HELPER is not set
    # CONFIG_NRF_PROVISIONING is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
    # end of Application protocols
    # CONFIG_OPENTHREAD_RPC is not set
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_PLATFORM is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # CONFIG_NFC_RPC is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # CONFIG_NRF_PROFILER is not set
    # CONFIG_FW_INFO is not set
    # Debug
    # CONFIG_CPU_LOAD is not set
    # CONFIG_PPI_TRACE is not set
    # end of Debug
    # CONFIG_SHELL_BT_NUS is not set
    # Multiprotocol service layer (MPSL)
    # CONFIG_MPSL_FEM_ONLY is not set
    CONFIG_MPSL_FEM_API_AVAILABLE=y
    # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_FEM_LOG_LEVEL=3
    CONFIG_MPSL_THREAD_COOP_PRIO=6
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    CONFIG_MPSL_LOW_PRIO_IRQN=25
    CONFIG_MPSL_HFCLK_LATENCY=1400
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_LOG_LEVEL=3
    # CONFIG_MPSL_PIN_DEBUG is not set
    # end of Multiprotocol service layer (MPSL)
    # Partition Manager
    CONFIG_PARTITION_MANAGER_ENABLED=y
    CONFIG_FLASH_MAP_CUSTOM=y
    CONFIG_SRAM_SIZE=256
    CONFIG_SRAM_BASE_ADDRESS=0x20000000
    # Zephyr subsystem configurations
    CONFIG_PM_PARTITION_SIZE_LITTLEFS=0x6000
    # CONFIG_PM_PARTITION_REGION_LITTLEFS_EXTERNAL is not set
    CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x2000
    # CONFIG_PM_PARTITION_REGION_SETTINGS_STORAGE_EXTERNAL is not set
    CONFIG_PM_PARTITION_ALIGN_SETTINGS_STORAGE=0x1000
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    # CONFIG_PM_SINGLE_IMAGE is not set
    CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER=y
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    CONFIG_PM_EXTERNAL_FLASH_ENABLED=y
    CONFIG_PM_EXTERNAL_FLASH_PATH="/soc/spi@4002f000/w25q64fv@0"
    CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=67108864
    # CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY is not set
    # CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x40000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # CONFIG_ZIGBEE is not set
    # Full Modem Firmware Update Management(FMFU)
    # CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_INF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
    CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT=y
    CONFIG_MGMT_FMFU_LOG_LEVEL=3
    # end of Full Modem Firmware Update Management(FMFU)
    # CONFIG_CAF is not set
    # Nordic IEEE 802.15.4
    # end of Nordic IEEE 802.15.4
    # CONFIG_DM_MODULE is not set
    # nRF Security
    # CONFIG_NORDIC_SECURITY_BACKEND is not set
    # CONFIG_NRF_SECURITY is not set
    # Nordic-added meta types
    # Nordic added alg types
    # CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
    # CONFIG_PSA_WANT_ALG_ED25519PH is not set
    # CONFIG_PSA_WANT_ALG_ED448PH is not set
    # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
    # CONFIG_PSA_WANT_ALG_SRP_6 is not set
    # CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_ALG_XTS is not set
    # Nordic added ECC curve types
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
    # CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
    # CONFIG_PSA_WANT_ALG_CHACHA20 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
    # Nordic addded RNG configuration
    # CONFIG_PSA_WANT_GENERATE_RANDOM is not set
    # Nordic added key types
    # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
    # end of nRF Security
    # Audio Modules
    # CONFIG_AUDIO_MODULE_TEST is not set
    CONFIG_AUDIO_MODULE_NAME_SIZE=20
    # Log levels
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_OFF is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_ERR is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_WRN is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_INF is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_DBG is not set
    CONFIG_AUDIO_MODULE_LOG_LEVEL_DEFAULT=y
    CONFIG_AUDIO_MODULE_LOG_LEVEL=3
    # end of Log levels
    # end of Audio Modules
    # Audio Modules
    # CONFIG_AUDIO_MODULE_TEMPLATE is not set
    # CONFIG_UART_ASYNC_ADAPTER is not set
    # CONFIG_TRUSTED_STORAGE is not set
    # Logging over RPC
    # CONFIG_LOG_FORWARDER_RPC is not set
    # CONFIG_LOG_BACKEND_RPC is not set
    # end of Logging over RPC
    # SUIT provisioning
    # CONFIG_SUIT_MPI_GENERATE is not set
    # end of SUIT provisioning
    # CONFIG_SUIT is not set
    # CONFIG_DULT is not set
    # CONFIG_NRF_COMPRESS is not set
    # MCUboot IDs (informative only, do not change)
    CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=0
    CONFIG_MCUBOOT_NETWORK_CORE_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_QSPI_XIP_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER=-1
    # end of MCUboot IDs (informative only, do not change)
    # end of Subsystems
    # CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
    # CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
    # CONFIG_WFA_QT_LOG_LEVEL_INF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
    CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
    CONFIG_WFA_QT_LOG_LEVEL=3
    # CONFIG_WFA_QT_CONTROL_APP is not set
    CONFIG_WFA_QT_THREAD_STACK_SIZE=5200
    CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
    CONFIG_WFA_QT_DEFAULT_INTERFACE="wlan0"
    CONFIG_WPAS_READY_TIMEOUT_MS=10000
    # Libraries
    # Binary libraries
    # end of Binary libraries
    # CONFIG_AT_MONITOR is not set
    # CONFIG_DISABLE_FLASH_PATCH is not set
    # CONFIG_LTE_LINK_CONTROL is not set
    CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x1000
    CONFIG_FPROTECT_BLOCK_SIZE=0x1000
    # CONFIG_FPROTECT is not set
    # CONFIG_AT_CMD_CUSTOM is not set
    # CONFIG_DK_LIBRARY is not set
    # CONFIG_AT_CMD_PARSER is not set
    # CONFIG_AT_PARSER is not set
    # CONFIG_MODEM_INFO is not set
    CONFIG_MULTITHREADING_LOCK=y
    # CONFIG_RESET_ON_FATAL_ERROR is not set
    # CONFIG_SMS is not set
    # CONFIG_SUPL_CLIENT_LIB is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_HW_ID_LIBRARY is not set
    # CONFIG_RAM_POWER_DOWN_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    # CONFIG_HW_UNIQUE_KEY_LOAD is not set
    CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0x1000
    # CONFIG_MODEM_JWT is not set
    # CONFIG_LOCATION is not set
    # CONFIG_QOS is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY is not set
    # CONFIG_PCM_MIX is not set
    # CONFIG_TONE is not set
    # CONFIG_PSCM is not set
    # CONFIG_DATA_FIFO is not set
    # CONFIG_FEM_AL_LIB is not set
    # CONFIG_SAMPLE_RATE_CONVERTER is not set
    # CONFIG_NCS_BOOT_BANNER is not set
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    CONFIG_ENTROPY_CC3XX=y
    # CONFIG_FLASH_RPC is not set
    # CONFIG_GPIO_NRFE_EGPIO_BACKEND_MBOX is not set
    CONFIG_GPIO_NRFE_EGPIO_BACKEND_ICMSG=y
    # CONFIG_GPIO_NRFE_EGPIO_BACKEND_ICBMSG is not set
    CONFIG_HW_CC3XX=y
    CONFIG_CLOCK_CONTROL_MPSL=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=1
    # CONFIG_ETH_RTT is not set
    # CONFIG_SENSOR is not set
    # CONFIG_NRF_SW_LPUART is not set
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
    # end of Device Drivers
    # External libraries
    # end of External libraries
    # Test
    CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # CONFIG_MOCK_NRF_RPC is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (C:/ncs/v2.8.0/nrf)
    # mcuboot (C:/ncs/v2.8.0/bootloader/mcuboot)
    # MCUboot
    CONFIG_BOOT_SIGNATURE_KEY_FILE=""
    # CONFIG_BOOT_BUILD_DIRECT_XIP_VARIANT is not set
    CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=4
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    CONFIG_MCUBOOT_USB_SUPPORT=y
    # CONFIG_USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY is not set
    # CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD is not set
    # CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS is not set
    # end of MCUboot
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (C:/ncs/v2.8.0/bootloader/mcuboot)
    # mbedtls (C:/ncs/v2.8.0/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    # end of mbedtls (C:/ncs/v2.8.0/modules/crypto/mbedtls)
    # oberon-psa-crypto (C:/ncs/v2.8.0/modules/crypto/oberon-psa-crypto)
    CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
    # end of oberon-psa-crypto (C:/ncs/v2.8.0/modules/crypto/oberon-psa-crypto)
    # trusted-firmware-m (C:/ncs/v2.8.0/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    # end of trusted-firmware-m (C:/ncs/v2.8.0/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
    CONFIG_ZEPHYR_SOC_HWMV1_MODULE=y
    # cjson (C:/ncs/v2.8.0/modules/lib/cjson)
    # CONFIG_CJSON_LIB is not set
    CONFIG_ZEPHYR_CJSON_MODULE=y
    # end of cjson (C:/ncs/v2.8.0/modules/lib/cjson)
    # azure-sdk-for-c (C:/ncs/v2.8.0/modules/lib/azure-sdk-for-c)
    # CONFIG_AZURE_SDK is not set
    CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    # end of azure-sdk-for-c (C:/ncs/v2.8.0/modules/lib/azure-sdk-for-c)
    # cirrus-logic (C:/ncs/v2.8.0/modules/hal/cirrus-logic)
    # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
    CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    # end of cirrus-logic (C:/ncs/v2.8.0/modules/hal/cirrus-logic)
    # openthread (C:/ncs/v2.8.0/modules/lib/openthread)
    # CONFIG_OPENTHREAD is not set
    CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    # end of openthread (C:/ncs/v2.8.0/modules/lib/openthread)
    # suit-generator (C:/ncs/v2.8.0/modules/lib/suit-generator)
    CONFIG_SUIT_ENVELOPE_TEMPLATE_FILENAME=""
    CONFIG_SUIT_ENVELOPE_TARGET=""
    CONFIG_SUIT_ENVELOPE_OUTPUT_ARTIFACT="merged.hex"
    # CONFIG_SUIT_RECOVERY is not set
    CONFIG_SUIT_ENVELOPE_OUTPUT_MPI_MERGE=y
    # CONFIG_SUIT_LOCAL_ENVELOPE_GENERATE is not set
    # CONFIG_SUIT_DFU_CACHE_EXTRACT_IMAGE is not set
    CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE=y
    # end of suit-generator (C:/ncs/v2.8.0/modules/lib/suit-generator)
    # suit-processor (C:/ncs/v2.8.0/modules/lib/suit-processor)
    # CONFIG_SUIT_PROCESSOR is not set
    CONFIG_SUIT_PLATFORM_DRY_RUN_SUPPORT=y
    CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE=y
    # end of suit-processor (C:/ncs/v2.8.0/modules/lib/suit-processor)
    # memfault-firmware-sdk (C:/ncs/v2.8.0/modules/lib/memfault-firmware-sdk)
    # CONFIG_MEMFAULT is not set
    CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    # end of memfault-firmware-sdk (C:/ncs/v2.8.0/modules/lib/memfault-firmware-sdk)
    # coremark (C:/ncs/v2.8.0/modules/benchmark/coremark)
    # CONFIG_COREMARK is not set
    CONFIG_ZEPHYR_COREMARK_MODULE=y
    # end of coremark (C:/ncs/v2.8.0/modules/benchmark/coremark)
    # canopennode (C:/ncs/v2.8.0/modules/lib/canopennode)
    CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    # end of canopennode (C:/ncs/v2.8.0/modules/lib/canopennode)
    # chre (C:/ncs/v2.8.0/modules/lib/chre)
    CONFIG_ZEPHYR_CHRE_MODULE=y
    # CONFIG_CHRE is not set
    # end of chre (C:/ncs/v2.8.0/modules/lib/chre)
    # lz4 (C:/ncs/v2.8.0/modules/lib/lz4)
    CONFIG_ZEPHYR_LZ4_MODULE=y
    # CONFIG_LZ4 is not set
    # end of lz4 (C:/ncs/v2.8.0/modules/lib/lz4)
    # nanopb (C:/ncs/v2.8.0/modules/lib/nanopb)
    CONFIG_ZEPHYR_NANOPB_MODULE=y
    # CONFIG_NANOPB is not set
    # end of nanopb (C:/ncs/v2.8.0/modules/lib/nanopb)
    CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
    # zscilib (C:/ncs/v2.8.0/modules/lib/zscilib)
    # CONFIG_ZSL is not set
    CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    # end of zscilib (C:/ncs/v2.8.0/modules/lib/zscilib)
    # cmsis (C:/ncs/v2.8.0/modules/hal/cmsis)
    CONFIG_ZEPHYR_CMSIS_MODULE=y
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
    # end of cmsis (C:/ncs/v2.8.0/modules/hal/cmsis)
    # cmsis-dsp (C:/ncs/v2.8.0/modules/lib/cmsis-dsp)
    CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
    # CONFIG_CMSIS_DSP is not set
    # end of cmsis-dsp (C:/ncs/v2.8.0/modules/lib/cmsis-dsp)
    # cmsis-nn (C:/ncs/v2.8.0/modules/lib/cmsis-nn)
    CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
    # CONFIG_CMSIS_NN is not set
    # end of cmsis-nn (C:/ncs/v2.8.0/modules/lib/cmsis-nn)
    # fatfs (C:/ncs/v2.8.0/modules/fs/fatfs)
    CONFIG_ZEPHYR_FATFS_MODULE=y
    # end of fatfs (C:/ncs/v2.8.0/modules/fs/fatfs)
    # hal_nordic (C:/ncs/v2.8.0/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    # CONFIG_NRF_802154_RADIO_DRIVER is not set
    # CONFIG_NRF_802154_SER_RADIO is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # nrfx drivers logging
    # CONFIG_NRFX_GPIOTE_LOG is not set
    # CONFIG_NRFX_NVMC_LOG is not set
    # CONFIG_NRFX_PPI_LOG is not set
    # CONFIG_NRFX_QSPI_LOG is not set
    # CONFIG_NRFX_SPIM_LOG is not set
    # CONFIG_NRFX_TWI_LOG is not set
    # end of nrfx drivers logging
    CONFIG_MPSL=y
    # CONFIG_NRFX_CLOCK is not set
    # CONFIG_NRFX_COMP is not set
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    CONFIG_NRFX_GPIOTE=y
    CONFIG_NRFX_GPIOTE0=y
    # CONFIG_NRFX_I2S0 is not set
    # CONFIG_NRFX_NFCT is not set
    CONFIG_NRFX_NVMC=y
    # CONFIG_NRFX_PDM0 is not set
    # CONFIG_NRFX_POWER is not set
    CONFIG_NRFX_PPI=y
    # CONFIG_NRFX_PWM0 is not set
    # CONFIG_NRFX_PWM1 is not set
    # CONFIG_NRFX_PWM2 is not set
    # CONFIG_NRFX_PWM3 is not set
    # CONFIG_NRFX_QDEC0 is not set
    CONFIG_NRFX_QSPI=y
    # CONFIG_NRFX_RNG is not set
    # CONFIG_NRFX_RTC0 is not set
    # CONFIG_NRFX_RTC1 is not set
    # CONFIG_NRFX_RTC2 is not set
    # CONFIG_NRFX_SAADC is not set
    # CONFIG_NRFX_SPI0 is not set
    # CONFIG_NRFX_SPI1 is not set
    # CONFIG_NRFX_SPI2 is not set
    CONFIG_NRFX_SPIM=y
    CONFIG_NRFX_SPIM3=y
    # CONFIG_NRFX_SYSTICK is not set
    # CONFIG_NRFX_TEMP is not set
    # CONFIG_NRFX_TIMER0 is not set
    # CONFIG_NRFX_TIMER1 is not set
    # CONFIG_NRFX_TIMER2 is not set
    # CONFIG_NRFX_TIMER3 is not set
    # CONFIG_NRFX_TIMER4 is not set
    CONFIG_NRFX_TWI=y
    CONFIG_NRFX_TWI0=y
    # CONFIG_NRFX_TWI1 is not set
    # CONFIG_NRFX_UARTE0 is not set
    # CONFIG_NRFX_UARTE1 is not set
    # CONFIG_NRFX_WDT0 is not set
    # Peripheral Resource Sharing module
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    # end of hal_nordic (C:/ncs/v2.8.0/modules/hal/nordic)
    # hal_st (C:/ncs/v2.8.0/modules/hal/st)
    CONFIG_ZEPHYR_HAL_ST_MODULE=y
    # end of hal_st (C:/ncs/v2.8.0/modules/hal/st)
    CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
    # hostap (C:/ncs/v2.8.0/modules/lib/hostap)
    # CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
    CONFIG_ZEPHYR_HOSTAP_MODULE=y
    # end of hostap (C:/ncs/v2.8.0/modules/lib/hostap)
    CONFIG_ZEPHYR_LIBMETAL_MODULE=y
    # liblc3 (C:/ncs/v2.8.0/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBLC3_MODULE=y
    # CONFIG_LIBLC3 is not set
    # end of liblc3 (C:/ncs/v2.8.0/modules/lib/liblc3)
    # littlefs (C:/ncs/v2.8.0/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (C:/ncs/v2.8.0/modules/fs/littlefs)
    # loramac-node (C:/ncs/v2.8.0/modules/lib/loramac-node)
    CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # end of loramac-node (C:/ncs/v2.8.0/modules/lib/loramac-node)
    # lvgl (C:/ncs/v2.8.0/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_LVGL_MODULE=y
    # end of lvgl (C:/ncs/v2.8.0/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
    CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
    CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
    # picolibc (C:/ncs/v2.8.0/modules/lib/picolibc)
    # CONFIG_PICOLIBC_MODULE is not set
    CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    # end of picolibc (C:/ncs/v2.8.0/modules/lib/picolibc)
    # segger (C:/ncs/v2.8.0/modules/debug/segger)
    CONFIG_ZEPHYR_SEGGER_MODULE=y
    CONFIG_HAS_SEGGER_RTT=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_SEGGER_RTT_CUSTOM_LOCKING=y
    CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
    CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
    CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
    CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
    CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
    CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
    # CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
    # CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
    CONFIG_SEGGER_RTT_MODE=0
    # CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
    # CONFIG_SEGGER_RTT_SECTION_NONE is not set
    # CONFIG_SEGGER_RTT_SECTION_DTCM is not set
    # CONFIG_SEGGER_RTT_SECTION_CCM is not set
    CONFIG_SEGGER_RTT_SECTION_CUSTOM=y
    # CONFIG_SEGGER_RTT_SECTION_CUSTOM_DTS_REGION is not set
    CONFIG_SEGGER_RTT_SECTION_CUSTOM_NAME=".rtt_buff_data"
    # CONFIG_SEGGER_RTT_INIT_MODE_ALWAYS is not set
    CONFIG_SEGGER_RTT_INIT_MODE_STRONG_CHECK=y
    # CONFIG_SEGGER_RTT_INIT_MODE_WEAK_CHECK is not set
    # end of segger (C:/ncs/v2.8.0/modules/debug/segger)
    CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
    # uoscore-uedhoc (C:/ncs/v2.8.0/modules/lib/uoscore-uedhoc)
    CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    # end of uoscore-uedhoc (C:/ncs/v2.8.0/modules/lib/uoscore-uedhoc)
    # zcbor (C:/ncs/v2.8.0/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    CONFIG_ZCBOR=y
    # CONFIG_ZCBOR_CANONICAL is not set
    # CONFIG_ZCBOR_STOP_ON_ERROR is not set
    # CONFIG_ZCBOR_VERBOSE is not set
    CONFIG_ZCBOR_MAX_STR_LEN=256
    # end of zcbor (C:/ncs/v2.8.0/modules/lib/zcbor)
    # custom_dac (C:/Luminarias/lum/ble_mesh_mvp/provisioner/../modules/custom_drivers)
    CONFIG_DAC_MCP4726=y
    # CONFIG_DAC_MCP4726_WRITE_TO_EEPROM is not set
    CONFIG_DAC_MCP4726_INIT_PRIORITY=80
    # CONFIG_LTR308 is not set
    # CONFIG_MCP39F511 is not set
    CONFIG_GPS_CTRL_LOG_LEVEL=2
    CONFIG_ZEPHYR_CUSTOM_DAC_MODULE=y
    # end of custom_dac (C:/Luminarias/lum/ble_mesh_mvp/provisioner/../modules/custom_drivers)
    # nrfxlib (C:/ncs/v2.8.0/nrfxlib)
    # Nordic nrfxlib
    # nrf_modem (Modem library)
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # end of nrf_modem (Modem library)
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    CONFIG_MPSL_BUILD_TYPE_LIB=y
    CONFIG_MPSL_LIB_DIR="nrf52"
    CONFIG_MPSL_LIB_FLOAT_ABI_DIR="hard-float"
    # Crypto libraries for nRF5x SOCs.
    CONFIG_NRFXLIB_CRYPTO=y
    CONFIG_HAS_HW_NRF_CC3XX=y
    CONFIG_NRF_OBERON=y
    # CONFIG_NRF_CC310_BL is not set
    CONFIG_NRF_CC3XX_PLATFORM=y
    CONFIG_CC3XX_MUTEX_LOCK=y
    # CONFIG_CC3XX_ATOMIC_LOCK is not set
    # end of Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_GZLL is not set
    # CONFIG_NRF_DM is not set
    # CONFIG_SW_CODEC_LC3_T2_SOFTWARE is not set
    # CONFIG_NRF_FUEL_GAUGE is not set
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (C:/ncs/v2.8.0/nrfxlib)
    # connectedhomeip (C:/ncs/v2.8.0/modules/lib/matter)
    # CONFIG_CHIP is not set
    CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # end of connectedhomeip (C:/ncs/v2.8.0/modules/lib/matter)
    # CONFIG_LIBMETAL is not set
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    # CONFIG_HAS_MEC5_HAL is not set
    # CONFIG_OPENAMP is not set
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    # CONFIG_TINYCRYPT_CTR_PRNG is not set
    CONFIG_TINYCRYPT_SHA256=y
    CONFIG_TINYCRYPT_SHA256_HMAC=y
    # CONFIG_TINYCRYPT_SHA256_HMAC_PRNG is not set
    CONFIG_TINYCRYPT_ECC_DH=y
    # CONFIG_TINYCRYPT_ECC_DSA is not set
    CONFIG_TINYCRYPT_AES=y
    # CONFIG_TINYCRYPT_AES_CBC is not set
    # CONFIG_TINYCRYPT_AES_CTR is not set
    # CONFIG_TINYCRYPT_AES_CCM is not set
    CONFIG_TINYCRYPT_AES_CMAC=y
    CONFIG_MCUBOOT_CMAKE_WEST_SIGN_PARAMS="--quiet"
    CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="C:/Luminarias/lum/ble_mesh_mvp/provisioner/private_key.pem"
    CONFIG_MCUBOOT_ENCRYPTION_KEY_FILE=""
    CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION="1.0.0+0"
    # CONFIG_MCUBOOT_IMGTOOL_OVERWRITE_ONLY is not set
    CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS=""
    # On board MCUboot operation mode
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SINGLE_APP is not set
    CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH=y
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_SCRATCH is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_OVERWRITE_ONLY is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP_WITH_REVERT is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_FIRMWARE_UPDATER is not set
    CONFIG_MCUBOOT_BOOTLOADER_MODE_HAS_NO_DOWNGRADE=y
    # CONFIG_MCUBOOT_BOOTLOADER_NO_DOWNGRADE is not set
    # CONFIG_MCUBOOT_BOOTLOADER_USES_SHA512 is not set
    # end of On board MCUboot operation mode
    CONFIG_MCUBOOT_BOOTUTIL_LIB=y
    CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_OFF is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_ERR is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_INF is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG is not set
    CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUBOOT_UTIL_LOG_LEVEL=3
    # CONFIG_BOOT_IMAGE_ACCESS_HOOKS is not set
    # Unavailable modules, please install those via the project manifest.
    # hal_gigadevice module not available.
    # Trusted-firmware-a module not available.
    # THRIFT module not available.
    # CONFIG_ACPI is not set
    # end of Modules
    CONFIG_BOARD="nrf52840dk"
    CONFIG_BOARD_REVISION=""
    CONFIG_BOARD_TARGET="nrf52840dk/nrf52840"
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_NRF52840DK=y
    CONFIG_BOARD_NRF52840DK_NRF52840=y
    CONFIG_BOARD_QUALIFIERS="nrf52840"
    # Board Options
    # end of Board Options
    # Hardware Configuration
    CONFIG_SOC_FAMILY_NORDIC_NRF=y
    CONFIG_SOC_SERIES_NRF52X=y
    CONFIG_SOC_NRF52840=y
    CONFIG_SOC_NRF52840_QIAA=y
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    CONFIG_HAS_HW_NRF_ACL=y
    CONFIG_HAS_HW_NRF_CC310=y
    CONFIG_HAS_HW_NRF_CCM=y
    CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_ECB=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIO1=y
    CONFIG_HAS_HW_NRF_GPIOTE0=y
    CONFIG_HAS_HW_NRF_MWU=y
    CONFIG_HAS_HW_NRF_NVMC_PE=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_PPI=y
    CONFIG_HAS_HW_NRF_PWM0=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
    CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
    CONFIG_HAS_HW_NRF_RADIO_TX_PWR_HIGH=y
    CONFIG_HAS_HW_NRF_RNG=y
    CONFIG_HAS_HW_NRF_SAADC=y
    CONFIG_HAS_HW_NRF_SPIM3=y
    CONFIG_HAS_HW_NRF_SWI0=y
    CONFIG_HAS_HW_NRF_SWI1=y
    CONFIG_HAS_HW_NRF_SWI2=y
    CONFIG_HAS_HW_NRF_SWI3=y
    CONFIG_HAS_HW_NRF_SWI4=y
    CONFIG_HAS_HW_NRF_SWI5=y
    CONFIG_HAS_HW_NRF_TEMP=y
    CONFIG_HAS_HW_NRF_TWI0=y
    CONFIG_HAS_HW_NRF_UARTE0=y
    CONFIG_HAS_HW_NRF_UARTE1=y
    CONFIG_HAS_HW_NRF_USBD=y
    CONFIG_HAS_HW_NRF_WDT0=y
    # CONFIG_NRF_SYS_EVENT is not set
    # CONFIG_GPIO_AS_PINRESET is not set
    CONFIG_NRF_ENABLE_ICACHE=y
    CONFIG_NRF52_ANOMALY_198_WORKAROUND=y
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
    # CONFIG_SOC_NRF54H20_GPD is not set
    # CONFIG_SOC_NRF54H20_NO_MRAM_LATENCY is not set
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    # CONFIG_NFCT_PINS_AS_GPIOS is not set
    CONFIG_NRF_APPROTECT_USE_UICR=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_TRACE_PORT is not set
    CONFIG_GPIO_INIT_PRIORITY=40
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    # CONFIG_SOC_LOG_LEVEL_INF is not set
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL_DEFAULT=y
    CONFIG_SOC_LOG_LEVEL=3
    # end of Hardware Configuration
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_COMPATIBLE_NRF52X=y
    CONFIG_ARCH="arm"
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_CPU_CORTEX=y
    CONFIG_KOBJECT_TEXT_AREA=256
    CONFIG_ARM_MPU=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    # ARM Options
    CONFIG_CPU_CORTEX_M=y
    # CONFIG_ARM_ZIMAGE_HEADER is not set
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    # CONFIG_PLATFORM_SPECIFIC_INIT is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_ARM_STORE_EXC_RETURN=y
    CONFIG_FP_HARDABI=y
    # CONFIG_FP_SOFTABI is not set
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M4=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_ZERO_LATENCY_IRQS=y
    CONFIG_ZERO_LATENCY_LEVELS=1
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DWT is not set
    # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
    CONFIG_MPU_STACK_GUARD=y
    CONFIG_MPU_STACK_GUARD_MIN_SIZE_FLOAT=128
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    CONFIG_HAS_SWO=y
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    # CONFIG_ARCH_LOG_LEVEL_INF is not set
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
    CONFIG_ARCH_LOG_LEVEL=3
    CONFIG_LITTLE_ENDIAN=y
    # CONFIG_USERSPACE is not set
    CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
    CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # CONFIG_FRAME_POINTER is not set
    # Interrupt Configuration
    CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
    # CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    CONFIG_EXCEPTION_DEBUG=y
    # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_SUPPORTS_ROM_START=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MPU=y
    # CONFIG_MPU_LOG_LEVEL_OFF is not set
    # CONFIG_MPU_LOG_LEVEL_ERR is not set
    # CONFIG_MPU_LOG_LEVEL_WRN is not set
    # CONFIG_MPU_LOG_LEVEL_INF is not set
    # CONFIG_MPU_LOG_LEVEL_DBG is not set
    CONFIG_MPU_LOG_LEVEL_DEFAULT=y
    CONFIG_MPU_LOG_LEVEL=3
    CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # DSP Options
    # end of DSP Options
    # Floating Point Options
    CONFIG_FPU_SHARING=y
    # end of Floating Point Options
    # Cache Options
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    # General Kernel Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    # CONFIG_KERNEL_LOG_LEVEL_INF is not set
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
    CONFIG_KERNEL_LOG_LEVEL=3
    CONFIG_MULTITHREADING=y
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_MAIN_THREAD_PRIORITY=-2
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    # CONFIG_DYNAMIC_THREAD is not set
    CONFIG_SCHED_DUMB=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_DUMB=y
    # Misc Kernel related options
    CONFIG_ERRNO=y
    # end of Misc Kernel related options
    # Kernel Debugging and Metrics
    # CONFIG_BOOT_BANNER is not set
    CONFIG_BOOT_DELAY=0
    # CONFIG_BOOT_CLEAR_SCREEN is not set
    CONFIG_THREAD_MONITOR=y
    # CONFIG_THREAD_NAME is not set
    # CONFIG_THREAD_RUNTIME_STATS is not set
    # end of Kernel Debugging and Metrics
    # CONFIG_OBJ_CORE is not set
    # System Work Queue Options
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    # end of System Work Queue Options
    # Barrier Operations
    CONFIG_BARRIER_OPERATIONS_ARCH=y
    # end of Barrier Operations
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    # end of Timer API Options
    # Other Kernel Object Options
    CONFIG_POLL=y
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    CONFIG_EVENTS=y
    # CONFIG_PIPES is not set
    CONFIG_KERNEL_MEM_POOL=y
    # CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
    # end of Other Kernel Object Options
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    # Security Options
    # CONFIG_STACK_CANARIES is not set
    CONFIG_STACK_POINTER_RANDOM=0
    # end of Security Options
    # Memory Domains
    CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
    CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
    # end of Memory Domains
    # SMP Options
    CONFIG_MP_NUM_CPUS=1
    # CONFIG_TICKET_SPINLOCKS is not set
    # end of SMP Options
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # CONFIG_THREAD_LOCAL_STORAGE is not set
    CONFIG_TOOLCHAIN_SUPPORTS_STATIC_INIT_GNU=y
    # CONFIG_STATIC_INIT_GNU is not set
    # CONFIG_BOOTARGS is not set
    # end of General Kernel Options
    # Device Options
    # CONFIG_DEVICE_DEPS is not set
    # CONFIG_DEVICE_MUTABLE is not set
    # CONFIG_DEVICE_DT_METADATA is not set
    # end of Device Options
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_LIBC=35
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Virtual Memory Support
    # end of Virtual Memory Support
    # SoC and Board Hooks
    # CONFIG_SOC_PREP_HOOK is not set
    # CONFIG_SOC_EARLY_INIT_HOOK is not set
    # CONFIG_SOC_LATE_INIT_HOOK is not set
    # CONFIG_BOARD_EARLY_INIT_HOOK is not set
    # CONFIG_BOARD_LATE_INIT_HOOK is not set
    # end of SoC and Board Hooks
    # Device Drivers
    # CONFIG_ADC is not set
    # CONFIG_AUDIO is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_BBRAM is not set
    # Bluetooth HCI Driver Options
    CONFIG_BT_HCI_INIT_PRIORITY=50
    # CONFIG_HCI_NXP_SET_CAL_DATA_ANNEX100 is not set
    CONFIG_FLASH=y
    CONFIG_BT_DRV_TX_STACK_SIZE=256
    CONFIG_BT_DRV_RX_STACK_SIZE=256
    # CONFIG_CAN is not set
    # CONFIG_CHARGER is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
    CONFIG_CLOCK_CONTROL_NRF_FORCE_ALT=y
    CONFIG_CLOCK_CONTROL_NRF=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_LOW_SWING is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
    # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
    # CONFIG_COMPARATOR is not set
    CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
    CONFIG_CONSOLE_HAS_DRIVER=y
    # CONFIG_CONSOLE_HANDLER is not set
    CONFIG_CONSOLE_INIT_PRIORITY=60
    CONFIG_UART_CONSOLE=y
    # CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
    # CONFIG_UART_CONSOLE_MCUMGR is not set
    # CONFIG_RAM_CONSOLE is not set
    CONFIG_RTT_CONSOLE=y
    CONFIG_RTT_TX_RETRY_CNT=2
    CONFIG_RTT_TX_RETRY_DELAY_MS=2
    # CONFIG_RTT_TX_RETRY_IN_INTERRUPT is not set
    # CONFIG_IPM_CONSOLE_SENDER is not set
    # CONFIG_IPM_CONSOLE_RECEIVER is not set
    # CONFIG_UART_MCUMGR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_CONSOLE_LOG_LEVEL=3
    # CONFIG_EFI_CONSOLE is not set
    # CONFIG_COREDUMP_DEVICE is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DAC is not set
    # CONFIG_DAI is not set
    # CONFIG_DISK_DRIVERS is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_DMA is not set
    # CONFIG_DP_DRIVER is not set
    # CONFIG_EDAC is not set
    # CONFIG_EEPROM is not set
    CONFIG_ENTROPY_GENERATOR=y
    # CONFIG_ENTROPY_LOG_LEVEL_OFF is not set
    # CONFIG_ENTROPY_LOG_LEVEL_ERR is not set
    # CONFIG_ENTROPY_LOG_LEVEL_WRN is not set
    # CONFIG_ENTROPY_LOG_LEVEL_INF is not set
    # CONFIG_ENTROPY_LOG_LEVEL_DBG is not set
    CONFIG_ENTROPY_LOG_LEVEL_DEFAULT=y
    CONFIG_ENTROPY_LOG_LEVEL=3
    CONFIG_ENTROPY_NRF5_RNG=y
    # CONFIG_ENTROPY_NRF5_BIAS_CORRECTION is not set
    CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=8
    CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4
    CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE=16
    CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12
    CONFIG_ENTROPY_BT_HCI=y
    CONFIG_ENTROPY_HAS_DRIVER=y
    # CONFIG_ESPI is not set
    # Firmware drivers
    # CONFIG_ARM_SCMI is not set
    # end of Firmware drivers
    CONFIG_FLASH_HAS_DRIVER_ENABLED=y
    CONFIG_FLASH_HAS_EX_OP=y
    CONFIG_FLASH_HAS_EXPLICIT_ERASE=y
    CONFIG_FLASH_HAS_PAGE_LAYOUT=y
    CONFIG_FLASH_JESD216=y
    # CONFIG_FLASH_JESD216_API is not set
    CONFIG_FLASH_PAGE_LAYOUT=y
    # CONFIG_FLASH_EX_OP_ENABLED is not set
    CONFIG_SOC_FLASH_NRF=y
    # CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE is not set
    # CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
    CONFIG_SOC_FLASH_NRF_TIMEOUT_MULTIPLIER=10
    # CONFIG_SOC_FLASH_NRF_UICR is not set
    # CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
    # MSPI flash device driver
    # end of MSPI flash device driver
    CONFIG_SPI_NOR_SFDP_MINIMAL=y
    # CONFIG_SPI_NOR_SFDP_DEVICETREE is not set
    # CONFIG_SPI_NOR_SFDP_RUNTIME is not set
    CONFIG_SPI_NOR_INIT_PRIORITY=80
    CONFIG_SPI_NOR_CS_WAIT_DELAY=0
    CONFIG_SPI_NOR_SLEEP_WHILE_WAITING_UNTIL_READY=y
    CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=65536
    CONFIG_NORDIC_QSPI_NOR_INIT_PRIORITY=41
    CONFIG_NORDIC_QSPI_NOR_TIMEOUT_MS=500
    # CONFIG_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_FLASH_LOG_LEVEL_WRN is not set
    # CONFIG_FLASH_LOG_LEVEL_INF is not set
    # CONFIG_FLASH_LOG_LEVEL_DBG is not set
    CONFIG_FLASH_LOG_LEVEL_DEFAULT=y
    CONFIG_FLASH_LOG_LEVEL=3
    # CONFIG_FPGA is not set
    # CONFIG_FUEL_GAUGE is not set
    CONFIG_GNSS=y
    CONFIG_GNSS_SATELLITES=y
    # CONFIG_GNSS_DUMP is not set
    # CONFIG_GNSS_DUMP_TO_LOG is not set
    CONFIG_GNSS_PARSE=y
    CONFIG_GNSS_NMEA0183=y
    CONFIG_GNSS_NMEA0183_MATCH=y
    CONFIG_GNSS_INIT_PRIORITY=80
    # CONFIG_GNSS_U_BLOX_PROTOCOL is not set
    CONFIG_GNSS_REFERENCE_FRAME_WGS84=y
    # CONFIG_GNSS_LOG_LEVEL_OFF is not set
    # CONFIG_GNSS_LOG_LEVEL_ERR is not set
    # CONFIG_GNSS_LOG_LEVEL_WRN is not set
    # CONFIG_GNSS_LOG_LEVEL_INF is not set
    # CONFIG_GNSS_LOG_LEVEL_DBG is not set
    CONFIG_GNSS_LOG_LEVEL_DEFAULT=y
    CONFIG_GNSS_LOG_LEVEL=3
    CONFIG_GNSS_NMEA_GENERIC=y
    CONFIG_GNSS_NMEA_GENERIC_SATELLITES_COUNT=24
    CONFIG_GNSS_U_BLOX_M8_SATELLITES_COUNT=24
    CONFIG_GNSS_LUATOS_AIR530Z_SATELLITES_COUNT=24
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    # CONFIG_GPIO_LOG_LEVEL_INF is not set
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
    CONFIG_GPIO_LOG_LEVEL=3
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    # CONFIG_GPIO_HOGS is not set
    # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRFX_INTERRUPT=y
    # CONFIG_HAPTICS is not set
    # CONFIG_HWINFO is not set
    # CONFIG_HWSPINLOCK is not set
    # CONFIG_I2C_CALLBACK is not set
    # CONFIG_I2C_RTIO is not set
    # CONFIG_I2C_TARGET is not set
    CONFIG_I2C_NRFX=y
    CONFIG_I2C_NRFX_TWI=y
    CONFIG_I2C_NRFX_TRANSFER_TIMEOUT=500
    CONFIG_I2C_INIT_PRIORITY=50
    # CONFIG_I2C_LOG_LEVEL_OFF is not set
    # CONFIG_I2C_LOG_LEVEL_ERR is not set
    # CONFIG_I2C_LOG_LEVEL_WRN is not set
    # CONFIG_I2C_LOG_LEVEL_INF is not set
    # CONFIG_I2C_LOG_LEVEL_DBG is not set
    CONFIG_I2C_LOG_LEVEL_DEFAULT=y
    CONFIG_I2C_LOG_LEVEL=3
    # CONFIG_I2S is not set
    # CONFIG_I3C is not set
    # Interrupt controller drivers
    CONFIG_INTC_INIT_PRIORITY=40
    # CONFIG_INTC_LOG_LEVEL_OFF is not set
    # CONFIG_INTC_LOG_LEVEL_ERR is not set
    # CONFIG_INTC_LOG_LEVEL_WRN is not set
    # CONFIG_INTC_LOG_LEVEL_INF is not set
    # CONFIG_INTC_LOG_LEVEL_DBG is not set
    CONFIG_INTC_LOG_LEVEL_DEFAULT=y
    CONFIG_INTC_LOG_LEVEL=3
    # end of Interrupt controller drivers
    # CONFIG_IPM is not set
    # CONFIG_KSCAN is not set
    # CONFIG_LED is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LORA is not set
    # CONFIG_MBOX is not set
    # CONFIG_MDIO is not set
    # CONFIG_MIPI_DBI is not set
    # Miscellaneous Drivers
    # CONFIG_TIMEAWARE_GPIO is not set
    # end of Miscellaneous Drivers
    # CONFIG_MM_DRV is not set
    # CONFIG_MSPI is not set
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_PECI is not set
    # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
    # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
    # CONFIG_PINCTRL_LOG_LEVEL_INF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
    CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
    CONFIG_PINCTRL_LOG_LEVEL=3
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_NRF=y
    # CONFIG_PM_CPU_OPS is not set
    # CONFIG_PS2 is not set
    # CONFIG_PTP_CLOCK is not set
    # CONFIG_PWM is not set
    # CONFIG_RETAINED_MEM is not set
    # CONFIG_RTC is not set
    # CONFIG_SDHC is not set
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    # CONFIG_UART_LOG_LEVEL_OFF is not set
    # CONFIG_UART_LOG_LEVEL_ERR is not set
    # CONFIG_UART_LOG_LEVEL_WRN is not set
    # CONFIG_UART_LOG_LEVEL_INF is not set
    # CONFIG_UART_LOG_LEVEL_DBG is not set
    CONFIG_UART_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_LOG_LEVEL=3
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # CONFIG_UART_PIPE is not set
    # CONFIG_UART_ASYNC_RX_HELPER is not set
    # Serial Drivers
    CONFIG_UART_NRFX=y
    CONFIG_UART_NRFX_UARTE=y
    CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
    CONFIG_UART_0_INTERRUPT_DRIVEN=y
    CONFIG_UART_0_ENHANCED_POLL_OUT=y
    # CONFIG_UART_0_NRF_PARITY_BIT is not set
    CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
    CONFIG_UART_1_INTERRUPT_DRIVEN=y
    CONFIG_UART_1_ENHANCED_POLL_OUT=y
    # CONFIG_UART_1_NRF_PARITY_BIT is not set
    CONFIG_UART_1_NRF_TX_BUFFER_SIZE=32
    # CONFIG_SMBUS is not set
    # CONFIG_SPI_ASYNC is not set
    # CONFIG_SPI_RTIO is not set
    # CONFIG_SPI_SLAVE is not set
    # CONFIG_SPI_EXTENDED_MODES is not set
    CONFIG_SPI_INIT_PRIORITY=50
    CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200
    # CONFIG_SPI_LOG_LEVEL_OFF is not set
    # CONFIG_SPI_LOG_LEVEL_ERR is not set
    # CONFIG_SPI_LOG_LEVEL_WRN is not set
    # CONFIG_SPI_LOG_LEVEL_INF is not set
    # CONFIG_SPI_LOG_LEVEL_DBG is not set
    CONFIG_SPI_LOG_LEVEL_DEFAULT=y
    CONFIG_SPI_LOG_LEVEL=3
    CONFIG_SPI_NRFX=y
    CONFIG_SPI_NRFX_SPIM=y
    CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8
    CONFIG_SPI_NRFX_WAKE_TIMEOUT_US=200
    # CONFIG_STEPPER is not set
    # Timer drivers
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
    CONFIG_NRF_RTC_TIMER_LOCK_ZERO_LATENCY_IRQS=y
    # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # end of Timer drivers
    # CONFIG_USB_BC12 is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_UHC_DRIVER is not set
    # CONFIG_UVB is not set
    # CONFIG_USB_DEVICE_DRIVER is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL=3
    # CONFIG_NRF_USBD_COMMON is not set
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_LOG_LEVEL_OFF is not set
    # CONFIG_USBC_LOG_LEVEL_ERR is not set
    # CONFIG_USBC_LOG_LEVEL_WRN is not set
    # CONFIG_USBC_LOG_LEVEL_INF is not set
    # CONFIG_USBC_LOG_LEVEL_DBG is not set
    CONFIG_USBC_LOG_LEVEL_DEFAULT=y
    CONFIG_USBC_LOG_LEVEL=3
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_USBC_PPC_DRIVER is not set
    # CONFIG_VIDEO is not set
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_W1 is not set
    # CONFIG_TEE is not set
    # CONFIG_REQUIRES_FULL_LIBC is not set
    # CONFIG_REQUIRES_FLOAT_PRINTF is not set
    CONFIG_FULL_LIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC_SUPPORTED=y
    CONFIG_NEWLIB_LIBC_SUPPORTED=y
    CONFIG_PICOLIBC_SUPPORTED=y
    # C Library
    # CONFIG_MINIMAL_LIBC is not set
    # CONFIG_PICOLIBC is not set
    CONFIG_NEWLIB_LIBC=y
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_COMMON_LIBC_ABORT=y
    # CONFIG_COMMON_LIBC_ASCTIME_R is not set
    # CONFIG_COMMON_LIBC_CTIME_R is not set
    # CONFIG_COMMON_LIBC_MALLOC is not set
    CONFIG_COMMON_LIBC_REMOVE=y
    CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=2048
    # CONFIG_NEWLIB_LIBC_FLOAT_SCANF is not set
    # CONFIG_NEWLIB_LIBC_HEAP_LISTENER is not set
    # CONFIG_NEWLIB_LIBC_CUSTOM_SBRK is not set
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_NEED_LIBC_MEM_PARTITION=y
    # end of C Library
    # C++ Language Support
    # CONFIG_CPP is not set
    # end of C++ Language Support
    CONFIG_CRC=y
    # Additional libraries
    # Hash Function Support
    # CONFIG_SYS_HASH_FUNC32 is not set
    # end of Hash Function Support
    # Hashmap (Hash Table) Support
    # CONFIG_SYS_HASH_MAP is not set
    # end of Hashmap (Hash Table) Support
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_STRESS is not set
    # CONFIG_SYS_HEAP_INFO is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    # CONFIG_SYS_HEAP_LISTENER is not set
    # CONFIG_SYS_HEAP_SMALL_ONLY is not set
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    CONFIG_SYS_HEAP_AUTO=y
    # CONFIG_MULTI_HEAP is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # end of Heap and Memory Allocation
    # Memory Blocks
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Memory Blocks
    CONFIG_NET_BUF=y
    # CONFIG_NET_BUF_LOG is not set
    # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
    # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
    # CONFIG_NET_BUF_LOG_LEVEL_INF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
    CONFIG_NET_BUF_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_BUF_LOG_LEVEL=3
    # CONFIG_NET_BUF_POOL_USAGE is not set
    CONFIG_NET_BUF_ALIGNMENT=0
    # OS Support Library
    # CONFIG_FDTABLE is not set
    CONFIG_ZVFS_OPEN_MAX=4
    # CONFIG_PRINTK_SYNC is not set
    CONFIG_MPSC_PBUF=y
    # CONFIG_SPSC_PBUF is not set
    # CONFIG_MPSC_CLEAR_ALLOCATED is not set
    CONFIG_HAS_POWEROFF=y
    # CONFIG_POWEROFF is not set
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    CONFIG_CBPRINTF_FP_SUPPORT=y
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_ALWAYS_A is not set
    CONFIG_CBPRINTF_N_SPECIFIER=y
    # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
    # CONFIG_ZVFS is not set
    # end of OS Support Library
    # POSIX API Support
    # POSIX Options
    # CONFIG_POSIX_API is not set
    CONFIG_POSIX_AEP_CHOICE_NONE=y
    # CONFIG_POSIX_AEP_CHOICE_BASE is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE51 is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE52 is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE53 is not set
    # CONFIG_POSIX_ASYNCHRONOUS_IO is not set
    # CONFIG_POSIX_BARRIERS is not set
    # CONFIG_POSIX_C_LANG_SUPPORT_R is not set
    # CONFIG_POSIX_C_LIB_EXT is not set
    # POSIX device I/O
    # CONFIG_POSIX_DEVICE_IO is not set
    CONFIG_POSIX_OPEN_MAX=4
    # end of POSIX device I/O
    # CONFIG_POSIX_FD_MGMT is not set
    # CONFIG_POSIX_FILE_SYSTEM is not set
    # POSIX memory
    CONFIG_POSIX_PAGE_SIZE=0x40
    # CONFIG_POSIX_SHARED_MEMORY_OBJECTS is not set
    # CONFIG_POSIX_MAPPED_FILES is not set
    # CONFIG_POSIX_MEMORY_PROTECTION is not set
    # end of POSIX memory
    # CONFIG_POSIX_MESSAGE_PASSING is not set
    # CONFIG_POSIX_SINGLE_PROCESS is not set
    # CONFIG_POSIX_MULTI_PROCESS is not set
    # CONFIG_POSIX_THREADS is not set
    # CONFIG_POSIX_READER_WRITER_LOCKS is not set
    # POSIX scheduler options
    # CONFIG_POSIX_PRIORITY_SCHEDULING is not set
    # end of POSIX scheduler options
    # CONFIG_POSIX_SEMAPHORES is not set
    # POSIX signals
    # CONFIG_POSIX_REALTIME_SIGNALS is not set
    # CONFIG_POSIX_SIGNALS is not set
    # end of POSIX signals
    # CONFIG_POSIX_SPIN_LOCKS is not set
    # POSIX synchronized I/O
    # CONFIG_POSIX_FSYNC is not set
    # CONFIG_POSIX_SYNCHRONIZED_IO is not set
    # end of POSIX synchronized I/O
    # CONFIG_POSIX_TIMERS is not set
    # X/Open system interfaces
    # CONFIG_XOPEN_STREAMS is not set
    # CONFIG_XSI_SYSTEM_LOGGING is not set
    # CONFIG_XSI_THREADS_EXT is not set
    # end of X/Open system interfaces
    # Miscellaneous POSIX-related options
    # CONFIG_EVENTFD is not set
    # end of Miscellaneous POSIX-related options
    # Deprecated POSIX options
    CONFIG_EVENTFD_MAX=0
    # CONFIG_FNMATCH is not set
    CONFIG_MAX_PTHREAD_COUNT=0
    CONFIG_MAX_PTHREAD_KEY_COUNT=0
    CONFIG_MAX_TIMER_COUNT=0
    CONFIG_MSG_COUNT_MAX=0
    # CONFIG_POSIX_CLOCK is not set
    # CONFIG_POSIX_FS is not set
    CONFIG_POSIX_LIMITS_RTSIG_MAX=0
    CONFIG_POSIX_MAX_FDS=4
    CONFIG_POSIX_MAX_OPEN_FILES=4
    # CONFIG_POSIX_MQUEUE is not set
    # CONFIG_POSIX_PUTMSG is not set
    # CONFIG_POSIX_SIGNAL is not set
    # CONFIG_POSIX_SYSCONF is not set
    # CONFIG_POSIX_UNAME is not set
    # CONFIG_PTHREAD is not set
    # CONFIG_PTHREAD_BARRIER is not set
    # CONFIG_PTHREAD_COND is not set
    # CONFIG_PTHREAD_IPC is not set
    # CONFIG_PTHREAD_KEY is not set
    # CONFIG_PTHREAD_MUTEX is not set
    # CONFIG_PTHREAD_RWLOCK is not set
    # CONFIG_PTHREAD_SPINLOCK is not set
    # CONFIG_TIMER is not set
    CONFIG_TIMER_DELAYTIMER_MAX=0
    CONFIG_SEM_NAMELEN_MAX=0
    CONFIG_SEM_VALUE_MAX=0
    # end of Deprecated POSIX options
    # end of POSIX Options
    # POSIX Shell Utilities
    # end of POSIX Shell Utilities
    # end of POSIX API Support
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # CONFIG_SMF is not set
    CONFIG_LIBGCC_RTLIB=y
    # Utility Library
    # CONFIG_JSON_LIBRARY is not set
    CONFIG_RING_BUFFER=y
    CONFIG_NOTIFY=y
    CONFIG_BASE64=y
    CONFIG_ONOFF=y
    # CONFIG_WINSTREAM is not set
    # CONFIG_UTF8 is not set
    # end of Utility Library
    # end of Additional libraries
    # Subsystems and OS Services
    # CONFIG_BINDESC is not set
    CONFIG_BT=y
    CONFIG_BT_HCI=y
    # CONFIG_BT_CUSTOM is not set
    # CONFIG_BT_HCI_RAW is not set
    # CONFIG_BT_HCI_RAW_H4 is not set
    # CONFIG_BT_HCI_RAW_CMD_EXT is not set
    CONFIG_BT_CONN_TX=y
    # CONFIG_BT_SCA_UPDATE is not set
    # CONFIG_BT_TRANSMIT_POWER_CONTROL is not set
    # CONFIG_BT_PATH_LOSS_MONITORING is not set
    # CONFIG_BT_SUBRATING is not set
    # CONFIG_BT_ISO_PERIPHERAL is not set
    # CONFIG_BT_ISO_CENTRAL is not set
    # CONFIG_BT_ISO_BROADCASTER is not set
    # CONFIG_BT_ISO_SYNC_RECEIVER is not set
    # Bluetooth buffer configuration
    # end of Bluetooth buffer configuration
    # Bluetooth Host
    # Advertiser
    # end of Advertiser
    # Provisioning
    # end of Provisioning
    # Network layer
    # end of Network layer
    # Transport layer
    # Transport SAR configuration
    # end of Transport SAR configuration
    # Replay Protection List
    # end of Replay Protection List
    # end of Transport layer
    # Access layer
    # end of Access layer
    # Models
    # end of Models
    # Proxy
    # end of Proxy
    # Beacons
    # end of Beacons
    # IV Index & Sequence number
    # end of IV Index & Sequence number
    # Capabilities
    # end of Capabilities
    # Persistent storage
    # end of Persistent storage
    # L2CAP Options
    # end of L2CAP Options
    # ATT and GATT Options
    # end of ATT and GATT Options
    # GATT Services
    # end of GATT Services
    # Bluetooth Classic Options
    # end of Bluetooth Classic Options
    # end of Bluetooth Host
    CONFIG_BT_CTLR_ENTROPY_SUPPORT=y
    CONFIG_BT_CTLR_CRYPTO_SUPPORT=y
    CONFIG_BT_CTLR_LE_ENC_SUPPORT=y
    CONFIG_BT_CTLR_EXT_REJ_IND_SUPPORT=y
    CONFIG_BT_CTLR_DATA_LEN_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_PRIVACY_SUPPORT=y
    CONFIG_BT_CTLR_EXT_SCAN_FP_SUPPORT=y
    CONFIG_BT_CTLR_PHY_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_PHY_2M_SUPPORT=y
    CONFIG_BT_CTLR_PHY_CODED_SUPPORT=y
    CONFIG_BT_CTLR_ADV_EXT_SUPPORT=y
    CONFIG_BT_CTLR_ADV_PERIODIC_SUPPORT=y
    CONFIG_BT_CTLR_ADV_PERIODIC_RSP_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_PERIODIC_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_PERIODIC_RSP_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_TRANSFER_RECEIVER_SUPPORT=y
    CONFIG_BT_CTLR_ADV_ISO_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_ISO_SUPPORT=y
    CONFIG_BT_CTLR_CENTRAL_ISO_SUPPORT=y
    CONFIG_BT_CTLR_PERIPHERAL_ISO_SUPPORT=y
    CONFIG_BT_CTLR_CHAN_SEL_2_SUPPORT=y
    CONFIG_BT_CTLR_SCA_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_CONN_RSSI_SUPPORT=y
    CONFIG_BT_CTLR_ECDH_SUPPORT=y
    CONFIG_BT_CTLR_LE_POWER_CONTROL_SUPPORT=y
    CONFIG_BT_CTLR_LE_PATH_LOSS_MONITORING_SUPPORT=y
    CONFIG_BT_CTLR_SUBRATING_SUPPORT=y
    # CONFIG_BT_LL_SW_SPLIT is not set
    # BLE Controller configuration
    CONFIG_BT_CTLR_ENTROPY=y
    CONFIG_BT_CTLR_CRYPTO=y
    CONFIG_BT_CTLR_TX_PWR_PLUS_8=y
    # CONFIG_BT_CTLR_TX_PWR_PLUS_7 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_6 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_5 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_4 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_3 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_2 is not set
    # CONFIG_BT_CTLR_TX_PWR_0 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_4 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_8 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_12 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_16 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_20 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_40 is not set
    CONFIG_BT_CTLR_TX_PWR_DBM=8
    CONFIG_BT_CTLR_TX_PWR_ANTENNA=0
    # CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL is not set
    # BLE Controller features
    # CONFIG_BT_CTLR_LE_ENC is not set
    CONFIG_BT_CTLR_ECDH=y
    CONFIG_BT_CTLR_EXT_REJ_IND=y
    # CONFIG_BT_CTLR_CONN_RSSI is not set
    # CONFIG_BT_CTLR_LE_POWER_CONTROL is not set
    # CONFIG_BT_CTLR_LE_PATH_LOSS_MONITORING is not set
    # CONFIG_BT_CTLR_FILTER_ACCEPT_LIST is not set
    # CONFIG_BT_CTLR_PRIVACY is not set
    CONFIG_BT_CTLR_EXT_SCAN_FP=y
    CONFIG_BT_CTLR_PHY_2M=y
    # CONFIG_BT_CTLR_PHY_CODED is not set
    # CONFIG_BT_CTLR_CHAN_SEL_2 is not set
    CONFIG_BT_CTLR_ADV_EXT=y
    CONFIG_BT_CTLR_ADV_SET=6
    CONFIG_BT_CTLR_ADV_INTERVAL_MAX=0xFFFFFF
    CONFIG_BT_CTLR_ADV_DATA_LEN_MAX=31
    # CONFIG_BT_CTLR_ADV_PERIODIC is not set
    # CONFIG_BT_CTLR_ADV_PERIODIC_RSP is not set
    # CONFIG_BT_CTLR_SYNC_PERIODIC is not set
    # CONFIG_BT_CTLR_SYNC_PERIODIC_RSP is not set
    # CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER is not set
    # CONFIG_BT_CTLR_ADV_ISO is not set
    # CONFIG_BT_CTLR_SYNC_ISO is not set
    # CONFIG_BT_CTLR_SET_HOST_FEATURE is not set
    # CONFIG_BT_CTLR_PERIPHERAL_ISO is not set
    # CONFIG_BT_CTLR_SUBRATING is not set
    # CONFIG_BT_CTLR_ASSERT_HANDLER is not set
    # CONFIG_BT_EAD is not set
    # Bluetooth logging
    # Common
    # end of Common
    # Libraries
    # end of Libraries
    # Host
    # end of Host
    # Mesh
    # end of Mesh
    # Services
    # end of Services
    # end of Bluetooth logging
    # Controller Area Network (CAN) bus subsystem
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # CONFIG_DAP is not set
    # System Monitoring Options
    # CONFIG_THREAD_ANALYZER is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_STACK_USAGE is not set
    # CONFIG_PRINTK is not set
    # CONFIG_EARLY_CONSOLE is not set
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_NO_COND_INFO is not set
    # CONFIG_ASSERT_NO_MSG_INFO is not set
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_INFO is not set
    # CONFIG_DEBUG_THREAD_INFO is not set
    # CONFIG_DEBUG_COREDUMP is not set
    # CONFIG_SYMTAB is not set
    # end of Debugging Options
    # CONFIG_MIPI_STP_DECODER is not set
    # CONFIG_CS_TRACE_DEFMT is not set
    CONFIG_IMG_MANAGER=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y
    CONFIG_MCUBOOT_UPDATE_FOOTER_SIZE=0x2000
    CONFIG_IMG_BLOCK_BUF_SIZE=512
    # CONFIG_IMG_ENABLE_IMAGE_CHECK is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_OFF is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_ERR is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_WRN is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_INF is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_DBG is not set
    CONFIG_IMG_MANAGER_LOG_LEVEL_DEFAULT=y
    CONFIG_IMG_MANAGER_LOG_LEVEL=3
    # CONFIG_DISK_ACCESS is not set
    # CONFIG_DSP is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    CONFIG_FILE_SYSTEM=y
    # CONFIG_FS_LOG_LEVEL_OFF is not set
    # CONFIG_FS_LOG_LEVEL_ERR is not set
    # CONFIG_FS_LOG_LEVEL_WRN is not set
    # CONFIG_FS_LOG_LEVEL_INF is not set
    # CONFIG_FS_LOG_LEVEL_DBG is not set
    CONFIG_FS_LOG_LEVEL_DEFAULT=y
    CONFIG_FS_LOG_LEVEL=3
    CONFIG_APP_LINK_WITH_FS=y
    CONFIG_FILE_SYSTEM_MAX_TYPES=2
    CONFIG_FILE_SYSTEM_MAX_FILE_NAME=-1
    CONFIG_FILE_SYSTEM_INIT_PRIORITY=99
    # CONFIG_FILE_SYSTEM_MKFS is not set
    # CONFIG_FAT_FILESYSTEM_ELM is not set
    CONFIG_FILE_SYSTEM_LITTLEFS=y
    # LittleFS Settings
    CONFIG_FS_LITTLEFS_NUM_FILES=4
    CONFIG_FS_LITTLEFS_NUM_DIRS=4
    CONFIG_FS_LITTLEFS_READ_SIZE=16
    CONFIG_FS_LITTLEFS_PROG_SIZE=16
    CONFIG_FS_LITTLEFS_CACHE_SIZE=64
    CONFIG_FS_LITTLEFS_LOOKAHEAD_SIZE=32
    CONFIG_FS_LITTLEFS_BLOCK_CYCLES=512
    # end of LittleFS Settings
    CONFIG_FS_LITTLEFS_FC_HEAP_SIZE=0
    CONFIG_FS_LITTLEFS_HEAP_PER_ALLOC_OVERHEAD_SIZE=32
    CONFIG_FS_LITTLEFS_FMP_DEV=y
    # CONFIG_FS_LITTLEFS_BLK_DEV is not set
    # CONFIG_FILE_SYSTEM_EXT2 is not set
    # CONFIG_EXT2_LOG_LEVEL_OFF is not set
    # CONFIG_EXT2_LOG_LEVEL_ERR is not set
    # CONFIG_EXT2_LOG_LEVEL_WRN is not set
    # CONFIG_EXT2_LOG_LEVEL_INF is not set
    # CONFIG_EXT2_LOG_LEVEL_DBG is not set
    CONFIG_EXT2_LOG_LEVEL_DEFAULT=y
    CONFIG_EXT2_LOG_LEVEL=3
    # CONFIG_FCB is not set
    CONFIG_NVS=y
    # CONFIG_NVS_LOOKUP_CACHE is not set
    # CONFIG_NVS_DATA_CRC is not set
    # CONFIG_NVS_LOG_LEVEL_OFF is not set
    # CONFIG_NVS_LOG_LEVEL_ERR is not set
    # CONFIG_NVS_LOG_LEVEL_WRN is not set
    # CONFIG_NVS_LOG_LEVEL_INF is not set
    # CONFIG_NVS_LOG_LEVEL_DBG is not set
    CONFIG_NVS_LOG_LEVEL_DEFAULT=y
    CONFIG_NVS_LOG_LEVEL=3
    # CONFIG_ZMS is not set
    # end of File Systems
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    # CONFIG_IPC_SERVICE is not set
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # CONFIG_LLEXT is not set
    # Linkable loadable Extension Development Kit (EDK)
    CONFIG_LLEXT_EDK_NAME="llext-edk"
    # CONFIG_LLEXT_EDK_USERSPACE_ONLY is not set
    # end of Linkable loadable Extension Development Kit (EDK)
    # Logging
    CONFIG_LOG_CORE_INIT_PRIORITY=0
    CONFIG_LOG_MODE_DEFERRED=y
    # CONFIG_LOG_MODE_IMMEDIATE is not set
    # CONFIG_LOG_MODE_MINIMAL is not set
    # CONFIG_LOG_FRONTEND is not set
    # CONFIG_LOG_FRONTEND_OPT_API is not set
    # CONFIG_LOG_CUSTOM_HEADER is not set
    # CONFIG_LOG_MULTIDOMAIN is not set
    # Logging levels filtering
    # CONFIG_LOG_RUNTIME_FILTERING is not set
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=3
    # end of Logging levels filtering
    # Processing
    CONFIG_LOG_PRINTK=y
    CONFIG_LOG_MODE_OVERFLOW=y
    # CONFIG_LOG_BLOCK_IN_THREAD is not set
    CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
    CONFIG_LOG_PROCESS_THREAD=y
    CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0
    CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
    CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=768
    # CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set
    CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
    # CONFIG_LOG_TIMESTAMP_64BIT is not set
    # CONFIG_LOG_SPEED is not set
    # end of Processing
    # Output Formatting
    # Prepend non-hexdump log message with function name
    # CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
    CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
    # end of Prepend non-hexdump log message with function name
    # CONFIG_LOG_MIPI_SYST_ENABLE is not set
    # CONFIG_LOG_THREAD_ID_PREFIX is not set
    # CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
    CONFIG_LOG_BACKEND_SHOW_COLOR=y
    # CONFIG_LOG_INFO_COLOR_GREEN is not set
    # CONFIG_LOG_DBG_COLOR_BLUE is not set
    CONFIG_LOG_TAG_MAX_LEN=0
    CONFIG_LOG_BACKEND_SUPPORTS_FORMAT_TIMESTAMP=y
    CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
    # CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
    # CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set
    # end of Output Formatting
    # Backends
    # CONFIG_LOG_BACKEND_FS is not set
    CONFIG_LOG_BACKEND_RTT=y
    # CONFIG_LOG_BACKEND_RTT_MODE_DROP is not set
    CONFIG_LOG_BACKEND_RTT_MODE_BLOCK=y
    # CONFIG_LOG_BACKEND_RTT_MODE_OVERWRITE is not set
    CONFIG_LOG_BACKEND_RTT_OUTPUT_TEXT=y
    # CONFIG_LOG_BACKEND_RTT_OUTPUT_DICTIONARY is not set
    # CONFIG_LOG_BACKEND_RTT_OUTPUT_CUSTOM is not set
    CONFIG_LOG_BACKEND_RTT_OUTPUT_DEFAULT=0
    CONFIG_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE=16
    CONFIG_LOG_BACKEND_RTT_RETRY_CNT=4
    CONFIG_LOG_BACKEND_RTT_RETRY_DELAY_MS=5
    CONFIG_LOG_BACKEND_RTT_BUFFER=0
    CONFIG_LOG_BACKEND_RTT_FORCE_PRINTK=y
    # CONFIG_LOG_BACKEND_SWO is not set
    # CONFIG_LOG_BACKEND_UART is not set
    # CONFIG_LOG_BACKEND_IPC_SERVICE is not set
    # end of Backends
    # Misc
    CONFIG_LOG_USE_VLA=y
    CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
    # CONFIG_LOG_ALWAYS_RUNTIME is not set
    # CONFIG_LOG_FMT_SECTION is not set
    # CONFIG_LOG_FMT_STRING_VALIDATE is not set
    # CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set
    # CONFIG_LOG_MEM_UTILIZATION is not set
    CONFIG_LOG_FAILURE_REPORT_PERIOD=1000
    # end of Misc
    CONFIG_LOG_OUTPUT=y
    # end of Logging
    CONFIG_MEM_ATTR=y
    # CONFIG_MEM_ATTR_HEAP is not set
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    CONFIG_MCUMGR=y
    # CONFIG_MCUMGR_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_LOG_LEVEL=3
    CONFIG_MCUMGR_MGMT_NOTIFICATION_HOOKS=y
    # CONFIG_MCUMGR_MGMT_HANDLER_USER_DATA is not set
    # CONFIG_MCUMGR_MGMT_CUSTOM_PAYLOAD is not set
    CONFIG_MCUMGR_SMP_CBOR_MAX_MAIN_MAP_ENTRIES=15
    CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVELS=2
    CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVEL_2=y
    CONFIG_MCUMGR_SMP_CBOR_MAX_DECODING_LEVELS=2
    CONFIG_MCUMGR_SMP_CBOR_MIN_ENCODING_LEVELS=0
    CONFIG_MCUMGR_SMP_CBOR_MAX_ENCODING_LEVELS=0
    CONFIG_MCUMGR_SMP_COMMAND_STATUS_HOOKS=y
    CONFIG_MCUMGR_SMP_SUPPORT_ORIGINAL_PROTOCOL=y
    # CONFIG_MCUMGR_SMP_VERBOSE_ERR_RESPONSE is not set
    # CONFIG_MCUMGR_SMP_LEGACY_RC_BEHAVIOUR is not set
    # SMP Client
    # CONFIG_SMP_CLIENT is not set
    # end of SMP Client
    # Command Handlers
    CONFIG_MCUMGR_GRP_FS=y
    CONFIG_MCUMGR_GRP_FS_MAX_FILE_SIZE_64KB=y
    # CONFIG_MCUMGR_GRP_FS_MAX_FILE_SIZE_4GB is not set
    CONFIG_MCUMGR_GRP_FS_MAX_OFFSET_LEN=3
    # CONFIG_MCUMGR_GRP_FS_DL_CHUNK_SIZE_LIMIT is not set
    CONFIG_MCUMGR_GRP_FS_FILE_STATUS=y
    # CONFIG_MCUMGR_GRP_FS_CHECKSUM_HASH is not set
    CONFIG_MCUMGR_GRP_FS_PATH_LEN=64
    CONFIG_MCUMGR_GRP_FS_FILE_ACCESS_HOOK=y
    CONFIG_MCUMGR_GRP_FS_FILE_SEMAPHORE_TAKE_TIME=100
    CONFIG_MCUMGR_GRP_FS_FILE_AUTOMATIC_IDLE_CLOSE_TIME=4000
    # CONFIG_MCUMGR_GRP_FS_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_GRP_FS_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_GRP_FS_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_GRP_FS_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_GRP_FS_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_GRP_FS_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_GRP_FS_LOG_LEVEL=3
    CONFIG_MCUMGR_GRP_IMG=y
    CONFIG_MCUMGR_GRP_IMG_UPDATABLE_IMAGE_NUMBER=1
    # CONFIG_MCUMGR_GRP_IMG_VERBOSE_ERR is not set
    CONFIG_MCUMGR_GRP_IMG_ALLOW_CONFIRM_NON_ACTIVE_IMAGE_SECONDARY=y
    # CONFIG_MCUMGR_GRP_IMG_ALLOW_CONFIRM_NON_ACTIVE_IMAGE_ANY is not set
    # CONFIG_MCUMGR_GRP_IMG_ALLOW_ERASE_PENDING is not set
    # CONFIG_MCUMGR_GRP_IMG_DIRECT_UPLOAD is not set
    # CONFIG_MCUMGR_GRP_IMG_REJECT_DIRECT_XIP_MISMATCHED_SLOT is not set
    # CONFIG_MCUMGR_GRP_IMG_FRUGAL_LIST is not set
    # CONFIG_MCUMGR_GRP_IMG_VERSION_CMP_USE_BUILD_NUMBER is not set
    # CONFIG_MCUMGR_GRP_IMG_UPLOAD_CHECK_HOOK is not set
    CONFIG_MCUMGR_GRP_IMG_STATUS_HOOKS=y
    # CONFIG_MCUMGR_GRP_IMG_MUTEX is not set
    CONFIG_MCUMGR_GRP_IMG_TOO_LARGE_DISABLED=y
    # CONFIG_MCUMGR_GRP_IMG_TOO_LARGE_SYSBUILD is not set
    # CONFIG_MCUMGR_GRP_IMG_IMAGE_SLOT_STATE_HOOK is not set
    CONFIG_MCUMGR_GRP_IMG_IMAGE_SLOT_STATE_STATES=15
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL=3
    CONFIG_MCUMGR_GRP_OS=y
    CONFIG_MCUMGR_GRP_OS_RESET_MS=250
    # CONFIG_MCUMGR_GRP_OS_RESET_HOOK is not set
    # CONFIG_MCUMGR_GRP_OS_TASKSTAT is not set
    CONFIG_MCUMGR_GRP_OS_ECHO=y
    # CONFIG_MCUMGR_GRP_OS_INFO is not set
    # CONFIG_MCUMGR_GRP_OS_BOOTLOADER_INFO is not set
    # CONFIG_MCUMGR_GRP_OS_BOOTLOADER_INFO_HOOK is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_GRP_OS_LOG_LEVEL=3
    # CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_GRP_ZBASIC_LOG_LEVEL=3
    # CONFIG_MCUMGR_GRP_ENUM is not set
    # end of Command Handlers
    # Transports and Transport Related Configuration Options
    CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_STACK_SIZE=4608
    CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_THREAD_PRIO=3
    CONFIG_MCUMGR_TRANSPORT_REASSEMBLY=y
    CONFIG_MCUMGR_TRANSPORT_NETBUF_COUNT=4
    CONFIG_MCUMGR_TRANSPORT_NETBUF_MIN_USER_DATA_SIZE=8
    CONFIG_MCUMGR_TRANSPORT_NETBUF_USER_DATA_SIZE=8
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL=3
    # CONFIG_MCUMGR_TRANSPORT_DUMMY is not set
    CONFIG_MCUMGR_TRANSPORT_BT=y
    CONFIG_MCUMGR_TRANSPORT_BT_REASSEMBLY=y
    CONFIG_MCUMGR_TRANSPORT_BT_PERM_RW=y
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL=y
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_MIN_INT=6
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_MAX_INT=9
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_LATENCY=0
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_TIMEOUT=42
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_RESTORE_TIME=5000
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_RETRY_TIME=1000
    # CONFIG_MCUMGR_TRANSPORT_UART is not set
    # end of Transports and Transport Related Configuration Options
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    CONFIG_MODEM_MODULES=y
    CONFIG_MODEM_CHAT=y
    CONFIG_MODEM_CHAT_LOG_BUFFER_SIZE=128
    # CONFIG_MODEM_CMUX is not set
    CONFIG_MODEM_PIPE=y
    # CONFIG_MODEM_PIPELINK is not set
    CONFIG_MODEM_STATS_BUFFER_NAME_SIZE=32
    # CONFIG_MODEM_UBX is not set
    # CONFIG_MODEM_MODULES_LOG_LEVEL_OFF is not set
    # CONFIG_MODEM_MODULES_LOG_LEVEL_ERR is not set
    # CONFIG_MODEM_MODULES_LOG_LEVEL_WRN is not set
    # CONFIG_MODEM_MODULES_LOG_LEVEL_INF is not set
    # CONFIG_MODEM_MODULES_LOG_LEVEL_DBG is not set
    CONFIG_MODEM_MODULES_LOG_LEVEL_DEFAULT=y
    CONFIG_MODEM_MODULES_LOG_LEVEL=3
    CONFIG_MODEM_BACKEND_UART=y
    CONFIG_MODEM_BACKEND_UART_ISR=y
    # CONFIG_MODEM_BACKEND_UART_ASYNC is not set
    CONFIG_MODEM_BACKEND_UART_ISR_RECEIVE_IDLE_TIMEOUT_MS=20
    # Networking
    # CONFIG_NETWORKING is not set
    # end of Networking
    # Power Management
    # CONFIG_PM_POLICY_LATENCY_STANDALONE is not set
    # end of Power Management
    # Portability
    # end of Portability
    # CONFIG_PROFILING is not set
    # Random Number Generators
    # CONFIG_TEST_RANDOM_GENERATOR is not set
    CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
    # CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR is not set
    CONFIG_XOSHIRO_RANDOM_GENERATOR=y
    CONFIG_CSPRNG_ENABLED=y
    CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
    # CONFIG_CTR_DRBG_CSPRNG_GENERATOR is not set
    # end of Random Number Generators
    # CONFIG_RTIO is not set
    # SD
    # CONFIG_MMC_STACK is not set
    # CONFIG_SDMMC_STACK is not set
    # CONFIG_SDIO_STACK is not set
    # end of SD
    CONFIG_SETTINGS=y
    # CONFIG_SETTINGS_LOG_LEVEL_OFF is not set
    # CONFIG_SETTINGS_LOG_LEVEL_ERR is not set
    # CONFIG_SETTINGS_LOG_LEVEL_WRN is not set
    # CONFIG_SETTINGS_LOG_LEVEL_INF is not set
    # CONFIG_SETTINGS_LOG_LEVEL_DBG is not set
    CONFIG_SETTINGS_LOG_LEVEL_DEFAULT=y
    CONFIG_SETTINGS_LOG_LEVEL=3
    # CONFIG_SETTINGS_RUNTIME is not set
    CONFIG_SETTINGS_DYNAMIC_HANDLERS=y
    # CONFIG_SETTINGS_FILE is not set
    CONFIG_SETTINGS_NVS=y
    # CONFIG_SETTINGS_NVS_NAME_CACHE is not set
    # CONFIG_SETTINGS_CUSTOM is not set
    # CONFIG_SETTINGS_NONE is not set
    CONFIG_SETTINGS_NVS_SECTOR_SIZE_MULT=1
    CONFIG_SETTINGS_NVS_SECTOR_COUNT=8
    # CONFIG_SHELL is not set
    # CONFIG_STATS is not set
    # Storage
    CONFIG_FLASH_MAP=y
    # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
    # CONFIG_FLASH_MAP_LABELS is not set
    CONFIG_STREAM_FLASH=y
    # CONFIG_STREAM_FLASH_ERASE is not set
    # CONFIG_STREAM_FLASH_PROGRESS is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_WRN is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_INF is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_DBG is not set
    CONFIG_STREAM_FLASH_LOG_LEVEL_DEFAULT=y
    CONFIG_STREAM_FLASH_LOG_LEVEL=3
    # end of Storage
    # CONFIG_TASK_WDT is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    # CONFIG_FORCE_COVERAGE is not set
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # CONFIG_USB_DEVICE_STACK is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    # CONFIG_USB_HOST_STACK is not set
    # CONFIG_USBC_STACK is not set
    # CONFIG_ZBUS is not set
    # CONFIG_MODULES is not set
    # end of Subsystems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_16=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_GNU_EXTENSIONS=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_FLASH_LOAD_SIZE=0x77000
    CONFIG_ROM_END_OFFSET=0x2000
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    CONFIG_LINKER_USE_RELAX=y
    # end of Linker Sections
    CONFIG_LINKER_ITERABLE_SUBALIGN=4
    CONFIG_LINKER_DEVNULL_SUPPORT=y
    # CONFIG_LINKER_DEVNULL_MEMORY is not set
    # end of Linker Options
    # Compiler Options
    # CONFIG_STD_C90 is not set
    CONFIG_STD_C99=y
    # CONFIG_STD_C11 is not set
    # CONFIG_STD_C17 is not set
    # CONFIG_STD_C23 is not set
    CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
    # CONFIG_GNU_C_EXTENSIONS is not set
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_COMPILER_FREESTANDING is not set
    CONFIG_SIZE_OPTIMIZATIONS=y
    # CONFIG_SIZE_OPTIMIZATIONS_AGGRESSIVE is not set
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    # CONFIG_DEBUG_OPTIMIZATIONS is not set
    # CONFIG_NO_OPTIMIZATIONS is not set
    # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # CONFIG_COMPILER_SAVE_TEMPS is not set
    CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    # CONFIG_FORTIFY_SOURCE_NONE is not set
    CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    # CONFIG_OUTPUT_DISASSEMBLY is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19 is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
    # CONFIG_BUILD_ALIGN_LMA is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    # CONFIG_BUILD_OUTPUT_META is not set
    CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
    CONFIG_CHECK_INIT_PRIORITIES=y
    # CONFIG_EMIT_ALL_SYSCALLS is not set
    # end of Build Options
    CONFIG_WARN_DEPRECATED=y
    CONFIG_EXPERIMENTAL=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    # Compatibility
    CONFIG_LEGACY_GENERATED_INCLUDE_PATH=y
    # end of Compatibility
    # Mesh Light Group Control
    CONFIG_BT_MESH_LIGHT_GROUP_CTRL_MESSAGE_LENGTH=90
    # end of Mesh Light Group Control
    # Custom options
    CONFIG_CUSTOM_VERSION=0
    # end of Custom options
    I updated the corrected answer here.
    Santiago Castellano said:
    In my current implementation, after calling bt_mesh_provision_remote, I wait LINK_ESTABLISHMENT_TIMEOUT (60) seconds for the node_added callback.
    No, this is not correct. It is not the timeout for the entire procedure, but the timeout between each request -> response sequence. Every received message resets the timer. You need to wait for link_close callback before starting a new procedure.
    Regarding remote provisioning robustness. Yes, the procedure is complex and is able to fail in many places. I can recommend only common things: add more buffers and segmented message contexts (see my recommendations regarding warnings from my first reply), and configure network transmit parameters with more repeats: https://github.com/nrfconnect/sdk-zephyr/blob/main/include/zephyr/bluetooth/mesh/cfg_cli.h#L713-L729 (note that it might improve, but might make it worse since it creates extra traffic and, as a consequence, more collisions).
    Also, you can add SAR models and tune SAR parameters to make communication more robust in their environment (I guess this is the more correct approach) since the remote provisioning procedure operates many SAR messages.
    SAR documentation:
    https://docs.nordicsemi.com/bundle/ncs-3.1.0/page/zephyr/connectivity/bluetooth/api/mesh/sar_cfg_cl…
    https://docs.nordicsemi.com/bundle/ncs-3.1.0/page/zephyr/connectivity/bluetooth/api/mesh/sar_cfg_sr…
    I will be out of the office for the next two weeks and will not be able to answer the case. If you need urgent support, please create a new support case.
    Merry Christmas & Happy New Year!
    Amanda H.
