Multiple SPIM sections using EasyDMA
My design is in alpha test and we just discovered that apparently SPIM allows only one module to be enabled at a time. When a second module (SPIM3, SPIM2) is enabled, the first turns off or the 2nd never turns on, depending on the relative priority of the two. Surely this can't be a restriction of the part, or there would be no reason to have multiple modules. Reducing the clock rates does not help. How can I run two (or more) SPIM modules simultaneously?
  • Post your dts overlay with the peripherial and pin configs. I can run multiple SPIM peripherials here - but its easy to make a mistake with the shared peripherials and the DTS checker won't catch all of them AFAIK.
  • I can't find any reference to "DTS checker" etc., so I must presume that's something in whatever IDE you're using. I'm using Segger. Below are snippets of my code that show what I'm doing with the SPIM. I have tried using different combinations of SPIM0 thru 3, and various clock frequencies. SPIM3, being highest priority, works best, but enabling any other SPIMx channel kills SPIM3.My code does not use any of the TWI, SPI, or SPIS channels that conflict with the SPIM channels.
    NRF_SPIM_Type *SPITable [Channels] = {NRF_SPIM3, NRF_SPIM2};
    NRF_SPIM_Type *SPI;
    SetPinCfg (PinNum [Ch], 0x00000303);
    SPI = SPITable [Ch];
       SPI -> TASKS_STOP = 1;
       SPI -> ENABLE = 0;
       SPI -> SHORTS = 1 << 17;
       SPI -> PSEL.SCK = (uint32_t) 0xFFFFFFFF; // disconnect Clk
       SPI -> PSEL.MOSI = PinNum [Ch];
       SPI -> PSEL.MISO = 0xFFFFFFFF; // Disconnect MISO
       SPI -> PSEL.CSN   = 0xFFFFFFFF;
       SPI -> FREQUENCY = SpiClkFreq [SpiClk [Ch]].Reg;
       SPI -> RXD.PTR = (uint32_t) &Dummy;
       SPI -> RXD.MAXCNT = sizeof Dummy;
       SPI -> RXD.LIST = 0;
       SPI -> TXD.PTR = (uint32_t) Buffer [Ch];
       SPI -> TXD.MAXCNT = NumBytes [Ch];
       SPI -> TXD.LIST = 0;
       SPI -> CONFIG = 0;
       SPI -> ENABLE = 7;
       SPI -> TASKS_START = 1;
  • I recommend migrating to VS code and the NCS SDK, which has support for Threads.
    BTW: I strongly suspect the problem in the very next line(s) to occur.
  • I tired of hearing about moving to the next "latest and greatest" development tools, with yet another steep learning curve, and its own set of bugs and quirks. I just want the hardware to do what the manufacturer advertises, without having to wade thru yet another layer of bloat. I don't need Threads, I just need the SPIM modules to do their own thing under EasyDMA (a great feature of this processor line).
    What are you anticipating in "the very next line(s)"? Once the SPIM is set up, it should run independently of my code, with due regard for bus contention by EasyDMA.
  • SCK is a required hardware pin and although it can be set to disconnected the SPIM then does not work correctly, particularly with multiple SPIMs. The reason is likely to be the hardware clock path to the internal SPI peripheral as the SPI peripheral must cope with both internal (Master) and external (Slave) clock routes. I suspect the physical path was simply designed to be identical and therefore requires the SCK to be an output pin driving the internal clock line. Even if you got a single SPIM to work multiple SPIMs would share the same clock line and therefore misbehave.
    In case I am correct regarding your issue, simply set SCK to any spare or unused pin for each SPIM and test again.
    Edit: Tidied up and found an old link: spi-not-transferring-when-sck-pin-not-used
    "It's not  bug, it's a feature .."
