PCB Review
I am attempting to develop an open source nRF52832 PCB design, aiming to minimize the footprint as much as possible.
Thus, I attempted to cramp as many components in a tight space as possible.
I know that my design, deviating from the reference PCB, probably sacrifices quite a bit of RF quality and signal strength.
Yet, I wanted to ask Nordics opinion on this design, and what I could improve.
Thanks a lot!nrf52_micro.zip
  • Hi an happy new year!
    Ticket has been passed around as there has been few people working during this holiday, so things move a round a bit while the ones left working are keeping track of everything.
    Daniel Dakhno said:
    As far as I can see, they are also not using more components than I do, yet I had amazing performance (10+ meters) with those modules.
    That is impressive. I have not looked at the HolyIOT module so not sure how well it performs, could be that the device has decent performance, but it is difficult for us to know and also difficult to give the "Ok this is fine" as we have seen many designs similar that preform relay bad.  Also some antennas are more forgiving then others.
    Daniel Dakhno said:
    2. You mentioned that I have not connected the debug pins. While that is true from the schematic, could you please also confirm that from the PCB design?
    G1 and F1 is not connected so no SWD pins, this will make it difficult to program. At least I don't see the pins connected to anything external. But I did not download the files again, only checked the one I already had.
    Daniel Dakhno said:
    I have connected most gpios only in the PCB. Is there a better way to do this?
    On such tiny designed you just have to find a place to route them, there is always a compromise, and keeping the layer count low does not make it easier.  The proper way to do it would be to use some in pad vias that can route out the pins on the bottom layer.
    Jonathan
  • Hey,
    thanks for such a comprehensive answer!
    The HolyIOT 17095 looks like this:
    Do you happen to notice any trickery there?
    Thanks again,
    Daniel
  • I don't see anything unique here, seems like the goal was to get it as square and compact as possible.
    But 10 + meters is not exactly great when it comes to range, its possible to achieve far more with so the performance does reflect the design here.
    I went looking and I do see we have a few tickets here on Devzone with the HolyIoT module, and this one comments on the range https://devzone.nordicsemi.com/f/nordic-q-a/64465/nrf52832-outdoor-range. I would suspect that a similarly sized design would perform the same with a similar antenna.
    If you want we do help with tuning, so you can send a unit or two to us and we can try and optimize the matching components for the radio here, might be able to squeeze out some extra power so that you get the best range. This is best done by just adjusting the radio matching components.
    Also operating at a higher voltage does yield some more power.
    Jonathan
    sorry, this took a while to get back to.
    I would love to take you up on the offer of optimization.
    What would be the next steps here?
    Could I order straight from JLCPCB to you?
    Thanks!
    This can be done, you can decide what you think is the best option for you here.
    We usually need a 2 devices, but since this is so small it is good to have a backup or two, so 3-4 devices just to make sure that we dont have to ask for extra devices.
    What we can do is have a look at the performance and provide a report, we do conducted testing for the radio and antenna and we will provide recommendations to components as to what would be a improvement if there is any significant performance boost to get.
    Jonathan
