Hi Team,
1. Radio Firmware upgrade supports only HTTP server?
2. Application can be transferred as a complete file instead of chunks of packets?
Sravan Rikka
Hi Team,
Sravan Rikka
No, using Serial LTE Modem you should also be able to upgrade using HTTPS as well.
Could you please elaborate?
Øyvind
Hi Øyvind,
2. Assume application firmware size is 100KB, is it possible to send 100KB binary file in single instance? or we have to send in chunks like 1KB, 1KB,,,,,,,,,,,1KB(100 times)?
Sravan Rikka
sravan.rikka said:2. Assume application firmware size is 100KB, is it possible to send 100KB binary file in single instance? or we have to send in chunks like 1KB, 1KB,,,,,,,,,,,1KB(100 times)?
This would depend on the average transfer speed, i.e. if you look at the LTE technology i.e. LTE-M or NB-IoT
| Features | LTE-M | NB-IoT | |
| Also known as | LTE CAT-M1, Enhanced Machine Type Communication (eMTC) | LTE Cat-NB1 (3GPP rel 13) | LTE Cat-NB2 (3GPP rel 14) |
| Bandwidth | 1.4 MHz | 200 kHz | 200 kHz |
| Max throughput (DL/UL) | 300/375 kbps | 30/60 kbps | 127/169 kbps |
These numbers depend on the coverage, network, etc. Have a look at our Download client. Note that there is a limitation TLS limitation in the modem itself as well, please see modem FW release notes
Øyvind
