Hi Team,
We are working on a commercial pre-production project using nRF5340 and are currently migrating from nRF Connect SDK 2.6.1 to NCS 3.1.1.
We followed the official Sysbuild migration guide:
Migration guide: Migration to sysbuild (https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/releases_and_maturity/migration/migration_sysbuild.html)
During migration we observed two issues regarding Sysbuild and dynamic partition management.
Environment
| Item | Version / Details |
| Hardware | nRF5340 (custom board or DK — specify) |
| SDK | nRF Connect SDK v3.1.1 (previously 2.6.1) |
| Toolchain | (ex: v2.5.0) |
| Build system | VSCode + West |
| Application type | Dual-core (App core + Net core), IPC/HCI based |
Issue Details
Issue 1 — Network core image not building
Following the migration guide, we initially created:
sysbuild.confwith:
SB_CONFIG_NETCORE_HCI_IPC=y
SB_CONFIG_PARTITION_MANAGER=y
sysbuild.cmakefile
However, the network core image was not getting built, and build failed with errors.
Issue 2 — Dynamic partition is not working
To resolve the first issue, we removed sysbuild.conf and instead added kconfig.sysbuild.
After this change:
Network core image is now building correctly
Dynamic partition still fails, showing the same partition-manager related build error.
787:45: error: 'user_storage' undeclared (first use in this function)
787 | err = flash_area_open(FLASH_AREA_ID(user_storage), &fa);
815:45: error: 'bad_block_table' undeclared (first use in this function); did you mean 'bad_blk_table'?
815 | err = flash_area_open(FLASH_AREA_ID(bad_block_table), &fa);
| bad_blk_table
841:45: error: 'settings_storage' undeclared (first use in this function)
841 | err = flash_area_open(FLASH_AREA_ID(settings_storage), &fa);
We expect partitions to be dynamically generated when using sysbuild, but it appears partition manager is not active or parameters are not being picked up.
What we need help with
Correct configuration for enabling dynamic partitioning under Sysbuild in NCS 3.1.1
Recommended usage of:
sysbuild.confvskconfig.sysbuild -
sysbuild.cmakeplacement & syntax
Any example reference for nRF5340 dual-core + IPC + Sysbuild + Partition Manager
Clarification if
SB_CONFIG_PARTITION_MANAGERis sufficient or additional settings are required
Additional Notes
This migration is time-critical since we are in the final pre-production stage and planning to freeze FW for manufacturing.
Any support or guidance would be very helpful.
pm.yml is bellow
app:
address: 0x00000000
size: 0xE8000 # 928 KB
memfault_storage:
address: 0x000E8000
size: 0x10000 # 64 KB
placement:
region: flash_primary
after: [app]
bad_block_table:
address: 0x00F8000
size: 0x2000 # 8 KB
placement:
after: [memfault_storage]
settings_storage:
address: 0x000FA000
size: 0x2000 # 8 KB
placement:
after: [bad_block_table]
user_storage:
address: 0x000FC000
size: 0x4000 # 16 KB
placement:
before: [end]
