nRF7002 DK Wifi
I've succesfully setup multiple nRF7002DK boards with an example app to connect to WiFi.
One out of the five boards the Wifi does not work. The interface stays down in Zephyr.
I've compared the switches on the boards and I did not identify differences. Identical binary file is used for all the boards.
What could be the reason of this?
    Do you try another USB cable or port on PC? Please ensure provide the correct voltage for the DK?
    Could you provide the log?
    What NCS version are you using?
    What is the DK version on the white sticker?
    Could you take a snapshot on DK?
    Amanda H.
  • Thank you for the questions, see below the requested information.
    I hope this helps to clarify the situation.
    Same cable works with other boards. Different USB cable gives the same result.
    It's powered via USB. Which voltage rail should I check?
    *** Booting My Application v2.1.0-dev-daf2946a0f07 ***
    *** Using nRF Connect SDK v2.7.0-5cb85570ca43 ***
    *** Using Zephyr OS v3.6.99-100befc70c74 ***
    *** Booting nRF Connect SDK v2.7.0-5cb85570ca43 ***
    uart:~$ net iface
    Interface wlan0 (0x20009230) (WiFi) [1]
    Interface is down.
    uart:~$ net ping 8.8.8.8
    PING 8.8.8.8
    [00:05:13.821,624] <err> net_arp: Gateway not set for iface 0x20009230
    [00:05:14.821,685] <err> net_arp: Gateway not set for iface 0x20009230
    [00:05:15.821,746] <err> net_arp: Gateway not set for iface 0x20009230
    Above is understandable as the interface is not up/not working.
    uart:~$ net conn
    Context Iface Flags Local Remote
    [ 1] 0x2000bfb0 1 4DU 0.0.0.0:47439 0.0.0.0:0
    [ 2] 0x2000c050 1 D AF_PACKET
    PCA10143
    1.0.3
    2024.4
    What do you exactly mean with taking a snapshot? A flash memory dump? A log trace?
    Seems you are using NCS v2.7.0. If so, please try the latest version, v3.1.1.
    Are you using Wi-Fi: Shell sample? Could you try to connect to WIFI (wifi connect -s <SSID> -k <key_management> -p <passphrase>) before executing "net iface"? You can check the WiFi connection status by "wifi status" command. See the Testing STA mode flow.
  • please help me im using nRF5340dk board and Ev-wt02c402(nRF5340 + nRF7002) external module for wifi
    i want to know h/w configuration so that i can use  nRF5340dk board as debugger and nRF5340 as host mcu and nRF7002 wifi
    overlay file configuration
    actually i tried with many sample + github code but i'm not getting output on wifi_scan cmd
  • Please create a new support ticket for your own issue.
