aws_iot_mqtt on nRF9160DK
Following the ongoing many issues to make Ethernet work alongside the modem on nRF9160 ((Missing Forum Thread) ,  aws_iot example without network offloadingdevzone.nordicsemi.com/.../ (clicking “Convert to public” on this one shows a blank page, Nordic devzone bug)) we are trying to build the aws_iot_mqtt sample (not Nordic’s custom one aws_iot) on the nrf9160dk/nrf9160/ns target.
Here’s the build log:
 *  Executing task: nRF Connect: Build [pristine]: aws_iot_mqtt/build_devkit (active)
Building aws_iot_mqtt
west build --build-dir /Users/gildev/Downloads/aws_iot_mqtt/build_devkit /Users/gildev/Downloads/aws_iot_mqtt --pristine --board [email protected]/nrf9160/ns --no-sysbuild --
-- Application: /Users/gildev/Downloads/aws_iot_mqtt
-- CMake version: 3.21.0
-- Found Python3: /opt/nordic/ncs/toolchains/561dce9adf/opt/[email protected]/bin/python3.12 (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
-- Cache files will be written to: /Users/gildev/Library/Caches/zephyr
-- Zephyr version: 4.1.99 (/opt/nordic/ncs/v3.1.1/zephyr)
-- Found west (found suitable version "1.4.0", minimum required is "0.14.0")
-- Board: nrf9160dk, Revision: 0.14.0, qualifiers: nrf9160/ns
-- Found host-tools: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/561dce9adf/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/561dce9adf/opt/zephyr-sdk)
-- Found Dtc: /opt/nordic/ncs/toolchains/561dce9adf/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
-- Found BOARD.dts: /opt/nordic/ncs/v3.1.1/zephyr/boards/nordic/nrf9160dk/nrf9160dk_nrf9160_ns.dts
-- Found devicetree overlay: /opt/nordic/ncs/v3.1.1/zephyr/boards/nordic/nrf9160dk/nrf9160dk_nrf9160_ns_0_14_0.overlay
-- Generated zephyr.dts: /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/zephyr/zephyr.dts
-- Generated pickled edt: /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/zephyr/edt.pickle
-- Generated devicetree_generated.h: /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/zephyr/include/generated/zephyr/devicetree_generated.h
warning: MBEDTLS_MEMORY_DEBUG (defined at
/opt/nordic/ncs/v3.1.1/nrf/subsys/nrf_security/Kconfig.tls:178, modules/mbedtls/Kconfig:166,
modules/mbedtls/Kconfig:166) was assigned the value 'y' but got the value 'n'. Check these
unsatisfied dependencies: ((MBEDTLS_TLS_LIBRARY && NRF_SECURITY) || (MBEDTLS_BUILTIN && MBEDTLS) ||
(MBEDTLS_BUILTIN && MBEDTLS && 0)) (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_MEMORY_DEBUG and/or look up
MBEDTLS_MEMORY_DEBUG in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
warning: MBEDTLS_AES_ROM_TABLES (defined at
/opt/nordic/ncs/v3.1.1/nrf/subsys/nrf_security/Kconfig.legacy:454,
modules/mbedtls/Kconfig.mbedtls:289, modules/mbedtls/Kconfig.mbedtls:289) was assigned the value 'y'
but got the value 'n'. Check these unsatisfied dependencies: ((!(OBERON_BACKEND || CC3XX_BACKEND) &&
MBEDTLS_CIPHER_MODE_CBC && MBEDTLS_AES_C && MBEDTLS_LEGACY_CRYPTO_C && NRF_SECURITY) ||
(MBEDTLS_CIPHER_AES_ENABLED && !(NRF_SECURITY || NORDIC_SECURITY_BACKEND) && MBEDTLS_BUILTIN &&
MBEDTLS_CFG_FILE = "config-mbedtls.h" && MBEDTLS) || (MBEDTLS_CIPHER_AES_ENABLED && !(NRF_SECURITY
|| NORDIC_SECURITY_BACKEND) && MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-mbedtls.h" && MBEDTLS
&& 0)) (=n). See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_AES_ROM_TABLES
and/or look up MBEDTLS_AES_ROM_TABLES in the menuconfig/guiconfig interface. The Application
Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of
the manual might be helpful too.
warning: MBEDTLS_SSL_MAX_CONTENT_LEN (defined at modules/hostap/Kconfig:409,
modules/mbedtls/Kconfig:73, modules/hostap/Kconfig:409, modules/hostap/Kconfig:409,
modules/mbedtls/Kconfig:73) was assigned the value '16384' but got the value ''. Check these
unsatisfied dependencies: ((WIFI_NM_WPA_SUPPLICANT_CRYPTO_ENTERPRISE && WIFI_NM_WPA_SUPPLICANT) ||
(MBEDTLS_BUILTIN && MBEDTLS) || (WIFI_NM_WPA_SUPPLICANT_CRYPTO_ENTERPRISE && WIFI_NM_WPA_SUPPLICANT)
|| (WIFI_NM_WPA_SUPPLICANT_CRYPTO_ENTERPRISE && WIFI_NM_WPA_SUPPLICANT && 0) || (MBEDTLS_BUILTIN &&
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN and/or look up
MBEDTLS_SSL_MAX_CONTENT_LEN in the menuconfig/guiconfig interface. The Application Development
Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
warning: MBEDTLS_SSL_ALPN (defined at modules/mbedtls/Kconfig.mbedtls:38,
modules/mbedtls/Kconfig.mbedtls:38) was assigned the value 'y' but got the value 'n'. Check these
unsatisfied dependencies: (((MBEDTLS_TLS_VERSION_1_2 || MBEDTLS_TLS_VERSION_1_3) && !(NRF_SECURITY
|| NORDIC_SECURITY_BACKEND) && MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-mbedtls.h" && MBEDTLS)
|| ((MBEDTLS_TLS_VERSION_1_2 || MBEDTLS_TLS_VERSION_1_3) && !(NRF_SECURITY ||
NORDIC_SECURITY_BACKEND) && MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-mbedtls.h" && MBEDTLS &&
0)) (=n). See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_SSL_ALPN and/or look
up MBEDTLS_SSL_ALPN in the menuconfig/guiconfig interface. The Application Development Primer,
helpful too.
warning: MBEDTLS_PEM_CERTIFICATE_FORMAT (defined at modules/mbedtls/Kconfig.mbedtls:448,
modules/mbedtls/Kconfig.mbedtls:448) was assigned the value 'y' but got the value 'n'. Check these
unsatisfied dependencies: ((MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-mbedtls.h" && MBEDTLS) ||
(MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-mbedtls.h" && MBEDTLS && 0)) (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_PEM_CERTIFICATE_FORMAT and/or look
up MBEDTLS_PEM_CERTIFICATE_FORMAT in the menuconfig/guiconfig interface. The Application Development
warning: MBEDTLS_SERVER_NAME_INDICATION (defined at modules/mbedtls/Kconfig.mbedtls:508,
modules/mbedtls/Kconfig.mbedtls:508) was assigned the value 'y' but got the value 'n'. Check these
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_SERVER_NAME_INDICATION and/or look
up MBEDTLS_SERVER_NAME_INDICATION in the menuconfig/guiconfig interface. The Application Development
warning: MBEDTLS_HAVE_TIME_DATE (defined at modules/mbedtls/Kconfig.mbedtls:519,
modules/mbedtls/Kconfig.mbedtls:519) was assigned the value 'y' but got the value 'n'. Check these
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_HAVE_TIME_DATE and/or look up
MBEDTLS_HAVE_TIME_DATE in the menuconfig/guiconfig interface. The Application Development Primer,
helpful too.
warning: The choice symbol MBEDTLS_BUILTIN (defined at modules/mbedtls/Kconfig:30,
modules/mbedtls/Kconfig:30) was selected (set =y), but MBEDTLS_LIBRARY_NRF_SECURITY (defined at
/opt/nordic/ncs/v3.1.1/nrf/subsys/nrf_security/Kconfig:255) ended up as the choice selection. See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_BUILTIN and/or look up
MBEDTLS_BUILTIN in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
Parsing /Users/gildev/Downloads/aws_iot_mqtt/Kconfig
Loaded configuration '/opt/nordic/ncs/v3.1.1/zephyr/boards/nordic/nrf9160dk/nrf9160dk_nrf9160_ns_defconfig'
Merged configuration '/Users/gildev/Downloads/aws_iot_mqtt/prj.conf'
Configuration saved to '/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/zephyr/.config'
Kconfig header saved to '/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/zephyr/include/generated/zephyr/autoconf.h'
-- Found GnuLd: /opt/nordic/ncs/toolchains/561dce9adf/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
-- Found assembler: /opt/nordic/ncs/toolchains/561dce9adf/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
=========== Generating psa_crypto_config ===============
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
Backup: CONFIG_MBEDTLS_THREADING_C: True
Backup: CONFIG_MBEDTLS_THREADING_ALT: False
=========== Checkpoint: backup ===============
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
Restore: CONFIG_MBEDTLS_THREADING_C: True
Restore: CONFIG_MBEDTLS_THREADING_ALT: False
=========== End psa_crypto_config ===============
=========== Generating psa_crypto_library_config ===============
Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
=========== End psa_crypto_library_config ===============
-- Using ccache: /opt/nordic/ncs/toolchains/561dce9adf/bin/ccache
-- Found gen_kobject_list: /opt/nordic/ncs/v3.1.1/zephyr/scripts/build/gen_kobject_list.py
CMake Warning at /opt/nordic/ncs/v3.1.1/zephyr/kernel/CMakeLists.txt:178 (message):
          CONFIG_HEAP_MEM_POOL_SIZE is less than requested minimum:
            512 < 808
          Setting the system heap size to 808
CMake Warning at /opt/nordic/ncs/v3.1.1/zephyr/CMakeLists.txt:1027 (message):
  No SOURCES given to Zephyr library:
  ..__nrf__subsys__net__lib__tls_credentials
  Excluding target from build.
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/gildev/Downloads/aws_iot_mqtt/build_devkit
[1/379] Preparing syscall dependency handling
[5/379] Generating misc/generated/syscalls.json, misc/generated/str[6/379] Generating include/generated/zephyr/version.h
-- Zephyr version: 4.1.99 (/opt/nordic/ncs/v3.1.1/zephyr), build: ncs-v3.1.1
[7/379] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, [7/379] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-si[9/379] Generating ../../tfm/CMakeCache.txt
-- Found Git: /opt/nordic/ncs/toolchains/561dce9adf/bin/git (found version "2.37.3")
-- Found Python3: /opt/nordic/ncs/toolchains/561dce9adf/opt/[email protected]/bin/python3.12 (found version "3.12.4") found components: Interpreter
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm
[10/379] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c,[12/379] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-s[17/379] Performing build step for 'tfm'
[1/143] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
FAILED: secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
/opt/nordic/ncs/toolchains/561dce9adf/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DBL1_HEADER_SIZE=0x000 -DBL1_TRAILER_SIZE=0x000 -DBL2_HEADER_SIZE=0x000 -DBL2_TRAILER_SIZE=0x000 -DCONFIG_TFM_FLOAT_ABI=0 -DCONFIG_TFM_USE_TRUSTZONE -DCRYPTO_EXT_RNG -DCRYPTO_HW_ACCELERATOR -DDAUTH_CHIP_DEFAULT -DINSIDE_TFM_BUILD -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_PSA_CRYPTO_CONFIG_FILE=\"nrf-psa-crypto-config.h\" -DMBEDTLS_PSA_CRYPTO_DRIVERS -DMCUBOOT_IMAGE_NUMBER=1 -DNRF9160_XXAA -DNRF91_SERIES -DNRF_ALLOW_NON_SECURE_FAULT_HANDLING -DNRF_ALLOW_NON_SECURE_RESET -DNRF_CONFIG_CPU_FREQ_MHZ=128 -DNRF_NS_STORAGE -DNRF_SECURE_UART_INSTANCE=1 -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DPLATFORM_DEFAULT_BL1 -DPLATFORM_NS_NV_COUNTERS=0 -DPROJECT_CONFIG_HEADER_FILE=\"/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/modules/nrf/modules/trusted-firmware-m/tfm_config.h\" -DPS_CRYPTO_AEAD_ALG_CCM -DPS_ENCRYPTION -DSECURE_UART1 -DTFM_EXCEPTION_INFO_DUMP -DTFM_FIH_PROFILE_OFF -DTFM_INTERNAL_TRUSTED_STORAGE_SERVICE_SID=0x00000070 -DTFM_ISOLATION_LEVEL=1 -DTFM_PARTITION_CRYPTO -DTFM_PARTITION_LOG_LEVEL=TFM_PARTITION_LOG_LEVEL_SILENCE -DTFM_PARTITION_NS_AGENT_TZ -DTFM_PARTITION_PLATFORM -DTFM_SPM_LOG_LEVEL=TFM_SPM_LOG_LEVEL_INFO -DTFM_SPM_LOG_RAW_ENABLED -D__NRF_TFM__ -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/core -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/core/arch -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/include/boot -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/include/interface -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/generated/secure_fw/partitions/crypto -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/generated/secure_fw/partitions/platform -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/. -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/native_drivers -I/opt/nordic/ncs/v3.1.1/modules/hal/nordic/nrfx -I/opt/nordic/ncs/v3.1.1/modules/hal/nordic/nrfx/mdk -I/opt/nordic/ncs/v3.1.1/modules/hal/nordic/nrfx/drivers/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/common -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/.. -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/services/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/nrf91/. -I/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/include -I/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/partition -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/../zephyr/include/generated -I/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/board -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/../zephyr/misc/generated/syscalls_links/include -I/opt/nordic/ncs/v3.1.1/zephyr/include -I/opt/nordic/ncs/v3.1.1/zephyr/soc/nordic/common -I/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/services/include -I/opt/nordic/ncs/v3.1.1/nrf/include -I/opt/nordic/ncs/v3.1.1/nrf/include/tfm -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/accelerator/interface -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/../secure_fw/spm/include/private -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/common -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/driver -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/config -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/crypto -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/firmware_update -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/initial_attestation -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/internal_trusted_storage -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/platform -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/protected_storage -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/generated/interface/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/crypto/../../../platform/include -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/generated/interface_nrf_security_psa -I/opt/nordic/ncs/v3.1.1/nrf/subsys/nrf_security/include -I/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-psa-crypto/include -I/opt/nordic/ncs/v3.1.1/nrf/subsys/nrf_security/src/utils -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/lib/fih/inc -I/opt/nordic/ncs/v3.1.1/modules/hal/cmsis_6/CMSIS/Core/Include -I/opt/nordic/ncs/v3.1.1/modules/hal/cmsis_6/CMSIS/Core/Include/m-profile -I/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-psa-crypto/library -I/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library -I/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/include -I/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/include/library -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/interface/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/lib/runtime/include -mcpu=cortex-m33+nofp -Os -DNDEBUG -specs=nano.specs -specs=nosys.specs -Wall -Wno-format -Wno-return-type -Wno-unused-but-set-variable -c -fdata-sections -ffunction-sections -fno-builtin -fshort-enums -funsigned-char -mthumb -std=c99 -gdwarf-4 -g -mfloat-abi=soft -mcmse -Wno-unused-value -include /opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/include/cmsis_override.h -MD -MT secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o -MF secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o.d -o secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o -c /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.c
In file included from /opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/partition/region_defs.h:10,
                 from /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.c:17:
/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/partition/flash_layout.h:10:10: fatal error: pm_config.h: No such file or directory
   10 | #include <pm_config.h>
compilation terminated.
[2/143] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
FAILED: secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
/opt/nordic/ncs/toolchains/561dce9adf/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DBL1_HEADER_SIZE=0x000 -DBL1_TRAILER_SIZE=0x000 -DBL2_HEADER_SIZE=0x000 -DBL2_TRAILER_SIZE=0x000 -DCONFIG_TFM_FLOAT_ABI=0 -DCONFIG_TFM_USE_TRUSTZONE -DCRYPTO_EXT_RNG -DCRYPTO_HW_ACCELERATOR -DDAUTH_CHIP_DEFAULT -DINSIDE_TFM_BUILD -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_PSA_CRYPTO_CONFIG_FILE=\"nrf-psa-crypto-config.h\" -DMBEDTLS_PSA_CRYPTO_DRIVERS -DMCUBOOT_IMAGE_NUMBER=1 -DNRF9160_XXAA -DNRF91_SERIES -DNRF_ALLOW_NON_SECURE_FAULT_HANDLING -DNRF_ALLOW_NON_SECURE_RESET -DNRF_CONFIG_CPU_FREQ_MHZ=128 -DNRF_NS_STORAGE -DNRF_SECURE_UART_INSTANCE=1 -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DPLATFORM_DEFAULT_BL1 -DPLATFORM_NS_NV_COUNTERS=0 -DPROJECT_CONFIG_HEADER_FILE=\"/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/modules/nrf/modules/trusted-firmware-m/tfm_config.h\" -DPS_CRYPTO_AEAD_ALG_CCM -DPS_ENCRYPTION -DSECURE_UART1 -DTFM_EXCEPTION_INFO_DUMP -DTFM_FIH_PROFILE_OFF -DTFM_INTERNAL_TRUSTED_STORAGE_SERVICE_SID=0x00000070 -DTFM_ISOLATION_LEVEL=1 -DTFM_PARTITION_CRYPTO -DTFM_PARTITION_LOG_LEVEL=TFM_PARTITION_LOG_LEVEL_SILENCE -DTFM_PARTITION_NS_AGENT_TZ -DTFM_PARTITION_PLATFORM -DTFM_SPM_LOG_LEVEL=TFM_SPM_LOG_LEVEL_INFO -DTFM_SPM_LOG_RAW_ENABLED -D__NRF_TFM__ -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/core -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/core/arch -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/include/boot -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/include/interface -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/generated/secure_fw/partitions/crypto -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/generated/secure_fw/partitions/platform -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/. -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/native_drivers -I/opt/nordic/ncs/v3.1.1/modules/hal/nordic/nrfx -I/opt/nordic/ncs/v3.1.1/modules/hal/nordic/nrfx/mdk -I/opt/nordic/ncs/v3.1.1/modules/hal/nordic/nrfx/drivers/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/common -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/.. -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/services/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/nrf91/. -I/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/include -I/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/partition -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/../zephyr/include/generated -I/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/board -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/../zephyr/misc/generated/syscalls_links/include -I/opt/nordic/ncs/v3.1.1/zephyr/include -I/opt/nordic/ncs/v3.1.1/zephyr/soc/nordic/common -I/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/services/include -I/opt/nordic/ncs/v3.1.1/nrf/include -I/opt/nordic/ncs/v3.1.1/nrf/include/tfm -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/accelerator/interface -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/../secure_fw/spm/include/private -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/common -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/driver -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/config -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/crypto -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/firmware_update -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/initial_attestation -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/internal_trusted_storage -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/platform -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/protected_storage -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/generated/interface/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/crypto/../../../platform/include -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/generated/interface_nrf_security_psa -I/opt/nordic/ncs/v3.1.1/nrf/subsys/nrf_security/include -I/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-psa-crypto/include -I/opt/nordic/ncs/v3.1.1/nrf/subsys/nrf_security/src/utils -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/lib/fih/inc -I/opt/nordic/ncs/v3.1.1/modules/hal/cmsis_6/CMSIS/Core/Include -I/opt/nordic/ncs/v3.1.1/modules/hal/cmsis_6/CMSIS/Core/Include/m-profile -I/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-psa-crypto/library -I/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library -I/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/include -I/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/include/library -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/interface/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/lib/runtime/include -mcpu=cortex-m33+nofp -Os -DNDEBUG -specs=nano.specs -specs=nosys.specs -Wall -Wno-format -Wno-return-type -Wno-unused-but-set-variable -c -fdata-sections -ffunction-sections -fno-builtin -fshort-enums -funsigned-char -mthumb -std=c99 -gdwarf-4 -g -mfloat-abi=soft -mcmse -Wno-unused-value -include /opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/include/cmsis_override.h -MD -MT secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o -MF secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o.d -o secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o -c /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.c
                 from /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.c:17:
[4/143] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/core/tfm_boot_data.o
FAILED: secure_fw/spm/CMakeFiles/tfm_spm.dir/core/tfm_boot_data.o
/opt/nordic/ncs/toolchains/561dce9adf/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DBL1_HEADER_SIZE=0x000 -DBL1_TRAILER_SIZE=0x000 -DBL2_HEADER_SIZE=0x000 -DBL2_TRAILER_SIZE=0x000 -DCONFIG_TFM_FLOAT_ABI=0 -DCONFIG_TFM_HALT_ON_CORE_PANIC -DCONFIG_TFM_USE_TRUSTZONE -DCRYPTO_EXT_RNG -DCRYPTO_HW_ACCELERATOR -DDAUTH_CHIP_DEFAULT -DINSIDE_TFM_BUILD -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_PSA_CRYPTO_CONFIG_FILE=\"nrf-psa-crypto-config.h\" -DMBEDTLS_PSA_CRYPTO_DRIVERS -DMCUBOOT_IMAGE_NUMBER=1 -DNRF9160_XXAA -DNRF91_SERIES -DNRF_ALLOW_NON_SECURE_FAULT_HANDLING -DNRF_ALLOW_NON_SECURE_RESET -DNRF_CONFIG_CPU_FREQ_MHZ=128 -DNRF_NS_STORAGE -DNRF_SECURE_UART_INSTANCE=1 -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DPLATFORM_DEFAULT_BL1 -DPLATFORM_NS_NV_COUNTERS=0 -DPROJECT_CONFIG_HEADER_FILE=\"/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/modules/nrf/modules/trusted-firmware-m/tfm_config.h\" -DPS_CRYPTO_AEAD_ALG_CCM -DPS_ENCRYPTION -DSECURE_UART1 -DTFM_EXCEPTION_INFO_DUMP -DTFM_FIH_PROFILE_OFF -DTFM_INTERNAL_TRUSTED_STORAGE_SERVICE_SID=0x00000070 -DTFM_ISOLATION_LEVEL=1 -DTFM_PARTITION_CRYPTO -DTFM_PARTITION_LOG_LEVEL=TFM_PARTITION_LOG_LEVEL_SILENCE -DTFM_PARTITION_NS_AGENT_TZ -DTFM_PARTITION_PLATFORM -DTFM_SPM_LOG_LEVEL=TFM_SPM_LOG_LEVEL_INFO -DTFM_SPM_LOG_RAW_ENABLED -D__NRF_TFM__ -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/core -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/lib/runtime -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/generated -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/generated/secure_fw/spm/include -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/generated/secure_fw/spm/core -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/core/arch -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/include/boot -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/include/interface -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/. -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/native_drivers -I/opt/nordic/ncs/v3.1.1/modules/hal/nordic/nrfx -I/opt/nordic/ncs/v3.1.1/modules/hal/nordic/nrfx/mdk -I/opt/nordic/ncs/v3.1.1/modules/hal/nordic/nrfx/drivers/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/common -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/.. -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/services/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/nrf91/. -I/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/include -I/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/partition -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/../zephyr/include/generated -I/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/board -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/../zephyr/misc/generated/syscalls_links/include -I/opt/nordic/ncs/v3.1.1/zephyr/include -I/opt/nordic/ncs/v3.1.1/zephyr/soc/nordic/common -I/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/services/include -I/opt/nordic/ncs/v3.1.1/nrf/include -I/opt/nordic/ncs/v3.1.1/nrf/include/tfm -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/accelerator/interface -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/../secure_fw/spm/include/private -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/common -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/driver -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/config -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/crypto -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/firmware_update -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/initial_attestation -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/internal_trusted_storage -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/platform -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/protected_storage -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/generated/interface/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/crypto/../../../platform/include -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/generated/interface_nrf_security_psa -I/opt/nordic/ncs/v3.1.1/nrf/subsys/nrf_security/include -I/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-psa-crypto/include -I/opt/nordic/ncs/v3.1.1/nrf/subsys/nrf_security/src/utils -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/lib/fih/inc -I/opt/nordic/ncs/v3.1.1/modules/hal/cmsis_6/CMSIS/Core/Include -I/opt/nordic/ncs/v3.1.1/modules/hal/cmsis_6/CMSIS/Core/Include/m-profile -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/generated/secure_fw/partitions/crypto -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/generated/secure_fw/partitions/platform -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/lib/runtime/include -I/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-psa-crypto/library -I/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library -I/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/include -I/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/include/library -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/interface/include -mcpu=cortex-m33+nofp -Os -DNDEBUG -specs=nano.specs -specs=nosys.specs -Wall -Wno-format -Wno-return-type -Wno-unused-but-set-variable -c -fdata-sections -ffunction-sections -fno-builtin -fshort-enums -funsigned-char -mthumb -std=c99 -gdwarf-4 -g -mfloat-abi=soft -mcmse -Wno-unused-value -include /opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/include/cmsis_override.h -MD -MT secure_fw/spm/CMakeFiles/tfm_spm.dir/core/tfm_boot_data.o -MF secure_fw/spm/CMakeFiles/tfm_spm.dir/core/tfm_boot_data.o.d -o secure_fw/spm/CMakeFiles/tfm_spm.dir/core/tfm_boot_data.o -c /opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/core/tfm_boot_data.c
                 from /opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/core/tfm_boot_data.c:12:
[7/143] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/load_info_ns_agent_tz.o
FAILED: secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/load_info_ns_agent_tz.o
/opt/nordic/ncs/toolchains/561dce9adf/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DBL1_HEADER_SIZE=0x000 -DBL1_TRAILER_SIZE=0x000 -DBL2_HEADER_SIZE=0x000 -DBL2_TRAILER_SIZE=0x000 -DCONFIG_TFM_FLOAT_ABI=0 -DCONFIG_TFM_USE_TRUSTZONE -DCRYPTO_EXT_RNG -DCRYPTO_HW_ACCELERATOR -DDAUTH_CHIP_DEFAULT -DINSIDE_TFM_BUILD -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_PSA_CRYPTO_CONFIG_FILE=\"nrf-psa-crypto-config.h\" -DMBEDTLS_PSA_CRYPTO_DRIVERS -DMCUBOOT_IMAGE_NUMBER=1 -DNRF9160_XXAA -DNRF91_SERIES -DNRF_ALLOW_NON_SECURE_FAULT_HANDLING -DNRF_ALLOW_NON_SECURE_RESET -DNRF_CONFIG_CPU_FREQ_MHZ=128 -DNRF_NS_STORAGE -DNRF_SECURE_UART_INSTANCE=1 -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DPLATFORM_DEFAULT_BL1 -DPLATFORM_NS_NV_COUNTERS=0 -DPROJECT_CONFIG_HEADER_FILE=\"/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/modules/nrf/modules/trusted-firmware-m/tfm_config.h\" -DPS_CRYPTO_AEAD_ALG_CCM -DPS_ENCRYPTION -DSECURE_UART1 -DTFM_EXCEPTION_INFO_DUMP -DTFM_FIH_PROFILE_OFF -DTFM_INTERNAL_TRUSTED_STORAGE_SERVICE_SID=0x00000070 -DTFM_ISOLATION_LEVEL=1 -DTFM_PARTITION_CRYPTO -DTFM_PARTITION_LOG_LEVEL=TFM_PARTITION_LOG_LEVEL_SILENCE -DTFM_PARTITION_NS_AGENT_TZ -DTFM_PARTITION_PLATFORM -DTFM_SPM_LOG_LEVEL=TFM_SPM_LOG_LEVEL_INFO -DTFM_SPM_LOG_RAW_ENABLED -D__NRF_TFM__ -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/core -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/core/arch -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/include/boot -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/include/interface -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/generated/secure_fw/partitions/crypto -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/generated/secure_fw/partitions/platform -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/. -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/native_drivers -I/opt/nordic/ncs/v3.1.1/modules/hal/nordic/nrfx -I/opt/nordic/ncs/v3.1.1/modules/hal/nordic/nrfx/mdk -I/opt/nordic/ncs/v3.1.1/modules/hal/nordic/nrfx/drivers/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/common -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/.. -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/services/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/nrf91/. -I/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/include -I/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/partition -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/../zephyr/include/generated -I/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/board -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/../zephyr/misc/generated/syscalls_links/include -I/opt/nordic/ncs/v3.1.1/zephyr/include -I/opt/nordic/ncs/v3.1.1/zephyr/soc/nordic/common -I/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/services/include -I/opt/nordic/ncs/v3.1.1/nrf/include -I/opt/nordic/ncs/v3.1.1/nrf/include/tfm -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/accelerator/interface -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/../secure_fw/spm/include/private -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/common -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/driver -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/config -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/crypto -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/firmware_update -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/initial_attestation -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/internal_trusted_storage -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/platform -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/protected_storage -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/generated/interface/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/crypto/../../../platform/include -I/Users/gildev/Downloads/aws_iot_mqtt/build_devkit/generated/interface_nrf_security_psa -I/opt/nordic/ncs/v3.1.1/nrf/subsys/nrf_security/include -I/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-psa-crypto/include -I/opt/nordic/ncs/v3.1.1/nrf/subsys/nrf_security/src/utils -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/lib/fih/inc -I/opt/nordic/ncs/v3.1.1/modules/hal/cmsis_6/CMSIS/Core/Include -I/opt/nordic/ncs/v3.1.1/modules/hal/cmsis_6/CMSIS/Core/Include/m-profile -I/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-psa-crypto/library -I/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library -I/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/include -I/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/include/library -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/interface/include -I/opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/lib/runtime/include -mcpu=cortex-m33+nofp -Os -DNDEBUG -specs=nano.specs -specs=nosys.specs -Wall -Wno-format -Wno-return-type -Wno-unused-but-set-variable -c -fdata-sections -ffunction-sections -fno-builtin -fshort-enums -funsigned-char -mthumb -std=c99 -gdwarf-4 -g -mfloat-abi=soft -mcmse -Wno-unused-value -include /opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/platform/include/cmsis_override.h -MD -MT secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/load_info_ns_agent_tz.o -MF secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/load_info_ns_agent_tz.o.d -o secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/load_info_ns_agent_tz.o -c /opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/ns_agent_tz/load_info_ns_agent_tz.c
                 from /opt/nordic/ncs/v3.1.1/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/ns_agent_tz/load_info_ns_agent_tz.c:24:
[14/143] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/core/main.o
FAILED: modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-build tfm/bin/tfm_s.elf tfm/bin/tfm_s.bin tfm/bin/tfm_s.hex tfm/bin/tfm_s_signed.bin tfm/bin/tfm_s_ns_signed.bin tfm/api_ns/interface/lib/s_veneers.o tfm/api_ns/interface/src/tfm_attest_api.c tfm/api_ns/interface/src/tfm_crypto_api.c tfm/api_ns/interface/src/tfm_fwu_api.c tfm/api_ns/interface/src/tfm_its_api.c tfm/api_ns/interface/src/tfm_platform_api.c tfm/api_ns/interface/src/tfm_ps_api.c tfm/api_ns/interface/src/tfm_tz_psa_ns_api.c tfm/api_ns/interface/src/tfm_ioctl_core_ns_api.c /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-build /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/bin/tfm_s.elf /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/bin/tfm_s.bin /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/bin/tfm_s.hex /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/bin/tfm_s_signed.bin /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/bin/tfm_s_ns_signed.bin /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/api_ns/interface/lib/s_veneers.o /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/api_ns/interface/src/tfm_attest_api.c /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/api_ns/interface/src/tfm_crypto_api.c /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/api_ns/interface/src/tfm_fwu_api.c /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/api_ns/interface/src/tfm_its_api.c /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/api_ns/interface/src/tfm_platform_api.c /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/api_ns/interface/src/tfm_ps_api.c /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/api_ns/interface/src/tfm_tz_psa_ns_api.c /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm/api_ns/interface/src/tfm_ioctl_core_ns_api.c
cd /Users/gildev/Downloads/aws_iot_mqtt/build_devkit/tfm && /opt/nordic/ncs/toolchains/561dce9adf/Cellar/cmake/3.21.0/bin/cmake --build .
FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/561dce9adf/bin/cmake --build /Users/gildev/Downloads/aws_iot_mqtt/build_devkit
 *  The terminal process terminated with exit code: 1.
Also interested in the aws_iot sample working with the modem but over MbedTLS (instead of the modem’s native TLS features), which could then make it easier to add an Ethernet controller by using the same network stack.
Thanks.
  • Some follow-up testing and information: I have tried compiling the aws_iot sample for the nrf9160dk/nrf9160/ns target, here is what I get:
    Building aws_iot_raw
    west build --build-dir /Users/gildev/Downloads/aws_iot_raw/build_devkit /Users/gildev/Downloads/aws_iot_raw --pristine --board nrf9160dk/nrf9160/ns
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    Parsing /Users/gildev/Downloads/aws_iot_raw/Kconfig.sysbuild
    Loaded configuration '/Users/gildev/Downloads/aws_iot_raw/build_devkit/_sysbuild/empty.conf'
    Merged configuration '/Users/gildev/Downloads/aws_iot_raw/build_devkit/_sysbuild/empty.conf'
    Configuration saved to '/Users/gildev/Downloads/aws_iot_raw/build_devkit/zephyr/.config'
    Kconfig header saved to '/Users/gildev/Downloads/aws_iot_raw/build_devkit/_sysbuild/autoconf.h'
       * Running CMake for mcuboot *
    -- Application: /opt/nordic/ncs/v3.1.1/bootloader/mcuboot/boot/zephyr
    -- Found Python3: /opt/nordic/ncs/toolchains/561dce9adf/bin/python (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Found BOARD.dts: /opt/nordic/ncs/v3.1.1/zephyr/boards/nordic/nrf9160dk/nrf9160dk_nrf9160.dts
    -- Found devicetree overlay: /opt/nordic/ncs/v3.1.1/zephyr/boards/nordic/nrf9160dk/nrf9160dk_nrf9160_0_14_0.overlay
    -- Found devicetree overlay: /Users/gildev/Downloads/aws_iot_raw/sysbuild/mcuboot/app.overlay
    -- Generated zephyr.dts: /Users/gildev/Downloads/aws_iot_raw/build_devkit/mcuboot/zephyr/zephyr.dts
    -- Generated pickled edt: /Users/gildev/Downloads/aws_iot_raw/build_devkit/mcuboot/zephyr/edt.pickle
    -- Generated devicetree_generated.h: /Users/gildev/Downloads/aws_iot_raw/build_devkit/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    warning: MBEDTLS_CFG_FILE (defined at
    /opt/nordic/ncs/v3.1.1/bootloader/mcuboot/boot/zephyr/Kconfig:490,
    /opt/nordic/ncs/v3.1.1/nrf/subsys/nrf_security/Kconfig:67, modules/mbedtls/Kconfig:59,
    modules/mbedtls/Kconfig:59) was assigned the value 'mcuboot-mbedtls-cfg.h' but got the value ''. See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_CFG_FILE and/or look up
    MBEDTLS_CFG_FILE in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    too.
    Parsing /opt/nordic/ncs/v3.1.1/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration '/opt/nordic/ncs/v3.1.1/zephyr/boards/nordic/nrf9160dk/nrf9160dk_nrf9160_defconfig'
    Merged configuration '/Users/gildev/Downloads/aws_iot_raw/sysbuild/mcuboot/prj.conf'
    Merged configuration '/opt/nordic/ncs/v3.1.1/nrf/modules/mcuboot/tfm.conf'
    Merged configuration '/Users/gildev/Downloads/aws_iot_raw/build_devkit/mcuboot/zephyr/.config.sysbuild'
    Configuration saved to '/Users/gildev/Downloads/aws_iot_raw/build_devkit/mcuboot/zephyr/.config'
    Kconfig header saved to '/Users/gildev/Downloads/aws_iot_raw/build_devkit/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
    MCUBoot bootloader key file: /opt/nordic/ncs/v3.1.1/bootloader/mcuboot/root-ec-p256.pem
    CMake Warning at CMakeLists.txt:412 (message):
      WARNING: Using default MCUboot signing key file, this file is for debug use
      only and is not secure!
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /Users/gildev/Downloads/aws_iot_raw/build_devkit/mcuboot
       * Running CMake for aws_iot_raw *
    -- Application: /Users/gildev/Downloads/aws_iot_raw
    -- Found devicetree overlay: /Users/gildev/Downloads/aws_iot_raw/boards/nrf9160dk_nrf9160_ns.overlay
    -- Generated zephyr.dts: /Users/gildev/Downloads/aws_iot_raw/build_devkit/aws_iot_raw/zephyr/zephyr.dts
    -- Generated pickled edt: /Users/gildev/Downloads/aws_iot_raw/build_devkit/aws_iot_raw/zephyr/edt.pickle
    -- Generated devicetree_generated.h: /Users/gildev/Downloads/aws_iot_raw/build_devkit/aws_iot_raw/zephyr/include/generated/zephyr/devicetree_generated.h
    Merged configuration '/Users/gildev/Downloads/aws_iot_raw/prj.conf'
    Merged configuration '/Users/gildev/Downloads/aws_iot_raw/boards/nrf9160dk_nrf9160_ns.conf'
    Merged configuration '/Users/gildev/Downloads/aws_iot_raw/build_devkit/aws_iot_raw/zephyr/.config.sysbuild'
    Configuration saved to '/Users/gildev/Downloads/aws_iot_raw/build_devkit/aws_iot_raw/zephyr/.config'
    Kconfig header saved to '/Users/gildev/Downloads/aws_iot_raw/build_devkit/aws_iot_raw/zephyr/include/generated/zephyr/autoconf.h'
    -- Including signing script: /opt/nordic/ncs/v3.1.1/nrf/cmake/sysbuild/image_signing.cmake
    CMake Warning at /opt/nordic/ncs/v3.1.1/zephyr/CMakeLists.txt:2232 (message):
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /Users/gildev/Downloads/aws_iot_raw/build_devkit/aws_iot_raw
    CMake Warning at /opt/nordic/ncs/v3.1.1/nrf/cmake/sysbuild/partition_manager.cmake:119 (message):
            --- WARNING: Using a bootloader without pm_static.yml.            ---
            --- There are cases where a deployed product can consist of       ---
            --- multiple images, and only a subset of these images can be     ---
            --- upgraded through a firmware update mechanism. In such cases,  ---
            --- the upgradable images must have partitions that are static    ---
            --- and are matching the partition map used by the bootloader     ---
            --- programmed onto the device.                                   ---
      /opt/nordic/ncs/v3.1.1/nrf/cmake/sysbuild/partition_manager.cmake:636 (partition_manager)
      /opt/nordic/ncs/v3.1.1/nrf/sysbuild/CMakeLists.txt:825 (include)
      cmake/modules/sysbuild_extensions.cmake:598 (nrf_POST_CMAKE)
      cmake/modules/sysbuild_extensions.cmake:598 (cmake_language)
      cmake/modules/sysbuild_images.cmake:46 (sysbuild_module_call)
      cmake/modules/sysbuild_default.cmake:21 (include)
      /opt/nordic/ncs/v3.1.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      /opt/nordic/ncs/v3.1.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      /opt/nordic/ncs/v3.1.1/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    Dropping partition 'nonsecure_storage' since it is empty.
    -- Configuring done
    -- Generating done
    [9/20] Performing build step for 'mcuboot'
    [1/190] Preparing syscall dependency handling
    [8/190] Generating include/generated/zephyr/version.h
    [9/190] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, [9/190] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-si[11/190] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c,[13/190] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-s[15/190] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/opt/nordic/ncs/v3.1.1/bootloader/mcuboot/boot/bo[15/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/modules[15/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/modules[15/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/modules[15/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/modules[15/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/modules[15/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/modules[15/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/modules[15/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/modules[15/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/modules[16/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/modules[17/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/modules[22/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/modules[23/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/modules[27/190] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/opt/nordic/ncs/v3.1.1/bootloader/mcuboot/boot/bo[30/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/modules[39/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/modules[41/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/modules[48/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/modules[79/190] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.1.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort[80/190] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.1.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_no_mu[92/190] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.1.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_no_mu[94/190] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.1.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort[129/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[190/190] Linking C executable zephyr/zephyr.elf
               FLASH:       29184 B        48 KB     59.38%
                 RAM:         16 KB        32 KB     50.00%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from /Users/gildev/Downloads/aws_iot_raw/build_devkit/mcuboot/zephyr/zephyr.elf for board: nrf9160dk
    [11/20] Performing build step for 'aws_iot_raw'
    [0/1] Re-running CMake...
    Loading Zephyr default modules (Zephyr base (cached)).
    Loaded configuration '/Users/gildev/Downloads/aws_iot_raw/build_devkit/aws_iot_raw/zephyr/.config'
    No change to configuration in '/Users/gildev/Downloads/aws_iot_raw/build_devkit/aws_iot_raw/zephyr/.config'
    No change to Kconfig header in '/Users/gildev/Downloads/aws_iot_raw/build_devkit/aws_iot_raw/zephyr/include/generated/zephyr/autoconf.h'
    -- Configuring done
    -- Generating done
    [1/385] Preparing syscall dependency handling
    [6/385] Generating include/generated/zephyr/version.h
    [7/385] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, [7/385] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-si[9/385] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, [11/385] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-s[12/385] Generating ../../tfm/CMakeCache.txt
    -- Found Python3: /opt/nordic/ncs/toolchains/561dce9adf/bin/python (found version "3.12.4") found components: Interpreter
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /Users/gildev/Downloads/aws_iot_raw/build_devkit/aws_iot_raw/tfm
    [17/385] Performing build step for 'tfm'
    [22/141] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_cry[23/141] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_p[37/141] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm[39/141] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sp_log.dir/__/__/__/__/platform/ext/common/tfm_hal_sp_logdev_peri[42/141] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm[44/141] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_cry[46/141] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_p[48/141] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sp_log.dir/__/__/__/__/platform/ext/common/tfm_hal_sp_logdev_peri[52/141] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/generated/secure_fw/partitions/c[53/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[54/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[55/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[56/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[57/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[58/141] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/generated/secure_fw/partitions/c[58/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[59/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[60/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[61/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[62/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[63/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[63/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_mute[64/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[64/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_even[65/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[65/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v[66/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[66/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/psa_core.dir/opt/nordic/ncs/v3[67/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[67/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/psa_core.dir/opt/nordic/ncs/v3[68/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_mute[68/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...eFiles/psa_core.dir/opt/nordic/ncs/v3.1[69/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...es/psa_core.dir/opt/nordic/ncs/v3.1.1/m[70/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[70/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...re.dir/opt/nordic/ncs/v3.1.1/modules/cr[71/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_even[71/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...s/psa_core.dir/opt/nordic/ncs/v3.1.1/mo[72/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[72/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...eFiles/psa_core.dir/opt/nordic/ncs/v3.1[73/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe..._driver.dir/opt/nordic/ncs/v3.1.1/modul[74/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/psa_core.dir/opt/nordic/ncs/v3[74/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...psa_driver.dir/opt/nordic/ncs/v3.1.1/mo[75/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...s/psa_core.dir/opt/nordic/ncs/v3.1.1/mo[75/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...sa_driver.dir/opt/nordic/ncs/v3.1.1/mod[76/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...es/psa_core.dir/opt/nordic/ncs/v3.1.1/m[76/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe..._driver.dir/opt/nordic/ncs/v3.1.1/modul[77/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...eFiles/psa_core.dir/opt/nordic/ncs/v3.1[77/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...sa_driver.dir/opt/nordic/ncs/v3.1.1/mod[78/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe..._driver.dir/opt/nordic/ncs/v3.1.1/modul[78/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe..._driver.dir/opt/nordic/ncs/v3.1.1/modul[79/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...psa_driver.dir/opt/nordic/ncs/v3.1.1/mo[79/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe..._psa_driver.dir/opt/nordic/ncs/v3.1.1/m[80/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...sa_driver.dir/opt/nordic/ncs/v3.1.1/mod[80/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe..._psa_driver.dir/opt/nordic/ncs/v3.1.1/m[81/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v[81/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...driver.dir/opt/nordic/ncs/v3.1.1/module[82/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe..._driver.dir/opt/nordic/ncs/v3.1.1/modul[82/141] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/generated/secure_fw/partitio[83/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[84/141] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/generated/secure_fw/partitio[84/141] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/platform/ext/common/syscalls[85/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...sa_driver.dir/opt/nordic/ncs/v3.1.1/mod[86/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...re.dir/opt/nordic/ncs/v3.1.1/modules/cr[87/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[89/141] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/platform/ext/common/syscalls[90/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[91/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe..._psa_driver.dir/opt/nordic/ncs/v3.1.1/m[93/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...eFiles/psa_core.dir/opt/nordic/ncs/v3.1[94/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe..._driver.dir/opt/nordic/ncs/v3.1.1/modul[97/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe..._psa_driver.dir/opt/nordic/ncs/v3.1.1/m[97/141] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/src/tfm_ioctl_[98/141] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/tfm_hal[99/141] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/assert.[100/141] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/dummy_[101/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_ob...driver.dir/opt/nordic/ncs/v3.1.1/module[101/141] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/tfm_ha[102/141] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/dummy_[102/141] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/dummy_[103/141] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/assert[103/141] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/ns_fau[104/141] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/src/tfm_platf[105/141] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/tfm_ha[107/141] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/dummy_[117/141] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/src/tfm_ioctl[118/141] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/tfm_ha[121/141] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/ns_fau[122/141] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/src/tfm_platf[123/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/psa_core.dir/opt/nordic/ncs/v[137/141] Linking C executable bin/tfm_s.axf
               FLASH:       31580 B      32256 B     97.90%
                 RAM:       10404 B        32 KB     31.75%
    [141/141] Linking C static library secure_fw/libtfm_s_veneers.a
    [19/385] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    ----- Installing platform NS -----
    [20/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[20/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[20/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[20/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[20/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[20/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[20/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[20/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[20/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[20/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[20/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-ps[20/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-ps[21/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[22/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[22/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[23/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[23/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[24/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[24/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[25/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[25/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[26/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-ps[26/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[27/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-ps[27/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[28/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[28/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[29/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[29/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[30/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[30/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[31/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[31/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[32/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[32/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-psa-cry[33/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[33/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[34/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[34/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[35/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[35/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[36/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[36/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[37/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[37/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[38/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[38/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[39/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[39/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[40/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[40/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[41/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[41/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[42/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[43/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[43/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[44/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-psa-cry[44/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[45/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[45/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[46/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[46/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[47/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[47/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[48/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[48/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[49/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[49/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[50/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[50/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[51/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[51/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[52/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[52/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[53/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[53/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[54/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[54/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[55/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[55/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[56/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[57/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[58/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[59/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[59/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[60/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[61/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[62/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[63/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[64/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[65/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[66/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[67/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[68/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[70/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[71/385] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[153/385] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mb[155/385] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mb[166/385] Building C object modules/nrf/subsys/net/lib/downloader/CMakeFiles/..__nrf__subsys__net__lib__downloader.dir/src/transports/http.c[167/385] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/fota_downlo[168/385] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/util/fota_d[169/385] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/util/fota_d[170/385] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/util/fota_d[170/385] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/util/fota_d[177/385] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/util/fota_d[177/385] Building C object modules/nrf/subsys/dfu/dfu_target/CMakeFiles/..__nrf__subsys__dfu__dfu_target.dir/src/dfu_target_modem_delta.c.o[180/385] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/util/fota_d[185/385] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/opt/nordic/ncs/v3.1.1/bootloader/mcuboot/boot/b[191/385] Building C object modules/nrf/subsys/net/lib/downloader/CMakeFiles/..__nrf__subsys__net__lib__downloader.dir/src/transports/http.c[192/385] Building C object modules/nrf/subsys/dfu/dfu_target/CMakeFiles/..__nrf__subsys__dfu__dfu_target.dir/src/dfu_target_modem_delta.c.o[198/385] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[200/385] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[200/385] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[201/385] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[202/385] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[203/385] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[206/385] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[206/385] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[207/385] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[209/385] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[210/385] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/opt/nordic/ncs/v3.1.1/bootloader/mcuboot/boot/b[211/385] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[211/385] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[217/385] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[218/385] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[225/385] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/fota_downlo[227/385] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[230/385] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[258/385] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[293/385] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.1.1/nrf/subsys/partition_manager/flash_map_partition_manager.c.ob[295/385] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[300/385] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.1.1/nrf/subsys/partition_manager/flash_map_partition_manager.c.ob[385/385] Linking C executable zephyr/zephyr.elf
               FLASH:      191376 B       448 KB     41.72%
                 RAM:       64660 B     195224 B     33.12%
    Generating files from /Users/gildev/Downloads/aws_iot_raw/build_devkit/aws_iot_raw/zephyr/zephyr.elf for board: nrf9160dk
    image.py: sign the payload
    [14/20] cd /Users/gildev/Downloads/aws_iot_raw/build_devkit/_sysbuild && /opt/nordic/ncs/toolchains/561dce9adf/Cellar/cmake/3.21.0/bin/cmake[17/20] cd /Users/gildev/Downloads/aws_iot_raw/build_devkit/_sysbuild && /opt/nordic/ncs/toolchains/561dce9adf/Cellar/cmake/3.21.0/bin/cmake[18/20] cd /Users/gildev/Downloads/aws_iot_raw/build_devkit/_sysbuild && /opt/nordic/ncs/toolchains/561dce9adf/Cellar/cmake/3.21.0/bin/cmake[20/20] Generating ../merged.hex
    Now I add the content of the https_client sample’s prj.conf to the above aws_iot sample’s project.conf, it ends up like this:
    # Copyright (c) 2020 Nordic Semiconductor ASA
    # General
    CONFIG_LOG=y
    CONFIG_LOG_BUFFER_SIZE=2048
    CONFIG_HW_ID_LIBRARY=y
    CONFIG_ASSERT=y
    CONFIG_JSON_LIBRARY=y
    CONFIG_REBOOT=y
    # Heap and stacks
    CONFIG_HEAP_MEM_POOL_SIZE=8192
    CONFIG_MAIN_STACK_SIZE=4096
    # Network
    CONFIG_NETWORKING=y
    CONFIG_NET_NATIVE=y
    CONFIG_NET_IPV4=y
    CONFIG_NET_CONNECTION_MANAGER=y
    # AWS IoT library
    CONFIG_AWS_IOT=y
    CONFIG_AWS_IOT_CLIENT_ID_STATIC="my-thing"
    CONFIG_AWS_IOT_BROKER_HOST_NAME="xxx.amazonaws.com"
    CONFIG_AWS_IOT_TOPIC_UPDATE_DELTA_SUBSCRIBE=y
    CONFIG_AWS_IOT_TOPIC_GET_ACCEPTED_SUBSCRIBE=y
    CONFIG_AWS_IOT_TOPIC_GET_REJECTED_SUBSCRIBE=y
    # MQTT helper library
    CONFIG_MQTT_HELPER=y
    CONFIG_MQTT_HELPER_SEC_TAG=201
    CONFIG_MQTT_HELPER_LAST_WILL=y
    CONFIG_MQTT_HELPER_STACK_SIZE=4096
    # MQTT - Maximum MQTT keepalive timeout specified by AWS IoT Core
    CONFIG_MQTT_KEEPALIVE=1200
    CONFIG_MQTT_CLEAN_SESSION=y
    ### From sample https_client with overlay-tfm-nrf91.conf
    # General
    CONFIG_HEAP_MEM_POOL_SIZE=1280
    # Logging
    CONFIG_LOG=y
    # Network
    CONFIG_NETWORKING=y
    CONFIG_NET_SOCKETS=y
    CONFIG_POSIX_API=y
    CONFIG_NET_IPV4=y
    CONFIG_NET_IPV6=y
    CONFIG_NET_CONNECTION_MANAGER_MONITOR_STACK_SIZE=4600
    # TFM configuration
    CONFIG_TFM_PROFILE_TYPE_NOT_SET=y
    # MbedTLS and security
    CONFIG_MBEDTLS=y
    CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
    CONFIG_MBEDTLS_ENABLE_HEAP=y
    CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=4096
    CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=4096
    CONFIG_MBEDTLS_SSL_SERVER_NAME_INDICATION=y
    CONFIG_MBEDTLS_HEAP_SIZE=32768
    CONFIG_MBEDTLS_RSA_C=y
    CONFIG_MBEDTLS_TLS_LIBRARY=y
    CONFIG_MBEDTLS_X509_LIBRARY=y
    CONFIG_MBEDTLS_PKCS1_V15=y
    CONFIG_NORDIC_SECURITY_BACKEND=y
    CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y
    CONFIG_PSA_WANT_ALG_SHA_1=y
    CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT=y
    CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN=y
    CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY=y
    CONFIG_PSA_WANT_ECC_SECP_R1_384=y
    # RSA requires that at least one key size is enabled
    CONFIG_PSA_WANT_RSA_KEY_SIZE_1024=y
    # Modem key management needs to be set to n, if not the certificate are provisioned to the modem
    CONFIG_MODEM_KEY_MGMT=n
    And now I get a huge flash overflow:
    Wwest build --build-dir /Users/gildev/Downloads/aws_iot_raw/build_devkit /Users/gildev/Downloads/aws_iot_raw --pristine --board [email protected]/nrf9160/ns --sysbuild --
    -- Found Python3: /opt/nordic/ncs/toolchains/561dce9adf/opt/[email protected]/bin/python3.12 (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: /Users/gildev/Library/Caches/zephyr
    -- Found west (found suitable version "1.4.0", minimum required is "0.14.0")
    -- Board: nrf9160dk, Revision: 0.14.0, qualifiers: nrf9160/ns
    -- CMake version: 3.21.0
    -- Zephyr version: 4.1.99 (/opt/nordic/ncs/v3.1.1/zephyr)
    -- Found host-tools: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/561dce9adf/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/561dce9adf/opt/zephyr-sdk)
    -- Found Dtc: /opt/nordic/ncs/toolchains/561dce9adf/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    -- Found GnuLd: /opt/nordic/ncs/toolchains/561dce9adf/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
    -- Found assembler: /opt/nordic/ncs/toolchains/561dce9adf/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    -- Using ccache: /opt/nordic/ncs/toolchains/561dce9adf/bin/ccache
    -- Found gen_kobject_list: /opt/nordic/ncs/v3.1.1/zephyr/scripts/build/gen_kobject_list.py
    -- Configuring done
    -- Generating done
    -- Found BOARD.dts: /opt/nordic/ncs/v3.1.1/zephyr/boards/nordic/nrf9160dk/nrf9160dk_nrf9160_ns.dts
    -- Found devicetree overlay: /opt/nordic/ncs/v3.1.1/zephyr/boards/nordic/nrf9160dk/nrf9160dk_nrf9160_ns_0_14_0.overlay
    warning: Deprecated symbol MBEDTLS_LEGACY_CRYPTO_C is enabled.
    warning: Experimental symbol TFM_EXPERIMENTAL is enabled.
    Loaded configuration '/opt/nordic/ncs/v3.1.1/zephyr/boards/nordic/nrf9160dk/nrf9160dk_nrf9160_ns_defconfig'
    =========== Generating psa_crypto_config ===============
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Backup: CONFIG_MBEDTLS_THREADING_C: True
    Backup: CONFIG_MBEDTLS_THREADING_ALT: False
    =========== Checkpoint: backup ===============
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Restore: CONFIG_MBEDTLS_THREADING_C: True
    Restore: CONFIG_MBEDTLS_THREADING_ALT: False
    =========== End psa_crypto_config ===============
    =========== Generating psa_crypto_library_config ===============
    Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: False
    Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: False
    Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    =========== End psa_crypto_library_config ===============
    CMake Warning at /opt/nordic/ncs/v3.1.1/nrf/subsys/net/lib/mqtt_helper/CMakeLists.txt:11 (message):
      Credentials are exposed in non-secure memory.  This should be avoided in
      production.
    CMake Warning at /opt/nordic/ncs/v3.1.1/zephyr/CMakeLists.txt:1027 (message):
      No SOURCES given to Zephyr library:
      ..__nrf__subsys__net__lib__tls_credentials
      Excluding target from build.
    -- Configuring done
    -- Generating done
    -- Configuring done
    -- Generating done
    -- Zephyr version: 4.1.99 (/opt/nordic/ncs/v3.1.1/zephyr), build: ncs-v3.1.1
    [9/190] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, [9/190] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-si[11/190] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c,[13/190] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-s[17/190] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.1.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort[18/190] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.1.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_no_mu[28/190] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.1.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort[30/190] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.1.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_no_mu[101/190] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/opt/nordic/ncs/v3.1.1/bootloader/mcuboot/boot/b[102/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[104/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[105/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[106/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[106/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[107/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[108/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[109/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[110/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[111/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[112/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[115/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[118/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[162/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[176/190] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/opt/nordic/ncs/v3.1.1/bootloader/mcuboot/boot/b[179/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[180/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[182/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[183/190] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[190/190] Linking C executable zephyr/zephyr.elf
               FLASH:       29312 B        48 KB     59.64%
                 RAM:         16 KB        88 KB     18.18%
      production.
    -- Configuring done
    -- Generating done
    [1/465] Preparing syscall dependency handling
    [5/465] Generating include/generated/zephyr/version.h
    [7/465] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, [7/465] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-si[9/465] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, [10/465] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-s[12/465] Generating ../../tfm/CMakeCache.txt
    -- Found Git: /opt/nordic/ncs/toolchains/561dce9adf/bin/git (found version "2.37.3")
    -- Configuring done
    -- Generating done
    [17/465] Performing build step for 'tfm'
    [0/198] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/protected_storage/auto_generated/load_info_tfm_pr[0/198] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/internal_trusted_storage/auto_generated/load_info[12/198] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/protected_storage/auto_generated/load_info_tfm_p[13/198] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/internal_trusted_storage/auto_generated/load_inf[25/198] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_cry[26/198] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/protected_storage/auto_generated/load_i[27/198] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/internal_trusted_storage/auto_generated[28/198] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_p[40/198] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/protected_storage/auto_generated/load_i[41/198] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_p[42/198] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/internal_trusted_storage/auto_generated[42/198] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/platform/ext/common/tfm_hal_sp_logdev_periph[45/198] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_cry[50/198] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sp_log.dir/__/__/__/__/platform/ext/common/tfm_hal_sp_logdev_peri[55/198] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/platform/ext/common/tfm_hal_sp_logdev_periph[58/198] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sp_log.dir/__/__/__/__/platform/ext/common/tfm_hal_sp_logdev_peri[64/198] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/generated/secure_fw/partitions/c[65/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v[66/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[67/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[68/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[69/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[70/198] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/generated/secure_fw/partitions/c[70/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[71/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[72/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[73/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[74/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[75/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[76/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[76/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_mute[77/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[77/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_even[78/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[78/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/psa_core.dir/opt/nordic/ncs/v3[79/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/psa_core.dir/opt/nordic/ncs/v3[80/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_mute[80/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...eFiles/psa_core.dir/opt/nordic/ncs/v3.1[81/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[81/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...es/psa_core.dir/opt/nordic/ncs/v3.1.1/m[82/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v[82/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...re.dir/opt/nordic/ncs/v3.1.1/modules/cr[83/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[83/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...s/psa_core.dir/opt/nordic/ncs/v3.1.1/mo[84/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[84/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...eFiles/psa_core.dir/opt/nordic/ncs/v3.1[85/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[85/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe..._driver.dir/opt/nordic/ncs/v3.1.1/modul[86/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_even[86/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...psa_driver.dir/opt/nordic/ncs/v3.1.1/mo[87/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/psa_core.dir/opt/nordic/ncs/v3[87/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...sa_driver.dir/opt/nordic/ncs/v3.1.1/mod[88/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...es/psa_core.dir/opt/nordic/ncs/v3.1.1/m[88/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe..._driver.dir/opt/nordic/ncs/v3.1.1/modul[89/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...eFiles/psa_core.dir/opt/nordic/ncs/v3.1[89/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...sa_driver.dir/opt/nordic/ncs/v3.1.1/mod[90/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...psa_driver.dir/opt/nordic/ncs/v3.1.1/mo[90/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe..._driver.dir/opt/nordic/ncs/v3.1.1/modul[91/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe..._driver.dir/opt/nordic/ncs/v3.1.1/modul[91/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe..._psa_driver.dir/opt/nordic/ncs/v3.1.1/m[92/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...sa_driver.dir/opt/nordic/ncs/v3.1.1/mod[92/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe..._psa_driver.dir/opt/nordic/ncs/v3.1.1/m[93/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe..._driver.dir/opt/nordic/ncs/v3.1.1/modul[93/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...driver.dir/opt/nordic/ncs/v3.1.1/module[94/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...s/psa_core.dir/opt/nordic/ncs/v3.1.1/mo[94/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...psa_driver.dir/opt/nordic/ncs/v3.1.1/mo[95/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe....dir/opt/nordic/ncs/v3.1.1/modules/cryp[96/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...sa_driver.dir/opt/nordic/ncs/v3.1.1/mod[96/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe..._psa_driver.dir/opt/nordic/ncs/v3.1.1/m[97/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe..._psa_driver.dir/opt/nordic/ncs/v3.1.1/m[97/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...a_driver.dir/opt/nordic/ncs/v3.1.1/modu[98/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modu[98/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...pt/nordic/ncs/v3.1.1/modules/crypto/obe[99/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...re.dir/opt/nordic/ncs/v3.1.1/modules/cr[99/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...psa_driver.dir/opt/nordic/ncs/v3.1.1/mo[100/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_ob..._driver.dir/opt/nordic/ncs/v3.1.1/modul[100/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_ob.../opt/nordic/ncs/v3.1.1/modules/crypto/o[101/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_ob...psa_driver.dir/opt/nordic/ncs/v3.1.1/mo[102/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_ob...driver.dir/opt/nordic/ncs/v3.1.1/module[103/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_ob...pt/nordic/ncs/v3.1.1/modules/crypto/obe[104/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_ob....dir/opt/nordic/ncs/v3.1.1/modules/cryp[105/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_ob...psa_driver.dir/opt/nordic/ncs/v3.1.1/mo[106/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_ob.../opt/nordic/ncs/v3.1.1/modules/crypto/o[107/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_ob...a_driver.dir/opt/nordic/ncs/v3.1.1/modu[108/198] Building C object secure_fw/partitions/protected_storage/CMakeFiles/tfm_app_rot_partitio...generated/secure_fw/partitions/protecte[110/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/mod[110/198] Building C object secure_fw/partitions/protected_storage/CMakeFiles/tfm_app_rot_partitio...ure_fw/partitions/internal_trusted_stor[111/198] Building C object secure_fw/partitions/protected_storage/CMakeFiles/tfm_app_rot_partition_ps.dir/__/__/__/generated/secure_fw/part[112/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_ob..._psa_driver.dir/opt/nordic/ncs/v3.1.1/m[112/198] Building C object secure_fw/partitions/protected_storage/CMakeFiles/tfm_app_rot_partitio.../generated/secure_fw/partitions/protect[113/198] Building C object secure_fw/partitions/protected_storage/CMakeFiles/tfm_app_rot_partitio...generated/secure_fw/partitions/protecte[113/198] Building C object secure_fw/partitions/protected_storage/CMakeFiles/tfm_app_rot_partition_ps.dir/__/__/__/platform/ext/common/sysc[114/198] Building C object secure_fw/partitions/protected_storage/CMakeFiles/tfm_app_rot_partition_ps.dir/__/__/__/generated/secure_fw/part[115/198] Building C object secure_fw/partitions/protected_storage/CMakeFiles/tfm_app_rot_partition_ps.dir/__/ns_agent_tz/load_info_ns_agent[117/198] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/tfm_internal_trusted_stor[119/198] Building C object secure_fw/partitions/protected_storage/CMakeFiles/tfm_app_rot_partition_ps.dir/__/__/__/platform/ext/common/sysc[120/198] Building C object secure_fw/partitions/protected_storage/CMakeFiles/tfm_app_rot_partitio...ure_fw/partitions/internal_trusted_stor[121/198] Building C object secure_fw/partitions/protected_storage/CMakeFiles/tfm_app_rot_partition_ps.dir/__/ns_agent_tz/load_info_ns_agent[123/198] Building C object secure_fw/partitions/protected_storage/CMakeFiles/tfm_app_rot_partition_ps.dir/__/__/__/generated/secure_fw/part[124/198] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/flash_fs/its_flash_fs_dbl[125/198] Building C object secure_fw/partitions/protected_storage/CMakeFiles/tfm_app_rot_partitio.../generated/secure_fw/partitions/protect[125/198] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/flash_fs/its_flash_fs_mbl[126/198] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/__/__/__/platform/ext/com[127/198] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_p...re_fw/partitions/internal_trusted_stora[128/198] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_p...re_fw/partitions/internal_trusted_stora[129/198] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/__/__/__/platform/ext/com[129/198] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/generated/secure_fw/partiti[130/198] Building C object secure_fw/partitions/protected_storage/CMakeFiles/tfm_app_rot_partition_ps.dir/__/__/__/generated/secure_fw/part[130/198] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/platform/ext/common/syscall[131/198] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/tfm_internal_trusted_stor[131/198] Building C object platform/CMakeFiles/platform_crypto_keys.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/com[135/198] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/flash_fs/its_flash_fs_dbl[136/198] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/generated/secure_fw/partiti[137/198] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/platform/ext/common/syscall[144/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_ob..._psa_driver.dir/opt/nordic/ncs/v3.1.1/m[145/198] Building C object platform/CMakeFiles/platform_crypto_keys.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/com[145/198] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/dummy_[146/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_obero...eFiles/psa_core.dir/opt/nordic/ncs/v3.1[146/198] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/tfm_ha[147/198] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/assert[148/198] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/dummy_[148/198] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/tfm_ha[151/198] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/ns_fau[152/198] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/assert[152/198] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/src/tfm_platf[153/198] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/src/tfm_ioctl[154/198] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/tfm_ha[155/198] Building C object secure_fw/partitions/internal_trusted_storage/CMakeFiles/tfm_psa_rot_partition_its.dir/flash_fs/its_flash_fs_mbl[161/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/mod[173/198] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/tfm_ha[175/198] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/src/tfm_ioctl[176/198] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/common/ns_fau[177/198] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.1.1/nrf/modules/trusted-firmware-m/tfm_boards/src/tfm_platf[178/198] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/psa_core.dir/opt/nordic/ncs/v[194/198] Linking C executable bin/tfm_s.axf
               FLASH:      195520 B     261632 B     74.73%
                 RAM:       59704 B        88 KB     66.26%
    [198/198] Linking C static library secure_fw/libtfm_s_veneers.a
    [19/465] Performing install step for 'tfm'
    [20/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/d[20/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[20/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/n[20/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[20/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[20/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[20/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[20/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[20/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[20/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[20/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[20/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[20/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[20/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[21/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/d[21/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[22/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[22/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[23/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/n[24/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[24/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[25/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[25/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[26/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[26/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[27/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[27/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[28/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[28/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[29/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[29/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[30/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[30/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[31/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[32/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[32/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[33/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[33/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[34/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[34/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[35/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[35/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[36/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[36/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-psa-cry[37/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[37/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[38/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[38/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[39/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[39/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[40/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[40/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[41/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[41/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[42/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-psa-cry[42/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[43/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[43/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[44/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[44/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[45/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[45/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[46/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[46/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[47/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[47/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[48/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[48/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[49/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[49/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[50/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[50/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[51/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[51/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[52/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[52/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[53/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[53/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[54/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[54/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[55/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[55/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[56/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[56/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[57/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[58/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[59/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[60/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[60/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[61/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[62/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[62/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/[63/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/[64/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[64/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/[65/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[65/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/[66/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/[66/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/[67/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[67/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/[68/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[68/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/[69/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[69/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/[70/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/[70/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[71/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/[71/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[72/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/[72/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-ps[73/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[73/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[74/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[74/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[75/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[76/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[76/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[77/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[77/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[78/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/[78/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-ps[79/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/[79/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[80/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[80/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[81/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-ps[81/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[82/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[83/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[84/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/s[85/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[86/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/[87/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[88/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[89/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[90/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/oberon-ps[92/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/librar[95/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[96/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/l[98/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/library/[105/465] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mbedtls/[138/465] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mb[152/465] Building C object modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/opt/nordic/ncs/v3.1.1/modules/crypto/mb[157/465] Building C object modules/nrf/subsys/net/lib/downloader/CMakeFiles/..__nrf__subsys__net__lib__downloader.dir/src/transports/http.c[158/465] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/fota_downlo[160/465] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/util/fota_d[161/465] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/util/fota_d[162/465] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/util/fota_d[164/465] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/util/fota_d[167/465] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/util/fota_d[167/465] Building C object modules/nrf/subsys/dfu/dfu_target/CMakeFiles/..__nrf__subsys__dfu__dfu_target.dir/src/dfu_target_modem_delta.c.o[172/465] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/util/fota_d[176/465] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/opt/nordic/ncs/v3.1.1/bootloader/mcuboot/boot/b[189/465] Building C object modules/nrf/subsys/dfu/dfu_target/CMakeFiles/..__nrf__subsys__dfu__dfu_target.dir/src/dfu_target_modem_delta.c.o[190/465] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[193/465] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[193/465] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[194/465] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[196/465] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[197/465] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[198/465] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[198/465] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[200/465] Building C object modules/nrf/subsys/net/lib/downloader/CMakeFiles/..__nrf__subsys__net__lib__downloader.dir/src/transports/http.c[200/465] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[201/465] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[202/465] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[202/465] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[204/465] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[206/465] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[207/465] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[209/465] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[217/465] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/opt/nordic/ncs/v3.1.1/bootloader/mcuboot/boot/b[229/465] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[235/465] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/fota_downlo[251/465] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.1.1/module[292/465] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.1.1/nrf/subsys/partition_manager/flash_map_partition_manager.c.ob[304/465] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.1.1/nrf/subsys/partition_manager/flash_map_partition_manager.c.ob[460/465] Linking C executable zephyr/zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /Users/gildev/Downloads/aws_iot_raw/build_devkit/aws_iot_raw/zephyr/zephyr_pre0.map
    : && ccache /opt/nordic/ncs/toolchains/561dce9adf/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc  -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  tfm/api_ns/interface/lib/s_veneers.o  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/Users/gildev/Downloads/aws_iot_raw/build_devkit/aws_iot_raw/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a  zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a  zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a  zephyr/lib/libc/picolibc/liblib__libc__picolibc.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/lib/posix/options/liblib__posix__options.a  zephyr/lib/net_buf/liblib__net_buf.a  zephyr/lib/os/zvfs/liblib__os__zvfs.a  zephyr/soc/soc/nrf9160/libsoc__nordic.a  zephyr/boards/nordic/nrf9160dk/libboards__nordic__nrf9160dk.a  zephyr/subsys/fs/libsubsys__fs.a  zephyr/subsys/random/libsubsys__random.a  zephyr/subsys/dfu/boot/libsubsys__dfu__boot.a  zephyr/subsys/net/libsubsys__net.a  zephyr/subsys/net/l2/offloaded_netdev/libsubsys__net__l2__offloaded_netdev.a  zephyr/subsys/net/ip/libsubsys__net__ip.a  zephyr/subsys/net/lib/mqtt/libsubsys__net__lib__mqtt.a  zephyr/subsys/net/lib/http/libsubsys__net__lib__http.a  zephyr/subsys/net/conn_mgr/libsubsys__net__conn_mgr.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/entropy/libdrivers__entropy.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/hwinfo/libdrivers__hwinfo.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/nrf_modem_lib/lib..__nrf__lib__nrf_modem_lib.a  modules/nrf/lib/at_monitor/lib..__nrf__lib__at_monitor.a  modules/nrf/lib/at_host/lib..__nrf__lib__at_host.a  modules/nrf/lib/at_parser/lib..__nrf__lib__at_parser.a  modules/nrf/lib/lte_link_control/lib..__nrf__lib__lte_link_control.a  modules/nrf/lib/modem_info/lib..__nrf__lib__modem_info.a  modules/nrf/lib/pdn/lib..__nrf__lib__pdn.a  modules/nrf/lib/hw_id/lib..__nrf__lib__hw_id.a  modules/nrf/lib/modem_antenna/lib..__nrf__lib__modem_antenna.a  modules/nrf/subsys/nrf_security/src/zephyr/libmbedtls_zephyr.a  modules/nrf/subsys/net/lib/aws_jobs/lib..__nrf__subsys__net__lib__aws_jobs.a  modules/nrf/subsys/net/lib/aws_fota/lib..__nrf__subsys__net__lib__aws_fota.a  modules/nrf/subsys/net/lib/aws_iot/lib..__nrf__subsys__net__lib__aws_iot.a  modules/nrf/subsys/net/lib/downloader/lib..__nrf__subsys__net__lib__downloader.a  modules/nrf/subsys/net/lib/fota_download/lib..__nrf__subsys__net__lib__fota_download.a  modules/nrf/subsys/net/lib/mqtt_helper/lib..__nrf__subsys__net__lib__mqtt_helper.a  modules/nrf/subsys/dfu/dfu_target/lib..__nrf__subsys__dfu__dfu_target.a  modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a  modules/nrf/modules/trusted-firmware-m/lib..__nrf__modules__trusted-firmware-m.a  modules/nrf/modules/trusted-firmware-m/libtfm_api_nrf.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  modules/trusted-firmware-m/libtfm_api.a  modules/cjson/libcjson.a  modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  /opt/nordic/ncs/v3.1.1/nrfxlib/nrf_modem/lib/cellular/nrf9160/soft-float/libmodem.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L/Users/gildev/Downloads/aws_iot_raw/build_devkit/aws_iot_raw/zephyr  modules/nrf/subsys/nrf_security/src/libmbedtls.a  modules/nrf/subsys/nrf_security/src/libmbedx509.a  modules/nrf/subsys/nrf_security/src/libmbedcrypto.a  modules/nrf/subsys/nrf_security/src/libmbedcrypto_base.a  modules/nrf/subsys/nrf_security/src/libnrf_security_utils.a  zephyr/kernel/libkernel.a  /opt/nordic/ncs/v3.1.1/nrfxlib/crypto/nrf_oberon/lib/cortex-m33/soft-float/liboberon_mbedtls_3.0.17.a  /opt/nordic/ncs/v3.1.1/nrfxlib/crypto/nrf_oberon/lib/cortex-m33/soft-float/liboberon_3.0.17.a  zephyr/arch/common/libisr_tables.a  -mcpu=cortex-m33  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -mtp=soft  -fuse-ld=bfd  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie  -specs=picolibc.specs  -DPICOLIBC_LONG_LONG_PRINTF_SCANF -L"/opt/nordic/ncs/toolchains/561dce9adf/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v8-m.main/nofp" -lc -lgcc && cd /Users/gildev/Downloads/aws_iot_raw/build_devkit/aws_iot_raw/zephyr && /opt/nordic/ncs/toolchains/561dce9adf/Cellar/cmake/3.21.0/bin/cmake -E true
    /opt/nordic/ncs/toolchains/561dce9adf/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/zephyr_pre0.elf section `text' will not fit in region `FLASH'
    /opt/nordic/ncs/toolchains/561dce9adf/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: region `FLASH' overflowed by 159716 bytes
    collect2: error: ld returned 1 exit status
    [14/20] cd /Users/gildev/Downloads/aws_iot_raw/build_devkit/_sysbuild && /opt/nordic/ncs/toolchains/561dce9adf/Cellar/cmake/3.21.0/bin/cmake -E true
    FAILED: _sysbuild/sysbuild/images/aws_iot_raw-prefix/src/aws_iot_raw-stamp/aws_iot_raw-build /Users/gildev/Downloads/aws_iot_raw/build_devkit/_sysbuild/sysbuild/images/aws_iot_raw-prefix/src/aws_iot_raw-stamp/aws_iot_raw-build
    cd /Users/gildev/Downloads/aws_iot_raw/build_devkit/aws_iot_raw && /opt/nordic/ncs/toolchains/561dce9adf/Cellar/cmake/3.21.0/bin/cmake --build .
    FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/561dce9adf/bin/cmake --build /Users/gildev/Downloads/aws_iot_raw/build_devkit
     *  The terminal process terminated with exit code: 1.
    Do you please know how to make it work? I feel like combining those two samples would allow me to connect to AWS through MbedTLS with the modem, making it then easier to add Ethernet with the same MbedTLS stack.
  • You may want to run Memory report on both samples to check what is taking a large amount of space in both of them.
    Security code may take up a big amount of space for example.
    Michal
