Inconsistent RESETREAS Values on nRF52832 for Power on reset, Brown-Out, and Wake-from-System-OFF (GPIO)
I am working on an nRF52832 using nRF5 SDK 16.0 and I am seeing inconsistent behaviour in the RESETREAS register. During a power-on reset, the value is usually 0 but occasionally appears as 4, so I am unsure whether 0 is the correct indication for a true POR. Software resets consistently show 4, which seems correct.
I also see an issue when the device wakes from System OFF. I put the device into deep sleep using sd_power_system_off(), and it wakes through a GPIO interrupt. However, instead of the expected 0x10000 (GPIO wake-up), the RESETREAS register still reports 4, as if it were a software reset. I would also like to understand whether the nRF DFU bootloader reads, clears, or modifies the RESETREAS register before my application starts.
After checking similar issues on the forum, I found suggestions to clear the reset reason register. But when I tested nrf_power_resetreas_clear(), calling it immediately triggers a software reset. I am not sure whether this behaviour is expected or if there are specific constraints when clearing the register.
I would appreciate guidance on how to reliably detect a true power-on reset or brown-out, why System OFF wake-ups appear as software resets, and whether the DFU bootloader affects RESETREAS behaviour.
Thanks & Regards,
Albin Mathew
