SPI00 of nrf54l15 not working
Hello team,
I am using SPI00 of NRF54L15 to communicate with w25q32fv (spi Flash). I am using a custom board. Below is the configuration I set in .overlay file
&pinctrl {
    spi00_default: spi00_default {
        group1 {
            psels = <NRF_PSEL(SPIM_SCK, 2, 1)>,
                    <NRF_PSEL(SPIM_MOSI, 2, 2)>,
                    <NRF_PSEL(SPIM_MISO, 2, 4)>;
    spi00_sleep: spi00_sleep {
        group1 {
            low-power-enable;
&spi00 {
	status = "okay";
    pinctrl-0 = <&spi00_default>;
    pinctrl-1 = <&spi00_sleep>;
	cs-gpios = <&gpio2 5 GPIO_ACTIVE_LOW>;
	w25q32fv: w25q32fv@0 {
		compatible = "jedec,spi-nor";
		reg = <0>;
		spi-max-frequency = <8000000>;
		label = "W25Q32FV";
		status = "okay";
		jedec-id = [ef 40 16];   /* optional but helpful */
		size = <0x400000>;       /* 4 MByte = 32 Mbit */
And below is the code I am using to read the ID of the flash
void data_write_spi()
    if (!device_is_ready(spi_dev)) {
        printf("SPI device not ready");
        return;
    uint8_t cmd[4];
    uint8_t rx[5];
    cmd[0] = 0x9F;
    struct spi_buf tx_bufs = {.buf = cmd, .len = 1};
    struct spi_buf rx_bufs = {.buf = rx, .len = 5};
    struct spi_buf_set tx = {.buffers = &tx_bufs, .count = 1};
    struct spi_buf_set rx_set = {.buffers = &rx_bufs, .count = 1};
    k_msleep(5);
    int ret = spi_transceive(spi_dev, &spi_cfg, &tx, &rx_set);
    if (ret == 0) {
        printf("JEDEC ID: %02X %02X %02X %02x %02x", rx[0], rx[1], rx[2], rx[3], rx[4]);
    } else {
        printf("SPI transfer failed: %d", ret);
I am getting the following error.
SPI transfer failed: -5
How can I fix this issue so I can use spi00 appropriately? Any help would be greatly appreciated.
Payal
  • Hi Payal,
    It is not easy for me to narrow down to the actual issue for an external sensor outside our solution. But the common issues with connecting with a sensor using SPI are to set the polarity right (CPOL and CPHA) that matches the specification of the sensor you are trying to communicate to. The other one is to set the pull of the pins correctly if the slave sensor needs the pull to be high or low.
    Also check using logic analyzer or oscilloscope connected to MOSI and MISO to see if you see any valid traffic at all.
