nRF5340 problems setting up XIP split + b0 + b0n + mcuboot + TF-M
I am currently struggling with setup and configuration of firmware for nRF5340. The idea is to use two stage bootloader setup, XIP split to external flash and build NS with TF-M.
Unfortunately I am unable to make this exact configuration to work. As a base for exploration and reproduction of the issue I used tfm_psa_template sample (as it was the only sample I found most closely demonstrating my setup).
I first did some minor changes for me to help me out:
- Removed APPROTECT to make stuff easier to debug (SB_CONFIG_APPROTECT_LOCK=n and SB_CONFIG_SECURE_APPROTECT_LOCK=n)
- Removed initial attestation from sample as it is not in my interest yet (comment out CONFIG_TFM_PARTITION_INITIAL_ATTESTATION and CONFIG_TFM_ATTEST_VERIFICATION_SERVICE_URL from prj.conf, and commented out related code in main.c - include file, get_attestation_token function and its call inside main)
After those initial changes I tested it on nRF5340dk and confirmed that everything still works as intended
On UART logs we can observe that we correctly went b0-mcuboot-application:
*** Using Zephyr OS v4.1.99-1f51b946c59e ***
Attempting to boot slot 0.
Attempting to boot from address 0x8200.
I: Trying to get Firmware version
I: Verifying signature against key 0.
I: Hash: 0xc2...c5
I: Firmware signature verified.
Firmware version 1
I: Setting monotonic counter (version: 1, slot: 0)
�*** Booting My Application v2.1.0-dev-9b4ae4cbc9e2 ***
*** Using nRF Connect SDK v3.1.1-c7b597ab943c ***
I: Starting bootloader
I: Image index: 0, Swap type: none
I: Image index: 1, Swap type: none
I: Image index: 2, Swap type: none
I: Bootloader chainload address offset: 0x20000
I: Image version: v0.0.0
�*** Booting nRF Connect SDK v3.1.1-c7b597ab943c ***
build time: Dec 11 2025 07:23:34
FW info S0:
Magic: 0x281ee6de8fcebb4c00003502
Total Size: 140
Version: 1
Address: 0x00008200
Boot address: 0x00008200
Valid: 0x9102ffff (CONFIG_FW_INFO_VALID_VAL=0x9102ffff)
FW info S1:
Total Size: 140
Version: 1
Address: 0x00014200
Boot address: 0x00014200
Active slot: S0
Then I added XIP split to sample and it breaks. I did following further changes:
- Added SB_CONFIG_QSPI_XIP_SPLIT_IMAGE=y to sysbuild.conf
- Added following lines to CMakeLists.txt to relocate something to external flash
zephyr_code_relocate(LIBRARY mbedtls_zephyr LOCATION EXTFLASH_TEXT NOCOPY)
zephyr_code_relocate(LIBRARY mbedtls_zephyr LOCATION EXTFLASH_RODATA NOCOPY)
- Added following pm_static.yml file to have split partition on external flash defined correctly
mcuboot_secondary:
  address: 0x0
  device: DT_CHOSEN(nordic_pm_ext_flash)
  end_address: 0xd4000
  region: external_flash
mcuboot_secondary_1:
  address: 0xd4000
  end_address: 0x114000
external_flash:
  address: 0x114000
  end_address: 0x800000
mcuboot_primary_2:
  address: 0x114000
  end_address: 0x214000
  orig_span: &id003
  - mcuboot_primary_2_pad
  - mcuboot_primary_2_app
  span: *id003
mcuboot_primary_2_pad:
  address: 0x114000
  end_address: 0x114200
mcuboot_primary_2_app:
  address: 0x114200
mcuboot_secondary_2:
  address: 0x214000
  end_address: 0x314000
With those changes in place, I no longer get into application code as bootloader no longer recognizes bootable image:
I: Hash: 0x43...c9
Firmware version 1
I: Image index: 3, Swap type: none
E: Unable to find bootable image
Please help me making this setup work
Regards!
