nrf54 SDK connect: can't wake uart, shell when using pm_device_action_run(uart, PM_DEVICE_ACTION_RESUME);
using nrf connect SDK v3.1.1
using nrf54L15 development board.
I have been trying to return set uart in low power mode and resume uart low power from a button press.
I have a working project that doesn't so much, I have set up the CLI shell using the standard uart20 as designed with this  dev board.
my objective was trying to get to low power modes when suspending uart, on button wake uart and continue the shell CLI.
this doesn't work as expected with pm_device_action_run API.
const struct device *uart = DEVICE_DT_GET(DT_NODELABEL(uart20));
pm_device_action_run(uart, PM_DEVICE_ACTION_SUSPEND);
void uart_enable(bool is_enable)
    if(is_enable == false)
static int shell_disable(const struct shell *shell, size_t argc, char **argv)
    //uart_enable_cmd = 0; // disable
    //Timer_start(my_tmr, 7000, &uart_enable_cmd);
     uart_enable(false); // disable uart
    return 0;
SHELL_STATIC_SUBCMD_SET_CREATE(sleep_cmds,
    SHELL_CMD(shell_disable, NULL, "Disable shell ", shell_disable),
    SHELL_SUBCMD_SET_END
SHELL_CMD_REGISTER(uart, &sleep_cmds, "Sleep commands", NULL);
also have a standard gpio callback that works fine (low power), and calls this uart_enable(true) to re- enable the uart.
also ran these pieces of code thru k_work_schedule, not to run in ISR context, or not in a "shell command context"
to prove that it is not a context issue.
with
pm_device_action_run(uart, PM_DEVICE_ACTION_SUSPEND); i do observe that current goes to the expected 2.9uA, put i can't get shell to wake and start again.
a solution was to replace the pm_device_action_run commands with
pm_device_runtime_get /
pm_device_runtime_put /
pm_device_runtime_enable
here is my proj.conf
CONFIG_PM_DEVICE=y
CONFIG_PM_DEVICE_RUNTIME=y
#CONFIG_NRFX_UARTE20=y
#CONFIG_PINCTRL=y
#CONFIG_PINCTRL_NRF=y
#CONFIG_PINCTRL_DYNAMIC=y
# Shell
CONFIG_SHELL=y
CONFIG_SHELL_BACKEND_SERIAL=y
CONFIG_UART_CONSOLE=y
# Logging
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=2
CONFIG_LOG_MODE_MINIMAL=n
#CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_RUNTIME_FILTERING=y              # adds ability to change log levels at runtime
#CONFIG_LOG_MODE_IMMEDIATE=y
CONFIG_LOG_CMDS=y                           # shell commands
CONFIG_LOG_PRINTK=y
why is this?
thanks
Dan
