TF-M without UART
I'm working on nRF9151 on custom board, NCS 3.1.0 and I'm building application with TF-M enabled.
I've encountered quite a strange problem. If I remove all UART instances (mainly UART0) mcu becomes secured after jumping to application. I can neither connect with RTT nor flash it without calling nrfjprog recovery. If I flash it, and connect with RTT immediately, while program is still in mcuboot/tf-m I can connect. But if I disconnect I cannot connect anymore, device is secured.
For now I found that I need UART0 defined and enabled (okay) in device tree and CONFIG_SERIAL=y set in prj.conf. If any is missing, cpu secures itself after starting app.
My board do not have any uart interface and unfortunately I need all 4 SPI/I2C/UART instances so I have to disable UART0 at some point.
I have CONFIG_TFM_LOG_LEVEL_SILENCE=y set in prj.conf which should disable any tf-m logging, but problem is still there.
Not sure if that changes anything but I have also CONFIG_TFM_PROFILE_TYPE_NOT_SET=y and CONFIG_TFM_PROFILE_TYPE_MINIMAL=n as I need various operations provided by tf-m.
Am I missing some configuration?
Thanks for help
Tomasz
  • Hi Tomasz,
    Can you please try with CONFIG_TFM_SECURE_UART=n ? It should already be at "n" as you enabled CONFIG_TFM_LOG_LEVEL_SILENCE, but we never know.
    If it doesn't work, what NCS SDK version are you using ?
    Can you maybe share some files from your project (devicetree/kconfig/...) ?
    Simon D-M
    At some point I've already tried with CONFIG_TFM_SECURE_UART without any effect.
    I'm using NCS 3.1.0
    I can provide tommorow some cleaned up files from devicetre and prj.conf
    Device tree have SPI0, I2C1, SPI2 and SPI3 configured with corresponding pins. Uart is nowhere mentioned, standard includes (as in most examples) are used.
    Part of prj.conf:
    CONFIG_SERIAL=n
    CONFIG_LOG=y
    CONFIG_CONSOLE=y
    CONFIG_RTT_CONSOLE=y
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_EXTENDED_LOGS=y
    CONFIG_NRF_SECURITY=y
    CONFIG_MBEDTLS_PSA_CRYPTO_C=y
    CONFIG_PSA_CRYPTO_DRIVER_OBERON=y # Fallback to Oberon if CC3XX fails
    CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y
    CONFIG_PSA_WANT_ALG_ECB_NO_PADDING=y
    CONFIG_PSA_WANT_ALG_SHA_256=y
    CONFIG_NRF_SECURITY_ADVANCED=y
    CONFIG_NORDIC_SECURITY_BACKEND=y
    Rest are config options for network, modem, spi, i2c...
    defconfig file:
    # Copyright (c) 2024 Nordic Semiconductor ASA
    # Enable MPU
    CONFIG_ARM_MPU=y
    # Enable TrustZone-M
    CONFIG_ARM_TRUSTZONE_M=y
    # Enable GPIO and PINCTRL
    CONFIG_GPIO=y
    CONFIG_PINCTRL=y
    CONFIG_PINCTRL_DYNAMIC=y
    # External Flash
    CONFIG_SPI=y
    CONFIG_SPI_NOR=y
    CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    CONFIG_FLASH_JESD216_API=y
    ns_defconfig file:
    # Enable MPU
    CONFIG_ARM_MPU=y
    # Generate TF-M image
    CONFIG_BUILD_WITH_TFM=y
    CONFIG_TFM_CMAKE_BUILD_TYPE_MINSIZEREL=y
    # This Board implies building Non-Secure firmware
    CONFIG_TRUSTED_EXECUTION_NONSECURE=y
    CONFIG_GPIO=y
    CONFIG_PINCTRL=y
    # External Flash
    CONFIG_SPI=y
    CONFIG_SPI_NOR=y
    Hope that helps at least something. If not, we can always convert ticket to privet and then I can share whole files.
    Best regards
    Tomasz
  • hmmm,
    Maybe I'm incorrectly assuming that it's tf-m fault.
    Looks like somethink is doing: "there is no standard debug uart, therfore this must be release build, I will enable readback protection".
    I have also mcuboot there, maybe it's or app itself is behaving that way?
    Is there such option maybe?
    Before searching more in depth, I found this erratum [Debug and Trace: Access port gets locked in WFI and WFE] which sounds a bit like your issue. It basically is that the access port gets locked after the device went to idle.
    Can you please try the suggested workaround and tell me if it helped?
    Simon D-M
  • I don't want to jinx it, but seems like it's working.
    I had to call it as early as possible doing in main.c:
    int const_lat(void)
        NRF_POWER->TASKS_CONSTLAT = 1; // Enable constant latency mode
        return 0;
    SYS_INIT(const_lat, EARLY, 0);
    For debug purposes I think it should be enough.
    Thank you for your help, haven't thought of checking errata, as it looked like some configuration issue. I guess uart was keeping clock active.
    Thanks again
    Tomasz
