Problem with zephyr build blinkly on nrf52840_dongle
Dear Nordic Community,
I want to build samples/basic/blinkly on nordic nrf52840_dongle inside my Zephyr workspace. I use Zephyr 4.2.0, but on Zephyr 4.3.0 I have similar problems. Output of `west build -b nrf52840dongle zephyr/samples/basic/blinky`
-- Application: /home/a.paleczny/zephyrproject/zephyr/samples/basic/blinky
-- CMake version: 3.28.1
-- Found Python3: /home/a.paleczny/zephyrproject/.venv/bin/python3 (found suitable version "3.12.3", minimum required is "3.10") found components: Interpreter
-- Cache files will be written to: /home/a.paleczny/.cache/zephyr
-- Zephyr version: 4.2.0 (/home/a.paleczny/zephyrproject/zephyr)
-- Found west (found suitable version "1.5.0", minimum required is "0.14.0")
-- Board: nrf52840dongle, qualifiers: nrf52840
-- ZEPHYR_TOOLCHAIN_VARIANT not set, trying to locate Zephyr SDK
-- Found host-tools: zephyr 0.17.4 (/home/a.paleczny/zephyr-sdk-0.17.4)
-- Found toolchain: zephyr 0.17.4 (/home/a.paleczny/zephyr-sdk-0.17.4)
-- Found Dtc: /home/a.paleczny/zephyr-sdk-0.17.4/sysroots/x86_64-pokysdk-linux/usr/bin/dtc (found suitable version "1.7.0", minimum required is "1.4.6")
-- Found BOARD.dts: /home/a.paleczny/zephyrproject/zephyr/boards/nordic/nrf52840dongle/nrf52840dongle_nrf52840.dts
-- Generated zephyr.dts: /home/a.paleczny/zephyrproject/build/zephyr/zephyr.dts
-- Generated pickled edt: /home/a.paleczny/zephyrproject/build/zephyr/edt.pickle
-- Generated devicetree_generated.h: /home/a.paleczny/zephyrproject/build/zephyr/include/generated/zephyr/devicetree_generated.h
warning: HAS_NORDIC_DRIVERS (defined at modules/hal_nordic/Kconfig:7) has direct dependencies 0 with value n, but is currently being y-selected by the following symbols:
 - SOC_SERIES_NRF52X (defined at soc/nordic/Kconfig.soc:30, soc/nordic/nrf52/Kconfig.soc:6, soc/nordic/nrf52/Kconfig:6), with value y, direct dependencies y (value: y), and select condition SOC_FAMILY_NORDIC_NRF (value: y)
warning: HAS_NRFX (defined at modules/hal_nordic/nrfx/Kconfig:4) has direct dependencies 0 with value n, but is currently being y-selected by the following symbols:
warning: NRFX_CLOCK (defined at modules/hal_nordic/nrfx/Kconfig:16) has direct dependencies HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols:
 - CLOCK_CONTROL_NRF (defined at drivers/clock_control/Kconfig.nrf:13), with value y, direct dependencies DT_HAS_NORDIC_NRF_CLOCK_ENABLED && CLOCK_CONTROL (value: y), and select condition !CLOCK_CONTROL_NRF_FORCE_ALT && DT_HAS_NORDIC_NRF_CLOCK_ENABLED && CLOCK_CONTROL (value: y)
warning: NRFX_GPIOTE0 (defined at modules/hal_nordic/nrfx/Kconfig:199) has direct dependencies HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols:
 - GPIO_NRFX (defined at drivers/gpio/Kconfig.nrfx:4), with value y, direct dependencies DT_HAS_NORDIC_NRF_GPIO_ENABLED && GPIO (value: y), and select condition HAS_HW_NRF_GPIOTE0 && DT_HAS_NORDIC_NRF_GPIO_ENABLED && GPIO (value: y)
warning: NRFX_POWER (defined at modules/hal_nordic/nrfx/Kconfig:296) has direct dependencies HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols:
 - USB_NRFX (defined at drivers/usb/device/Kconfig:108), with value y, direct dependencies DT_HAS_NORDIC_NRF_USBD_ENABLED && USB_DEVICE_DRIVER (value: y), and select condition DT_HAS_NORDIC_NRF_USBD_ENABLED && USB_DEVICE_DRIVER (value: y)
warning: NRFX_GPPI (defined at modules/hal_nordic/nrfx/Kconfig:237) has direct dependencies HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols:
 - UART_0_ENHANCED_POLL_OUT (defined at drivers/serial/Kconfig.nrfx_uart_instance:21), with value y, direct dependencies !n && HAS_HW_NRF_UARTE0 && (HAS_HW_NRF_PPI || HAS_HW_NRF_DPPIC) && (HAS_HW_NRF_UART0 || HAS_HW_NRF_UARTE0) && UART_NRFX && SERIAL (value: y), and select condition !n && HAS_HW_NRF_UARTE0 && (HAS_HW_NRF_PPI || HAS_HW_NRF_DPPIC) && (HAS_HW_NRF_UART0 || HAS_HW_NRF_UARTE0) && UART_NRFX && SERIAL (value: y)
warning: NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED (defined at modules/hal_nordic/nrfx/Kconfig:22) has direct dependencies NRFX_CLOCK && HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols:
 - CLOCK_CONTROL_NRF_K32SRC_XTAL (defined at drivers/clock_control/Kconfig.nrf:41), with value y, direct dependencies <choice CLOCK_CONTROL_NRF_SOURCE> (value: y), and select condition !SOC_SERIES_BSIM_NRFXX && !CLOCK_CONTROL_NRF_FORCE_ALT && <choice CLOCK_CONTROL_NRF_SOURCE> (value: y)
warning: NRFX_CLOCK_LF_SRC_XTAL (defined at modules/hal_nordic/nrfx/Kconfig:31) has direct dependencies NRFX_CLOCK && HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols:
 - CLOCK_CONTROL_NRF_K32SRC_XTAL (defined at drivers/clock_control/Kconfig.nrf:41), with value y, direct dependencies <choice CLOCK_CONTROL_NRF_SOURCE> (value: y), and select condition !CLOCK_CONTROL_NRF_FORCE_ALT && <choice CLOCK_CONTROL_NRF_SOURCE> (value: y)
error: Aborting due to Kconfig warnings
Parsing /home/a.paleczny/zephyrproject/zephyr/Kconfig
Loaded configuration '/home/a.paleczny/zephyrproject/zephyr/boards/nordic/nrf52840dongle/nrf52840dongle_nrf52840_defconfig'
Merged configuration '/home/a.paleczny/zephyrproject/zephyr/samples/basic/blinky/prj.conf'
CMake Error at /home/a.paleczny/zephyrproject/zephyr/cmake/modules/kconfig.cmake:389 (message):
  command failed with return code: 1
  /home/a.paleczny/zephyrproject/zephyr/cmake/modules/zephyr_default.cmake:131 (include)
  /home/a.paleczny/zephyrproject/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
  /home/a.paleczny/zephyrproject/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  CMakeLists.txt:4 (find_package)
What is wrong and what can I change?
