nRF54L15 + MCUboot + mx25r64 with SQSPI : Failed to open flash area on mx25r64.
Hello
I  tried to test OTA function with smp_svr example.
I want to use the external flash mx25r64 on nrf54l15-dk(v0.9.3) to store update Firmware over BLE.  SDK version 3.2.0 was used.
The driver and dts for mcuboot was configured with "sysbuild\mcuboot.conf", "sysbuild\mcuboot.overlay".
partitions manager was used with "pm_static.yml".
Before mcuboot start, mspi and flash driver was loaded correctly.
Then mcuboot to read seconed image slot on external flash failed. could you give some advice for this issue?
The source code is attached below.
2046.smp_svr.zip
  • Hi Max,
    Thanks for the report. I haven't managed to figure out what could be wrong here.
    In theory it should work in MCUBoot the same as in application but it seems not. I have forwarded your question internally but due to holiday session I haven't got the reply yet.
    Please try adding SB_CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y to the sysbuild.conf file. This should enable the bootloader to access the secondary slot using the MSPI NOR driver without the -ENOENT error.
    Vidar
    Thanks for quick help.
    This configuration has indeed taken the program one step forward, but the image check reports a new "slot sectors" error.
    Are there any other configuration items related to partition?
    partition manager file was attached below.
    pm_static.yaml
    app:
      address: 0x20800
      end_address: 0x163000
      region: flash_primary
    bootconf:
      address: 0xffd080
      end_address: 0xffd084
      region: bootconf
    littlefs_storage:
      address: 0x143000
      device: DT_CHOSEN(nordic_pm_ext_flash)
      end_address: 0x800000
      placement:
        before:
        - end
      region: external_flash
    settings_storage:
      address: 0x163000
      end_address: 0x165000
      placement:
        align:
          start: 0x1000
    mcuboot:
      address: 0x0
      end_address: 0x20000
      placement:
        align:
          end: 0x1000
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0x20000
      end_address: 0x20800
      placement:
        align:
          start: 0x1000
        before:
        - mcuboot_primary_app
    mcuboot_primary:
      address: 0x20000
      orig_span: &id001
      - mcuboot_pad
      - app
      span: *id001
    mcuboot_primary_app:
      address: 0x20800
      orig_span: &id002
      - app
      span: *id002
    mcuboot_secondary:
      address: 0x000000
      end_address: 0x143000
      placement:
        align:
          start: 0x4
      share_size:
      - mcuboot_primary
    otp:
      address: 0xffd500
      end_address: 0xffd9fc
      region: otp
    sram_primary:
      address: 0x20000000
      end_address: 0x2003c000
      region: sram_primary
    Please also add CONFIG_FLASH_MSPI_NOR_LAYOUT_PAGE_SIZE=4096 to your mcuboot and application project configuration to ensure the sector size matches the sector size used in internal memory.
  • Thanks for your help.
    when CONFIG_FLASH_MSPI_NOR_LAYOUT_PAGE_SIZE=4096 was added to mcuboot and app configuration, mcuboot stop at "I: Jumping to the first image slot".
    Does it means image in slot-0 is invalid when image magic is bad checked by mcuboot.
    Is there any other configuration for image need to be set?
