Button causes repeated interrupt callback
I'm trying to make the basic Button sample work but am having problems.
The physical button is a latching button. Press it and it moves in with a click and physically stays there. Press again and with a click, the latch releases and the button pops out.
This is the button:
Button in "out" state
Out state
Button in "in" state
In state
In terms of code, what happens is this: When I press the button in, I don't think a callback is received. When it is released to its "out" position, the button's interrupt callback function is repeatedly called, over and over again, and its state is always 1. I never see a state of 0 which is why I assume there's no callback when the button is put into its "in" state.
Here's a video:
And here's the code:
Shows how to control a push button with built-in LED like this one:
https://thepihut.com/products/16mm-illuminated-pushbutton-green-latching-on-off-switch?variant=27739372497
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/sys/util.h>
#include <inttypes.h>
#define SLEEP_TIME_MS	1000
#define START_STOP_BTN_NODE	DT_ALIAS(btnpin)
/* Check if the node is valid before proceeding */
#if !DT_NODE_HAS_STATUS(START_STOP_BTN_NODE, okay)
#error "Start/Stop button pin devicetree node is disabled or not found"
#define START_STOP_LED_NODE	DT_ALIAS(btnled)
#if !DT_NODE_HAS_STATUS(START_STOP_LED_NODE, okay)
#error "Start/Stop LED devicetree node is disabled or not found"
static const struct gpio_dt_spec button = GPIO_DT_SPEC_GET_OR(START_STOP_BTN_NODE, gpios,
							      {0});
static struct gpio_callback button_cb_data;
static const struct gpio_dt_spec led = GPIO_DT_SPEC_GET_OR(START_STOP_LED_NODE, gpios,
							      {0});
void set_led() {
    int state = 1 - gpio_pin_get_dt(&button);
    printk("Setting LED state to %d\n",state);
    gpio_pin_set_dt(&led, state);
void button_pressed(const struct device *dev, struct gpio_callback *cb,
		    uint32_t pins)
    printk("Button! State=%d\n",gpio_pin_get_dt(&button));
	printk("Button pressed at %" PRIu32 "\n", k_cycle_get_32());
    // set_led();
    printk("button test v20\n");
	int ret;
	if (!gpio_is_ready_dt(&button)) {
		printk("Error: button device %s is not ready\n",
		       button.port->name);
		return 0;
    printk("Button is ready \n");
	ret = gpio_pin_configure_dt(&button, GPIO_INPUT);
	if (ret != 0) {
		printk("Error %d: failed to configure %s pin %d\n",
		       ret, button.port->name, button.pin);
		return 0;
    printk("Button configured for input\n");
    if (!gpio_is_ready_dt(&led)) {
        printk("Error: LED device %s is not ready\n",
                led.port->name);
        return 0;
    printk("LED is ready \n");
	ret = gpio_pin_configure_dt(&led, GPIO_OUTPUT);
	if (ret != 0) {
		       ret, led.port->name, led.pin);
		return 0;
    printk("LED configured for output \n");
    // set_led();
	ret = gpio_pin_interrupt_configure_dt(&button,
					      GPIO_INT_EDGE_TO_ACTIVE);
	if (ret != 0) {
		printk("Error %d: failed to configure interrupt on %s pin %d\n",
		return 0;
    printk("Button attached to interrupt\n");
	gpio_init_callback(&button_cb_data, button_pressed, BIT(button.pin));
	gpio_add_callback(button.port, &button_cb_data);
	printk("Set up button at %s pin %d\n", button.port->name, button.pin);
	printk("Press the button\n");
	return 0;
Overlay with DTS definitions for the button and its integral LED as follows:
    /* Define a new node within the root of the devicetree */
    custom_gpios {
        /* Use the generic 'gpio-leds' compatible binding */
        compatible = "gpio-leds";
        /* Define a button node with a unique label 'start_stop_btn' */
        start_stop_btn: start_stop_gpio_connector {
             * 'gpios' property is a phandle-array that takes:
             * 1. Phandle to the GPIO controller (&gpio0 refers to the node with label 'gpio0')
             * 2. The pin number (e.g., 13)
             * 3. The flags (e.g., GPIO_ACTIVE_LOW for an active-low LED)
            gpios = <&gpio0 6 GPIO_ACTIVE_LOW>;
            label = "Start/stop button";
        /* Define an LED node with a unique label 'btn_led' */
        start_stop_led: btn_led_gpio_connector {
            gpios = <&gpio0 8 GPIO_ACTIVE_LOW>;
            label = "Button LED";
    /* Add an alias for easy access in application code */
    aliases {
        btnpin = &start_stop_btn;
        btnled = &start_stop_led;
I assume the issue is that this is a latching button rather than a simple momentary push button but I'm not sure how to handle this in code.
Advice and guidance appreciated as always :-)
Update
Tested with various GPIO interrupt flag combinations with the following results:
    // Button Out: repeated callbacks. Button In: no callback. State=1
	// ret = gpio_pin_interrupt_configure_dt(&button,
	// 				      GPIO_INT_EDGE_TO_ACTIVE);
    // Button Out: repeated callbacks. Button In: no callback. State=0
	// 				      GPIO_INT_LEVEL_INACTIVE|GPIO_INT_LEVEL_ACTIVE);
	// 				      GPIO_INT_EDGE_RISING);
					      GPIO_INT_EDGE_FALLING);
    // Button Out: repeated callbacks. Button In: no callback. State=1 and 0 alternating i.e. 2 callbacks each time button released to OUT state.
	// 				      GPIO_INT_EDGE_BOTH);
    // Button Out: repeated callbacks with state=0. Button In: callback with state 1.
					      GPIO_INT_LEVEL_LOW|GPIO_INT_LEVEL_HIGH);
  • I initially tested with a battery and breadboard and it seemed fine. I'm going to double check that though now that you've mentioned it.
  • Good news. It's working :-)
    The full story:
    Tested again with breadboard and battery just to be sure, this time with an LED connected into the switch circuit. It works fine. Note that the LED embedded within the switch is permanently powered in the test circuit and so is always on. The external LED is in a circuit which is switched by the button and behaves as expected.
    My logic analyzer triggers successfully on rising edge. So I tried the button configured in code with
    (which I thought I'd already tested, according to comments in my code!)
    And waddayouknow, it works. Not sure why I thought this wasn't working before (or in fact why it *wasn't* working!).
    *** Booting nRF Connect SDK v3.1.1-e2a97fe2578a ***
    *** Using Zephyr OS v4.1.99-ff8f0c579eeb ***
    button test v35
    Button is ready
    LED is ready
    Set up button at gpio@50000000 pin 6
    Press the button
    Button state=1
    Button pressed at 125004
    Button state=0
    Button pressed at 212011
    Note that I still have pullup specified in the DTS so this might also be significant.
    gpios = <&gpio0 6 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
    Thanks for the support, both technical and moral!
