I am encountering a strange hardware/software mapping issue with the SAADC on an nRF52833 DK running on Zephyr (NCS). Using VS Code nRF Toolchain and SDK (V3.2)
The issue is a persistent mismatch between the configured SAADC input and the actual physical pin being read.
The Problem: We are explicitly configuring the SAADC to sample from P0.04 (AIN2). However, our observations suggest that the ADC is physically sampling P0.05 (AIN3) instead.
When we apply a signal to P0.04, the ADC reads 0 or noise.
When we apply a signal to P0.05, the ADC (configured for P0.04) reacts and reads the values.
Troubleshooting Steps Taken: To rule out any persistent register settings, board-level caching, or corruption:
We performed a complete factory reset
We re-flashed the firmware from a clean build state (pristine build).
Despite these steps, the crossover/mismatch issue persists.
Code Configuration: We are bypassing the Devicetree macros for the channel configuration to ensure direct control. Here is the configuration struct we are using:
static const struct adc_channel_cfg channel_cfg = {
.channel_id = 0,
.gain = ADC_GAIN_1_6,
.reference = ADC_REF_INTERNAL,
.acquisition_time = ADC_ACQ_TIME_DEFAULT,
.input_positive = NRF_SAADC_INPUT_AIN2, // Intending to read P0.04
My Questions:
Is there any known errata or internal routing conflict on the nRF52 series that could cause
NRF_SAADC_INPUT_AIN2to be internally routed to or shorted with theAIN3(P0.05) line? -
Since a full chip recover/erase did not solve the issue, could this indicate a damaged internal mux on the chip, or is there a hidden default state in the Zephyr board definition files that might override our manual C-struct configuration?
We need to confirm if this is a hardware defect or a lower-level software mapping anomaly.
