If you have tested the nRF9151's GPS with the CMW100 or IQ station. We need to know:
1. What test waveform file is required?
2. Should we use the ARB file or the CW waveform?
I tested by setting the instrument output power to -130 dBm, with the external LNA turned on and an attenuator added, adjusting the output power to -150 dBm. However, the CN0 value remains very low, reaching a maximum of only 25, and it still fluctuates, sometimes dropping to 0.
Thanks for your response. Your case is being discussed internally by relevant team and will be responded very soon.
Best Regards,
Syed Maysum
Thank you for the additional details. Based on our internal review of the test results, the observed behavior is consistent with the characteristics of the GNSS ARB waveform. The example ARB files typically contain a single GPS signal. At -130 dBm, the nRF9151 correctly tracks SV1 with CN0 around 38-42 dB-Hz, which is expected and indicates normal GNSS operation.
The tracking loss after ~2 minutes likely coincides with the rapid adjustment of the signal level to -150 dBm. Sudden power changes during tracking can cause temporary loss of lock. The signal is later reacquired with CN0 again above ~38 dBHz, confirming proper receiver behavior when the signal level is stable.
The additional fluctuating CN0 values (0-25 dBHz) correspond to acquisition attempts for other satellites rather than stable tracked signals. With ARB playback, these acquisition artifacts can be more visible, especially if there is some noise in the waveform or reflections in the conducted RF setup. In controlled GNSS simulator configurations generating a single GPS signal (like in single channel simulator mode), this effect is typically less pronounced.
We recommend keeping the signal level stable during measurement and ensuring the RF path is clean.
Best Regards,
Syed Maysum
