Control opening or closing with Button 2 and 3 for Matter Closure sample
It was possible to activate the Window covering sample to control opening or closing with nRF5340-DK Button 2 and 3.
Button 1:
Depending on how long you press the button:
  • If pressed for less than three seconds:
    • If the device is not provisioned to the Matter network, it initiates the SMP server (Simple Management Protocol) and Bluetooth LE advertising for Matter commissioning. After that, the Device Firmware Update (DFU) over Bluetooth Low Energy can be started. (See Upgrading the device firmware.) Bluetooth LE advertising makes the device discoverable over Bluetooth LE for the predefined period of time (1 hour by default).
    • If the device is already provisioned to the Matter network, it re-enables the SMP server. After that, the DFU over Bluetooth Low Energy can be started. (See Upgrading the device firmware.)
  • If pressed for more than three seconds, it initiates the factory reset of the device. Releasing the button within a 3-second window of the initiation cancels the factory reset procedure.
Button 2:
When pressed once and released, it moves the window cover towards the open position by one step. Depending on the movement mode of the cover (see Overview), the button decreases the brightness of either LED 2 for the lift mode or LED 3 for the tilt mode.
Button 3:
When pressed once and released, it moves the cover towards the closed position by one step. Depending on the movement mode of the cover (see Overview), the button increases the brightness of either LED 2 for the lift mode or LED 3 for the tilt mode.
Is it not possible to do the same with the Closure sample?
With the closure sample, only button 1 is used.
Regards
